01-Fundamentals Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath F1000[F5000] Firewalls Series Command Reference(V7)-6W90001-Fundamentals Command Reference
02-RBAC commands
02-RBAC commands 302.51 KB
RBAC commands
Non-default vSystems do not support some of the RBAC commands. For information about vSystem support for a command, see the usage guidelines on that command. For information about vSystem, see Virtual Technologies Configuration Guide.
description
Use description to configure a description for a user role for easy identification.
A user role does not have a description.
User role view
context-admin
vsys-admin
text: Specifies a description, a case-sensitive string of 1 to 128 characters.
# Configure the description as labVIP for user role role1.
[Sysname] role name role1
[Sysname-role-role1] description labVIP
display role
role
display role
Use display role to display user role information.
display role [ name role-name ]
context-admin
context-operator
vsys-admin
vsys-operator
name role-name: Specifies a user role name, a case-sensitive string of 1 to 63 characters. If you do not specify a user role name, the command displays information about all user roles, including the predefined user roles.
# Display information about user role 123.
<Sysname> display role name 123
Role: 123
  Description: new role
  VLAN policy: Permit (default)
  Interface policy: Permit (default)
  VPN instance policy: Permit (default)
  Security zone policy: Permit (default)
# Display information about all user roles.
Role: network-admin
  Description: Predefined network admin role has access to all commands on the device
  Rule    Perm   Type  Scope         Entity
  sys-1   permit       command       *
  sys-2   permit RWX   web-menu      -
  sys-3   permit RWX   xml-element   -
  sys-4   deny         command       display security-logfile summary
  sys-5   deny         command       system-view ; info-center securi
                                     ty-logfile directory *
  sys-6   deny         command       security-logfile save
  sys-7   permit RW-   oid           1
  R:Read W:Write X:Execute
Role: network-operator
  Description: Predefined network operator role has access to all read commands on the device
  sys-1   permit       command       display *
  sys-2   permit       command       xml
  sys-3   deny         command       display history-command all
  sys-4   deny         command       display exception *
  sys-5   deny         command       display cpu-usage configuration
  sys-6   deny         command       display kernel exception *
  sys-7   deny         command       display kernel deadloop *
  sys-8   deny         command       display kernel starvation *
  sys-9   deny         command       display kernel reboot *
  sys-12  permit       command       system-view ; local-user *
  sys-13  permit       command       system-view ; switchto *
  sys-14  permit R--   web-menu      -
  sys-15  permit RW-   web-menu      m_device/m_maintenance/m_changep
                                     assword
  sys-16  permit R--   xml-element   -
  sys-17  deny         command       display security-logfile summary
  sys-18  deny         command       system-view ; info-center securi
  sys-19  deny         command       security-logfile save
  sys-20  deny         command       system-view ; local-user-import
  sys-21  deny         command       system-view ; local-user-export
  sys-22  permit R--   oid           1
Role: context-admin
  Description: Predefined context admin role has access to all commands within a context
  sys-4   deny   RWX   feature       context
  sys-5   permit       command       display context *
  sys-6   deny         command       display security-logfile summary
  sys-7   deny         command       system-view ; info-center securi
  sys-8   deny         command       security-logfile save
  sys-9   permit RW-   oid           1
Role: context-operator
  Description: Predefined context operator role has access to all read commands within a context
  sys-13  permit R--   web-menu      -
  sys-14  permit RW-   web-menu      m_device/m_maintenance/m_changep
                                     assword
  sys-15  permit R--   xml-element   -
  sys-16  deny         command       display security-logfile summary
  sys-17  deny         command       system-view ; info-center securi
  sys-18  deny         command       security-logfile save
  sys-19  permit R--   oid           1
Role: level-0
  Description: Predefined level-0 role
  sys-1   permit       command       tracert *
  sys-2   permit       command       telnet *
  sys-3   permit       command       ping *
  sys-4   permit       command       ssh2 *
  sys-5   permit       command       super *
Role: level-1
  Description: Predefined level-1 role
  sys-5   permit       command       display *
  sys-6   permit       command       super *
  sys-7   deny         command       display history-command all
Role: level-2
  Description: Predefined level-2 role
Role: level-3
  Description: Predefined level-3 role
Role: level-4
  Description: Predefined level-4 role
Role: level-5
  Description: Predefined level-5 role
Role: level-6
  Description: Predefined level-6 role
Role: level-7
  Description: Predefined level-7 role
Role: level-8
  Description: Predefined level-8 role
Role: level-9
  Description: Predefined level-9 role
  sys-1   permit RWX   feature       -
  sys-2   deny   RWX   feature       device
  sys-3   deny   RWX   feature       filesystem
  sys-4   permit       command       display *
  sys-5   deny         command       display history-command all
Role: level-10
  Description: Predefined level-10 role
Role: level-11
  Description: Predefined level-11 role
Role: level-12
  Description: Predefined level-12 role
Role: level-13
  Description: Predefined level-13 role
Role: level-14
  Description: Predefined level-14 role
Role: level-15
  Description: Predefined level-15 role
Role: security-audit
  Description: Predefined security audit role only has access to commands for the security log administrator
  sys-1   deny         command       *
  sys-2   permit       command       display security-logfile summary
  sys-3   permit       command       system-view ; info-center securi
  sys-4   permit       command       security-logfile save
  sys-5   permit       command       cd *
  sys-6   permit       command       copy *
  sys-7   permit       command       delete *
  sys-8   permit       command       dir *
  sys-9   permit       command       mkdir *
  sys-10  permit       command       more *
  sys-11  permit       command       move *
  sys-12  permit       command       rmdir *
  sys-13  permit       command       pwd
  sys-14  permit       command       rename *
  sys-15  permit       command       undelete *
  sys-16  permit       command       ftp *
  sys-17  permit       command       sftp *
Role: guest-manager
  Description: Predefined guest manager role can't access to commands
  sys-1   permit RWX   xml-element   useraccounts/approveguest/
  sys-2   permit RWX   xml-element   useraccounts/exportguestaccount/
  sys-3   permit RWX   xml-element   useraccounts/generateguestaccoun
                                     t/
  sys-4   permit RWX   xml-element   useraccounts/guest/
  sys-5   permit RWX   xml-element   useraccounts/guestconfigure/
  sys-6   permit RWX   xml-element   useraccounts/importguestaccount/
  sys-7   permit RWX   xml-element   useraccounts/exportguesttemplet/
  sys-8   permit RWX   xml-element   rpc/
  sys-9   permit RWX   web-menu      m_global/m_networksecurity/m_gue
                                     stmanage/m_guestlist/
  sys-10  permit RWX   web-menu      m_global/m_networksecurity/m_gue
                                     stmanage/m_importguest/
  sys-11  permit RWX   web-menu      m_global/m_networksecurity/m_gue
                                     stmanage/m_generateguest/
  sys-12  permit RWX   web-menu      m_global/m_networksecurity/m_gue
                                     stmanage/m_approveguest/
  sys-13  deny         command       *
Role: system-admin
  Description: Predefined system admin role only has access to commands for the system administrator
  sys-1   permit RWX   web-menu      dashboard/
  sys-2   permit RWX   web-menu      m_monitor/m_monitorlog/m_syslog
  sys-3   permit RWX   web-menu      m_network/m_ipservice/m_http
  sys-4   permit RWX   web-menu      m_device/m_virtualdevice/m_clust
                                     er
  sys-5   permit RWX   web-menu      m_device/m_virtualdevice/m_conte
                                     xt/
  sys-6   permit RWX   web-menu      m_device/m_highavailability/m_ho
                                     tbackup
  sys-7   permit RWX   web-menu      m_device/m_highavailability/m_vr
                                     rp
  sys-8   permit RWX   web-menu      m_device/m_highavailability/m_tr
                                     ack
  sys-9   permit RWX   web-menu      m_device/m_highavailability/m_nq
                                     a
  sys-10  permit RWX   web-menu      m_device/m_highavailability/m_bf
                                     d
  sys-11  permit RWX   web-menu      m_device/m_highavailability/m_vr
                                     rpinterface
  sys-12  permit RWX   web-menu      m_device/m_logconf/m_basiclog
  sys-13  permit RWX   web-menu      m_device/m_logconf/m_lblog
  sys-14  permit RWX   web-menu      m_device/m_reportconf/m_lb_expor
                                     tform
  sys-15  permit RWX   web-menu      m_device/m_logconf/m_emailserver
  sys-16  permit RWX   web-menu      m_device/m_logconf/m_natlog
  sys-17  permit RWX   web-menu      m_device/m_logconf/m_sessionlog
  sys-18  permit RWX   web-menu      m_device/m_logconf/m_atkadvancel
                                     og
  sys-19  permit RWX   web-menu      m_device/m_logconf/m_ipreputatio
                                     nlog
  sys-20  permit RWX   web-menu      m_device/m_logconf/m_threatenlog
  sys-21  permit RWX   web-menu      m_device/m_logconf/m_urlfilterlo
                                     g
  sys-22  permit RWX   web-menu      m_device/m_logconf/m_waflog
  sys-23  permit RWX   web-menu      m_device/m_logconf/m_auditlog
  sys-24  permit RWX   web-menu      m_device/m_logconf/m_netsharelog
  sys-25  permit RWX   web-menu      m_device/m_logconf/m_bandwidthal
                                     arm
  sys-26  permit RWX   web-menu      m_device/m_diagnosis/m_ipsecdiag
  sys-27  permit RWX   web-menu      m_device/m_logconf/m_securitypol
                                     icylog
  sys-28  permit RWX   web-menu      m_device/m_logconf/m_heartbeatlo
                                     g
  sys-29  permit RWX   web-menu      m_device/m_logconf/m_avclog
  sys-30  permit RWX   web-menu      m_device/m_logconf/m_aftlog
  sys-31  permit RWX   web-menu      m_device/m_logconf/m_iplog
  sys-32  permit RWX   web-menu      m_device/m_logconf/m_maclog
  sys-33  permit RWX   web-menu      m_device/m_logconf/m_sandboxlog
  sys-34  permit RWX   web-menu      m_device/m_logconf/m_terminalala
                                     rmlog
  sys-35  permit RWX   web-menu      m_device/m_logconf/m_cfgadvancel
                                     og
  sys-36  permit RWX   web-menu      m_device/m_logconf/m_bandwidthal
                                     armsettings
  sys-37  permit RWX   web-menu      m_device/m_reportconf/m_reportsu
                                     bscription
  sys-38  permit RWX   web-menu      m_device/m_reportconf/m_mailserv
                                     erconfig
  sys-39  permit RWX   web-menu      m_device/m_sessionagingtimeset/m
                                     _protocolstatesessionagingtime
  sys-40  permit RWX   web-menu      m_device/m_sessionagingtimeset/m
                                     _appagingtime
  sys-41  permit RWX   web-menu      m_device/m_sessionagingtimeset/m
                                     _sessionsettings
  sys-42  permit RWX   web-menu      m_device/m_signatureupgrade/m_up
                                     gradecenter
  sys-43  permit RWX   web-menu      m_device/m_signatureupgrade/m_up
                                     grade
  sys-44  permit RWX   web-menu      m_device/m_license
  sys-45  permit RWX   web-menu      m_device/m_maintenance/m_devices
                                     ettings/
  sys-46  permit RWX   web-menu      m_device/m_maintenance/m_macreco
                                     gnition/
  sys-47  permit RWX   web-menu      m_device/m_maintenance/m_snmp
  sys-48  permit RWX   web-menu      m_device/m_maintenance/m_config
  sys-49  permit RWX   web-menu      m_device/m_maintenance/m_reboot
  sys-50  permit RWX   web-menu      m_device/m_maintenance/m_about/
  sys-51  permit RWX   web-menu      m_device/m_diagnosis/m_pcapware
  sys-52  permit RWX   web-menu      m_device/m_diagnosis/m_webdiag
  sys-53  permit RWX   web-menu      m_device/m_diagnosis/m_diagnosti
                                     c
  sys-54  permit RWX   web-menu      m_device/m_diagnosis/m_troublesh
                                     oot
  sys-55  permit RWX   web-menu      m_device/m_configguide/m_interne
                                     tguide
  sys-56  permit RWX   web-menu      m_device/m_maintenance/m_changep
                                     assword
  sys-57  permit RWX   web-menu      m_device/m_diagnosis/m_lbschedul
                                     etest
  sys-58  permit RWX   web-menu      m_device/m_adminuser/m_admin
  sys-59  permit RWX   web-menu      m_device/m_adminuser/m_rbacrole
  sys-60  permit       command       tracert *
  sys-61  permit       command       ping *
Role: security-admin
  Description: Predefined security admin role only has access to commands for the security administrator
  sys-1   permit RWX   web-menu      m_monitor/m_atklog/m_blacklistlo
                                     g
  sys-2   permit RWX   web-menu      m_monitor/m_atklog/m_terminallog
  sys-3   permit RWX   web-menu      m_monitor/m_videosafe/m_videohot
  sys-4   permit RWX   web-menu      m_monitor/m_atklog/m_singleatk
  sys-5   permit RWX   web-menu      m_monitor/m_atklog/m_scanatk
  sys-6   permit RWX   web-menu      m_monitor/m_atklog/m_floodatk
  sys-7   permit RWX   web-menu      m_monitor/m_atklog/m_threatlog
  sys-8   permit RWX   web-menu      m_monitor/m_riskassets
  sys-9   permit RWX   web-menu      m_monitor/m_botnetlog
  sys-10  permit RWX   web-menu      m_monitor/m_threatanalysis
  sys-11  permit RWX   web-menu      m_monitor/m_atklog/m_urllog
  sys-12  permit RWX   web-menu      m_monitor/m_atklog/m_filefilterl
                                     og
  sys-13  permit RWX   web-menu      m_monitor/m_atklog/m_zonepairlog
  sys-14  permit RWX   web-menu      m_monitor/m_atklog/m_aptlog
  sys-15  permit RWX   web-menu      m_monitor/m_atklog/m_natflowlog
  sys-16  permit RWX   web-menu      m_monitor/m_atklog/m_sslvpnuserl
                                     og
  sys-17  permit RWX   web-menu      m_monitor/m_atklog/m_sslvpnresou
                                     rcelog
  sys-18  permit RWX   web-menu      m_monitor/m_auditlogs/m_auditimc
                                     hatlog
  sys-19  permit RWX   web-menu      m_monitor/m_auditlogs/m_auditcom
                                     munitylog
  sys-20  permit RWX   web-menu      m_monitor/m_auditlogs/m_auditsea
                                     rchenginelog
  sys-21  permit RWX   web-menu      m_monitor/m_auditlogs/m_auditmai
                                     llog
  sys-22  permit RWX   web-menu      m_monitor/m_auditlogs/m_auditfil
                                     etransferlog
  sys-23  permit RWX   web-menu      m_monitor/m_auditlogs/m_auditrel
                                     axstocklog
  sys-24  permit RWX   web-menu      m_monitor/m_auditlogs/m_auditoth
                                     erapplog
  sys-25  permit RWX   web-menu      m_monitor/m_monitorlog/m_traffic
                                     log
  sys-26  permit RWX   web-menu      m_monitor/m_online/m_ipv4user
  sys-27  permit RWX   web-menu      m_monitor/m_online/m_ipv6user
  sys-28  permit RWX   web-menu      m_monitor/m_online/m_macuser
  sys-29  permit RWX   web-menu      m_monitor/m_rank/m_trafficrank/
  sys-30  permit RWX   web-menu      m_monitor/m_rank/m_threadrank/
  sys-31  permit RWX   web-menu      m_monitor/m_rank/m_urlfilterrank
  sys-32  permit RWX   web-menu      m_monitor/m_rank/m_ffilterrank/
  sys-33  permit RWX   web-menu      m_monitor/m_rank/m_secpolicytarg
                                     etrank
  sys-34  permit RWX   web-menu      m_monitor/m_rank/m_securityaudit
  sys-35  permit RWX   web-menu      m_monitor/m_rank/m_lb_serverrepo
                                     rt/
  sys-36  permit RWX   web-menu      m_monitor/m_rank/m_lb_linkreport
  sys-37  permit RWX   web-menu      m_monitor/m_rank/m_lb_dnsproxyre
                                     port/
  sys-38  permit RWX   web-menu      m_monitor/m_rank/m_dropstats
  sys-39  permit RWX   web-menu      m_monitor/m_trend/m_traffictrend
  sys-40  permit RWX   web-menu      m_monitor/m_trend/m_threadtrend/
  sys-41  permit RWX   web-menu      m_monitor/m_trend/m_urlfiltertre
                                     nd/
  sys-42  permit RWX   web-menu      m_monitor/m_trend/m_ffiltertrend
  sys-43  permit RWX   web-menu      m_monitor/m_trend/m_lb_linktrend
  sys-44  permit RWX   web-menu      m_monitor/m_trend/m_lb_linkpolic
                                     y/
  sys-45  permit RWX   web-menu      m_monitor/m_trend/m_lb_vstrend/
  sys-46  permit RWX   web-menu      m_monitor/m_trend/m_lb_serfarmtr
                                     end/
  sys-47  permit RWX   web-menu      m_monitor/m_trend/m_lb_realsertr
                                     end/
  sys-48  permit RWX   web-menu      m_monitor/m_trend/m_dnsdomaintre
                                     nd/
  sys-49  permit RWX   web-menu      m_monitor/m_trend/m_secpolicytar
                                     gettrend/
  sys-50  permit RWX   web-menu      m_monitor/m_trend/m_lb_urltrend
  sys-51  permit RWX   web-menu      m_monitor/m_cdas
  sys-52  permit RWX   web-menu      m_monitor/m_trend/m_sslvpn_usert
                                     rend
  sys-53  permit RWX   web-menu      m_monitor/m_report
  sys-54  permit RWX   web-menu      m_monitor/m_session
  sys-55  permit RWX   web-menu      m_monitor/m_lbsessioninfo
  sys-56  permit RWX   web-menu      m_monitor/m_userinfocenter
  sys-57  permit RWX   web-menu      m_monitor/m_lb_dnscaches
  sys-58  permit RWX   web-menu      m_policy/m_firewall/m_secpolicy
  sys-59  permit RWX   web-menu      m_policy/m_firewall/m_targetpoli
                                     cy
  sys-60  permit RWX   web-menu      m_policy/m_firewall/m_redundancy
                                     rules
  sys-61  permit RWX   web-menu      m_policy/m_firewall/m_appoptimit
                                     ed
  sys-62  permit RWX   web-menu      m_policy/m_nat66
  sys-63  permit RWX   web-menu      m_policy/m_attackdefense/m_atkpo
                                     licy
  sys-64  permit RWX   web-menu      m_policy/m_attackdefense/m_riska
                                     nalysis
  sys-65  permit RWX   web-menu      m_policy/m_attackdefense/m_clien
                                     tverifyprotectip
  sys-66  permit RWX   web-menu      m_policy/m_attackdefense/m_black
                                     listmanual
  sys-67  permit RWX   web-menu      m_policy/m_attackdefense/m_white
                                     listmanual
  sys-68  permit RWX   web-menu      m_policy/m_attackdefense/m_clien
                                     tverifyzone
  sys-69  permit RWX   web-menu      m_policy/m_attackdefense/m_connl
                                     imitpolicies
  sys-70  permit RWX   web-menu      m_policy/m_attackdefense/m_iplim
                                     it
  sys-71  permit RWX   web-menu      m_monitor/m_rank/m_topn
  sys-72  permit RWX   web-menu      m_policy/m_attackdefense/m_urpf/
  sys-73  permit RWX   web-menu      m_policy/m_threatintelligence/m_
                                     ipreputation
  sys-74  permit RWX   web-menu      m_policy/m_nat/m_natbasicchange
  sys-75  permit RWX   web-menu      m_policy/m_nat/m_natglobalpolicy
  sys-76  permit RWX   web-menu      m_policy/m_nat/m_natoutboundconf
                                     ig/
  sys-77  permit RWX   web-menu      m_policy/m_nat/m_natserverconfig
  sys-78  permit RWX   web-menu      m_policy/m_nat/m_natstaticchange
  sys-79  permit RWX   web-menu      m_policy/m_nat/m_natoutbound444c
                                     onfig/
  sys-80  permit RWX   web-menu      m_policy/m_nat/m_natoutboundstat
                                     ic444config/
  sys-81  permit RWX   web-menu      m_policy/m_nat/m_natsettings/
  sys-82  permit RWX   web-menu      m_policy/m_aft/m_aftaddrgrp
  sys-83  permit RWX   web-menu      m_policy/m_aft/m_aftnat64
  sys-84  permit RWX   web-menu      m_policy/m_aft/m_aftoutbound
  sys-85  permit RWX   web-menu      m_policy/m_aft/m_aftset
  sys-86  permit RWX   web-menu      m_policy/m_appaudit/m_auditpolic
                                     y
  sys-87  permit RWX   web-menu      m_policy/m_appaudit/m_keywordgro
                                     ups
  sys-88  permit RWX   web-menu      m_policy/m_bandwidthmanagement/m
                                     _bandwidthpolicy
  sys-89  permit RWX   web-menu      m_policy/m_bandwidthmanagement/m
                                     _bandwidthchannel
  sys-90  permit RWX   web-menu      m_policy/m_bandwidthmanagement/m
                                     _interfacebandwidth
  sys-91  permit RWX   web-menu      m_policy/m_loadbalance/m_lb_glob
                                     alconfig/
  sys-92  permit RWX   web-menu      m_policy/m_loadbalance/m_lb_serv
                                     er/
  sys-93  permit RWX   web-menu      m_policy/m_loadbalance/m_lb_link
  sys-94  permit RWX   web-menu      m_policy/m_scd
  sys-95  permit RWX   web-menu      m_policy/m_proxymanagement/m_pro
                                     xypolicy
  sys-96  permit RWX   web-menu      m_policy/m_proxymanagement/m_whi
                                     telisthostname
  sys-97  permit RWX   web-menu      m_policy/m_proxymanagement/m_ssl
                                     certificate
  sys-98  permit RWX   web-menu      m_resource/m_healthmonitor
  sys-99  permit RWX   web-menu      m_policy/m_netshare/m_netsharepo
                                     licy
  sys-100 permit RWX   web-menu      m_policy/m_netshare/m_netsharest
                                     atus
  sys-101 permit RWX   web-menu      m_resource/m_user/m_usercontrol/
  sys-102 permit RWX   web-menu      m_resource/m_user/m_authenticati
                                     on/
  sys-103 permit RWX   web-menu      m_resource/m_user/m_access/
  sys-104 permit RWX   web-menu      m_resource/m_dpi/m_ipscfg/
  sys-105 permit RWX   web-menu      m_resource/m_dpi/m_wafcfg/
  sys-106 permit RWX   web-menu      m_resource/m_dpi/m_antiviruscfg/
  sys-107 permit RWX   web-menu      m_resource/m_dpi/m_dfltcfg/
  sys-108 permit RWX   web-menu      m_resource/m_dpi/m_ufltcfg/
  sys-109 permit RWX   web-menu      m_resource/m_dpi/m_ffltcfg/
  sys-110 permit RWX   web-menu      m_resource/m_dpi/m_aptcfg/
  sys-111 permit RWX   web-menu      m_resource/m_dpi/m_apprecognitio
                                     n/
  sys-112 permit RWX   web-menu      m_resource/m_dpi/m_terminal/
  sys-113 permit RWX   web-menu      m_resource/m_dpi/m_securityactio
                                     n/
  sys-114 permit RWX   web-menu      m_resource/m_dpi/m_dpicfg
  sys-115 permit RWX   web-menu      m_resource/m_objectgroup/m_ipv4o
                                     bjectgroup
  sys-116 permit RWX   web-menu      m_resource/m_objectgroup/m_ipv6o
                                     bjectgroup
  sys-117 permit RWX   web-menu      m_resource/m_objectgroup/m_macob
                                     jectgroup
  sys-118 permit RWX   web-menu      m_resource/m_objectgroup/m_servi
                                     ceobjectgroup
  sys-119 permit RWX   web-menu      m_resource/m_objectgroup/m_timer
                                     ange
  sys-120 permit RWX   web-menu      m_resource/m_acl/m_ipv4acl
  sys-121 permit RWX   web-menu      m_resource/m_acl/m_ipv6acl
  sys-122 permit RWX   web-menu      m_resource/m_acl/m_macacl
  sys-123 permit RWX   web-menu      m_resource/m_ssl/m_sslserver
  sys-124 permit RWX   web-menu      m_resource/m_ssl/m_sslclient
  sys-125 permit RWX   web-menu      m_resource/m_ssl/m_ssladvanceset
                                     tiing
  sys-126 permit RWX   web-menu      m_resource/m_publickey/m_publick
                                     eylocal
  sys-127 permit RWX   web-menu      m_resource/m_publickey/m_publick
                                     eypeer
  sys-128 permit RWX   web-menu      m_resource/m_pki_cert/m_pki
  sys-129 permit RWX   web-menu      m_resource/m_pki_cert/m_certific
                                     atepolicy
  sys-130 permit RWX   web-menu      m_resource/m_pki_cert/m_certific
                                     atesubject
  sys-131 permit RWX   web-menu      m_network/m_eps
  sys-132 permit RWX   web-menu      m_network/m_vrf
  sys-133 permit RWX   web-menu      m_network/m_if/m_interface
  sys-134 permit RWX   web-menu      m_network/m_if/m_inlineall
  sys-135 permit RWX   web-menu      m_network/m_if/m_collaborations
  sys-136 permit RWX   web-menu      m_network/m_if/m_lagg
  sys-137 permit RWX   web-menu      m_network/m_seczone
  sys-138 permit RWX   web-menu      m_network/m_link/m_vlan
  sys-139 permit RWX   web-menu      m_network/m_link/m_mac_sum/
  sys-140 permit RWX   web-menu      m_network/m_dns_sum/m_dnshosts
  sys-141 permit RWX   web-menu      m_network/m_dns_sum/m_dns
  sys-142 permit RWX   web-menu      m_network/m_dns_sum/m_ddns
  sys-143 permit RWX   web-menu      m_network/m_dns_sum/m_dnsadvance
  sys-144 permit RWX   web-menu      m_network/m_arp
  sys-145 permit RWX   web-menu      m_network/m_nd
  sys-146 permit RWX   web-menu      m_network/m_ipfw
  sys-147 permit RWX   web-menu      m_network/m_vpn/m_gre
  sys-148 permit RWX   web-menu      m_network/m_vpn/m_ipsec/
  sys-149 permit RWX   web-menu      m_network/m_vpn/m_advpn/
  sys-150 permit RWX   web-menu      m_network/m_vpn/m_l2tp/
  sys-151 permit RWX   web-menu      m_network/m_secaccess/m_macauth/
  sys-152 permit RWX   web-menu      m_network/m_secaccess/m_ipauth/
  sys-153 permit RWX   web-menu      m_network/m_sslvpn/m_sslvpn_cont
                                     ext
  sys-154 permit RWX   web-menu      m_network/m_sslvpn/m_sslvpn_gate
                                     way
  sys-155 permit RWX   web-menu      m_network/m_sslvpn/m_sslvpn_ipv4
                                     addrpool
  sys-156 permit RWX   web-menu      m_network/m_sslvpn/m_sslvpn_acif
  sys-157 permit RWX   web-menu      m_network/m_sslvpn/m_sslvpn_glob
                                     alconfig
  sys-158 permit RWX   web-menu      m_network/m_sslvpn/m_sslvpn_stat
                                     istics
  sys-159 permit RWX   web-menu      m_network/m_sslvpn/m_sslvpn_temp
                                     management
  sys-160 permit RWX   web-menu      m_network/m_routing/m_routingtab
                                     le
  sys-161 permit RWX   web-menu      m_network/m_routing/m_staticrout
                                     ing
  sys-162 permit RWX   web-menu      m_network/m_routing/m_policyrout
                                     ing/
  sys-163 permit RWX   web-menu      m_network/m_routing/m_ospf
  sys-164 permit RWX   web-menu      m_network/m_routing/m_bgp
  sys-165 permit RWX   web-menu      m_network/m_routing/m_rip
  sys-166 permit RWX   web-menu      m_network/m_multicast/m_multicas
                                     trouting
  sys-167 permit RWX   web-menu      m_network/m_multicast/m_pim
  sys-168 permit RWX   web-menu      m_network/m_multicast/m_igmp
  sys-169 permit RWX   web-menu      m_network/m_multicast/m_ipv6mult
                                     icastrouting
  sys-170 permit RWX   web-menu      m_network/m_multicast/m_mld
  sys-171 permit RWX   web-menu      m_network/m_dhcp/m_dhcpservice
  sys-172 permit RWX   web-menu      m_network/m_dhcp/m_dhcppool
  sys-173 permit RWX   web-menu      m_network/m_ipservice/m_ssh
  sys-174 permit RWX   web-menu      m_network/m_ipservice/m_ntp
  sys-175 permit RWX   web-menu      m_network/m_ipservice/m_ftp
  sys-176 permit RWX   web-menu      m_network/m_ipservice/m_telnet
  sys-177 permit RWX   web-menu      m_device/m_diagnosis/m_ping
  sys-178 permit RWX   web-menu      m_device/m_diagnosis/m_tracert
  sys-179 permit RWX   web-menu      m_device/m_maintenance/m_changep
                                     assword
  sys-180 permit       command       tracert *
  sys-181 permit       command       ping *
Role: audit-admin
  Description: Predefined audit admin role only has access to commands for the audit administrator
  sys-1   permit RWX   web-menu      m_monitor/m_monitorlog/m_operati
                                     onlog
  sys-2   permit RWX   web-menu      m_device/m_maintenance/m_changep
                                     assword
  sys-3   permit       command       tracert *
  sys-4   permit       command       ping *
Role
User role name.
Predefined user role names:
·     network-admin.
·     network-operator.
·     context-admin.
·     context-operator.
·     level-n (where n represents an integer in the range of 0 to 15).
·     security-audit.
·     guest-manager.
·     system-admin.
·     security-admin.
·     audit-admin.
User role description.
VLAN policy
VLAN policy for the user role:
·     Deny—Denies access to any VLANs except for permitted VLANs.
·     Permit (default)—Default VLAN policy, which enables the user role to access all VLANs.
Permitted VLANs
VLANs accessible to the user role.
Interface policy
Interface policy for the user role:
·     Deny—Denies access to any interfaces except for permitted interfaces.
·     Permit (default)—Default interface policy, which enables the user role to access all interfaces.
Permitted interfaces
Interfaces accessible to the user role.
VPN instance policy
VPN instance policy for the user role:
·     Deny—Denies access to any VPN instances except for permitted VPN instances.
·     Permit (default)—Default VPN instance policy, which enables the user role to access all VPN instances.
Permitted VPN instances
VPN instances accessible to the user role.
Security zone policy for the user role:
·     Deny—Denies access to any security zones except for permitted security zones.
·     Permit (default)—Default security zone policy, which enables the user role to access all security zones.
Permitted security zones
Security zones accessible to the user role.
Rule
User role rule number.
Predefined user role rules are identified by sys-n, where n represents an integer.
Perm
Access control type:
·     Permit—User role has access to the items in the Entity field.
·     Deny—User role does not have access to the items in the Entity field.
Controlled type:
·     R—Read-only.
·     W—Write.
·     X—Execute.
Scope
Rule control scope:
·     command—Controls access to the command or commands, as specified in the Entity field.
·     feature—Controls access to the commands of the feature, as specified in the Entity field.
·     feature-group—Controls access to the commands of the features in the feature group, as specified in the Entity field.
·     web-menu—Controls access to Web menus.
·     xml-element—Controls access to XML elements. ‌
·     oid—Controls access to MIB nodes.
Entity
Command string, feature name, feature group, OID, Web menu, or XML element specified in the user role rule:
·     An en dash (–) represents any feature.
·     An asterisk (*) represents zero or more characters.
role
display role feature
Use display role feature to display features available in the system.
display role feature [ name feature-name | verbose ]
context-admin
context-operator
vsys-admin
vsys-operator
name feature-name: Specifies a feature by feature name. The feature-name argument represents the feature name, and all letters must be in lower case.
verbose: Displays the commands of each feature.
If you do not specify any parameters, the command displays only the list of features available in the system.
# Display the list of feature names.
<Sysname> display role feature
Feature: device          (Device configuration related commands)
Feature: interface       (Interface related commands)
Feature: syslog          (Syslog related commands)
# Display the commands of each feature.
<Sysname> display role feature verbose
  display clock    (R)
  debugging dev    (W)
  display debugging dev    (R)
  display device *    (R)
  display diagnostic-information *    (R)
  display environment *    (R)
  display fan *    (R)
  display alarm *    (R)
  display power *    (R)
  display current-configuration *    (R)
  display saved-configuration *    (R)
  display default-configuration *    (R)
  display startup    (R)
  display this *    (R)
# Display the commands of feature aaa.
<Sysname> display role feature name aaa
Feature: aaa             (AAA related commands)
  system-view ; domain *    (W)
  system-view ; header *    (W)
  system-view ; aaa *    (W)
  display domain *    (R)
  system-view ; user-group *    (W)
  system-view ; local-user *    (W)
  display local-user *    (R)
  display user-group *    (R)
  display debugging local-server    (R)
  debugging local-server *    (W)
  super *    (X)
  display password-control *    (R)
  reset password-control *    (W)
  system-view ; password-control *    (W)
Table 2 Command output (display role feature name aaa)
Feature
Displays the name and brief function description of the feature.
All commands that start with the domain keyword in system view, and all commands in ISP domain view.
All commands that start with the header keyword in system view.
system-view ; aaa *
All commands that start with the aaa keyword in system view.
display domain *
All commands that start with the display domain keywords in user view.
All commands that start with the user-group keyword in system view, and all commands in user group view.
All commands that start with the local-user keyword in system view, and all commands in local user view.
All commands that start with the display local-user keywords in user view.
All commands that start with the display user-group keywords in user view.
All commands that start with the display debugging local-server keywords in user view.
All commands that start with the debugging local-server keywords in user view.
super *
All commands that start with the super keyword in user view.
All commands that start with the display password-control keywords in user view.
All commands that start with the reset password-control keywords in user view.
All commands that start with the password-control keyword in system view.
(W)
Command type is Write. A write command configures the system.
(R)
Command type is Read. A read command displays configuration or maintenance information.
(X)
Command type is Execute. An execute command executes a specific function.
feature
display role feature-group
Use display role feature-group to display feature group information.
display role feature-group [ name feature-group-name ] [ verbose ]
context-admin
context-operator
vsys-admin
vsys-operator
name feature-group-name: Specifies a feature group. The feature-group-name argument represents the feature group name, a case-sensitive string of 1 to 31 characters. If you do not specify a feature group, the command displays information about all feature groups.
verbose: Displays the commands of each feature in feature groups. If you do not specify this keyword, the command displays only the feature lists of feature groups.
Feature groups L2 and L3 are predefined feature groups.
# Display the feature lists of feature groups.
<Sysname> display role feature-group
Feature group: L2
Feature: igmp-snooping   (IGMP-Snooping related commands)
Feature: mld-snooping    (MLD-Snooping related commands)
Feature: lacp            (LACP related commands)
Feature: stp             (STP related commands)
Feature: lldp            (LLDP related commands)
Feature: dldp            (DLDP related commands)
Feature: smart-link      (Smart-link related commands)
Feature: monitor-link    (Monitor-link related commands)
Feature: loopbk-detect   (Loopback-detection related commands)
Feature: vlan            (Virtual LAN related commands)
Feature: evb             (EVB related commands)
Feature: ofp             (OFP related commands)
Feature group: L3
Feature: route           (Route management related commands)
Feature: usr             (Unicast static route related commands)
Feature: ospf            (Open Shortest Path First protocol related commands)
Feature: rip             (Routing Information Protocol related commands)
Feature: isis            (ISIS protocol related commands)
Feature: lisp            (LISP protocol related commands)
Feature: bgp             (Border Gateway Protocol related commands)
Feature: l3vpn           (Layer 3 Virtual Private Network related commands)
Feature: route-policy    (Routing Policy related commands)
Feature: multicast       (Multicast related commands)
Feature: pim             (Protocol Independent Multicast related commands)
Feature: igmp            (Internet Group Management Protocol related commands)
Feature: mld             (Multicast Listener Discovery related commands)
# Display the commands in each feature group. For more information about the wildcards and marks used in the command list, see Table 2.
<Sysname> display role feature-group verbose
Feature group: L2
  display l2-multicast *    (R)
  system-view ; probe ; display system internal l2-multicast *    (R)
  reset l2-multicast *    (W)
  display ipv6 l2-multicast *    (R)
  system-view ; probe ; display system internal ipv6 l2-multicast *    (R)
  reset ipv6 l2-multicast *    (W)
  display link-aggregation *    (R)
  display lacp *    (R)
  system-view ; interface Bridge-Aggregation *    (W)
  system-view ; interface Route-Aggregation *    (W)
  system-view ; link-aggregation *    (W)
  system-view ; lacp *    (W)
  system-view ; interface * ; link-aggregation *    (W)
  system-view ; interface * ; port link-aggregation *    (W)
  system-view ; interface * ; lacp *    (W)
  system-view ; probe ; display system internal link-aggregation *    (R)
  system-view ; probe ; debugging system internal link-aggregation *    (W)
  reset lacp *    (W)
  debugging link-aggregation *    (W)
# Display the feature list of the L3 feature group.
<Sysname> display role feature-group name L3
Feature group: L3
feature
role feature-group
feature
Use feature to add a feature to a feature group.
Use undo feature to remove a feature from a feature group.
feature feature-name
undo feature feature-name
A user-defined feature group does not have any features.
Feature group view
context-admin
feature-name: Specifies a feature name. You must enter the feature name in lower case.
Non-default vSystems do not support this command.
Repeat the feature command to add multiple features to a feature group.
# Add the AAA and ACL features to feature group security-features.
[Sysname] role feature-group name security-features
[Sysname-featuregrp-security-features] feature aaa
[Sysname-featuregrp-security-features] feature acl
role feature-group
interface policy deny
Use interface policy deny to enter the interface policy view for a user role.
Use undo interface policy deny to restore the default.
A user role has access to all interfaces.
User role view
context-admin
vsys-admin
CAUTION
CAUTION:
The interface policy deny command denies a user role access to any interfaces if you do not specify accessible interfaces by using the permit interface command. To configure an interface, make sure that interface is permitted by the interface policy in use.
To limit the scope of interfaces accessible to a user role, perform the following tasks:
1.     Use interface policy deny to enter the interface policy view for the user role.
2.     Use permit interface to specify accessible interfaces.
You can perform the following operations to manage an accessible interface:
·     Create, remove, or configure the interface.
·     Enter interface view.
·     Specify the interface in feature commands.
The create and remove operations are available only for logical interfaces.
Any change to the interface policy for a user role takes effect only on users who log in with the user role after the change.
# Prevent user role role1 from accessing any interfaces.
[Sysname-role-role1] interface policy deny
[Sysname-role-role1-ifpolicy] quit
# Prevent user role role1 from accessing any interfaces except for GigabitEthernet 1/0/1 to GigabitEthernet 1/0/4.
[Sysname-role-role1-ifpolicy] permit interface gigabitethernet 1/0/1 to gigabitethernet 1/0/4
display role
permit interface
role
permit interface
Use permit interface to configure a list of interfaces accessible to a user role.
Use undo permit interface to disable the access of a user role to specific interfaces.
permit interface interface-list
undo permit interface [ interface-list ]
No permitted interfaces are configured in interface policy view.
Interface policy view
context-admin
vsys-admin
interface-list: Specifies a space-separated list of up to 10 interface items. Each interface item specifies one interface in the interface-type interface-number form or a range of interfaces in the interface-type interface-number to interface-type interface-number form. If you specify an interface range, the end interface must meet the following requirements:
·     Be the same type as the start interface.
·     Have a higher interface number than the start interface.
To permit a user role to access an interface after you execute the interface policy deny command, you must add the interface to the permitted interface list of the policy. With the user role, you can perform the following operations to manage the interfaces in the permitted interface list:
·     Create, remove, or configure the interfaces.
·     Enter the interface views.
·     Specify the interfaces in feature commands.
You can repeat the permit interface command to add multiple permitted interfaces to the interface policy for a user role.
The undo permit interface command removes the entire list of permitted interfaces if you do not specify an interface.
1.     Configure user role role1:
# Permit user role role1 to execute all commands available in interface view.
[Sysname-role-role1] rule 1 permit command system-view ; interface *
# Permit user role role1 to execute all commands available in VLAN view.
[Sysname-role-role1] rule 2 permit command system-view ; vlan *
# Permit the user role to access only GigabitEthernet 1/0/1.
[Sysname-role-role1] quit
2.     Verify that you cannot use user role role1 to manage any interfaces except for GigabitEthernet 1/0/1:
# Verify that you can enter GigabitEthernet 1/0/1 interface view.
# Verify that you can assign GigabitEthernet 1/0/1 to VLAN 10. In this example, the user role can access all VLANs because the default VLAN policy for the user role is used.
[Sysname] vlan 10
[Sysname-vlan10] port gigabitethernet 1/0/1
[Sysname-vlan10] quit
# Verify that you cannot enter interface view of GigabitEthernet 1/0/2.
Permission denied.
display role
role
permit security-zone
Use permit security-zone to configure a list of security zones accessible to a user role.
Use undo permit security-zone to remove the permission for a user role to access specific security zones.
permit security-zone security-zone-name&<1-10>
undo permit security-zone [ security-zone-name&<1-10> ]
No permitted security zones are configured in security zone policy view.
Security zone policy view
context-admin
vsys-admin
security-zone-name&<1-10>: Specifies a space-separated list of up to 10 security zone names. Each name is a case-sensitive string of 1 to 31 characters.
To permit a user role to access a security zone after you use the security-zone policy deny command, you must add the security zone to the permitted security zone list of the policy. With the user role, you can perform the following operations to manage the security zones in the permitted security zone list:
·     Create, remove, or configure the security zones.
·     Enter the security zone views.
·     Specify the security zones in feature commands.
You can repeat the permit security-zone command to add multiple permitted security zones to a user role security zone policy.
The undo permit security-zone command removes the entire list of permitted security zones if you do not specify a security zone.
Any change to the security zone policy for a user role takes effect only on users who log in with the user role after the change.
# Permit user role role1 to execute all commands available in system view.
[Sysname-role-role1] rule 1 permit command system-view ; *
# Permit the user role to access security zones trust and abc.
[Sysname-role-role1] security-zone policy deny
[Sysname-role-role1-zonepolicy] permit security-zone trust abc
[Sysname-role-role1-zonepolicy] quit
2.     Verify that you cannot use user role role1 to manage any security zones except for security zones trust and abc:
# Verify that you can create security zone abc and enter security zone view.
[Sysname] security-zone name abc
[Sysname-security-zone-abc] quit
# Verify that you can create a zone pair with source security zone trust and destination zone abc.
[Sysname] zone-pair security source trust destination abc
[Sysname-zone-pair-security-Trust-abc] quit
# Verify that you cannot create security zone local or enter its view.
[Sysname] security-zone name local
Permission denied.
display role
role
permit vlan
Use permit vlan to configure a list of VLANs accessible to a user role.
Use undo permit vlan to remove the permission for a user role to access specific VLANs.
permit vlan vlan-id-list
undo permit vlan [ vlan-id-list ]
No permitted VLANs are configured in VLAN policy view.
VLAN policy view
context-admin
vsys-admin
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each VLAN item specifies a VLAN by VLAN ID or specifies a range of VLANs in the form of vlan-id1 to vlan-id2. The value range for the VLAN IDs is 1 to 4094. If you specify a VLAN range, the value for the vlan-id2 argument must be greater than the value for the vlan-id1 argument.
To permit a user role to access a VLAN after you use the vlan policy deny command, you must add the VLAN to the permitted VLAN list of the policy. With the user role, you can perform the following operations to manage the VLANs in the permitted VLAN list:
·     Create, remove, or configure the VLANs.
·     Enter the VLAN views.
·     Specify the VLANs in feature commands.
You can repeat the permit vlan command to add multiple permitted VLANs to a user role VLAN policy.
The undo permit vlan command removes the entire list of permitted VLANs if you do not specify a VLAN.
Any change to a user role VLAN policy takes effect only on users who log in with the user role after the change.
By default, all access ports belong to VLAN 1. To assign an access port to any other VLAN by using the port access vlan command, make sure you have a user role that can access both VLAN 1 and the new VLAN.
# Permit user role role1 to execute all commands available in interface view and VLAN view.
# Permit user role role1 to access VLANs 1, 2, 4, and 50 to 100.
[Sysname-role-role1] vlan policy deny
[Sysname-role-role1-vlanpolicy] permit vlan 1 2 4 50 to 100
[Sysname-role-role1-vlanpolicy] quit
2.     Verify that you cannot use user role role1 to manage any VLANs except for VLANs 1, 2, 4, and 50 to 100:
# Verify that you can create VLAN 100 and enter VLAN view.
[Sysname] vlan 100
[Sysname-vlan100] quit
# Verify that you can add GigabitEthernet 1/0/1 to VLAN 100 as an access port.
[Sysname-GigabitEthernet1/0/1] port access vlan 100
# Verify that you cannot create VLAN 101 or enter VLAN view.
[Sysname] vlan 101
Permission denied.
display role
role
vlan policy deny
permit vpn-instance
Use permit vpn-instance to configure a list of MPLS L3VPN instances accessible to a user role.
Use undo permit vpn-instance to disable the access of a user role to specific MPLS L3VPN instances.
permit vpn-instance vpn-instance-name&<1-10>
undo permit vpn-instance [ vpn-instance-name&<1-10> ]
No permitted VPN instances are configured in user role VPN instance policy.
User role VPN instance policy view
context-admin
vpn-instance-name&<1-10>: Specifies a space-separated list of up to 10 MPLS L3VPN instance names. Each name is a case-sensitive string of 1 to 31 characters.
To permit a user role to access a VPN instance after you use the vpn-instance policy deny command, you must add the VPN instance to the permitted VPN instance list of the policy. With the user role, you can perform the following operations to manage the VPN instances in the permitted VPN instance list:
·     Create, remove, or configure the VPN instances.
·     Enter the VPN instance views.
·     Specify the VPN instances in feature commands.
You can repeat the permit vpn-instance command to add multiple permitted VPN instances to a user role VPN instance policy.
The undo permit vpn-instance command removes the entire list of permitted VPN instances if you do not specify a VPN instance.
Any change to a user role VPN instance policy takes effect only on users who log in with the user role after the change.
# Permit the user role to execute all commands available in system view and in the child views of system view.
# Permit the user role to access VPN instance vpn1.
[Sysname-role-role1] vpn policy deny
[Sysname-role-role1-vpnpolicy] permit vpn-instance vpn1
[Sysname-role-role1-vpnpolicy] quit
2.     Verify that you cannot use user role role1 to manage any VPN instances except for vpn1:
# Verify that you can enter the view of vpn1.
# Verify that you can specify the primary accounting server at 10.110.1.2 in VPN instance vpn1 for RADIUS scheme radius1.
[Sysname] radius scheme radius1
[Sysname-radius-radius1] primary accounting 10.110.1.2 vpn-instance vpn1
[Sysname-radius-radius1] quit
# Verify that you cannot create VPN instance vpn2 or enter VPN instance view.
[Sysname] ip vpn-instance vpn2
Permission denied.
display role
role
role
Use role to create a user role and enter its view, or enter the view of an existing user role.
Use undo role to delete a user role.
role name role-name
undo role name role-name
The system has the following predefined user roles: network-admin, network-operator, context-admin, context-operator, level-n (where n represents an integer in the range of 0 to 15), guest-manager, security-audit, system-admin, security-admin, and audit-admin.
context-admin
vsys-admin
name role-name: Specifies a username. The role-name argument is a case-sensitive string of 1 to 63 characters.
You can create a maximum of 64 user roles in addition to the predefined user roles.
You cannot delete the predefined user roles or change the permissions assigned to network-admin, network-operator, context-admin, context-operator, level-15, guest-manager, security-audit, system-admin, security-admin, or audit-admin.
The access permissions of the level-0 to level-14 user roles can be modified through user role rules and resource access policies. However, you cannot make changes on the predefined access permissions of these user roles. For example, you cannot change the access permission of these user roles to the display history-command all command.
# Create user role role1 and enter its view.
display role
rule
vlan policy deny
role default-role enable
Use role default-role enable to enable the default user role feature for remote AAA users.
Use undo role default-role enable to restore the default.
role default-role enable [ role-name ]
The default user role feature is disabled. AAA users who do not have a user role cannot log in to the device.
context-admin
vsys-admin
role-name: Specifies a user role by its name for the default user role. The user role must already exist. The argument is a case-sensitive string of 1 to 63 characters.
The default user role feature assigns the default user role to AAA-authenticated users if the authentication server (local or remote) does not assign any user roles to the users. These users are allowed to access the system with the default user role.
For local authorization, this command is required if you do not use the authorization-attribute user role command to assign user roles to local users.
If AAA users have been assigned user roles, they log in with the user roles.
If you do not specify the role-name argument, the following default user role settings apply:
·     For login to the default context, the default user role is network-operator.
·     For login to a non-default context, the default user role is context-operator.
·     For login to the default vSystem, the default user role is network-operator.
·     For login to a non-default vSystem, the default user role is vsys-operator.
# Enable the default user role feature.
[Sysname] role default-role enable
role
role feature-group
Use role feature-group to create a user role feature group and enter its view, or enter the view of an existing user role feature group.
Use undo role feature-group to delete a user role feature group.
role feature-group name feature-group-name
undo role feature-group name feature-group-name
Two user role feature groups L2 and L3 exist.
context-admin
name feature-group-name: Specifies a feature group name. The feature-group-name argument is a case-sensitive string of 1 to 31 characters.
The L2 feature group includes all Layer 2 feature commands, and the L3 feature group includes all Layer 3 feature commands. These predefined feature groups are not user configurable.
In addition to the predefined feature groups L2 and L3, you can create a maximum of 64 user role feature groups.
# Create feature group security-features and enter its view.
feature
rule
Use rule to create or change a user role rule.
Use undo rule to delete user role rules.
rule number { deny | permit } { command command-string | { execute | read | write } * { feature [ feature-name ] | feature-group feature-group-name | oid oid-string | web-menu [ web-string ] | xml-element [ xml-string ] } }
undo rule { number | all }
A user-defined user role does not have any rules and cannot access any resources.
User role view
context-admin
vsys-admin
number: Specifies a rule number in the range of 1 to 256.
deny: Denies access to the specified commands, MIB nodes, Web menus, or XML elements.
permit: Permits access to the specified commands, MIB nodes, Web menus, or XML elements.
command command-string: Specifies a command string. The command string can represent a command or a group of commands. The command-string argument is a case-sensitive string of 1 to 128 characters, including the wildcard asterisk (*), the delimiters space and tab, and all printable characters. If the command string includes a left bracket ([) or right bracket (]), you must add a back slash (\) as the escape character before the left or right bracket. For example, to specify the statistics[ifindex="*"] command, you must enter statistics\[ifindex="*"\] for the command-string argument.
execute: Specifies the execute commands, MIB nodes, Web menus, or XML elements to execute a specific function or program. The ping command is an example of execute commands.
read: Specifies the read commands, MIB nodes, Web menus, or XML elements to display configuration or maintenance information. The display, dir, more, and pwd commands are examples of read commands.
write: Specifies the write commands, MIB nodes, Web menus, or XML elements to configure the system. The ssh server enable command is an example of write commands.
feature [ feature-name ]: Specifies one or all features. The feature-name argument is a case-sensitive character string. If you do not specify a feature name, you specify all the features in the system.
feature-group feature-group-name: Specifies a user-defined or predefined feature group. The feature-group-name argument represents the feature group name, a case-sensitive string of 1 to 31 characters. If the feature group has not been created, the rule takes effect after the group is created. To display the feature groups that have been created, use the display role feature-group command.
oid oid-string: Specifies an OID of a MIB node. The oid-string argument represents the OID, a case-insensitive string of 1 to 255 characters. The OID is a dotted numeric string that uniquely identifies the path from the root node to this node. For example, 1.3.6.1.4.1.25506.8.35.14.19.1.1.
web-menu [ web-string ]: Specifies a Web menu. The web-string argument represents the ID path of the Web menu, a case-insensitive string of 1 to 255 characters. Use the forward slash (/) to separate ID items, for example, M_DEVICE/I_BASIC_INFO/I_reboot. If you do not specify a Web menu, the rule applies to all Web items. To verify the ID path of a Web menu, use the display web menu command.
xml-element [ xml-string ]: Specifies an XML element. The xml-string argument represents the XPath of the XML element, a case-insensitive string of 1 to 255 characters. Use the forward slash (/) to separate Xpath items, for example, Interfaces/Index/Name. If you do not specify an XML element, the rule applies to all XML elements.
all: Specifies all the user role rules.
You can define the following types of rules for different access control granularities:
·     Command rule—Controls access to a command or a set of commands that match a regular expression.
·     Feature rule—Controls access to the commands of a feature by command type.
·     Feature group rule—Controls access to the commands of a group of features by command type.
·     Web menu rule—Controls access to Web menus by menu type.
·     XML element rule—Controls access to XML elements by element type.
·     OID rule—Controls access to the specified MIB node and its child nodes by node type.
A user role can access the set of permitted resources specified in the user role rules. User role rules include predefined (identified by sys-n) and user-defined user role rules.
You can configure a maximum of 256 user-defined rules for a user role. The total number of user-defined user role rules cannot exceed 1024.
Any rule modification, addition, or removal for a user role takes effect only on the users who log in with the user role after the change.
Access to the file system commands is controlled by both the file system command rules and the file system feature rule.
A command with output redirection to the file system is permitted only when the command type write is assigned to the file system feature.
The following guidelines apply to non-OID rules:
·     If two user-defined rules of the same type conflict, the rule with the higher ID takes effect. For example, a user role can use the tracert command but not the ping command if the user role contains rules configured by using the following commands:
¡     rule 1 permit command ping
¡     rule 2 permit command tracert
¡     rule 3 deny command ping
·     If a predefined user role rule and a user-defined user role rule conflict, the user-defined user role rule takes effect.
The following guidelines apply to OID rules:
·     The system compares an OID with the OIDs specified in rules, and it uses the longest match principle to select a rule for the OID. For example, a user role cannot access the MIB node with OID 1.3.6.1.4.1.25506.141.3.0.1 if the user role contains rules configured by using the following commands:
¡     rule 1 permit read write oid 1.3.6
¡     rule 2 deny read write oid 1.3.6.1.4.1
¡     rule 3 permit read write oid 1.3.6.1.4
·     If the same OID is specified in multiple rules, the rule with the higher ID takes effect. For example, a user role can access the MIB node with OID 1.3.6.1.4.1.25506.141.3.0.1 if the user role contains rules configured by using the following commands:
¡     rule 3 permit read write oid 1.3.6.1.4.1
When you specify a command string, follow the guidelines in Table 3.
Table 3 Command string configuration rules
Rule
Guidelines
Semicolon (;) is the delimiter.
Use a semicolon to separate the command of each view that you must enter before you access a command or a set of commands. However, do not use a semicolon to separate commands available in user view or any view, for example, display and dir.
Each semicolon-separated segment must have a minimum of one printable character.
To specify the commands in a view but not the commands in the view's subviews, use a semicolon as the last printable character in the last segment. To specify the commands in a view and the view's subviews, the last printable character in the last segment must not be a semicolon.
For example, you must enter system view before you enter interface view. To specify all commands starting with the ip keyword in any interface view, you must use the "system ; interface * ; ip * ;" command string.
For another example, the "system ; radius scheme * ;" command string represents all commands that start with the radius scheme keywords in system view. The "system ; radius scheme *" command string represents all commands that start with the radius scheme keywords in system view and all commands in RADIUS scheme view.
Asterisk (*) is the wildcard.
An asterisk represents zero or multiple characters.
In a non-last segment, you can use an asterisk only at the end of the segment.
In the last segment, you can use an asterisk in any position of the segment. If the asterisk appears at the beginning, you cannot specify a printable character behind the asterisk.
For example, the "system ; *" command string represents all commands available in system view and all subviews of the system view. The "debugging * event" command string represents all event debugging commands available in user view.
Keyword abbreviation is allowed.
You can specify a keyword by entering the first few characters of the keyword. Any command that starts with this character string matches the rule.
For example, "rule 1 deny command display arp source *" denies access to the display arp source-mac interface and display arp source-suppression commands.
To control the access to a command, you must specify the command immediately after the view that has the command.
To control access to a command, you must specify the command immediately behind the view to which the command is assigned. The rules that control command access for any subview do not apply to the command.
For example, the "rule 1 deny command system ; interface * ; *" command string disables access to any command that is assigned to interface view. However, you can still execute the acl advanced command in interface view, because this command is assigned to system view rather than interface view. To disable access to this command, use "rule 1 deny command system ; acl *;".
Do not include the vertical bar (|), greater-than sign (>), or double greater-than sign (>>) when you specify display commands in a user role command rule.
The system does not treat the redirect signs and the parameters that follow the signs as part of command lines. However, in user role command rules, these redirect signs and parameters are handled as part of command lines. As a result, no rule that includes any of these signs can find a match.
For example, "rule 1 permit command display debugging > log" can never find a match. This is because the system has a display debugging command but not a display debugging > log command.
# Permit user role role1 to execute the display acl command.
[Sysname-role-role1] rule 1 permit command display acl
# Permit user role role1 to execute all commands that start with the display keyword.
[Sysname-role-role1] rule 2 permit command display *
# Permit user role role1 to execute the radius scheme aaa command in system view and use all commands assigned to RADIUS scheme view.
[Sysname-role-role1] rule 3 permit command system ; radius scheme aaa
# Deny the access of role1 to the read or write commands of any features.
[Sysname-role-role1] rule 4 deny read write feature
# Deny the access of role1 to the read commands of the aaa feature.
[Sysname-role-role1] rule 5 deny read feature aaa
# Permit role1 to access all read, write, and execute commands of feature group security-features.
[Sysname-role-role1] rule 6 permit read write execute feature-group security-features
# Permit role1 to access all read and write MIB nodes starting from the node with OID 1.1.2.
[Sysname-role-role1] rule 7 permit read write oid 1.1.2
display role
display web menu
role
Use security-zone policy deny to enter the security zone policy view for a user role.
Use undo security-zone policy deny to restore the default.
A user role has access to all security zones.
User role view
context-admin
vsys-admin
CAUTION
CAUTION:
The security-zone policy deny command denies a user role access to any security zones if you do not specify accessible security zones by using the permit security-zone command. To configure a security zone, make sure that security zone is permitted by the security zone policy in use.
To limit the scope of security zones accessible to a user role, perform the following tasks:
1.     Use security-zone policy deny to enter user role security zone policy view and deny the user role access to any security zones.
2.     Use permit security-zone to specify accessible security zones.
You can perform the following operations to manage an accessible security zone:
·     Create, remove, or configure the security zone.
·     Enter security zone view.
·     Specify the security zone in feature commands.
Any change to a user role security zone policy takes effect only on users who log in with the user role after the change.
# Prevent user role role1 from accessing any security zones.
# Prevent user role role1 from accessing any security zones except for security zones trust and abc.
display role
role
super
Use super to obtain another user role without reconnecting to the device.
super [ role-name ]
context-admin
role-name: Specifies a user role, a case-sensitive string of 1 to 63 characters. The user role must exist in the system and cannot be security-audit or guest-manager. If you do not specify a user role, you obtain the default target user role which is set by using the super default role command.
The obtained user role is a temporary user role, because this command is effective only on the current login. The next time you are logged in with the user account, the original user role settings take effect.
To enable a user to obtain another user role without reconnecting to the device, you must configure user role authentication.
Enter the username (if any) and password within 60 seconds after you enter the super command. If you fail to do so, the command will time out. To obtain the role, you will need to re-execute the command.
·     If no local password is configured in the local password authentication (local), a console user can obtain the user role by either entering a string or not entering anything.
·     If no local password is configured in the local-then-remote authentication (local scheme), a console or VTY user performs remote authentication.
# Obtain the user role network-operator.
<Sysname> super network-operator
Password:
User privilege role is network-operator, and only those commands that authorized to the role can be used.
authentication super (Security Command Reference)
super authentication-mode
super password
Use super authentication-mode to set an authentication mode for temporary user role authorization.
Use undo super authentication-mode to restore the default.
super authentication-mode { local | scheme } *
Local password authentication applies.
context-admin
local: Enables local password authentication.
scheme: Enables remote AAA authentication.
For local password authentication, use the super password command to set a password.
For remote AAA authentication, set the username and password on the RADIUS or HWTACACS server.
If you specify both local and scheme keywords, the keyword first entered in the command takes precedence.
·     scheme local—Enables remote-then-local authentication mode. The device first performs AAA authentication to obtain a temporary user role. Local password authentication is performed if the remote HWTACACS or RADIUS server does not respond, or if the AAA configuration on the device is invalid.
·     local scheme—Enables local-then-remote authentication mode. The device first performs local password authentication. If no password is configured for the user role, the device performs remote authentication for VTY users.A console user can obtain another user role by either entering a string or not entering anything.
For more information about AAA, see Security Configuration Guide.
# Enable local-only authentication for temporary user role authorization.
[Sysname] super authentication-mode local
# Enable remote-then-local authentication for temporary user role authorization.
[Sysname] super authentication-mode scheme local
super password
super default role
Use super default role to specify the default target user role for temporary user role authorization.
Use undo super default role to restore the default.
super default role role-name
If you log in to the default context, the default target user role is network-admin.
If you log in to a non-default context, the default target user role is context-admin.
context-admin
role-name: Specifies the name of the default target user role, a case-sensitive string of 1 to 63 characters. The user role must exist in the system and cannot be security-audit or guest-manager.
The default target user role is applied to the super or super password command when you do not specify a user role for the command.
# Specify network-operator as the default target user role for temporary user role authorization.
[Sysname] super default role network-operator
super
super password
super password
Use super password to set a password for a user role.
Use undo super password to delete the password for a user role.
super password [ role role-name ] [ { hash | simple } string ]
undo super password [ role role-name ]
No password is set for a user role.
context-admin
role role-name: Specifies a user role, a case-sensitive string of 1 to 63 characters. The user role must exist in the system and cannot be security-audit or guest-manager. If you do not specify a user role, the command sets a password for the default target user role which is set by using the super default role command.
hash: Specifies a password in hashed form.
simple: Specifies a password in plaintext form. For security purposes, the password specified in plaintext form will be stored in hashed form.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 63 characters and its hashed form is a case-sensitive string of 1 to 110 characters.
If you do not specify any parameters, you specify a plaintext password in the interactive mode.
Set a password if you configure local password authentication for temporary user role authorization.
It is a good practice to specify different passwords for different user roles.
When the global password control feature is enabled, the device maintains a history of super passwords, which are stored in hashed form.
Use the following guidelines when you change the authentication password for a user role when the global password control feature is enabled:
·     If you set the new password in plaintext form, you must make sure the password is different from the current one and those stored in the history super password records.
·     If you set the new password in hashed form, the system does not compare the new super password with the current one or the history super password records. The password can be the same as the current one or a history password retained by the device.
# Set the password to 123456TESTplat&! in plaintext form for user role network-operator.
[Sysname] super password role network-operator simple 123456TESTplat&!
# Set the password to 123456TESTplat&! in the interactive mode for user role network-operator.
Password:
Confirm :
Updating user information. Please wait......
super default role
super use-login-username
Use super use-login-username to enable the device to automatically obtain the login username when a login user requests temporary user role authorization from a remote authentication server.
Use undo super use-login-username to restore the default.
The device prompts for a username when a login user requests temporary user role authorization from a remote authentication server.
context-admin
This command is applicable only to the login from a user line that uses scheme authentication, which requires a username for login.
If the user was logged in from a user line that uses password authentication or no authentication, the device cannot obtain the login username. The request for temporary user role authorization from a remote authentication server will fail.
This command does not take effect on local password authentication for temporary user role authorization.
# Enable the device to automatically obtain the login username when a login user requests temporary user role authorization from a remote authentication server.
[Sysname] super use-login-username
super password
vlan policy deny
Use vlan policy deny to enter the VLAN policy view for a user role.
Use undo vlan policy deny to restore the default.
vlan policy deny
A user role has access to all VLANs.
User role view
context-admin
vsys-admin
CAUTION
CAUTION:
The vlan policy deny command denies a user role access to any VLANs if you do not specify accessible VLANs by using the permit vlan command. To configure a VLAN, make sure that VLAN is permitted by the VLAN policy in use.
To limit the scope of VLANs accessible to a user role, perform the following tasks:
1.     Use vlan policy deny to enter user role VLAN policy view and deny the user role access to any VLANs.
2.     Use permit vlan to specify accessible VLANs.
You can perform the following operations to manage an accessible VLAN:
·     Create, remove, or configure the VLAN.
·     Enter VLAN view.
·     Specify the VLAN in feature commands.
# Prevent user role role1 from accessing any VLANs.
[Sysname] role name role1
# Prevent user role role1 from accessing any VLANs except for VLANs 50 to 100.
[Sysname-role-role1-vlanpolicy] permit vlan 50 to 100
display role
permit vlan
role
Use vpn-instance policy deny to enter the VPN instance policy view for a user role.
Use undo vpn-instance policy deny to restore the default.
A user role has access to all VPN instances.
User role view
context-admin
CAUTION
CAUTION:
The vpn-instance policy deny command denies a user role access to any VPN instances if you do not specify accessible VPN instances by using the permit vpn-instance command. To configure a VPN instance, make sure that VPN instance is permitted by the VPN instance policy in use.
To limit the scope of VPN instances accessible to a user role, perform the following tasks:
1.     Use vpn-instance policy deny to enter user role VPN instance policy view and deny the user role access to any VPN instances.
2.     Use permit vpn-instance to specify accessible VPN instances.
You can perform the following operations to manage an accessible VPN instance:
·     Create, remove, or configure the VPN instance.
·     Enter VPN instance view.
·     Specify the VPN instance in feature commands.
# Prevent user role role1 from accessing any VPN instances.
[Sysname-role-role1] vpn-instance policy deny
# Prevent user role role1 from accessing any VPN instances except for vpn2.
[Sysname-role-role1-vpnpolicy] permit vpn-instance vpn2
display role
permit vpn-instance
role
