04-System Management
HomeSupportReference GuidesMIB CompanionH3C MSR Router Series MIB Reference-R6749-6W10004-System Management
07-HH3C-POWER-ETH-EXT-MIB
07-HH3C-POWER-ETH-EXT-MIB 78.60 KB
About this MIB
This MIB is an extension of POWER-ETHERNET-MIB. To implement this MIB, you must first implement relevant parts of POWER-ETHERNET-MIB, such as pethMainPseTable.
This MIB adds some objects which POWER-ETHERNET-MIB does not contain to monitor some specific aspects of entities for better and comprehensive management on devices.
MIB file name
hh3c-power-eth-ext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cPowerEthernetExt(14)
Scalar objects
hh3cPsePolicyMode (1.3.6.1.4.1.25506.2.14.9)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
disabled(1), priority(2)
PSE power management policy mode.
As per the MIB.
hh3cPDPolicyMode (1.3.6.1.4.1.25506.2.14.10)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
PD power management policy mode.
As per the MIB.
Tabular objects
hh3cPsePortTable
About this table
Use this table to manage PSE ports.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are pethPsePortGroupIndex and pethPsePortIndex.
Object (OID)
Access
Value range
Implementation
hh3cPsePortPeakPower (1.3.6.1.4.1.25506.2.14.1.1.3)
read-write
Integer32
Standard MIB values.
Peak power of the PSE port, in milliwatts.
As per the MIB.
You can set the value to 0. Other values are not effective.
hh3cPsePortAveragePower (1.3.6.1.4.1.25506.2.14.1.1.4)
read-write
Integer32
Average power of the PSE port, in milliwatts.
As per the MIB.
hh3cPsePortCurrentPower (1.3.6.1.4.1.25506.2.14.1.1.5)
read-only
Integer32
Current power of the PSE port, in milliwatts.
As per the MIB.
hh3cPsePortPowerLimit (1.3.6.1.4.1.25506.2.14.1.1.6)
read-write
Integer32
Power limit for the PSE port, in milliwatts.
As per the MIB.
hh3cPsePortProfileIndex (1.3.6.1.4.1.25506.2.14.1.1.7)
read-write
Integer32
Integer32 (0..100)
Index of the power profile currently associated with this port.
As per the MIB.
hh3cMainPseTable
About this table
Use this table to manage PSEs.
This table is not supported on non-default MDCs.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is pethPsePortGroupIndex.
Object (OID)
Access
Value range
Implementation
hh3cMainPsePowerLimit (1.3.6.1.4.1.25506.2.14.2.1.1)
read-write
Integer32
Power limit for the PSE, in watts.
As per the MIB.
hh3cMainPseAveragePower (1.3.6.1.4.1.25506.2.14.2.1.2)
read-write
Integer32
Average power of the PSE, in watts.
As per the MIB.
hh3cMainPsePeakPower (1.3.6.1.4.1.25506.2.14.2.1.3)
read-write
Integer32
Peak power of the PSE, in watts.
As per the MIB.
hh3cMainGuaranteedPowerRemaining (1.3.6.1.4.1.25506.2.14.2.1.4)
read-only
Integer32
Remaining guaranteed power of the PSE, in watts.
As per the MIB.
hh3cMainPseLegacy (1.3.6.1.4.1.25506.2.14.2.1.6)
read-write
INTEGER
enable(0), disable(1)
Standard or nonstandard PD detection mode.
As per the MIB.
hh3cMainPsePowerPriority (1.3.6.1.4.1.25506.2.14.2.1.7)
read-write
INTEGER
critical(1), high(2), low(3)
Priority of the PSE.
As per the MIB.
hh3cPseProfilesTable
About this table
Use this table to manage power profiles.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is hh3cPseProfileIndex.
Object (OID)
Access
Value range
Implementation
hh3cPseProfileIndex (1.3.6.1.4.1.25506.2.14.7.1.1)
not-accessible
Integer32
Integer32 (1..100)
Profile index.
As per the MIB.
hh3cPseProfileName (1.3.6.1.4.1.25506.2.14.7.1.2)
read-create
DisplayString
OCTET STRING (1..15)
Profile name.
As per the MIB.
hh3cPseProfilePowerMode (1.3.6.1.4.1.25506.2.14.7.1.3)
read-create
INTEGER
powerDisabled(1), powerEnabled(2)
Power mode.
As per the MIB.
hh3cPseProfilePowerLimit (1.3.6.1.4.1.25506.2.14.7.1.4)
read-create
Integer32
Power limit, in milliwatts.
As per the MIB.
hh3cPseProfilePriority (1.3.6.1.4.1.25506.2.14.7.1.5)
read-create
INTEGER
Port priority.
As per the MIB.
hh3cPseProfilePairs (1.3.6.1.4.1.25506.2.14.7.1.6)
read-create
INTEGER
signal(1), spare(2)
Pairs in use.
As per the MIB.
hh3cPseProfileApplyNum (1.3.6.1.4.1.25506.2.14.7.1.7)
read-only
Integer32
Number of this profile being applied.
As per the MIB.
hh3cPseProfileRowStatus (1.3.6.1.4.1.25506.2.14.7.1.8)
read-create
RowStatus
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6)
Row status.
Supports only active, createAndGo, and destory.
This row cannot be deleted when the value of the hh3cPseProfileApplyNum is 0.
Notifications
hh3cpsePDChangeNotification
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.14.6.1
PD connection status changed
Informational
Warning
N/A
ON
Notification triggers
This notification is generated when a PD is connected or disconnected.
System impact
No negative impact on the system.
Status control
ON
MIB: Set pethNotificationControlEnable to true(1).
OFF
MIB: Set pethNotificationControlEnable to false(2).
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.105.1.1.1.6 (pethPsePortDetectionStatus)
PD detection status of the PSE port.
pethPsePortIndex
INTEGER
disabled(1), searching(2), deliveringPower(3), fault(4), test(5), otherFault(6)
Recommended action
Check the PD connection and make sure the PD is connected correctly.
No action is required if the PD is disconnected or connected on purpose.
