04-Layer 2—LAN Switching Command Reference
HomeSupportSwitchesS7500X-G SeriesReference GuidesCommand ReferencesH3C S7500X-G Switch Series Command References-R7755Pxx-6W10004-Layer 2—LAN Switching Command Reference
06-MVRP commands
06-MVRP commands 115.98 KB
MVRP commands
MDC is supported only when the device operates in standalone mode. For more information about standalone mode, see IRF configuration in Virtual Technologies Configuration Guide. For more information about MDC and device models that support MDC, see MDC configuration in Virtual Technologies Configuration Guide.
display mvrp running-status
Use display mvrp running-status to display MVRP running status.
display mvrp running-status [ interface interface-list ]
interface interface-list: Specifies a range of Ethernet interfaces in the form of interface-type interface-number1 [ to interface-type interface-number2 ]. The interface-type interface-number argument represents the interface type and interface number. The value for the interface-number2 argument must be greater than or equal to the value for the interface-number1 argument. If the specified interfaces are not enabled with MVRP, this command displays global MVRP information. If you do not specify this option, the command displays global MVRP information and MVRP running status for all MVRP-enabled ports.
# Display global MVRP information and MVRP running status for all MVRP-enabled ports.
<Sysname> display mvrp running-status
 -------[MVRP Global Info]-------
 Global Status     : Enabled
 Compliance-GVRP   : False
 ----[Ten-GigabitEthernet3/0/1]----
 Config Status                  : Enabled
 Running Status                 : Enabled
 Join Timer                     : 20 (centiseconds)
 Leave Timer                    : 60 (centiseconds)
 Periodic Timer                 : 100 (centiseconds)
 LeaveAll Timer                 : 1000 (centiseconds)
 Registration Type              : Normal
 Registered VLANs :
  1(default), 2-10
 Declared VLANs :
  1(default), 2-10
 Propagated VLANs :
  1(default), 2-10
 ----[Ten-GigabitEthernet3/0/2]----
 Running Status                 : Disabled
 Registered VLANs :
  None
 Declared  VLANs :
  None
 Propagated VLANs :
  None
MVRP Global Info
Global MVRP information.
Global Status
Global MVRP status:
·     Enabled.
·     Disabled.
Compliance-GVRP
GVRP compatibility status:
·     True—Compatible.
·     False—Incompatible.
Config Status
Whether MVRP is enabled on the port:
·     Enabled.
·     Disabled.
Running Status
Whether MVRP takes effect on the port:
·     Enabled—MVRP takes effect on the port.
·     Disabled—MVRP does not take effect on the port.
Whether MVRP takes effect on a port is determined by the following items:
·     Global and port-specific MVRP enabling status.
·     Physical link state of the port.
·     Port link type.
·     Whether the port is a member of an aggregation group.
Registration Type
MVRP registration mode:
·     Normal.
·     Fixed.
·     Forbidden.
Registered VLANs
VLANs that the port has registered.
Declared VLANs
VLANs that the port has declared to its peer participant.
Propagated VLANs
VLANs that the port has learned and notified other participants on the same device to declare to their respective peer participants.
display mvrp state
Use display mvrp state to display the MVRP state of a port in a VLAN.
display mvrp state interface interface-type interface-number vlan vlan-id
interface interface-type interface-number: Specifies a port by its type and number.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094.
# Display the MVRP state of Ten-GigabitEthernet 3/0/1 in VLAN 2.
<Sysname> display mvrp state interface ten-gigabitethernet 3/0/1 vlan 2
 MVRP state of VLAN 2 on port XGE3/0/1:
 Port                      VLAN   App-state   Reg-state
 XG3/0/1                      2       VP          IN
App-state
State of the attribute that the local participant declares to its peer participant:
·     VO—Very anxious observer.
·     VP—Very anxious passive.
·     VN—Very anxious new.
·     AN—Anxious new.
·     AA—Anxious active.
·     QA—Quiet active.
·     LA—Leaving active.
·     AO—Anxious observer.
·     QO—Quiet observer.
·     AP—Anxious passive.
·     QP—Quiet passive.
·     LO—Leaving observer.
Reg-state
Registration state of the attribute declared by the peer participant on the local participant:
·     IN—The attribute is registered.
·     LV—The attribute is previously registered, but now it is being deregistered.
·     MT—The attribute is not registered.
display mvrp statistics
Use display mvrp statistics to display MVRP statistics.
display mvrp statistics [ interface interface-list ]
interface interface-list: Specifies a range of Ethernet interfaces in the form of interface-type interface-number1 [ to interface-type interface-number2 ]. The interface-type interface-number argument represents the interface type and interface number. The value for the interface-number2 argument must be greater than or equal to the value for the interface-number1 argument. If you do not specify this option, the command displays MVRP statistics of all MVRP-enabled ports.
If MVRP is disabled on the specified ports, this command does not provide any output.
# Display MVRP statistics of all ports.
<Sysname> display mvrp statistics
 Failed Registrations        : 1
 Last PDU Origin             : 000f-e200-0010
 Frames Received             : 201
  New Event Received          : 0
  JoinIn Event Received       : 1167
  In Event Received           : 0
  JoinMt Event Received       : 22387
  Mt Event Received           : 31
  Leave Event Received        : 210
  LeaveAll Event Received     : 63
 Frames Transmitted          : 120
  New Event Transmitted       : 0
  JoinIn Event Transmitted    : 311
  In Event Transmitted        : 0
  JoinMt Event Transmitted    : 873
  Mt Event Transmitted        : 11065
  Leave Event Transmitted     : 167
  LeaveAll Event Transmitted  : 4
 Frames Discarded            : 0
 Failed Registrations        : 0
 Last PDU Origin             : 0000-0000-0000
 Frames Received             : 0
  JoinIn Event Received       : 0
  JoinMt Event Received       : 0
  Leave Event Received        : 0
  LeaveAll Event Received     : 0
 Frames Transmitted          : 0
  JoinIn Event Transmitted    : 0
  JoinMt Event Transmitted    : 0
  Leave Event Transmitted     : 0
  LeaveAll Event Transmitted  : 0
Number of VLAN registration failures through MVRP on the local participant.
Last PDU Origin
Source MAC address of the last MVRPDU.
Frames Received
Number of MVRP frames received.
New Event Received
Number of New events received.
Number of JoinIn events received.
In Event Received
Number of In events received.
Number of JoinMt events received.
Mt Event Received
Number of Mt events received.
Number of Leave events received.
Number of LeaveAll events received.
Frames Transmitted
Number of MVRP frames sent.
Number of New events sent.
Number of JoinIn events sent.
Number of In events sent.
Number of JoinMt events sent.
Number of Mt events sent.
Number of Leave events sent.
Number of LeaveAll events sent.
Frames Discarded
Number of MVRP frames dropped.
mrp timer join
Use mrp timer join to set the Join timer.
Use undo mrp timer join to restore the default.
mrp timer join timer-value
undo mrp timer join
The Join timer is 20 centiseconds.
timer-value: Specifies the Join timer value (in centiseconds). The Join timer must meet the following requirements:
·     Not less than 20 centiseconds.
·     Less than half the Leave timer.
·     Divisible by 20 centiseconds.
# Set the Join timer to 40 centiseconds. (In this example, the Leave timer is 100 centiseconds.)
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] mrp timer join 40
mrp timer leave
mrp timer leave
Use mrp timer leave to set the Leave timer.
Use undo mrp timer leave to restore the default.
mrp timer leave timer-value
The Leave timer is 60 centiseconds.
timer-value: Specifies the Leave timer value (in centiseconds). The Leave timer must meet the following requirements:
·     Greater than two times the Join timer.
·     Less than the LeaveAll timer.
# Set the Leave timer to 100 centiseconds. (In this example, the Join timer and LeaveAll timer use their default settings.)
[Sysname-Ten-GigabitEthernet3/0/1] mrp timer leave 100
mrp timer join
mrp timer leaveall
mrp timer leaveall
Use mrp timer leaveall to set the LeaveAll timer.
Use undo mrp timer leaveall to restore the default.
mrp timer leaveall timer-value
The LeaveAll timer is 1000 centiseconds.
Parameter
timer-value: Specifies the LeaveAll timer value (in centiseconds). The LeaveAll timer must meet the following requirements:
·     Greater than any Leave timer on each port.
·     Not greater than 32760 centiseconds.
Each time the LeaveAll timer of a port expires, all attributes of the MSTIs on the port are deregistered throughout the network. To prevent this type of deregistration from affecting the network, do not set the LeaveAll timer to less than its default value.
To keep the dynamic VLANs learned through MVRP stable, do not set the LeaveAll timer less than its default value.
The device randomly changes the LeaveAll timer within a certain range when an MRP participant restarts its LeaveAll timer. This prevents the LeaveAll timer of a particular participant from always expiring first.
# Set the LeaveAll timer to 1500 centiseconds. (In this example, the Leave timer on each port uses the default setting.)
[Sysname-Ten-GigabitEthernet3/0/1] mrp timer leaveall 1500
mrp timer leave
mrp timer periodic
Use mrp timer periodic to set the Periodic timer.
Use undo mrp timer periodic to restore the default.
mrp timer periodic timer-value
The Periodic timer is 100 centiseconds.
timer-value: Specifies the Periodic timer, which can be 0 or 100 centiseconds.
Setting the Periodic timer to 0 disables the Periodic timer.
Setting the Periodic timer to 100 enables the Periodic timer. The participant then sends MRP frames at an interval of 100 centiseconds.
# Disable the Periodic timer.
[Sysname-Ten-GigabitEthernet3/0/1] mrp timer periodic 0
mvrp enable
Use mvrp enable to enable MVRP on a port.
Use undo mvrp enable to disable MVRP on a port.
mvrp enable
undo mvrp enable
MVRP is disabled on a port.
For MVRP to take effect on a port, make sure the following requirements are met:
·     MVRP is enabled both globally and on the port.
·     The port is physically up.
·     The port link type is trunk.
·     The port is not a member of an aggregation group.
# Enable MVRP on Ten-GigabitEthernet 3/0/1.
[Sysname] mvrp global enable
[Sysname-Ten-GigabitEthernet3/0/1] port link-type trunk
[Sysname-Ten-GigabitEthernet3/0/1] mvrp enable
mvrp global enable
Use mvrp global enable to enable MVRP globally.
Use undo mvrp global enable to disable MVRP globally.
mvrp global enable
MVRP is disabled globally.
For MVRP to take effect on a port, enable MVRP both on the port and globally.
Disabling MVRP globally also disables MVRP on all ports.
# Enable MVRP globally.
mvrp gvrp-compliance enable
Use mvrp gvrp-compliance enable to enable GVRP compatibility for MVRP.
Use undo mvrp gvrp-compliance enable to restore the default.
MVRP is incompatible with GVRP.
When you enable GVRP compatibility for MVRP, the device can receive and send both MVRP and GVRP frames.
# Enable GVRP compatibility for MVRP.
[Sysname] mvrp gvrp-compliance enable
mvrp registration
Use mvrp registration to set the MVRP registration mode on a port.
Use undo mvrp registration to restore the default.
mvrp registration { fixed | forbidden | normal }
The MVRP registration mode is normal.
fixed: Specifies the fixed registration mode.
forbidden: Specifies the forbidden registration mode.
normal: Specifies the normal registration mode.
# Set the MVRP registration mode to fixed on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] mvrp registration fixed
reset mvrp statistics
Use reset mvrp statistics to clear MVRP statistics for ports.
reset mvrp statistics [ interface interface-list ]
interface interface-list: Specifies a range of Ethernet interfaces in the form of interface-type interface-number1 [ to interface-type interface-number2 ]. The interface-type interface-number argument represents the interface type and interface number. The value for the interface-number2 argument must be greater than or equal to the value for the interface-number1 argument. If you do not specify this option, the command clears MVRP statistics of all ports.
# Clear MVRP statistics for all ports.
<Sysname> reset mvrp statistics
