00-Preface | 117.14 KB |
Preface
This guide describes the installation method for the general software package of the H3C vSCN5100, including product introduction, preparation before vSCN installation, installing vSCN, logging in to vSCN CLI, vSCN CLI configuration, and web login.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents a mobile communication endpoint. |
Represents a mobile communication base station, such as an eNodeB. |
Represents a BBU. |
Represents an RRU. |
Represents an FSW. |
Represents a pRRU. |
Documentation feedback
We appreciate your comments.
