H3C WX3840X Access Controllers Installation Guide-6W103
HomeSupportWirelessWX3800X Series Access ControllersInstall & UpgradeInstallation GuidesH3C WX3840X Access Controllers Installation Guide-6W103
07-Appendix B LEDs
07-Appendix B LEDs 101.62 KB
Appendix B LEDs
LEDs
Figure7-1 LEDs
(1) 100/1000BASE-T autosensing Ethernet port LEDs
(2) 1000BASE-X SFP port LED
(3) Power module LED (PWR1)
(4) Power module LED (PWR2)
(5) System status LED (SYS)
(6) Expansion module status LED (SLOT1)
(7) Expansion module status LED (SLOT2)
(8) Expansion module status LED (SLOT3)
(9) 100/1000BASE-T out-of-band management Ethernet port status LED (LINK/ACT)
LED description
Table7-1 LED description
LED
Mark
Status
Power module LED
PWR1 PWR2
Steady green
The power module is operating correctly.
Steady red
An exception has occurred on the power module.
Off
No power module is present.
System status LED
SYS
Slow flashing green (once every 2 seconds)
The device is operating correctly.
Fast flashing green (four times per second)
The device is starting up.
Steady red
The device has failed self-POST or other severe issues were detected.
Off
No power is input.
SLOT1
SLOT2
SLOT3
Steady green
The expansion module is in position.
Steady red
An error has occurred on the expansion module.
Off
No expansion module is present.
Drive status LED
N/A
Steady green
The drive is present and operating correctly.
Fast flashing green
Data is being read from or written to the drive.
Off
No drive is present.
100/1000BASE-T out-of-band management Ethernet port LED
LINK/ACT
Steady green
A link is present.
Flashing green
The port is receiving and sending data.
Off
No link is present.
N/A
Steady yellow
A 100 Mbps link is present.
Flashing yellow
The port is receiving and sending data at 100 Mbps.
Steady green
A 1000 Mbps link is present.
Flashing green
The port is receiving and sending data at 1000 Mbps.
Off
No link is present.
N/A
Steady green
Flashing green
Off
No link is present.
