| 02-Appendix B Sensor Name and Description | 41.05 KB |
Table 1 Sensor name and description
Sensor type |
Sensor name |
Sensor description |
Temperature |
Inlet_Temp |
Air inlet temperature |
Outlet_Temp |
Air outlet temperature |
CPUN_Temp |
CPU core temperature |
CPUN_DTS |
Remaining temperature before CPU throttling. The value is typically negative. The smaller the value, the larger the remaining temperature. |
Px_DIMM_Chy-z |
Max. temperature of DIMM channels for CPU N |
Front_HD_Max |
Max. temperature of front SAS/SATA drives |
Front_NVMe_Max |
Max. temperature of front NVMe drives |
Rear_HD_Max |
Max. temperature of rear SAS/SATA drives |
Rear_NVMe_Max |
Max. temperature of rear NVMe drives |
Rear_BP_Zone |
Max. temperature of the rear drive backplane |
Mid_HD_Max |
Max. temperature of middle SAS/SATA drives |
Mid_NVMe_Max |
Max. temperature of middle NVMe drives |
PCH |
PCH temperature |
PSUN |
Power supply temperature |
CPUN_VR |
CPU VR temperature |
Expander_Card |
Expander card temperature |
PCIN |
PCI/PCIe module temperature |
PCIN_Zone |
Temperature of PCI/ PCIe slots on the riser card |
Voltage |
CPUN_Vcore |
CPU N core voltage |
CPUN_DDR_VPP1 |
VPP1 voltage of DIMMs for CPU N |
CPUN_DDR_VPP2 |
VPP2 voltage of DIMMs for CPU N |
CPUN_DDR_VDDQ1 |
VDDQ1 voltage of DIMMs for CPU N |
CPUN_DDR_VDDQ2 |
VDDQ2 voltage of DIMMs for CPU N |
PSUN_VIN |
Power supply N input voltage |
PSUN_VOUT |
Power supply N output voltage |
SYS_12V |
System 12V voltage (system HSC output voltage) |
SYS_5V |
System 5V voltage |
SYS_3V3 |
System 3.3V voltage |
SYS_3V_BAT |
Voltage of the RTC battery on the system board |
HDD_BPN_12V |
12V voltage for the front drive backplane |
M_HDD_BPN_12V |
12V voltage for the middle drive backplane |
R_HDD_BPN_12V |
12V voltage for the rear drive backplane |
Current |
PSUN_IIN |
Power supply N input current |
PSUN_IOUT |
Power supply N output current |
Power |
Total_Power |
Total chassis power |
FAN_Power |
Total fan power |
CPU_Power |
Total CPU power |
MEM_Power |
Total memory power |
DISK_Power |
Total drive power |
PSUN_PIN |
Power supply N input power |
PSUN_POUT |
Power supply N output power |
Rotation speed |
FANx_Speed or FANx_F_Speed or FANx_R_Speed |
Rotation speed of fan module x in RPM or rotation speed of the front fan in fan module x in RPM or rotation speed of the rear fan in fan module x in RPM |
Status |
CPUN_Status |
CPU status |
CPUx_CHy_Dz |
DIMM status |
PCH_Status |
PCH status The embedded storage controllers and SAS controllers are included. |
Watchdog2 |
System watchdog overflow and action |
Sys_Restart |
System startup/startup reason |
Boards |
Exceptional host power outage |
BIOS_Boot_Up |
BIOS startup completed |
Sys_FW_Progress |
System firmware (BIOS) and POST status |
ACPI_State |
ACPI power status |
Power_Button |
Power button on the lower panel |
PSUN_Status |
System power supply N status (N: 0 to n) |
PSU_Mismatch |
Model inconsistency between power supplies |
PSU_Redundant |
System power redundancy status |
FANN_Status or FANN_F_Status or FANN_R_Status |
Fan module N status Status of front/rear fan in fan module N |
FAN_Redundant |
Fan redundancy status |
Front: Disk_FN_Status Rear: Disk_RN_Status Middle: Disk_MN_Status |
Drive status (N: 0 to n) |
LAN_Leash_Lost |
Link status of network adapter ports |
PCIe_Status |
Overall PCIe alarm status |
LAN_N_Link |
Link status of network adapter port N (N: 0 to n) |
BMC_Boot_Up |
BMC startup |
UID_Button |
Long press on the UID button on the panel for BMC reset |
SEL_Status |
SEL status |
HDD_BPN_Status |
Status of front drive backplane N (N: 0 to n, depending on product marks) |
M_HDD_BPN_Status |
Status of middle drive backplane N (N: 0 to n, depending on product marks) |
R_HDD_BPN_Status |
Status of rear drive backplane N (N: 0 to n, depending on product marks) |
MB_Status |
System board status |
AreaIntrusion |
Chassis status |
