04-Layer 2—LAN Switching Command Reference
HomeSupportSwitchesS7500X-G SeriesReference GuidesCommand ReferencesH3C S7500X-G Switch Series Command References-R7755Pxx-6W10004-Layer 2—LAN Switching Command Reference
13-Service loopback group commands
13-Service loopback group commands 46.95 KB
MDC is supported only when the device operates in standalone mode. For more information about standalone mode, see IRF configuration in Virtual Technologies Configuration Guide. For more information about MDC and device models that support MDC, see MDC configuration in Virtual Technologies Configuration Guide.
Only SD interface modules, SF SD interface modules, and ports on the SC MPUs prefixed with LSCM2 support the service loopback group feature.
display service-loopback group
Use display service-loopback group to display service loopback group information.
display service-loopback group [ group-id ]
group-id: Specifies a service loopback group ID. The value range for the group-id argument is 1 to 1024. If you do not specify a service loopback group, this command displays information about all service loopback groups.
# Display information about service loopback group 5.
<Sysname> display service-loopback group 5
Group ID: 5                Service type: VSI-gateway
Group ID
Service loopback group ID.
Service type
Service type of the service loopback group. The value is VSI-gateway, which represents VSI gateway services.
Use service-loopback group to create a service loopback group and specify its service type.
Use undo service-loopback group to delete a service loopback group.
service-loopback group group-id type vsi-gateway
undo service-loopback group group-id
No service loopback groups exist.
type: Specifies the service type of the service loopback group.
vsi-gateway: Specifies VSI gateway services.
You can apply a service loopback group to other features once the group is created. The service loopback group will process services for the features.
You can configure only one service loopback group.
To ensure correct traffic processing, do not delete the service loopback group after the group is being used by a feature.
# Create service loopback group 5 and specify VSI gateway services for the group.
[Sysname] service-loopback group 5 type vsi-gateway
