05-HH3C-INFOCENTER-MIB | 131.58 KB |
hh3cICMaxLogbufferSize (1.3.6.1.4.1.25506.2.119.1.1.1)
hh3cICLogbufferSize (1.3.6.1.4.1.25506.2.119.1.1.2)
hh3cICLogbufferCurrentMessages (1.3.6.1.4.1.25506.2.119.1.1.3)
hh3cICLogbufferOverwrittenMessages (1.3.6.1.4.1.25506.2.119.1.1.4)
hh3cICLogbufferDroppedMessages (1.3.6.1.4.1.25506.2.119.1.1.5)
hh3cICMaxLoghost (1.3.6.1.4.1.25506.2.119.2.1.1)
hh3cICLoghostSourceInterface (1.3.6.1.4.1.25506.2.119.2.1.2)
hh3cICLoghostTimestampType (1.3.6.1.4.1.25506.2.119.2.1.3)
hh3cICLogGlobalState (1.3.6.1.4.1.25506.2.119.5.1.1)
hh3cICLogTimestampType (1.3.6.1.4.1.25506.2.119.5.1.2)
HH3C-INFOCENTER-MIB
About this MIB
Use this MIB to configure information center settings, including enabling the information center or configuring log buffers and log hosts. You can access this MIB to obtain information about log entries in the log buffer.
MIB file name
hh3c-infocenter.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cInfoCenter(119)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICMaxLogbufferSize (1.3.6.1.4.1.25506.2.119.1.1.1) |
read-only |
Unsigned32 |
Standard MIB values. |
Maximum number of log entries that can be buffered. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogbufferSize (1.3.6.1.4.1.25506.2.119.1.1.2) |
read-write |
Unsigned32 |
Current buffer size. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogbufferCurrentMessages (1.3.6.1.4.1.25506.2.119.1.1.3) |
read-only |
Unsigned32 |
Number of messages stored in the log buffer. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogbufferOverwrittenMessages (1.3.6.1.4.1.25506.2.119.1.1.4) |
read-only |
Counter32 |
Number of overwritten messages in the log buffer. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogbufferDroppedMessages (1.3.6.1.4.1.25506.2.119.1.1.5) |
read-only |
Counter32 |
Number of dropped messages in the log buffer. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICMaxLoghost (1.3.6.1.4.1.25506.2.119.2.1.1) |
read-only |
Unsigned32 |
Maximum number of log hosts supported by the information center. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLoghostSourceInterface (1.3.6.1.4.1.25506.2.119.2.1.2) |
read-write |
InterfaceIndexOrZero |
Source interface through which log messages are sent to log hosts. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLoghostTimestampType (1.3.6.1.4.1.25506.2.119.2.1.3) |
read-write |
ICTimeStampType |
date(0), boot(1), iso(2), dateWithoutYear(3), none(4), isoWithTimezone(5), dataWithMilliseconds(6), isoWithMilliseconds(7), isoWithMillisecondsAndTimezone(8) |
Timestamp format for logs sent to log hosts. |
Does not support boot(1). Does not support boot(1), isoWithTimezone(5), dataWithMilliseconds(6), isoWithMilliseconds(7), or isoWithMillisecondsAndTimezone(8). Does not support boot(1) or isoWithTimezone(5). |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogGlobalState (1.3.6.1.4.1.25506.2.119.5.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Selects whether to enable the information center globally. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogTimestampType (1.3.6.1.4.1.25506.2.119.5.1.2) |
read-write |
ICTimeStampType |
date(0), |
Timestamp format for log messages. |
Supports only boot, date, and none. |
Tabular objects
hh3cICLogbufferContTable
About this table
This table contains log buffer information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cICLogbufferContIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogbufferContIndex (1.3.6.1.4.1.25506.2.119.1.2.1.1) |
not-accessible |
Integer32 |
Integer32 (1..2147483647) |
Table index. |
As per the MIB. |
hh3cICLogbufferContDescription (1.3.6.1.4.1.25506.2.119.1.2.1.2) |
read-only |
DisplayString |
OCTET STRING (0..1600) |
Content of the log buffer. |
As per the MIB. |
hh3cICLoghostTable
About this table
This table specifies a log host and configures output parameters, including IP address of the log host, VPN instance, logging facility, port number of the log host, and log output destination. You can also access this table to obtain log host-related information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cICLoghostIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLoghostIndex (1.3.6.1.4.1.25506.2.119.2.2.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (1..64) |
Table index. |
As per the MIB. |
hh3cICLoghostIpaddressType (1.3.6.1.4.1.25506.2.119.2.2.1.2) |
read-create |
InetAddressType |
unknown(0), ipv4(1), ipv6(2), ipv4z(3), ipv6z(4), dns(16) |
Address type for the log host. |
As per the MIB. |
hh3cICLoghostIpaddress (1.3.6.1.4.1.25506.2.119.2.2.1.3) |
read-create |
InetAddress |
OCTET STRING (0..255) |
IP address of the log host. |
As per the MIB. |
hh3cICLoghostVPNName (1.3.6.1.4.1.25506.2.119.2.2.1.4) |
read-create |
DisplayString |
Name of the VPN instance to which the log host belongs. |
As per the MIB. |
hh3cICLoghostFacility (1.3.6.1.4.1.25506.2.119.2.2.1.5) |
read-create |
ICFacilityType |
kernel(0), userLevel(1), mailSystem(2), systemDaemons(3), securityAuthorization(4), internallyMessages(5), linePrinter(6), networkNews(7), uucp(8), clockDaemon(9), securityAuthorization2(10), ftpDaemon(11), ntp(12), logAudit(13), logAlert(14), clockDaemon2(15), local0(16), local1(17), local2(18), local3(19), local4(20), local5(21), local6(22), local7(23) |
Logging facility for marking different logging sources, and querying and filtering log messages. |
Supports only local0(0), local1(1), local2(2), local3(3), local4(4), local5(5), local6(6), and local7(7). |
hh3cICLoghostOperateRowStatus (1.3.6.1.4.1.25506.2.119.2.2.1.6) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
As per the MIB. |
hh3cICLoghostIpaddressPort (1.3.6.1.4.1.25506.2.119.2.2.1.7) |
read-create |
Unsigned32 |
Unsigned32 (1..65535) |
Port number of the log host. |
As per the MIB. |
hh3cICLoghostTAddress (1.3.6.1.4.1.25506.2.119.2.2.1.8) |
read-create |
TAddress |
OCTET STRING (1..255) |
Supports only IPv4 addresses. |
hh3cICDirectionTable
About this table
This table contains information about syslog output directions and specifies the enablement status of output directions.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is hh3cICDirectionIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICDirectionIndex (1.3.6.1.4.1.25506.2.119.3.1.1.1) |
not-accessible |
Unsigned32 |
Table index. |
As per the MIB. |
hh3cICDirectionName (1.3.6.1.4.1.25506.2.119.3.1.1.2) |
read-only |
DisplayString |
OCTET STRING (1..30) |
Name of a log output destination. |
As per the MIB. |
hh3cICDirectionState (1.3.6.1.4.1.25506.2.119.3.1.1.3) |
read-write |
TruthValue |
true(1), false(2) |
Status of the log output destination. |
Specifies whether to enable log output to the log buffer, log file, security log file, or diagnostic log file. Log output to other destinations than the above destinations are all enabled. |
hh3cICModuleTable
About this table
This table contains available source modules.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cICModuleName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICModuleName (1.3.6.1.4.1.25506.2.119.4.1.1.1) |
read-only |
DisplayString |
OCTET STRING (1..8) |
Name of a source module. |
As per the MIB. |
hh3cICLogTable
About this table
This table specifies the log level of log messages generated by a specific module to a specific output destination, and contains the log buffer information.
Create |
Edit/Modify |
Delete |
Read |
The module name in a row cannot contain lowercase letters and cannot be default |
A row with the source module named default cannot be deleted |
Supported |
Supported |
Columns
The table indexes are hh3cICDirectionIndex and hh3cICModuleName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogLevel (1.3.6.1.4.1.25506.2.119.5.2.1.1) |
read-create |
ICMessageLevelType |
emergency(0), |
Severity level of a log message. |
As per the MIB. |
hh3cICLogRowStatus (1.3.6.1.4.1.25506.2.119.5.2.1.2) |
read-create |
RowStatus |
active(1), |
Row status. |
As per the MIB. |
