- 05-Layer 2—LAN Switching Configuration Guide
- 01-MAC address table configuration
- 02-Ethernet link aggregation configuration
- 03-M-LAG configuration
- 04-Port isolation configuration
- 05-VLAN configuration
- 06-QinQ configuration
- 07-Loop detection configuration
- 08-Spanning tree configuration
- 09-LLDP configuration
- 10-PFC configuration
- 11-Service loopback group configuration
| 02-Ethernet link aggregation configuration | 554.47 KB |
Configuring Ethernet link aggregation
About Ethernet link aggregation
Ethernet link aggregation application scenario
Aggregate interface, aggregation group, and member port
How static link aggregation works
How dynamic link aggregation works
Load sharing modes for link aggregation groups
Restrictions and guidelines: Mixed use of manual and automatic link aggregation configuration
Ethernet link aggregation tasks at a glance
Configuring a manual link aggregation
Restrictions and guidelines for aggregation group configuration
Configuring a Layer 2 aggregation group
Configuring a Layer 3 aggregation group
Configuring a 1+1 backup aggregation group
About 1+1 backup link aggregation
1+1 backup link aggregation tasks at a glance
Configuring a static 1+1 backup aggregation group
Specifying a primary member port
Configuring a 1+1 backup aggregation group to place its secondary member port in down state
Performing a primary/secondary member port switchover
Configuring an aggregate interface
Configuring the basic parameters of an aggregate interface
Assigning a MAC address to an aggregate interface
Configuring jumbo frame support
Setting the MTU of an aggregate interface
Configuring an edge aggregate interface
Enabling statistics collection on Layer 3 aggregate subinterfaces
Enabling interframe gap and preamble statistics in the traffic statistics
Restoring the default settings for an aggregate interface
Setting the minimum and maximum numbers of Selected ports for an aggregation group
Setting the minimum percentage of Selected ports in an aggregation group
Configuring the link aggregation capability of the device
Configuring load sharing for link aggregation groups
Setting static load sharing modes for link aggregation groups
Setting a dynamic load sharing mode for a link aggregation group
Specifying ignored packet fields for default link-aggregation load sharing
Configuring link aggregation load sharing algorithm settings
Setting a hash offset to adjust the load balancing results on link aggregations
Setting the load sharing mode for tunneled traffic
Isolating aggregate interfaces on the device
Enabling BFD for an aggregation group
Verifying and maintaining Ethernet link aggregation
Displaying the link aggregation capability of the device
Verifying aggregate interface and aggregation member port running status
Displaying the local system ID
Displaying link-aggregation load sharing information
Displaying and clearing interface statistics
Clearing LACP statistics for link aggregation member ports
Ethernet link aggregation configuration examples
Example: Configuring a Layer 2 static aggregation group
Example: Configuring a Layer 2 dynamic aggregation group
Example: Configuring a Layer 2 edge aggregate interface
Example: Configuring a Layer 3 static aggregation group
Ethernet link aggregation bundles multiple physical Ethernet links into one logical link (called an aggregate link). Link aggregation provides the following benefits:
· Increased bandwidth beyond the limits of a single individual link. In an aggregate link, traffic is distributed across the member ports.
· Improved link reliability. The member ports dynamically back up one another. When a member port fails, its traffic is automatically switched to other member ports.
As shown in Figure 1, Device A and Device B are connected by three physical Ethernet links. These physical Ethernet links are combined into an aggregate link called link aggregation 1. The bandwidth of this aggregate link can reach up to the total bandwidth of the three physical Ethernet links. At the same time, the three Ethernet links back up one another. When a physical Ethernet link fails, the traffic transmitted on the failed link is switched to the other two links.
Figure 1 Ethernet link aggregation diagram
Each link aggregation is represented by a logical aggregate interface. Each aggregate interface has an automatically created aggregation group, which contains member ports to be used for aggregation. The type and number of an aggregation group are the same as its aggregate interface.
Supported aggregate interface types
An aggregate interface can be one of the following types:
· Layer 2—A Layer 2 aggregate interface is created manually. The member ports in a Layer 2 aggregation group can only be Layer 2 Ethernet interfaces.
· Layer 3—A Layer 3 aggregate interface is created manually. The member ports in its Layer 3 aggregation group can only be Layer 3 Ethernet interfaces.
On a Layer 3 aggregate interface, you can create subinterfaces. A Layer 3 aggregate subinterface processes traffic only for the VLAN numbered with the same ID as the subinterface number.
The port rate of an aggregate interface equals the total rate of its Selected member ports. Its duplex mode is the same as that of the Selected member ports. For more information about Selected member ports, see "Aggregation states of member ports in an aggregation group."
A member port in an aggregation group can be in any of the following aggregation states:
· Selected—A Selected port can forward traffic.
· Unselected—An Unselected port cannot forward traffic.
· Individual—An Individual port can forward traffic as a normal physical port. This state is peculiar to the member ports of edge aggregate interfaces. A member port is placed in Individual state if it has not received LACPDUs before the first expiration of the LACP timeout timer after either of the following event occurs:
¡ The aggregate interface is configured as an edge aggregate interface.
¡ The member port goes down and then comes up after it is placed in Unselected or Selected state.
For more information about edge aggregate interfaces, see "Edge aggregate interface."
Operational key
When aggregating ports, the system automatically assigns each port an operational key based on port information, such as port rate and duplex mode. Any change to this information triggers a recalculation of the operational key.
In an aggregation group, all Selected ports have the same operational key.
Configuration types
Port configuration includes the attribute configuration and protocol configuration. Attribute configuration affects the aggregation state of the port but the protocol configuration does not.
To become a Selected port, a member port must have the same attribute configuration as the aggregate interface. Table 1 describes the attribute configuration.
Table 1 Attribute configuration
Feature |
Attribute configuration |
VLAN |
VLAN attribute settings: · Permitted VLAN IDs. · PVID. · Link type (trunk, hybrid, or access). For information about VLANs, see "Configuring VLANs." |
Protocol configuration
Protocol configuration of a member port does not affect the aggregation state of the member port. MAC address learning and spanning tree settings are examples of the protocol configuration.
Link aggregation modes
An aggregation group operates in one of the following modes:
· Static—Static aggregation is stable. An aggregation group in static mode is called a static aggregation group. The aggregation states of the member ports in a static aggregation group are not affected by the peer ports.
· Dynamic—An aggregation group in dynamic mode is called a dynamic aggregation group. Dynamic aggregation is implemented through IEEE 802.3ad Link Aggregation Control Protocol (LACP). The local system and the peer system automatically maintain the aggregation states of the member ports. Dynamic link aggregation reduces the administrators' workload.
Reference port selection process
When setting the aggregation states of the ports in an aggregation group, the system automatically chooses a member port as the reference port. A Selected port must have the same operational key and attribute configurations as the reference port.
The system chooses a reference port from the member ports in up state.
The candidate reference ports are organized into different priority levels following these rules:
1. In descending order of port priority.
2. Full duplex.
3. In descending order of speed.
4. Half duplex.
5. In descending order of speed.
From the candidate ports with the same attribute configurations as the aggregate interface, the one with the highest priority level is chosen as the reference port.
· If multiple ports have the same priority level, the port that has been Selected (if any) is chosen. If multiple ports with the same priority level have been Selected, the one with the smallest port number is chosen.
· If multiple ports have the same priority level and none of them has been Selected, the port with the smallest port number is chosen.
Setting the aggregation state of each member port
After the reference port is chosen, the system sets the aggregation state of each member port in the static aggregation group.
Figure 2 Setting the aggregation state of a member port in a static aggregation group
After the limit on Selected ports is reached, the aggregation state of a new member port varies by following conditions:
· The port is placed in Unselected state if the port and the Selected ports have the same port priority. This mechanism prevents traffic interruption on the existing Selected ports. A device reboot can cause the device to recalculate the aggregation states of member ports.
· The port is placed in Selected state when the following conditions are met:
¡ The port and the Selected ports have different port priorities, and the port has a higher port priority than a minimum of one Selected port.
¡ The port has the same attribute configurations as the aggregate interface.
Any operational key or attribute configuration change might affect the aggregation states of link aggregation member ports.
About LACP
LACP uses LACPDUs to exchange aggregation information between LACP-enabled devices. Each member port in a dynamic aggregation group can exchange information with its peer. When a member port receives an LACPDU, it compares the received information with information received on the other member ports. In this way, the two systems reach an agreement on which ports are placed in Selected state.
LACP functions
LACP offers basic LACP functions and extended LACP functions, as described in Table 2.
Table 2 Basic and extended LACP functions
Category |
Basic LACP functions |
Implemented through the basic LACPDU fields, including the LACP system priority, system MAC address, port priority, port number, and operational key. |
Extended LACP functions |
Implemented by extending the LACPDU with new TLV fields. |
LACP operating modes
LACP can operate in active or passive mode.
When LACP is operating in passive mode on a local member port and its peer port, both ports cannot send LACPDUs. When LACP is operating in active mode on either end of a link, both ports can send LACPDUs.
LACP priorities
LACP priorities include LACP system priority and port priority, as described in Table 3. The smaller the priority value, the higher the priority.
Type |
LACP system priority |
Used by two peer devices (or systems) to determine which one is superior in link aggregation. In dynamic link aggregation, the system that has higher LACP system priority sets the Selected state of member ports on its side. The system that has lower priority sets the aggregation state of local member ports the same as their respective peer ports. |
Port priority |
Determines the likelihood of a member port to be a Selected port on a system. A port with a higher port priority is more likely to become Selected. |
LACP timeout interval
The LACP timeout interval specifies how long a member port waits to receive LACPDUs from the peer port. If a local member port has not received LACPDUs from the peer within the LACP timeout interval, the member port considers the peer as failed.
The LACP timeout interval also determines the LACPDU sending rate of the peer. LACP timeout intervals include the following types:
· Short timeout interval—3 seconds. If you use the short timeout interval, the peer sends one LACPDU per second.
· Long timeout interval—90 seconds. If you use the long timeout interval, the peer sends one LACPDU every 30 seconds.
Methods to assign interfaces to a dynamic link aggregation group
You can use one of the following methods to assign interfaces to a dynamic link aggregation group:
· Manual assignment—Manually assign interfaces to the dynamic link aggregation group.
· Automatic assignment—Enable automatic assignment on interfaces to have them automatically join a dynamic link aggregation group depending on the peer information in the received LACPDUs.
NOTE: When you use automatic assignment on one end, you must use manual assignment on the other end. |
Automatic member port assignment
This feature automates the assignment of aggregation member ports to an aggregation group. You can use this feature when setting up an aggregate link to a server.
As shown in Figure 3, an interface enabled with automatic assignment joins a dynamic aggregation group based on the peer information in the LACPDUs received from the aggregation peer. If none of the existing dynamic aggregation groups is qualified, the device automatically creates a new dynamic aggregation group, Then, the device assigns the interface to that group and synchronizes the interface's attribute configurations to the aggregate interface.
A dynamic aggregation group that contains automatically assigned member ports selects a reference port and Selected ports as described in "How dynamic link aggregation works." The assignment methods of member ports do not change the processes of reference port selection and Selected port selection.
Figure 3 Automatic member port assignment process
Choosing a reference port
The system chooses a reference port from the member ports in up state. A Selected port must have the same operational key and attribute configurations as the reference port.
The local system (the actor) and the peer system (the partner) negotiate a reference port by using the following workflow:
1. The two systems determine the system with the smaller system ID.
A system ID contains the LACP system priority and the system MAC address.
a. The two systems compare their LACP priority values.
The lower the LACP priority, the smaller the system ID. If the LACP priority values are the same, the two systems proceed to step b.
b. The two systems compare their MAC addresses.
The lower the MAC address, the smaller the system ID.
2. The system with the smaller system ID chooses the port with the smallest port ID as the reference port.
A port ID contains a port priority and a port number. The lower the port priority, the smaller the port ID.
a. The system chooses the port with the lowest priority value as the reference port.
If the ports have the same priority, the system proceeds to step b.
b. The system compares their port numbers.
The smaller the port number, the smaller the port ID.
The port with the smallest port number and the same attribute configurations as the aggregate interface is chosen as the reference port.
NOTE: To identify the port numbers of aggregation member ports, execute the display link-aggregation verbose command and examine the Index field in the command output. |
After the reference port is chosen, the system with the smaller system ID sets the state of each member port on its side.
Figure 4 Setting the state of a member port in a dynamic aggregation group
The system with the greater system ID can detect the aggregation state changes on the peer system. The system with the greater system ID sets the aggregation state of local member ports the same as their peer ports.
When you aggregate interfaces in dynamic mode, follow these guidelines:
· A dynamic link aggregation group chooses only full-duplex ports as the Selected ports.
· For stable aggregation and service continuity, do not change the operational key or attribute configurations on any member port.
· When a member port changes to the Selected or Unselected state, its peer port changes to the same aggregation state.
· After the Selected port limit is reached, a newly joining port becomes a Selected port if it is more eligible than a current Selected port.
Dynamic link aggregation fails on a server-facing aggregate interface if dynamic link aggregation is configured only on the device. The device forwards traffic by using only one of the physical ports that are connected to the server.
To improve link reliability, configure the aggregate interface as an edge aggregate interface. This feature enables all member ports of the aggregation group to forward traffic. When a member port fails, its traffic is automatically switched to other member ports.
After dynamic link aggregation is configured on the server, the device can receive LACPDUs from the server. Then, link aggregation between the device and the server operates correctly.
An edge aggregate interface takes effect only when it is configured on an aggregate interface corresponding to a dynamic aggregation group.
In a link aggregation group, traffic can be load shared across the Selected ports based on any of the following modes:
· Per-flow load sharing—Distributes traffic on a per-flow basis. The load sharing mode classifies packets into flows and forwards packets of the same flow on the same link. This mode can be one of or a combination of the following hashing keys:
¡ Ingress port.
¡ Source or destination IP.
¡ Source or destination MAC.
¡ Source or destination port number.
¡ Protocol number.
¡ VLAN tag.
S-MLAG
Simple multichassis link aggregation (S-MLAG) enhances dynamic link aggregation to establish an aggregation that spans multiple standalone devices to a remote device.
An S-MLAG multichassis aggregation connects one dynamic Layer 2 aggregate interface on each S-MLAG device to the remote device, as shown in Figure 5.
S-MLAG uses an S-MLAG group to manage the aggregate interfaces for each aggregation, and it runs LACP to maintain each aggregation as does dynamic link aggregation. To the remote device, the S-MLAG devices appear as one peer aggregation system.
Figure 5 S-MLAG application scenario
To avoid unexpected aggregation issues, do not use manual assignment, automatic assignment, and automatic link aggregation in any combination. If you use any two of these features in combination, an automatically assigned member port might move between aggregation groups or undesirably change from Selected to Unselected in some situations.
For a mirroring group, do not assign the source port to an aggregation group other than the one that accommodates the monitor port, egress port, or reflector port. If the source port is in a different aggregation group than the other ports, mirrored LACPDUs will be transmitted between the aggregation groups and cause aggregate interface flapping.
To configure Ethernet link aggregation, perform the following tasks:
2. Configuring link aggregations
¡ Configuring a manual link aggregation
¡ Configuring a 1+1 backup aggregation group
3. (Optional.) Configuring an aggregate interface
¡ Configuring the basic parameters of an aggregate interface
¡ Assigning a MAC address to an aggregate interface
¡ Configuring jumbo frame support
¡ Setting the MTU of an aggregate interface
¡ Configuring an edge aggregate interface
An edge aggregate interface uses all member ports to forward traffic when the aggregation peer is not enabled with dynamic link aggregation.
¡ Enabling statistics collection on Layer 3 aggregate subinterfaces
¡ Enabling interframe gap and preamble statistics in the traffic statistics
¡ Restoring the default settings for an aggregate interface
4. (Optional.) Adjusting aggregation states of link aggregation member ports
¡ Setting the minimum and maximum numbers of Selected ports for an aggregation group
¡ Setting the minimum percentage of Selected ports in an aggregation group
5. (Optional.) Configuring load sharing for link aggregation groups
¡ Setting static load sharing modes for link aggregation groups
¡ Setting a dynamic load sharing mode for a link aggregation group
¡ Specifying ignored packet fields for default link-aggregation load sharing
¡ Configuring link aggregation load sharing algorithm settings
¡ Setting a hash offset to adjust the load balancing results on link aggregations
6. (Optional.) Optimizing traffic forwarding
¡ Isolating aggregate interfaces on the device
7. (Optional.) Enabling BFD for an aggregation group
Configuring the system ID
The two ends of a dynamic aggregate link choose a reference port from the end with a smaller system ID.
The system ID contains the LACP system priority and LACP system MAC address. Two devices use the following rules to compare their system IDs:
· If their system IDs contain different LACP system priorities, the system ID with a smaller LACP system priority value is smaller.
· If their system IDs contain the same LACP system priority, the system ID with a lower LACP system MAC address is smaller.
To view the LACP system MAC address and LACP system priority, execute the display link-aggregation verbose command.
You can configure the system ID globally and in aggregate interface view. The global system ID takes effect on all aggregation groups, and an aggregate-interface-specific system ID takes precedence over the global system ID.
Member devices in an S-MLAG system must use the same LACP system priority and LACP system MAC address.
On an M-LAG system, M-LAG interfaces in the same M-LAG group cannot use the same LACP system MAC address.
For member ports to be selected correctly, do not modify the LACP system priority and LACP system MAC address after a dynamic link aggregation is established.
1. Enter system view.
2. Set the LACP system MAC address globally.
lacp system-mac mac-address
By default, the LACP system MAC address is the bridge MAC address of the device.
3. Set the LACP system priority globally.
lacp system-priority priority
By default, the LACP system priority is 32768.
4. Enter aggregate interface view.
¡ Enter Layer 3 aggregate interface view.
5. Set the LACP system MAC address on the aggregate interface.
port lacp system-mac mac-address
6. Set the LACP system priority on the aggregate interface.
port lacp system-priority priority
Layer 2 aggregation group restrictions
You cannot assign an interface to a Layer 2 aggregation group if that interface has been forcibly brought up by using the port up-mode command. For more information about forcibly bringing up a fiber port, see Ethernet interface configuration in Interface Configuration Guide.
Aggregation member port restrictions
Deleting an aggregate interface also deletes its aggregation group and causes all member ports to leave the aggregation group.
An interface cannot join an aggregation group if it has different attribute configurations from the aggregate interface. After joining an aggregation group, an interface inherits the attribute configurations on the aggregate interface. You can modify the attribute configurations only on the aggregate interface.
You cannot assign monitor ports for port mirroring to an aggregation group.
Attribute and protocol configuration restrictions
For a link aggregation, attribute configurations are configurable only on the aggregate interface and are automatically synchronized to all member ports. You cannot configure attribute configurations on a member port until it is removed from the link aggregation group. The configurations that have been synchronized from the aggregate interface are retained on the member ports even after the aggregate interface is deleted.
If an attribute setting on the aggregate interface fails to be synchronized to a Selected member port, the port might change to the Unselected state.
The protocol configurations for an aggregate interface take effect only on the current aggregate interface. The protocol configurations for a member port take effect only when the port leaves its aggregation group.
Configuration consistency requirements
You must configure the same aggregation mode at the two ends of an aggregate link.
· For a successful static aggregation, make sure the ports at both ends of each link are in the same aggregation state.
· For a successful dynamic aggregation:
¡ Make sure the ports at both ends of a link are assigned to the correct aggregation group. The two ends can automatically negotiate the aggregation state of each member port.
¡ If you use automatic interface assignment on one end, you must use manual assignment on the other end.
2. Create a Layer 2 aggregate interface and enter Layer 2 aggregate interface view.
When you create a Layer 2 aggregate interface, the system automatically creates a Layer 2 static aggregation group numbered the same as that interface.
3. Configure the aggregation group to operate in static mode.
link-aggregation mode static
By default, an aggregation group operates in static mode.
4. Return to system view.
5. Assign an interface to the Layer 2 aggregation group:
a. Enter Layer 2 Ethernet interface view.
b. Assign the interface to the Layer 2 aggregation group.
port link-aggregation group group-id [ force ]
Repeat the substeps to assign more interfaces to the aggregation group.
To synchronize the attribute configurations from the aggregate interface when the current interface joins the aggregation group, specify the force keyword.
6. (Optional.) Set the port priority of the interface.
The default port priority of an interface is 32768.
3. Configure the aggregation group to operate in dynamic mode.
link-aggregation mode dynamic
b. Assign the interface to the Layer 2 aggregation group or enable automatic assignment on that interface.
port link-aggregation group { group-id [ force ] | auto [ group-id ] }
Repeat these two substeps to assign more Layer 2 Ethernet interfaces to the aggregation group.
To enable automatic assignment, specify the auto keyword. As a best practice, do not modify the configuration on an automatically created aggregate interface or its member ports.
6. Set the LACP operating mode for the interface.
¡ Set the LACP operating mode to passive.
lacp mode passive
¡ Set the LACP operating mode to active.
undo lacp mode
By default, LACP is operating in active mode.
7. (Optional.) Set the port priority for the interface.
The default setting is 32768.
8. (Optional.) Set the short LACP timeout interval (3 seconds) for the interface.
lacp period short
By default, the long LACP timeout interval (90 seconds) is used by the interface.
2. Create a Layer 3 aggregate interface and enter Layer 3 aggregate interface view.
When you create a Layer 3 aggregate interface, the system automatically creates a Layer 3 static aggregation group numbered the same as that interface.
5. Assign an interface to the Layer 3 aggregation group:
a. Enter Layer 3 Ethernet interface view.
b. Assign the interface to the Layer 3 aggregation group.
Configuring a Layer 3 dynamic aggregation group
b. Assign the interface to the Layer 3 aggregation group or enable automatic assignment on that interface.
port link-aggregation group { group-id | auto [ group-id ] }
Repeat these two substeps to assign more Layer 3 Ethernet interfaces to the aggregation group.
lacp mode passive
undo lacp mode
7. (Optional.) Set the port priority of the interface.
lacp period short
As shown in Figure 6, a 1+1 backup aggregation group is used on a CE that is dualhomed to PEs for high availability of services. A 1+1 backup aggregation group is a static Layer 3 aggregation group that contains one primary member port and one secondary member port. The primary member port is placed in Selected state to forward all traffic, and the secondary member port is placed in Unselected state as a standby.
Figure 6 Application scenarios for 1+1 backup link aggregation
To configure a 1+1 backup aggregation group, perform the following tasks:
1. Configuring a static 1+1 backup aggregation group
2. (Optional.) Specifying a primary member port
3. (Optional.) Setting the reversion delay
4. (Optional.) Configuring a 1+1 backup aggregation group to place its secondary member port in down state
5. (Optional.) Performing a primary/secondary member port switchover
A 1+1 backup aggregation group can contain a maximum of two member ports.
3. Set the aggregation mode to static 1+1 backup.
link-aggregation mode static backup
Repeat these two substeps to assign more interfaces to the aggregation group.
In a 1+1 backup aggregation group, the primary member port is placed in Selected state to forward all traffic, and the secondary member port is placed in Unselected state as a standby. You can specify a primary member port or let the system to select a primary member port. If you specify a primary member port for a 1+1 backup aggregation group, the aggregation group can revert to the primary member port when that port recovers from failure. As a best practice, manually specify a primary member port.
If you do not specify a primary member port for an aggregation group, the system acts as follows:
· Assigns the primary role to the reference port If the member ports join the aggregation group simultaneously.
· Assigns the primary role to the member port that first becomes Selected if the member ports join the aggregation group successively.
You cannot perform this task on a port that is not an aggregation group member or is in an aggregation group not operating in 1+1 backup mode.
A 1+1 backup aggregation group can have only one primary member port.
2. Enter Layer 3 Ethernet interface view.
3. Assign the primary role to the interface.
link-aggregation primary-port
By default, a member port is not assigned the primary role in a 1+1 backup aggregation group.
The reversion delay is the time a 1+1 backup aggregation group must wait before reverting to the primary member port after that port recovers from failure. This timer prevents link flapping from causing frequent primary/secondary member port switchovers.
For the reversion delay to take effect on an aggregation group, first configure the aggregation group to operate in 1+1 backup mode and manually specify its primary member port.
2. Enter Layer 3 aggregate interface view.
3. Set the reversion delay.
link-aggregation reversion delay time-value
By default, a 1+1 backup aggregation group reverts to the primary member port immediately after that port recovers from failure.
If the peer for a 1+1 backup aggregation group is unaware of the member port roles, it might send traffic to the secondary member port, and traffic loss occurs consequently. To prevent traffic loss, configure the aggregation group to place its secondary member port in down state. This allows the peer and local ends to use only up ports to transmit traffic.
For this feature to take effect on an aggregation group, first configure the aggregation group to operate in 1+1 backup mode.
3. Configure the aggregation group to place its secondary member port in down state.
link-aggregation secondary-down
By default, the secondary member port in a 1+1 backup aggregation group is in Unselected state.
Perform this task to switch member port roles for a 1+1 backup aggregation group whose primary member port is set by the system when the state of peer ports changes.
This task might cause traffic loss. Make sure you are fully aware of the impacts of this task when you perform it on a live network.
If the link-aggregation secondary-down command has been executed for a 1+1 backup aggregation group, this task brings up the down secondary member port for it to take over the primary role.
Before you perform this task for a 1+1 backup aggregation group, verify that the following requirements are met:
· The aggregation group contains one Selected port and one Unselected port.
· The primary member port is set by the system.
· The secondary member port can become Selected.
3. Perform a primary/secondary member port switchover.
link-aggregation switchover
Configuring S-MLAG
Use S-MLAG only to establish aggregate links with servers.
Each S-MLAG group can contain only one aggregate interface on each device.
The aggregate interfaces in an S-MLAG group cannot be used as M-LAG interfaces or peer-link interfaces in M-LAG. For more information about M-LAG interfaces and peer-link interfaces, see M-LAG configuration in Layer 2—LAN Switching Configuration Guide.
On S-MLAG devices, make sure the member ports in an aggregation group have the same speed and duplex mode. Inconsistency in these settings might cause reference port reselection and interrupt traffic forwarding when new member ports join the aggregation group.
Do not configure the following settings on S-MLAG devices:
· Maximum or minimum number of Selected ports.
· Automatic member port assignment.
· Spanning tree. For more information about spanning tree, see "Configuring spanning tree protocols."
As a best practice, maintain consistency across S-MLAG devices in service feature configuration.
Configure the link aggregation settings other than S-MLAG settings on each S-MLAG device. Make sure the settings are consistent across the S-MLAG devices.
2. Set the LACP system MAC address.
All S-MLAG devices must use the same LACP system MAC address.
3. Set the LACP system priority.
All S-MLAG devices must use the same LACP system priority.
4. Set the LACP system number.
lacp system-number number
By default, the LACP system number is not set.
You must assign a unique LACP system number to each S-MLAG device.
5. Enter Layer 2 aggregate interface view.
6. Set the link aggregation mode to dynamic.
7. Assign the aggregate interface to an S-MLAG group.
port s-mlag group group-id
By default, an aggregate interface is not assigned to any S-MLAG group.
Most settings that can be made on Layer 2 or Layer 3 Ethernet interfaces can also be made on Layer 2 or Layer 3 aggregate interfaces.
Shutting down or bringing up an aggregate interface changes the aggregation states of the member ports in the aggregation group of the aggregate interface.
· When you shut down the aggregate interface, all Selected ports become Unselected, and all aggregation member ports become down.
· When you bring up the aggregate interface, the system recalculates the aggregation states of all aggregation member ports.
When you shut down or bring up a Layer 3 aggregate interface, all its aggregate subinterfaces are also shut down or brought up. Shutting down or bringing up a Layer 3 aggregate subinterface does not affect the state of the main aggregate interface.
For more information about the description, bandwidth, and shutdown commands, see common interface commands in Interface Command Reference.
2. Enter aggregate interface view.
¡ Enter Layer 3 aggregate subinterface view.
interface route-aggregation interface-number.subnumber }
3. Configure the interface description.
By default, the description of an interface is interface-name Interface.
You can configure the description of an aggregate interface for administration purposes, for example, describing the purpose of the interface.
4. Set the expected bandwidth for the interface.
bandwidth bandwidth-value
By default, the expected bandwidth (in kbps) is not configured.
5. Shut down the interface.
shutdown
CAUTION: The shutdown command will disconnect all links established on an interface. Make sure you are fully aware of the impacts of this command when you use it on a live network. |
Typically, all aggregate interfaces on a device use the same MAC address, and aggregate interfaces on different devices use different MAC addresses. However, you must set different MAC addresses for aggregate interfaces on a device in some situations.
3. Assign a MAC address to the aggregate interface.
mac-address mac-address
By default, no MAC address is assigned to an aggregate interface.
An aggregate interface might receive frames larger than 1536 bytes during high-throughput data exchanges, such as file transfers. These frames are called jumbo frames.
How an aggregate interface processes jumbo frames depends on whether jumbo frame support is enabled on the interface.
· If configured to deny jumbo frames, the aggregate interface discards jumbo frames.
· If enabled with jumbo frame support, the aggregate interface performs the following operations:
¡ Processes jumbo frames that are within the allowed length.
¡ Discards jumbo frames that exceed the allowed length.
3. Allow jumbo frames.
jumboframe enable [ size ]
By default, an aggregate interface allows jumbo frames with a maximum length of 9216 bytes to pass through.
The MTU of an interface affects IP packets fragmentation and reassembly on the interface.
2. Enter interface view.
3. Set the MTU.
mtu size
The default setting is 1500 bytes.
This configuration takes effect only on aggregate interfaces in dynamic mode.
3. Configure the aggregate interface as an edge aggregate interface.
lacp edge-port
By default, an aggregate interface does not operate as an edge aggregate interface.
Restriction and guidelines
You can use the flow-interval command to adjust the interval at which the statistics are polled. To conserve hardware resources, increase the polling interval. For more information about this command, see Ethernet interface commands in Interface Command Reference.
3. Enable rate statistics for subinterfaces of the Layer 3 aggregate interface.
sub-interface rate-statistic
By default, rate statistics collection is disabled for Layer 3 aggregate subinterfaces.
4. (Optional.) Display rate statistics for a Layer 3 aggregate subinterface.
display interface
If you execute the display interface command, the Last 300 seconds input rate or Last 300 seconds output rate field in the command output displays the average outbound or inbound traffic rate in the last 300 seconds.
By default, traffic rate = native frame length × packet throughput per second. Execute the traffic-statistic include-interframe command if you need the total traffic statistics, including the native frame length, interframe gap length and preamble length, for a specific time period. If you execute this command, traffic rate = (native frame length + interframe gap length + preamble length) × packet throughput per second.
If you perform this task on an aggregate interface, the configuration takes effect on all Ethernet interfaces in the aggregation group of the aggregate interface. The interframe gap and preamble statistics setting configured in Ethernet interface view do not take effect. If an Ethernet interface is removed from the aggregation group, the interframe gap and preamble statistics setting configured in Ethernet interface view takes effect.
When you execute the traffic-statistic include-interframe command on an Ethernet interface or aggregate interface for the first time, the system will clear statistics of the interface. Re-executing this command will not clear the statistics. When an interface joins or leaves an aggregation group, you do not need to execute this command, and the system will automatically clear the statistics of the interface.
2. Enter Ethernet interface view.
¡ Enter Layer 3 Ethernet interface view.
3. Enable interframe gap and preamble statistics in the traffic statistics.
The default for this command varies by device model.
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you execute it on a live network. |
The default command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions.
To resolve this issue:
1. Use the display this command in interface view to identify these commands.
2. Use their undo forms or follow the command reference to restore their default settings.
3. If the restoration attempt still fails, follow the error message instructions to resolve the issue.
For more information about the default command, see common interface commands in Interface Command Reference.
3. Restore the default settings for the aggregate interface.
default
The bandwidth of an aggregate link increases as the number of Selected member ports increases. To avoid congestion, you can set the minimum number of Selected ports required for bringing up an aggregate interface.
This minimum threshold setting affects the aggregation states of aggregation member ports and the state of the aggregate interface.
· When the number of member ports eligible to be Selected ports is smaller than the minimum threshold, the following events occur:
¡ The eligible member ports are placed in Unselected state.
¡ The link layer state of the aggregate interface becomes down.
· When the number of member ports eligible to be Selected ports reaches or exceeds the minimum threshold, the following events occur:
¡ The eligible member ports are placed in Selected state.
¡ The link layer state of the aggregate interface becomes up.
The maximum number of Selected ports allowed in an aggregation group is limited by either manual configuration or hardware limitation, whichever value is smaller.
You can implement backup between two ports by performing the following tasks:
· Assigning two ports to an aggregation group.
· Setting the maximum number of Selected ports to 1 for the aggregation group.
Then, only one Selected port is allowed in the aggregation group, and the Unselected port acts as a backup port.
For an aggregation group, the maximum number of Selected ports must be equal to or higher than the minimum number of Selected ports.
3. Set the minimum number of Selected ports for the aggregation group.
By default, the minimum number of Selected ports is not specified for an aggregation group.
4. Set the maximum number of Selected ports for the aggregation group.
link-aggregation selected-port maximum max-number [ lacp-sync ]
By default, the maximum number of Selected ports allowed in an aggregation group is 128.
For a static aggregate link, you must set the maximum number of Selected ports to the same value at its two ends.
For a dynamic aggregate link, you must set the maximum number of Selected ports to the same value at its two ends if you do not specify the lacp-sync keyword. If you specify this keyword, the two ends of the aggregate link compare their maximum Selected port number settings and use the smaller value.
The minimum number of Selected ports in an aggregation group equals the higher one of the following values:
· The number of member ports in the aggregation group multiplied by the minimum percentage of Selected ports.
· The limit set by using the link-aggregation selected-port minimum command.
After you perform this task, aggregate interface flapping might occur when ports join or leave an aggregation group. Make sure you are fully aware of the impacts of this command when you execute it on a live network.
If you set the minimum percentage of Selected ports for the aggregation group, do not set the maximum number of Selected ports. If you set the maximum number of Selected ports, the calculated minimum number of Selected ports might be larger than the maximum number of Selected ports.
You must set the same minimum percentage of Selected ports at the two ends of an aggregate link.
¡ Enter Layer 3 aggregate interface.
interface route-aggregation { interface-number }
3. Set the minimum percentage of Selected ports.
link-aggregation selected-port minimum percentage number
By default, the minimum percentage of Selected ports is not set for an aggregation group.
Perform this task to modify the maximum number of aggregation groups and the maximum number of Selected ports per aggregation group.
After you configure the link aggregation capability of the device, save the configuration and reboot the device for the configuration to take effect. Before rebooting the device, make sure you know the possible impact on the network.
For link aggregation to operate correctly, set the same link aggregation capability at both ends of an aggregate link.
The maximum number of Selected ports in an aggregation group is limited by one of the following values, whichever value is smaller:
· Maximum number set by using the link-aggregation selected-port maximum command.
· Maximum number of Selected ports allowed by the link aggregation capability.
2. Configure the link aggregation capability of the device.
link-aggregation capability max-group max-group-number max-selected-port max-selected-port-number
By default, the S9855 switch series supports up to 1000 aggregation groups, with a maximum of 128 Selected ports per aggregation group. The S9825 switch supports up to 248 aggregation groups, with a maximum of 64 Selected ports per aggregation group.
Disabling the default action of selecting a Selected port for dynamic aggregation groups that have not received LACPDUs
The default port selection action applies to dynamic aggregation groups.
This action automatically chooses the port with the lowest ID from among all up member ports as a Selected port if none of them has received LACPDUs before the LACP timeout interval expires.
After this action is disabled, a dynamic aggregation group will not have any Selected ports to forward traffic if it has not received LACPDUs before the LACP timeout interval expires.
2. Disable the default port selection action.
lacp default-selected-port disable
By default, the default port selection action is enabled for dynamic aggregation groups.
Configuring a dynamic aggregation group to use port speed as the prioritized criterion for reference port selection
Perform this task to ensure that a dynamic aggregation group selects a high-speed member port as the reference port. After you perform this task, the reference port will be selected based on the criteria in order of device ID, port speed, and port ID.
Changing reference port selection criteria might cause transient traffic interruption. Make sure you understand the impact of this task on your network.
You must perform this task at both ends of the aggregate link so the peer aggregation systems use the same criteria for reference port selection.
As a best practice, shut down the peer aggregate interfaces before you execute this command and bring up the interfaces after this command is executed on both of them.
3. Specify port speed as the prioritized criterion for reference port selection.
lacp select speed
By default, port ID is the prioritized criterion for reference port selection of a dynamic aggregation group.
You can set the global load sharing mode only.
The global link-aggregation load sharing mode can be any combination of the hashing keys.
For the S9825 switch series, if you distribute traffic based on MAC addresses together with IP addresses or port numbers simultaneously, some of the hashing keys might not take effect. Make sure you are fully aware of the impacts of this operation.
The system will also use symmetric load sharing on aggregate interfaces if you enable symmetric load sharing. For more information about symmetric load sharing, see Layer 3—IP Routing Configuration Guide.
Setting the global link-aggregation load sharing mode
2. Set the global link-aggregation load sharing mode.
link-aggregation global load-sharing mode { { destination-ip | destination-mac | destination-port | flow-label | ingress-port | ip-protocol | source-ip | source-mac | source-port | vlan-id } *
By default, the device selects a global load sharing mode for packets depending on their packet type, as follows:
¡ Layer 2 packets are load shared on the following information:
- Ingress port.
- Source and destination MAC addresses.
¡ Layer 3 packets are load shared on the following information:
- Ingress port.
- Source and destination IP addresses.
- Source and destination port numbers.
- Protocol number.
An aggregation group does not distribute traffic based on the bandwidth usage of its member ports when using a static load sharing mode. As a result, traffic might be distributed unevenly among the aggregation member ports. To obtain balanced load sharing results, you can use dynamic load sharing to distribute traffic based on the bandwidth usage of aggregation member ports.
Dynamic load sharing supports the following modes:
· Eligible—Distributes the traffic from a flow on a per-flowlet basis. Flowlets are bursts of packets from a flow, which are separated based on the flowlet gap timer. If the forwarding latency between two bursts of packets is larger than the flowlet gap timer, they are two flowlets and can be forwarded on different links. The link selected for a flowlet is the least utilized link at the time of selection.
· Fixed—Distributes traffic across the aggregation member links on a per-flow basis. The link selected for a flow is the least utilized link at the time of selection.
· Spray—Distributes traffic across the aggregation member links on a per-packet basis. The link selected for a packet is the least utilized link at the time of selection.
IMPORTANT: In spray mode, packets in a flow might be distributed to different links and arrive at the receiving device out of order. When you use this mode, you must make sure the receiving device supports packet reordering. |
Hardware and feature compatibility
This feature is supported only on the S9855 switch series.
Dynamic load sharing is supported only for known unicast packets, and you can configure this feature only between devices of the same series.
Changing the global static load sharing mode affects the dynamic load sharing mode configured on an aggregation group and impacts load sharing.
The dynamic load sharing mode has priority over the static load sharing mode. If you configure both settings on an aggregate interface, the dynamic mode takes effect.
3. Configure a dynamic load sharing mode.
link-aggregation load-sharing mode dynamic { eligible [ flowlet-gap-time flowlet-gap-time ] | fixed | spray }
By default, an aggregation group uses the static load sharing mode.
To obtain the optimal load distribution performance in the default load sharing mode, you can perform this task to exclude some fields from load sharing calculation.
2. Specify ignored packet fields for default link-aggregation load sharing.
link-aggregation load-sharing ignore { destination-ip | destination-mac | destination-port | ingress-port | ip-protocol | source-ip | source-mac | source-port | vlan-id } *
By default, no ignored packet fields are specified for default link-aggregation load sharing.
To optimize traffic distribution on aggregate links, you can configure the link aggregation load sharing algorithm and the hash seed. The algorithm determines the CRC calculation method. The hash seed is a parameter used in hashing.
In default load sharing mode, if the device fails to load share traffic flows across all Selected ports, repeat the following procedure until the problem is resolved:
1. Configure the load sharing algorithm or hash seed.
2. Use the display counters command to view traffic statistics on Selected ports.
You can use a load sharing algorithm and a hash seed individually or in combination to obtain the optimal load sharing performance.
This feature does not take effect on per-flow load sharing.
2. Configure a link aggregation load sharing algorithm.
link-aggregation global load-sharing algorithm algorithm-number
By default, the link aggregation capability is not configured.
3. Configure a link aggregation load sharing hash seed.
link-aggregation global load-sharing seed seed-number
By default, no hash seed is configured.
If undesirable traffic imbalance occurs on link aggregations, you can use this command to adjust the load sharing results on link aggregations.
Misuse of this feature causes unbalanced traffic distribution. Make sure you are fully aware of the impacts of this feature when you configure it on a live network.
2. Set a hash offset to adjust the load sharing results on link aggregations.
link-aggregation global load-sharing offset offset-value
By default, no hash offset for the load balancing hash result is configured.
Perform this task to set the criterion used by aggregation groups to distribute tunneled traffic for load sharing.
The device can use one of the following modes to distribute tunneled traffic on a link aggregation:
· All—Distributes tunneled traffic based on the inner IP header and outer IP header. The S9825 switch series does not support this mode. On the S9855 switch series, the device will distribute tunneled traffic based on the inner IP header and outer IP header after you specify the all mode.
¡ For tunneled traffic to be forwarded with the tunnel header removed, information in the inner IP header is used for load sharing.
¡ For tunneled traffic to be forwarded without removing the tunnel header, information in both the inner and outer IP headers is used for load sharing.
· Inner—Distributes tunneled traffic based on the inner IP header.
· Outer—Distributes tunneled traffic based on the outer IP header.
2. Set the load sharing mode for tunneled traffic on aggregate links.
link-aggregation global load-sharing tunnel { all | inner | outer }
By default, no load sharing mode is configured for tunneled traffic.
Aggregate interface isolation is applicable to the aggregate interfaces that act as M-LAG interfaces when the device acts an M-LAG member device in an M-LAG system. It gracefully changes all M-LAG interfaces on the device to the Unselected state and switch traffic over to their counterpart M-LAG interfaces on the other M-LAG member device.
This feature takes effect only on dynamic aggregate interfaces. It cannot isolate static aggregate interfaces or peer-link interfaces in an M-LAG system.
As a best practice, make sure no M-LAG interfaces are in M-LAG MAD DOWN state before you isolate them. If one of the M-LAG interfaces is in M-LAG MAD DOWN state when you isolate them, M-LAG interface will persist in that state and cannot forward traffic after the isolation is removed.
2. Isolate aggregate interfaces.
link-aggregation lacp isolate
By default, aggregate interfaces are not isolated.
To remove M-LAG interface isolation, execute the undo form of this command.
You can use BFD to monitor member link status in an aggregation group. After you enable BFD on an aggregate interface, each Selected port in the aggregation group establishes a BFD session with its peer port. BFD operates differently depending on the aggregation mode.
· BFD on a static aggregation—When BFD detects a link failure, BFD notifies the Ethernet link aggregation module that the peer port is unreachable. The local port is then placed in Unselected state. However, the BFD session between the local and peer ports remains, and the local port keeps sending BFD packets. When BFD on the local port receives packets from the peer port upon link recovery, BFD notifies the Ethernet link aggregation module that the peer port is reachable. Then, the local port is placed in Selected state again. This mechanism ensures that the local and peer ports of a static aggregate link have the same aggregation state.
· BFD on a dynamic aggregation—When BFD detects a link failure, BFD notifies the Ethernet link aggregation module that the peer port is unreachable. At the same time, BFD clears the session and stops sending BFD packets. When the local port is placed in Selected state again upon link recovery, the local port establishes a new session with the peer port and BFD notifies the Ethernet link aggregation module that the peer port is reachable. Because BFD provides fast failure detection, the local and peer systems of a dynamic aggregate link can negotiate the aggregation state of their member ports faster.
For more information about BFD, see High Availability Configuration Guide.
For BFD to operate correctly on an aggregate link whose remote end is a third-party device that implements BFD differently from the device, enable If BFD compatible mode. With BFD compatible mode enabled, all member ports in an aggregation group establish BFD sessions with their peer ports. The BFD sessions are not deleted or re-established when the aggregation states of the member ports change.
When you enable BFD for an aggregation group, follow these restrictions and guidelines:
· Make sure the source and destination IP addresses are reversed between the two ends of an aggregate link. For example, if you execute link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2 at the local end, execute link-aggregation bfd ipv4 source 2.2.2.2 destination 1.1.1.1 at the peer end. The source and destination IP addresses cannot be the same.
· The BFD parameters configured on an aggregate interface take effect on all BFD sessions established by the member ports in its aggregation group. BFD on a link aggregation supports only control packet mode for session establishment and maintenance. The two ends of an established BFD session can only operate in Asynchronous mode.
· As a best practice, do not configure BFD for any protocols on a BFD-enabled aggregate interface.
· Make sure the number of member ports in a BFD-enabled aggregation group is less than or identical to the number of BFD sessions supported by the device. If the aggregation group contains more member ports than the supported sessions, some Selected ports might change to the Unselected state.
· If the number of BFD sessions differs between the two ends of an aggregate link, check their settings for inconsistency in the maximum number of Selected ports. You must make sure the two ends have the same setting for the maximum number of Selected ports.
3. (Optional.) Enable BFD compatible mode.
link-aggregation bfd-compatible enable
By default, BFD compatible mode is disabled on aggregate interfaces. Perform this step if the remote aggregation system is a third-party device that implements BFD differently from the local end.
4. Enable BFD for the aggregation group.
link-aggregation bfd ipv4 source ipv4-address destination ipv4-address
By default, BFD is disabled for an aggregation group.
To display the link aggregation capability of the device, execute the following command in any view:
display link-aggregation capability
Perform all display tasks in any view.
· Display information about aggregate interfaces.
display interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ] [ brief [ description | down ] ]
· Display summary information about all aggregation groups.
display link-aggregation summary
· Display detailed information about aggregation groups.
display link-aggregation verbose [ { bridge-aggregation | route-aggregation } [ interface-number ] ] [ all-configuration ]
· Display detailed link aggregation information about link aggregation member ports.
display link-aggregation member-port [ interface-list | auto ]
· Display the aggregation states of aggregation member ports and the reason why a port was placed in Unselected state.
display link-aggregation troubleshooting [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
To display the local system ID, execute the following command in any view:
display lacp system-id
· Display the global link-aggregation load sharing modes.
display link-aggregation load-sharing mode [ interface [ { bridge-aggregation | route-aggregation } interface-number ] ]
Only the S9855 switch series supports displaying the type of group-specific link-aggregation load sharing modes.
· Display forwarding information about the specified traffic flow.
display link-aggregation load-sharing path interface { bridge-aggregation | route-aggregation } interface-number ingress-port interface-type interface-number [ route ] { { destination-ip ip-address | destination-ipv6 ipv6-address } | { source-ip ip-address | source-ipv6 ipv6-address } | destination-mac mac-address | destination-port port-id | ip-protocol protocol-id | source-mac mac-address | source-port port-id | vlan vlan-id } *
For more information about the following commands, see common interface commands in Interface Command Reference.
Displaying aggregate interface statistics
· Display interface traffic statistics.
display counters { inbound | outbound } interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
· Display traffic rate statistics for interfaces in up state for the most recent statistics polling interval.
display counters rate { inbound | outbound } interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
Clearing aggregate interface statistics
To clear statistics for aggregate interfaces, execute the following command in user view:
reset counters interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
To clear LACP statistics for link aggregation member ports, execute the following command in user view:
On the network shown in Figure 7, perform the following tasks:
· Configure a Layer 2 static aggregation group on both Device A and Device B.
· Enable VLAN 10 at one end of the aggregate link to communicate with VLAN 10 at the other end.
· Enable VLAN 20 at one end of the aggregate link to communicate with VLAN 20 at the other end.
1. Configure Device A:
# Create VLAN 10, and assign port HundredGigE 1/0/4 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port hundredgige 1/0/4
[DeviceA-vlan10] quit
# Create VLAN 20, and assign port HundredGigE 1/0/5 to VLAN 20.
[DeviceA] vlan 20
[DeviceA-vlan20] port hundredgige 1/0/5
[DeviceA-vlan20] quit
# Create Layer 2 aggregate interface Bridge-Aggregation 1.
[DeviceA] interface bridge-aggregation 1
[DeviceA-Bridge-Aggregation1] quit
# Assign ports HundredGigE 1/0/1 through HundredGigE 1/0/3 to link aggregation group 1.
[DeviceA] interface hundredgige 1/0/1
[DeviceA-HundredGigE1/0/1] port link-aggregation group 1
[DeviceA-HundredGigE1/0/1] quit
[DeviceA] interface hundredgige 1/0/2
[DeviceA-HundredGigE1/0/2] port link-aggregation group 1
[DeviceA-HundredGigE1/0/2] quit
[DeviceA] interface hundredgige 1/0/3
[DeviceA-HundredGigE1/0/3] port link-aggregation group 1
[DeviceA-HundredGigE1/0/3] quit
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as a trunk port and assign it to VLANs 10 and 20.
[DeviceA-Bridge-Aggregation1] port link-type trunk
[DeviceA-Bridge-Aggregation1] port trunk permit vlan 10 20
2. Configure Device B in the same way Device A is configured. (Details not shown.)
# Display detailed information about all aggregation groups on Device A.
[DeviceA] display link-aggregation verbose
Port: A -- Auto port, M -- Management port, R -- Reference port
G -- Defaulted, H -- Expired
Role: P -- Primary, S -- Secondary
Aggregation Mode: Static
Management VLANs: None
Port Status Priority Oper-Key
HGE1/0/1(R) S 32768 1
HGE1/0/2 S 32768 1
HGE1/0/3 S 32768 1
The output shows that link aggregation group 1 is a Layer 2 static aggregation group that contains three Selected ports.
Example: Configuring a Layer 2 dynamic aggregation group
On the network shown in Figure 8, perform the following tasks:
· Configure a Layer 2 dynamic aggregation group on both Device A and Device B.
# Create VLAN 10, and assign the port HundredGigE 1/0/4 to VLAN 10.
[DeviceA] vlan 10
# Create VLAN 20, and assign the port HundredGigE 1/0/5 to VLAN 20.
[DeviceA] vlan 20
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and set the link aggregation mode to dynamic.
[DeviceA-Bridge-Aggregation1] link-aggregation mode dynamic
Creation Mode: Manual
Aggregation Mode: Dynamic
Local:
Port Status Priority Index Oper-Key Flag
HGE1/0/1(R) S 32768 11 1 {ACDEF}
HGE1/0/2 S 32768 12 1 {ACDEF}
HGE1/0/3 S 32768 13 1 {ACDEF}
Remote:
Actor Priority Index Oper-Key SystemID Flag
HGE1/0/1 32768 81 1 0x8000, 000f-e267-57ad {ACDEF}
HGE1/0/2 32768 82 1 0x8000, 000f-e267-57ad {ACDEF}
HGE1/0/3 32768 83 1 0x8000, 000f-e267-57ad {ACDEF}
The output shows that link aggregation group 1 is a Layer 2 dynamic aggregation group that contains three Selected ports.
Example: Configuring a Layer 2 edge aggregate interface
As shown in Figure 9, a Layer 2 dynamic aggregation group is configured on the device. The server is not configured with dynamic link aggregation.
Configure an edge aggregate interface so that both HundredGigE 1/0/1 and HundredGigE 1/0/2 can forward traffic to improve link reliability.
[Device] interface bridge-aggregation 1
[Device-Bridge-Aggregation1] link-aggregation mode dynamic
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as an edge aggregate interface.
[Device-Bridge-Aggregation1] lacp edge-port
[Device-Bridge-Aggregation1] quit
# Assign ports HundredGigE 1/0/1 and HundredGigE 1/0/2 to link aggregation group 1.
[Device] interface hundredgige 1/0/1
[Device-HundredGigE1/0/1] port link-aggregation group 1
[Device-HundredGigE1/0/1] quit
[Device] interface hundredgige 1/0/2
[Device-HundredGigE1/0/2] port link-aggregation group 1
[Device-HundredGigE1/0/2] quit
# Display detailed information about all aggregation groups on the device when the server is not configured with dynamic link aggregation.
[Device] display link-aggregation verbose
Local:
HGE1/0/1 I 32768 11 1 {AG}
HGE1/0/2 I 32768 12 1 {AG}
Remote:
HGE1/0/1 32768 81 0 0x8000, 0000-0000-0000 {DEF}
HGE1/0/2 32768 82 0 0x8000, 0000-0000-0000 {DEF}
The output shows that HundredGigE 1/0/1 and HundredGigE 1/0/2 are in Individual state when they do not receive LACPDUs from the server. Both HundredGigE 1/0/1 and HundredGigE 1/0/2 can forward traffic. When one port fails, its traffic is automatically switched to the other port.
Example: Configuring a Layer 3 static aggregation group
On the network shown in Figure 10, perform the following tasks:
· Configure a Layer 3 static aggregation group on both Device A and Device B.
· Configure IP addresses and subnet masks for the corresponding Layer 3 aggregate interfaces.
# Create Layer 3 aggregate interface Route-Aggregation 1, and configure an IP address and subnet mask for the aggregate interface.
[DeviceA] interface route-aggregation 1
[DeviceA-Route-Aggregation1] ip address 192.168.1.1 24
[DeviceA-Route-Aggregation1] quit
# Assign Layer 3 Ethernet interfaces HundredGigE 1/0/1 through HundredGigE 1/0/3 to aggregation group 1.
HGE1/0/2 S 32768 1
HGE1/0/3 S 32768 1
The output shows that link aggregation group 1 is a Layer 3 static aggregation group that contains three Selected ports.
Example: Configuring a Layer 3 dynamic aggregation group
On the network shown in Figure 11, perform the following tasks:
· Configure a Layer 3 dynamic aggregation group on both Device A and Device B.
# Create Layer 3 aggregate interface Route-Aggregation 1.
# Set the link aggregation mode to dynamic.
[DeviceA-Route-Aggregation1] link-aggregation mode dynamic
# Configure an IP address and subnet mask for Route-Aggregation 1.
Local:
Remote:
The output shows that link aggregation group 1 is a Layer 3 dynamic aggregation group that contains three Selected ports.
Example: Configuring S-MLAG
Device B, Device C, and Device D are standalone devices. As shown in Figure 12, configure Device B, Device C, and Device D as S-MLAG devices to establish a multidevice aggregate link with Device A.
# Create Layer 2 aggregate interface Bridge-Aggregation 10, and set the link aggregation mode to dynamic.
[DeviceA] interface bridge-aggregation 10
[DeviceA-Bridge-Aggregation10] link-aggregation mode dynamic
[DeviceA-Bridge-Aggregation10] quit
# Assign HundredGigE 1/0/1 through HundredGigE 1/0/3 to aggregation group 10.
[DeviceA-HundredGigE1/0/1] port link-aggregation group 10
[DeviceA-HundredGigE1/0/2] port link-aggregation group 10
[DeviceA-HundredGigE1/0/3] port link-aggregation group 10
2. Configure Device B:
# Set the LACP system MAC address to 0001-0001-0001.
[DeviceB] lacp system-mac 1-1-1
# Set the LACP system priority to 123.
[DeviceB] lacp system-priority 123
# Set the LACP system number to 1.
[DeviceB] lacp system-number 1
# Create Layer 2 aggregate interface Bridge-Aggregation 2, and set the link aggregation mode to dynamic.
[DeviceB] interface bridge-aggregation 2
[DeviceB-Bridge-Aggregation2] link-aggregation mode dynamic
# Assign Bridge-Aggregation 2 to S-MLAG group 100.
[DeviceB-Bridge-Aggregation2] port s-mlag group 100
# Assign HundredGigE 1/0/1 to aggregation group 2.
[DeviceB] interface hundredgige 1/0/1
[DeviceB-HundredGigE1/0/1] port link-aggregation group 2
[DeviceB-HundredGigE1/0/1] quit
3. Configure Device C:
<DeviceC> system-view
[DeviceC] lacp system-mac 1-1-1
[DeviceC] lacp system-priority 123
# Set the LACP system number to 2.
[DeviceC] lacp system-number 2
# Create Layer 2 aggregate interface Bridge-Aggregation 3, and set the link aggregation mode to dynamic.
[DeviceC] interface bridge-aggregation 3
[DeviceC-Bridge-Aggregation3] link-aggregation mode dynamic
# Assign Bridge-Aggregation 3 to S-MLAG group 100.
[DeviceC-Bridge-Aggregation3] port s-mlag group 100
# Assign HundredGigE 1/0/1 to aggregation group 3.
[DeviceC] interface hundredgige 1/0/1
[DeviceC-HundredGigE1/0/1] port link-aggregation group 3
[DeviceC-HundredGigE1/0/1] quit
4. Configure Device D:
<DeviceD> system-view
[DeviceD] lacp system-mac 1-1-1
[DeviceD] lacp system-priority 123
# Set the LACP system number to 3.
[DeviceD] lacp system-number 3
# Create Layer 2 aggregate interface Bridge-Aggregation 4, and set the link aggregation mode to dynamic.
[DeviceD] interface bridge-aggregation 4
[DeviceD-Bridge-Aggregation4] link-aggregation mode dynamic
# Assign Bridge-Aggregation 4 to S-MLAG group 100.
[DeviceD-Bridge-Aggregation4] port s-mlag group 100
# Assign HundredGigE 1/0/1 to aggregation group 4.
[DeviceD] interface hundredgige 1/0/1
[DeviceD-HundredGigE1/0/1] port link-aggregation group 4
[DeviceD-HundredGigE1/0/1] quit
# Verify that HundredGigE 1/0/1 through HundredGigE 1/0/3 on Device A are Selected ports.
Aggregate Interface: Bridge-Aggregation10
System ID: 0x8000, 40fa-264f-0100
Local:
HGE1/0/1(R) S 32768 1 1 {ACDEF}
HGE1/0/2 S 32768 2 1 {ACDEF}
HGE1/0/3 S 32768 3 1 {ACDEF}
Remote:
HGE1/0/1 32768 16385 50100 0x7b , 0001-0001-0001 {ACDEF}
HGE1/0/2 32768 32769 50100 0x7b , 0001-0001-0001 {ACDEF}
HGE1/0/3 32768 49153 50100 0x7b , 0001-0001-0001 {ACDEF}
