- H3C S6805 & S6825 & S6850 & S9850 & S9820 Config Examples-Release 66xx-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 14-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 15-GRE Tunnel Configuration Examples
- 16-GRE with OSPF Configuration Examples
- 17-OSPF Configuration Examples
- 18-IS-IS Configuration Examples
- 19-BGP Configuration Examples
- 20-Policy-Based Routing Configuration Examples
- 21-OSPFv3 Configuration Examples
- 22-IPv6 IS-IS Configuration Examples
- 23-Routing Policy Configuration Examples
- 24-IGMP Snooping Configuration Examples
- 25-IGMP Configuration Examples
- 26-BIDIR-PIM Configuration Examples
- 27-MLD Snooping Configuration Examples
- 28-IPv6 Multicast VLAN Configuration Examples
- 29-Basic MPLS Configuration Examples
- 30-MPLS L3VPN Configuration Examples
- 31-ACL Configuration Examples
- 32-Control Plane-Based QoS Policy Configuration Examples
- 33-Traffic Policing Configuration Examples
- 34-GTS and Rate Limiting Configuration Examples
- 35-Priority Mapping and Queue Scheduling Configuration Examples
- 36-Traffic Filtering Configuration Examples
- 37-AAA Configuration Examples
- 38-Port Security Configuration Examples
- 39-Portal Configuration Examples
- 40-SSH Configuration Examples
- 41-IP Source Guard Configuration Examples
- 42-Ethernet OAM Configuration Examples
- 43-CFD Configuration Examples
- 44-DLDP Configuration Examples
- 45-VRRP Configuration Examples
- 46-BFD Configuration Examples
- 47-NTP Configuration Examples
- 48-SNMP Configuration Examples
- 49-NQA Configuration Examples
- 50-Mirroring Configuration Examples
- 51-sFlow Configuration Examples
- 52-FCoE Configuration Examples
- 53-OpenFlow Configuration Examples
- 54-MAC Address Table Configuration Examples
- 55-Static Multicast MAC Address Entry Configuration Examples
- 56-IP Unnumbered Configuration Examples
- 57-MVRP Configuration Examples
- 58-MCE Configuration Examples
- 59-Congestion Avoidance and Queue Scheduling Configuration Examples
- 60-Attack Protection Configuration Examples
- 61-Smart Link Configuration Examples
- 62-RRPP Configuration Examples
- 63-BGP Route Selection Configuration Examples
- 64-IS-IS Route Summarization Configuration Examples
- 65-IRF Configuration Examples
- 66-MPLS OAM Configuration Examples
- 67-MPLS TE Configuration Examples
- 68-VXLAN Configuration Examples
- 69-NetStream Configuration Examples
- 70-DRNI Configuration Examples
- 71-DRNI and EVPN Configuration Examples
- 72-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 73-VCF Fabric Configuration Examples
- 74-PTP Configuration Examples
- 75-S-MLAG Configuration Examples
- 76-Puppet Configuration Examples
- 77-802.1X Configuration Examples
- 78-MAC Authentication Configuration Examples
- 79-MOD and Elephant and Mice Flow Configuration Examples
- 80-TCB Configuration Examples
- 81-Multicast VPN Configuration Examples
| 71-DRNI and EVPN Configuration Examples | 553.55 KB |
H3C S6805 & S6825 & S6850 & S9850 & S9820 |
Copyright © 2020-2023 New H3C Technologies Co., Ltd. All rights reserved.
General restrictions and guidelines
Example: Configuring DRNI using an Ethernet aggregate link as the IPL on EVPN VTEPs
Configuring routed (Layer 3) interfaces
Configuring BGP to advertise BGP EVPN routes
Mapping Ethernet service instances to VSIs
Verifying the configuration on a DR member device
Verifying the network connectivity of the VMs
Example: Configuring DRNI using a VXLAN tunnel as the IPL on EVPN VTEPs
Configuring Layer 3 interfaces
Configuring a monitor link group
Example: Configuring DRNI using an Ethernet aggregate link as the IPL on EVPN gateways
Setting the VXLAN hardware resource mode
Configuring distributed EVPN gateways
Example: Configuring DRNI using a VXLAN tunnel as the IPL on EVPN gateways
Introduction
This document provides configuration examples for using Distributed Resilient Network Interconnect (DRNI) on an Ethernet Virtual Private Network (EVPN) network.
DRNI virtualizes two physical devices into one system through multichassis link aggregation. You can use DRNI to virtualize two VTEPs or EVPN gateways into one distributed-relay (DR) system to avoid single points of failure.
The following information is provided based on the assumption that you have basic knowledge of DRNI and EVPN.
You can set up a DR system by using two VTEPs or EVPN gateways. The DR member devices must have the same AC configuration, VSI and VXLAN ID mappings, and EVPN router MAC address. The EVPN router MAC address is configurable with the evpn global-mac and mac-address commands. If an aggregate link acts as the IPL, the DR member devices must have the same single-homed AC configuration.
Perform the following tasks on the DR member devices:
· Use the drni mad exclude interface command to exclude all interfaces used by EVPN from the MAD shutdown action by DRNI, including:
¡ VSI interfaces.
¡ Interfaces that provide BGP peer addresses.
¡ Interfaces used for setting up the keepalive link.
¡ Transport-facing outgoing interfaces of VXLAN tunnels.
· Configuring or deleting DRNI settings causes a routing table refresh. As a best practice, configure DRNI prior to service features.
· On each DR member device, the virtual VTEP address and the BGP peer address must belong to different interfaces.
· If you use a VXLAN tunnel as the IPL, make sure the following requirements are met on each DR member device:
¡ The source address of the IPL VXLAN tunnel must be the address used by the device to establish BGP peer relationships with other devices.
¡ The virtual VTEP address cannot be the local VTEP IP address.
· Use the drni restore-delay command to set the restoration delay to 180 seconds or longer.
· You must disable spanning tree on the Layer 2 Ethernet interface that acts as the physical traffic outgoing interface of a VXLAN tunnel. If you enable spanning tree on that interface, the upstream device will falsely block the interfaces connected to the DR member devices.
Follow these software version restrictions:
· If both DR member devices run Release 6616, Release 6616P01, or Release 6635 or later, you can use the display l2vpn drni mac-address command to view the MAC addresses synchronized from the DR peer.
· If one or both DR member devices run Release 6607 or earlier, you can use the display evpn drni synchronized-mac command to view the MAC addresses synchronized from the DR peer.
As shown in Figure 1, perform the following tasks to make sure the VMs can communicate with one another:
· Configure VXLAN 10 on Switch A, Switch B, and Switch D.
· Configure DRNI on Switch A and Switch B to virtualize them into one VTEP. Configure an Ethernet aggregate link as the IPL between the switches.
· Configure Switch C as a route reflector (RR).
Analysis
To conserve resources, configure Switch C to reflect routes for Switch A, Switch B, and Switch D.
Hardware |
Software version |
S6805 switch series |
Release 6607, Release 6616, Release 6616P01, Release 6635 and later |
S6825 switch series |
S6850 switch series S9850 switch series |
Release 6555P01, Release 6607, Release 6616, Release 6616P01, Release 6635 and later |
S9820-64H |
Not supported |
S9820-8C |
Not supported |
A VTEP supports a maximum of 4000 ACs.
As a best practice, use the IP address of a loopback interface as the virtual VTEP address.
You can configure only the following criteria for Ethernet service instances:
· encapsulation s-vid { vlan-id | vlan-id-list }
· encapsulation untagged
You must map the Ethernet service interfaces that use the same match criterion on different ports to the same VSI.
As a best practice, do not redistribute external routes on the DR member devices.
Procedures
# Configure the Layer 3 interfaces on Switch A.
[SwitchA-Loopback0] ip address 1.1.1.1 32
[SwitchA-Loopback0] quit
[SwitchA] interface loopback 1
[SwitchA-Loopback1] ip address 1.2.3.4 32
[SwitchA-Loopback1] quit
[SwitchA] vlan 11
[SwitchA-vlan11] port hundredgige 1/0/5
[SwitchA-vlan11] quit
[SwitchA-Vlan-interface11] ip address 11.1.1.1 24
[SwitchA] interface hundredgige 1/0/4
[SwitchA-HundredGigE1/0/4] port link-mode route
[SwitchA-HundredGigE1/0/4] ip address 60.1.1.1 24
[SwitchA-HundredGigE1/0/4] quit
# Configure the Layer 3 interfaces on other switches. (Details not shown.)
Configuring OSPF
Configuring Switch A
# Configure OSPF to advertise the networks attached to the Layer 3 interfaces.
[SwitchA] ospf 1 router-id 1.1.1.1
[SwitchA-ospf-1] area 0
[SwitchA-ospf-1-area-0.0.0.0] network 1.1.1.1 0.0.0.0
[SwitchA-ospf-1-area-0.0.0.0] network 1.2.3.4 0.0.0.0
[SwitchA-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[SwitchA-ospf-1] quit
# Configure routing between Switch A and Switch B.
[SwitchA] vlan 100
[SwitchA-vlan100] quit
[SwitchA] interface Vlan-interface 100
[SwitchA-Vlan-interface100] ip address 100.1.1.1 255.255.255.0
[SwitchA-Vlan-interface100] ospf 1 area 0.0.0.0
Configuring Switch B
[SwitchB] ospf 1 router-id 2.2.2.2
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1-area-0.0.0.0] network 1.2.3.4 0.0.0.0
[SwitchB-ospf-1-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[SwitchB-ospf-1] quit
[SwitchB] vlan 100
[SwitchB-vlan100] quit
[SwitchB] interface Vlan-interface 100
[SwitchB-Vlan-interface100] ip address 100.1.1.2 255.255.255.0
[SwitchB-Vlan-interface100] ospf 1 area 0.0.0.0
Configuring Switch C
[SwitchC] ospf 1 router-id 3.3.3.3
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[SwitchC-ospf-1] quit
Configuring Switch D
<SwitchD> system-view
[SwitchD] ospf 1 router-id 4.4.4.4
[SwitchD-ospf-1] area 0
[SwitchD-ospf-1-area-0.0.0.0] network 4.4.4.4 0.0.0.0
[SwitchD-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[SwitchD-ospf-1] quit
Configuring EVPN
# Enable L2VPN.
[SwitchA] l2vpn enable
# Disable remote MAC address learning and remote ARP learning.
[SwitchA] vxlan tunnel mac-learning disable
[SwitchA] vxlan tunnel arp-learning disable
# Create an EVPN instance on VSI vpna.
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] arp suppression enable
[SwitchA-vsi-vpna] evpn encapsulation vxlan
# Configure the switch to automatically generate an RD and a route target for the EVPN instance.
[SwitchA-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchA-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchA-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[SwitchA-vsi-vpna] vxlan 10
[SwitchA-vsi-vpna] quit
# Enable L2VPN.
[SwitchB] l2vpn enable
[SwitchB] vxlan tunnel mac-learning disable
[SwitchB] vxlan tunnel arp-learning disable
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] arp suppression enable
[SwitchB-vsi-vpna] evpn encapsulation vxlan
[SwitchB-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchB-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchB-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[SwitchB-vsi-vpna] vxlan 10
[SwitchB-vsi-vpna] quit
# Enable L2VPN.
[SwitchD] l2vpn enable
[SwitchD] vxlan tunnel mac-learning disable
[SwitchD] vxlan tunnel arp-learning disable
[SwitchD] vsi vpna
[SwitchD-vsi-vpna] arp suppression enable
[SwitchD-vsi-vpna] evpn encapsulation vxlan
[SwitchD-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchD-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchD-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[SwitchD-vsi-vpna] vxlan 10
[SwitchD-vsi-vpna-vxlan-10] quit
[SwitchD-vsi-vpna] quit
Configuring DRNI
Choose one of the following frame match criterion creation methods for dynamic ACs. Use the same method on Switch A and Switch B. This example uses the default method.
· Enable the device to create frame match criteria based on VXLAN IDs for the dynamic ACs on the IPL.
[SwitchA] l2vpn drni peer-link ac-match-rule vxlan-mapping
· Use the default setting for dynamic ACs on the IPL to use frame match criteria identical to those of site-facing ACs.
# Specify the virtual VTEP address as 1.2.3.4.
[SwitchA] evpn drni group 1.2.3.4
# Configure DR system parameters.
[SwitchA] drni system-mac 0001-0001-0001
[SwitchA] drni system-number 1
[SwitchA] drni system-priority 10
[SwitchA] drni restore-delay 180
[SwitchA] drni keepalive ip destination 60.1.1.2 source 60.1.1.1
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 3.
[SwitchA] interface bridge-aggregation 3
[SwitchA-Bridge-Aggregation3] link-aggregation mode dynamic
[SwitchA-Bridge-Aggregation3] quit
# Assign HundredGigE 1/0/3 to aggregation group 3.
[SwitchA] interface hundredgige 1/0/3
[SwitchA-HundredGigE1/0/3] port link-aggregation group 3
[SwitchA-HundredGigE1/0/3] quit
# Specify Bridge-Aggregation 3 as the IPP.
[SwitchA-Bridge-Aggregation3] port drni intra-portal-port 1
[SwitchA-Bridge-Aggregation3] undo mac-address static source-check enable
# Disable static source check and spanning tree on HundredGigE 1/0/5.
[SwitchA] interface hundredgige 1/0/5
[SwitchA-HundredGigE1/0/5] undo mac-address static source-check enable
[SwitchA-HundredGigE1/0/5] undo stp enable
[SwitchA-HundredGigE1/0/5] quit
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 4.
[SwitchA] interface bridge-aggregation 4
[SwitchA-Bridge-Aggregation4] link-aggregation mode dynamic
[SwitchA-Bridge-Aggregation4] quit
# Assign HundredGigE 1/0/1 to aggregation group 4.
[SwitchA] interface hundredgige 1/0/1
[SwitchA-HundredGigE1/0/1] port link-aggregation group 4
[SwitchA-HundredGigE1/0/1] quit
# Assign Bridge-Aggregation 4 to DR group 4.
[SwitchA-Bridge-Aggregation4] port drni group 4
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 5.
[SwitchA] interface bridge-aggregation 5
[SwitchA-Bridge-Aggregation5] link-aggregation mode dynamic
[SwitchA-Bridge-Aggregation5] quit
# Assign HundredGigE 1/0/2 to aggregation group 5.
[SwitchA] interface hundredgige 1/0/2
[SwitchA-HundredGigE1/0/2] port link-aggregation group 5
[SwitchA-HundredGigE1/0/2] quit
# Assign Bridge-Aggregation 5 to DR group 5.
[SwitchA-Bridge-Aggregation5] port drni group 5
# Exclude all interfaces used by EVPN from the shutdown action by DRNI MAD.
[SwitchA] drni mad exclude interface loopback 0
[SwitchA] drni mad exclude interface hundredgige 1/0/4
[SwitchA] drni mad exclude interface hundredgige 1/0/5
[SwitchA] drni mad exclude interface vlan-interface 11
[SwitchB] l2vpn drni peer-link ac-match-rule vxlan-mapping
[SwitchB] evpn drni group 1.2.3.4
[SwitchB] drni system-mac 0001-0001-0001
[SwitchB] drni system-number 2
[SwitchB] drni system-priority 10
[SwitchB] drni restore-delay 180
[SwitchB] drni keepalive ip destination 60.1.1.1 source 60.1.1.2
[SwitchB] interface bridge-aggregation 3
[SwitchB-Bridge-Aggregation3] link-aggregation mode dynamic
[SwitchB-Bridge-Aggregation3] quit
[SwitchB] interface hundredgige 1/0/3
[SwitchB-HundredGigE1/0/3] port link-aggregation group 3
[SwitchB-HundredGigE1/0/3] quit
[SwitchB-Bridge-Aggregation3] port drni intra-portal-port 1
[SwitchB-Bridge-Aggregation3] undo mac-address static source-check enable
[SwitchB] interface hundredgige 1/0/5
[SwitchB-HundredGigE1/0/5] undo mac-address static source-check enable
[SwitchB-HundredGigE1/0/5] undo stp enable
[SwitchB-HundredGigE1/0/5] quit
[SwitchB] interface bridge-aggregation 4
[SwitchB-Bridge-Aggregation4] link-aggregation mode dynamic
[SwitchB-Bridge-Aggregation4] quit
[SwitchB] interface hundredgige 1/0/1
[SwitchB-HundredGigE1/0/1] port link-aggregation group 4
[SwitchB-HundredGigE1/0/1] quit
[SwitchB-Bridge-Aggregation4] port drni group 4
[SwitchB] interface bridge-aggregation 5
[SwitchB-Bridge-Aggregation5] link-aggregation mode dynamic
[SwitchB-Bridge-Aggregation5] quit
[SwitchB] interface hundredgige 1/0/2
[SwitchB-HundredGigE1/0/2] port link-aggregation group 5
[SwitchB-HundredGigE1/0/2] quit
[SwitchB-Bridge-Aggregation5] port drni group 5
[SwitchB] drni mad exclude interface loopback 0
[SwitchB] drni mad exclude interface hundredgige 1/0/4
[SwitchB] drni mad exclude interface hundredgige 1/0/5
[SwitchA] drni mad exclude interface vlan-interface 12
# Configure BGP to advertise BGP EVPN routes.
[SwitchA] bgp 200
[SwitchA-bgp-default] peer 3.3.3.3 as-number 200
[SwitchA-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[SwitchA-bgp-default] address-family l2vpn evpn
[SwitchA-bgp-default-evpn] peer 3.3.3.3 enable
[SwitchA-bgp-default-evpn] quit
[SwitchA-bgp-default] quit
[SwitchB] bgp 200
[SwitchB-bgp-default] peer 3.3.3.3 as-number 200
[SwitchB-bgp-default] address-family l2vpn evpn
[SwitchB-bgp-default-evpn] peer 3.3.3.3 enable
[SwitchB-bgp-default-evpn] quit
[SwitchB-bgp-default] quit
# Configure BGP to advertise BGP EVPN routes and configure the switch as an RR.
[SwitchC] bgp 200
[SwitchC-bgp-default] group evpn
[SwitchC-bgp-default] peer 1.1.1.1 group evpn
[SwitchC-bgp-default] peer 2.2.2.2 group evpn
[SwitchC-bgp-default] peer 4.4.4.4 group evpn
[SwitchC-bgp-default] peer evpn as-number 200
[SwitchC-bgp-default] peer evpn connect-interface loopback 0
[SwitchC-bgp-default] address-family l2vpn evpn
[SwitchC-bgp-default-evpn] peer evpn enable
[SwitchC-bgp-default-evpn] undo policy vpn-target
[SwitchC-bgp-default-evpn] peer evpn reflect-client
[SwitchC-bgp-default-evpn] quit
[SwitchC-bgp-default] quit
[SwitchD] bgp 200
[SwitchD-bgp-default] peer 3.3.3.3 as-number 200
[SwitchD-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[SwitchD-bgp-default] address-family l2vpn evpn
[SwitchD-bgp-default-evpn] peer 3.3.3.3 enable
[SwitchD-bgp-default-evpn] quit
[SwitchD-bgp-default] quit
# On Bridge-Aggregation 4, create Ethernet service instance 1000 to match VLAN 2.
[SwitchA-Bridge-Aggregation4] port link-type trunk
[SwitchA-Bridge-Aggregation4] port trunk permit vlan 2
[SwitchA-Bridge-Aggregation4] service-instance 1000
[SwitchA-Bridge-Aggregation4-srv1000] encapsulation s-vid 2
# Map Ethernet service instance 1000 to VSI vpna.
[SwitchA-Bridge-Aggregation4-srv1000] xconnect vsi vpna
[SwitchA-Bridge-Aggregation4-srv1000] quit
# On Bridge-Aggregation 5, create Ethernet service instance 1000 to match VLAN 3.
[SwitchA-Bridge-Aggregation5] port link-type trunk
[SwitchA-Bridge-Aggregation5] port trunk permit vlan 3
[SwitchA-Bridge-Aggregation5] service-instance 1000
[SwitchA-Bridge-Aggregation5-srv1000] encapsulation s-vid 3
[SwitchA-Bridge-Aggregation5-srv1000] xconnect vsi vpna
[SwitchA-Bridge-Aggregation5-srv1000] quit
[SwitchB-Bridge-Aggregation4] port link-type trunk
[SwitchB-Bridge-Aggregation4] port trunk permit vlan 2
[SwitchB-Bridge-Aggregation4] service-instance 1000
[SwitchB-Bridge-Aggregation4-srv1000] encapsulation s-vid 2
[SwitchB-Bridge-Aggregation4-srv1000] xconnect vsi vpna
[SwitchB-Bridge-Aggregation4-srv1000] quit
[SwitchB-Bridge-Aggregation5] port link-type trunk
[SwitchB-Bridge-Aggregation5] port trunk permit vlan 3
[SwitchB-Bridge-Aggregation5] service-instance 1000
[SwitchB-Bridge-Aggregation5-srv1000] encapsulation s-vid 3
[SwitchB-Bridge-Aggregation5-srv1000] xconnect vsi vpna
[SwitchB-Bridge-Aggregation5-srv1000] quit
# On HundredGigE 1/0/1, create Ethernet service instance 1000 to match VLAN 2.
[SwitchD] interface hundredgige 1/0/1
[SwitchD-HundredGigE1/0/1] port link-type trunk
[SwitchD-HundredGigE1/0/1] port trunk permit vlan 2
[SwitchD-HundredGigE1/0/1] service-instance 1000
[SwitchD-HundredGigE1/0/1] encapsulation s-vid 2
[SwitchD-HundredGigE1/0/1] xconnect vsi vpna
[SwitchD-HundredGigE1/0/1] quit
The verification procedure uses Switch A as an example.
# Verify that Switch A has BGP EVPN routes.
[Switch A]display bgp l2vpn evpn
BGP local router ID is 1.2.3.4
Status codes: * - valid, > - best, d - dampened, h - history
a - additional-path
Total number of routes from all PEs: 1
Route distinguisher: 1:10
Total number of routes: 2
* > [3][0][32][1.2.3.4]/80
1.2.3.4 0 100 32768 i
* >i [3][0][32][4.4.4.4]/80
4.4.4.4 0 100 0 i
# Verify that the VXLAN tunnel to Switch D is up, and the source address of the tunnel is the virtual VTEP address.
[SwitchA] display interface tunnel
Tunnel0
Current state: UP
Line protocol state: UP
Bandwidth: 64 kbps
Tunnel source 1.2.3.4, destination 4.4.4.4
# Verify that ACs have been created on the IPP and mapped to VXLAN 10.
[SwitchA] display l2vpn vsi verbose
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
Bandwidth : Unlimited
Broadcast Restrain : Unlimited
Multicast Restrain : Unlimited
Unknown Unicast Restrain: Unlimited
MAC Learning : Enabled
MAC Table Limit : -
MAC Learning rate : -
Drop Unknown : -
Flooding : Enabled
Statistics : Disabled
VXLAN ID : 10
Tunnels:
Tunnel Name Link ID State Type Flood proxy
Tunnel0 0x5000000 UP Auto Disabled
ACs:
AC Link ID State Type
BAGG4 srv1000 0 Up Manual
BAGG3 srv2 1 Up Dynamic (MLAG)
BAGG5 srv1000 2 Up Manual
BAGG3 srv3 3 Up Dynamic (MLAG)
# Verify that VM 1, VM 2, and VM 3 can communicate when both Switch A and Switch B are operating correctly. (Details not shown.)
# Verify that VM 1, VM 2, and VM 3 can communicate when Switch A's or Switch B's links to the local site are disconnected. (Details not shown.)
Configuration files
· Switch A:
area 0.0.0.0
vlan 11
l2vpn enable
vsi vpna
vxlan 10
vpn-target auto export-extcommunity
vpn-target auto import-extcommunity
interface Bridge-Aggregation3
interface Bridge-Aggregation4
port drni group 4
xconnect vsi vpna
interface Bridge-Aggregation5
port drni group 5
xconnect vsi vpna
interface LoopBack0
ip address 1.1.1.1 255.255.255.255
interface LoopBack0
ip address 1.2.3.4 255.255.255.255
interface Vlan-interface11
ip address 11.1.1.1 255.255.255.0
interface HundredGigE1/0/4
ip address 60.1.1.1 255.255.255.0
interface HundredGigE1/0/1
port link-mode bridge
interface HundredGigE1/0/2
interface HundredGigE1/0/3
interface HundredGigE1/0/5
port access vlan 11
bgp 200
peer 3.3.3.3 connect-interface LoopBack0
peer 3.3.3.3 enable
drni mad exclude interface LoopBack0
drni mad exclude interface HundredGigE1/0/4
drni mad exclude interface HundredGigE1/0/5
drni mad exclude interface Vlan-interface11
return
· Switch B:
area 0.0.0.0
vlan 12
l2vpn enable
vsi vpna
vxlan 10
port drni group 4
xconnect vsi vpna
port drni group 5
xconnect vsi vpna
interface LoopBack0
ip address 2.2.2.2 255.255.255.255
interface LoopBack1
interface Vlan-interface12
ip address 12.1.1.2 255.255.255.0
ip address 60.1.1.2 255.255.255.0
port access vlan 12
bgp 200
peer 3.3.3.3 enable
drni mad exclude interface Vlan-interface12
return
· Switch C:
area 0.0.0.0
vlan 11 to 13
interface LoopBack0
ip address 3.3.3.3 255.255.255.255
ip address 11.1.1.3 255.255.255.0
ip address 12.1.1.3 255.255.255.0
interface Vlan-interface13
ip address 13.1.1.3 255.255.255.0
port access vlan 11
port access vlan 12
port access vlan 13
bgp 200
group evpn internal
peer evpn connect-interface LoopBack0
peer evpn enable
return
· Switch D:
area 0.0.0.0
vlan 13
l2vpn enable
vsi vpna
vxlan 10
interface LoopBack0
ip address 4.4.4.4 255.255.255.255
ip address 13.1.1.4 255.255.255.0
xconnect vsi vpna
port access vlan 13
bgp 200
peer 3.3.3.3 enable
As shown in Figure 2, perform the following tasks to make sure the VMs can communicate with one another:
· Configure DRNI on Switch A and Switch B to virtualize them into one VTEP. Manually set up a VXLAN tunnel as the IPL between the switches.
· Create a monitor link group on Switch A and Switch B. Configure the transport-facing interfaces of Switch A and Switch B as uplink interfaces for the monitor link group, and member interfaces of DR interfaces as downlink interfaces.
· Configure Switch C as an RR.
Analysis
To make sure the overlay network has connectivity,, configure a routing protocol on these switches to advertise routes for reaching their interfaces, including the loopback interfaces. In this example, OSPF is used.
Hardware |
Software version |
S9820-64H |
Not supported |
S9820-8C |
Not supported |
Manually create a VXLAN tunnel interface and configure it as the IPP. The IPL VXLAN tunnel supports only overlay services. You cannot use an automatically created VXLAN tunnel as an IPL.
The IPL VXLAN tunnel and transport VXLAN tunnels must use different physical interfaces as traffic outgoing interfaces.
Disable the spanning tree feature on the Layer 2 Ethernet interface that acts as the physical traffic outgoing interface of the IPL VXLAN tunnel. If you enable the spanning tree feature on that interface, the upstream device might falsely block the interfaces connected to the DR member devices.
Use the reserved vxlan command to specify a reserved VXLAN to forward DRNI protocol packets. The DR member devices in a DR system must have the same reserved VXLAN.
To prioritize transmission of DRNI protocol packets on the IPL, use the tunnel tos command on the VXLAN tunnel interface to set a high ToS value for tunneled packets.
Procedures
[SwitchA] vlan 11
Configuring OSPF
Configuring EVPN
# Enable L2VPN.
# Specify the reserved VXLAN as VXLAN 1234.
[SwitchA] reserved vxlan 1234
[SwitchA] vsi vpna
# Create VXLAN 10.
# Enable L2VPN.
[SwitchB] reserved vxlan 1234
[SwitchB] vsi vpna
# Create VXLAN 10.
# Enable L2VPN.
[SwitchD] vsi vpna
# Create VXLAN 10.
Configuring DRNI
# Create a tunnel to Switch B, and set the ToS of tunneled packets to 100.
[SwitchA-Tunnel1] tunnel tos 100
[SwitchA-Tunnel1] quit
# Exclude the VXLAN tunnel outgoing interface from the shutdown action by DRNI MAD.
[SwitchA] drni mad exclude interface tunnel 1
# Specify the VXLAN tunnel interface as the IPP.
[SwitchA-Tunnel1] port drni intra-portal-port 1
# Create a tunnel to Switch A, and set the ToS of tunneled packets to 100.
[SwitchB] interface tunnel 1 mode vxlan
[SwitchB-Tunnel1] source 2.2.2.2
[SwitchB-Tunnel1] destination 1.1.1.1
[SwitchB-Tunnel1] tunnel tos 100
[SwitchB-Tunnel1] quit
[SwitchB] drni mad exclude interface tunnel 1
[SwitchB-Tunnel1] port drni intra-portal-port 1
[SwitchB] drni mad exclude interface vlan-interface 12
# Create monitor link group 1 and assign uplink and downlink interfaces to it.
[SwitchA] monitor-link group 1
[SwitchA-mtlk-group1] port twenty-fivegige 1/0/1 downlink
[SwitchA-mtlk-group1] port twenty-fivegige 1/0/2 downlink
[SwitchA-mtlk-group1] port twenty-fivegige 1/0/4 uplink
[SwitchA-mtlk-group1] quit
[SwitchB] monitor-link group 1
[SwitchB-mtlk-group1] port twenty-fivegige 1/0/1 downlink
[SwitchB-mtlk-group1] port twenty-fivegige 1/0/2 downlink
[SwitchB-mtlk-group1] port twenty-fivegige 1/0/4 uplink
[SwitchB-mtlk-group1] quit
[SwitchA] bgp 200
[SwitchB] bgp 200
[SwitchC] bgp 200
[SwitchD] bgp 200
a - additional-path
Total number of routes from all PEs: 2
Total number of routes: 4
* > [3][0][32][1.1.1.1]/80
1.1.1.1 0 100 32768 i
* >i [3][0][32][2.2.2.2]/80
2.2.2.2 0 100 0 i
4.4.4.4 0 100 0 i
# Verify that the IPL Tunnel 1 is up, and Tunnel 0 to Switch D uses the virtual VTEP address as the source address.
[SwitchA] display interface Tunnel
Tunnel0
Current state: UP
Bandwidth: 64 kbps
Tunnel1
Current state: UP
Bandwidth: 64 kbps
Last 300 seconds input rate: 13 bytes/sec, 104 bits/sec, 0 packets/sec
Last 300 seconds output rate: 13 bytes/sec, 104 bits/sec, 0 packets/sec
Input: 332 packets, 36377 bytes, 0 drops
Output: 583 packets, 59132 bytes, 0 drops
# Verify that the VXLAN tunnels have been assigned to VXLAN 10.
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 10
Tunnels:
Tunnel1 0x5000001 UP Manual Disabled
ACs:
Configuration files
· Switch A:
area 0.0.0.0
vlan 11
l2vpn enable
reserved vxlan 1234
vsi vpna
vxlan 10
port drni group 4
xconnect vsi vpna
port drni group 5
xconnect vsi vpna
interface LoopBack0
interface LoopBack1
port access vlan 11
interface Tunnel1 mode vxlan
source 1.1.1.1
destination 2.2.2.2
tunnel tos 100
bgp 200
peer 3.3.3.3 enable
drni keepalive ip destination 12.1.1.2 source 11.1.1.1
drni mad exclude interface Tunnel1
drni mad exclude interface Vlan-interface 11
return
· Switch B:
area 0.0.0.0
vlan 12
l2vpn enable
reserved vxlan 1234
vsi vpna
vxlan 10
port drni group 4
xconnect vsi vpna
port drni group 5
xconnect vsi vpna
interface LoopBack0
interface LoopBack1
port access vlan 12
source 2.2.2.2
destination 1.1.1.1
tunnel tos 100
bgp 200
peer 3.3.3.3 enable
drni keepalive ip destination 11.1.1.1 source 12.1.1.2
drni mad exclude interface Vlan-interface 12
return
· Switch C:
area 0.0.0.0
vlan 11 to 13
interface LoopBack0
port access vlan 11
port access vlan 12
port access vlan 13
bgp 200
group evpn internal
peer evpn enable
return
· Switch D:
area 0.0.0.0
vlan 13
l2vpn enable
vsi vpna
vxlan 10
interface LoopBack0
xconnect vsi vpna
port access vlan 13
bgp 200
peer 3.3.3.3 enable
return
As shown in Figure 3, perform the following tasks to make sure the VMs can communicate with one another:
· Configure VXLAN 10 on Switch A, Switch B, and Switch D, and configure VXLAN 20 on Switch A and Switch B.
· Configure Switch A, Switch B, and Switch D as distributed EVPN gateways to provide Layer 3 forwarding service for VMs.
Analysis
Hardware |
Software version |
S9820-64H |
Not supported |
S9820-8C |
Not supported |
The Ethernet service interfaces that use the same match criterion on different ports must be mapped to the same VSI.
Procedures
# Set the VXLAN hardware resource mode on Switch A, Switch B, and Switch D and reboot the switches for the mode to take effect. This step uses Switch A as an example.
[SwitchA] hardware-resource vxlan l3gw
Do you want to change the specified hardware resource working mode? [Y/N]:y
The hardware resource working mode is changed, please save the configuration and
reboot the system to make it effective.
[SwitchA] quit
<SwitchA> reboot
Start to check configuration with next startup configuration file, please wait..
.......DONE!
Current configuration may be lost after the reboot, save current configuration?
[Y/N]:y
[SwitchA] vlan 11
# On VM 1, VM 3, and VM 5, specify 10.1.1.1 as the gateway address. On VM 2 and VM 4, specify 10.1.2.1 as the gateway address. (Details not shown.)
Configuring OSPF
[SwitchA] vlan 100
[SwitchB] vlan 100
Configuring EVPN
# Enable L2VPN.
# Configure the EVPN global MAC address as 0002-0003-0004.
[SwitchA] evpn global-mac 2-3-4
[SwitchA] vsi vpna
# Create VXLAN 10.
# Create an EVPN instance on VSI vpnb.
[SwitchA] vsi vpnb
[SwitchA-vsi-vpnb] evpn encapsulation vxlan
[SwitchA-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[SwitchA-vsi-vpnb-evpn-vxlan] vpn-target auto
[SwitchA-vsi-vpnb-evpn-vxlan] quit
# Create VXLAN 20.
[SwitchA-vsi-vpnb] vxlan 20
[SwitchA-vsi-vpnb-vxlan-20] quit
[SwitchA-vsi-vpnb] quit
# Enable L2VPN.
[SwitchB] evpn global-mac 2-3-4
[SwitchB] vsi vpna
# Create VXLAN 10.
[SwitchB] vsi vpnb
[SwitchB-vsi-vpnb] evpn encapsulation vxlan
[SwitchB-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[SwitchB-vsi-vpnb-evpn-vxlan] vpn-target auto
[SwitchB-vsi-vpnb-evpn-vxlan] quit
# Create VXLAN 20.
[SwitchB-vsi-vpnb] vxlan 20
[SwitchB-vsi-vpnb-vxlan-20] quit
[SwitchB-vsi-vpnb] quit
# Enable L2VPN.
[SwitchD] vsi vpna
# Create VXLAN 10.
# Configure RD and route target settings for VPN instance vpna.
[SwitchA] ip vpn-instance vpna
[SwitchA-vpn-instance-vpna] route-distinguisher 1:1
[SwitchA-vpn-instance-vpna] address-family ipv4
[SwitchA-vpn-ipv4-vpna] vpn-target 2:2
[SwitchA-vpn-ipv4-vpna] quit
[SwitchA-vpn-instance-vpna] address-family evpn
[SwitchA-vpn-evpn-vpna] vpn-target 1:1
[SwitchA-vpn-evpn-vpna] quit
[SwitchA-vpn-instance-vpna] quit
# Configure VSI-interface 1 as a distributed gateway.
[SwitchA] interface vsi-interface 1
[SwitchA-Vsi-interface1] ip binding vpn-instance vpna
[SwitchA-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchA-Vsi-interface1] mac-address 1-1-1
[SwitchA-Vsi-interface1] distributed-gateway local
[SwitchA-Vsi-interface1] local-proxy-arp enable
[SwitchA-Vsi-interface1] quit
# Configure VSI-interface 2 as a distributed gateway.
[SwitchA] interface vsi-interface 2
[SwitchA-Vsi-interface2] ip binding vpn-instance vpna
[SwitchA-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[SwitchA-Vsi-interface2] mac-address 2-2-2
[SwitchA-Vsi-interface2] distributed-gateway local
[SwitchA-Vsi-interface2] local-proxy-arp enable
[SwitchA-Vsi-interface2] quit
# Create VSI-interface 3. Associate VSI-interface 3 with VPN instance vpna, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchA] interface vsi-interface 3
[SwitchA-Vsi-interface3] ip binding vpn-instance vpna
[SwitchA-Vsi-interface3] l3-vni 1000
[SwitchA-Vsi-interface3] quit
# Specify VSI-interface 1 as the gateway interface for VSI vpna.
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] gateway vsi-interface 1
# Specify VSI-interface 2 as the gateway interface for VSI vpnb.
[SwitchA] vsi vpnb
[SwitchA-vsi-vpnb] gateway vsi-interface 2
[SwitchB] ip vpn-instance vpna
[SwitchB-vpn-instance-vpna] route-distinguisher 1:1
[SwitchB-vpn-instance-vpna] address-family ipv4
[SwitchB-vpn-ipv4-vpna] vpn-target 2:2
[SwitchB-vpn-ipv4-vpna] quit
[SwitchB-vpn-instance-vpna] address-family evpn
[SwitchB-vpn-evpn-vpna] vpn-target 1:1
[SwitchB-vpn-evpn-vpna] quit
[SwitchB-vpn-instance-vpna] quit
[SwitchB] interface vsi-interface 1
[SwitchB-Vsi-interface1] ip binding vpn-instance vpna
[SwitchB-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchB-Vsi-interface1] mac-address 1-1-1
[SwitchB-Vsi-interface1] distributed-gateway local
[SwitchB-Vsi-interface1] local-proxy-arp enable
[SwitchB-Vsi-interface1] quit
[SwitchB] interface vsi-interface 2
[SwitchB-Vsi-interface2] ip binding vpn-instance vpna
[SwitchB-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[SwitchB-Vsi-interface2] mac-address 2-2-2
[SwitchB-Vsi-interface2] distributed-gateway local
[SwitchB-Vsi-interface2] local-proxy-arp enable
[SwitchB-Vsi-interface2] quit
[SwitchB] interface vsi-interface 3
[SwitchB-Vsi-interface3] ip binding vpn-instance vpna
[SwitchB-Vsi-interface3] l3-vni 1000
[SwitchB-Vsi-interface3] quit
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] gateway vsi-interface 1
[SwitchB] vsi vpnb
[SwitchB-vsi-vpnb] gateway vsi-interface 2
[SwitchD] ip vpn-instance vpna
[SwitchD-vpn-instance-vpna] route-distinguisher 1:1
[SwitchD-vpn-instance-vpna] address-family ipv4
[SwitchD-vpn-ipv4-vpna] vpn-target 2:2
[SwitchD-vpn-ipv4-vpna] quit
[SwitchD-vpn-instance-vpna] address-family evpn
[SwitchD-vpn-evpn-vpna] vpn-target 1:1
[SwitchD-vpn-evpn-vpna] quit
[SwitchD-vpn-instance-vpna] quit
[SwitchD] interface vsi-interface 1
[SwitchD-Vsi-interface1] ip binding vpn-instance vpna
[SwitchD-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchD-Vsi-interface1] mac-address 1-1-1
[SwitchD-Vsi-interface1] distributed-gateway local
[SwitchD-Vsi-interface1] local-proxy-arp enable
[SwitchD-Vsi-interface1] quit
# Create VSI-interface 3. Associate VSI-interface 3 with VPN instance vpna and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchD] interface vsi-interface 3
[SwitchD-Vsi-interface3] ip binding vpn-instance vpna
[SwitchD-Vsi-interface3] l3-vni 1000
[SwitchD-Vsi-interface3] quit
[SwitchD] vsi vpna
[SwitchD-vsi-vpna] gateway vsi-interface 1
Configuring DRNI
[SwitchA] drni system-mac 0001-0002-0003
[SwitchA] drni mad exclude interface vsi-interface 1
[SwitchA] drni mad exclude interface vsi-interface 2
[SwitchB] drni system-mac 0001-0002-0003
[SwitchB] drni mad exclude interface vsi-interface 1
[SwitchB] drni mad exclude interface vsi-interface 2
[SwitchA] bgp 200
[SwitchB] bgp 200
[SwitchC] bgp 200
[SwitchD] bgp 200
# Map Ethernet service instance 1000 to VSI vpnb.
[SwitchA-Bridge-Aggregation5-srv1000] xconnect vsi vpnb
[SwitchB-Bridge-Aggregation5-srv1000] xconnect vsi vpnb
[SwitchD-HundredGigE1/0/1-srv1000] encapsulation s-vid 2
[SwitchD-HundredGigE1/0/1-srv1000] xconnect vsi vpna
[SwitchD-HundredGigE1/0/1-srv1000] quit
a - additional-path
Route distinguisher: 1:1(vpna)
* > [5][0][24][10.1.1.0]/80
* > [5][0][24][10.1.2.0]/80
4.4.4.4 0 100 0 i
Route distinguisher: 1:20
4.4.4.4 0 100 0 i
Tunnel0
Current state: UP
Bandwidth: 64 kbps
# Verify that ACs have been created on the IPP and mapped to VXLAN 10 and VXLAN 20.
VSI Name: Auto_L3VNI1000_3
VSI Index : 1
VSI State : Down
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
Gateway Interface : VSI-interface 3
VXLAN ID : 1000
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
Gateway Interface : VSI-interface 1
VXLAN ID : 10
Tunnels:
ACs:
VSI Name: vpnb
VSI Index : 2
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
Gateway Interface : VSI-interface 2
VXLAN ID : 20
Tunnels:
ACs:
BAGG5 srv1000 0 Up Manual
BAGG3 srv3 1 Up Dynamic (MLAG)
# Verify that the VMs can communicate when both Switch A and Switch B are operating correctly. (Details not shown.)
# Verify that VM 1 and VM 5 can communicate when Switch A's or Switch B's links to the local site are disconnected. (Details not shown.)
Configuration files
· Switch A:
address-family ipv4
vpn-target 2:2 import-extcommunity
vpn-target 2:2 export-extcommunity
address-family evpn
vpn-target 1:1 import-extcommunity
vpn-target 1:1 export-extcommunity
area 0.0.0.0
vlan 11
l2vpn enable
evpn global-mac 0002-0003-0004
vsi vpna
vxlan 10
vsi vpnb
vxlan 20
port drni group 4
xconnect vsi vpna
port drni group 5
xconnect vsi vpnb
interface LoopBack0
interface LoopBack1
port access vlan 11
interface Vsi-interface1
mac-address 0001-0001-0001
interface Vsi-interface2
mac-address 0002-0002-0002
interface Vsi-interface3
l3-vni 1000
bgp 200
peer 3.3.3.3 enable
drni mad exclude interface Vsi-interface1
drni mad exclude interface Vsi-interface2
return
· Switch B:
address-family ipv4
address-family evpn
area 0.0.0.0
vlan 12
l2vpn enable
vsi vpna
vxlan 10
vsi vpnb
vxlan 20
port drni group 4
xconnect vsi vpna
port drni group 5
xconnect vsi vpnb
interface LoopBack0
interface LoopBack1
port access vlan 12
l3-vni 1000
bgp 200
peer 3.3.3.3 enable
return
· Switch C:
area 0.0.0.0
vlan 11 to 13
interface LoopBack0
port access vlan 11
port access vlan 12
port access vlan 13
bgp 200
group evpn internal
peer evpn enable
return
· Switch D:
address-family ipv4
address-family evpn
area 0.0.0.0
vlan 13
l2vpn enable
vsi vpna
vxlan 10
interface LoopBack0
xconnect vsi vpna
port access vlan 13
l3-vni 1000
bgp 200
peer 3.3.3.3 enable
return
As shown in Figure 4, perform the following tasks to make sure the VMs can communicate with one another:
· Configure VXLAN 10 on Switch A, Switch B, and Switch D, and configure VXLAN 20 on Switch A, and Switch B.
Analysis
Hardware |
Software version |
S9820-64H |
Not supported |
S9820-8C |
Not supported |
Procedures
[SwitchA] quit
<SwitchA> reboot
.......DONE!
[Y/N]:y
[SwitchA] vlan 11
Configuring OSPF
[SwitchA] vlan 100
[SwitchB] vlan 100
Configuring EVPN
# Enable L2VPN.
[SwitchA] vsi vpna
# Create VXLAN 10.
[SwitchA] vsi vpnb
# Create VXLAN 20.
# Enable L2VPN.
[SwitchB] vsi vpna
# Create VXLAN 10.
[SwitchB] vsi vpnb
# Create VXLAN 20.
# Enable L2VPN.
[SwitchD] vsi vpna
# Create VXLAN 10.
[SwitchA] vsi vpna
[SwitchA] vsi vpnb
[SwitchB] vsi vpna
[SwitchB] vsi vpnb
[SwitchD] vsi vpna
Configuring DRNI
[SwitchA] drni mad exclude interface loopback0
[SwitchA] drni mad exclude interface hundredgige1/0/5
[SwitchB] drni mad exclude interface loopback0
[SwitchB] drni mad exclude interface hundredgige1/0/5
[SwitchA] bgp 200
[SwitchB] bgp 200
[SwitchC] bgp 200
[SwitchD] bgp 200
a - additional-path
Total number of routes from all PEs: 3
2.2.2.2 0 100 0 i
4.4.4.4 0 100 0 i
Total number of routes: 3
2.2.2.2 0 100 0 i
Tunnel0
Current state: UP
Bandwidth: 64 kbps
Tunnel1
Current state: UP
Bandwidth: 64 kbps
Last 300 seconds input rate: 149 bytes/sec, 1192 bits/sec, 1 packets/sec
Last 300 seconds output rate: 379 bytes/sec, 3032 bits/sec, 3 packets/sec
Input: 398 packets, 46446 bytes, 0 drops
Output: 3597 packets, 363591 bytes, 0 drops
# Verify that the VXLAN tunnels have been assigned to VXLAN 10 and VXLAN 20.
VSI Index : 1
VSI State : Down
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 1000
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 10
Tunnels:
ACs:
VSI Name: vpnb
VSI Index : 2
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 20
Tunnels:
ACs:
Configuration files
· Switch A:
address-family ipv4
address-family evpn
area 0.0.0.0
vlan 11
l2vpn enable
reserved vxlan 1234
vsi vpna
vxlan 10
vsi vpnb
vxlan 20
port drni group 4
xconnect vsi vpna
port drni group 5
xconnect vsi vpnb
interface LoopBack0
interface LoopBack1
port access vlan 11
l3-vni 1000
source 1.1.1.1
destination 2.2.2.2
tunnel tos 100
bgp 200
peer 3.3.3.3 enable
return
· Switch B:
address-family ipv4
address-family evpn
area 0.0.0.0
vlan 12
l2vpn enable
reserved vxlan 1234
vsi vpna
vxlan 10
vsi vpnb
vxlan 20
port drni group 4
xconnect vsi vpna
port drni group 5
xconnect vsi vpnb
interface LoopBack0
interface LoopBack1
port access vlan 12
l3-vni 1000
source 2.2.2.2
destination 1.1.1.1
tunnel tos 100
bgp 200
peer 3.3.3.3 enable
return
· Switch C:
area 0.0.0.0
vlan 11 to 13
interface LoopBack0
port access vlan 11
port access vlan 12
port access vlan 13
bgp 200
group evpn internal
peer evpn enable
return
· Switch D:
address-family ipv4
address-family evpn
area 0.0.0.0
vlan 13
l2vpn enable
vsi vpna
vxlan 10
interface LoopBack0
xconnect vsi vpna
port access vlan 13
l3-vni 1000
bgp 200
peer 3.3.3.3 enable
return
Related documentation
Use this document in conjunction with the following documents for the product and software version you are working with:
· EVPN Configuration Guide
· EVPN Command Reference
