14-Network Management and Monitoring Configuration Guide
HomeSupportReference GuidesCommand ReferencesH3C SR6600[SR6600-X] Routers Configuration Guides(V7)-R8149-6W10014-Network Management and Monitoring Configuration Guide
23-SQA configuration
23-SQA configuration 105.26 KB
Configuring SQA
About SQA
Service quality analysis (SQA) enables the device to identify SIP- or H.323-based multimedia traffic and preferentially forward this traffic to ensure multimedia service quality. Use this feature to decrease multimedia stuttering and improve user experience.
Restrictions: Hardware compatibility with SQA
This feature is supported only on devices installed with the RPE-X5 or RPE-X5E MPU and any of the following service modules:
·     FIP-260.
·     FIP-380.
·     FIP-660.
·     SAP-XP4GE32.
Restrictions and guidelines: SQA configuration
SQA does not support analysis of encrypted SIP or H.323 protocol packets.
Configuring SIP-based SQA
Make sure SQA uses different port numbers to listen for SIP and H.323 packets.
2.     Enter SQA view.
sqa
3.     Enable SIP-based SQA.
sqa-sip enable
By default, SIP-based SQA is disabled.
Configuring H.323-based SQA
2.     Enter SQA view.
sqa
3.     Enable H.323-based SQA.
sqa-h323 enable
By default, H.323-based SQA is disabled.
Display and maintenance commands for SQA
Execute display commands in any view .
Display SIP or H.323 call information.
display sqa { h323 | sip } call [ [ call-id call-id ] verbose ]
Display SIP or H.323 call statistics.
display sqa { h323 | sip } call-statistics
SQA configuration examples
Example: Configuring SIP-based SQA
As shown in Figure 1, the SIP server installed with third-party VoIP server software acts as both the SIP proxy server and SIP registrar to manage SIP UA registration and SIP calls. Host A and Host B installed with third-party client software can place calls to each other.
Configure SIP-based SQA on Device A, Device B, and Device C to optimize multimedia traffic of SIP calls to provide high-quality multimedia services.
Figure 1 Network diagram
Assign IP addresses to interfaces, and make sure the devices can reach each other.
1.     Configure the SIP server:
Install third-party VoIP server software, register UAs, and specify the usernames (phone numbers) and passwords for the clients. (Details not shown.)
2.     Configure PC A and PC B:
Install third-party VoIP client software, specify the IP address of the SIP server, and configure the username (phone number), password, and other parameters on each PC. (Details not shown.)
3.     Configure Device A:
# Enable SIP-based SQA.
[DeviceA] sqa
[DeviceA-sqa] sqa-sip enable
[DeviceA-sqa] quit
[DeviceA] quit
4.     Configure Device B and Device C:
# Configure Device B and Device C in the same way as Device A is configured. (Details not shown.)
# Display brief information about all SIP calls on Device A.
<DeviceA> display sqa sip call
Caller                 Callee                 CallId
6.159.107.207:49172    6.159.108.51:52410     3101326658
6.159.107.203:49172    6.159.108.47:52410     4530332933
6.159.107.208:49172    6.159.108.52:52410     4445702693
6.159.107.206:49172    6.159.108.50:52410     8263542841
6.159.107.201:49172    6.159.108.45:52410     4752123310
6.159.107.200:49172    6.159.108.44:52410     99462146
# Display detailed information about the SIP call that Host A placed to Host B.
<DeviceA> display sqa sip call call-id 99462146 verbose
Call ID: 99462146
  Caller information:
    IP: 6.159.107.200      Port: 49172    MAC: a036-9fd4-b5bd
    Tag: [email protected]
  Callee information:
    IP: 6.159.108.44       Port: 52410    MAC: a036-9fd4-b5bc
  Type: Audio     VLAN: 1               StartTime: 2019-7-14 15:40:39
  MOS(F): 4.40    MOS(R): 4.40
  Forward flow (octets): 4793344        Forward flow (packets): 4681
  Reverse flow (octets): 3810304        Reverse flow (packets): 3721
The output shows that the MOS value for both originating and returning traffic is high, which indicates the quality of the audio service is high.
Example: Configuring H.323-based SQA
As shown in Figure 2, the H.323 server installed with third-party VoIP server software acts as both the H.323 proxy server and H.323 registrar to manage H.323 user registration and H.323 calls. Host A and Host B installed with third-party client software can place calls to each other.
Configure H.323-based SQA on Device A, Device B, and Device C to optimize multimedia traffic of H.323 calls to provide high-quality multimedia services.
Figure 2 Network diagram
1.     Configure the H.323 proxy server:
Install third-party VoIP server software, and specify the usernames (phone numbers) and passwords for the clients. (Details not shown.)
Install third-party VoIP client software, specify the IP address of the H.323 server, and configure the username (phone number), password, and other parameters on each PC. (Details not shown.)
# Enable H.323-based SQA.
[DeviceA] sqa
[DeviceA-sqa] sqa-h323 enable
[DeviceA-sqa] quit
[DeviceA] quit
# Display brief information about all H.323 calls on Device A.
<DeviceA> display sqa h323 call
6.159.107.207:49172   6.159.108.51:52410    42910c03-e31c-1910-9a63-000c29209aa9
6.159.107.203:49172   6.159.108.47:52410    3e33ecbd-6f1d-1910-8b52-6805ca5d1208
6.159.107.208:49172   6.159.108.52:52410    01a788fe-e21c-1910-8ee7-000c29209aa9
6.159.107.206:49172   6.159.108.50:52410    4e9516ff-e21c-1910-8f98-000c29209aa9
6.159.107.200:49172   6.159.108.44:52410    703b6fff-e21c-1910-9f51-000c29209aa9
# Display detailed information about the H.323 call that Host A placed to Host B.
<DeviceA> display sqa h323 call call-id 703b6fff-e21c-1910-9f51-000c29209aa9 verbose
Call ID: 703b6fff-e21c-1910-9f51-000c29209aa9
  Caller information:
  Callee information:
  GUID: 703b6fff-e21c-1910-9f61-000c29209aa9
  Protocol: TCP(6)
  Session ID: 2
  Type: Audio          Vlan: 1          StartTime: 2019-7-14 15:40:39
  Forward flow (octet): 4793344         Forward flow (packet): 4681
  Reverse flow (octet): 3810304         Reverse flow (packet): 3721
