- H3C S6805 & S6825 & S6850 & S9850 & S9820 Config Examples-Release 66xx-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 14-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 15-GRE Tunnel Configuration Examples
- 16-GRE with OSPF Configuration Examples
- 17-OSPF Configuration Examples
- 18-IS-IS Configuration Examples
- 19-BGP Configuration Examples
- 20-Policy-Based Routing Configuration Examples
- 21-OSPFv3 Configuration Examples
- 22-IPv6 IS-IS Configuration Examples
- 23-Routing Policy Configuration Examples
- 24-IGMP Snooping Configuration Examples
- 25-IGMP Configuration Examples
- 26-BIDIR-PIM Configuration Examples
- 27-MLD Snooping Configuration Examples
- 28-IPv6 Multicast VLAN Configuration Examples
- 29-Basic MPLS Configuration Examples
- 30-MPLS L3VPN Configuration Examples
- 31-ACL Configuration Examples
- 32-Control Plane-Based QoS Policy Configuration Examples
- 33-Traffic Policing Configuration Examples
- 34-GTS and Rate Limiting Configuration Examples
- 35-Priority Mapping and Queue Scheduling Configuration Examples
- 36-Traffic Filtering Configuration Examples
- 37-AAA Configuration Examples
- 38-Port Security Configuration Examples
- 39-Portal Configuration Examples
- 40-SSH Configuration Examples
- 41-IP Source Guard Configuration Examples
- 42-Ethernet OAM Configuration Examples
- 43-CFD Configuration Examples
- 44-DLDP Configuration Examples
- 45-VRRP Configuration Examples
- 46-BFD Configuration Examples
- 47-NTP Configuration Examples
- 48-SNMP Configuration Examples
- 49-NQA Configuration Examples
- 50-Mirroring Configuration Examples
- 51-sFlow Configuration Examples
- 52-FCoE Configuration Examples
- 53-OpenFlow Configuration Examples
- 54-MAC Address Table Configuration Examples
- 55-Static Multicast MAC Address Entry Configuration Examples
- 56-IP Unnumbered Configuration Examples
- 57-MVRP Configuration Examples
- 58-MCE Configuration Examples
- 59-Congestion Avoidance and Queue Scheduling Configuration Examples
- 60-Attack Protection Configuration Examples
- 61-Smart Link Configuration Examples
- 62-RRPP Configuration Examples
- 63-BGP Route Selection Configuration Examples
- 64-IS-IS Route Summarization Configuration Examples
- 65-IRF Configuration Examples
- 66-MPLS OAM Configuration Examples
- 67-MPLS TE Configuration Examples
- 68-VXLAN Configuration Examples
- 69-NetStream Configuration Examples
- 70-DRNI Configuration Examples
- 71-DRNI and EVPN Configuration Examples
- 72-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 73-VCF Fabric Configuration Examples
- 74-PTP Configuration Examples
- 75-S-MLAG Configuration Examples
- 76-Puppet Configuration Examples
- 77-802.1X Configuration Examples
- 78-MAC Authentication Configuration Examples
- 79-MOD and Elephant and Mice Flow Configuration Examples
- 80-TCB Configuration Examples
- 81-Multicast VPN Configuration Examples
| 61-Smart Link Configuration Examples | 380.26 KB |
H3C S6805&S6825&S6850 & S9850 & S9820 |
Copyright © 2020-2023 New H3C Technologies Co., Ltd. All rights reserved.
General restrictions and guidelines
Example: Configuring Smart Link load sharing
Example: Configuring Smart Link and Monitor Link collaboration
Example: Configuring Smart Link in an IRF fabric
Introduction
This document provides Smart Link configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of Smart Link, Monitor Link, and IRF.
If you configure a port as both an aggregation group member and a smart link group member, only the aggregation group configuration takes effect. The port is not shown in the output from the display smart-link group command.
As shown in Figure 1, VLAN 10 and VLAN 11 are assigned to the Finance department and the Marketing department of an enterprise, respectively. Traffic of VLAN 10 and VLAN 11 on Device A is dually uplinked to Device D by Device B and Device C. Configure Smart Link to meet the following requirements:
· When the link between Device A and Device B and the link between Device A and Device C are both available, the traffic of the Finance department is forwarded trough the link between Device A and Device B. The traffic of the Marketing department is forwarded through the link between Device A and Device C.
· When one link fails, the traffic on the link is switched to another link. When the link recovers, the traffic is switched back to the link.
Device |
VLAN |
Device |
VLAN |
Device A |
HGE1/0/1 |
10, 11 |
Device C |
HGE1/0/1 |
10, 11 |
HGE1/0/2 |
10, 11 |
HGE1/0/2 |
10, 11 |
HGE1/0/3 |
10 |
Device D |
HGE1/0/1 |
10, 11 |
HGE1/0/4 |
11 |
HGE1/0/2 |
10, 11 |
Device B |
HGE1/0/1 |
10, 11 |
HGE1/0/3 |
10, 11 |
HGE1/0/2 |
10, 11 |
Analysis
To implement load sharing on the two uplinks, create two smart link groups with the same member ports on Device A. The role of each port must be different in the two smart link groups. Use the VLANs of the Finance department and Marketing department as the protected VLANs of the corresponding smart link groups.
For the traffic to switch back to the recovered link, enable role preemption for the two smart link groups.
For the upstream device to refresh MAC address entries and ARP/ND entries when link switchover occurs in a smart link group, perform the following tasks:
· Enable flush message sending on Device A.
· Enable flush message receiving on ports of the primary and secondary links from Device A to Device D.
Hardware |
Software version |
S6805 switch series |
Release 6607, Release 6616, Release 6616P01, Release 6635 and later |
S6825 switch series |
S6850 switch series S9850 switch series |
Release 6555P01, Release 6607, Release 6616, Release 6616P01, Release 6635 and later |
S9820-64H switch |
S9820-8C switch |
When you configure Smart Link load sharing, follow these restrictions and guidelines:
· Before you configure a port as a smart link group member, shut down the port to prevent loops. You can bring up the port only after completing the smart link group configuration.
· Before you configure a smart link group member port or its directly connected port, disable the spanning tree feature and RRPP on the port.
· Make sure the receive control VLAN configured on the upstream device is the same as the transmit control VLAN configured on the smart link device.
· The control VLAN configured for a smart link group must be different from the control VLAN configured for any other smart link groups.
· The control VLAN of a smart link group must also be one of its protected VLANs. Do not remove the control VLAN. Otherwise, flush messages cannot be sent correctly.
Procedures
Configuring Device A
1. Create VLAN 10 and VLAN 11.
[DeviceA] vlan 10 to 11
2. Configure HundredGigE 1/0/1:
# Shut down HundredGigE 1/0/1.
[DeviceA] interface hundredgige 1/0/1
[DeviceA-HundredGigE1/0/1] shutdown
# Configure HundredGigE 1/0/1 as a trunk port.
[DeviceA-HundredGigE1/0/1] port link-type trunk
# Assign the port to VLAN 10 and VLAN 11.
[DeviceA-HundredGigE1/0/1] port trunk permit vlan 10 11
# Remove the port from VLAN 1.
[DeviceA-HundredGigE1/0/1] undo port trunk permit vlan 1
# Disable the spanning tree feature on the port.
[DeviceA-HundredGigE1/0/1] undo stp enable
[DeviceA-HundredGigE1/0/1] quit
3. Configure HundredGigE 1/0/2 in the same way HundredGigE 1/0/1 is configured.
[DeviceA] interface hundredgige 1/0/2
[DeviceA-HundredGigE1/0/2] shutdown
[DeviceA-HundredGigE1/0/2] port link-type trunk
[DeviceA-HundredGigE1/0/2] port trunk permit vlan 10 11
[DeviceA-HundredGigE1/0/2] undo port trunk permit vlan 1
[DeviceA-HundredGigE1/0/2] undo stp enable
[DeviceA-HundredGigE1/0/2] quit
4. Configure HundredGigE 1/0/3:
# Configure HundredGigE 1/0/3 as an access port and assign the port to VLAN 10.
[DeviceA] interface hundredgige 1/0/3
[DeviceA-HundredGigE1/0/3] port access vlan 10
# Bring up the port.
[DeviceA-HundredGigE1/0/3] undo shutdown
[DeviceA-HundredGigE1/0/3] quit
5. Configure HundredGigE 1/0/4:
# Configure HundredGigE 1/0/4 as an access port and assign the port to VLAN 11.
[DeviceA] interface hundredgige 1/0/4
[DeviceA-HundredGigE1/0/4] port access vlan 11
[DeviceA-HundredGigE1/0/4] undo shutdown
[DeviceA-HundredGigE1/0/4] quit
6. Configure VLAN-to-MSTI mappings and activate the MST region configuration:
# Enter MST region view.
[DeviceA] stp region-configuration
# Map VLAN 10 to MSTI 1, and VLAN 11 to MSTI 2.
[DeviceA-mst-region] instance 1 vlan 10
[DeviceA-mst-region] instance 2 vlan 11
# Activate the MST region configuration.
[DeviceA-mst-region] active region-configuration
[DeviceA-mst-region] quit
7. Configure smart link group 1:
# Create smart link group 1 and configure the VLAN mapped to MSTI 1, VLAN 10, as the protected VLAN.
[DeviceA] smart-link group 1
[DeviceA-smlk-group1] protected-vlan reference-instance 1
# Configure HundredGigE 1/0/1 as the primary port and HundredGigE 1/0/2 as the secondary port.
[DeviceA-smlk-group1] port hundredgige 1/0/1 primary
[DeviceA-smlk-group1] port hundredgige 1/0/2 secondary
# Enable flush message sending, and configure VLAN 10 as the transmit control VLAN.
[DeviceA-smlk-group1] flush enable control-vlan 10
# Enable role preemption and set the preemption delay to 10 seconds.
[DeviceA-smlk-group1] preemption mode role
[DeviceA-smlk-group1] preemption delay 10
[DeviceA-smlk-group1] quit
8. Configure smart link group 2:
# Create smart link group 2 and configure the VLAN mapped to MSTI 2, VLAN 11, as the protected VLAN.
[DeviceA] smart-link group 2
[DeviceA-smlk-group2] protected-vlan reference-instance 2
# Configure HundredGigE 1/0/2 as the primary port and HundredGigE 1/0/1 as the secondary port.
[DeviceA-smlk-group2] port hundredgige 1/0/2 primary
[DeviceA-smlk-group2] port hundredgige 1/0/1 secondary
# Enable flush message sending, and configure VLAN 11 as the transmit control VLAN.
[DeviceA-smlk-group2] flush enable control-vlan 11
[DeviceA-smlk-group2] preemption mode role
[DeviceA-smlk-group2] preemption delay 10
[DeviceA-smlk-group2] quit
9. Bring up HundredGigE 1/0/1 and HundredGigE 1/0/2:
[DeviceA-HundredGigE1/0/1] undo shutdown
[DeviceA-HundredGigE1/0/2] undo shutdown
Configuring Device B
[DeviceB] vlan 10 to 11
[DeviceB] interface hundredgige 1/0/1
[DeviceB-HundredGigE1/0/1] port link-type trunk
[DeviceB-HundredGigE1/0/1] port trunk permit vlan 10 11
[DeviceB-HundredGigE1/0/1] undo port trunk permit vlan 1
[DeviceB-HundredGigE1/0/1] undo stp enable
# Enable flush message receiving and configure VLAN 10 and VLAN 11 as the receive control VLANs on the port.
[DeviceB-HundredGigE1/0/1] smart-link flush enable control-vlan 10 11
[DeviceB-HundredGigE1/0/1] undo shutdown
[DeviceB-HundredGigE1/0/1] quit
3. Configure HundredGigE 1/0/2:
# Configure HundredGigE 1/0/2 as a trunk port.
[DeviceB] interface hundredgige 1/0/2
[DeviceB-HundredGigE1/0/2] port link-type trunk
[DeviceB-HundredGigE1/0/2] port trunk permit vlan 10 11
[DeviceB-HundredGigE1/0/2] undo port trunk permit vlan 1
[DeviceB-HundredGigE1/0/2] smart-link flush enable control-vlan 10 11
[DeviceB-HundredGigE1/0/2] undo shutdown
[DeviceB-HundredGigE1/0/2] quit
Configuring Device C
<DeviceC> system-view
[DeviceC] vlan 10 to 11
[DeviceC] interface hundredgige 1/0/1
[DeviceC-HundredGigE1/0/1] port link-type trunk
[DeviceC-HundredGigE1/0/1] port trunk permit vlan 10 11
[DeviceC-HundredGigE1/0/1] undo port trunk permit vlan 1
[DeviceC-HundredGigE1/0/1] undo stp enable
[DeviceC-HundredGigE1/0/1] smart-link flush enable control-vlan 10 11
[DeviceC-HundredGigE1/0/1] undo shutdown
[DeviceC-HundredGigE1/0/1] quit
[DeviceC] interface hundredgige 1/0/2
[DeviceC-HundredGigE1/0/2] port link-type trunk
[DeviceC-HundredGigE1/0/2] port trunk permit vlan 10 11
[DeviceC-HundredGigE1/0/2] undo port trunk permit vlan 1
[DeviceC-HundredGigE1/0/2] smart-link flush enable control-vlan 10 11
[DeviceC-HundredGigE1/0/2] undo shutdown
[DeviceC-HundredGigE1/0/2] quit
Configuring Device D
<DeviceD> system-view
[DeviceD] vlan 10 to 11
[DeviceD] interface hundredgige 1/0/1
[DeviceD-HundredGigE1/0/1] port link-type trunk
[DeviceD-HundredGigE1/0/1] port trunk permit vlan 10 11
[DeviceD-HundredGigE1/0/1] undo port trunk permit vlan 1
[DeviceD-HundredGigE1/0/1] smart-link flush enable control-vlan 10 11
[DeviceD-HundredGigE1/0/1] undo shutdown
[DeviceD-HundredGigE1/0/1] quit
[DeviceD] interface hundredgige 1/0/2
[DeviceD-HundredGigE1/0/2] port link-type trunk
[DeviceD-HundredGigE1/0/2] port trunk permit vlan 10 11
[DeviceD-HundredGigE1/0/2] undo port trunk permit vlan 1
[DeviceD-HundredGigE1/0/2] smart-link flush enable control-vlan 10 11
[DeviceD-HundredGigE1/0/2] undo shutdown
[DeviceD-HundredGigE1/0/2] quit
# Configure HundredGigE 1/0/3 as a trunk port
[DeviceD] interface hundredgige 1/0/3
[DeviceD-HundredGigE1/0/3] port link-type trunk
[DeviceD-HundredGigE1/0/3] port trunk permit vlan 10 11
[DeviceD-HundredGigE1/0/3] undo port trunk permit vlan 1
[DeviceD-HundredGigE1/0/3] undo shutdown
[DeviceD-HundredGigE1/0/3] quit
1. Verify the smart link group configuration when Device A is operating correctly:
# Display information about all smart link groups on Device A.
[DeviceA] display smart-link group all
Smart link group 1 information:
Device ID : 0000-fc00-2500
Preemption mode : Role
Preemption delay: 10(s)
Control VLAN : 10
Protected VLAN : Reference Instance 1
Member Role State Flush-count Last-flush-time
HGE1/0/1 PRIMARY ACTIVE 0 NA
HGE1/0/2 SECONDARY STANDBY 2 16:22:40 2014/12/29
Smart link group 2 information:
Control VLAN : 11
Protected VLAN : Reference Instance 2
HGE1/0/2 PRIMARY ACTIVE 2 16:22:40 2014/12/29
HGE1/0/1 SECONDARY STANDBY 0 NA
¡ In smart link group 1, the primary port HundredGigE 1/0/1 is active to transmit traffic from VLAN 10.
¡ In smart link group 2, the primary port HundredGigE 1/0/2 is active to transmit traffic from VLAN 11.
2. Verify the smart link group configuration when HundredGigE 1/0/1 on Device A is down:
Control VLAN : 10
HGE1/0/1 PRIMARY DOWN 0 NA
HGE1/0/2 SECONDARY ACTIVE 3 16:43:06 2014/12/29
Control VLAN : 11
HGE1/0/1 SECONDARY DOWN 0 NA
¡ In smart link group 1, the secondary port HundredGigE 1/0/2 is active to transmit traffic from VLAN 10.
¡ In smart link group 2, the primary port HundredGigE 1/0/2 remains active to transmit traffic from VLAN 11.
# Display information about the received flush messages on Device B.
[DeviceB] display smart-link flush
Received flush packets : 1
Receiving interface of the last flush packet : HundredGigE1/0/2
Receiving time of the last flush packet : 16:43:08 2014/10/29
Device ID of the last flush packet : 0000-fc00-2500
Control VLAN of the last flush packet : 10
Configuration files
· Device A:
vlan 1
vlan 10 to 11
instance 1 vlan 10
instance 2 vlan 11
smart-link group 1
preemption delay 10
smart-link group 2
preemption delay 10
interface HundredGigE1/0/1
port link-mode bridge
port trunk permit vlan 10 to 11
undo stp enable
port smart-link group 1 primary
port smart-link group 2 secondary
interface HundredGigE1/0/2
undo stp enable
port smart-link group 1 secondary
port smart-link group 2 primary
interface HundredGigE1/0/3
port access vlan 10
interface HundredGigE1/0/4
port access vlan 11
· Device B:
vlan 1
vlan 10 to 11
undo stp enable
smart-link flush enable control-vlan 10 to 11
· Device C:
vlan 1
vlan 10 to 11
undo stp enable
· Device D:
vlan 1
vlan 10 to 11
As shown in Figure 2, VLAN 10 and VLAN 11 are assigned to Zone A and Zone B, respectively. Traffic of VLAN 10 is dually uplinked from Device A to Device E by Device C and Device D. Traffic of VLAN 11 is dually uplinked from Device B to Device E by Device C and Device D. Configure Smart Link and Monitor Link to meet the following requirements:
· When the link between Device A and Device C and the link between Device A and Device D are both available, the traffic of Zone A is forwarded trough the link between Device A and Device C. When the link between Device A and Device C fails, the traffic is switched to the link between Device A and Device D. When the link between Device A and Device C recovers, the traffic switches back to the link.
· When the link between Device B and Device C and the link between Device B and Device D are both available, the traffic of Zone B is forwarded trough the link between Device B and Device D. When the link between Device B and Device D fails, the traffic is switched to the link between Device B and Device C. When the link between Device B and Device D recovers, the traffic switches back to the link.
· Configure Monitor Link on Device C and Device D to associate the state of downlink interfaces with the state of uplink interfaces. When Monitor link shuts down the downlink interfaces because of an uplink failure, Smart Link triggers a link switchover.
Device |
VLAN |
Device |
VLAN |
Device A |
HGE1/0/1 |
10 |
Device D |
HGE1/0/1 |
11 |
HGE1/0/2 |
10 |
HGE1/0/2 |
10, 11 |
HGE1/0/3 |
10 |
HGE1/0/3 |
10 |
Device B |
HGE1/0/1 |
11 |
Device E |
HGE1/0/1 |
10, 11 |
HGE1/0/2 |
11 |
HGE1/0/2 |
10, 11 |
HGE1/0/3 |
11 |
HGE1/0/3 |
10, 11 |
Device C |
HGE1/0/1 |
10 |
HGE1/0/2 |
10, 11 |
HGE1/0/3 |
11 |
Analysis
To implement dual uplink backup on Device A and Device B, perform the following tasks:
· Create a smart link group on Device A and Device B, respectively.
· Configure the VLANs of Zone A and Zone B as the protected VLANs of the corresponding smart link groups.
For the upstream device to refresh MAC address forwarding entries and ARP/ND entries when link switchover occurs in a smart link group, perform the following tasks:
· Enable flush message sending on Device A and Device B.
· Enable flush message receiving on the downlink ports on Device C and Device D.
Hardware |
Software version |
S9820-64H switch |
S9820-8C switch |
When you configure Smart Link and Monitor Link collaboration, follow these restrictions and guidelines:
· You can assign a port to only one monitor link group.
· Do not use the shutdown command or the undo shutdown command to change the state of the downlink interfaces in a monitor link group.
Procedures
# Assign the port to VLAN 10.
5. Configure VLAN-to-MSTI mappings and activate the MST region configuration:
# Map VLAN 10 to MSTI 1.
6. Configure smart link group 1:
7. Bring up HundredGigE 1/0/1 and HundredGigE 1/0/2:
[DeviceB-HundredGigE1/0/1] shutdown
# Assign the port to VLAN 11.
[DeviceB-HundredGigE1/0/1] port trunk permit vlan 11
[DeviceB-HundredGigE1/0/2] shutdown
[DeviceB-HundredGigE1/0/2] port trunk permit vlan 11
[DeviceB-HundredGigE1/0/2] undo stp enable
# Configure HundredGigE 1/0/3 as an access port and assign the port to VLAN 11.
[DeviceB] interface hundredgige 1/0/3
[DeviceB-HundredGigE1/0/3] port access vlan 11
[DeviceB-HundredGigE1/0/3] undo shutdown
[DeviceB-HundredGigE1/0/3] quit
[DeviceB] stp region-configuration
# Map VLAN 11 to MSTI 1.
[DeviceB-mst-region] instance 1 vlan 11
[DeviceB-mst-region] active region-configuration
[DeviceB-mst-region] quit
6. Configure smart link group 1.
# Create smart link group 1 and configure the VLAN mapped to MSTI 1, VLAN 11, as the protected VLAN.
[DeviceB] smart-link group 1
[DeviceB-smlk-group1] protected-vlan reference-instance 1
[DeviceB-smlk-group1] port hundredgige 1/0/1 primary
[DeviceB-smlk-group1] port hundredgige 1/0/2 secondary
[DeviceA-smlk-group1] flush enable control-vlan 11
[DeviceB-smlk-group1] preemption mode role
[DeviceB-smlk-group1] preemption delay 10
[DeviceB-smlk-group1] quit
# Enable flush message receiving and configure VLAN 10 as the receive control VLAN on the port.
# Configure HundredGigE 1/0/3 as a trunk port.
[DeviceC] interface hundredgige 1/0/3
[DeviceC-HundredGigE1/0/3] port link-type trunk
[DeviceC-HundredGigE1/0/3] port trunk permit vlan 11
[DeviceC-HundredGigE1/0/3] undo port trunk permit vlan 1
[DeviceC-HundredGigE1/0/3] undo stp enable
# Enable flush message receiving and configure VLAN 11 as the receive control VLAN on the port.
[DeviceC-HundredGigE1/0/3] smart-link flush enable control-vlan 11
5. Configure monitor link group 1:
# Create monitor link group 1.
[DeviceC] monitor-link group 1
# Configure the uplink interface threshold for triggering monitor link group state switchover as 1.
[DeviceC-mtlk-group1] uplink up-port-threshold 1
# Configure HundredGigE 1/0/2 as the uplink port and HundredGigE 1/0/1 and HundredGigE 1/0/3 as the downlink ports.
[DeviceC-mtlk-group1] port hundredgige 1/0/2 uplink
[DeviceC-mtlk-group1] port hundredgige 1/0/1 downlink
[DeviceC-mtlk-group1] port hundredgige 1/0/3 downlink
[DeviceC-mtlk-group1] quit
[DeviceD-HundredGigE1/0/1] port trunk permit vlan 11
[DeviceD-HundredGigE1/0/1] undo stp enable
[DeviceD-HundredGigE1/0/1] smart-link flush enable control-vlan 11
[DeviceD-HundredGigE1/0/3] undo stp enable
[DeviceD-HundredGigE1/0/3] smart-link flush enable control-vlan 10
[DeviceD] monitor-link group 1
[DeviceD-mtlk-group1] uplink up-port-threshold 1
[DeviceD-mtlk-group1] port hundredgige 1/0/2 uplink
[DeviceD-mtlk-group1] port hundredgige 1/0/1 downlink
[DeviceD-mtlk-group1] port hundredgige 1/0/3 downlink
[DeviceD-mtlk-group1] quit
Configuring Device E
<DeviceE> system-view
[DeviceE] vlan 10 to 11
[DeviceE] interface hundredgige 1/0/1
[DeviceE-HundredGigE1/0/1] port link-type trunk
[DeviceE-HundredGigE1/0/1] port trunk permit vlan 10 11
[DeviceE-HundredGigE1/0/1] undo port trunk permit vlan 1
[DeviceE-HundredGigE1/0/1] smart-link flush enable control-vlan 10 11
[DeviceE-HundredGigE1/0/1] undo shutdown
[DeviceE-HundredGigE1/0/1] quit
[DeviceE] interface hundredgige 1/0/2
[DeviceE-HundredGigE1/0/2] port link-type trunk
[DeviceE-HundredGigE1/0/2] port trunk permit vlan 10 11
[DeviceE-HundredGigE1/0/2] undo port trunk permit vlan 1
[DeviceE-HundredGigE1/0/2] smart-link flush enable control-vlan 10 11
[DeviceE-HundredGigE1/0/2] undo shutdown
[DeviceE-HundredGigE1/0/2] quit
[DeviceE] interface hundredgige 1/0/3
[DeviceE-HundredGigE1/0/3] port link-type trunk
[DeviceE-HundredGigE1/0/3] port trunk permit vlan 10 11
[DeviceE-HundredGigE1/0/3] undo port trunk permit vlan 1
[DeviceE-HundredGigE1/0/3] undo shutdown
[DeviceE-HundredGigE1/0/3] quit
1. Verify the smart link group configuration when Device A and Device B are operating correctly:
Control VLAN : 10
HGE1/0/1 PRIMARY ACTIVE 1 17:37:49 2014/12/29
HGE1/0/2 SECONDARY STANDBY 3 17:43:06 2014/12/29
The output shows that in smart link group 1, the primary port HundredGigE 1/0/1 is active to transmit traffic from VLAN 10.
# Display information about all smart link groups on Device B.
[DeviceB] display smart-link group all
Device ID : 0000-fc01-2501
Control VLAN : 11
HGE1/0/1 PRIMARY ACTIVE 2 17:22:40 2014/12/29
HGE1/0/2 SECONDARY STANDBY 0 NA
The output shows that in smart link group 1, the primary port HundredGigE 1/0/1 is active to transmit traffic from VLAN 11.
2. Verify the monitor link group configuration when Device C and Device D are operating correctly:
# Display information about all monitor link groups on Device C.
[DeviceC] display monitor-link group all
Monitor link group 1 information:
Group status : UP
Downlink up-delay: 0(s)
Last-up-time : 17:07:26 2014/12/29
Last-down-time : -
Up-port-threshold: 1
Member Role Status
HGE1/0/2 UPLINK UP
HGE1/0/1 DOWNLINK UP
HGE1/0/3 DOWNLINK UP
The output shows that in monitor link group 1, the uplink port HundredGigE 1/0/2 is up, and the downlink ports HundredGigE 1/0/1 and HundredGigE 1/0/3 are up.
# Display information about all monitor link groups on Device D.
[DeviceD] display monitor-link group all
Group status : UP
Last-up-time : 17:09:33 2014/12/29
Last-down-time : -
Member Role Status
HGE1/0/2 UPLINK UP
3. Verify the smart link group configuration when HundredGigE 1/0/1 on Device A is down:
Control VLAN : 10
HGE1/0/1 PRIMARY DOWN 1 17:37:49 2014/12/29
HGE1/0/2 SECONDARY ACTIVE 4 17:49:06 2014/12/29
The output shows that in smart link group 1, the secondary port HundredGigE 1/0/2 is active to transmit traffic from VLAN 10.
# Display information about the received flush messages on Device C.
[DeviceC] display smart-link flush
Receiving time of the last flush packet : 17:49:08 2014/12/29
4. Verify the monitor link group configuration when the uplink port HundredGigE 1/0/2 on Device C is down:
Group status : DOWN
Last-down-time : 18:01:05 2014/12/29
Member Role Status
HGE1/0/2 UPLINK DOWN
HGE1/0/1 DOWNLINK DOWN
HGE1/0/3 DOWNLINK DOWN
The output shows that monitor link group 1 is down, and the downlink ports HundredGigE 1/0/1 and HundredGigE 1/0/3 in monitor link group 1 are down.
Group status : UP
Last-down-time : -
Member Role Status
HGE1/0/2 UPLINK UP
The output shows that monitor link group 1 is up, and the downlink ports HundredGigE 1/0/1 and HundredGigE 1/0/3 in monitor link group 1 are up.
Control VLAN : 10
HGE1/0/1 PRIMARY DOWN 2 17:57:49 2014/12/29
HGE1/0/2 SECONDARY ACTIVE 5 18:01:06 2014/12/29
The output shows that HundredGigE 1/0/1 on Device A is down. In smart link group 1, the secondary port HundredGigE 1/0/2 becomes active to transmit traffic from VLAN 10.
Configuration files
· Device A:
vlan 1
vlan 10
instance 1 vlan 10
smart-link group 1
preemption delay 10
undo stp enable
undo stp enable
port access vlan 10
· Device B:
vlan 1
vlan 11
instance 1 vlan 11
smart-link group 1
preemption delay 10
undo stp enable
undo stp enable
port access vlan 11
· Device C:
vlan 1
vlan 10 to 11
undo stp enable
port monitor-link group 1 downlink
port monitor-link group 1 uplink
undo stp enable
· Device D:
vlan 1
vlan 10 to 11
undo stp enable
undo stp enable
· Device E:
vlan 1
vlan 10 to 11
As shown in Figure 3, the Finance department in VLAN 10 and the Marketing department in VLAN 11 are connected to Device A and Device B, respectively. Device A and Device B form an IRF fabric and are connected to Device C and Device D.
· When the uplinks of Device A and Device B are available, traffic is forwarded through the link between Device A and Device C.
· When the link between Device A and Device C fails, the traffic switches to another link.
· When the link recovers, the traffic is switched back to the link.
Device |
VLAN |
Device |
Device |
Device A |
HGE1/0/1 |
10, 11 |
Device B |
HGE2/0/1 |
10, 11 |
HGE1/0/3 |
10 |
HGE2/0/3 |
11 |
Device C |
HGE1/0/1 |
10, 11 |
Device D |
HGE1/0/1 |
10, 11 |
HGE1/0/2 |
10, 11 |
HGE1/0/2 |
10, 11 |
Analysis
To implement dual uplink redundancy on Device A and Device B, configure a smart link group for the IRF fabric formed by Device A and Device B.
· Enable flush message receiving on HundredGigE 1/0/1 on Device C and Device D.
Hardware |
Software version |
S9820-64H switch |
S9820-8C switch |
Not supported |
When you configure Smart Link in an IRF fabric, follow these restrictions and guidelines:
· Before you configure a smart link member port or its directly connected port, disable the spanning tree feature and RRPP on the port.
· For the restrictions and guidelines for configuring IRF, see the virtual technologies configuration guide.
Procedures
Setting up an IRF fabric
# Bind HundredGigE 1/0/2 to IRF port 1/2 and save the configuration.
[DeviceA] irf-port 1/2
[DeviceA-irf-port1/2] port group interface hundredgige 1/0/2
[DeviceA-irf-port1/2] quit
[DeviceA] save
# Activate the IRF port.
[DeviceA] irf-port-configuration active
# Assign IRF member ID 2 to Device B and reboot the device.
[DeviceB] irf member 1 renumber 2
Warning: Renumbering the member ID may result in configuration change or loss. Continue? [Y/N]:y
[DeviceB] quit
<DeviceB> reboot
# After you connect the ports as shown in Figure 3, log in to the device again. Bind HundredGigE 2/0/2 to IRF port 2/1 and save the configuration.
[DeviceB] interface hundredgige 2/0/2
[DeviceB-HundredGigE2/0/2] shutdown
[DeviceB-HundredGigE2/0/2] quit
[DeviceB] irf-port 2/1
[DeviceB-irf-port2/1] port group interface hundredgige 2/0/2
[DeviceB-irf-port2/1] quit
[DeviceB-HundredGigE2/0/2] undo shutdown
[DeviceB] save
[DeviceB] irf-port-configuration active
Device A and Device B start a master election. When the master (Device A in this example) is elected, the other device reboots. An IRF fabric is formed after the reboot.
3. Configure HundredGigE 2/0/1 in the same way HundredGigE 1/0/1 is configured.
[DeviceA] interface hundredgige 2/0/1
[DeviceA-HundredGigE2/0/1] shutdown
[DeviceA-HundredGigE2/0/1] port link-type trunk
[DeviceA-HundredGigE2/0/1] port trunk permit vlan 10 11
[DeviceA-HundredGigE2/0/1] undo port trunk permit vlan 1
[DeviceA-HundredGigE2/0/1] undo stp enable
[DeviceA-HundredGigE2/0/1] quit
5. Configure HundredGigE 2/0/3:
# Configure HundredGigE 2/0/3 as an access port and assign the port to VLAN 11.
[DeviceA] interface hundredgige 2/0/3
[DeviceA-HundredGigE2/0/3] port access vlan 11
[DeviceA-HundredGigE2/0/3] undo shutdown
[DeviceA-HundredGigE2/0/3] quit
6. Configure VLAN-to-MSTI mappings and activate the MST region configuration::
# Map VLAN 10 and VLAN 11 to MSTI 1.
[DeviceA-mst-region] instance 1 vlan 10 11
# Create smart link group 1 and configure the VLANs mapped to MSTI 1, VLAN 10 and VLAN 11, as the protected VLANs.
# Configure HundredGigE 1/0/1 as the primary port and HundredGigE 2/0/1 as the secondary port.
[DeviceA-smlk-group1] port hundredgige 2/0/1 secondary
8. Bring up HundredGigE 1/0/1 and HundredGigE 2/0/1:
[DeviceA-HundredGigE2/0/1] undo shutdown
# Enable flush message receiving, and configure VLAN 10 and VLAN 11 as the receive control VLANs on the port.
1. Verify the IRF fabric configuration after you complete the configuration:
# Display IRF fabric information on Device A.
<Sysname> display irf
MemberID Role Priority CPU-Mac Description
*+1 Master 1 0210-fc01-0001 -----
2 Standby 1 0210-fc02-0002 -----
The Bridge MAC of the IRF is: 00e0-fc00-1000
Auto upgrade : yes
Mac persistent : 6 min
Domain ID : 0
IRF mode : normal
The output shows that an IRF fabric has been established successfully.
2. Verify the smart link group configuration when Device A is operating correctly:
Device ID : 00e0-fc00-c518
Control VLAN : 10
HGE1/0/1 PRIMARY ACTIVE 3 18:16:44 2014/12/29
HGE2/0/1 SECONDARY STANDBY 0 NA
The output shows that in smart link group 1, the primary port HundredGigE 1/0/1 is active to transmit traffic from VLAN 10 and VLAN 11.
3. Verify the smart link group configuration when HundredGigE 1/0/1 on Device A is down.
Control VLAN : 10
HGE1/0/1 PRIMARY DOWN 3 18:16:44 2014/12/29
HGE2/0/1 SECONDARY ACTIVE 1 18:22:37 2014/12/29
The output shows that in smart link group 1, the secondary port HundredGigE 2/0/1 is active to transmit traffic for VLAN 10 and VLAN 11.
Receiving interface of the last flush packet : HundredGigE1/0/3
Receiving time of the last flush packet : 18:22:39 2014/12/29
Device ID of the last flush packet : 00e0-fc00-c518
# Display information about the received flush messages on Device D.
[DeviceD] display smart-link flush
Receiving interface of the last flush packet : HundredGigE1/0/1
Receiving time of the last flush packet : 18:22:38 2014/12/29
Configuration files
· Device A:
sysname DeviceA
vlan 10 to 11
irf mac-address persistent always
irf auto-update enable
undo irf link-delay
irf member 1 priority 1
irf member 2 priority 1
irf-port 1/2
port group 1 interface HundredGigE1/0/2
irf-port 2/1
port group 1 interface HundredGigE2/0/2
instance 1 vlan 10 to 11
smart-link group 1
preemption delay 10
undo stp enable
port access vlan 10
interface HundredGigE2/0/1
undo stp enable
interface HundredGigE2/0/3
port access vlan 11
· Device C:
sysname DeviceC
vlan 10 to 11
undo stp enable
· Device D:
sysname DeviceD
vlan 10 to 11
undo stp enable
Related documentation
Use this document in conjunction with the following documents for the product and software version you are working with:
· Layer 2—LAN Switching Command Reference
· Layer 2—LAN Switching Configuration Guide
· High Availability Command Reference
· High Availability Configuration Guide
· Virtual Technologies Command Reference
· Virtual Technologies Configuration Guide
