18-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath F1000[F5000] Firewalls Series Configuration Guides(V7)-6W90018-Network Management and Monitoring Command Reference
01-Information center commands
01-Information center commands 402.22 KB
Information center commands· 1
check logfile· 1
check logfile· 1
diagnostic-logfile save· 2
display character-set 3
display diagnostic-logfile summary· 4
display info-center 5
display info-center file-server 5
display info-center filter 7
display info-center source· 8
display logbuffer 9
display logbuffer summary· 11
display logfile summary· 12
display security-logfile summary· 13
enable log updown· 14
info-center diagnostic-logfile directory· 14
info-center diagnostic-logfile enable· 15
info-center diagnostic-logfile frequency· 16
info-center diagnostic-logfile quota· 16
info-center enable· 17
info-center file-server transport-type· 18
info-center file-server user 19
info-center filter 20
info-center format 21
info-center logbuffer 22
info-center logbuffer reserved-size· 23
info-center logbuffer size· 24
info-center logfile directory· 25
info-center logfile enable· 25
info-center logfile frequency· 26
info-center logfile module alarm-threshold· 27
info-center logfile size-quota· 28
info-center logging suppress duplicates· 28
info-center logging suppress module· 29
info-center loghost 30
info-center loghost locate-info with-sn· 32
info-center loghost source· 32
info-center loghost vsys-to-admin enable· 33
info-center security-logfile alarm-threshold· 34
info-center security-logfile directory· 35
info-center security-logfile enable· 35
info-center security-logfile frequency· 36
info-center security-logfile size-quota· 36
info-center source· 37
info-center synchronous· 39
info-center syslog min-age (for multi-logfile devices) 40
info-center syslog min-age (for single-logfile devices) 40
info-center syslog trap buffersize· 41
info-center syslog utf-8 enable· 42
info-center timestamp· 42
info-center timestamp loghost 43
info-center trace-logfile quota· 44
logfile save· 45
reset logbuffer 45
security syslog rate-limit 46
security-logfile save· 47
snmp-agent trap enable syslog· 48
terminal debugging· 49
terminal logging level 50
terminal monitor 50
The supported storage devices vary by device model. This document assumes that the device uses the flash memory.
Non-default vSystems do not support some of the information center commands. For information about vSystem support for a command, see the usage guidelines on that command. For information about vSystem, see Virtual Technologies Configuration Guide.
check logfile
Use check logfile to perform integrity check for a log file.
check logfile file-path
context-admin
file-path: Specifies the absolute path of the log file. For successful execution of this command, the file extension must be .log or .log.gz.
Non-default vSystems do not support this command.
When the information center saves a log message to the log file, it uses the default device master key to calculate a digest for the log file and saves the digest in the log file. The digest is used to perform integrity check for the log file.
When this command is executed, the information center uses the master key to recalculate a digest for the log file and then compares the digest with that saved in the log file. If the two digests are consistent, the log file passes the integrity check. If they do not match, the log file fails the integrity check.
# Perform integrity check for log file flash:/logfile/logfile.log.
<Sysname> check logfile flash:/logfile/logfile.log
The integrity check for the logfile succeeded.
check logfile
context-admin
When the information center saves a log message to the log file, it uses the device master key to calculate a digest for the log file and saves the digest in the log file. The digest is used to perform integrity check for the log file. You can use the default device master key or a master key configured by using the set master-key command. For more information about the master key, see public key management in Security Configuration Guide.
set master-key (Security Command Reference)
Use diagnostic-logfile save to manually save diagnostic logs from the diagnostic log file buffer to the diagnostic log file.
context-admin
You can specify the directory to save the diagnostic log file by using the info-center diagnostic-logfile directory command.
The system clears the diagnostic log file buffer after saving the buffered diagnostic logs to the diagnostic log file.
If the diagnostic log file buffer is empty, this command displays a success message event though no logs are saved to the diagnostic log file.
# Manually save diagnostic logs from the diagnostic log file buffer to the diagnostic log file.
<Sysname> diagnostic-logfile save
The contents in the diagnostic log file buffer have been saved to the file flash:/diagfile/diagfile.log.
Use display character-set to display the character set encoding used on the device or the login terminal.
display character-set [ terminal ]
context-admin
context-operator
terminal: Displays the character set encoding used on the login terminal. If you do not specify this keyword, this command displays the character set encoding used on the device. By default, the device uses the GB18030 encoding and the encoding cannot be changed.
For the user' login terminal to correctly display Chinese characters in log messages received from the device, the device and the terminal must use the same character set encoding.
Use the display character-set terminal command to identify the character set encoding used on the login terminal. The device will send test characters in both UTF-8 and GB18030 encodings to the terminal. The test characters will be displayed as 中文 for the character set encoding used on the terminal.
# Display the character set encoding used on the device.
[Sysname] display character-set
Current character set encoding: GB18030
# Display the character set encoding used on the login terminal.
[Sysname] display character-set terminal
Character set           Test characters
UTF-8                   涓枃
GB18030                 中文
Character set encoding used on the device.
Character set
Character set encoding used by the device to send test strings to the terminal. Options are UTF-8 and GB18030.
Test characters
Parsing result of the test characters.
The test characters will be displayed as 中文 for the character set encoding used on the login terminal.
Use display diagnostic-logfile summary to display the diagnostic log file configuration.
context-admin
context-operator
# Display the diagnostic log file configuration.
<Sysname> display diagnostic-logfile summary
  Diagnostic log file: Enabled.
  Diagnostic log file size quota: 10 MB
  Diagnostic log file directory: flash:/diagfile
  Writing frequency: 24 hour 0 min 0 sec
Diagnostic log file
Status of the diagnostic log file:
·     Enabled—Diagnostic logs can be output to the diagnostic log file.
·     Disabled—Diagnostic logs cannot be output to the diagnostic log file.
Maximum size for the diagnostic log file, in MB.
Log file directory
Directory where the diagnostic log file is saved.
Writing frequency
Interval at which the system saves diagnostic logs from the buffer to the diagnostic log file.
display info-center
Use display info-center to display information center configuration.
display info-center
context-admin
context-operator
# Display information center configuration.
<Sysname> display info-center
Information Center: Enabled
Console: Enabled
Monitor: Enabled
Log host: Enabled
    192.168.0.1, log output filter: loghost1
    port number: 5000, host facility: local7
Log buffer: Enabled
    Max buffer size 1024, current buffer size 512,
    Current messages 0, dropped messages 0, overwritten messages 0
Log file: Enabled
Security log file: Enabled
Information timestamp format:
    Log host: Date
    Other output destination: Date
Use display info-center file-server to display the configuration of the remote server and the backup records.
context-admin
context-operator
When the local device performs a log file backup to the remote server, it records relevant information for this backup operation. The device supports saving a maximum of 10 backup records.
You can use this command to view information about backup operations, including the backup execution time and result.
# Display the configuration of the remote server and the backup records.
<Sysname> display info-center file-server
Username: test
Protocol: tcp
IP: 1.1.1.1
Port: 22
VPN: vpnname
Directory: /backup
Filename prefix: my_backup
File type: logfile, security-logfile
Backup records:
 No. TimeStamp                FileName
 1   Wed Jan 15 14:20:18 2022 my_backup_20220115142018.log
!2   Wed Jan 15 14:33:10 2022 my_backup_20220115143310.log
 3   Wed Jan 15 14:49:37 2022 my_backup_20220115144937.log
The exclamation mark (!) indicates that the backup attempt failed.
Username
Username for logging in to the remote server. This field displays N/A if the username is not configured.
To back up log files through FTP or SCP, you must configure the login username and password.
Protocol
Protocol used in backing up log files.
IP
IP address of the remote server.
Port
Port number of the remote server.
VPN
VPN to which the remote server belongs.
Directory
Log file storage directory on the remote server.
Filename prefix
Filename prefix used in saving log files to the remote server.
Backup records
Records of log file backups, including the following information:
·     No.—Sequence number of the backup operation.
·     TimeStamp—System time when the device started backing up log files.
·     FileName—Filename used in saving log files on the remote server.
The name consists of the filename prefix (displayed in the Filename prefix field) and the timestamp (based on the value displayed in the TimeStamp field).
Use display info-center filter to display information about log output filters.
display info-center filter [ filtername ]
context-admin
context-operator
filter-name: Specifies an existing log output filter by its name. If you do not specify a log output filter, this command display information about all log output filters.
# Display information about log output filter loghost1.
<Sysname> display info-center filter loghost1
 Log output filter: loghost1
 Module                       Rule
 ARP                          Debugging
 CFGLOG                       Deny
 Default                      Informational
Log output filter:
Name of the log output filter.
Module
Module to which the log output filter applies.
Rule
Rules in the log output filter.
info-center filter
Use display info-center source to display the log output rules by source modules.
display info-center source [ module module-name ]
context-admin
context-operator
module module-name: Specifies a module. The module-name argument is a case insensitive string that represents the complete module name. To view the names of supported modules, execute the display info-center source module ? command. If you do not specify a module, this command displays the log output rules for all modules.
By default, the information center outputs logs of different modules according to the default log output rules (see Table 11). You can use the info-center source command to change the log output rules. The display info-center source command displays the current log output rules of log source modules.
# Display the current log output rules for all modules.
<Sysname> display info-center source
 Module   Console       Monitor       Loghost       Logbuffer     Logfile
 ACL      DEBUG         DEBUG         INFO          INFO          INFO
 ADJ4     DEBUG         DEBUG         INFO          INFO          INFO
 ADJ6     DEBUG         DEBUG         INFO          INFO          INFO
# Display the current log output rules for the EDEV module.
<Sysname> display info-center source module EDEV
 EDEV     DEBUG         DEBUG         INFO          INFO          INFO
Table 5 Command output
Module
Module name.
Console
Lowest level of logs that can be output to the console.
This field displays deny if no logs of the module can be output to the console.
Monitor
Lowest level of logs that can be output to the monitor terminal.
This field displays deny if no logs of the module can be output to the monitor terminal.
Loghost
Lowest level of logs that can be output to the log host.
This field displays deny if no logs of the module can be output to the log host.
Logbuffer
Lowest level of logs that can be output to the log buffer.
This field displays deny if no logs of the module can be output to the log buffer.
Logfile
Lowest level of logs that can be output to the log file.
This field displays deny if no logs of the module can be output to the log file.
info-center source
display logbuffer
Use display logbuffer to display log buffer information and buffered logs.
display logbuffer [ vsys vsys-name ] [ module module-name [ submodule submodule-name ] ] [ reverse ] [ level severity | size buffersize | slot slot-number ] * [ last-mins mins ]
context-admin
context-operator
vsys-admin
vsys-operator
vsys vsys-name: Displays information for the log buffer of a vSystem. The vsys-name argument is a case-sensitive string of 1 to 31 characters. Valid characters include English letters, digits, underscores (_), and hyphens (-). Non-default vSystems do not support this parameter.
module module-name: Displays information for the log buffer of a module. The module-name argument is a case-insensitive string that represents the complete module name. To view the names of supported modules, execute the display logbuffer module ? command. If you do not specify a module, this command displays the information for the general log buffer.
submodule submodule-name: Displays log buffer information for a submodule of the specified module. The submodule--name argument is a case-insensitive string that represents the complete submodule name. To view the names of supported submodules, execute the display logbuffer module module-name submodule ? command. If you do not specify a submodule, this command displays log buffer information for all submodules of the specified module.
reverse: Displays log entries chronologically, with the most recent entry at the top. If you do not specify this keyword, the command displays log entries chronologically, with the oldest entry at the top.
level severity: Specifies a severity level in the range of 0 to 7. If you do not specify a severity level, this command displays log information for all levels.
Table 6 Log levels
Severity value
Level
0
Emergency
The system is unusable. For example, the system authorization has expired.
1
Alert
Action must be taken immediately. For example, traffic on an interface exceeds the upper limit.
2
Critical
Critical condition. For example, the device temperature exceeds the upper limit, the power module fails, or the fan tray fails.
3
Error
Error condition. For example, the link state changes.
4
Warning
Warning condition. For example, an interface is disconnected, or the memory resources are used up.
5
Notification
Normal but significant condition. For example, a terminal logs in to the device, or the device reboots.
6
Informational
Informational message. For example, a command or a ping operation is executed.
7
Debugging
Debugging message.
size buffersize: Specifies the number of latest logs to be displayed. The value range is 1 to 1024. If you do not specify this option, the command displays all logs in the log buffer.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information for all member devices.
last-mins mins: Displays logs buffered over the last specified period of time. The mins argument specifies a time period in the range of 1 to 43200 minutes. If you do not specify a time period, the command displays all logs in the log buffer.
# Display log buffer information and buffered logs.
<Sysname> display logbuffer
Log buffer: Enabled
Max buffer size: 1024
Actual buffer size: 512
Dropped messages: 0
Overwritten messages: 718
Current messages: 512
Some messages might not be displayed due to permission issues.
%Jun 17 15:57:09:578 2017 Sysname SYSLOG/7/SYS_RESTART:System restarted --
# Display log buffer information and logs buffered over the last 5 minutes.
<Sysname> display logbuffer last-mins 5
Log buffer: Enabled
Dropped messages: 0
Overwritten messages: 0
Current messages: 191
%Jan  1 01:00:06:784 2018 Sysname SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=192.168.1.242-User=**; Command is display current-configuration
%Jan  1 01:03:19:691 2018 Sysname SHELL/5/SHELL_LOGIN: VTY logged in from 192.168.1.33.
%Jan  1 01:03:21:269 2018 Sysname SHELL/6/SHELL_CMD: -Line=vty1-IPAddr=192.168.1.33-User=**; Command is display logbuffer last-mins 5
Table 7 Command output
Log buffer
Status of the log buffer:
·     Enabled—Logs can be output to the log buffer.
·     Disabled—Logs cannot be output to the buffer.
Max buffer size
Maximum buffer size supported by the device.
Actual buffer size
Maximum buffer size configured by using the info-center logbuffer size command.
Dropped messages
Number of dropped messages.
Number of overwritten messages.
Current messages
Number of current messages.
Failed to obtain the specified data. The following tries to display all data in the log buffer.
Failed to obtain the specified data. The system tries to display all data in the log buffer.
The log information displayed by the display logbuffer command varies by user role. For information about user roles, see RBAC configuration in Fundamentals Configuration Guide.
reset logbuffer
Use display logbuffer summary to display the log buffer summary.
display logbuffer summary [ level severity | slot slot-number ] *
context-admin
context-operator
level severity: Specifies a severity level in the range of 0 to 7. If you do not specify a severity level, this command displays log information of all levels in the log buffer. For more information about log levels, see Table 6.
This command displays only the summary of the general log buffer.
# Display the summary of the log buffer.
<Sysname> display logbuffer summary
  Slot EMERG ALERT  CRIT ERROR  WARN NOTIF  INFO DEBUG
     1     0     0     0     7     0    34    38     0
Table 8 Command output
EMERG
Represents emergency. For more information, see Table 6.
ALERT
Represents alert. For more information, see Table 6.
CRIT
Represents critical. For more information, see Table 6.
ERROR
Represents error. For more information, see Table 6.
WARN
Represents warning. For more information, see Table 6.
NOTIF
Represents notification. For more information, see Table 6.
INFO
Represents informational. For more information, see Table 6.
DEBUG
Represents debug. For more information, see Table 6.
Use display logfile summary to display the log file configuration.
context-admin
context-operator
This command displays only the general log file configuration.
# Display the log file configuration.
<Sysname> display logfile summary
  Log file: Enabled.
  Log file size quota: 10 MB
  Log file directory: flash:/logfile
  Writing frequency: 24 hour 0 min 10 sec
Table 9 Command output
Log file
Log file status:
·     Enabled—Logs can be output to the log file.
·     Disabled—Logs cannot be output to the log file.
Log file size quota
Maximum log file size, in MB.
Log file directory
Log file directory.
Writing frequency
Log file writing frequency.
Use display security-logfile summary to display the summary of the security log file.
security-audit
To use this command, a local user must have the security-audit user role. For information about configuring the security-audit user role, see AAA commands in Security Command Reference.
# Display the summary of the security log file.
<Sysname> display security-logfile summary
  Security log file size quota: 10 MB
  Security log file directory: flash:/seclog
  Alarm threshold: 80%
  Current usage: 30%
Table 10 Command output
Security log file
Status of the security log file:
·     Enabled—Security logs can be output to the security log file.
·     Disabled—Security logs cannot be output to the security log file.
Maximum storage space reserved for the security log file.
Security log file directory.
Alarm-threshold
Alarm threshold of the security log file usage.
Current usage
Current usage of the security log file.
Writing frequency
Security log file writing frequency.
authorization-attribute (Security Command Reference)
enable log updown
Use enable log updown to enable an interface to generate link up or link down logs when the interface state changes.
Use undo enable log updown to disable an interface from generating link up or link down logs when the interface state changes.
enable log updown
All interfaces are allowed to generate link up and link down logs.
Interface view
context-admin
# Disable GigabitEthernet 1/0/1 from generating link up or link down logs.
[Sysname-GigabitEthernet1/0/1] undo enable log updown
Use info-center diagnostic-logfile directory to configure the directory to save the diagnostic log file.
The diagnostic log file is saved in the diagfile folder under the root directory of the default file system.
context-admin
dir-name: Specifies a directory by its name, a string of 1 to 64 characters.
The specified directory must have been created.
This command cannot survive an IRF reboot or a master/subordinate switchover.
# Set the diagnostic log file directory to flash:/test.
<Sysname> mkdir test
[Sysname] info-center diagnostic-logfile directory flash:/test
Use info-center diagnostic-logfile enable to enable saving of diagnostic logs to the diagnostic log file.
Use undo info-center diagnostic-logfile enable to disable saving of diagnostic logs to the diagnostic log file.
Saving of diagnostic logs to the diagnostic log file is enabled.
context-admin
This command enables saving diagnostic logs to the diagnostic log file for centralized management. You can view the diagnostic logs to monitor device activities and to troubleshoot problems.
# Enable saving diagnostic logs to the diagnostic log file.
[Sysname] info-center diagnostic-logfile enable
Use info-center diagnostic-logfile frequency to configure the interval at which the system saves diagnostic logs from the diagnostic log file buffer to the diagnostic log file.
Use undo info-center diagnostic-logfile frequency to restore the default.
The diagnostic log file saving interval is 86400 seconds.
context-admin
freq-sec: Specifies the diagnostic log file saving interval in seconds. The value range is 10 to 86400.
The system outputs diagnostic logs to the diagnostic log file buffer, and then saves the buffered logs to the diagnostic log file at the specified interval.
# Set the diagnostic log file saving interval to 600 seconds.
[Sysname] info-center diagnostic-logfile frequency 600
Use info-center diagnostic-logfile quota to set the maximum size for the diagnostic log file.
Use undo info-center diagnostic-logfile quota to restore the default.
The maximum size for the diagnostic log file is 10 MB.
context-admin
size: Specifies the maximum size for the diagnostic log file, in MB. The value range is 1 to 10.
# Set the maximum size to 6 MB for the diagnostic log file.
[Sysname] info-center diagnostic-logfile quota 6
info-center enable
Use info-center enable to enable the information center.
Use undo info-center enable to disable the information center.
info-center enable
The information center is enabled.
context-admin
# Enable the information center.
[Sysname] info-center enable
Use info-center file-server transport-type to back up log files to a remote server.
Use undo info-center file-server transport-type to restore the default.
info-center file-server transport-type { ftp | scp | tftp } { ipv4-address | ipv6 ipv6-address } [ port port-number ] [ vpn-instance vpn-instance-name ] [ directory directory ] filename-prefix filename-prefix [ file-type { logfile | security-logfile } ]
The device does not back up log files to a remote server.
context-admin
ftp: Uses FTP to back up log files to the remote server. The device acts as the FTP client. For more information about FTP, see FTP and TFTP configuration in Fundamentals Configuration Guide.
scp: Uses SCP to back up log files to the remote server. The SCP protocol is based on SSH2 and provides secure file copy function. The device acts as the SCP client. For more information about SCP, see SSH configuration in Security Configuration Guide.
tftp: Uses TFTP to back up log files to the remote server. The device acts as the TFTP client. For more information about TFTP, see FTP and TFTP configuration in Fundamentals Configuration Guide.
ipv4-address: Specifies a remote server by its IPv4 address. The address must be the same as that configured on the remote server.
ipv6 ipv6-address: Specifies a remote server by its IPv6 address. The address must be the same as that configured on the remote server.
port port-number: Specifies the listening port number of the remote server, in the range of 1 to 65535. The default is 21 for FTP, 22 for SCP, and 69 for TFTP. The port number must be the same as that configured on the remote server.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the log host is on the public network, do not specify this option.
directory directory: Specifies a log file storage directory on the remote server, a case-sensitive string of 1 to 63 characters. If you do not specify a directory, log files will be backed up to the working path of the remote server. You can use this option to specify a subdirectory under the working path of the remote server. For successful backup, make sure the subdirectory has been created on the remote server. Specify the relative path of the subdirectory for a TFTP or FTP server, and the absolute path of the subdirectory for an SCP server.
filename-prefix filename-prefix: Specifies a filename prefix used in saving log files to the remote server, a case-sensitive string of 1 to 30 characters. For example, you can use the device's IP address as the filename prefix to identify the device that generated the log files.
file-type { logfile | security-logfile }: Specifies the type of log files to back up. If you do not specify a log file type, all general log files and security log files under the corresponding directories will be backed up.
·     logfile: General log files under the directory specified by the info-center logfile directory command.
·     security-logfile: Security log files under the directory specified by the info-center security-logfile directory command.
You can use this command to back up general log files and/or security log files to a remote server through FTP, TFTP, or SCP, so as to enhance the log file security.
If the device supports only a single log file, the device will automatically back up the log file to the remote server every time logs are written into the log file.
If the device supports multiple log files, the device will automatically back up a log file to the remote server when a log file is full.
# Use FTP to back up general log files to the remote server at 1.1.1.1, and specify the port number and filename prefix as 8000 and 2-2-2-2, respectively.
[Sysname] info-center file-server transport-type ftp 1.1.1.1 port 8000 filename-prefix 2-2-2-2 file-type logfile
Use info-center file-server user to specify the username and password for logging in to the remote server to back up log files.
info-center file-server user user-name password { cipher | simple } password
undo info-center file-server user
The username and password for logging in to the remote server to back up log files are not specified.
context-admin
user-name: Specifies a username for logging in to the remote server.
password { cipher | simple } password: Specifies a password for logging in to the remote server, case sensitive.
·     cipher: Specifies a password in encrypted form, a string of 33 to 117 characters.
·     simple: Specifies a password in plaintext form, a string of 1 to 63 characters. For security purposes, the password specified in plaintext form will be stored in encrypted form.
Before backing up log files to a FTP or SCP remote server, use this command to specify the username and password for logging in to the remote server. The username and password configured in this command must be the same as those configured on the remote server.
# Specify the username and password for logging in to the FTP or SCP remote server as ftpuser and ftp123456, respectively.
[Sysname] info-center file-server user ftpuser password simple ftp123456
info-center filter
Use info-center filter to create a log output filter.
Use undo info-center filter to delete a log output filter.
info-center filter filter-name { module-name | default } { deny | level severity }
undo info-center filter filter-name [ module-name | default ]
No log output filters exist.
context-admin
filter-name: Specifies a name for the log output filter, a case-insensitive string of 1 to 8 characters.
module-name: Specifies a module by its name. To view the names of supported modules, execute the info-center filter filter-name ? command.
default: Specifies all supported modules.
deny: Disables log output.
level severity: Specifies a log severity level by its name. Supported severity levels are alert, critical, debugging, emergency, error, informational, notification, and warning. See Table 6 for more information about the log severity levels. The log output filter applies to logs of the specified severity level and all higher levels.
A log output filter contains a set of log output filter rules for modules. You can create multiple log output filters. When specifying a log host, you can apply a log output filter to control log output to the log host.
You can also use the info-center source command to configure log output rules for the log host output destination. The system chooses the settings to control log output to a log host in the following order:
1.     Log output filter specified for the log host by using the info-center loghost command.
2.     Log output rules configured for the log host output destination by using the info-center source command.
3.     Default log output rules (see Table 11).
Follow these restrictions and guidelines when you configure a log output filter:
·     To set a log output filter rule for a module, use the module-name argument to specify the module name.
If you set log output filter rules for the same module multiple times, the most recent configuration takes effect.
·     To set a general log output filter rule for all modules, use the default keyword. The general log output filter rule applies to all modules that do not have module-specific filter rules.
If you set a general log output filter rule multiple times, the most recent configuration takes effect.
·     If no general log output filter rule is set, the system outputs logs with severity levels informational through alert for modules that do not have module-specific filter rules.
·     To remove a module-specific log output filter rule, you must use the module-name argument. You cannot use the default keyword to remove module-specific log output filter rules. If you do not specify any parameters, the entire log output filter is deleted.
# Create log output filter loghost1. In the log output filter, enable the ARP module to output logs with severity levels notification through alert, enable the SNMP module to output logs with severity levels warning through alert, and disable log output of all other modules.
[Sysname] info-center filter loghost1 arp level notification
[Sysname] info-center filter loghost1 snmp level warning
[Sysname] info-center filter loghost1 default deny
info-center loghost
info-center source
info-center format
Use info-center format to set the format for logs sent to log hosts.
Use undo info-center format to restore the default.
info-center format { cmcc | rfc5424 | sgcc | unicom }
Logs are sent to log hosts in non-customized format.
context-admin
cmcc: Specifies the China Mobile Communications Corporation (CMCC) format.
rfc5424: Specifies the RFC 5424 format.
sgcc: Specifies the State Grid Corporation of China (SGCC) format.
unicom: Specifies the China Unicom format.
Logs can be sent to log hosts in non-customized, China Unicom, SGCC, CMCC, or RFC 5424 format. For more information about log formats, see information center configuration in Network Management and Monitoring Configuration Guide.
The format specified by the info-center format command applies to all log hosts and that specified by the info-center loghost command applies to the specified log hosts. For a log host, the format specified by the info-center loghost command takes precedence over the format specified by the info-center format command.
# Set the log format to RFC 5424 for logs sent to log hosts.
[Sysname] info-center format rfc5424
info-center loghost
Use info-center logbuffer to enable log output to the log buffer.
Use undo info-center logbuffer to disable log output to the log buffer.
Log output to the log buffer is enabled.
context-admin
This command enables vSystem log output to log buffers.
·     Default vSystem logs are saved in the default vSystem log buffer.
·     Non-default vSystem logs are saved in the non-default vSystem log buffer. All non-default vSystems share a log buffer.
This command enables log output to log buffers based on the log source modules.
·     Logs generated by modules or submodules that have separate log buffers are saved to their respective log buffers.
For example, session logs are saved to the session log buffer.
·     Logs generated by other modules are saved to the general log buffer.
To view log buffer information and buffered logs, use the display logbuffer command.
To set the log buffer size, use the info-center logbuffer size command.
# Enable log output to the log buffer.
[Sysname] info-center logbuffer
display logbuffer
info-center enable
Use info-center logbuffer reserved-size to specify the log buffer size reserved for the non-default vSystems.
Use undo info-center logbuffer reserved-size to restore the default.
info-center logbuffer reserved-size reserved-size-value
All non-default vSystems share and preempt the non-default vSystem log buffer resources.
vSystem view
reserved-size-value: Specifies the log buffer size reserved for the non-default vSystems. The value range is 1 to 512..
The saving of the vSystem logs varies by vSystem log type.
·     Default vSystem logs are saved in the default vSystem log buffer. You can execute the info-center logbuffer size command to set the default vSystem log buffer size.
·     Non-default vSystem logs are saved in the non-default vSystem log buffer. By default, all non-default vSystems share and preempt the non-default vSystem log buffer resources.
This command enables you to reserve a log buffer size for the specified non-default vSystems. When saving the non-default vSystem logs, the shared log buffer resources take precedence over the reserved log buffer resources. When the shared log buffer resources are insufficient, only the vSystems configured with this command can use the reserved log buffer resources. The logs of the vSystems that are configured without this command will be discarded.
# Reserve 100 logs that can be buffered for vSystem vsys1.
<sysname> system-view
[sysname] vsys vsys1
[sysname-vsys-2-vsys1] info-center logbuffer reserved-size 100
Use info-center logbuffer size to set the maximum number of logs that can be buffered.
Use undo info-center logbuffer size to restore the default.
info-center logbuffer [ module module-name ] size buffersize
undo info-center logbuffer [ module module-name ] size
A maximum of 512 logs can be buffered.
context-admin
module module-name: Sets the size for the log buffer of a module. The module-name argument is a case-insensitive string that represents the complete module name. To view the names of supported modules, execute the info-center logbuffer module ? command. If you do not specify a module, this command sets the size for the general log buffer.
buffersize: Specifies the maximum log buffer size. The value range is 0 to 1024.
# Set the maximum log buffer size to 50.
[Sysname] info-center logbuffer size 50
# Restore the default maximum log buffer size.
[Sysname] undo info-center logbuffer size
display logbuffer
info-center enable
Use info-center logfile directory to specify the directory to save the log file.
The log file is saved in the logfile folder under the root directory of the default file system.
context-admin
The specified log file directory must have been created.
The log file uses the .log extension.
# Set the log file directory to flash:/test.
[Sysname] info-center logfile directory flash:/test
Use info-center logfile enable to enable the log file feature.
Use undo info-center logfile enable to disable the log file feature.
The log file feature is enabled.
context-admin
After you configure this command, the system outputs logs to log files according to the log source modules.
·     Logs generated by modules or submodules that have separate log files are output to their respective log files.
For example, session logs are output to the log file named session.log.
The modules and submodules that have separate log files are predefined and they cannot be changed.
·     Logs generated by other modules are output to the general log file.
# Enable log output to the log file.
[Sysname] info-center logfile enable
Use info-center logfile frequency to configure the interval at which the system saves logs from the log file buffer to the log file.
Use undo info-center logfile frequency to restore the default.
The log file saving interval is 86400 seconds.
context-admin
freq-sec: Specifies the log file saving interval in seconds. The value range is 1 to 86400.
This command enables the system to automatically save logs in the log file buffer to the log file at the specified interval.
# Set the log file saving interval to 60000 seconds.
[Sysname] info-center logfile frequency 60000
Use info-center logfile module alarm-threshold to set the log file usage alarm threshold for a module.
Use undo info-center logfile module alarm-threshold to restore the default.
info-center logfile module module-name alarm-threshold usage
undo info-center logfile module module-name alarm-threshold
The log file usage alarm threshold is 80% of the log file size. When the log file usage ratio of a module reaches 80%, the system outputs a message to inform the user.
context-admin
module module-name: Specifies a module. The module-name argument is a case insensitive string that represents the complete module name. To view the names of supported modules, execute the info-center logfile module ? command.
usage: Specifies an alarm threshold in percentage in the range of 0 to 100. Set the value to 0 to disable the log file usage alarm feature.
After you set the alarm threshold for the log file usage of a module, the system outputs a message to inform the user when the threshold is reached. The user can then back up the log file to avoid loss of log data.
# Set the log file usage alarm threshold to 90% of the log file size for the session module.
[Sysname] info-center logfile module SESSION alarm-threshold 90
Use info-center logfile size-quota to set the maximum log file size.
Use undo info-center logfile size-quota to restore the default.
info-center logfile [ module module-name ] size-quota size
undo info-center logfile [ module module-name ] size-quota
The maximum log file size for the general log file and module-specific log file is 10 MB and 1 MB, respectively.
context-admin
module module-name: Sets the maximum log file size for a module. The module-name argument is a case-insensitive string that represents the complete module name. To view the names of supported modules, execute the info-center logfile module ? command. If you do not specify a module, this command sets the size for the general log file.
size: Specifies the maximum log file size in MB. The value range is 1 to 10.
# Set the maximum log file size to 2 MB.
[Sysname] info-center logfile size-quota 2
Use info-center logging suppress duplicates to enable duplicate log suppression.
Use undo info-center logging suppress duplicates to disable duplicate log suppression.
Duplicate log suppression is disabled.
context-admin
Outputting consecutive duplicate logs wastes system and network resources and increases device maintenance costs. You can enable this feature to suppress output of consecutive duplicate logs.
# Enable duplicate log suppression on device A.
[Sysname] info-center logging suppress duplicates
Use info-center logging suppress module to configure a log suppression rule for a module.
Use undo info-center logging suppress module to delete a log suppression rule.
undo info-center logging suppress module module-name mnemonic { all | mnemonic-value }
The device does not suppress output of any logs from any modules.
context-admin
module-name: Specifies a log source module by its name, a case-insensitive string of 1 to 8 characters. To view the list of available log source modules, use the info-center logging suppress module ? command.
mnemonic { all | mnemonic-value }: Configures a mnemonic filter for log suppression.
·     all: Suppresses output of all logs of the module.
·     mnemonic-value: Suppresses output of logs with the specified mnemonic value. The mnemonic-value argument is a case-insensitive string of 1 to 32 characters, which must be the complete value contained in the mnemonic field of the log message. Log suppression will fail if a partial mnemonic value is specified.
You can configure log suppression rules to filter out the logs that you are not concerned with. A log suppression rule suppresses output of all logs or only logs with a specific mnemonic value for a module.
# Configure a log suppression rule to suppress output of logs with the shell_login mnemonic value for the shell module.
[Sysname] info-center logging suppress module shell mnemonic shell_login
info-center source
info-center loghost
Use info-center loghost to specify a log host and to configure output parameters.
Use undo info-center loghost to remove a log host.
Default vSystem:
info-center loghost [ vpn-instance vpn-instance-name ] { hostname | ipv4-address | ipv6 ipv6-address } [ facility local-number | filter filter-name | format { cmcc | default | rfc5424 | sgcc | unicom } | port port-number | source-ip source-ip-address | tcp [ ssl-client-policy policy-name ] ] *
undo info-center loghost [ vpn-instance vpn-instance-name ] { hostname | ipv4-address | ipv6 ipv6-address }
Non-default vSystem:
info-center loghost { ipv4-address | ipv6 ipv6-address } [ port port-number | tcp [ ssl-client-policy policy-name ] ]
undo info-center loghost { ipv4-address | ipv6 ipv6-address }
No log hosts are specified.
context-admin
vsys-admin
hostname: Specifies a log host by its name, a case-insensitive string of 1 to 253 characters. The host name can contain letters, digits, and special characters including hyphen (-), underscore (_), and dot (.).
ipv4-address: Specifies a log host by its IPv4 address.
ipv6 ipv6-address: Specifies a log host by its IPv6 address.
facility local-number: Specifies a logging facility from local0 to local7 for the log host. The default value is local7. Logging facilities are used to mark different logging sources, and query and filer logs.
filter filter-name: Specifies a log output filter to control log output to the log host. The filter-name argument represents the filter name, a case-insensitive string of 1 to 8 characters. If you do not specify a log output filter, the log output rules configured by using the info-center source command for the log host destination are used.
format { cmcc | default | rfc5424 | sgcc | unicom }: Specifies a format for logs sent to log hosts. If you do not specify this keyword, the format specified by the info-center format command is used.
·     cmcc: Specifies the China Mobile Communications Corporation (CMCC) format.
·     default: Specifies the non-customized format.
·     rfc5424: Specifies the RFC 5424 format.
·     sgcc: Specifies the State Grid Corporation of China (SGCC) format.
·     unicom: Specifies the China Unicom format.
port port-number: Specifies the port number of the log host, in the range of 1 to 65535. The default is 514. It must be the same as the value configured on the log host. Otherwise, logs cannot be sent to the log host.
source-ip source-ip-address: Specifies the source IP address for logs sent to the specified log hosts. If you do not specify this option, the source IP address specified by the info-center loghost source command is used.
tcp: Uses TCP to send logs. The device uses UDP to send logs by default.
ssl-client-policy policy-name: Specifies an SSL client policy to encrypt the sent logs, a case-insensitive string of 1 to 31 characters. If you do not specify this option, logs are sent without encryption.
Application scenarios
After logging in to a vSystem, you can execute this command to output the logs of the vSystem to the specified log hosts.
To use an SSL client policy to encrypt the logs sent to a log host, configure the SSL client policy first. If you have not configured the SSL client policy, the SSL connection cannot be established and logs cannot be sent to the log host. For more information about SSL client policy configuration, see SSL VPN configuration in Security Configuration Guide.
The info-center loghost command takes effect only after the information center is enabled by using info-center enable command.
# Output logs to the log host at 1.1.1.1.
[Sysname] info-center loghost 1.1.1.1
info-center filter
info-center format
info-center source
ssl client-policy (Security Command Reference)
Use info-center loghost locate-info with-sn to add the device serial number to the location field of logs sent to log hosts.
Use undo info-center loghost locate-info with-sn to restore the default.
The device does not add the device serial number to the location field of logs sent to log hosts.
context-admin
# Add the device serial number to the location field of logs sent to log hosts.
[Sysname] info-center loghost locate-info with-sn
Use info-center loghost source to specify a source IP address for logs sent to log hosts.
Use undo info-center loghost source to restore the default.
The source IP address of logs sent to log hosts is the primary IP address of the outgoing interface.
context-admin
The system uses the primary IP address of the specified interface as the source IP address of the logs sent to log hosts.
The info-center loghost source command takes effect only after the information center is enabled by using info-center enable command.
The source IP address specified by the info-center loghost source command applies to all log hosts and that specified by the info-center loghost command applies to the specified log hosts. For a log host, the source IP address specified by the info-center loghost command takes precedence over that specified by the info-center loghost source command.
# Use the IP address of interface Loopback 0 as the source IP address of the logs sent to log hosts.
[Sysname] interface loopback 0
[Sysname-LoopBack0] ip address 2.2.2.2 32
[Sysname-LoopBack0] quit
[Sysname] info-center loghost source loopback 0
info-center loghost
Use info-center loghost vsys-to-admin enable to enable outputting the logs of non-default vSystems to log hosts specified on the default vSystem.
Use undo info-center loghost vsys-to-admin enable to restore the default.
The non-default vSystem logs will not be output to the log hosts specified on the default vSystem.
views
You can specify log hosts for the default vSystem and non-default vSystems, thus the default vSystem logs and non-default vSystem logs can be output to their respective log hosts. After configuring log hosts for the default vSystem, you can execute this command to enable outputting the logs of non-default vSystems to the logs hosts specified on the default vSystem. Thus, you do not need to log in to each non-default vSystem to specify the log hosts.
# Enable outputting the logs of non-default vSystems to log hosts specified on the default vSystem.
<vsys-aaa> system-view
[Sysname] info-center loghost vsys-to-admin enable
info-center loghost
Use info-center security-logfile alarm-threshold to set the alarm threshold for security log file usage.
Use undo info-center security-logfile alarm-threshold to restore the default.
The alarm threshold for security log file usage is 80. When the usage of the security log file reaches 80%, the system outputs a message to inform the administrator.
context-admin
usage: Specifies an alarm threshold. The value must be an integer in the range of 1 to 100.
When the security log file is full, the system deletes the oldest logs and then writes new logs to the security log file. This feature helps avoid security log loss by setting an alarm threshold for the security log file usage. When the threshold is reached, the system outputs log information to inform the administrator. The administrator can log in to the device with the security-audit user role and back up the security log file.
# Set the alarm threshold for security log file usage to 90.
[Sysname] info-center security-logfile alarm-threshold 90
Use info-center security-logfile directory to specify the security log file directory.
The security log file is saved in the seclog folder under the root directory of the default file system.
security-audit
# Set the security log file directory to flash:/test.
[Sysname] info-center security-logfile directory flash:/test
Use info-center security-logfile enable to enable saving of security logs to the security log file.
Use undo info-center security-logfile enable to restore the default.
Saving of security logs to the security log file is disabled.
context-admin
This feature enables the system to output security logs to the security log file buffer, and then saves the buffered logs to the security log file regularly.
# Enable saving security logs to the security log file.
[Sysname] info-center security-logfile enable
Use info-center security-logfile frequency to configure the interval for saving security logs to the security log file.
Use undo info-center security-logfile frequency to restore the default.
The security log file saving interval is 86400 seconds.
context-admin
freq-sec: Specifies the security log file saving interval in seconds. The value range is 10 to 86400 seconds.
The system outputs security logs to the security log file buffer, and then saves the buffered logs to the security log file at the specified interval.
# Set the security log file saving interval to 600 seconds.
[Sysname] info-center security-logfile frequency 600
Use info-center security-logfile size-quota to set the maximum size for the security log file.
Use undo info-center security-logfile size-quota to restore the default.
The maximum size for the security log file is 10 MB.
context-admin
size: Sets the maximum size for the security log file, in MB. The value range is 1 to 10.
# Set the maximum size to 6 MB for the security log file.
[Sysname] info-center security-logfile size-quota 6
info-center source
Use info-center source to configure a log output rule for a module.
Use undo info-center source to restore the default.
info-center source { module-name | default } { console | logbuffer | logfile | loghost | monitor } { deny | level severity }
undo info-center source { module-name | default } { console | logbuffer | logfile | loghost | monitor }
Table 11 lists the default log output rules.
Table 11 Default output rules
Destination
Log source modules
Output switch
Severity
Console
All supported modules
Enabled
Debugging
Monitor terminal
Disabled
Debugging
Log host
Enabled
Informational
Log buffer
Enabled
Informational
Log file
Enabled
Informational
context-admin
module-name: Specifies a module by its name. You can use the info-center source ? command to view the modules supported by the device.
console: Outputs logs to the console.
logbuffer: Outputs logs to the log buffer.
logfile: Outputs logs to the log file.
loghost: Outputs logs to the log host.
monitor: Outputs logs to the monitor terminal.
level severity: Specifies a severity level in the range of 0 to 7. The smaller the severity value, the higher the severity level. See Table 6 for more information. Logs at the specified severity level and higher levels are allowed to be output.
If you do not set an output rule for a module, the module uses the output rule set by using the default keyword. If no rule is set by using the default keyword, the module uses the default output rule.
To modify or remove an output rule set for a module, you must use the module-name argument. A new output rule configured by using the default keyword does not take effect on the module.
If you execute this command for a module multiple times, the most recent configuration takes effect.
If you execute this command for the default modules multiple times, the most recent configuration takes effect.
# Output only VLAN module's information with the emergency level to the console.
[Sysname] info-center source default console deny
[Sysname] info-center source vlan console level emergency
# Based on the previous configuration, disable output of VLAN module's information to the console so no system information is output to the console.
[Sysname] undo info-center source vlan console
Use info-center synchronous to enable synchronous information output.
Use undo info-center synchronous to disable synchronous information output.
Synchronous information output is disabled.
context-admin
System log output interrupts ongoing configuration operations, including obscuring previously entered commands. Synchronous information output shows the obscured commands. It also provides a command prompt in command editing mode, or a [Y/N] string in interaction mode so you can continue your operation from where you were stopped.
# Enable synchronous information output, and then execute the display current-configuration command to view the current configuration of the device.
[Sysname] info-center synchronous
Info-center synchronous output is on
[Sysname] display current-
At this time, the system receives log information. It displays the log information first, and then displays your previous input, which is display current- in this example.
%May 21 14:33:19:425 2007 Sysname SHELL/5/SHELL_LOGIN: VTY logged in from 192.168.1.44
Enter configuration to complete the display current-configuration command, and press the Enter key to execute the command.
# Enable synchronous information output, and then save the current configuration (enter interactive information).
[Sysname] save
The current configuration will be written to the device. Are you sure? [Y/N]:
At this time, the system receives the log information. It displays the log information first and then displays [Y/N].
[Y/N]:
Enter Y or N to complete your input.
Use info-center syslog min-age to set the minimum storage period.
Use undo info-center syslog min-age to restore the default.
info-center syslog [ module module-name ] min-age min-age
undo info-center syslog [ module module-name ] min-age
The minimum storage period is not set.
context-admin
module module-name: Sets the minimum storage period for logs in the log file and log buffer of a module. The module-name argument is a case-insensitive string that represents the complete module name. To view the names of supported modules, execute the info-center syslog module ? command. If you do not specify a module, this command sets the minimum storage period for the general log files and logs in the general log buffer.
min-age: Sets the minimum storage period in hours. The value range is 1 to 8760.
# Set the minimum storage period to 168 hours.
[Sysname] info-center syslog min-age 168
Use info-center syslog min-age to set the minimum storage period for logs in the log buffer and log file.
context-admin
module module-name: Sets the minimum storage period for logs in the log buffer and log file of a module. The module-name argument is a case-insensitive string that represents the complete module name. To view the names of supported modules, execute the info-center syslog module ? command. If you do not specify a module, this command sets the minimum storage period for logs in the general log buffer and general log file.
Use info-center syslog trap buffersize to set the maximum number of log traps that can be stored in the log trap buffer.
Use undo info-center syslog trap buffersize to restore the default.
The log trap buffer can store a maximum of 1024 traps.
context-admin
buffersize: Specifies the maximum number of log traps that can be stored in the log trap buffer. The value range is 0 to 65535. Value 0 indicates that the device does not buffer log traps.
Log traps are SNMP notifications stored in the log trap buffer. After the snmp-agent trap enable syslog command is configured, the device sends log messages in SNMP notifications to the log trap buffer. You can view the log traps by accessing the MIB corresponding to the trap buffer.
The default buffer size is usually used. You can adjust the buffer size according to your network condition. New traps overwrite the oldest traps when the log trap buffer is full.
# Set the log trap buffer size to 2048.
[Sysname] info-center syslog trap buffersize 2048
info-center syslog utf-8 enable
Use info-center syslog utf-8 enable to enable the information center to use the UTF-8 encoding.
Use undo info-center syslog utf-8 enable to restore the default.
The information center uses the GB18030 encoding.
context-admin
For the user' login terminal to correctly display Chinese characters in log messages received from the information center, the information center and the terminal must use the same character set encoding.
The information center supports both GB18030 and UTF-8 encodings. By default, the GB18030 encoding is used.
If the login terminal uses the UTF-8 encoding, you can use this command to enable the information center to use the UTF-8 encoding.
# Enable the information center to use the UTF-8 encoding.
[Sysname] info-center syslog utf-8 enable
info-center timestamp
Use info-center timestamp to set the timestamp format for logs sent to the console, monitor terminal, log buffer, and log file.
Use undo info-center timestamp to restore the default.
The timestamp format for logs sent to the console, monitor terminal, log buffer, and log file is date.
context-admin
boot: Sets the timestamp format to xxx.yyy, where xxx is the most significant 32 bits (in milliseconds) and yyy is the least significant 32 bits. For example, 0.21990989 equals Jun 25 14:09:26:881 2007. The boot time shows the time since system startup.
date: Sets the timestamp format to MMM DD hh:mm:ss:ms YYYY, such as Dec  8 10:12:21:708 2007. The date time shows the current system time.
·     MMM: Abbreviations of the months in English, which could be Jan, Feb, Mar, Apr, May, Jun, Jul, Aug, Sep, Oct, Nov, or Dec.
·     DD: Date, starting with a space if it is less than 10, for example " 7".
·     hh:mm:ss:ms: Local time, with hh in the range of 00 to 23, mm and ss in the range of 00 to 59, and ms in the range of 0 to 999.
·     YYYY: Year.
none: Indicates no time information is provided.
Non-default vSystems do not support this command.
# Set the timestamp format to boot for logs sent to the console, monitor terminal, log buffer, and log file.
[Sysname] info-center timestamp boot
info-center timestamp loghost
Use info-center timestamp loghost to set the timestamp format for logs sent to log hosts.
Use undo info-center timestamp loghost to restore the default.
info-center timestamp loghost { date [ with-milliseconds ] | iso [ with-milliseconds ] | no-year-date | none }
The timestamp format for logs sent to log hosts is date.
context-admin
date: Sets the timestamp format to mmm dd hh:mm:ss yyyy, such as Dec  8 10:12:21 2007. The date time shows the current system time.
iso: Sets the ISO 8601 timestamp format, for example, 2009-09-21T15:32:55.
with-milliseconds: Sets the timestamp to be accurate to milliseconds for logs output to log hosts in date or ISO 8601 format. The millisecond value is appended to the time information in the timestamp with a dot as the separator. If you do not specify this keyword, the timestamp in date or ISO 8601 format is accurate to seconds.
·     Example of a timestamp in date format with millisecond accuracy: Dec 8 10:12:21.708 2018.
·     Example of a timestamp in ISO 8601 format with millisecond accuracy: 2018-09-21T15:32:55.708.
no-year-date: Sets the timestamp format to the current system date and time without year.
none: Indicates that no timestamp information is provided.
# Set the timestamp format to no-year-date for logs sent to log hosts.
[Sysname] info-center timestamp loghost no-year-date
info-center trace-logfile quota
Use info-center trace-logfile quota to set the maximum size for the trace log file.
Use undo info-center trace-logfile quota to restore the default.
The maximum trace log file size is 1 MB.
context-admin
size: Sets the maximum size for the trace log file, in MB.The value range is 1 to 10.
# Set the maximum size to 6 MB for the trace log file.
[Sysname] info-center trace-logfile quota 6
logfile save
Use logfile save to manually save logs in the log file buffer to the log file.
logfile save
context-admin
You can specify the directory to save the log file by using the info-center logfile directory command.
The system clears the log file buffer after saving the buffered logs to the log file automatically or manually.
If the log file buffer is empty, this command displays a success message event though no logs are saved to the log file.
# Manually save logs from the log file buffer to the log file.
<Sysname> logfile save
The contents in the log file buffer have been saved to the file flash:/logfile/logfile.log.
reset logbuffer
Use reset logbuffer to clear the log buffer.
reset logbuffer [ module module-name [ submodule submodule-name ] ]
context-admin
module module-name: Clears the log buffer of a module. The module-name argument is a case-insensitive string that represents the complete module name. To view the names of supported modules, execute the reset logbuffer module ? command. If you do not specify a module, this command clears the general log buffer.
submodule submodule-name: Clears the log buffer of a submodule of the specified module. The submodule--name argument is a case-insensitive string that represents the complete submodule name. To view the names of supported submodules, execute the display logbuffer module module-name submodule ? command. If you do not specify a submodule, this command clears the log buffers of all submodules of the specified module.
This command clears the default vSystem log buffer and the log buffer for non-default vSystems.
# Clear the log buffer.
<Sysname> reset logbuffer
display logbuffer
security syslog rate-limit
Use security syslog rate-limit to set the maximum number of security logs that can be sent per second.
Use undo security syslog rate-limit to restore the default.
security syslog rate-limit max-value
The device can send a maximum of 1000 security logs per second to the information center.
context-admin
max-value: Sets the maximum number of security logs that can be sent per second. The value range for the max-value argument is 0 to 10000. Value 0 indicates that the device does not send security logs to the information center.
When the device processes the following security services, a large number of security logs will be generated and sent to the information center, which will cause overload of the information center:
·     AFT.
·     ASPF.
·     Data filtering.
·     File filtering.
·     URL filtering.
·     NAT.
·     Session management.
·     Anti-virus.
·     Application audit and management.
·     IPS.
·     NetShare Control.
·     Server connection detection.
·     Attack detection and prevention.
This feature allows you to set the maximum number of security logs that can be sent per second to the information center. With this feature configured, the device will discard the subsequent security logs when the number of security logs sent to the information center per second reaches the maximum value allowed. Set an appropriate maximum value according to your network condition.
# Set 1000 as the maximum number of security logs that can be sent per second.
[Sysname] security syslog rate-limit 1000
security-logfile save
Use security-logfile save to manually save security logs from the security log file buffer to the security log file.
security-audit
The system clears the security log file buffer after saving the buffered security logs to the security log file automatically or manually.
If the security log file buffer is empty, this command displays a success message event though no security logs are saved to the security log file.
# Manually save the security logs in the security log file buffer to the security log file.
<Sysname> security-logfile save
The contents in the security log file buffer have been saved to the file flash:/seclog/seclog.log.
Use snmp-agent trap enable syslog to enable SNMP notifications for log messages.
Use undo snmp-agent trap enable syslog to disable SNMP notifications for log messages.
The device does not send SNMP notifications for log messages.
context-admin
This command enables the device to send an SNMP notification for each log message it outputs. The device encapsulates logs in SNMP notifications and then sends them to the SNMP module and the log trap buffer.
For the SNMP module to send the received SNMP notifications correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
To view the traps in the log trap buffer, access the MIB corresponding to the log trap buffer. The log trap buffer size can be set by using the info-center syslog trap buffersize command.
# Enable the device to send SNMP notifications for log messages.
[Sysname] snmp-agent trap enable syslog
terminal debugging
Use terminal debugging to enable output of debugging messages to the current terminal.
Use undo terminal debugging to disable output of debugging messages to the current terminal.
terminal debugging
Output of debugging messages to the current terminal is disabled.
context-admin
This command enables output of debugging-level log messages to the current terminal.
To enable output of debugging messages to the console, perform the following tasks:
1.     Execute the terminal debugging command.
2.     Enable the information center. The information center is enabled by default.
3.     Use a debugging command to enable the related debugging.
To enable output of debugging messages to the monitor terminal, perform the following tasks:
1.     Execute the terminal monitor and terminal debugging commands.
This command takes effect only for the current connection between the terminal and the device. If a new connection is established, the default is restored.
You can also enable output of debugging messages to the current terminal by executing the terminal logging level 7 command. The terminal logging level 7 command and the terminal debugging command have the following differences:
·     The terminal logging level 7 command enables log output for all log severity levels (levels 0 through 7).
·     The terminal debugging command enables log output for the following log severity levels:
¡     Debugging level (level 7).
¡     Severity level higher than or equal to the level specified in the terminal logging level command.
# Enable output of debugging messages to the current terminal.
<Sysname> terminal debugging
The current terminal is enabled to display debugging logs.
terminal monitor
Use terminal logging level to set the lowest level of logs that can be output to the current terminal.
Use undo terminal logging level to restore the default.
The lowest level of logs that can be output to the current terminal is 6 (Informational).
context-admin
severity: Specifies a log severity level. Valid values are alert, critical, debugging, emergency, error, informational, notification, warning, and digits from 0 to 7.
This command enables the device to output logs with a severity level higher than or equal to the specified level to the current terminal. For example, if you set the severity argument to 6, logs with a severity value from 0 to 6 are output to the current terminal.
# Configure the device to output logs with the debugging level and higher levels to the current terminal.
<Sysname> terminal logging level 7
terminal monitor
Use terminal monitor to enable log output to the current terminal.
Use undo terminal monitor to disable log output to the current terminal.
terminal monitor
Log output to the console is enabled, and log output to the monitor terminal is disabled.
context-admin
vsys-admin
# Enable log output to the current terminal.
<Sysname> terminal monitor
