04-System Management
HomeSupportReference GuidesMIB CompanionH3C MSR Router Series MIB Reference-R6749-6W10004-System Management
09-HH3C-TRAP-MIB
09-HH3C-TRAP-MIB 62.65 KB
HH3C-TRAP-MIB
About this MIB
Use this MIB to enable the device to send a notification to a network management station when a specific event occurs, such as a MAC address table getting full.
MIB file name
hh3c-trap.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cTrap(38)
Tabular objects
hh3cTrapDesInfoTable
About this table
Use this table to configure a trap destination host address and port number.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cTrapDesInfoIndex.
Object (OID)
Access
Value range
Implementation
hh3cTrapDesInfoIndex (1.3.6.1.4.1.25506.2.38.1.7.1.1.1)
not-accessible
Integer32
Integer32 (1..20)
Index nodes of a trap destination information entry.
As per the MIB.
hh3cTrapDesIPAddress (1.3.6.1.4.1.25506.2.38.1.7.1.1.2)
read-create
IpAddress
Standard MIB values
Trap destination host IP address.
As per the MIB.
hh3cTrapDesPort (1.3.6.1.4.1.25506.2.38.1.7.1.1.3)
read-create
Integer32
Integer32 (0..65535)
Trap destination port number.
As per the MIB.
hh3cTrapDesRowStatus (1.3.6.1.4.1.25506.2.38.1.7.1.1.4)
read-create
RowStatus
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6)
Row status.
Supports only active(1), createAndGo(4), and destroy(6).
hh3cTrapDesAddrTAddress (1.3.6.1.4.1.25506.2.38.1.7.1.1.5)
read-create
TAddress
Standard MIB values
Transport address.
As per the MIB.
Notifications
This section contains the HH3C-TRAP-MIB notifications.
hh3cRtTabFullTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.38.1.3.5.1
Routing table full
Informational
Major
N/A
ON
Notification triggers
This notification is generated when the number of routes in the routing table for the public network exceeds the upper limit.
System impact
New entries cannot be added to the routing table for the public network, and traffic interruption might occur.
Status control
This notification cannot be disabled.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.38.1.3.4.1 (hh3cRtTabLen)
Length of the routing table.
N/A
Integer32
Standard MIB values.
Recommended action
1.     Use the display ip routing-table summary command to check the values for the Max Active Route and Remain Active Route fields to identify whether the number of routes for the public network has reached the upper limit.
2.     Use the display ip routing-table statistics command to identify whether the number of routes for each protocol is as expected.
¡     If the numbers are as expected, use the ip public-instance command to enter public instance view and change the maximum number of active IPv4/IPv6 routes supported by the device to a larger value.
¡     If the numbers are not as expected, change the route settings for the target protocols as needed and then perform step 1 again. For more information about how to change the route settings for the target protocols, see the related protocol configuration guide.
3.     If the issue persists, collect configuration file, log, and alarm information, and contact H3C Support.
