- 04-Layer 2—LAN Switching Command Reference
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-M-LAG commands
- 04-Port isolation commands
- 05-VLAN commands
- 06-MVRP commands
- 07-QinQ commands
- 08-VLAN mapping commands
- 09-Loop detection commands
- 10-Spanning tree commands
- 11-LLDP commands
- 12-L2PT commands
- 13-Service loopback group commands
- 14-PFC commands
| 05-VLAN commands | 522.85 KB |
display interface vlan-interface
reset counters interface vlan-interface
display ip-subnet-vlan interface
display protocol-vlan interface
ARP flood suppression commands
port private-vlan trunk promiscuous
port private-vlan trunk secondary
display voice-vlan mac-address
VLAN commands
The device supports MDC only when it is operating in standalone mode. For more information about the standalone mode and device models that support MDC, see Virtual Technologies Configuration Guide.
Basic VLAN commands
bandwidth
Use bandwidth to set the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
VLAN interface view
# Set the expected bandwidth to 10000 kbps for VLAN-interface 1.
[Sysname-Vlan-interface1] bandwidth 10000
control-packet dot1p
Use control-packet dot1p to configure the 802.1p priority for control packets sent by a device.
Use undo control-packet dot1p to restore the default.
control-packet dot1p priority
The 802.1p priority is 6 for control packets sent by a device.
priority: Specifies an 802.1p priority value in the range of 0 to 7. 0 indicates the lowest priority, and 7 indicates the highest priority.
By default, the 802.1p priority is 6 for control packets sent by a device. However, some devices will drop or not process packets with 802.1p priority 6, which affects the operation of protocols in the network. To resolve this problem, configure the 802.1p priority for control packets sent by a device.
This command configures the 802.1p priority for packets of the following protocols: ARP, NTP, OSPF, BGP, PIM, SSH, Telnet, and LDP. As a best practice, make sure you have known the impact on the network before executing this command.
# Configure the 802.1p priority as 7 for control packets sent by the device.
[Sysname] control-packet dot1p 7
default
Use default to restore the default settings for a VLAN interface.
default
VLAN interface view
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network. |
This command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for VLAN-interface 1.
[Sysname-Vlan-interface1] default
description
Use description to configure the description of a VLAN or VLAN interface.
For a VLAN, the description is VLAN vlan-id. The vlan-id argument specifies the VLAN ID in a four-digit format. If the VLAN ID has fewer than four digits, leading zeros are added. For example, the default description of VLAN 100 is VLAN 0100.
For a VLAN interface, the description is the name of the interface. For example, Vlan-interface1 Interface.
VLAN view
VLAN interface view
To manage VLANs and VLAN interfaces efficiently, configure descriptions for them based on their functions or connections.
# Configure the description of VLAN 2 as sales-private.
[Sysname] vlan 2
[Sysname-vlan2] description sales-private
# Configure the description of VLAN-interface 2 as linktoPC56.
[Sysname] vlan 2
[Sysname-vlan2] quit
[Sysname-Vlan-interface2] description linktoPC56
display vlan
Use display interface vlan-interface to display VLAN interface information.
display interface [ vlan-interface [ interface-number ] ] [ brief [ description | down ] ]
vlan-interface interface-number: Specifies a VLAN interface number. If you do not specify the vlan-interface keyword, the command displays information about all interfaces supported by the device. If you specify the vlan-interface keyword without specifying an interface number, the command displays information about all existing VLAN interfaces.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 25 characters of each interface description.
down: Displays VLAN interfaces in down state and their down causes. If you do not specify this keyword, the command displays information about VLAN interfaces in all states.
# Display information about VLAN-interface 10.
<Sysname> display interface vlan-interface 10
Vlan-interface10
Current state: UP
Line protocol state: UP
Description: Vlan-interface10 Interface
Bandwidth: 100000 kbps
Internet Address is 192.168.1.54/24 Primary
IP packet frame type: Ethernet II, hardware address: 0023-89b6-d613
IPv6 packet frame type: Ethernet II, hardware address: 0023-89b6-d613
# Display brief information about VLAN-interface 2.
<Sysname> display interface vlan-interface 2 brief
Protocol: (s) - spoofing
Vlan2 DOWN DOWN -- aaaaaaaaaaaaaaaaaaaaaaaaa
Vlan-interface2 |
VLAN interface name. |
Current state |
Physical link state of the VLAN interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down. The VLAN of this VLAN interface does not contain any physical ports in up state. The ports might not be connected correctly or the links might have failed. · UP—The interface is both administratively and physically up. |
Line protocol state |
Data link layer state of the VLAN interface: · DOWN—The link layer protocol state of the interface is down. · UP—The link layer protocol state of the interface is up. |
Description of the VLAN interface. |
Bandwidth |
Expected bandwidth of the VLAN interface. |
Maximum transmission unit |
MTU of the VLAN interface. |
Internet protocol processing : Disabled |
The VLAN interface is not assigned an IP address and cannot process IP packets. |
Internet address: ip-address/mask-length (Type) |
IP address of the interface and type of the address in parentheses. Possible IP address types include: · Primary—Manually configured primary IP address. · Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed. · DHCP-allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3—IP Services Configuration Guide. · BOOTP-allocated—BOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3—IP Services Configuration Guide. · Unnumbered—IP address borrowed from another interface. · MAD—IP address assigned to an IRF member device for MAD on the interface. For more information, see IRF configuration in Virtual Technologies Configuration Guide. |
IP packet frame type |
IPv4 packet framing format. |
hardware address |
MAC address of the VLAN interface. |
IPv6 packet frame type |
IPv6 packet framing format. |
Last clearing of counters |
The most recent time that the reset counters interface vlan-interface command was executed. This field displays Never if you have never executed this command. |
Brief information on interfaces in route mode |
Brief information about Layer 3 interfaces. |
Abbreviated interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol state of the interface is up. · DOWN—The data link layer protocol state of the interface is down. · UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. |
Primary IP |
Primary IP address of the interface. |
display vlan
Use display vlan to display VLAN information.
display vlan [ vlan-id1 [ to vlan-id2 ] | all | dynamic | reserved | static ]
vlan-id1: Specifies a VLAN by its ID in the range of 1 to 4094.
vlan-id1 to vlan-id2: Specifies a VLAN ID range. Both the vlan-id1 and the vlan-id2 arguments are in the range of 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
all: Specifies all VLANs except the reserved VLANs.
dynamic: Specifies dynamic VLANs. If you specify this keyword, the command displays the total number of dynamic VLANs and each dynamic VLAN ID. Dynamic VLANs are generated through MVRP or assigned by a RADIUS server.
reserved: Specifies reserved VLANs. Protocol modules determine which VLANs are reserved according to function implementation. The reserved VLANs provide services for protocol modules. You cannot configure reserved VLANs.
static: Specifies static VLANs. If you specify this keyword, the command displays the total number of static VLANs and each static VLAN ID. Static VLANs are manually created.
# Display information about VLAN 2.
<Sysname> display vlan 2
VLAN ID: 2
VLAN type: Static
Description: VLAN 0002
Tagged ports:
None
Untagged ports:
Ten-GigabitEthernet3/0/1(U) Ten-GigabitEthernet3/0/2(U)
Ten-GigabitEthernet3/0/3(D)
# Display information about VLAN 3.
<Sysname> display vlan 3
VLAN ID: 3
VLAN type: static
Route interface: Configured
IPv4 address: 1.1.1.1
IPv4 subnet mask: 255.255.255.0
Description: VLAN 0003
Tagged ports:
None
Untagged ports:
None
VLAN type |
VLAN type, static or dynamic. |
Route interface |
Whether the VLAN interface is configured for the VLAN. · Not configured. · Configured. |
Description of the VLAN. |
Name |
VLAN name. |
IP address |
Primary IPv4 address of the VLAN interface. This field is displayed only when an IPv4 address is configured for the VLAN interface. When the VLAN interface is also configured with secondary IPv4 addresses, you can view them by using one of the following commands: · display interface vlan-interface. · display this (VLAN interface view). |
Subnet mask |
Subnet mask of the primary IP address. This field is available only when an IP address is configured for the VLAN interface. |
Tagged ports |
Tagged members of the VLAN, and state of each tagged member: · (U) —The port is physically connected. · (D) —The port is physically disconnected. · None—The port does not exist. |
Untagged ports |
Untagged members of the VLAN, and state of each untagged member: · (U) —The port is physically connected. · (D) —The port is physically disconnected. · None—The port does not exist. |
display vlan brief
Use display vlan brief to display brief VLAN information.
display vlan brief
# Display brief VLAN information.
<Sysname> display vlan brief
Brief information about all VLANs:
Supported Minimum VLAN ID: 1
Supported Maximum VLAN ID: 4094
Default VLAN ID: 1
VLAN ID Name Port
1 VLAN 0001 XGE3/0/1(U) XGE3/0/2(D) XGE3/0/3(U)
XGE3/0/4(U) XGE3/0/5(D) XGE3/0/6(D)
2 VLAN 0002
3 VLAN 0003
Default VLAN ID |
System default VLAN ID. |
Name |
VLAN name. |
Port |
Ports that allow packets from the VLAN to pass through, and state of each port: · (U) —The port is physically connected. · (D) —The port is physically disconnected. |
display vlan statistics
Use display vlan statistics to display packet statistics for a VLAN.
In standalone mode:
display vlan vlan-id statistics [ slot slot-number ]
In IRF mode:
display vlan vlan-id statistics [ chassis chassis-number slot slot-number ]
vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays VLAN packet statistics on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays VLAN packet statistics on all cards. (In IRF mode.)
# Display packet statistics for VLAN 2 on slot 1.
<Sysname> display vlan 2 statistics slot 1
Slot 1:
Direction Total packets Total bytes
Rate (pps) Rate (Bps)
Inbound 5824579 745546112
0 0
Outbound 0 0
0 0
# Display packet statistics for VLAN 2.
Slot 1:
0 0
Outbound 0 0
0 0
Slot 2:
Inbound 0 0
0 0
Outbound 0 0
0 0
Total:
0 0
Outbound 0 0
0 0
Direction |
VLAN packet direction: · Inbound. · Outbound. |
Total packets |
Total number of packets. |
Total bytes |
Total number of bytes. |
reset vlan statistics
statistics enable
Use interface vlan-interface to create a VLAN interface and enter its view, or enter the view of an existing VLAN interface.
Use undo interface vlan-interface to delete a VLAN interface.
undo interface vlan-interface interface-number
No VLAN interfaces exist.
interface-number: Specifies a VLAN interface number in the range of 1 to 4094.
Create the VLAN before you create the VLAN interface for a VLAN.
# Create VLAN-interface 2, and enter its view.
[Sysname] vlan 2
mac-address
Use mac-address to assign a MAC address to a VLAN interface.
Use undo mac-address to restore the default.
mac-address mac-address
undo mac-address
No MAC address is configured for a VLAN interface.
VLAN interface view
mac-address: Specifies a MAC address in the format of H-H-H.
# Assign MAC address 0001-0001-0001 to VLAN-interface 2.
[Sysname-Vlan-interface2] mac-address 1-1-1
mtu
Use mtu to set the MTU for a VLAN interface.
mtu size
undo mtu
The MTU of a VLAN interface is 1500 bytes.
VLAN interface view
size: Sets the MTU in bytes. To view the value range for this argument, enter a question mark (?).
If you configure both the mtu and ip mtu commands on a VLAN interface, the MTU set by the ip mtu command is used for fragmentation. For more information about the ip mtu command, see Layer 3—IP Services Command Reference.
# Set the MTU to 1492 bytes for VLAN-interface 1.
[Sysname-Vlan-interface1] mtu 1492
name
Use name to assign a name to a VLAN.
Use undo name to restore the default.
name text
undo name
The name of a VLAN is VLAN vlan-id. The vlan-id argument specifies the VLAN ID in a four-digit format. If the VLAN ID has fewer than four digits, leading zeros are added. For example, the name of VLAN 100 is VLAN 0100.
VLAN view
text: Specifies a VLAN name, a case-sensitive string of 1 to 32 characters.
For 802.1X or MAC authentication, you can specify authorization VLANs by their names or IDs. If a large number of VLANs are configured, use VLAN names to identify them.
# Assign the name test vlan to VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] name test vlan
port outbound-vlan-tag enable
Use port outbound-vlan-tag enable to enable the function of setting VLAN tags for sent protocol packets on an interface.
Use the undo port outbound-vlan-tag enable command to disable the function of setting VLAN tags for sent protocol packets on an interface.
The function of setting VLAN tags for sent protocol packets is disabled on an interface.
With this feature enabled on an interface, the interface records all layers of VLAN tags of received LACP or BFD protocol packets. When the interface sends the same protocol packets, the interface adds the recorded VLAN tags to the sent protocol packets, regardless of whether the link type of the interface allows these packets to carry these VLAN tags. For more information about LACP, see Ethernet link aggregation configuration in Layer 2—LAN Switching Configuration Guide. For more information about BFD, see BFD configuration in High Availability Configuration Guide.
Executing the port outbound-vlan-tag enable command and then its undo form on an interface will cause BFD sessions on the interface to go down. Perform this operation with caution.
Executing this command on an aggregation group member port does not affect the other member ports in the same aggregation group or affect the Selected state of aggregation group member ports. To ensure configuration consistency within an aggregation group, manually execute this command on all aggregation group member ports.
# Enable the function of setting VLAN tags for sent protocol packets on Ten-GigabitEthernet 3/0/1.
<System> system-view
[System] interface ten-gigabitethernet 3/0/1
[System-Ten-GigabitEthernet3/0/1] port outbound-vlan-tag enable
Use reset counters interface vlan-interface to clear statistics on a VLAN interface.
reset counters [ interface vlan-interface [ interface-number ] ]
vlan-interface interface-number: Specifies a VLAN interface by its number. If you do not specify the vlan-interface keyword, the command clears statistics on all interfaces. If you specify the vlan-interface keyword without specifying an interface number, the command clears statistics on all existing VLAN interfaces.
Use this command to clear the history statistics before you collect statistics within a time period.
# Clear statistics on VLAN-interface 2.
<Sysname> reset counters interface vlan-interface 2
Use reset vlan statistics to clear packet statistics for a VLAN.
In standalone mode:
reset vlan vlan-id statistics [ slot slot-number ]
In IRF mode:
reset vlan vlan-id statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears VLAN packet statistics on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears VLAN packet statistics on all cards. (In IRF mode.)
# Clear packet statistics for VLAN 2.
<Sysname> reset vlan 2 statistics
statistics enable
service
Use service to specify a traffic processing slot for a VLAN interface.
Use undo service to restore the default.
In standalone mode:
service slot slot-number
undo service slot
In IRF mode:
service chassis chassis-number slot slot-number
undo service chassis
No traffic processing slot is specified for a VLAN interface. Traffic on a VLAN interface is processed on the slot at which the traffic arrives.
VLAN interface view
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
Specify a traffic processing slot for a VLAN interface if all traffic on the VLAN interface must be processed on the same slot.
Make sure the specified traffic processing slot is available. If the specified traffic processing slot is not available, traffic on the VLAN interface cannot be forwarded. Traffic on the VLAN interface will not be forwarded until the traffic processing slot becomes available or until you respecify an available traffic processing slot.
# Specify slot 2 to process traffic for VLAN-interface 2.
[Sysname] vlan 2
[Sysname-Vlan-interface2] service slot 2
shutdown
Use shutdown to shut down a VLAN interface.
Use undo shutdown to bring up a VLAN interface.
shutdown
A VLAN interface is not manually shut down.
VLAN interface view
CAUTION: Executing the shutdown command on a VLAN interface will disconnect the link of the VLAN interface and interrupt communication. Use this command with caution. |
When a VLAN interface is not manually shut down, the following guidelines apply to the interface state:
· The VLAN interface is down if all ports in the VLAN are down.
· The VLAN interface is up if one or more ports in the VLAN are up.
When you use this command to shut down a VLAN interface, the VLAN interface remains in DOWN (Administratively) state. In this case, the VLAN interface state is not affected by the state of the ports in the VLAN.
Before you configure parameters for a VLAN interface, use this command to shut it down to prevent the configuration from affecting the network. After you complete the VLAN interface configuration, use the undo shutdown command to make the settings take effect.
To troubleshoot a failed VLAN interface, you can use the shutdown command and then the undo shutdown command on the interface to see whether it recovers.
In a VLAN, the state of each Ethernet port is independent of the state of the VLAN interface.
# Shut down VLAN-interface 2, and then bring it up.
[Sysname-Vlan-interface2] shutdown
[Sysname-Vlan-interface2] undo shutdown
statistics enable
Use statistics enable to enable packet statistics for a VLAN.
Use undo statistics enable to disable packet statistics for a VLAN.
statistics enable
Packet statistics is disabled for a VLAN.
VLAN view
When you need to examine or troubleshoot the network, you can enable packet statistics for a VLAN to monitor the total number of packets in the VLAN. The VLAN packet statistics include statistics on unicast, multicast, and broadcast packets.
Disable packet statistics for a VLAN to save system resources when you do not need this feature.
After packet statistics is enabled for a VLAN, you can use the display vlan statistics command to display the packet statistics for the VLAN.
The system does not automatically clear the packet statistics for VLANs. To clear the packet statistics for a VLAN, use the reset vlan statistics command.
# Enable packet statistics for VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] statistics enable
vlan
Use vlan vlan-id-list to create VLANs in batches, except reserved VLANs.
Use vlan all to create VLANs 1 through 4094.
Use undo vlan to delete the specified VLANs.
vlan { vlan-id-list | all }
undo vlan { vlan-id-list | all }
VLAN 1 (system default VLAN) exists.
vlan-id-list: Specifies a space-separated list of up to 32 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 [ to vlan-id2 ]. The value for vlan-id2 must be equal to or greater than the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
all: Specifies all VLANs except reserved VLANs. The keyword is not supported when the maximum number of VLANs that can be created on a device is less than 4094.
You cannot create or delete the system default VLAN (VLAN 1) or reserved VLANs.
Before you delete a dynamic VLAN or a VLAN locked by an application, you must first remove the configuration from the VLAN.
# Create VLAN 2 and enter its view.
[Sysname] vlan 2
[Sysname-vlan2]
# Create VLAN 2 and VLANs 4 through 100.
[Sysname] vlan 2 4 to 100
display vlan
Port-based VLAN commands
display port
Use display port to display information about hybrid or trunk ports.
hybrid: Specifies hybrid ports.
trunk: Specifies trunk ports.
# Display information about hybrid ports.
<Sysname> display port hybrid
Interface PVID VLAN Passing
XGE3/0/1 100 Tagged: 1000, 1002, 1500, 1600-1611, 2000,
2555-2558, 3000, 4000
Untagged:1, 10, 15, 18, 20-30, 44, 55, 67, 100,
150-160, 200, 255, 286, 300-302
# Display information about trunk ports.
<Sysname> display port trunk
XGE3/0/2 2 1-4, 6-100, 145, 177, 189-200, 244, 289, 400,
555, 600-611, 1000, 2006-2008
Table 5 Command output
Interface name. |
PVID |
Port VLAN ID. |
VLAN Passing |
Existing VLANs allowed on the port. |
Tagged |
VLANs from which the port sends packets without removing VLAN tags. |
Untagged |
VLANs from which the port sends packets after removing VLAN tags. |
port
Use port to assign the specified access ports to a VLAN.
Use undo port to remove the specified access ports from a VLAN.
port interface-list
undo port interface-list
All ports are in VLAN 1.
VLAN view
interface-list: Specifies a space-separated list of up to 10 Ethernet interface items. Each item specifies an Ethernet interface or a range of Ethernet interfaces in the form of interface-type interface-number1 to interface-type interface-number2. The value for the interface-number2 argument must be equal to or greater than the value for the interface-number1 argument.
This command is applicable only to access ports. This command cannot assign access ports to or remove access ports from VLAN 1.
By default, all ports are access ports. You can manually configure the port link type. For more information, see "port link-type."
# Assign Ten-GigabitEthernet 3/0/1 through Ten-GigabitEthernet 3/0/3 to VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] port ten-gigabitethernet 3/0/1 to ten-gigabitethernet 3/0/3
display vlan
port access vlan
Use port access vlan to assign an access port to the specified VLAN.
Use undo port access vlan to restore the default.
port access vlan vlan-id
All access ports belong to VLAN 1.
By default, all access ports belong to VLAN 1. Therefore, this command cannot be used to assign access ports to VLAN 1. To move an access port to VLAN 1, execute the undo port access vlan command on the access port.
Before assigning an access port to a VLAN, make sure the VLAN has been created.
# Assign Ten-GigabitEthernet 3/0/1 to VLAN 3.
[Sysname] vlan 3
[Sysname-vlan3] quit
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] port access vlan 3
port hybrid pvid
Use port hybrid pvid to set the PVID of a hybrid port.
Use undo port hybrid pvid to set the PVID of a hybrid port to 1.
port hybrid pvid vlan vlan-id
The PVID of a hybrid port is the ID of the VLAN to which the port belongs when its link type is access.
You can use a nonexistent VLAN as the PVID of a hybrid port. When you delete the PVID of a hybrid port by using the undo vlan command, the PVID setting of the port does not change.
For correct packet transmission, set the same PVID for a local hybrid port and its peer.
To enable a hybrid port to transmit packets from its PVID, you must assign the hybrid port to the PVID by using the port hybrid vlan command.
# Configure Ten-GigabitEthernet 3/0/1 as a hybrid port, set its PVID to VLAN 100, and assign it to VLAN 100 as an untagged member.
[Sysname] vlan 100
[Sysname-vlan100] quit
[Sysname-Ten-GigabitEthernet3/0/1] port link-type hybrid
[Sysname-Ten-GigabitEthernet3/0/1] port hybrid pvid vlan 100
[Sysname-Ten-GigabitEthernet3/0/1] port hybrid vlan 100 untagged
port hybrid vlan
port link-type
port hybrid vlan
Use port hybrid vlan to assign a hybrid port to the specified VLANs.
Use undo port hybrid vlan to remove a hybrid port from the specified VLANs.
undo port hybrid vlan vlan-id-list
A hybrid port is an untagged member of the VLAN to which the port belongs when its link type is access.
vlan-id-list: Specifies a space-separated list of up to 32 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument. The specified VLANs must already exist on the device.
tagged: Configures the port as a tagged member of the specified VLANs. A tagged member of a VLAN sends packets from the VLAN without removing VLAN tags.
untagged: Configures the port as an untagged member of the specified VLANs. An untagged member of a VLAN sends packets from the VLAN after removing VLAN tags.
A hybrid port can allow multiple VLANs. If you execute this command multiple times on a hybrid port, the hybrid port allows all the specified VLANs.
# Configure Ten-GigabitEthernet 3/0/1 as a hybrid port, and assign it to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100 as a tagged member.
[Sysname-Ten-GigabitEthernet3/0/1] port hybrid vlan 2 4 50 to 100 tagged
port link-type
port link-type
Use port link-type to set the link type of a port.
Use undo port link-type to restore the default link type of a port.
undo port link-type
Each port is an access port.
access: Sets the port link type to access.
hybrid: Sets the port link type to hybrid.
trunk: Sets the port link type to trunk.
To change the link type of a port from trunk to hybrid or vice versa, first set the link type to access.
# Configure Ten-GigabitEthernet 3/0/1 as a trunk port.
[Sysname-Ten-GigabitEthernet3/0/1] port link-type trunk
port trunk permit vlan
Use port trunk permit vlan to assign a trunk port to the specified VLANs.
Use undo port trunk permit vlan to remove a trunk port from the specified VLANs.
undo port trunk permit vlan { vlan-id-list | all }
A trunk port allows packets only from VLAN 1 to pass through.
all: Specifies all VLANs. To prevent unauthorized VLAN users from accessing restricted resources through the port, use the port trunk permit vlan all command with caution.
A trunk port can allow multiple VLANs. If you execute this command multiple times on a trunk port, the trunk port allows all the specified VLANs.
On a trunk port, packets only from the PVID can pass through untagged.
# Configure Ten-GigabitEthernet 3/0/1 as a trunk port, and assign it to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100.
[Sysname-Ten-GigabitEthernet3/0/1] port trunk permit vlan 2 4 50 to 100
port link-type
port trunk pvid
Use port trunk pvid to set the PVID for a trunk port.
Use undo port trunk pvid to restore the default.
port trunk pvid vlan vlan-id
The PVID of a trunk port is VLAN 1.
You can use a nonexistent VLAN as the PVID for a trunk port. When you delete the PVID of a trunk port by using the undo vlan command, the PVID setting of the port does not change.
For correct packet transmission, set the same PVID for a local trunk port and its peer.
To enable a trunk port to transmit packets from its PVID, you must assign the trunk port to the PVID by using the port trunk permit vlan command.
# Configure Ten-GigabitEthernet 3/0/1 as a trunk, set its PVID to VLAN 100, and assign it to VLAN 100.
[Sysname-Ten-GigabitEthernet3/0/1] port trunk pvid vlan 100
[Sysname-Ten-GigabitEthernet3/0/1] port trunk permit vlan 100
port link-type
MAC-based VLAN commands
display mac-vlan
Use display mac-vlan to display MAC-to-VLAN entries.
display mac-vlan { all | dynamic | mac-address mac-address [ mask mac-mask ] | static | vlan vlan-id }
all: Specifies all MAC-to-VLAN entries.
dynamic: Specifies dynamically configured MAC-to-VLAN entries.
mac-address mac-address: Specifies the MAC address in the MAC-to-VLAN entry. The format of the mac-address argument is H-H-H.
mask mac-mask: Specifies the mask for matching MAC addresses in MAC-to-VLAN entries. For the mac-mask argument, the high-order bits must be consecutive 1s in binary notation or consecutive Fs in hexadecimal notation. The default value is ffff-ffff-ffff.
static: Specifies statically configured MAC-to-VLAN entries.
vlan vlan-id: Specifies the VLAN in MAC-to-VLAN entries. The value range for the vlan-id argument is 1 to 4094.
# Display all MAC-to-VLAN entries.
<Sysname> display mac-vlan all
The following MAC VLAN entries exist:
State: S - Static, D - Dynamic
MAC address Mask VLAN ID Dot1p State
0008-0001-0000 ffff-ff00-0000 5 3 S
0002-0001-0000 ffff-ffff-ffff 5 3 S&D
Total MAC VLAN entries count: 2
Table 6 Command output
S - Static |
Statically configured MAC-to-VLAN entries. |
D - Dynamic |
Dynamically configured MAC-to-VLAN entries. |
MAC address |
MAC address of the MAC-to-VLAN entry. |
Mask |
MAC address mask of the MAC-to-VLAN entry. |
VLAN ID |
VLAN ID of the MAC-to-VLAN entry. |
Dot1p |
802.1p priority of the VLAN in the MAC-to-VLAN entry. |
State |
State of a MAC-to-VLAN entry: · S—The MAC-to-VLAN entry is configured statically. · D—The MAC-to-VLAN entry is dynamically issued by the authentication server. · S&D—The MAC-to-VLAN entry is configured both statically and dynamically. |
mac-vlan mac-address
display mac-vlan interface
Use display mac-vlan interface to display all ports that are enabled with the MAC-based VLAN feature.
# Display all ports that are enabled with the MAC-based VLAN feature.
<Sysname> display mac-vlan interface
MAC VLAN is enabled on following ports:
Ten-GigabitEthernet3/0/1 Ten-GigabitEthernet3/0/2 Ten-GigabitEthernet3/0/3
mac-vlan enable
mac-vlan enable
Use mac-vlan enable to enable the MAC-based VLAN feature on a port.
Use undo mac-vlan enable to disable the MAC-based VLAN feature on a port.
mac-vlan enable
The MAC-based VLAN feature is disabled on a port.
# Enable the MAC-based VLAN feature on Ten-GigabitEthernet 3/0/1.
[Sysname–Ten-GigabitEthernet3/0/1] mac-vlan enable
Use mac-vlan mac-address to configure a MAC-to-VLAN entry.
Use undo mac-vlan to delete the specified MAC-to-VLAN entries.
mac-vlan mac-address mac-address [ mask mac-mask ] vlan vlan-id [ dot1p priority ]
undo mac-vlan { all | mac-address mac-address [ mask mac-mask ] | vlan vlan-id }
No MAC-to-VLAN entries exist.
mac-address mac-address: Specifies a MAC address in the format of H-H-H. The MAC address cannot be a multicast MAC address or all 0s. When you configure a MAC address, leading zeros in each H section can be omitted. For example, to configure a MAC address 000f-00e2-0001, you can enter only f-e2-1.
mask mac-mask: Specifies the MAC address mask. For the mac-mask argument, the high-order bits must be consecutive 1s in binary notation or consecutive Fs in hexadecimal notation. The default value is ffff-ffff-ffff.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
dot1p priority: Specifies the 802.1p priority of the VLAN specific to the MAC-to-VLAN entry. The value range for the priority argument is 0 to 7, and the default value is 0. The higher the value, the higher the 802.1p priority.
all: Specifies all static MAC-to-VLAN entries.
For successful dynamic MAC-based VLAN assignment, use static VLANs when you create MAC-to-VLAN entries.
Different types of MAC-to-VLAN entries are created depending on whether you specify the mask keyword.
· When you specify this keyword, the created MAC-to-VLAN entry describes the relationship among a group of MAC addresses, a VLAN, and the 802.1p priority for the VLAN.
· When you do not specify this keyword, the created MAC-to-VLAN entry describes the relationship among a MAC address, a VLAN, and the 802.1p priority for the VLAN.
These different types of MAC-to-VLAN entries are stored separately in two tables. The system updates the two tables according to the configuration.
# Associate the MAC address 0000-0001-0001 with VLAN 100, and set the 802.1p priority to 7 for VLAN 100 in this entry.
[Sysname] mac-vlan mac-address 0-1-1 vlan 100 dot1p 7
# Associate VLAN 100 with MAC addresses whose six high-order bits are 121122, and set the 802.1p priority to 4 for VLAN 100 in this entry.
[Sysname] mac-vlan mac-address 1211-2222-3333 mask ffff-ff00-0000 vlan 100 dot1p 4
display mac-vlan
mac-vlan trigger enable
Use mac-vlan trigger enable to enable dynamic MAC-based VLAN assignment on a port.
Use undo mac-vlan trigger enable to disable dynamic MAC-based VLAN assignment on a port.
Dynamic MAC-based VLAN assignment is disabled on a port.
VLAN assignment for a port is triggered only when the source MAC address of its received packet exactly matches the MAC address in a MAC-to-VLAN entry.
# Enable dynamic MAC-based VLAN assignment on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] mac-vlan trigger enable
port pvid forbidden
port pvid forbidden
Use port pvid forbidden to disable a port from forwarding packets that fail the exact MAC address match in its PVID.
Use undo port pvid forbidden to restore the default.
port pvid forbidden
When a port receives packets whose source MAC addresses fail the exact MAC address match, the port forwards them in its PVID.
Use this feature only with dynamic MAC-based VLAN assignment.
# Disable Ten-GigabitEthernet 3/0/1 from forwarding packets that fail the exact MAC address match in its PVID.
[Sysname-Ten-GigabitEthernet3/0/1] port pvid forbidden
vlan precedence
Use vlan precedence to set the VLAN matching order.
Use undo vlan precedence to restore the default.
vlan precedence mac-vlan
A port matches VLANs based on MAC addresses preferentially when both the MAC-based VLAN and IP subnet-based VLAN are configured on a port.
mac-vlan: Matches VLANs based on MAC addresses preferentially.
This command takes effect only on MAC-based VLANs and IP subnet-based VLANs.
When you enable dynamic MAC-based VLAN assignment, execute the vlan precedence mac-vlan command as a best practice to ensure the priority of MAC-based VLAN matching.
# Configure Ten-GigabitEthernet 3/0/1 to match VLANs based on MAC addresses preferentially.
[Sysname-Ten-GigabitEthernet3/0/1] vlan precedence mac-vlan
IP subnet-based VLAN commands
The LSCM1GT48SC0 cards do not support this command.
Use display ip-subnet-vlan interface to display IP subnet-based VLANs that are associated with the specified ports.
display ip-subnet-vlan interface { interface-type interface-number1 [ to interface-type interface-number2 ] | all }
interface-type interface-number1 to interface-type interface-number2: Specifies an interface range. Both the interface-type interface-number1 argument and the interface-type interface-number2 argument represent the interface type and interface number. The value for the interface-number2 argument must be greater than or equal to the value for the interface-number1 argument.
all: Specifies all ports.
# Display IP subnet-based VLANs on Ten-GigabitEthernet 3/0/1.
<Sysname> display ip-subnet-vlan interface ten-gigabitethernet 3/0/1
Interface: Ten-GigabitEthernet3/0/1
VLAN ID Subnet index IP address Subnet mask Status
3 0 192.168.1.0 255.255.255.0 Active
4 N/A N/A N/A Inactive
4094 65535 172.16.1.1 255.255.0.0 Inactive
Table 7 Command output
VLAN ID |
ID of the IP subnet-based VLAN. |
Subnet index |
Index of the IP subnet. This field displays N/A if no IP subnet-based VLAN is configured. |
IP address |
IP address of the subnet. It can be an IP address or a subnet address. This field displays N/A if no IP subnet address is configured for the VLAN. |
Subnet mask |
Mask of the IP subnet. This field displays N/A if no subnet mask is configured for the VLAN. |
Status |
Whether the IP subnet-based VLAN has taken effect on the port: · Active—The IP subnet-based VLAN has taken effect. · Inactive—The IP subnet-based VLAN has not taken effect. For example, this field displays Inactive in one of the following conditions: ¡ The configuration of the IP subnet-based VLAN is not complete. ¡ The port does not allow the IP subnet-based VLAN. |
display ip-subnet-vlan vlan
ip-subnet-vlan
port hybrid ip-subnet-vlan
Use display ip-subnet-vlan vlan to display information about IP subnet-based VLANs.
display ip-subnet-vlan vlan { vlan-id1 [ to vlan-id2 ] | all }
vlan-id1: Specifies an IP subnet-based VLAN by its VLAN ID in the range of 1 to 4094.
vlan-id1 to vlan-id2: Specifies an IP subnet-based VLAN ID range. Both the vlan-id1 and the vlan-id2 arguments are in the range of 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
all: Specifies all IP subnet-based VLANs.
# Display information about all IP subnet-based VLANs.
<Sysname> display ip-subnet-vlan vlan all
VLAN ID: 3
Table 8 Command output
VLAN ID |
Subnet index |
Index of the IP subnet. |
IP address |
IP address of the subnet. It can be an IP address or a subnet address. |
Subnet mask |
Mask of the IP subnet. |
ip-subnet-vlan
ip-subnet-vlan
Use ip-subnet-vlan to associate a VLAN with the specified IP subnet or IP address.
Use undo ip-subnet-vlan to disassociate a VLAN from the specified IP subnet or IP address.
ip-subnet-vlan [ ip-subnet-index ] ip ip-address [ mask ]
undo ip-subnet-vlan { ip-subnet-index [ to ip-subnet-end ] | all }
A VLAN is not associated with an IP subnet or IP address.
VLAN view
ip-subnet-index: Specifies a beginning IP subnet index in the range of 0 to 65535. The value can be configured by users. It can also be automatically numbered by the system based on the order in which the IP subnets or IP addresses are associated with the VLAN.
ip ip-address [ mask ]: Specifies the source IP address or network address that is associated with the VLAN. The ip-address argument specifies the source IP address or network address in dotted decimal notation. The mask argument is the subnet mask of the source IP address or network address, in dotted decimal notation with a default value of 255.255.255.0.
to ip-subnet-end: Specifies an end IP subnet index of an IP subnet index range, in the range of 0 to 65535. The value for the ip-subnet-end argument must be greater than or equal to the beginning IP subnet index.
all: Specifies all IP subnets or IP addresses that are associated with the VLAN.
The IP subnet or IP address cannot be a multicast network segment or a multicast address.
# Configure VLAN 3 as an IP subnet-based VLAN and associate it with the subnet 192.168.1.0/24.
[Sysname] vlan 3
[Sysname-vlan3] ip-subnet-vlan ip 192.168.1.0 255.255.255.0
Use port hybrid ip-subnet-vlan to associate a port with the specified IP subnet-based VLAN.
Use undo port hybrid ip-subnet-vlan to disassociate a port from the specified IP subnet-based VLAN.
port hybrid ip-subnet-vlan vlan vlan-id
undo port hybrid ip-subnet-vlan { vlan vlan-id | all }
A port is not associated with an IP subnet-based VLAN.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
For this command to take effect, perform the following tasks:
1. Create a VLAN and associate it with the specified IP subnet or IP address.
2. Set the port link type to hybrid.
3. Configure the port to allow the IP subnet-based VLAN to pass through.
# Associate Ten-GigabitEthernet 3/0/1 with IP subnet-based VLAN 3.
[Sysname] vlan 3
[Sysname-Ten-GigabitEthernet3/0/1] port hybrid vlan 3 untagged
[Sysname-Ten-GigabitEthernet3/0/1] port hybrid ip-subnet-vlan vlan 3
# Associate Layer 2 aggregate interface Bridge-Aggregation 1 with IP subnet-based VLAN 3.
[Sysname] vlan 3
[Sysname-Bridge-Aggregation1] port link-type hybrid
[Sysname-Bridge-Aggregation1] port hybrid vlan 3 untagged
[Sysname-Bridge-Aggregation1] port hybrid ip-subnet-vlan vlan 3
ip-subnet-vlan
Protocol-based VLAN commands
IMPORTANT: This feature is not supported on LSCM1GT48SC0 cards installed. |
Use display protocol-vlan interface to display protocol-based VLANs that are associated with the specified ports.
display protocol-vlan interface { interface-type interface-number1 [ to interface-type interface-number2 ] | all }
# Display protocol-based VLAN information on Ten-GigabitEthernet 3/0/1.
<Sysname> display protocol-vlan interface ten-gigabitethernet 3/0/1
VLAN ID Protocol index Protocol type Status
2 0 IPv6 Active
2 1 N/A Inactive
4094 65535 IPv4 Inactive
VLAN ID |
ID of the protocol-based VLAN. |
Protocol index |
Protocol template index. |
Protocol type |
Protocol type specified by the protocol template. This field displays N/A if the protocol type is not specified. |
Status |
Whether the protocol-based VLAN has taken effect: · Active—The protocol-based VLAN has taken effect. · Inactive—The protocol-based VLAN has not taken effect. |
display protocol-vlan vlan
port hybrid protocol-vlan
protocol-vlan
Use display protocol-vlan vlan to display information about protocol-based VLANs.
display protocol-vlan vlan { vlan-id1 [ to vlan-id2 ] | all }
vlan-id1: Specifies a protocol-based VLAN ID in the range of 1 to 4094.
vlan-id1 to vlan-id2: Specifies a protocol-based VLAN ID range. Both the vlan-id1 and the vlan-id2 arguments are in the range of 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
all: Specifies all protocol-based VLANs.
# Displays information about all protocol-based VLANs.
<Sysname> display protocol-vlan vlan all
VLAN ID: 2
0 IPv4
65535 IPv6
VLAN ID: 3
0 IPv4
65535 LLC DSAP 0x11 SSAP 0x22
VLAN ID |
Protocol index |
Protocol type |
Protocol type or encapsulation format specified by the protocol template. |
protocol-vlan
Use port hybrid protocol-vlan to associate a port with the specified protocol-based VLAN.
Use undo port hybrid protocol-vlan to disassociate a port from the specified protocol-based VLAN.
port hybrid protocol-vlan vlan vlan-id { protocol-index [ to protocol-end ] | all }
undo hybrid protocol-vlan { vlan vlan-id { protocol-index [ to protocol-end ] | all } | all }
A port is not associated with a protocol-based VLAN.
protocol-index: Specifies a beginning protocol template index in the range of 0 to 65535.
to protocol-end: Specifies an end protocol template index of a protocol template range, in the range of 0 to 65535. The value for this argument must be greater than or equal to the beginning protocol template index.
all: Specifies all protocol templates.
1. Create a VLAN and associate it with the specified protocol templates.
3. Configure the port to allow the protocol-based VLAN to pass through.
When you execute the undo port hybrid protocol-vlan command on a port, follow these guidelines:
· If you specify both the vlan-id argument and the all keyword, this command disassociates the port from all protocol templates of the specified VLAN.
· If you specify only the all keyword, this command disassociates the port from all protocol templates of all VLANs.
# Configure Ten-GigabitEthernet 3/0/1 as a hybrid port, assign it to VLAN 2 as an untagged member, and associated it with protocol template 1 in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] protocol-vlan 1 ipv4
[Sysname-Ten-GigabitEthernet3/0/1] port hybrid vlan 2 untagged
[Sysname-Ten-GigabitEthernet3/0/1] port hybrid protocol-vlan vlan 2 1
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as a hybrid port, assign it to VLAN 2 as an untagged member, and associated it with protocol template 1 in VLAN 2.
[Sysname] vlan 2
[Sysname-Bridge-Aggregation1] port hybrid vlan 2 untagged
[Sysname-Bridge-Aggregation1] port hybrid protocol-vlan vlan 2 1
protocol-vlan
Use protocol-vlan to associate a VLAN with the specified protocol template.
Use undo protocol-vlan to disassociate a VLAN from the specified protocol template.
protocol-vlan [ protocol-index ] { at | ipv4 | ipv6 | ipx { ethernetii | llc | raw | snap } | mode { ethernetii etype etype-id | llc { dsap dsap-id [ ssap ssap-id ] | ssap ssap-id } | snap etype etype-id } }
undo protocol-vlan { protocol-index [ to protocol-end ] | all }
A VLAN is not associated with a protocol template.
VLAN view
at: Specifies the AppleTalk-based VLAN.
ipv4: Specifies the IPv4-based VLAN.
ipv6: Specifies the IPv6-based VLAN.
ipx: Specifies the IPX-based VLAN. The keywords ethernetii, llc, raw, and snap specify IPX encapsulation formats.
mode: Configures a user-defined protocol template for the VLAN. The keywords ethernetii, llc, and snap specify the available encapsulation formats.
ethernetii etype etype-id: Matches the Ethernet II encapsulation format and the specified protocol type ID. The etype-id argument specifies the protocol type ID of inbound packets, in the range of 600 to ffff in hexadecimal notation, excluding 800, 86dd, 809b, and 8137.
llc: Matches the LLC encapsulation format.
dsap dsap-id: Specifies the destination service access point in hexadecimal notation, in the range of 0 to ff.
ssap ssap-id: Specifies the source service access point in hexadecimal notation, in the range of 0 to ff.
snap etype etype-id: Matches the SNAP encapsulation format and the specified protocol type value. The etype-id argument specifies the Ethernet type of inbound packets, in the range of 600 to ffff in hexadecimal notation, excluding 8137.
protocol-index: Specifies a protocol template index that is associated with the VLAN. The value range for this argument is 0 to 65535. The system will automatically assign an index if you do not specify this argument.
to protocol-end: Specifies an end protocol template index of a protocol template range, in the range of 0 to 65535. The value for the protocol-end argument must be greater than or equal to the value for the protocol-index argument.
all: Specifies all protocols associated with the VLAN.
CAUTION: IP uses ARP for address resolution in Ethernet. To prevent communication failures, configure the IP and ARP templates in the same VLAN and associate them with the same port. |
When you use the mode keyword to configure a protocol template, follow these restrictions and guidelines:
· Do not set the etype-id argument in the ethernetii etype etype-id option to the following hexadecimal values:
¡ 800—Specifies the IPv4 protocol in Ethernet II encapsulation.
¡ 809b—Specifies the AppleTalk protocol in Ethernet II encapsulation.
¡ 8137—Specifies the IPX protocol in Ethernet II encapsulation.
¡ 86dd—Specifies the IPv6 protocol in Ethernet II encapsulation.
· Do not set both the dsap-id and ssap-id arguments to any of the following hexadecimal values:
¡ e0—Specifies the 802.2 LLC encapsulation format for IPX packets.
¡ ff—Specifies the 802.3 raw encapsulation format for IPX packets.
¡ aa—Specifies the 802.2 SNAP encapsulation format.
When either of the dsap-id and ssap-id arguments is configured, the system assigns the hexadecimal value aa to the other argument.
· Do not set the etype-id argument in the snap etype etype-id option to the hexadecimal value 8137. Otherwise, the template format will be the same as that of the IPX protocol. You can set the etype-id argument to the hexadecimal value 800, 809b, or 86dd. The hexadecimal values 800, 809b, and 86dd correspond to IPv4, AppleTalk, and IPv6, respectively.
# Assign ARP packets in Ethernet II encapsulation and IPv4 packets to VLAN 3 for transmission. (The protocol type ID for ARP is 0806 in hexadecimal notation.)
[Sysname] vlan 3
[Sysname-vlan3] protocol-vlan 1 ipv4
[Sysname-vlan3] protocol-vlan 2 mode ethernetii etype 0806
port protocol-vlan
arp suppression enable
Use arp suppression enable to enable ARP flood suppression.
Use undo arp suppression enable to disable ARP flood suppression.
ARP flood suppression is disabled.
VLAN view
Application scenarios
Excessive ARP packets in the network lead to increased CPU load on the device, affecting normal processing of other user operations. To resolve this issue, you can enable ARP flood suppression on the device to reduce the flood of ARP packets and ensure normal network communication.
Operating mechanism
With this feature enabled, the device can monitor the ARP packets passing through it. When other devices initiate ARP resolution again, the device can respond to the ARP requests to suppress the network flood caused by ARP resolution.
# Enable ARP flood suppression for VLAN 1.
[Sysname] vlan 1
[Sysname-vlan2] arp suppression enable
display arp suppression vlan
Use display arp suppression vlan to display ARP flood suppression entries.
In standalone mode:
display arp suppression vlan [ vlan-id ] [ slot slot-number ] [ count ]
display arp suppression vlan vlan-id ip ip-address [ slot slot-number ]
In IRF mode:
display arp suppression vlan [ vlan-id ] [ chassis chassis-number slot slot-number ] [ count ]
display arp suppression vlan vlan-id ip ip-address [ chassis chassis-number slot slot-number ]
vlan: Displays ARP flood suppression entries in VLAN.
vlan-id: Displays ARP flood suppression entries in the specified VLAN. The value range is 1 to 4094. If you do not specify this argument, this command displays entries for all the VLANs.
count: Displays the number of ARP flood suppression entries that match the command.
ip ip-address: Displays ARP flood suppression entries in the VLAN with specified IP address.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays entries on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number Specifies a card on an IRF member device. The chassis-number argument represents the IRF member ID. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays entries on the global active MPU. (In IRF mode.)
# Display ARP flood suppression entries in VLAN 2.
<Sysname> display arp suppression vlan 2
IP Address MAC Address VLAN ID Interface Aging Status
3.3.3.3 0003-0003-0003 2 XGE3/0/1 20 Valid
3.3.3.4 0004-0004-0004 2 XGE3/0/2 5 Invalid
# Display ARP flood suppression entries with IP address 1.1.1.1 in VLAN 2.
<Sysname> display arp suppression vlan 2 ip 1.1.1.1
IP address MAC address VLAN ID Interface Aging Status
1.1.1.1 001f-e201-0111 2 XGE3/0/1 15 Valid
# Display the number of ARP flood suppression entries.
<Sysname> display arp suppression vlan count
Total entries: 3
Table 11 Command output
IP Address |
IP address of the ARP flood suppression entry. |
MAC Address |
MAC address of the ARP flood suppression entry. |
VLAN ID |
VLAN number of the ARP flood suppression entry. |
Incoming interface corresponding to the ARP flood suppression entry. |
Aging |
Aging time (in minutes) of the ARP flood suppression entry. N/A indicates the current slot is not the slot where the port that created the ARP flood suppression entry is located or it is an EVPN remote synchronization entry. |
Status |
State of ARP flood suppression entry: · Valid · Invalid · Collision |
Total entries |
Number of ARP flood suppression entries. |
reset arp suppression
reset arp suppression vlan
Use reset arp suppression vlan to clear ARP flood suppression entries in VLANs.
reset arp suppression vlan [ vlan-id ip ip-address | vlan-id ]
vlan: Clears ARP flood suppression entries in VLAN.
vlan-id: Clears ARP flood suppression entries in the specified VLAN. The value range is 1 to 4094. If you do not specify this argument, this command clears entries for all the VLANs.
ip ip-address: Clears ARP flood suppression entries in the VLAN with specified IP address.
# Clear ARP flood suppression entries in VLAN 2.
<Sysname> reset arp suppression vlan 2
# Clear ARP flood suppression entries with IP address 1.1.1.1 in VLAN 2.
<Sysname> reset arp suppression vlan 2 ip 1.1.1.1
VLAN group commands
display vlan-group
Use display vlan-group to display VLAN group information.
display vlan-group [ group-name ]
group-name: Specifies a VLAN group by its name, a case-sensitive string of 1 to 31 characters. The first character must be an alphabetical character. If you do not specify this argument, the command displays information about all VLAN groups.
# Display information about VLAN group test001.
<Sysname> display vlan-group test001
VLAN group: test001
VLAN list: 2-4 100 200
# Display information about all VLAN groups.
VLAN group: test001
VLAN group: rnd
VLAN list: Null
Table 12 Command output
VLAN group |
Name of the VLAN group. |
VLAN list |
VLAN list in the VLAN group. |
vlan-group
vlan-list
vlan-group
Use vlan-group to create a VLAN group and enter its view, or enter the view of an existing VLAN group.
Use undo vlan-group to delete a VLAN group.
vlan-group group-name
undo vlan-group group-name
No VLAN groups exist.
A VLAN group includes a set of VLANs. You can add multiple VLAN lists to a VLAN group.
# Create a VLAN group named test001 and enter VLAN group view.
[Sysname] vlan-group test001
[Sysname-vlan-group-test001]
vlan-list
vlan-list
Use vlan-list to add VLANs to a VLAN group.
Use undo vlan-list to remove VLANs from a VLAN group.
vlan-list vlan-id-list
undo vlan-list vlan-id-list
No VLANs exist in a VLAN group.
VLAN group view
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
# Add VLAN 2 through VLAN 4, VLAN 100, and VLAN 200 to VLAN group test001.
[Sysname-vlan-group-test001] vlan-list 2 to 4 100 200
vlan-group
Super VLAN commands
Only SC interface modules prefixed with LSCM2, SD interface modules, and SF interface modules support Super VLAN.
display supervlan
Use display supervlan to display information about super VLANs and their associated sub-VLANs.
display supervlan [ supervlan-id ]
supervlan-id: Specifies a super VLAN ID in the range of 1 to 4094. If you do not specify a super VLAN ID, this command displays information about all super VLANs and their associated sub-VLANs.
# Display information about super VLAN 2 and its associated sub-VLANs.
<Sysname> display supervlan 2
Super VLAN ID: 2
Sub-VLAN ID: 3-5
VLAN ID: 2
VLAN type: Static
It is a super VLAN.
IPv4 address: 10.153.17.41
IPv4 subnet mask: 255.255.252.0
IPv6 global unicast addresses:
2001::1, subnet is 2001::/64 [TENTATIVE]
Tagged ports: None
Untagged ports: None
VLAN ID: 3
VLAN type: Static
It is a sub VLAN.
Tagged ports: None
Untagged ports:
VLAN ID: 4
VLAN type: Static
It is a sub VLAN.
Description: VLAN 0004
Tagged ports: None
Untagged ports:
Ten-GigabitEthernet3/0/4
Table 13 Command output
VLAN type |
VLAN type, dynamic or static. |
Route interface |
Whether a VLAN interface is configured for the VLAN. |
IPv4 address |
IPv4 subnet mask |
Subnet mask for the primary IPv4 address of the VLAN interface. This field is displayed only when an IPv4 address is configured for the VLAN interface. |
IPv6 global unicast addresses |
Global unicast IPv6 address of the VLAN interface. This field is not displayed when no IPv6 address is configured for the VLAN interface. The IPv6 address states are as follows: · TENTATIVE—Initial state. DAD is being performed or is to be performed on the address. An address in this state cannot be used as the source address or destination address of packets. · DUPLICATE—DAD has been completed for the address. The address is not unique on the link and cannot be used. · PREFERRED—The address is preferred and can be used as the source or destination address of a packet. If an address is in this state, the command does not display the address state. · DEPRECATED—The address is beyond the preferred lifetime but within the valid lifetime. It is valid, but it cannot be used as the source address for a new connection. Packets destined to the address are processed correctly. |
VLAN description. |
Name |
VLAN name. |
Tagged ports |
Tagged members of the VLAN. |
Untagged ports |
Untagged members of the VLAN. |
subvlan
supervlan
subvlan
Use subvlan to associate a super VLAN with the specified sub-VLANs.
Use undo subvlan to dissociate sub-VLANs from a super VLAN.
subvlan vlan-id-list
undo subvlan [ vlan-id-list ]
A super VLAN is not associated with any sub-VLANs.
VLAN view
vlan-id-list: Specifies a space-separated list of up to 10 sub-VLAN items. Each item specifies a sub-VLAN ID or a range of sub-VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for sub-VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
Make sure sub-VLANs already exist before you associate them with a super VLAN.
You can add ports to and remove ports from a sub-VLAN that is already associated with a super VLAN.
When you use the undo subvlan command, follow these guidelines:
· If you do not specify the vlan-id-list argument, this command dissociates all sub-VLANs from the current super VLAN.
· If you specify the vlan-id-list argument, this command dissociates the specified sub-VLANs from the current super VLAN.
# Associate super VLAN 10 with sub-VLANs 3, 4, and 5.
[Sysname] vlan 3 to 5
[Sysname] vlan 10
[Sysname-vlan10] supervlan
[Sysname-vlan10] subvlan 3 to 5
display supervlan
supervlan
supervlan
Use supervlan to configure a VLAN as a super VLAN.
Use undo supervlan to restore the default.
supervlan
undo supervlan
A VLAN is not a super VLAN.
VLAN view
A VLAN cannot be configured as both a super VLAN and a guest VLAN, Auth-Fail VLAN, or critical VLAN. For more information about guest VLANs, Auth-Fail VLANs, and critical VLANs, see Security Configuration Guide.
As a best practice, do not configure VRRP for a super VLAN interface, because the configuration affects network performance.
Layer 2 multicast configuration for super VLANs does not take effect because they do not have physical ports.
# Configure VLAN 2 as a super VLAN.
[Sysname] vlan 2
[Sysname-vlan2] supervlan
display supervlan
subvlan
Private VLAN commands
Only the SC modules prefixed with LSCM2, SD interface modules and SF interface modules support Private VLAN.
display private-vlan
Use display private-vlan to display information about primary VLANs and their associated secondary VLANs.
display private-vlan [ primary-vlan-id ]
primary-vlan-id: Specifies a primary VLAN ID in the range of 1 to 4094. If you do not specify a primary VLAN ID, this command displays information about all primary VLANs and their associated secondary VLANs.
# Display information about primary VLANs and their associated secondary VLANs.
<Sysname> display private-vlan
Primary VLAN ID: 2
Secondary VLAN ID: 3-4
VLAN ID: 2
VLAN type: Static
Private VLAN type: Primary
Tagged ports: None
Untagged ports:
VLAN ID: 3
VLAN type: Static
Private VLAN type: Secondary
Tagged ports: None
Untagged ports:
VLAN ID: 4
VLAN type: Static
Tagged ports: None
Untagged ports:
Table 14 Command output
VLAN type |
Private VLAN type |
Private VLAN type: · Primary—Primary VLAN. · Secondary—Secondary VLAN.
Route interface |
Whether a VLAN interface is created for the VLAN: · Configured. · Not configured. |
IPv4 address |
IPv4 subnet mask |
VLAN description. |
Name |
VLAN name. |
Tagged ports |
Untagged ports |
private-vlan (VLAN view)
private-vlan primary
port private-vlan host
Use port private-vlan host to configure a port as a host port.
Use undo port private-vlan to restore the default.
A port is not a host port.
If the port has been assigned to a secondary VLAN, the command assigns the port to the primary VLAN associated with the secondary VLAN. Also, the following events occur:
· For an access port, the device performs the following operations:
¡ Changes the port link type to hybrid.
¡ Configures the secondary VLAN as the PVID.
¡ Assigns the port to the primary VLAN as an untagged member.
· For a trunk port, the device does not change the port link type or PVID.
· For a hybrid port, the device does not change the port link type or PVID.
¡ If the hybrid port has been a tagged or untagged member of the primary VLAN, this member attribute remains in the primary VLAN.
¡ If the hybrid port does not allow the primary VLAN, the device assigns the port to the primary VLAN as an untagged member.
You can assign the port to a secondary VLAN before or after you execute this command.
The undo port private-vlan command does not change the VLAN attributes (allowed VLANs, port link type, and PVID) of the port.
The port private-vlan host command is mutually exclusive with the port private-vlan trunk promiscuous and port private-vlan trunk secondary commands.
In this example, VLAN 20 is a secondary VLAN and is associated with primary VLAN 2.
# Configure Ten-GigabitEthernet 3/0/1 as a host port, and then verify the configuration.
[Sysname-Ten-GigabitEthernet3/0/1] port private-vlan host
[Sysname-Ten-GigabitEthernet3/0/1] display this
interface Ten-GigabitEthernet3/0/1
port link-mode bridge
return
The output show that Ten-GigabitEthernet 3/0/1 is operating in bridge mode and is a host port.
# Assign Ten-GigabitEthernet 3/0/1 to VLAN 20, and then verify the configuration.
[Sysname-Ten-GigabitEthernet3/0/1] port access vlan 20
undo port hybrid vlan 1
port hybrid vlan 2 20 untagged
port hybrid pvid vlan 20
return
The output shows that:
· Ten-GigabitEthernet 3/0/1 is an untagged member of secondary VLAN 20 and primary VLAN 2.
· The port link type of Ten-GigabitEthernet 3/0/1 is hybrid and its PVID is VLAN 20.
port private-vlan promiscuous
Use port private-vlan promiscuous to configure a port as a promiscuous port of the specified VLAN and assign the port to the VLAN.
port private-vlan vlan-id promiscuous
A port is not a promiscuous port of any VLANs.
vlan-id: Specifies a VLAN ID in the range of 1 to 4094. Though VLAN 1 is in the valid value range, it cannot be configured in the command.
If the specified VLAN is a primary VLAN that has been associated with secondary VLANs, the command assigns the port to the associated secondary VLANs. Also, the following events occur:
¡ Configures the primary VLAN as the PVID.
¡ Assigns the port to the primary VLAN and its associated secondary VLANs as an untagged member.
¡ If the hybrid port has been a tagged or untagged member of the primary VLAN and part of its associated secondary VLANs, this member attribute remains in these VLANs. The device assigns the hybrid port to the rest of the associated secondary VLANs as an untagged member.
¡ If the hybrid port does not allow any of the primary VLAN and its associated secondary VLANs, the command assigns the port to these VLANs as an untagged member.
If you execute this command on a promiscuous port multiple times, the most recent configuration takes effect.
The undo port private-vlan command does not change the VLAN attributes (allowed secondary VLANs, link type, and PVID) of the port. When you execute the undo port private-vlan command on a promiscuous port of a VLAN, the command removes the port from the VLAN.
You can configure the VLAN as a primary VLAN before or after you execute the port private-vlan promiscuous command.
This command is mutually exclusive with the port private-vlan trunk promiscuous and port private-vlan trunk secondary commands.
In this example, VLAN 2 is a primary VLAN, and it is associated with secondary VLAN 20.
# Display information about Ten-GigabitEthernet 3/0/1.
return
# Configure Ten-GigabitEthernet 3/0/1 as a promiscuous port of VLAN 2, and then verify the configuration.
[Sysname-Ten-GigabitEthernet3/0/1] port private-vlan 2 promiscuous
return
· Ten-GigabitEthernet 3/0/1 is a promiscuous port of VLAN 2.
· Ten-GigabitEthernet 3/0/1 is an untagged member of primary VLAN 2 and secondary VLAN 20.
· The port link type of Ten-GigabitEthernet 3/0/1 is hybrid and its PVID is VLAN 2.
# Execute the undo port private-vlan command on Ten-GigabitEthernet 3/0/1, and then verify the configuration.
[Sysname-Ten-GigabitEthernet3/0/1] undo port private-vlan
port hybrid vlan 20 untagged
return
· Ten-GigabitEthernet 3/0/1 is removed from primary VLAN 2.
· Ten-GigabitEthernet 3/0/1 is an untagged member of VLAN 20.
· The link type and PVID of Ten-GigabitEthernet 3/0/1 do not change.
Use port private-vlan trunk promiscuous to configure a port as a trunk promiscuous port of the specified VLANs and assign the port to these VLANs.
Use undo port private-vlan trunk promiscuous to cancel the trunk promiscuous attribute of a port in the specified VLANs.
port private-vlan vlan-id-list trunk promiscuous
undo port private-vlan vlan-id-list trunk promiscuous
A port is not a trunk promiscuous port of any VLANs.
vlan-id-list: Specifies a space-separated list of up to 10 primary VLAN items. Each item specifies a primary VLAN ID or a range of primary VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for primary VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument. Though the system default VLAN (VLAN 1) is in the valid value range, it cannot be configured in the command.
If the specified VLANs are primary VLANs that have been associated with secondary VLANs, the command assigns the port to the associated secondary VLANs. Also, the following events occur:
¡ Changes the port link type to hybrid. The PVID of the port does not change.
¡ Assigns the port to the primary VLANs and the associated secondary VLANs as a tagged member.
¡ If the hybrid port has been a tagged or untagged member of part of the primary VLANs and their associated secondary VLANs, this member attribute remains in these VLANs. The device assigns the hybrid port to the rest of the primary VLANs and their associated secondary VLANs as a tagged member.
¡ If the hybrid port does not allow any of the primary VLANs and their associated secondary VLANs, the device assigns the port to these VLANs as a tagged member.
The undo form of this command does not change the VLAN attributes (allowed secondary VLANs, port link type, and PVID) of the port.
If you execute the undo form of this command on a trunk promiscuous port, the command removes the port from the VLANs specified by the vlan-id-list argument.
You can configure the specified VLANs as primary VLANs before or after you execute this command.
This command is mutually exclusive with the port private-vlan host, port private-vlan promiscuous and port private-vlan trunk secondary commands.
For an uplink port to permit multiple primary VLANs, use the port private-vlan trunk promiscuous command to assign the port to these VLANs. The port can then transmit packets from these primary VLANs with VLAN tags. For an uplink port to permit only one primary VLAN, use the port private-vlan promiscuous command to assign the port to the VLAN. The port can then transmit packets from the primary VLAN without VLAN tags.
In this example, VLANs 2 and 3 are primary VLANs. VLAN 2 is associated with secondary VLAN 20. VLAN 3 is associated with secondary VLAN 30.
return
# Configure Ten-GigabitEthernet 3/0/1 as a trunk promiscuous port of VLANs 2 and 3, and then verify the configuration.
[Sysname-Ten-GigabitEthernet3/0/1] port private-vlan 2 3 trunk promiscuous
port hybrid vlan 2 3 20 30 tagged
port hybrid vlan 1 untagged
return
· Ten-GigabitEthernet 3/0/1 is a trunk promiscuous port of VLANs 2 and 3.
· Ten-GigabitEthernet3/0/1 is a tagged member of VLANs 2, 3, 20, and 30.
· The port link type of Ten-GigabitEthernet 3/0/1 is hybrid.
# Execute the undo port private-vlan trunk promiscuous command on Ten-GigabitEthernet 3/0/1, and then verify the configuration.
[Sysname-Ten-GigabitEthernet3/0/1] undo port private-vlan 2 3 trunk promiscuous
port hybrid vlan 20 30 tagged
return
· Ten-GigabitEthernet 3/0/1 is removed from VLANs 2 and 3.
· Ten-GigabitEthernet 3/0/1 is a tagged member of VLANs 20 and 30.
· The port link type and PVID of Ten-GigabitEthernet 3/0/1 do not change.
Use port private-vlan trunk secondary to configure a port as a trunk secondary port of the specified VLANs and assign the port to these VLANs.
Use undo port private-vlan trunk secondary to cancel the trunk secondary attribute of a port in the specified VLANs.
port private-vlan vlan-id-list trunk secondary
undo port private-vlan vlan-id-list trunk secondary
A port is not a trunk secondary port of any VLANs.
vlan-id-list: Specifies a space-separated list of up to 10 secondary VLAN items. Each item specifies a secondary VLAN ID or a range of secondary VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for secondary VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument. Though the system default VLAN (VLAN 1) is in the valid value range, it cannot be configured in the command.
If the specified VLANs are secondary VLANs that have been associated with primary VLANs, the command also assigns the port to the associated primary VLANs. Also, the following events occur:
¡ Assigns the port to the secondary VLANs and the associated primary VLANs as a tagged member.
¡ If the port has been an untagged or tagged member of part of the secondary VLANs and their associated primary VLANs, this member attribute remains in these VLANs. The device assigns the port to the rest of the secondary VLANs and their associated primary VLANs as a tagged member.
¡ If the hybrid port does not allow any of the secondary VLANs and their associated primary VLANs, the device assigns the port to these VLANs as a tagged member.
A trunk secondary port can join only one secondary VLAN among all secondary VLANs associated with a primary VLAN. However, it can join multiple secondary VLANs that are associated with different primary VLANs.
The undo form of this command does not change the VLAN attributes (allowed primary VLANs, port link type, and PVID) of the port.
When you execute the undo form of this command on a trunk secondary port of the VLANs specified by the vlan-id-list argument, one of the following events occurs:
· If the port is an access port, the device does not change the VLAN configuration of the port.
· If the port is a trunk or hybrid port, the device removes the port from the specified VLANs.
You can associate the specified VLANs with their respective primary VLANs before or after you execute this command.
This command does not take effect on the specified VLAN if any of the following conditions applies:
· The specified VLAN does not exist.
· The specified VLAN is not a secondary VLAN and is used for other purposes.
· The specified VLAN shares the same primary VLAN with other secondary VLANs, and the current port has been configured as a trunk secondary port in one of the other secondary VLANs.
This command is mutually exclusive with the port private-vlan host, port private-vlan promiscuous and port private-vlan trunk promiscuous commands.
For a downlink port to permit multiple secondary VLANs associated with different primary VLANs, use the port private-vlan trunk secondary command to assign the port to these secondary VLANs. The port can then transmit packets from these secondary VLANs with VLAN tags. For a downlink port to permit only one secondary VLAN, use the port private-vlan host command to assign the port to the secondary VLAN. The port can then transmit packets from the secondary VLAN without VLAN tags.
· In this example, VLANs 2 and 3 are primary VLANs. VLAN 2 is associated with secondary VLAN 20. VLAN 3 is associated with secondary VLAN 30.
return
# Configure Ten-GigabitEthernet 3/0/1 as a trunk secondary port of VLANs 20 and 30, and then verify the configuration.
[Sysname-Ten-GigabitEthernet3/0/1] port private-vlan 20 30 trunk secondary
return
¡ Ten-GigabitEthernet 3/0/1 is a trunk secondary port of VLANs 20 and 30.
¡ Ten-GigabitEthernet 3/0/1 is a tagged member of VLANs 2, 3, 20, and 30.
¡ The port link type of Ten-GigabitEthernet 3/0/1 is hybrid.
# Execute the undo port private-vlan trunk secondary command on Ten-GigabitEthernet 3/0/1, and then verify the configuration.
[Sysname-Ten-GigabitEthernet3/0/1] undo port private-vlan 20 30 trunk secondary
port hybrid vlan 2 3 tagged
return
¡ Ten-GigabitEthernet 3/0/1 is removed from VLANs 20 and 30.
¡ Ten-GigabitEthernet 3/0/1 is a tagged member of VLANs 2 and 3.
¡ The port link type and PVID of Ten-GigabitEthernet 3/0/1 do not change.
· In this example, VLAN 10 is not a secondary VLAN.
return
# Configure Ten-GigabitEthernet 3/0/1 as a trunk secondary port of VLAN 10, and then verify the configuration.
[Sysname-Ten-GigabitEthernet3/0/1] port private-vlan 10 trunk secondary
port hybrid vlan 10 tagged
return
¡ Ten-GigabitEthernet 3/0/1 is a trunk secondary port of VLAN 10.
¡ Ten-GigabitEthernet 3/0/1 is a tagged member of VLAN 10.
# Execute the undo port private-vlan trunk secondary command on Ten-GigabitEthernet3/0/1, and then verify the configuration.
[Sysname-Ten-GigabitEthernet3/0/1] undo port private-vlan 10 trunk secondary
return
¡ Ten-GigabitEthernet 3/0/1 is removed from VLAN 10.
Use private-vlan to associate a primary VLAN with the specified secondary VLANs.
Use undo private-vlan to dissociate a primary VLAN from the specified secondary VLANs.
private-vlan secondary vlan-id-list
undo private-vlan [ secondary vlan-id-list ]
A primary VLAN is not associated with any secondary VLANs.
VLAN view
secondary vlan-id-list: Specifies a space-separated list of up to 10 secondary VLAN items. Each item specifies a secondary VLAN ID or a range of secondary VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for secondary VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument. Though the system default VLAN (VLAN 1) is in the valid value range, it cannot be configured in the command.
A primary VLAN can be associated with multiple secondary VLANs. When you execute this command in the same VLAN view multiple times, all the specified secondary VLANs are associated with the primary VLAN.
The configuration synchronization is triggered based on the interface configuration when the following conditions exist:
· This command is configured for a primary VLAN.
· Ports on the device are promiscuous, trunk promiscuous, or host ports.
When you execute the undo private-vlan command, follow these guidelines:
· If you specify the secondary vlan-id-list option, this command dissociates the primary VLAN from the specified secondary VLANs.
· If you do not specify the secondary vlan-id-list option, this command dissociates the primary VLAN from all secondary VLANs.
# Associate primary VLAN 2 with secondary VLANs 3 and 4.
[Sysname] vlan 3 to 4
[Sysname] vlan 2
[Sysname-vlan2] private-vlan primary
[Sysname-vlan2] private-vlan secondary 3 to 4
primary-vlan primary
Use private-vlan primary to configure a VLAN as a primary VLAN.
Use undo private-vlan primary to restore the default.
A VLAN is not a primary VLAN.
VLAN view
· This command is configured for a VLAN that has been associated with secondary VLANs.
· Ports on the device are promiscuous, trunk promiscuous, host, or trunk secondary ports.
# Configure VLAN 5 as a primary VLAN.
[Sysname] vlan 5
[Sysname-vlan5] private-vlan primary
Voice VLAN commands
display voice-vlan mac-address
Use display voice-vlan mac-address to display the OUI addresses supported on the device.
# Display the OUI addresses supported on the device.
<Sysname> display voice-vlan mac-address
OUI Address Mask Description
0001-e300-0000 ffff-ff00-0000 Siemens phone
0003-6b00-0000 ffff-ff00-0000 Cisco phone
0004-0d00-0000 ffff-ff00-0000 Avaya phone
000f-e200-0000 ffff-ff00-0000 H3C Aolynk phone
0060-b900-0000 ffff-ff00-0000 Philips/NEC phone
00d0-1e00-0000 ffff-ff00-0000 Pingtel phone
00e0-7500-0000 ffff-ff00-0000 Polycom phone
00e0-bb00-0000 ffff-ff00-0000 3Com phone
Table 15 Command output
OUI Address |
OUI address allowed on the device. |
Mask |
Mask of the OUI address. |
Description of the OUI address. |
display voice-vlan state
Use display voice-vlan state to display voice VLAN information.
# Display voice VLAN information.
<Sysname> display voice-vlan state
Current voice VLANs: 1
Voice VLAN security mode: Security
Voice VLAN aging time: 1440 minutes
Voice VLAN enabled ports and their modes:
Port VLAN Mode CoS DSCP
XGE1/0/1 111 Auto 6 46
Table 16 Command output
Current Voice VLANs |
Number of existing voice VLANs. |
Voice VLAN security mode |
Voice VLAN mode: · Security. · Normal. |
Voice VLAN aging time |
Voice VLAN aging timer. No aging indicates that the voice VLAN does not age out. |
Voice VLAN enabled ports and their modes |
Voice VLAN-enabled ports and their voice VLAN assignment modes. |
Port |
Name of the voice VLAN-enabled port. |
VLAN |
ID of the voice VLAN enabled on the port. |
Mode |
Voice VLAN assignment mode of the port: · Manual. · Automatic. |
voice-vlan aging
voice-vlan enable
voice-vlan mode auto
voice-vlan security enable
voice-vlan aging
Use voice-vlan aging to set the voice VLAN aging timer.
Use undo voice-vlan aging to restore the default.
voice-vlan aging minutes
The voice VLAN aging timer is 1440 minutes (24 hours).
minutes: Sets the voice VLAN aging timer to 0 minutes or a value in the range of 5 to 43200 minutes. If you set the voice VLAN aging timer to 0 minutes, the voice VLAN does not age out.
In automatic voice VLAN assignment mode, after a port is assigned to a voice VLAN, the voice VLAN is controlled by a voice VLAN aging timer. The voice VLAN aging timer starts only when the dynamic MAC address entry of the voice VLAN ages out. If no voice packets are received on the port before the voice VLAN aging timer expires, the device removes the port from the voice VLAN.
The aging period for a voice VLAN equals the sum of the voice VLAN aging timer and the aging timer for its dynamic MAC address entry. For more information about the aging timer for dynamic MAC address entries, see MAC address table configuration in Layer 2—LAN Switching Configuration Guide.
Set the voice VLAN aging timer only when the voice VLAN assignment mode is automatic.
# Set the voice VLAN aging timer to 100 minutes.
[Sysname] voice-vlan aging 100
voice-vlan enable
Use voice-vlan enable to enable the voice VLAN feature on a port.
Use undo voice-vlan enable to disable the voice VLAN feature on a port.
voice-vlan vlan-id enable
undo voice-vlan [ vlan-id ] enable
The voice VLAN feature is disabled on ports.
vlan-id: Specifies a voice VLAN ID in the range of 2 to 4094.
Use this command only on a hybrid or trunk port operating in automatic voice VLAN assignment mode.
Before you execute this command, make sure the specified VLAN already exists.
# Enable the voice VLAN feature on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] voice-vlan 2 enable
Use voice-vlan mac-address to configure the OUI address information for voice packet identification.
Use undo voice-vlan mac-address to delete an OUI address.
voice-vlan mac-address mac-address mask oui-mask [ description text ]
undo voice-vlan mac-address oui
System default OUI addresses exist.
Table 17 System default OUI addresses
Number |
OUI address |
Vendor |
1 |
0001-e300-0000 |
Siemens phone |
2 |
0003-6b00-0000 |
Cisco phone |
3 |
0004-0d00-0000 |
Avaya phone |
4 |
000f-e200-0000 |
H3C Aolynk phone |
5 |
0060-b900-0000 |
Philips/NEC phone |
6 |
00d0-1e00-0000 |
Pingtel phone |
7 |
00e0-7500-0000 |
Polycom phone |
8 |
00e0-bb00-0000 |
3Com phone |
mac-address: Specifies a source MAC address of voice traffic, in the format of H-H-H. For example, 1234-1234-1234.
mask oui-mask: Specifies the valid length of the OUI address by using a mask in the format of H-H-H. The mask contains consecutive 1s and 0s. For example, ffff-0000-0000. To match the voice devices of a vendor, set the mask to ffff-ff00-0000.
description text: Specifies the OUI address description, a case-sensitive string of 1 to 30 characters.
oui: Specifies an OUI address to delete, in the format of H-H-H. For example, 1234-1200-0000. An OUI address is the logical AND result of the mac-address and oui-mask arguments. It cannot be a broadcast address, a multicast address, or an all-zero address.
You can manually delete or add the system default OUI addresses.
# Add OUI address 1234-1200-0000 by specifying the MAC address as 1234-1234-1234 and the mask as fff-ff00-0000. Configure the OUI address description as PhoneA.
[Sysname] voice-vlan mac-address 1234-1234-1234 mask ffff-ff00-0000 description PhoneA
Use voice-vlan mode auto to configure a port to operate in automatic voice VLAN assignment mode.
Use undo voice-vlan mode auto to configure a port to operate in manual voice VLAN assignment mode.
A port operates in automatic voice VLAN assignment mode.
To make a voice VLAN take effect on a port operating in manual mode, you must manually assign the port to the voice VLAN.
# Configure Ten-GigabitEthernet 3/0/1 to operate in manual voice VLAN assignment mode.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] undo voice-vlan mode auto
voice-vlan qos
Use voice-vlan qos to configure a port to modify the CoS and DSCP values for incoming voice VLAN packets.
Use undo voice-vlan qos to restore the default.
voice-vlan qos cos-value dscp-value
undo voice-vlan qos
A port modifies the CoS and DSCP values for incoming voice VLAN packets to 6 and 46, respectively.
cos-value: Specifies a CoS value in the range of 0 to 7. A bigger CoS value represents a higher priority.
dscp-value: Specifies a DSCP value in the range of 0 to 63. A bigger DSCP value represents a higher priority.
You cannot execute this command on a voice VLAN-enabled port. Before you execute this command on a port, you must disable the voice VLAN feature on it.
If you execute both the voice-vlan qos and voice-vlan qos trust commands multiple times, the most recent configuration takes effect.
# Configure Ten-GigabitEthernet 3/0/1 to modify the CoS and DSCP values for voice VLAN packets to 5 and 45, respectively.
[Sysname-Ten-GigabitEthernet3/0/1] voice-vlan qos 5 45
Use voice-vlan qos trust to configure a port to trust the priority settings in incoming voice VLAN packets.
undo voice-vlan qos
When a port trusts the QoS priority settings in incoming voice VLAN packets, the port does not modify their CoS and DSCP values.
# Configure Ten-GigabitEthernet 3/0/1 to trust the priority settings in incoming voice VLAN traffic.
[Sysname-Ten-GigabitEthernet3/0/1] voice-vlan qos trust
voice-vlan qos
Use voice-vlan security enable to enable the voice VLAN security mode.
Use undo voice-vlan security enable to disable the voice VLAN security mode.
The voice VLAN security mode is enabled.
In security mode, a voice VLAN transmits only voice packets whose source MAC addresses match the OUI addresses of the device.
In normal mode, a voice VLAN transmits voice packets and non-voice packets.
# Disable the voice VLAN security mode.
[Sysname] undo voice-vlan security enable
voice-vlan track lldp
Use voice-vlan track lldp to enable LLDP for automatic IP phone discovery.
Use undo voice-vlan track lldp to disable LLDP for automatic IP phone discovery.
LLDP for automatic IP phone discovery is disabled.
# Enable LLDP for automatic IP phone discovery.
[Sysname] voice-vlan track lldp
