01-Fundamentals Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath F1000[F5000] Firewalls Series Command Reference(V7)-6W90001-Fundamentals Command Reference
05-Device management commands
05-Device management commands 489.53 KB
Device management commands· 1
clock datetime· 1
clock protocol 2
clock summer-time· 3
clock timezone· 4
command· 5
copyright-info enable· 6
display alarm·· 7
display clock· 8
display copyright 9
display cpu-usage· 9
display cpu-usage configuration· 10
display cpu-usage history· 12
display device· 13
display device manuinfo· 15
display diagnostic-information· 15
display environment 17
display fan· 19
display memory· 20
display memory-threshold· 21
display power 22
display scheduler job· 24
display scheduler logfile· 24
display scheduler reboot 25
display scheduler schedule· 26
display system stable state· 27
display transceiver alarm·· 29
display transceiver diagnosis· 30
display transceiver interface· 31
display transceiver manuinfo· 32
display version· 33
display version-update-record· 34
display voltage· 35
header 36
job· 37
locator blink· 37
memory-threshold· 38
memory-threshold usage· 39
monitor cpu-usage enable· 40
monitor cpu-usage interval 41
monitor cpu-usage logging· 42
monitor cpu-usage statistics-interval core· 42
monitor cpu-usage threshold· 43
monitor cpu-usage threshold core· 44
monitor memory-usage logging· 45
monitor resend cpu-usage core-interval 46
monitor resource-usage { bridge-aggregation | route-aggregation } threshold· 47
monitor resource-usage bandwidth inbound threshold· 48
monitor resource-usage context threshold· 48
monitor resource-usage nat threshold· 49
monitor resource-usage security-policy threshold· 50
monitor resource-usage session-count threshold· 51
monitor resource-usage session-rate threshold· 51
password-recovery enable· 52
reboot 53
reset scheduler logfile· 54
reset version-update-record· 54
restore factory-default 55
scheduler job· 56
scheduler logfile size· 56
scheduler reboot at 57
scheduler reboot delay· 58
scheduler schedule· 59
shutdown-interval 60
sysid· 61
sysname· 61
temperature-limit 62
time at 63
time once· 64
time repeating· 65
usb disable· 67
user-role· 67
Non-default vSystems do not support some of the device management commands. For information about vSystem support for a command, see the usage guidelines on that command. For information about vSystem, see Virtual Technologies Configuration Guide.
clock datetime
Use clock datetime to set the system time.
clock datetime time date
The system time is Coordinated Universal Time (UTC) 00:00:00 01/01/2011.
time: Specifies a time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
date: Specifies a date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
CAUTION
CAUTION:
This command changes the system time of the device, which affects the execution of system time-related features (for example, scheduled tasks), and collaborative operations of the device with other devices (for example, log reporting and statistics collection). Make sure you understand its impact on the live network before executing this command.
This command is supported only on the default context.
Non-default vSystems do not support this command.
Correct system time is essential to network management and communication. You must configure the system time correctly before you run the device on the network.
For the device to use the local system time, execute the clock protocol none command and this command in turn. The specified system time takes effect immediately. Then, the device uses the clock signals generated by its built-in crystal oscillator to maintain the system time.
# Set the system time to 08:08:08 01/01/2015.
<Sysname> clock datetime 8:8:8 1/1/2015
# Set the system time to 08:10:00 01/01/2015.
<Sysname> clock datetime 8:10 2015/1/1
clock protocol
clock summer-time
clock timezone
display clock
clock protocol
Use clock protocol to specify the method for obtaining the system time.
Use undo clock protocol to use NTP to obtain the UTC time on the default context..
clock protocol { none |  ntp context context-id }
undo clock protocol
In a version earlier than RXX60, the device uses NTP to obtain the UTC time on the default context.
In RXX60 or later:
·     If the device starts up with factory defaults, it uses the system time set by using the clock datetime command.
·     If the device starts up with the initial configuration, it uses NTP to obtain the UTC time on the default context.
For more information about the factory defaults and initial configuration, see configuration file management in Fundamentals Configuration Guide.
none: Uses the system time set by using the clock datetime command.
ntp: Uses NTP to obtain the UTC time periodically. You must configure NTP correctly. For more information about NTP and NTP configuration, see Network Management and Monitoring Configuration Guide.
context context-id: Specifies a context. For more information about context and the value range for the context ID, see Virtual Technologies Command Reference.
·     If you use the clock protocol none command, you can use the clock datetime command to configure the system time. The device then uses the clock signals generated by its built-in crystal oscillator to maintain the system time.
·     If you use the clock protocol ntp command, the device obtains the UTC time through GNSS, NTP, or PTP periodically. After obtaining the UTC time, the device uses the UTC time, time zone, and daylight saving time to calculate the system time. If the GNSS, NTP, or PTP signals are lost, the device uses the clock signals generated by its built-in crystal oscillator to maintain the system time. After the GNSS, NTP, or PTP signals recover, the device obtains the UTC time again from the signals.
All contexts on the device use the same system time. After obtaining the system time from a context, the device automatically synchronizes the system time to the other contexts.
# Configure the device to use the local UTC time.
[Sysname] clock protocol none
clock summer-time
Use clock summer-time to set the daylight saving time.
Use undo clock summer-time to restore the default.
The daylight saving time is not set.
name: Specifies a name for the daylight saving time schedule, a case-sensitive string of 1 to 32 characters.
start-time: Specifies the start time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
start-date: Specifies the start date in one of the following formats:
·     MM/DD. The value range for MM is 1 to 12. The value range for DD varies by month.
·     month week day, where:
¡     month—Takes January, February, March, April, May, June, July, August, September, October, November or December.
¡     week—Represents week of the month. It takes first, second, third, fourth, fifth, or last.
¡     day—Takes Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, or Saturday.
end-time: Specifies the end time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
end-date: Specifies the end date in one of the following formats:
add-time: Specifies the time to be added to the standard time, in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
After you set the daylight saving time, the device recalculates the system time. To view the system time, use the display clock command.
Make sure all devices on the network are using the same daylight saving time as the local time.
# Set the system time ahead 1 hour for the period between 06:00:00 on 08/01 and 06:00:00 on 09/01.
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
clock datetime
clock timezone
display clock
clock timezone
Use clock timezone to set the time zone.
Use undo clock timezone to restore the default.
undo clock timezone
The UTC time zone is used.
zone-name: Specifies a time zone by its name, a case-sensitive string of 1 to 32 characters.
add: Adds an offset to the UTC time.
minus: Decreases the UTC time by an offset.
zone-offset: Specifies an offset to the UTC time, in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
After you set the time zone, the device recalculates the system time. To view the system time, use the display clock command.
Make sure all devices on the network are using the same time zone as the local time.
# Set the name of the time zone to Z5, and add 5 hours to the UTC time.
[Sysname] clock timezone Z5 add 5
clock datetime
clock summer-time
display clock
command
Use command to assign a command to a job.
Use undo command to revoke a command.
command id command
undo command id
No command is assigned to a job.
Job view
context-admin
id: Specifies an ID for the command, in the range of 0 to 4294967295. A command ID uniquely identifies a command in a job. Commands in a job are executed in ascending order of their command IDs.
command: Specifies the command to be assigned to the job.
To assign a command (command A) to a job, you must first assign the job the command or commands for entering the view of command A.
If you specify the ID of an existing command for another command, the existing command is replaced.
Make sure all commands in a schedule are compliant to the command syntax. The system does not examine the syntax when you assign a command to a job.
If a command requires a yes or no answer, the system always assumes that a Y or Yes is entered. If a command requires a character string input, the system assumes that either the default character string (if any) or a null string is entered.
A job cannot contain the telnet, ftp, ssh2, or monitor process command.
# Assign commands to the backupconfig job to back up the startup.cfg file to the TFTP server at 192.168.100.11.
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
# Assign commands to the shutdownGE job to shut down GigabitEthernet 1/0/1.
[Sysname] scheduler job shutdownGE
[Sysname-job-shutdownGE] command 1 system-view
[Sysname-job-shutdownGE] command 2 interface gigabitethernet 1/0/1
[Sysname-job-shutdownGE] command 3 shutdown
scheduler job
Use copyright-info enable to enable copyright statement display.
Use undo copyright-info enable to disable copyright statement display.
Copyright statement display is enabled.
context-admin
# Enable copyright statement display.
[Sysname] copyright-info enable
The device will display the following statement when a user logs in:
* Without the owner's prior written consent,                                 *
* no decompiling or reverse-engineering shall be allowed.                    *
display alarm
Use display alarm to display alarm information.
display alarm [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays alarm information for all IRF member devices.
# Display alarm information.
<Sysname> display alarm
Slot CPU Level   Info
1    0   ERROR   faulty
Slot
Slot that generated the alarm. If the alarm was generated by the frame, this field displays a hyphen (-).
Level
Alarm severity. Possible values include ERROR, WARNING, NOTICE, and INFO, in descending order.
Info
Detailed alarm information:
·     faulty—The slot is starting up or faulty.
·     Fan n is absent—The specified fan is absent.
·     Power n is absent—The specified power module is absent.
·     Power n is faulty—The specified power module is faulty.
·     The temperature of sensor n exceeds the lower limit—The temperature of the specified sensor is lower than the low-temperature threshold.
·     The temperature of sensor n exceeds the upper limit—The temperature of the specified sensor is higher than the high-temperature warning threshold.
display clock
Use display clock to display the system time, date, time zone, and daylight saving time.
display clock
context-admin
context-operator
# Display the system time and date when the time zone is not specified.
<Sysname> display clock
10:09:00.258 UTC Fri 03/16/2015
The time is in the hour:minute:second.milliseconds format.
# Display the system time and date when the time zone Z5 is specified.
15:10:00.152 Z5 Fri 03/16/2015
Time Zone : Z5 add 05:00:00
# Display the system time and date when the time zone Z5 and daylight saving time PDT are specified.
15:11:00.211 Z5 Fri 03/16/2015
clock datetime
clock timezone
clock summer-time
display copyright
Use display copyright to display the copyright statement.
display copyright
context-admin
context-operator
# Display the copyright statement.
<Sysname> display copyright
display cpu-usage
Use display cpu-usage to display the current CPU usage statistics.
display cpu-usage [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ]
display cpu-usage [ control-plane | data-plane ] [ summary ] [ slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
control-plane: Displays CPU usage statistics for the control plane. If you do not specify this keyword or the data-plane keyword, the command displays the total CPU usage statistics.
data-plane: Displays CPU usage statistics for the data plane. If you do not specify this keyword or the control-plane keyword, the command displays the total CPU usage statistics.
summary: Displays CPU usage statistics in table form. If you do not specify this keyword, the command displays CPU usage statistics in text form.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays CPU usage statistics for all member devices.
cpu cpu-number: Specifies a CPU by its number.
core { core-number | all }: Displays CPU core usage statistics. If you specify a CPU core by its number, this command displays usage statistics for the CPU core. If you specify the all keyword, this command displays average usage statistics for all CPU cores.
Executing this command on a context displays the current CPU usage statistics for the context.
If two hyphens (--) are displayed for the CPU usage during the most recent 5-second, 1-minute, and 5-minute intervals, the command might fail to obtain data from the database on the device. Try the command later.
# Display the current CPU usage statistics in text form.
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
       1% in last 5 seconds
       1% in last 1 minute
       1% in last 5 minutes
# Display the current CPU usage statistics in table form.
Slot CPU        Last 5 sec        Last 1 min        Last 5 min
1    0          17%               29%               28%
x% in last 5 seconds
Last 5 sec
Average CPU usage during the most recent 5-second interval.
y% in last 1 minute
Last 1 min
Average CPU usage during the most recent 1-minute interval.
z% in last 5 minutes
Last 5 min
Average CPU usage during the most recent 5-minute interval.
Use display cpu-usage configuration to display CPU usage monitoring settings.
context-admin
vsys-admin
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the CPU usage monitoring settings for the master device.
cpu cpu-number: Specifies a CPU by its number. If you do not specify a CPU, this command displays the CPU usage monitoring settings for all CPUs on the specified slot.
Executing this command on a context displays CPU usage monitoring settings for the context.
# Display the CPU usage monitoring settings.
<Sysname> display cpu-usage configuration slot 4
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current monitor threshold is 90%.
Current monitor recovery threshold is 40%.
Current statistics-interval is 90 seconds for the following cores: 0 to 31.
CPU usage monitor is xxx.
Whether CPU usage tracking is enabled.
Current monitor interval is xxx.
Sampling interval for CPU usage tracking.
Current monitor threshold is xxx.
CPU usage threshold.
Current monitor recovery threshold is xxx.
CPU usage recovery threshold.
Current statistics-interval is xxx seconds for the following cores
CPU core usage statistics interval.
Use display cpu-usage history to display the historical CPU usage statistics in a coordinate system.
context-admin
context-operator
job job-id: Specifies a process by its ID. The value range for job-id is 1 to 2147483647. If you do not specify a process, this command displays the statistics for the entire system's CPU usage (the total CPU usage of all processes). To view the IDs and names of the running processes, use the display process command. For more information, see Network Management and Monitoring Configuration Guide.
slot slot-number: Specifies an IRF member device by its member ID. If you specify a process but do not specify a member device, this command displays the statistics for the process on the master device. If you do not specify any options, this command displays the statistics for all processes on all member devices.
cpu cpu-number: Specifies a CPU by its number. If you specify a process but do not specify a CPU, this command displays the statistics for the default CPU. If you do not specify a process or CPU, this command displays the historical statistics for all CPUs.
After CPU usage monitoring is enabled, the system regularly samples CPU usage and saves the samples to the history record buffer. This command displays the most recent 60 samples in a coordinate system as follows:
The vertical axis represents the CPU usage. If a statistic is not a multiple of the usage step, it is rounded up or down to the closest multiple of the usage step. For example, if the CPU usage step is 5%, the statistic 53% is rounded up to 55%, and the statistic 52% is rounded down to 50%.
The horizontal axis represents the time.
Pound signs (#) indicate the CPU usage. The value on the vertical axis for the topmost pound sign at a specific time represents the CPU usage at that time.
Executing this command on a context displays the historical CPU usage statistics for the context.
# Display the historical CPU usage statistics.
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
The output shows the following items:
·     Process name. The name SYSTEM represents the entire system.
·     CPU that is holding the process: CPU 0 in slot 1.
·     Historical CPU usage statistics for the entire system during the last 60 minutes.
¡     12 minutes ago—Approximately 5%.
¡     13 minutes ago—Approximately 10%.
¡     14 minutes ago—Approximately 15%.
¡     15 minutes ago—Approximately 10%.
¡     16 and 17 minutes ago—Approximately 5%.
¡     18 minutes ago—Approximately 10%.
¡     19 minutes ago—Approximately 5%.
¡     Other time—2% or lower.
display device
Use display device to display device information.
display device [ harddisk | usb ] [ slot slot-number [ subslot subslot-number ] | verbose ]
context-admin
context-operator
harddisk: Displays hard disk information.
usb: Displays USB interface information.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information for all member devices.
subslot subslot-number: Specifies an interface module by the number of its slot marked on the device panel. If you do not specify an interface module, this command does not display information about interface modules.
verbose: Displays detailed information. If you do not specify this keyword, this command displays brief information, and does not display firewall card information.
If you do not specify the harddisk and usb keyword, this command displays information about member devices.
This command displays information about the physical device, whether you execute it on the default context or a non-default context.
# Display device information.
<Sysname> display device
Slot.No   Cpu.Id   Brd Type      Brd Status    Subslot    Sft Ver    Patch Ver
1         0        F5000-CN-G85  Normal        0          8190P01    None
1         0        NS-NIM-GT8B   Normal        1          None       None
1         0        NONE          Absent        2          None       None
Slot.No
Member device ID.
Cpu.Id
CPU ID.
Brd Type
Device model.
Brd Status
Status of the device in the IRF fabric:
·     Normal—The member device is operating correctly.
·     Fault—The member device is not operating correctly.
·     Absent—The member device is not present.
Sft Ver
Software version of the device.
Patch Ver
Most recently released patch image version that is running on the device. If no patch image is installed, this field displays None.
If both incremental and non-incremental patch images are running on the device, this field displays the most recently released incremental patch image version. For more information about patch image types, see "Upgrading software."
Use display device manuinfo to display electronic label information for the device.
context-admin
context-operator
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays electronic label information for all member devices.
An electronic label contains the permanent configuration information, including the hardware serial number, manufacturing date, MAC address, and vendor name. The data is written to the storage component during hardware debugging or testing. This command displays only part of the electronic label information.
# Display electronic label information for the device.
<Sysname> display device manuinfo
 Slot 1 CPU 0:
 DEVICE_NAME          : F5000-AI160
 DEVICE_SERIAL_NUMBER : 210235A2QB H164000026
 MAC_ADDRESS          : 487A-DA95-91BB
 MANUFACTURING_DATE   : 2022-01-29
 VENDOR_NAME          : H3C
Use display diagnostic-information to display or save operating information for features and hardware modules.
display diagnostic-information [ hardware | infrastructure | l2 | l3 | service ] [ context context-name ] [ key-info ] [ filename ]
context-admin
context-operator
hardware: Specifies hardware-related operating information.
infrastructure: Specifies operating information for the fundamental features.
l2: Specifies operating information for the Layer 2 features.
l3: Specifies operating information for the Layer 3 features.
service: Specifies operating information for Layer 4 and upper-layer features.
context context-name: Specifies a context by its name, a case-sensitive string of 1 to 15 characters. If you do not specify a context, this command display or save operating information for the default context.
For more information about contexts, see context configuration in Virtual Technologies Command Reference.
key-info: Displays or saves only critical operating information. The device might have a large amount of operating information if an exception occurs or after the device runs for a long period of time. Specifying this keyword reduces the command execution time and helps you focus on critical operating information. If you do not specify this keyword, the command displays or saves both critical and non-critical operating information.
filename: Saves the information to a file. The filename argument must use the .tar.gz extension. If you do not specify this argument, the command prompts you to choose whether to save the information to a file or display the information.
You can use one of the following methods to collect operating statistics for diagnostics and troubleshooting:
·     Use separate display commands to collect operating information feature by feature or module by module.
·     Use the display diagnostic-information command to collect operating information for multiple or all features and hardware modules.
To save storage space, this command automatically compresses the information before saving the information to a file. To view the file content:
1.     Use the tar extract command to extract the file.
2.     Use the gunzip command to decompress the extracted file.
3.     Use the more command to view the content of the decompressed file.
If you abort the display diagnostic-information command, the gunzip command might not be able to decompress the extracted file. To decompress the extracted file, export the extracted file to a PC that is running Linux, and use the gunzip -c command.
If you do not specify a file name for the command, the system prompts you to choose whether to display or save the information. If you choose to save the information, the system automatically assigns a file name and displays the file name in brackets. For file name uniqueness, the file name includes the device name and the current system time. If the device name contains any of the following special characters, the system uses an underscore (_) to replace each special character: forward slashes (/), backward slashes (\), colons (:), asterisks (*), question marks (?), less than signs (<), greater than signs (>), pipeline signs (|), and quotation marks ("). For example, device name A/B will change to A_B in the file name, as in flash:/diag_A_B_20160101-000438.tar.gz.
If you do not specify any feature parameters, this command displays or saves the operating information for all features and modules.
This command does not support the |, >, and >> options.
While the device is executing this command, do not execute any other commands. Executing other commands might affect the collected operating information.
# Display the operating information for all features and modules.
14:03:55 UTC Thu 01/05/2015
# Save the operating information to the default file.
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_Sysname_20160101-024601.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20160101-024601.tar.gz.
Please wait...
Save successfully.
Press Enter when the system prompts you to enter the file name.
# Save the operating information for all features and modules to file test.tar.gz.
<Sysname> display diagnostic-information test.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
gunzip
more
tar extract
display environment
Use display environment to display temperature information.
context-admin
context-operator
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays temperature information for all member devices.
# Display information about all temperature sensors on the device.
<Sysname> display environment
System Temperature information (degree centigrade):
 Slot     Sensor   Temperature LowerLimit Warning-UpperLimit  Alarm-UpperLimit S
hutdown-UpperLimit
1      inflow  1      33          0              54                59
     NA
1      inflow  2      32          0              54                59
     NA
1      hotspot 1      43          0              73                77
     NA
1      hotspot 2      38          0              70                75
     NA
Table 5 Command output
Temperature information (°C).
sensor
Temperature sensor:
·     hotspot—Hotspot sensor.
·     inflow—Air inlet sensor. Support for this option varies by device model.
Slot
Sensor position.
Temperature
Current temperature.
LowerLimit
Low-temperature threshold. If the device does not support this field, this field displays NA.
Warning-UpperLimit
High-temperature warning threshold. If the device does not support this field, this field displays NA.
Alarm-UpperLimit
High-temperature alarming threshold. If the device does not support this field, this field displays NA.
Shutdown-UpperLimit
High-temperature shutdown temperature threshold. When the sensor temperature reaches the limit, the system shuts down automatically. If the device does not support this field, this field displays NA.
display fan
Use display fan to display fan tray operating status information.
display fan [ slot slot-number [ fan-id ] ]
context-admin
context-operator
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays fan tray operating status information for all member devices.
fan-id: Specifies a fan tray by its ID. If you do not specify a fan tray, this command displays operating status information for all fan trays at the specified position.
verbose: Displays detailed information. If you do not specify this keyword, this command displays brief information.
# Display the operating states of all fan trays.
<Sysname> display fan
SLOT 1 Fan 0      Status: Normal  Speed:13953
SLOT 1 Fan 1      Status: Normal  Speed:13953
SLOT 1 Fan 2      Status: Normal  Speed:14285
SLOT 1 Fan 3      Status: Normal  Speed:14285
SLOT 1 Fan 4      Status: Normal  Speed:13953
Table 6 Command output
Slot 1
Number of the member device.
Fan 1
Fan tray number.
Fan status:
·     Absent—The slot is not installed with a fan tray.
·     Fault—The fan tray is faulty.
·     Normal—The fan tray is operating correctly.
·     FanDirectionFault—The actual airflow direction is not the preferred direction.
Speed
Fan speed.
display memory
Use display memory to display memory usage information.
context-admin
context-operator
summary: Displays brief information about memory usage. If you do not specify this keyword, the command displays detailed information about memory usage.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays memory usage for all member devices.
Executing this command on a context displays memory usage information for the context.
If two hyphens (--) are displayed for all the fields in a line of the command output, the command might fail to obtain data from the database on the device. Try the command later.
# Display detailed memory usage information.
<Sysname> display memory
Memory statistics are measured in KB:
Slot 1:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:        984560    456128    528432         0         4     45616       53.7%
-/+ Buffers/Cache:    410508    574052
Swap:            0         0         0
# Display brief memory usage information.
<Sysname> display memory summary
Slot CPU        Total      Used      Free  Buffers    Caches FreeRatio
   1   0       984560    456128    528432        4     45616     53.7%
Table 7 Command output
Mem
Memory usage information.
Total
Total size of the physical memory space that can be allocated.
The memory space is virtually divided into two parts. Part 1 is solely used for kernel code, kernel management, and ISSU functions. Part 2 can be allocated and used for such tasks as running service modules and storing files. The size of part 2 equals the total size minus the size of part 1.
Used
Used physical memory.
Free
Free physical memory.
Shared
Physical memory shared by processes.
If this field is not supported, two hyphens (--) are displayed.
Buffers
Physical memory used for buffers.
Cached
Caches
Physical memory used for caches.
FreeRatio
Free memory ratio.
-/+ Buffers/Cache
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications.
-/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications.
Swap
Memory space for swapping.
Use display memory-threshold to display memory alarm thresholds and statistics.
context-admin
context-operator
vsys-admin
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the memory usage thresholds and statistics for the master device.
For more information about memory usage notifications, see log information containing MEM_EXCEED_THRESHOLD or MEM_BELOW_THRESHOLD.
# Display memory alarm thresholds and statistics.
<Sysname> display memory-threshold
Memory usage threshold: 95%
Free-memory thresholds:
    Minor: 397M
    Severe: 318M
    Critical: 238M
    Normal: 477M
    Early-warning: 556M
    Secure: 636M
Current memory state: Normal
Event statistics:
 [Back to normal state]
    First notification: 0.0
    Latest notification: 0.0
    Total number of notifications sent: 0
 [Enter minor low-memory state]
    First notification at: 0.0
    Latest notification at: 0.0
 [Back to minor low-memory state]
 [Enter severe low-memory state]
 [Back to severe low-memory state]
 [Enter critical low-memory state]
display power
Use display power to display power module information.
display power [ slot slot-number [ power-id ] ]
context-admin
context-operator
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays power module information for all member devices.
power-id: Specifies a power module by its ID. If you do not specify a power module, this command displays information about all power modules at the specified position.
# Display brief power module information.
<Sysname> display power
Slot    PowerID   State     Mode    Current(A)   Voltage(V)   Power(W)
 1       0         Absent    --        --           --          --
 1       1         Normal    AC        4.02         12.06       49.00
Table 8 Command output
PowerID
Power module ID.
Power module status:
·     Absent—The slot is not installed with a power module.
·     Fault—The power module is faulty.
·     Normal—The power module is operating correctly.
Mode
Mode of the power module:
·     AC—AC power module.
·     DC—DC power module.
Current(A)
Output current of the power module, in amperes.
Voltage(V)
Output voltage of the power module, in volts.
Power(W)
Output power of the power module, in watts.
Use display scheduler job to display job configuration information.
context-admin
context-operator
job-name: Specifies a job by its name, a case-sensitive string of 1 to 47 characters. If you do not specify a job, this command displays configuration information for all jobs.
# Display configuration information for all jobs.
<Sysname> display scheduler job
Job name: saveconfig
 copy startup.cfg backup.cfg
Job name: backupconfig
Job name: creat-VLAN100
 vlan 100
// The output shows that the device has three jobs: the first has one command, the second does not have any commands, and the third has two commands. Jobs are separated by blank lines.
Use display scheduler logfile to display job execution log information.
context-admin
context-operator
# Display job execution log information.
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name        : shutdown
Schedule name   : shutdown
Execution time  : Tue Dec 27 10:44:42 2015
Completion time : Tue Dec 27 10:44:47 2015
<Sysname>system-view
[Sysname]interface rang gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[Sysname-if-range]shutdown
Table 9 Command output
Logfile Size
Size of the log file, in bytes.
Schedule name
Schedule to which the job belongs.
Execution time
Time when the job was started.
Completion time
Time when the job was completed. If the job has never been executed or the job does not have any commands, this field is blank.
Job output
Commands in the job and their output.
Use display scheduler reboot to display the automatic reboot schedule.
context-admin
context-operator
# Display the automatic reboot schedule.
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2015 (in 1 hours and 39 minutes).
scheduler reboot at
Use display scheduler schedule to display schedule information.
context-admin
context-operator
schedule-name: Specifies a schedule by its name, a case-sensitive string of 1 to 47 characters. If you do not specify a schedule, this command displays information about all schedules.
# Display information about all schedules.
<Sysname> display scheduler schedule
Schedule type        : Run once after 0 hours 2 minutes
Start time           : Tue Dec 27 10:44:42 2015
Last execution time  : Tue Dec 27 10:44:42 2015
Last completion time : Tue Dec 27 10:44:47 2015
Execution counts     : 1
shutdown                                          Successful
Table 10 Command output
Schedule type
Execution time setting of the schedule. If no execution time is specified, this field is not displayed.
Start time
Time to execute the schedule for the first time. If no execution time is specified, this field is not displayed.
Last execution time
Last time when the schedule was executed. If no execution time is specified, this field is not displayed. If the schedule has never been executed, "Yet to be executed" is displayed for this field.
Last time when the schedule was completed. If no execution time is specified, this field is not displayed.
Execution counts
Number of times the schedule has been executed. If the schedule has never been executed, this field is not displayed.
Job name
Name of a job under the schedule.
Result of the most recent execution:
·     Successful.
·     Failed.
·     Waiting—The device is executing the schedule and the job is waiting to be executed.
·     In process—The job is being executed.
·     -NA-—The execution time has not arrived yet.
To view information about whether the commands in the job has been executed and the execution results, execute the display scheduler logfile command.
Use display system stable state to display system stability and status information.
display system stable state [ context { context-id | all } ]
context-admin
context-operator
context { context-id | all }: Specifies a context by its ID or specifies all contexts. For more information about context and the value range for the context ID, see Virtual Technologies Command Reference.
If you do not specify a context, this command displays stability information for the system.
Before performing an ISSU or a switchover, execute this command multiple times to identify whether the system is operating stably. If the value of the System State field is not Stable, you cannot perform an ISSU. If the value of the Redundancy Stable field is not Stable, you cannot perform a switchover.
The device or context startup process takes some time. If the values of the status fields do not change to Stable, execute this command multiple times to identify the devices or contexts that are not in Stable state. You can also use other commands to identify the faulty components. For example:
·     Use the display device command to identify the device operating status.
·     Use the display ha service-group command to display the status of HA service groups and identify the groups in batch backup state.
·     Use the display system internal process state command in probe view to display service operating status.
# Display system stability and status information.
<Sysname> display system stable state
System state    : Stable
Redundancy state: No redundancy
  Slot   CPU   Role      State
 1      0     Active    Stable
Table 11 Command output
System state
System status:
·     Stable—The system is operating stably.
·     Not ready—The system is not operating stably. You cannot perform an ISSU when the system is in this state.
Redundancy state
System redundancy status:
·     Stable—Member devices are operating stably. You can perform a switchover.
·     No redundancy—The system has only one member device. You cannot perform a switchover.
·     Not ready—The system is not operating stably. You cannot perform a switchover.
Role
Role of the member device in the system:
·     Active—The member device is the master.
·     Standby—The member device is a subordinate member.
Member device status:
·     Stable—The member device is operating stably.
·     Board inserted—The member device has just been installed.
·     Kernel initiating—Member device kernel is being initialized.
·     Service starting—Services are starting on the member device.
·     Service stopping—Services are stopping on the member device.
·     HA Batch backup—An HA batch backup is going on.
·     Interface data batch backup—An interface data batch backup is in progress.
·     Context starting—Contexts are starting.
·     Context stopping—Contexts are stopping.
·     Automatic configuration—The context is being automatically configured.
The object is not operating stably.
display context (Virtual Technologies Command Reference)
display device
display ha service-group (High Availability Command Reference)
Use display transceiver alarm to display transceiver alarms.
context-admin
context-operator
controller [ controller-type controller-number ]: Specifies a controller by its type and number. If no controller is specified, this command displays the alarms present on all controllers.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the alarms present on every transceiver module.
Table 12 shows the common transceiver alarm components. If no error occurs, "None" is displayed.
Table 12 Common transceiver alarm components
APD
Avalanche photo diode
PCS
Physical coding sublayer
PHY XS
PHY extended sublayer
PMA/PMD
Physical medium attachment/physical medium dependent
power
Optical power
REFCLK
Reference clock
RX
Receive
Temp
Temperature
TX
Transmit
WIS
WAN interface sublayer
# Display the alarms present on the transceiver module in interface GigabitEthernet 1/0/1.
<Sysname> display transceiver alarm interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 transceiver current alarm information:
  RX loss of signal
  RX power low
Table 13 Command output
Alarms present on the transceiver module.
RX loss of signal
Received signals are lost.
RX power low
Received power is low.
Use display transceiver diagnosis to display the current values of the digital diagnosis parameters of transceiver modules.
context-admin
context-operator
controller [ controller-type controller-number ] : Specifies a controller by its type and number. If no controller is specified, this command displays the current values of the digital diagnosis parameters on all controllers.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the current values of the digital diagnosis parameters on all interfaces.
# Display the current values of the digital diagnosis parameters on the transceiver module in interface GigabitEthernet 1/0/1.
<Sysname> display transceiver diagnosis interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 transceiver diagnostic information:
    Temp(°C)  Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    36        3.31        6.13      -35.64          -5.19
  Alarm thresholds:
           Temp(°C)   Voltage(V)  Bias(mA)  RX power(dBM)  TX power(dBM)
    High   50         3.55        1.44      -10.00         5.00
    Low    30         3.01        1.01      -30.00         0.00
Table 14 Command output
Digital diagnosis information for the transceiver module in the interface.
Temp.(°C)
Temperature in °C, accurate to 1°C.
Voltage(V)
Voltage in V, accurate to 0.01 V.
Bias(mA)
Bias current in mA, accurate to 0.01 mA.
RX power(dBm)
Receive power in dBm, accurate to 0.01 dBm.
TX power(dBm)
Transmit power in dBm, accurate to 0.01 dBm.
Use display transceiver interface to display the key parameters of transceiver modules.
context-admin
context-operator
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the key parameters of every transceiver module.
# Display the key parameters of the transceiver module in interface GigabitEthernet 1/0/1.
<Sysname> display transceiver interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 transceiver information:
  Transceiver Type              : 1000_BASE_SX_SFP
  Connector Type                : LC
  Wavelength(nm)                : 850
  Transfer Distance(m)          : 550(50um),270(62.5um)
  Digital Diagnostic Monitoring : YES
  Vendor Name                   : H3C
  Ordering Name                 : SFP-GE-SX-MM850
Table 15 Command output
Wavelength(nm)
Central wavelength of the laser in nm.
For a fiber transceiver module that supports multiple wavelengths, for example, the 10GBASE-LX4 transceiver module, this field displays all the wavelengths, separating the values by commas (,).
For a copper module, this field displays N/A.
Transmission distance, in km (for single-mode modules) or in m (for other modules). For a module that supports multiple transmission media, this field displays all the transmission distances, separating the values by commas (,). Each transmission distance is followed by the medium name in parentheses.
·     9um—9/125um single-mode optical fiber.
·     50um—50/125um OM 2 multi-mode optical fiber.
·     62.5um—62.5/125um OM 1 multi-mode optical fiber.
·     CX4—CX4 cable.
·     OM3—50 um OM3 multi-mode optical fiber.
·     OM4—50 um OM4 multi-mode optical fiber.
·     OM5—50 um OM5 multi-mode optical fiber.
·     STACK—Stack cable.
·     TP—Twisted pair cable.
Whether digital diagnosis is supported:
·     YES—Digital diagnosis is supported.
·     NO—Digital diagnosis is not supported.
Use display transceiver manuinfo to display electronic label information for transceiver modules.
context-admin
context-operator
controller [ controller-type controller-number ] : Specifies a controller by its type and number. If no controller is specified, this command displays the electronic label information for the transceiver modules in all controllers.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays electronic label information for the transceiver modules in all interfaces.
# Display electronic label information for the transceiver module in interface GigabitEthernet 1/0/1.
<Sysname> display transceiver manuinfo interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 transceiver manufacture information:
  Manu. Serial Number  : 213410A0000054000251
  Manufacturing Date   : 2017-09-01
  Vendor Name          : H3C
display version
Use display version to display system version information.
display version
context-admin
context-operator
# Display system version information.
<Sysname> display version
H3C Comware Software, Version 7.1.064, Ess 8190
Copyright (c) 2004-2022 New H3C Technologies Co., Ltd. All rights reserved.
H3C SecPath F5000-CN-G85 uptime is 1 week, 4 days, 8 hours, 44 minutes
Last reboot reason: User reboot
Boot image: flash:/f5000dcnfw-cmw710-boot-E8190.bin
Boot image version: 7.1.064, Ess 8190
  Compiled Dec 22 2022 15:00:00
System image: flash:/f5000dcnfw-cmw710-system-E8190.bin
System image version: 7.1.064, Ess 8190
SLOT 1 CPU 0
CPU type           : Multi-core CPU
DDR4 SDRAM Memory  : 16384M bytes
FLASH              : 7441M bytes
Board PCB       Version: Ver. A
CPLD            Version:   3.0
Basic  BootWare Version:  1.03
Extend BootWare Version:  1.03
[SubSlot 0] 6GE+4SFP (Hardware)Ver.A, (Driver)1.0, (Cpld)3.0
[SUBCARD 1] NS-NIM-GT8B (Hardware)Ver.A, (Driver)1.0, (Cpld)1.0
Table 16 Command output
Last reboot reason
Reason for the last reboot:
·     User reboot—The reboot was manually initiated from a user interface, such as the CLI or SNMP.
·     Cold reboot—The reboot was caused by a power cycle.
·     Kernel abnormality reboot—The reboot was caused by kernel exceptions.
·     DeadLoop reboot—The reboot was caused by a kernel thread dead loop.
·     DEV HandShake reboot—The reboot was caused by a device management handshake failure.
·     SlaveSwitch reboot—The reboot was caused by a master/subordinate switchover.
·     IRF Merge reboot—The reboot was caused by an IRF merge.
·     Auto Update reboot—The reboot was caused by an automatic software upgrade.
·     Memory exhaust reboot—The reboot was caused by a card-memory-exhausted event.
Use display version-update-record to display startup software image upgrade records.
The device records its current startup software version information whenever it starts up, and records all software version update information. Such information can survive reboots.
# Display the startup software image upgrade records.
<Sysname> display version-update-record
Record 1  (updated on Apr 18 2015 at 06:23:54):
 *Name        : boot-test.bin
  Version     : 7.1.070 Test 0001
  Compile time: Mar 25 2015 15:52:43
 *Name        : system-test.bin
Table 17 Command output
Record n
Number of the startup software image upgrade record. Record 1 is the most recent record.
Name
Software image file name.
The software image version changed during the upgrade.
display voltage
Use display voltage to display voltage information.
display voltage [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays voltage information for all member devices.
This command is supported only on the default MDC.
If the voltage is lower than the lower limit or higher than the higher limit, the device sends a log message and a trap.
# Display voltage information.
<Sysname> display voltage
System voltage information (volt):
Slot Sensor Voltage Status Required LowLimit HighLimit Description
1    0      0.763   Normal 0.750    0.675    0.825     0.75
1    1      1.051   Normal 1.050    0.945    1.155     1.05
Table 18 Command output
Slot
Chassis ID/slot ID. For a sensor on a slot, this field displays the slot number.
Sensor
ID of the sensor.
Voltage
Current voltage of the sensor.
Description for the sensor. This field is generated by the device. It displays the rated voltage of the sensor. If another sensor has the same rated voltage value, a string is automatically inserted before the rated voltage value to uniquely identify the item.
header
Use header to configure a banner.
Use undo header to delete a banner.
header { legal | login | motd | shell } text
undo header { legal | login | motd | shell }
The device does not have banners.
context-admin
legal: Configures the banner to be displayed before a user inputs the username and password to access the CLI.
login: Configures the banner to be displayed before password or scheme authentication is performed for a login user.
motd: Configures the greeting banner to be displayed before the legal banner appears.
shell: Configures the banner to be displayed before a user accesses user view.
text: Specifies the banner message. You can enter the banner message on the same line as the keywords or on different lines. For more information, see device management in Fundamentals Configuration Guide.
# Configure the legal banner.
[Sysname] header legal
Welcome to use the legal banner%
job
Use job to assign a job to a schedule.
Use undo job to revoke a job.
job job-name
undo job job-name
No job is assigned to a schedule.
Schedule view
context-admin
job-name: Specifies the job name, a case-sensitive string of 1 to 47 characters.
You can assign multiple jobs to a schedule. The jobs in a schedule are executed concurrently.
The jobs to be assigned to a schedule must already exist. To create a job, use the scheduler job command.
# Assign job save-job to schedule saveconfig.
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
scheduler job
scheduler schedule
locator blink
Use locator blink blink-time to start LED flashing to locate devices.
Use locator blink stop to stop LED flashing.
locator [ slot slot-number ] blink blink-time
locator [ slot slot-number ] blink stop
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the command applies to all member devices.
blink-time: Specifies the flash duration in seconds.  The value range is 5 to 120.
stop: Stops flashing.
The device provides a LED for device locating. The locator blink blink-time command flashes the specified LEDs quickly for a period of time unless you execute the locator blink stop command. You can observe the LEDs to locate the devices.
# Start LED flashing to locate devices.
<Sysname> locator blink 30
# Stop LED flashing.
<Sysname> locator blink stop
memory-threshold
Use memory-threshold to set free-memory thresholds.
Use undo memory-threshold to restore the default.
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
The default varies by device model. To view the default, use the undo memory-threshold command to restore the default and then execute the display memory-threshold command.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets free-memory thresholds for the master device.
ratio: Specifies free-memory thresholds in percentage. If you do not specify this keyword, the command sets free-memory thresholds in MB.
minor minor-value: Specifies the minor alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the minor-value argument. Setting this threshold to 0 disables the minor alarm feature.
severe severe-value: Specifies the severe alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the severe-value argument. Setting this threshold to 0 disables the severe alarm feature.
critical critical-value: Specifies the critical alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the critical-value argument. Setting this threshold to 0 disables the critical alarm feature.
normal normal-value: Specifies the normal state threshold. To view the value range for this threshold, enter a question mark (?) in the place of the normal-value argument.
early-warning early-warning-value: Specifies the early-warning threshold. To view the value range for this threshold, enter a question mark (?) in the place of the early-warning-value argument. Setting this threshold to 0 disables the early warning feature.
secure secure-value: Specifies the sufficient-memory threshold. To view the value range for this threshold, enter a question mark (?) in the place of the secure-value argument.
To ensure correct operation and improve memory efficiency, the system monitors the amount of free memory space in real time. If the amount of free memory space decreases to or below the minor, severe, or critical alarm threshold, the system issues an alarm to affected service modules or processes.
The early warning feature warns you of an approaching insufficient-memory condition.
If a memory alarm occurs, delete unused configuration items or disable some features to increase the free memory space. Because the memory space is insufficient, some configuration items might not be able to be deleted.
For more information about the thresholds, see device management in Fundamentals Configuration Guide.
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 64 MB, 48 MB, 32 MB, and 96 MB, respectively.
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
Use memory-threshold usage to set the memory usage threshold.
Use undo memory-threshold usage to restore the default.
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
The memory usage threshold is 95%.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets the memory usage threshold for the master device.
memory-threshold: Specifies the memory usage threshold in percentage. The value range is 0 to 100.
The device samples memory usage at 1-minute intervals. If the sample is equal to or greater than the memory usage threshold, the device sends a trap.
# Set the memory usage threshold to 80%.
[Sysname] memory-threshold usage 80
monitor cpu-usage enable
Use monitor cpu-usage enable to enable CPU usage monitoring.
Use undo monitor cpu-usage enable to disable CPU usage monitoring.
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
CPU usage monitoring is enabled.
context-admin
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command enables CPU usage monitoring for the master device.
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the interval specified by the monitor cpu-usage interval command. You can use the display cpu-usage history command to view recent CPU usage.
# Enable CPU usage monitoring.
[Sysname] monitor cpu-usage enable
Use monitor cpu-usage interval to set the sampling interval for CPU usage monitoring.
The system samples CPU usage every 1 minute.
context-admin
interval: Specifies the sampling interval for CPU usage monitoring. Valid values include 5Sec (5 seconds), 1Min (1 minute), and 5Min (5 minutes), case insensitive.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets the interval for the master device.
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the specified interval. You can use the display cpu-usage history command to view recent CPU usage.
# Set the sampling interval for CPU usage monitoring to 5 seconds.
[Sysname] monitor cpu-usage interval 5Sec
monitor cpu-usage logging
Use monitor cpu-usage logging to enable periodic CPU usage logging.
Use undo monitor cpu-usage logging to disable periodic CPU usage logging.
monitor cpu-usage logging slot slot-number cpu cpu-number interval interval-time
undo monitor cpu-usage logging slot slot-number cpu cpu-number
Periodic CPU usage logging is disabled.
context-admin
interval interval-time: Specifies the logging interval in seconds, a multiple of five in the range of 5 to 300.
Non-default vSystems do not support this command.
# Enable periodic CPU usage logging for CPU 0 on slot 1 and set the logging interval to 5 seconds.
[Sysname] monitor cpu-usage logging slot 1 cpu 0 interval 5
monitor cpu-usage statistics-interval core
Use monitor cpu-usage statistics-interval core to set CPU core usage statistics intervals.
Use undo monitor cpu-usage statistics-interval core to restore the default.
monitor cpu-usage statistics-interval interval slot slot-number cpu cpu-number core core-id-list
undo monitor cpu-usage statistics-interval slot slot-number cpu cpu-number core core-id-list
The CPU core usage statistics interval is 60 seconds.
context-admin
interval: Specifies the CPU core usage statistics interval in seconds. The value range for this argument is 10 to 3600. As a best practice, set this argument to a multiple of the sampling interval, which is fixed at 5 seconds. If you do not do so, the actual statistics interval is the biggest multiple of the sampling interval that is smaller than the setting. For example, if you set this argument to 12 seconds, the actual statistics interval is 10 seconds.
core core-id-list: Specifies a space-separated list of up to 10 CPU core items. Each item specifies a CPU core or a range of CPU cores in the form of core-id1 [ to core-id2 ]. The value for core-id2 must be greater than or equal to the value for core-id1.
The device samples CPU core usage at 5-second intervals and calculates the average value during each CPU core usage statistics interval. If the value during an interval is greater than the CPU core usage threshold, the device issues an alarm and logs the event.
# Set the usage statistics interval to 60 seconds for a CPU core.
[Sysname] monitor cpu-usage statistics-interval 60 slot 1 cpu 0 core 0
monitor cpu-usage threshold core
monitor resend cpu-usage core-interval
Use monitor cpu-usage threshold to set CPU usage alarm thresholds.
Use undo monitor cpu-usage threshold to restore the default.
monitor cpu-usage threshold severe-threshold recovery-threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ]
The CPU usage alarm threshold is 70%. The CPU usage recovery threshold is 30%.
context-admin
severe-threshold: Specifies the severe CPU usage alarm threshold in percentage. The value range for this argument is 2 to 100.
recovery-threshold recovery-threshold: Specifies the CPU usage recovery threshold in percentage. The value range for this argument is 0 to the minor CPU usage alarm threshold minus 1.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets the CPU usage threshold for the master device.
CAUTION
CAUTION:
If you set the severe CPU usage alarm threshold to a too low value, the device will reach the threshold easily. Normal service processing will be affected.
The device samples CPU usage at 1-minute intervals. If the sample is greater than the CPU usage threshold, the device sends a trap.
# Set the CPU usage alarm threshold to 90% and the CPU usage recovery threshold to 70%.
[Sysname] monitor cpu-usage threshold 90 recovery-threshold 70
Use monitor cpu-usage threshold core to set CPU core usage alarm thresholds.
Use undo monitor cpu-usage threshold core to restore the default.
monitor cpu-usage threshold severe-threshold [ recovery-threshold recovery-threshold ] slot slot-number cpu cpu-number core core-id-list
undo monitor cpu-usage threshold [ recovery-threshold ] slot slot-number cpu cpu-number core core-id-list
The CPU core usage alarm threshold is 100.
context-admin
severe-threshold: Specifies the CPU core usage alarm threshold in percentage. The value range for this argument is 2 to 100.
recovery-threshold recovery-threshold: Specifies the CPU core usage recovery threshold in percentage. The value range for this argument is 0 to the CPU core usage alarm threshold minus 1.
If you set the CPU core usage alarm threshold to 100, the CPU core usage alarm is disabled. The device does not issue an alarm or generate a log even if the CPU core usage reaches 100%.
If you have specified the CPU core usage alarm threshold but not specified the CPU core usage recovery threshold, the recovery threshold is 80% of the alarm threshold.
# Set the CPU core usage alarm threshold to 90% and CPU core usage recovery threshold to 70% for CPU core 0.
[Sysname] monitor cpu-usage threshold 90 recovery-threshold 70 core 0
monitor memory-usage logging
Use monitor memory-usage logging to enable periodic memory usage logging.
Use undo monitor memory-usage logging to disable periodic memory usage logging.
monitor memory-usage logging slot slot-number cpu cpu-number interval interval-time
undo monitor memory-usage logging slot slot-number cpu cpu-number
Periodic memory usage logging is disabled.
context-admin
# Enable periodic memory usage logging for CPU 0 on slot 1 and set the logging interval to 5 seconds.
[Sysname] monitor memory-usage logging slot 1 cpu 0 interval 5
Use monitor resend cpu-usage core-interval to set CPU core alarm resending intervals.
Use undo monitor resend cpu-usage core-interval to restore the default.
monitor resend cpu-usage core-interval core-interval [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend cpu-usage core-interval [ slot slot-number [ cpu cpu-number ] ]
The CPU core alarm resending interval is 300 seconds.
context-admin
core-interval: Specifies the CPU core alarm resending interval in seconds, a multiple of 5 in the range of 10 to 3600.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets the CPU core alarm resending interval for the master device.
# Set the CPU core alarm resending interval to 60 seconds.
[Sysname] monitor resend cpu-usage core-interval 60
monitor resource-usage { bridge-aggregation | route-aggregation } threshold
Use monitor resource-usage { bridge-aggregation | route-aggregation } threshold to set aggregate interface usage thresholds.
Use undo monitor resource-usage { bridge-aggregation | route-aggregation } threshold to restore the default.
monitor resource-usage { bridge-aggregation | route-aggregation } threshold threshold-value
No aggregate interface usage thresholds are set. The aggregate interface usage alarm feature is disabled.
context-admin
bridge-aggregation: Sets the Layer 2 aggregate interface usage threshold.
route-aggregation: Sets the Layer 3 aggregate interface usage threshold.
threshold-value: Specifies the aggregate interface usage threshold in the range of 1 to 4294967295.
When the number of created Layer 2 or Layer 3 aggregate interfaces reaches the threshold, the device sends an alarm. If the alarm state persists, the device resends the alarm at 3-hour intervals.
# Set the Layer 2 aggregate interface usage threshold to 100.
[Sysname] monitor resource-usage bridge-aggregation threshold 100
# Set the Layer 3 aggregate interface usage threshold to 150.
[Sysname] monitor resource-usage route-aggregation threshold 150
monitor resource-usage bandwidth inbound threshold
Use monitor resource-usage bandwidth inbound threshold to set the total inbound bandwidth usage threshold.
Use undo monitor resource-usage bandwidth inbound threshold to restore the default.
monitor resource-usage bandwidth inbound threshold threshold-value [ duration duration-value ]
The total inbound bandwidth usage threshold is not set. The bandwidth usage alarm feature is disabled.
threshold-value: Specify the total inbound bandwidth usage threshold in Mbps. The value range for this argument is 1 to 4294967295.
duration duration-value: Specify the high-usage duration criterion in seconds, a multiple of five in the range of 5 to 300. The default value is 300.
This command is supported only on the default context.
If the total inbound traffic remains greater than or equal to the total inbound bandwidth usage threshold for the specified duration, the device sends an alarm. If the alarm state persists, the device resends the alarm at 5-second intervals.
# Set the total inbound bandwidth usage threshold to 1024 Mbps and set the high-usage duration criterion to 60 seconds.
[Sysname] monitor resource-usage bandwidth inbound threshold 1024 duration 60
monitor resource-usage context threshold
Use monitor resource-usage context threshold to set the global context usage threshold.
Use undo monitor resource-usage context threshold to restore the default.
monitor resource-usage context threshold threshold-value
The global context usage threshold is not set. The context usage alarm feature is disabled.
threshold-value: Specifies the global context usage threshold in the range of 1 to 4294967295.
When the number of created contexts on the device reaches the threshold, the device sends an alarm. If the alarm state persists, the device resends the alarm at 6-hour intervals.
# Set the global context usage threshold to 16.
[Sysname] monitor resource-usage context threshold 16
monitor resource-usage nat threshold
Use monitor resource-usage nat threshold to set the NAT mapping threshold.
Use undo monitor resource-usage nat threshold to restore the default.
monitor resource-usage nat threshold threshold-value
The NAT mapping threshold is not set. The NAT mapping alarm feature is disabled.
context-admin
threshold-value: Specifies the NAT mapping threshold in the range of 1 to 4294967295.
When the number of NAT mappings reaches the threshold, the device sends an alarm. If the alarm state persists, the device resends the alarm at 3-hour intervals.
In the current software version, this feature counts only static NAT mappings and effective NAT server mappings. To display the status of NAT server mappings, execute the display nat server command.
# Set the NAT mapping threshold to 300.
[Sysname] monitor resource-usage nat threshold 300
display nat server (Layer 3—IP Services Command Reference)
monitor resource-usage security-policy threshold
Use monitor resource-usage security-policy { ip | ipv6 } threshold to set security policy rule usage thresholds.
Use undo monitor resource-usage security-policy { ip | ipv6 } threshold to restore the default.
monitor resource-usage security-policy { ip | ipv6 } threshold threshold-value
No security policy rule thresholds are set. The security policy rule alarm feature is disabled.
context-admin
ip: Sets the IPv4 security policy rule threshold.
ipv6: Sets the IPv6 security policy rule threshold.
threshold-value: Specifies the security policy rule threshold in the range of 1 to 4294967295.
When the number of created security policy rules reaches the threshold, the device sends an alarm. If the alarm state persists, the device resends the alarm at 6-hour intervals.
# Set the IPv4 security policy rule threshold to 500.
[Sysname] monitor resource-usage security-policy ip threshold 500
# Set the IPv6 security policy rule threshold to 500.
[Sysname] monitor resource-usage security-policy ipv6 threshold 500
monitor resource-usage session-count threshold
Use monitor resource-usage session-count threshold to set session usage thresholds.
Use undo monitor resource-usage session-count threshold to restore the default.
monitor resource-usage session-count [ slot slot-number ] threshold threshold-value
undo monitor resource-usage session-count [ slot slot-number ] threshold
No session usage thresholds are set. The session usage alarm feature is disabled.
context-admin
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets the session usage threshold for the master device.
threshold-value: Specifies the session threshold in the range of 1 to 4294967295.
When the number of sessions reaches the threshold, the device sends an alarm. If the alarm state persists, the device resends the alarm at 10-minute intervals.
# Set the session usage threshold to 100000.
[Sysname] monitor resource-usage session-count threshold 100000
monitor resource-usage session-rate threshold
Use monitor resource-usage session-rate threshold to set session establishment rate thresholds.
Use undo monitor resource-usage session-rate threshold to restore the default.
monitor resource-usage session-rate [ slot slot-number ] threshold threshold-value
undo monitor resource-usage session-rate [ slot slot-number ] threshold
No session establishment rate thresholds are set. The session establishment rate alarm feature is disabled.
context-admin
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets the session establishment rate threshold for the master device.
threshold-value: Specifies the session establishment rate threshold in the range of 1 to 4294967295.
When the session establishment rate reaches the threshold, the device sends an alarm. If the alarm state persists, the device resends the alarm at 10-minute intervals.
# Set the session establishment rate threshold to 500.
[Sysname] monitor resource-usage session-rate threshold 500
password-recovery enable
Use password-recovery enable to enable password recovery capability.
Use undo password-recovery enable to disable password recovery capability.
Password recovery capability is enabled.
Password recovery capability controls console user access to the device configuration and SDRAM from BootWare menus.
If password recovery capability is enabled, a console user can access the device configuration without authentication to configure new passwords.
If password recovery capability is disabled, console users must restore the factory-default configuration before they can configure new passwords. Restoring the factory-default configuration deletes the next-startup configuration files.
To enhance system security, disable password recovery capability.
To access the device configuration without authentication, you must connect to the master device and access the BootWare menu while the master device is starting up.
Availability of BootWare menu options depends on the password recovery capability setting. For more information, see the release notes.
# Disable password recovery capability.
[Sysname] undo password-recovery enable
reboot
Use reboot to reboot the device.
context-admin
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, the command reboots all IRF member devices.
force: Reboots the device immediately without performing software or hard disk check. If this keyword is not specified, the system first identifies whether the reboot might result in data loss or a system failure. For example, the system identifies whether the main system software image file exists and whether a write operation is in progress on a storage medium. If the reboot might cause problems, the system does not reboot the device.
CAUTION
CAUTION:
·     A reboot might interrupt network services.
·     Use the force keyword only when the device fails or a reboot command without the force keyword cannot perform a reboot correctly. A reboot command with the force keyword might result in file system corruption because it does not perform data protection.
If the main startup software images are corrupt or missing, you must re-specify a set of main startup software images before executing the reboot command.
For data security, the device does not reboot if you reboot the device while the device is performing file operations.
If the IRF fabric has only one member device, rebooting the member device reboots the entire IRF fabric. If the IRF fabric has a subordinate member and the member is operating correctly, rebooting the master triggers a master/subordinate switchover.
To ensure correct operation of the IRF fabric and member devices, do not trigger a switchover by rebooting the master if no subordinate member devices are in Stable state. To view the status of subordinate member devices, execute the display system stable state command.
# Reboot the device. Save the running configuration at prompt.
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to mainboard device successfully.
Now rebooting, please wait...
# Reboot the device immediately without performing software check.
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
reset scheduler logfile
Use reset scheduler logfile to clear job execution log information.
# Clear job execution log information.
<Sysname> reset scheduler logfile
reset version-update-record
Use reset version-update-record to clear startup software image upgrade records.
# Clear the startup software image upgrade records.
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
restore factory-default
Use restore factory-default to restore the factory-default configuration for the device.
CAUTION
CAUTION:
This command restores the device to the factory default. Make sure you understand its impact on the live network before executing the command.
Use this command only when you cannot troubleshoot the device by using other methods, or you want to use the device in a different scenario.
# Restore the factory-default configuration for the device.
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data, and forcibly reboot the system. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait....Done.
The system is rebooting...
reboot
scheduler job
Use scheduler job to create a job and enter its view, or enter the view of an existing job.
Use undo scheduler job to delete a job.
scheduler job job-name
undo scheduler job job-name
No job exists.
context-admin
A job can be referenced by multiple schedules. In job view, you can assign commands to the job.
# Create a job named backupconfig and enter job view.
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig]
command
scheduler schedule
scheduler logfile size
Use scheduler logfile size to set the size of the job execution log file.
scheduler logfile size value
The size of the job execution log file is 16 KB.
context-admin
value: Specifies the size of the job execution log file, in KB. The value range is 16 to 1024.
The job execution log file stores the execution information of jobs. If the file is full, old records are deleted to make room for new records. If the size of the log information to be written to the file is greater than the file size, the excessive information is not written to the file.
# Set the size of the job execution log file to 32 KB.
[Sysname] scheduler logfile size 32
scheduler reboot at
Use scheduler reboot at to specify the reboot date and time.
Use undo scheduler reboot to delete the reboot schedule configuration.
No reboot date or time is specified.
context-admin
time: Specifies the reboot time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the reboot date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
CAUTION
CAUTION:
This command reboots the device at the specified time and interrupts network services. Make sure you understand its impact on the live network before executing the command.
When the date argument is not specified, the system uses the following rules to determine the reboot time:
·     If the reboot time is later than the current time, a reboot occurs at the reboot time of the current day.
·     If the reboot time is earlier than the current time, a reboot occurs at the reboot time the next day.
The device supports only one device reboot schedule. If you execute both the scheduler reboot delay and scheduler reboot at commands or execute one of the commands multiple times, the most recent configuration takes effect.
For data security, the system does not reboot at the reboot time if a file operation is being performed.
# Configure the device to reboot at 12:00 p.m. This example assumes that the current time is 11:43 a.m. on June 6, 2015.
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2015 (in 0 hours and 16 minutes). Confirm? [Y/N]:
Use scheduler reboot delay to specify the reboot delay time.
scheduler reboot delay time
No reboot delay time is specified.
context-admin
time: Specifies the reboot delay time in the hh:mm or mm format. This argument can contain up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
CAUTION
CAUTION:
This command reboots the device after the specified delay time and interrupts network services. Make sure you understand its impact on the live network before executing the command.
The device supports only one device reboot schedule. If you execute both the scheduler reboot delay and schedule reboot at commands or execute one of the commands multiple times, the most recent configuration takes effect.
# Configure the device to reboot after 88 minutes. This example assumes that the current time is 11:48 a.m. on June 6, 2015.
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2015(in 1 hours and 28 minutes). Confirm? [Y/N]:
scheduler schedule
Use scheduler schedule to create a schedule and enter its view, or enter the view of an existing schedule.
Use undo scheduler schedule to delete a schedule.
undo scheduler schedule schedule-name
No schedule exists.
context-admin
schedule-name: Specifies the schedule name, a case-sensitive string of 1 to 47 characters.
You can configure a schedule to have the device automatically run a command or a set of commands without administrative interference.
To configure a schedule:
1.     Use the scheduler job command to create a job and enter job view.
2.     Use the command command to assign commands to the job.
3.     Use the scheduler schedule command to create a schedule and enter schedule view.
4.     Use the job command to assign the job to the schedule. You can assign multiple jobs to a schedule. The jobs must already exist.
5.     Use the user-role command to assign user roles to the schedule. You can assign up to 64 user roles to a schedule.
6.     Use the time at, time once, or time repeating command to specify an execution time for the schedule. You can specify only one execution time for a schedule.
# Create a schedule named saveconfig.
job
time at
time once
shutdown-interval
Use shutdown-interval to set the port status detection timer.
Use undo shutdown-interval to restore the default.
shutdown-interval interval
The port status detection timer setting is 30 seconds.
context-admin
interval: Specifies the port status detection timer value in seconds. The value range is 0 to 300. If the value is 0, the system does not detect the port status automatically. To restore the port status, execute the undo shutdown command.
The device starts a port status detection timer when a port is shut down by a protocol. Once the timer expires, the system restores its physical status.
If you change the timer setting during port detection, the device compares the new setting (T1) with the time that elapsed since the port was shut down (T).
If T < T1, the port will be brought up after T1 – T seconds.
If T ≥ T1, the port is brought up immediately.
For example, the timer setting is 30 seconds. If you change it to 10 seconds 2 seconds after the port is shut down, the port will come up 8 seconds later. If you change the timer setting to 2 seconds 10 seconds after the port is shut down, the port comes up immediately.
# Set the port status detection timer to 100 seconds.
[Sysname] shutdown-interval 100
sysid
Use sysid to set the system ID.
Use undo sysid to restore the default.
sysid system-id
undo sysid
The device does not have a system ID.
context-admin
system-id: Specifies the system ID for the device. You can use this argument to indicate the position or functionality of the device or any other information.
# Set the system ID of the device to position-hall.
[Sysname] sysid positon-hall
sysname
Use sysname to set the device name.
Use undo sysname to restore the default.
sysname sysname
undo sysname
The device name is H3C.
context-admin
sysname: Specifies a name for the device, a string of 1 to 64 characters.
A device name identifies a device in a network and is used in CLI view prompts. For example, if the device name is Sysname, the user view prompt is <Sysname>.
# Set the name of the device to R2000.
[Sysname] sysname R2000
[R2000]
temperature-limit
Use temperature-limit to set the temperature alarm thresholds.
Use undo temperature-limit to restore the default.
temperature-limit slot slot-number { hotspot | inflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number { hotspot | inflow } sensor-number
The defaults vary by temperature sensor model. To view the defaults, execute the undo temperature-limit and display environment commands in turn.
context-admin
hotspot: Configures temperature alarm thresholds for hotspot sensors. A hotspot sensor is typically near the chip that generates a great amount of heat and used to monitor the chip.
inflow: Configures temperature alarm thresholds for inlet sensors. An inlet sensor is near the air inlet and used for monitoring ambient temperature.
sensor-number: Specifies a sensor by its number. To view the value range, enter a question mark (?) in the place of this argument.
lowlimit: Specifies the low-temperature threshold in Celsius degrees. The value range varies by temperature sensor. To view the value range, enter a question mark (?) in the place of this argument.
warninglimit: Specifies the high-temperature warning threshold in Celsius degrees. This threshold must be greater than the low-temperature threshold. To view the value range, enter a question mark (?) in the place of this argument.
alarmlimit: Specifies the high-temperature alarming threshold in Celsius degrees. This threshold must be greater than the warning threshold. To view the value range, enter a question mark (?) in the place of this argument.
When the device temperature drops below the low-temperature threshold or reaches the high-temperature warning or alarming threshold, the device performs the following operations:
·     Sends log messages and traps.
·     Sets LEDs on the device panel.
# Set temperature alarm thresholds for hotspot sensor 1 in a slot.
[Sysname] temperature-limit slot 1 hotspot 1 -10 50 60
display environment
time at
Use time at to specify an execution date and time for a non-periodic schedule.
Use undo time to delete the execution date and time configuration for a non-periodic schedule.
time at time date
undo time
No execution time or date is specified for a non-periodic schedule.
Schedule view
context-admin
time: Specifies the schedule execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the schedule execution date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
The specified time (date plus time) must be later than the current system time.
The time at command, the time once command, and the time repeating command overwrite one another. The most recently executed command takes effect.
# Configure the device to execute schedule saveconfig at 01:01 a.m. on May 11, 2015.
[Sysname-schedule-saveconfig] time at 1:1 2015/05/11
scheduler schedule
time once
Use time once to specify one or more execution days and the execution time for a non-periodic schedule.
Use undo time to delete the execution day and time configuration for a non-periodic schedule.
time once delay time
undo time
No execution time or day is specified for a non-periodic schedule.
Schedule view
context-admin
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
month-date month-day: Specifies a day in the current month, in the range of 1 to 31. If you specify a day that does not exist in the current month, the configuration takes effect on that day in the next month.
week-day week-day&<1-7>: Specifies a space-separated list of up to seven week days for the schedule. Valid week day values include Mon, Tue, Wed, Thu, Fri, Sat, and Sun.
delay time: Specifies the delay time for executing the schedule, in the hh:mm or mm format. This argument can have up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
If the specified time has already occurred, the schedule will be executed at the specified time the following day.
If the day in the month has already occurred, the schedule will be executed at the specified day in the following month.
If the specified day in a week has already occurred, the schedule will be executed at the specified day in the following week.
# Configure the device to execute schedule saveconfig once at 15:00.
[Sysname-schedule-saveconfig] time once at 15:00
Schedule starts at 15:00 5/11/2011.
# Configure the device to execute schedule saveconfig once at 15:00 on the coming 15th day in a month.
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# Configure the device to execute schedule saveconfig at 12:00 p.m. on the coming Monday and Friday.
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# Configure the device to execute schedule saveconfig after 10 minutes.
[Sysname-schedule-saveconfig] time once delay 10
scheduler schedule
time repeating
Use time repeating to specify an execution time table for a periodic schedule.
Use undo time to delete the execution time table configuration for a periodic schedule.
time repeating [ at time [ date ] ] interval interval
undo time
No execution time table is specified for a periodic schedule.
Schedule view
context-admin
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. If you do not specify this option, the current system time is used as the execution time.
date: Specifies the start date for the periodic schedule, in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month. If you do not specify this argument, the execution start date is the first day when the specified time arrives.
interval interval: Specifies the execution time interval in the hh:mm or mm format. This argument can have up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59. When in the mm format, this argument must be equal to or greater than 1 minute.
month-date [ month-day | last ]: Specifies a day in a month, in the range 1 to 31. The last keyword indicates the last day of a month. If you specify a day that does not exist in a month, the configuration takes effect on that day in the next month.
The time repeating [ at time [ date ] ] interval interval command configures the device to execute a schedule at intervals from the specified time on.
The time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ] command configures the device to execute a schedule at the specified time on every specified day in a month or week.
The time at command, the time once command, and the time repeating command overwrite one another, whichever is executed most recently takes effect.
# Configure the device to execute schedule saveconfig once an hour from 8:00 a.m. on.
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# Configure the device to execute schedule saveconfig at 12:00 p.m. every day.
[Sysname-schedule-saveconfig] time repeating at 12:00
# Configure the device to execute schedule saveconfig at 8:00 a.m. on the 5th of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# Configure the device to execute schedule saveconfig at 8:00 a.m. on the last day of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# Configure the device to execute schedule saveconfig at 8:00 a.m. every Friday and Saturday.
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
scheduler schedule
usb disable
Use usb disable to disable USB interfaces.
Use undo usb disable to enable USB interfaces.
usb disable
undo usb disable
All USB interfaces are enabled.
You can use USB interfaces to upload or download files. By default, all USB interfaces are enabled.
Before executing this command, use the umount command to unmount all USB file systems.
# Enable USB interfaces.
[Sysname] undo usb disable
user-role
Use user-role to assign user roles to a schedule.
Use undo user-role to remove user roles from a schedule.
user-role role-name
undo user-role role-name
A schedule has the user roles of the schedule creator.
Schedule view
context-admin
role-name: Specifies a user role name, a case-sensitive string of 1 to 63 characters. The user role can be user-defined or predefined. Predefined user roles include network-admin, network-operator, context-admin, context-operator, and level-0 to level-15.
A schedule must have one or more user roles. A command in a schedule can be executed if it is permitted by one or more user roles of the schedule. For more information about user roles, see the RBAC configuration in Fundamentals Configuration Guide.
A schedule can have a maximum of 64 user roles. After the limit is reached, you cannot assign additional user roles to the schedule.
# Assign user role rolename to schedule test.
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
command
scheduler schedule
