05-Layer 3—IP Routing Configuration Examples
HomeSupportConfigure & DeployConfiguration ExamplesH3C S12500&S10500&S7500 Switch Series Configuration Examples-R7639Pxx-6W10005-Layer 3—IP Routing Configuration Examples
08-Policy-Based Routing Configuration Examples
08-Policy-Based Routing Configuration Examples 105.93 KB
Introduction
This document provides PBR configuration examples.
PBR uses a user-defined policy to route packets based on fields such as the source address, destination address, IP precedence, and protocol. PBR takes precedence over destination-based routing.
This document assumes that you have basic knowledge of PBR.
When you configure the action of forwarding traffic to a next hop, do not specify the following addresses:
·     An IPv6 address in an IPv4 ACL rule.
·     An IPv4 address in an IPv6 ACL rule.
Example: Configuring PBR
As shown in Figure 1, on Device, all packets destined for Server are forwarded to the next hop 10.4.1.2 by default.
Configure PBR to meet the following requirements:
·     Packets with source IPv4 address 10.2.1.1 received on VLAN-interface 2 are forwarded to the next hop 10.5.1.2.
·     HTTP packets with source IPv4 addresses other than 10.2.1.1 received on VLAN-interface 2 are forwarded to the next hop 10.3.1.2.
Figure 1 Network diagram
Analysis
To forward the two types of packets to different next hops, you must perform the following tasks:
·     Configure two ACLs to classify the two types of packets.
·     Configure two policy nodes to forward the packets to the specified next hops.
To ensure that packets with source address 10.2.1.1 are forwarded to the next hop 10.5.1.2, assign a node a smaller node ID to match the packets.
Hardware
Software version
S12500G-AF switch series
Release 7639P01 and later
S10500X switch series
S10500 switch series
S7500E-X switch series
S7500E switch series
S7500X switch series
Procedures
# Configure an IPv4 address for VLAN-interface 2.
[Device] interface vlan-interface 2
[Device-Vlan-interface2] ip address 10.1.2.1 255.255.255.0
[Device-Vlan-interface2] quit
# Configure IPv4 addresses for other interfaces in the same way VLAN-interface 2 is configured. (Details not shown.)
# Configure three static routes and configure 10.4.1.2 as the default next hop.
[Device] ip route-static 192.168.1.0 24 10.3.1.2
[Device] ip route-static 192.168.1.0 24 10.4.1.2 preference 40
[Device] ip route-static 192.168.1.0 24 10.5.1.2
# Create ACL 3005 to match packets with source address 10.2.1.1.
[Device] acl advanced 3005
[Device-acl-ipv4-adv-3005] rule 0 permit ip source 10.2.1.1 0
[Device-acl-ipv4-adv-3005] quit
# Create ACL 3006 to match HTTP packets with source addresses other than 10.2.1.1.
[Device] acl advanced 3006
[Device-acl-ipv4-adv-3006] rule 0 permit tcp destination-port eq www
[Device-acl-ipv4-adv-3006] quit
# Configure Node 0 for policy pbr1 to forward packets matching ACL 3005 to the next hop 10.5.1.2.
[Device] policy-based-route pbr1 permit node 0
[Device-pbr-pbr1-0] if-match acl 3005
[Device-pbr-pbr1-0] apply next-hop 10.5.1.2
[Device-pbr-pbr1-0] quit
# Configure Node 1 for policy pbr1 to forward packets matching ACL 3006 to the next hop 10.3.1.2.
[Device] policy-based-route pbr1 permit node 1
[Device-pbr-pbr1-1] if-match acl 3006
[Device-pbr-pbr1-1] apply next-hop 10.3.1.2
[Device-pbr-pbr1-1] quit
# Apply policy pbr1 to VLAN-interface 2.
[Device-Vlan-interface2] ip policy-based-route pbr1
# On Device, display PBR policy information.
[Device] display ip policy-based-route policy pbr1
Policy name: pbr1
  node 0 permit:
    if-match acl 3005
  node 1 permit:
    if-match acl 3006
The output shows that the PBR configurations are successful.
# On Switch, display the path for forwarding non-HTTP packets with source address 10.1.1.1.
Before you use a tracert command, perform the following tasks:
·     Enable sending of ICMP timeout packets on the intermediate devices.
·     Enable sending of ICMP destination unreachable packets on the destination device.
<Switch> tracert -a 10.1.1.1 192.168.1.1
traceroute to 192.168.1.1 (192.168.1.1) from 10.1.1.1, 30 hops at most, 52 bytes
 each packet, press CTRL_C to break
 1  10.1.2.1 (10.1.2.1)  2.178 ms  1.364 ms  1.058 ms
 2  10.4.1.2 (10.4.1.2)  1.548 ms  1.248 ms  1.112 ms
 3  192.168.1.1 (192.168.1.1)  1.594 ms  1.321 ms  1.093 ms
The output shows that non-HTTP packets with source address 10.1.1.1 are forwarded to the next hop 10.4.1.2.
# On Switch, display the path for forwarding packets with source address 10.2.1.1.
<Switch> tracert -a 10.2.1.1 192.168.1.1
traceroute to 192.168.1.1 (192.168.1.1) from 10.2.1.1, 30 hops at most, 40 bytes
 1  10.1.2.1 (10.1.2.1)  1.721 ms  1.226 ms  1.050 ms
 2  10.5.1.2 (10.5.1.2)  4.494 ms  1.385 ms  1.170 ms
 3  192.168.1.1 (192.168.1.1)  1.448 ms  1.304 ms  1.093 ms
The output shows that packets with source address 10.2.1.1 are forwarded to the next hop 10.5.1.2.
Configuration files
vlan 1
vlan 2 to 5
 if-match acl 3005
 if-match acl 3006
interface Vlan-interface2
interface Vlan-interface3
 ip address 10.3.1.1 255.255.255.0
interface Vlan-interface4
 ip address 10.4.1.1 255.255.255.0
interface Vlan-interface5
 ip address 10.5.1.1 255.255.255.0
acl number 3005
acl number 3006
Example: Configuring IPv6 PBR
As shown in Figure 2, on Device, all packets destined for Server are forwarded to the next hop 2004::2 by default.
Configure IPv6 PBR to meet the following requirements:
·     Packets with source IPv6 address 2002::1 received on VLAN-interface 2 are forwarded to the next hop 2005::2.
·     HTTP packets with source IPv6 addresses other than 2002::1 received on VLAN-interface 2 are forwarded to the next hop 2003::2.
Figure 2 Network diagram
Analysis
To ensure that packets with source address 2002::1 are forwarded to the next hop 2005::2, assign a node a smaller node ID to match the packets.
Hardware
Software version
Procedures
# Configure an IPv6 address for VLAN-interface 2.
[Device-Vlan-interface2] ipv6 address 2007::1 64
# Configure IPv6 addresses for other interfaces in the same way VLAN-interface 2 is configured. (Details not shown.)
# Configure three static routes and configure 2004::2/64 as the default next hop.
[Device] ipv6 route-static 3001::1 64 2003::2
[Device] ipv6 route-static 3001::1 64 2004::2 preference 40
[Device] ipv6 route-static 3001::1 64 2005::2
# Create IPv6 ACL 3005 to match packets with source address 2002::1.
[Device] acl ipv6 advanced 3005
[Device-acl-ipv6-adv-3005] rule 0 permit ipv6 source 2002::1/128
[Device-acl-ipv6-adv-3005] quit
# Create IPv6 ACL 3006 to match HTTP packets with source addresses other than 2002::1.
[Device] acl ipv6 advanced 3006
[Device-acl-ipv6-adv-3006] rule 0 permit tcp destination-port eq www
[Device-acl-ipv6-adv-3006] quit
# Configure Node 0 for policy pbr1 to forward packets matching IPv6 ACL 3005 to the next hop 2005::2.
[Device] ipv6 policy-based-route pbr1 permit node 0
[Device-pbr6-pbr1-0] if-match acl 3005
[Device-pbr6-pbr1-0] apply next-hop 2005::2
[Device-pbr6-pbr1-0] quit
# Configure Node 1 for policy pbr1 to forward packets matching IPv6 ACL 3006 to the next hop 2003::2.
[Device] ipv6 policy-based-route pbr1 permit node 1
[Device-pbr6-pbr1-1] if-match acl 3006
[Device-pbr6-pbr1-1] apply next-hop 2003::2
[Device-pbr6-pbr1-1] quit
[Device-Vlan-interface2] ipv6 policy-based-route pbr1
# On Device, display IPv6 PBR policy information.
[Device] display ipv6 policy-based-route policy pbr1
Policy name: pbr1
  node 0 permit:
    if-match acl 3005
  node 1 permit:
    if-match acl 3006
The output shows that the IPv6 PBR configurations are successful.
# On Device, verify the forwarding of packets with source address 2002::1. (Details not shown.)
·     If 2005::2 is reachable, packets are forwarded to the next hop 2005::2.
·     If 2005::2 is not reachable, packets are forwarded to the next hop 2004::2.
# On Device, verify the forwarding of HTTP packets. (Details not shown.)
·     If 2003::2 is reachable, packets are forwarded to the next hop 2003::2.
·     If 2003::2 is not reachable, packets are forwarded to the next hop 2004::2.
Configuration files
vlan 1
vlan 2 to 5
 if-match acl 3005
 if-match acl 3006
 ipv6 address 2007::1/64
 ipv6 address 2003::1 64
 ipv6 address 2004::1 64
 ipv6 address 2005::1 64
ipv6 route-static 3001:: 64 2003::2
 ipv6 route-static 3001:: 64 2004::2 preference 40
 ipv6 route-static 3001:: 64 2005::2
 acl ipv6 number 3005
 acl ipv6 number 3006
