10-High Availability Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S6805 & S6825 & S6850 & S9850 Configuration Guides-Release 6715-6W10010-High Availability Configuration Guide
09-BFD configuration
09-BFD configuration 463.42 KB
Configuring BFD·· 1
About BFD·· 1
Mechanism·· 1
Single-hop detection and multihop detection· 2
BFD session states· 2
BFD session modes· 3
BFD session creation methods· 7
BFD session flapping suppression· 7
Hardware BFD·· 7
Supported features· 7
Link types supported by BFD·· 8
Technical benefits of BFD·· 9
Protocols and standards· 9
Restrictions and guidelines: BFD configuration· 9
BFD tasks at a glance· 10
Configuring hardware BFD·· 10
Configuring BFD sessions in echo packet mode· 12
About BFD session creation methods· 12
Restrictions and guidelines· 12
Creating a static BFD session· 12
Configuring detection time settings· 14
Configuring BFD sessions in control packet mode· 15
About BFD session creation methods· 15
Restrictions and guidelines· 16
Configuring the session establishment mode· 16
Configuring the detection mode· 16
Creating a static BFD session· 17
Configuring detection time settings· 18
Configuring the authentication mode· 20
Configuring the destination port number for multihop BFD control packets· 20
Configuring the notification delay timer for session establishment failures· 21
Enabling the echo function· 21
Associating the interface state with BFD·· 22
Configuring the TTL value for BFD packets· 23
Configuring BFD session flapping suppression· 23
Forwarding the specified BFD echo packets through the peer link in an M-LAG system·· 24
Configuring event logging and SNMP notifications for BFD·· 25
Enabling BFD event logging· 25
Enabling SNMP notifications for BFD·· 26
Display and maintenance commands for BFD·· 26
Configuring SBFD·· 1
About SBFD·· 1
Restrictions and guidelines: SBFD configuration· 1
SBFD tasks at a glance· 1
Configuring the initiator 2
Restrictions and guidelines· 2
Configuring the initiator for LDP LSP detection· 2
Configuring the initiator for MPLS TE tunnel detection· 3
Configuring the reflector 4
Configuring a BFD template· 4
Configuring event logging and SNMP notifications for SBFD·· 5
Enabling SBFD event logging· 5
Enabling SNMP notifications for SBFD·· 5
Display and maintenance commands for SBFD·· 5
Configuring BFD
About BFD
Bidirectional forwarding detection (BFD) provides a general-purpose, standard, medium- and protocol-independent fast failure detection mechanism. It can detect and monitor the connectivity of forwarding paths to detect communication failures quickly so that measures can be taken to ensure service continuity and enhance network availability.
BFD can uniformly and quickly detect the failures of the bidirectional forwarding paths between two devices for upper-layer protocols such as routing protocols. The hello mechanism used by upper-layer protocols needs seconds to detect a link failure, while BFD can provide detection measured in milliseconds.
Mechanism
BFD establishes a session between two network devices to detect failures on the bidirectional forwarding paths between the devices and provide services for upper-layer protocols. BFD provides no neighbor discovery mechanism. Protocols that BFD services notify BFD of devices to which it needs to establish sessions. After a session is established, if no BFD control packet is received from the peer within the negotiated BFD interval, BFD notifies a failure to the protocol, which then takes appropriate measures.
Figure 1 describes the operation of BFD for OSPF.
1.     OSPF discovers neighbors by sending Hello packets and establishes neighbor relationships.
2.     After establishing neighbor relationships, OSPF notifies BFD of the neighbor information, including destination and source addresses.
3.     BFD uses the information to establish BFD sessions.
4.     After session establishment, BFD starts periodic link detection.
Figure 1 BFD session establishment
Figure 2 describes the BFD fault detection process.
1.     The detected link fails.
2.     BFD detects the link failure and tears down the session.
3.     BFD notifies the neighbor unreachability to OSPF.
4.     OSPF terminates the neighbor relationship on the link.
Figure 2 BFD fault detection
BFD establishes sessions in echo packet mode or control packet mode depending on the BFD packets used.
BFD can be used for single-hop and multihop detections.
·     Single-hop detection—Detects the IP connectivity between two directly connected systems, for example, Device A and Device B as shown in Figure 3.
Figure 3 Single-hop detection
·     Multihop detection—Detects any of the paths between two systems, for example, Device A and Device B as shown in Figure 4. These paths have multiple hops, and might overlap.
Figure 4 Multihop detection
BFD session states
A BFD session can be in DOWN, ADMIN DOWN, INIT or UP state. The meanings of the states are as follows:
·     DOWN—The local BFD session has been shut down or is newly created. This state indicates that the forwarding path is unavailable and that the upper-layer application must take an appropriate action, such as primary/backup path switchover.
·     ADMIN DOWN—The BFD session of the local system is administratively shut down. This state does not indicate that the forwarding path is unavailable. The upper-layer application is not required to take an action.
·     INIT—The local end can communicate with the remote end and requires the BFD session to transition to UP state.
·     UP—The BFD session has been established on the local end. This state indicates that the forwarding path is available.
BFD session modes
BFD sessions use echo packets and control packets.
Echo packet mode
Echo packets are encapsulated into UDP packets. The packet contains destination port 3785, a destination IP address (transmitting interface's IP address), and a source IP address (transmitting interface's IP address).
The local end of the link sends echo packets to establish BFD sessions and monitor link status. The peer end does not establish BFD sessions and only forwards the packets back to the originating end. If the local end does not receive echo packets from the peer end within the detection time, it considers the session down.
BFD sessions in echo packet mode do not require both ends to support BFD. Upon receiving BFD echo packets, the peer end loops back the packets for detection purposes.
In echo packet mode, BFD supports only single-hop detection and the BFD sessions are independent of the operating mode.
Control packet mode
Control packets are encapsulated into UDP packets with port number 3784 for single-hop detection or port number 4784 for multihop detection.
The two ends of the link negotiate the establishment of BFD sessions by using the session parameters carried in control packets. Session parameters include session discriminators, desired minimum packet sending and receiving intervals, and local BFD session state.
State machine transition mechanism for a BFD session in control packet mode
Figure 5 shows the state machine transition mechanism for a BFD session in control packet mode. The ADMIN DOWN state in the state machine is also the DOWN state.
Figure 5 State machine transition mechanism for a BFD session
BFD control packet format
Figure 6 shows the format of a BFD control packet. The BFD control packet contains the required portion and optional authentication portion.
Figure 6 BFD control packet format
Table 1 shows the description of the fields in a BFD control packet.
Table 1 BFD control packet field description
Length
Vers (Version)
3 bits
BFD version number. The current version number is 1.
Diag (Diagnostic)
5 bits
Diagnostic code, which indicates the reason for the most recent session down of the sender. Options include:
·     0—No diagnostic information.
·     1—A control-mode BFD session goes down because local detection times out.
·     2—An echo-mode BFD session goes down, because local detection times out or the source IP address of echo packets is deleted.
·     3—The remote end notifies the local end of BFD session down upon detection timeout.
·     7—The local system prevents a BFD session from being established.
·     31—A packet in AdminDown state is received from the remote end.
Sta (State)
2 bits
BFD session state of the sender:
·     0—AdminDown.
·     1—Down.
·     2—Init.
·     3—Up.
P (Poll)
1 bit
Upon session parameter changes, the sender sends a BFD packet with the P bit set. The receiver must immediately respond this packet.
·     0—The sender does not request verification.
·     1—The sender requests verification of the connectivity or parameter changes.
F (Final)
1 bit
The F bit determines whether BFD sends a response packet upon receiving a packet with the P bit set.
·     0—The sending system does not respond to packets with the P bit set.
·     1—The sending system responds to received packets with the P bit set.
C (Control Plane Independent)
1 bit
Forwarding- and control-plane separation bit. If this bit is set, the BFD implementation is independent of its control plane. That is, changes in the control plane do not affect BFD detection. For example, when IS-IS on the control plane performs GR, BFD can continue to detect link state.
·     1—The BFD implementation on the sending system is independent of the control plane. That is, BFD packets are transmitted on the forwarding plane. BFD can still perform link detection even if the control plane becomes invalid.
·     0—Indicates that BFD packets are transmitted on the control plane.
A (Authentication Present)
1 bit
If this bit is set, the control packet contains the authentication field and the session requires authentication.
D (Demand)
1 bit
If this bit is set, the sender wants to operate in Demand mode. If this bit is not set, the sender does not want to operate in Demand mode or does not support the Demand mode.
M (Multipoint)
1 bit
Reserved bit. It is set to 0 during transmission and ignored during reception.
Detect Mult
8 bits
Detect time multiplier used by the detecting party to calculate the detection interval.
Length
8 bits
BFD control packet length, in bytes.
My Discriminator
32 bits
Local discriminator of the BFD session. It is a unique, non-zero value generated by the sender to identify a BFD session.
Your Discriminator
32 bits
Remote discriminator of the BFD session. If a BFD control packet is received from the session-associated neighbor, the value is My Discriminator in the received packet. If no BFD control packet is received from the neighbor, this value is 0.
Desired Min TX Interval
32 bits
Minimum interval for sending BFD control packets desired by the local system, in microseconds.
Required Min RX Interval
32 bits
Minimum interval for receiving BFD control packets supported by the local system, in milliseconds.
Required Min Echo RX Interval
32 bits
Minimum interval for receiving BFD echo packets supported by the local system, in milliseconds. Value 0 indicates that the echo function is not supported.
Auth Type
8 bits
Authentication type.
Auth Len
8 bits
Authentication field length in bytes, including Auth Type field and Auth Len fields.
Authentication Data
Variable
Authentication data field.
Establishing a BFD session in control packet mode
BFD can use the following operating modes to establish a session:
·     Active mode—BFD actively sends BFD control packets regardless of whether any BFD control packet is received from the peer.
·     Passive mode—BFD does not send control packets until a BFD control packet is received from the peer.
At least one end must operate in active mode for a BFD session to be established.
BFD uses a three-way handshake mechanism to establish sessions. The sender fills the Sta field with the current session state in the transmitted BFD control packets. The receiver transits the state machine states based on the Sta field value in the received BFD control packets and local session status to establish a session.
Figure 7 BFD session establishment process
Detection mechanism of the BFD session in control packet mode
After a BFD session in control packet mode is established, the two ends can operate in the following modes:
·     Asynchronous mode—The device periodically sends BFD control packets. The device considers that the session is down if it does not receive any BFD control packets within the detection interval. By default, a BFD session is in Asynchronous mode.
·     Demand mode—If a large number of BFD sessions exist in the system, you can specify the Demand mode to prevent periodic sending of BFD control packets from affecting system operations. As a best practice, enable the BFD echo function when the detection mode is Demand mode.
¡     If the local end operates in Demand mode, the local device periodically sends BFD control packets with the D bit set to 1. Upon receiving such packets, if the peer end operates in Asynchronous mode (default setting), it stops sending BFD control packets.
¡     If the peer end is operating in Demand mode, both ends stop sending BFD control packets. When the connectivity to another system needs to be verified explicitly, a system sends several BFD control packets with the P bit set at the negotiated transmit interval. If no packets with the F bit set to 1 are received from the peer end within the detection interval, the session is considered down. If a packet with the F bit set to 1 is received from the peer end, the connectivity is found to be up, and no more BFD control packets are sent until the next command is issued.
Echo function of a BFD session in control packet mode
When you use Asynchronous mode BFD to detect the connectivity between directly connected devices, you can enable the echo function. This function enables the local system to periodically send echo packets to the remote system and reduces the control packet receiving rate to save bandwidth usage. The remote system loops back the echo packets to the local system without processing them. If the local system does not receive echo packets looped back from the remote system in a consecutive number of times, the local system declares the BFD session down.
The echo function is supported only for single-hop detection.
BFD sessions in control packet mode can be created statically or established dynamically.
BFD sessions are distinguished by the local discriminator and remote discriminator in control packets. The main difference between a statically created session and a dynamically established session is that they obtain the local discriminator and remote discriminator in different ways.
·     The local discriminator and remote discriminator of a static BFD session are manually configured.
·     The local discriminator of a dynamic BFD session is automatically assigned by the device, and the remote discriminator is obtained during BFD session negotiation.
When BFD detects a link failure, it tears down the BFD session and notifies the upper-layer protocol of the failure. When the upper-layer protocol re-establishes a neighbor relationship, the BFD session comes up again. BFD session flaps occur when a link fails and recovers repeatedly, which consumes significant system resources and causes network instability. You can use BFD session flapping suppression to solve the previous problems.
This feature allows you to suppress BFD session flapping by setting different suppression intervals based on the BFD session down times. Within the suppression intervals, BFD sessions cannot be re-established. The more the BFD session down times, the longer the suppression time to avoid BFD flapping.
Hardware BFD
Software BFD uses the CPU to receive and send BFD packets and to maintain the BFD state machine. Software BFD greatly consumes CPU resources and cannot support a large number of BFD sessions.
Hardware BFD uses hardware chips to process CPU-intensive tasks, such as receiving and sending BFD packets and fault detection. Hardware BFD improves CPU utilization and can support a large number of BFD sessions.
The Hardware mode field in the output from the display bfd session verbose command indicates whether BFD packets are processed in hardware:
·     Enabled—BFD packets are processed in hardware.
·     Disabled—BFD packets are processed in software.
You can take the following actions to disable hardware BFD:
·     Execute commands that are not supported by hardware BFD.
·     Remove cards that support hardware BFD.
When you disable hardware BFD, the BFD session might flap. Before performing this operation, make sure you understand its potential impact on the network.
Supported features
Table 2 shows the features supported by BFD.
Table 2 Features supported by BFD
Feature
Reference
Link aggregation
Ethernet link aggregation in Layer 2—LAN Switching Configuration Guide
IPv4 static routing
Static routing in Layer 3IP Routing Configuration Guide
IPv6 static routing
IPv6 static routing in Layer 3IP Routing Configuration Guide
RIP
RIP in Layer 3IP Routing Configuration Guide
OSPF
OSPF in Layer 3IP Routing Configuration Guide
OSPFv3
OSPFv3 in Layer 3IP Routing Configuration Guide
IS-IS
IS-IS in Layer 3IP Routing Configuration Guide
BGP
BGP in Layer 3IP Routing Configuration Guide
PIM
PIM in IP Multicast Configuration Guide
IPv6 PIM
IPv6 PIM in IP Multicast Configuration Guide
RSVP
RSVP in MPLS Configuration Guide
Track
"Configuring Track"
BFD can detect connectivity for various types of links, as shown in Table 3.
Table 3 Link types supported by BFD
Link category
Link types
IP link
·     Layer 3 Ethernet interface
·     Layer 3 Ethernet subinterface (including aggregate subinterface)
You can establish BFD sessions separately for an Ethernet interface and each of its subinterfaces. As a best practice, do not perform that operation.
Ethernet aggregate link
·     Layer 2 Ethernet aggregate link
·     Member links of the Layer 2 Ethernet aggregate link
·     Layer 3 Ethernet aggregate link
·     Member links of the Layer 3 Ethernet aggregate link
You can establish BFD sessions separately for trunk member ports and the trunk port. As a best practice, do not perform that operation.
MPLS LSP
Statically established BFD sessions that can detect the following types of LSPs:
·     LDP LSPs
·     TE—TE tunnels and static CRLSPs bound to the tunnels.
Dynamic established BFD sessions that can detect the following types of LSPs:
·     LDP LSPs
·     TE—TE tunnels and dynamic CRLSPs bound to the tunnels.
The BFD session used to detect MPLS LSP connectivity is negotiated in one of the following ways:
·     Statically establish the BFD session—Manually configure the local discriminator and remote discriminator of the session, and use the negotiation mechanism provided by BFD to establish the BFD session.
·     Dynamically establish the BFD session—The local discriminator is automatically assigned by the local device, and the remote discriminator is obtained during BFD session negotiation. Use the negotiation mechanism provided by BFD to establish the BFD session.
PW
Single segment of PW
Supports using both statically and dynamically established BFD sessions to detect PWs.
BFD has the following technical benefits:
·     BFD can detect the failures of the bidirectional forwarding paths of any type (including logical links, such as tunnels) between two network devices.
·     BFD can provide services for upper-layer protocols and unified detection mechanisms.
·     BFD provides millisecond-level detection speed to accelerate network convergence, reduce application interruption time, and enhance network reliability.
·     RFC 5880, Bidirectional Forwarding Detection (BFD)
·     RFC 5881, Bidirectional Forwarding Detection (BFD) for IPv4 and IPv6 (Single Hop)
·     RFC 5882, Generic Application of Bidirectional Forwarding Detection (BFD)
·     RFC 5883, Bidirectional Forwarding Detection (BFD) for Multihop Paths
·     RFC 5884, Bidirectional Forwarding Detection (BFD) for MPLS Label Switched Paths (LSPs)
·     RFC 5885, Bidirectional Forwarding Detection (BFD) for the Pseudowire Virtual Circuit Connectivity Verification (VCCV)
·     RFC 7130, Bidirectional Forwarding Detection (BFD) on Link Aggregation Group (LAG) Interfaces
·     By default, the device runs BFD version 1 and is compatible with BFD version 0. You cannot change the BFD version to 0 through commands. When the peer device runs BFD version 0, the local device automatically switches to BFD version 0.
·     After a BFD session is established, the two ends negotiate BFD parameters, including minimum sending interval, minimum receiving interval, initialization mode, and packet authentication, by exchanging negotiation packets. They use the negotiated parameters without affecting the session status.
·     BFD session flapping might occur on an aggregate interface with member ports on different IRF member devices. When the master device, which receives and sends BFD packets, is removed or restarted, a subordinate device might not immediately take over. For example, a subordinate device will not take over when the subordinate device has a short detection time or a large number of BFD sessions.
All the BFD tasks are optional.
1.     Configuring hardware BFD
2.     Configuring BFD sessions in echo packet mode
¡     Creating a static BFD session
¡     Configuring detection time settings
3.     Configuring BFD sessions in control packet mode
¡     Configuring the session establishment mode
¡     Configuring the detection mode
¡     Configuring the authentication mode
¡     Configuring the destination port number for multihop BFD control packets
¡     Configuring the notification delay timer for session establishment failures
¡     Enabling the echo function
¡     Associating the interface state with BFD
¡     Configuring the TTL value for BFD packets
4.     Configuring BFD session flapping suppression
5.     Forwarding the specified BFD echo packets through the peer link in an M-LAG system
6.     Configuring event logging and SNMP notifications for BFD
¡     Enabling BFD event logging
¡     Enabling SNMP notifications for BFD
If you specify the firmware resource mode as PTP-BFD or INT-BFD, the device processes the following BFD sessions through the hardware chip and other BFD sessions through the software:
·     Single-hop BFD sessions in control packet mode, with protocol port number 3784.
·     Multihop BFD sessions in control packet mode, with protocol port number 4784.
BFD processed by the hardware chip is called hardware BFD, and BFD processed by the software is called software BFD.
You can configure hardware BFD and software BFD in the same way. For the sessions assigned to but not supported by hardware BFD, software BFD will process them.
Firmware resource modes
The device has INT, PTP, and BFD firmware types, but only two of them can operate. For more information about INT, see Telemetry Configuration Guide. For more information about PTP, see Network Management and Monitoring Configuration Guide.
This task allows you to specify the following firmware resource modes so that two types of firmware can operate on the device:
·     INT-PTP—Specifies both INT and PTP to operate.
·     PTP-BFD—Specifies both BFD and PTP to operate.
·     INT-BFD—Specifies both INT and BFD to operate.
Table 4 Feature compatibility in different firmware resource modes
Operating firmware
BFD support
INT support
PTP support
INT-PTP
INT and PTP
All BFD features are supported. The BFD packet sending and receiving and BFD FSM maintenance are entirely dependent on the CPU.
All INT features are supported.
All PTP features are supported.
PTP-BFD
PTP and BFD
All BFD features are supported. The CPU-intensive features, such as BFD packet sending and receiving and fault detection, are processed by the hardware chip.
The device can be configured as only the transit node.
INT-BFD
INT and BFD
PTP is not supported.
Software version and feature compatibility
This feature is supported only in Release 6635 and later.
The firmware resource mode can take effect only after you save the configuration and reboot the device. As a best practice, make sure you understand the impact on the network before rebooting the device.
If he firmware resource mode is INT-PTP, the device might not be able to establish BFD sessions correctly when you roll back the software version from Release 6635 or later to a version earlier than Release 6635.
Follow these guidelines when you configure hardware BFD:
·     Hardware BFD supports only BFD sessions in control packet mode.
·     If you configure authentication settings on the local device but not on the peer device, the BFD session immediately goes down. If you configure consistent authentication settings for both ends, the BFD session goes up again.
·     Hardware BFD cannot detect the changes in ARP or ND entries used by the upper-layer protocol. You need to manually update the ARP or ND entries by reconfiguring BFD.
·     Hardware BFD does not support encapsulating tunnel packets.
·     You cannot associate link aggregation, interface state, or MPLS with hardware BFD.
·     For multihop BFD sessions in control packet mode that use ECMP links, the BFD sessions might flap upon ECMP link switchovers.
·     If the output interface for a BFD session is an aggregate interface, the BFD session might flap upon member port switchovers.
·     When the minimum BFD detection interval is 3 to 99 milliseconds and you edited the configuration to a value not supported by hardware BFD, software BFD takes over and the BFD session might flap.
·     Hardware BFD does not support detecting VXLAN tunnels.
·     Hardware BFD is not supported on IRF devices.
·     Hardware BFD does not support VPN.
·     Upon switchover from hardware BFD to software BFD, the BFD session flap.
2.     Specify the firmware resource mode.
hardware-resource firmware-mode { INT-PTP | PTP-BFD | INT-BFD }
By default, the firmware resource mode is INT-PTP.
3.     Configure hardware BFD settings.
Configure hardware BFD in the same way software BFD is configured.
A BFD session can be created manually by using the bfd static command or created dynamically through collaboration between an application module and BFD.
To avoid echo packet loss, do not configure the echo packet mode on a device with uRPF enabled. For more information about uRPF, see Security Configuration Guide.
A static BFD session in echo packet mode can be used to perform single-hop detection or multihop detection.
You need to create a static BFD session in echo packet mode on only the local device to perform detection.
When creating a static BFD session, you must specify a peer IPv4 or IPv6 address. The system checks only the format of the IP address but not its correctness. If the peer IPv4 or IPv6 address is incorrect, the static BFD session cannot be established.
Different static BFD sessions cannot have the same local discriminator.
As a best practice, specify the source IP address for echo packets when creating a static BFD session. If you do not specify the source IP address, the device uses the IP address specified in the bfd echo-source-ip or bfd echo-source-ipv6 command as the source IP address of echo packets.
Creating a static BFD session for single-hop detection
2.     Configure the source IP address of echo packets.
¡     Configure the source IP address of echo packets.
bfd echo-source-ip ip-address
By default, no source IPv4 address is configured for echo packets.
As a best practice, do not configure the source IPv4 address to be on the same network segment as any local interfaces. This can avoid network congestion caused a large number of ICMP redirect packets sent from the peer.
¡     Configure the source IPv6 address of echo packets.
By default, no source IPv6 address is configured for echo packets.
The source IPv6 address of echo packets can only be a global unicast address.
3.     Create a static BFD session and enter static BFD session view.
IPv4:
bfd static session-name [ peer-ip ipv4-address interface interface-type interface-number destination-ip ipv4-address [ source-ip ipv4-address ] one-arm-echo [ discriminator { auto | local local-value } ] ]
IPv6:
bfd static session-name [ peer-ipv6 ipv6-address interface interface-type interface-number destination-ipv6 ipv6-address [ source-ipv6 ipv6-address ] one-arm-echo [ discriminator { auto | local local-value } ] ]
4.     (Optional.) Specify a local discriminator for the static BFD session.
discriminator local local-value
By default, no local discriminator is specified.
You can use this command only if you do not specify a local discriminator when creating a static BFD session.
Creating a static BFD session for multihop detection
2.     (Optional.) Configure the source IP address of echo packets.
¡     Configure the source IPv4 address of echo packets.
As a best practice, do not configure the source IPv4 address to be on the same network segment as any local interfaces. If you configure such a source IPv4 address, a large number of ICMP redirect packets might be sent from the peer, resulting in link congestion.
IPv4:
bfd static session-name [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] destination-ip ipv4-address [ source-ip ipv4-address ] one-arm-echo[ discriminator { auto | local local-value } ] ]
IPv6:
bfd static session-name [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] destination-ipv6 ipv6-address [ source-ipv6 ipv6-address ] one-arm-echo [ discriminator { auto | local local-value } ] ]
When creating a BFD session in echo packet mode, you can configure the minimum interval for receiving BFD echo packets and the detection time multiplier for the device.
When the same BFD session (with the same source IP address, destination IP address, interface, VPN, and destination port number) is associated with multiple upper layer applications, BFD selects the detection time settings for the BFD session as follows:
1.     Minimum values of the following settings:
¡     Settings configured in static BFD session view.
¡     Settings configured in the BFD template specified by the upper layer application.
¡     Settings configured by the upper layer application.
2.     Settings configured in interface view or system view.
3.     Default settings.
When a BFD session is associated with only one upper layer application, BFD selects the detection time settings for the BFD session as follows:
1.     BFD selects the detection time settings for the BFD session based on whether the upper layer application supports using a BFD template and configuring detection time settings:
¡     If a BFD template is specified and detection time settings are also configured for the upper layer application, BFD selects the settings configured in the specified BFD template.
¡     If a BFD template is specified for the upper layer application that does not support configuring detection time settings, BFD selects the settings configured in the specified BFD template.
¡     If detection time settings are configured for the upper layer application that does not support using a BFD template, BFD selects the configured settings.
Configure detection time settings for single-hop BFD detection
2.     Enter interface view or static BFD session view.
¡     Enter interface view.
¡     Enter static BFD session view.
The static BFD session must already exist.
To configure parameters for a static BFD session, you must enter its view.
3.     Set the minimum interval for receiving BFD echo packets.
The default setting is 400 milliseconds.
4.     Set the detection time multiplier.
bfd detect-multiplier value
The default setting is 5.
Configure detection time settings for multihop BFD detection
2.     (Optional.) Enter static BFD session view.
bfd multi-hop min-echo-receive-interval interval
·     The local discriminator and remote discriminator of a static BFD session are specified manually in the bfd static command or in the commands that associate specific applications with BFD. For example, to use a static BFD session to detect MPLS LSPs, you must manually specify the local discriminator and remote discriminator. For more information, see MPLS OAM in MPLS Configuration Guide.
·     The local discriminator of a dynamic BFD session is assigned by the device, and the remote discriminator is obtained during BFD session negotiation. The device can automatically assign the local discriminator to the BFD session in the following conditions:
¡     The auto keyword is specified for the bfd static command.
¡     The local and remote discriminators are not specified for the BFD session associated with a specific application.
After an upper-layer protocol is configured to support BFD, the device automatically creates BFD sessions in control packet mode. You do not need to perform this task.
BFD version 0 does not support the following commands:
·     bfd session init-mode.
·     bfd authentication-mode.
·     bfd demand enable.
·     bfd echo enable.
2.     Configure the BFD session establishment mode.
By default, BFD uses the active mode to establish a session.
After a BFD session is established, the two ends can operate in the following modes:
·     Demand mode—The Demand mode can be used to reduce the overhead when a large number of BFD sessions exist.
¡     If the peer end is operating in Asynchronous mode (default), the peer end stops sending BFD control packets after receiving control packets with the D bit set. In this scenario, BFD detects only the link between the local end and the peer end. The device considers that the session is down if it does not receive any BFD control packets within the detection interval.
¡     If the peer end is operating in Demand mode, both ends stop sending BFD control packets. In this scenario, the system uses features other than BFD, such as Hello packets and hardware CC, to verify the connectivity to another system.
2.     Enter interface view.
3.     Specify the Demand mode for the BFD session.
bfd demand enable
A static BFD session can be used for single-hop detection and multihop detection. By working with Track, a static BFD session can provide fast failure detection. For more information about Track association with BFD, see "Configuring Track."
Restrictions and guidelines for static BFD session configuration
If a static BFD session is created on the remote end, the static BFD session must be created on the local end.
2.     Create a static BFD session and enter static BFD session view.
IPv4:
bfd static session-name peer-ip ipv4-address interface interface-type interface-number source-ip ipv4-address [ discriminator { auto | local local-value remote remote-value } ]
For a static BFD session to be established, specify the IPv4 address of the peer interface where the static BFD session resides for the peer-ip ipv4-address option. Specify the IPv4 address of the local interface where the static BFD session resides for the source-ip ipv4-address option.
IPv6:
bfd static session-name peer-ipv6 ipv6-address interface interface-type interface-number source-ipv6 ipv6-address [ discriminator { auto | local local-value remote remote-value } ]
For a static BFD session to be established, specify the IPv6 address of the peer interface where the static BFD session resides for the peer-ipv6 ipv6-address option. Specify the IPv6 address of the local interface where the static BFD session resides for the source-ipv6 ipv6-address option.
3.     (Optional.) Specify the local and remote discriminators for the static BFD session.
discriminator { local local-value | remote remote-value }
By default, no local discriminator or remote discriminator is specified for a static BFD session.
Use this command only if you do not specify the local or remote discriminator when creating a static BFD session.
Create a static BFD session for multihop detection
IPv4:
bfd static session-name peer-ip ipv4-address [ vpn-instance vpn-instance-name ] source-ip ipv4-address [ discriminator { auto |local local-value remote remote-value } ] [ track-interface interface-type interface-number ]
IPv6:
bfd static session-name peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] source-ipv6 ipv6-address [ discriminator { auto | local local-value remote remote-value } ] [ track-interface interface-type interface-number ]
When creating a BFD session in control packet mode, you can configure the minimum interval for receiving and transmitting BFD control packets and the detection time multiplier for the device.
3.     Set the minimum interval for receiving echo packets.
4.     Set the minimum interval for transmitting and receiving single-hop BFD control packets.
¡     Set the minimum interval for transmitting single-hop BFD control packets.
¡     Set the minimum interval for receiving single-hop BFD control packets.
5.     Set the single-hop detection time multiplier.
3.     Set the multihop detection time multiplier.
4.     Set the minimum interval for transmitting and receiving multihop BFD control packets.
¡     Set the minimum interval for transmitting multihop BFD control packets.
¡     Set the minimum interval for receiving multihop BFD control packets.
You can configure authentication settings, including algorithm and key, to enhance BFD session security.
Configure the authentication mode for a single-hop BFD session
3.     Configure the authentication mode for single-hop control packets.
bfd authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher cipher-string | plain plain-string }
By default, no authentication mode is configured for single-hop control packets.
Configure the authentication mode for a multihop BFD session
3.     Configure the authentication mode for multihop BFD control packets.
bfd multi-hop authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher cipher-string | plain plain-string }
By default, no authentication mode is configured for multihop BFD control packets.
IANA assigned port number 4784 to BFD for multihop BFD detection in control packet mode. By default, H3C devices use 4784 as the destination port number for multihop BFD control packets, while devices from other vendors might use 3784. To avoid BFD session establishment failures, make sure the devices on both ends of the BFD session use the same destination port number for multihop BFD control packets.
This command applies to only new multihop BFD sessions in control packet mode.
2.     Configure the destination port number for multihop BFD control packets.
The default setting is 4784.
By default, BFD does not notify upper-layer protocols of session establishment failures. The notification is required in some scenarios. For example, upon a session establishment failure in an aggregate link, the aggregate link can place the associated member port in Unselected state based on the failure notification. You can configure the delay timer for BFD to notify upper-layer protocols of session establishment failures.
This feature does not apply to BFD sessions in echo packet mode.
2.     Set the delay timer for BFD to notify upper-layer protocols of session establishment failures.
bfd init-fail-timer seconds
CAUTION
CAUTION:
For session establishment failures caused by configuration mismatches at the two ends, this command can cause the upper-layer protocol to act incorrectly. Therefore, use this command with caution. BFD status mismatch and BFD authentication configuration mismatch are examples of configuration mismatches.
This function is supported only for single-hop detection.
This function does not take effect on BFD sessions associated with interface states.
3.     Enable the echo function.
By default, the echo function is disabled.
By creating a BFD session for single-hop detection through exchange of BFD control packets, this feature implements fast link detection. When BFD detects a link fault, it sets the link layer protocol state to DOWN(BFD). This behavior helps applications relying on the link layer protocol state achieve fast convergence. The source IP address of control packets is specified manually, and the destination IP address is fixed at 224.0.0.184. As a best practice, specify the IP address of the interface as the source IP address. If the interface does not have an IP address, specify a unicast IP address other than 0.0.0.0 as the source IP address.
You can associate the state of the following interfaces with BFD:
·     Layer 2 Ethernet interfaces.
·     Member ports in a Layer 2 aggregation group.
·     Layer 3 Ethernet interfaces.
·     Member ports in a Layer 3 aggregation group.
·     Layer 3 Ethernet subinterfaces.
·     Layer 2 aggregate interfaces.
·     Layer 3 aggregate interfaces.
The echo function does not take effect on BFD sessions associated with interface states.
3.     Associate the interface state with BFD.
bfd detect-interface source-ip ip-address [ discriminator local local-value remote remote-value ] [ template template-name ]
If the peer device does not support obtaining BFD session discriminators through autonegotiation, you must specify the discriminators on both the local and peer devices. Without the discriminators, the BFD session cannot come up.
4.     (Optional.) Configure the timer that delays reporting the first BFD session establishment failure to the data link layer.
bfd detect-interface first-fail-timer seconds
By default, the first BFD session establishment failure is not reported to the data link layer.
5.     (Optional.) Enable special processing for BFD sessions.
bfd detect-interface special-processing [ admin-down | authentication-change | session-up ] *
By default, all types of special processing are disabled for BFD sessions.
When you connect an H3C device to a third-party device, for successful BFD session negotiation, make sure the TTL value settings for BFD packets on both ends of the BFD session are the same. When the device receives a BFD packet in DOWN or INIT state from its peer, it verifies the TTL value of the packet and performs one of the following actions:
·     For a single-hop BFD session, if the device receives a packet that carries a TTL value that is different from the TTL value specified with the bfd ttl command, the device drops the packet.
·     For a multihop BFD session, if the device receives a packet that carries a TTL value that is greater than the TTL value specified with the bfd ttl command, the device drops the packet.
·     If the BFD session is already up, the device sets the BFD session state to AdminDown, which triggers a BFD session renegotiation.
·     The bfd ttl command does not take effect on BFD sessions in echo packet mode.
·     The bfd ttl command does not take effect on SBFD packets,and the device does not verify the TTL value in SBFD packets.
·     For an IPv4 or IPv6 address with different mask lengths or prefix lengths, the device uses the TTL value specified with the longest mask or prefix length.
·     For an IPv4 or IPv6 subnet, the TTL value of single-hop BFD packets must be greater than the TTL value of multihop BFD packets.
2.     Specify the TTL value for BFD packets.
bfd { peer-ip ipv4-address mask-length | peer-ipv6 ipv6-address prefix-length } ttl { single-hop | multi-hop } ttl-value
By default, the TTL value of single-hop BFD packets is 255 and the TTL value of multihop BFD packets is 64.
This feature allows you to suppress BFD session flapping by using the initial-interval, secondary-interval, and maximum-interval arguments.
·     A BFD session is suppressed within the specified interval. The suppression time does not exceed the maximum-interval.
·     After a BFD session goes down for the second time, it cannot be re-established within the initial-interval.
·     After a BFD session goes down for the third time, it cannot be re-established within the secondary-interval.
·     After a BFD session goes down for the fourth time and at any later time, the following rules apply:
¡     If secondary-interval × 2n-3 is smaller than or equal to the maximum-interval, the BFD session cannot be re-established within the secondary-interval × 2n-3.
¡     If secondary-interval × 2n-3 is greater than the maximum-interval, the BFD session cannot be re-established within the maximum-interval.
The letter n, starting from 4, is the number of times the BFD session flaps.
2.     Configure BFD session flapping suppression.
bfd dampening [ maximum maximum-interval initial initial-interval secondary secondary-interval ]
By default, BFD sessions are not suppressed.
The values for the initial-interval and secondary-interval arguments cannot be greater than or equal to the value for the maximum-interval argument.
Typically, only local discriminators are required for static BFD sessions in echo packet mode, and you do not need to configure remote discriminators. In an M-LAG system, a BFD session state anomaly might occur if the following conditions exist:
·     AN M-LAG member device uses a static BFD session in echo packet mode to detect the link to the downlink device.
·     The destination IP address in the BFD echo packets is the same as the IP address of the other M-LAG member device.
For example, as shown in Figure 8, Device C in the user network is dual-homed to an OSPF network through an M-LAG system. The M-LAG member devices are configured as gateways to implement Layer 3 forwarding. The gateway interfaces (for example, VLAN interfaces or VSI interfaces) on the M-LAG member devices use the same IP address and MAC address. Each M-LAG member device uses a static BFD session in echo packet mode to detect the link to Device C. The destination IP address in the BFD echo packets sent by the M-LAG member devices is the gateway IP address. Upon receiving the BFD echo packet sent by M-LAG 1, Device C might forward the packet to M-LAG 2. M-LAG 2 does not send the packet to M-LAG 1 because the destination IP address in the packet is the local device. Because no BFD echo packet is received from Device C, the BFD session state will become abnormal on M-LAG 1.
To resolve this issue, you can specify the local discriminator on M-LAG 1 for M-LAG 2 as a remote discriminator. Upon receiving a BFD echo packet matching a remote discriminator, M-LAG 2 sends the packet to M-LAG 1 through the peer link. This ensures that the BFD session on M-LAG 1 can come up correctly. Similarly, you can specify the local discriminator on M-LAG 2 for M-LAG 1 as a remote discriminator to ensure that the BFD session on M-LAG 2 can come up correctly.
Figure 8 BFD for M-LAG
As a best practice, make sure the BFD session discriminators on the M-LAG member interfaces do not overlap in an M-LAG system.
1.     Enter system view
2.     Specify remote discriminators of static BFD sessions for the local device.
bfd forwarding match remote-discriminator discr-value-list { discr-value1 [ to discr-value2 ] } &<1-10>
By default, no remote discriminators of static BFD sessions are specified for the local device.
Use this feature to enable the device to record the following types of BFD event logs to help you locate the reason for BFD session state anomalies:
·     BFD session down events.
·     Driver packet-sending events.
2.     Enable BFD event logging.
bfd event-log enable { down [ log-size ] | driver-packet [ detection-abnormal-autostop ] }
By default, BFD event logging is disabled.
You can repeat this command to modify the maximum number of logs allowed for BFD session down events. After modification, the device clears recorded logs.
The device can record a maximum number of 8192 logs for driver packet-sending events.
To report critical BFD events to an NMS, enable SNMP notifications for BFD. For BFD event notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
2.     Enable SNMP notifications for BFD.
snmp-agent trap enable bfd
By default, SNMP notifications are enabled for BFD.
Execute the display command in any view and the reset command in user view.
Display BFD session information.
display bfd session [ discriminator local local-value | static session-name | verbose ]
display bfd session [ [ dynamic ] [ control | echo ] [ ip ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] [ ipv6 ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] [ lsp | te | pw ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] | [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] ] [ verbose ] ]
display bfd session [ [ static ] [ ip ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] [ verbose ]
display bfd session [ [ static ] [ ipv6 ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ verbose ]
Display the TTL values for BFD packets.
display bfd ttl
Clear BFD session statistics.
reset bfd session statistics
Configuring SBFD
About SBFD
Seamless BFD (SBFD) is a unidirectional failure detection mechanism that provides shorter detection time than BFD. SBFD is used in scenarios where only one end of a link requires failure detection, such as MPLS TE tunneling and LSP establishment through LDP. For information about SRLSP, see SR-MPLS configuration in Segment Routing Configuration Guide. For information about LSP establishment through LDP, see LDP configuration in MPLS Configuration Guide.
An SBFD session involves the following roles:
·     Initiator—Periodically sends SBFD control packets to detect connectivity to remote entities. The initiator injects SBFD control packets into an MPLS TE tunnel or LDP LSP. The initiator initiates SBFD sessions and maintains SBFD session state.
·     Reflector—Listens for incoming SBFD control packets on local entities and replies with response SBFD control packets.
As shown in Figure 9, in an SR-based MPLS TE tunnel, the SRLSP from Router A to Router E is considered available if Router A (initiator) can receive response SBFD control packets from Router E (reflector).
Figure 9 Initiator and reflector in SBFD
A node can act as the initiator of one session and the reflector of another session at the same time.
An SBFD session can only be established statically. You must manually specify the remote discriminator for an SBFD session.
To configure SBFD, perform the following tasks:
1.     Configuring the initiator
¡     Configuring the initiator for LDP LSP detection
¡     Configuring the initiator for MPLS TE tunnel detection
2.     Configuring the reflector
3.     Configuring a BFD template
4.     Configuring event logging and SNMP notifications for SBFD
¡     Enabling SBFD event logging
¡     Enabling SNMP notifications for SBFD
The remote discriminator in SBFD control packets sent by the initiator must be specified in the sbfd local-discriminator command on the reflector. If the discriminator is not specified on the reflector, the reflector does not reply with response SBFD control packets.
SBFD detects the connectivity of an LDP LSP in the following process:
1.     The initiator injects SBFD packets into an LDP LSP. The ingress node of the LDP LSP is used as the initiator.
2.     After receiving an SBFD packet, the reflector checks whether the remote discriminator carried in the packet is the same as the local discriminator. If they are the same, the reflector sends a response SBFD packet to the initiator according to the routing table. The egress node of the LDP LSP is used as the reflector.
3.     If the initiator receives the response SBFD packet before the detection time expires, it considers the LDP LSP available.
For more information about using LDP to dynamically establishing an LSP, see LDP in MPLS Configuration Guide.
When informing SBFD to establish an SBFD session, the LDP LSP sends the source and destination IP addresses of the packet to SBFD. The source IP address is the MPLS LSR ID of the local device. To configure LDP LSP detection, you must first configure an MPLS LSR ID on the local device and make sure the remote device has a route to the MPLS LSR ID.
2.     Enable BFD for MPLS.
mpls bfd enable
By default, BFD for MPLS is disabled.
For more information about this command, see MPLS OAM commands in MPLS Command Reference.
3.     (Optional.) Set the detection time multiplier.
4.     (Optional.) Set the minimum interval for sending SBFD control packets.
5.     Configure SBFD to verify LSP connectivity for an FEC.
mpls sbfd dest-addr mask-length [ nexthop nexthop-address ] remote remote-id [ template template-name ]
By default, SBFD is not configured to verify LSP connectivity for an FEC.
SBFD detects the connectivity of an SR-MPLS-based MPLS TE tunnel in the following process:
1.     The initiator injects SBFD packets into an SRLSP. The ingress node of the MPLS TE tunnel is used as the initiator.
2.     After receiving an SBFD packet, the reflector checks whether the remote discriminator carried in the packet is the same as the local discriminator. If they are the same, the reflector sends a response SBFD packet to the initiator according to the IP routing table. The egress node of the MPLS TE tunnel is used as the reflector.
3.     If the initiator receives the response SBFD packet before the detection time expires, it considers the SRLSP available.
For more information about SRLSPs, see SR-MPLS in Segment Routing Configuration Guide.
When informing SBFD to establish an SBFD session, the MPLS TE tunnel sends the source and destination IP addresses of the packet to SBFD. The source IP address is the MPLS LSR ID of the local device. To configure MPLS TE tunnel detection, you must first configure an MPLS LSR ID on the local device and make sure the remote device has a route to the MPLS LSR ID.
mpls bfd enable
5.     Enter the view of an MPLS TE tunnel interface.
interface tunnel number [ mode mpls-te ]
6.     Enable SBFD to verify MPLS TE tunnel connectivity.
mpls sbfd remote remote-id [ template template-name ]
By default, SBFD is not enabled for an MPLS TE tunnel.
If you configure an IPv4 address as the local discriminator, the device automatically converts it to an integer. Configure an IPv4 address local discriminator only when it is required for interoperation with a third-party device.
The reflector replies with a response SBFD control packet only when the remote discriminator in the SBFD control packet sent from the initiator is specified in the sbfd local-discriminator command.
2.     Configure a local discriminator.
sbfd local-discriminator { ipv4-address | integer-value }
By default, no local discriminator is configured.
You can execute this command multiple times to configure multiple local discriminators.
You can configure SBFD parameters for the following paths through a BFD template:
·     LDP LSPs.
·     MPLS TE tunnels.
2.     Create a BFD template and enter BFD template view.
bfd template template-name
3.     Set the detection time multiplier.
4.     Set the minimum interval for sending SBFD control packets.
Use this feature to enable the device to record the following types of SBFD event logs to help you locate the reason for SBFD session state anomalies:
·     SBFD session down events.
2.     Enable SBFD event logging.
By default, SBFD event logging is disabled.
You can repeat this command to modify the maximum number of logs allowed for SBFD session down events. After modification, the device clears recorded logs.
To report critical SBFD events to an NMS, enable SNMP notifications for SBFD. For SBFD event notifications to be sent correctly, you must also configure SNMP as described in the network management and monitoring configuration guide for the device.
2.     Enable SNMP notifications for SBFD.
By default, SNMP notifications are enabled for SBFD.
Execute the display command in any view.
Display SBFD session information.
display sbfd session { initiator | reflector } [ discriminator value | verbose ]
