H3C WX3840X Access Controllers Installation Guide-6W103
HomeSupportWirelessWX3800X Series Access ControllersInstall & UpgradeInstallation GuidesH3C WX3840X Access Controllers Installation Guide-6W103
06-Appendix A Chassis views and technical specifications
Chassis views
Figure6-1 Front view
(1) Drive slot
(2) USB port
(3) 100/1000BASE-T autosensing Ethernet ports 1 through 7
(4) 1000BASE-X SFP ports 9 through 16
(5) Console port
(6) Expansion slot
(7) Reset button (RESET)
(8) 100/1000BASE-T out-of-band Ethernet port
Figure6-2 Rear view
(1) Power supply slot PWR1
(2) Power supply slot PWR2
(3) Expansion slot 1
(4) Expansion slot 2
(5) Grounding screw
Power supply views
AC power supply
Figure6-3 AC power supply
(1) Power receptacle
(2) Air outlet vent
DC power supply
Figure6-4 DC power supply
(2) Air outlet vent
Interface arrangement
The access controller provides fixed interfaces GigabitEthernet 1/0/1 through GigabitEthernet 1/0/16. You can identify an interface by its mark.
·     GigabitEthernet 1/0/1 through GigabitEthernet 1/0/8—100/1000BASE-T autosensing Ethernet ports.
·     GigabitEthernet 1/0/9 through GigabitEthernet 1/0/16—1000BASE-X SFP ports.
Internal interfaces GigabitEthernet1/0/17 and GigabitEthernet1/0/18 are 100/1000BASE-T autosensing Ethernet interfaces for connecting expansion modules. You can edit interface settings as needed.
Technical specifications
Table6-1 Technical specifications
Item
Specification
Console port
1, 9600 bps (default) to 115200bps
GE port
8 × 100/1000BASE-T autosensing Ethernet ports
Management port
1 × 100/1000BASE-T management Ethernet port
SFP port
8 × 1000BASE-X SFP ports
·     To restore the device to factory default settings, press and hold the button for more than 5 seconds.
·     To reset the device, press and hold the button for more than 1 second.
Memory
16GB DDR4
Storage media
8GB eMMC
Dimensions (H × W × D) (excluding the rubber feet and mounting brackets)
44 × 440 × 435 mm (1.73 × 17.32 × 17.13 in)
AC power supply
Rated voltage range: 100 to 240 VAC @ 50/60 Hz
DC power supply
Rated voltage range: –48 VDC to –60 VDC
System power consumption
36 W to 107 W
Weight
9 kg (19.84 lb)
Operating temperature
0°C to 45°C (32°F to 113°F)
Operating humidity (non condensing)
5% RH to 95% RH
Table6-2 AC power supply specifications
Item
Specification
Model
PSR250-12A1
Product code
PSR250-12A1-D
Rate input voltage range
100 VAC to 240 VAC @ 50 Hz or 60 Hz
Rated power
250 W
Table6-3 DC power supply specifications
Item
Specification
Model
PSR450-12D
Product code
PSR450-12D
–48 VDC to –60 VDC
Rated power
450 W
