01-Multicast routing and forwarding commands | 207.94 KB |
display multicast fast-forwarding cache
display multicast forwarding df-info
display multicast forwarding event
display multicast forwarding-table
display multicast forwarding-table df-list
display multicast routing-table
display multicast routing-table static
multicast forwarding-table cache-unknown per-entry
multicast forwarding-table cache-unknown total
reset multicast fast-forwarding cache
reset multicast forwarding event
reset multicast forwarding-table
Non-default vSystems do not support some of the multicast routing and forwarding commands. For information about vSystem support for a command, see the usage guidelines on that command. For information about vSystem, see Virtual Technologies Configuration Guide.
delete ip rpf-route-static
Use delete ip rpf-route-static to delete all static multicast routes.
context-admin
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command deletes all static multicast routes on the public network.
Non-default vSystems do not support this command.
This command deletes all static multicast routes. To delete a specified static multicast route, use the undo ip rpf-route-static command.
# Delete all static multicast routes on the public network.
[Sysname] delete ip rpf-route-static
This will erase all multicast static routes and their configurations, you must reconfigure all static routes.
Are you sure?[Y/N]:y
ip rpf-route-static
display mrib interface
Use display mrib interface to display information about interfaces maintained by the MRIB.
context-admin
context-operator
vsys-admin
vsys-operator
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about interfaces maintained by the MRIB on the public network.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about all interfaces maintained by the MRIB.
# Display information about interfaces maintained by the MRIB on the public network.
<Sysname> display mrib interface
Index: 0x00004444
Current state: up
MTU: 1500
Type: BROADCAST
Protocol: PIM-DM
PIM protocol state: Enabled
Address list:
1. Local address : 8.12.0.2/16
Remote address: 0.0.0.0
Reference : 1
State : NORMAL
Interface name. |
Index |
Index number of the interface. |
Current state |
Current status of the interface: up or down. |
MTU |
MTU value. |
Type |
Interface type: · BROADCAST—Broadcast link interface. · P2P—P2P interface. · LOOP—Loopback interface. · REGISTER—Register interface. · NBMA—NBMA interface. · MTUNNEL—Multicast tunnel interface. This field is empty if the interface is Null 0. |
Protocol |
Protocol running on the interface: PIM-DM, PIM-SM, IGMP, PROXY, or MD. |
PIM protocol state |
Whether PIM is enabled: Enabled or Disabled. |
Address list |
Interface address list. |
Local address |
Local IP address. |
Remote address |
Remote end IP address. This field is displayed only when the interface is vlink type. |
Reference |
Number of times that the address has been referenced. |
State |
Status of the interface address: NORMAL or DEL. |
display multicast boundary
Use display multicast boundary to display multicast boundary information.
context-admin
context-operator
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays multicast boundary information on the public network.
group-address: Specifies a multicast group by its IP address in the range of 224.0.0.0 to 239.255.255.255. If you do not specify a multicast group, this command displays multicast boundary information for all multicast groups.
mask-length: Specifies an address mask length in the range of 4 to 32. The default is 32.
mask: Specifies an address mask. The default is 255.255.255.255.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays multicast boundary information for all interfaces.
# Display information about all multicast boundaries on the public network.
<Sysname> display multicast boundary
Boundary Interface
224.1.1.0/24 GE1/0/1
239.2.2.0/24 GE1/0/2
Boundary |
Multicast group associated with the multicast boundary. |
Boundary interface associated with the multicast boundary. |
multicast boundary
Use display multicast fast-forwarding cache to display multicast fast forwarding entries.
display multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache [ source-address | group-address ] * [ slot slot-number ]
context-admin
context-operator
vsys-admin
vsys-operator
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays multicast fast forwarding entries on the public network.
source-address: Specifies a multicast source address.
group-address: Specifies a multicast group address in the range of 224.0.1.0 to 239.255.255.255.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays multicast fast forwarding entries for the master device.
# Display multicast fast forwarding entries on the public network.
<Sysname> display multicast fast-forwarding cache
Total 1 entries, 1 matched
(60.1.1.200, 225.0.0.2)
Status : Enabled
Source port: 2001 Destination port: 2002
Protocol : 2 Flag : 0x2
Incoming interface: GigabitEthernet1/0/3
List of 1 outgoing interfaces:
GigabitEthernet1/0/2
Status: Enabled Flag: 0x14
Total 1 entries, 1 matched |
Total number of (S, G) entries in the multicast fast forwarding table, and the total number of matching (S, G) entries. |
(60.1.1.200, 225.0.0.2) |
(S, G) entry. |
Protocol |
Protocol number. |
Flag of the (S, G) entry or the outgoing interface in the entry. This field displays one flag or the sum of multiple flags. In this example, the value 0x2 means that the entry has only one flag 0x2. The value 0x14 means that the interface has flags 0x4 and 0x10. The following flags are available for an entry: · 0x1—The entry is created because of packets passed through between cards. · 0x2—The entry is added by multicast forwarding. The following flags are available for an outgoing interface: · 0x1—The interface is added to the entry because of packets passed through between cards. · 0x2—The interface is added to an existing entry. · 0x4—The MAC address of the interface is needed for fast forwarding. · 0x8—The interface is an outgoing interface associated with the incoming VLAN interface. · 0x10—The interface is associated with the entry. · 0x20—The interface is to be deleted. |
Status |
Status of the (S, G) entry or the outgoing interface: · Enabled—Available. · Disabled—Unavailable. |
Incoming interface |
Incoming interface of the (S, G) entry. |
List of 1 outgoing interfaces |
Outgoing interface list of the (S, G) entry. |
reset multicast fast-forwarding cache all
Use display multicast forwarding df-info to display DF information.
display multicast [ vpn-instance vpn-instance-name ] forwarding df-info [ rp-address ] [ verbose ] [ slot slot-number ]
context-admin
context-operator
vsys-admin
vsys-operator
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays DF information on the public network.
rp-address: Specifies a BIDIR-PIM RP by its IP address.
verbose: Specifies detailed information. If you do not specify this keyword, the command displays brief information about DFs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays DF information for the master device.
In a BIDIR-PIM domain, only the DF on each subnet can forward multicast data destined for a multicast group toward the RP of the group. For more information about the DF, see IP Multicast Configuration Guide.
# Display brief information about DFs on an ADVPN network.
<Sysname> display multicast forwarding df-info
Total 1 RPs, 1 matched
00001. RP address: 1.1.1.1
Flags: 0x0
Uptime: 00:00:53
RPF interface: Tunnel2, 192.168.0.1
List of 2 DF interfaces:
1: LoopBack0
2: Tunnel2, 192.168.0.3
# Display brief information about DFs on the public network.
00001. RP address: 7.11.0.2
Flags: 0x0
Uptime: 04:14:40
RPF interface: GigabitEthernet1/0/1
List of 1 DF interfaces:
1: GigabitEthernet1/0/2
# Display detailed information about DFs on the public network.
<Sysname> display multicast forwarding df-info verbose
MID: 2, Flags: 0x0
Uptime: 03:37:22
Product information: 0x7a2f762f, 0x718fee9f, 0x4b82f137, 0x71c32184
Product information: 0xa567d6fc, 0xadeb03e3
Tunnel information: 0xdfb107d4, 0x7aa5d510
Product information: 0xa986152b, 0xb74a9a2f
Tunnel information: 0x297ca208, 0x76985b89
Total 1 RPs, 1 matched |
Total number of RPs, and the total number of matching RPs. |
00001 |
Sequence number of the entry to which the RP is designated. |
RP address |
IP address of the RP. |
MID |
ID of the entry to which the RP is designated. Each entry to which the RP is designated has a unique MID. |
Flags |
Entry flag. This field displays one flag or the sum of multiple flags. In this example, the value 0x0 means that the entry has only one flag 0x0. The following flags are available for an entry: · 0x0—The entry is in correct state. · 0x4—The entry fails to update. · 0x8—DF interface information fails to update for the entry. · 0x40—The entry is to be deleted. · 0x100—The entry is being deleted. · 0x200—The entry is in GR state. |
Uptime |
Length of time for which the entry has been up. |
RPF interface |
RPF interface to the RP. |
List of 1 DF interfaces |
DF interface list. |
Tunnel2, 192.168.0.3 |
ADVPN tunnel interface, and the IP address of the remote end. |
Use display multicast forwarding event to display statistics of multicast forwarding events.
display multicast [ vpn-instance vpn-instance-name ] forwarding event [ slot slot-number ]
context-admin
context-operator
vsys-admin
vsys-operator
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays statistics of the multicast forwarding events on the public network.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays statistics of multicast forwarding events for the master device.
# Display statistics of multicast forwarding events on the public network.
<Sysname> display multicast forwarding event
Total active events sent: 0
Total inactive events sent: 0
Total NoCache events sent: 2
Total NoCache events dropped: 0
Total WrongIF events sent: 0
Total WrongIF events dropped: 0
Total SPT switch events sent: 0
NoCache rate limit: 1024 packets/s
WrongIF rate limit: 1 packets/10s
Total timer of register suppress timeout: 0
Total active events sent |
Number of times that entry-active events have been sent. |
Total inactive events sent |
Number of times that entry-inactive events have been sent. |
Total NoCache events sent |
Number of times that NoCache events have been sent. |
Total NoCache events dropped |
Number of times that NoCache events have been dropped. |
Total WrongIF events sent |
Number of times that WrongIF events have been sent. |
Total WrongIF events dropped |
Number of times that WrongIF events have been dropped. |
Total SPT switch events sent |
Number of times that SPT-switch events have been sent. |
NoCache rate limit |
Rate limit for sending NoCache events, in pps. |
WrongIF rate limit |
Rate limit for sending WrongIF events, in packets per 10 seconds. |
Total timer of register suppress timeout |
Number of times that the registration suppression has timed out in total. |
Use display multicast forwarding-table to display multicast forwarding entries.
context-admin
context-operator
vsys-admin
vsys-operator
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays multicast forwarding entries on the public network.
group-address: Specifies a multicast group address in the range of 224.0.0.0 to 239.255.255.255.
mask-length: Specifies an address mask length. The default value is 32. For a multicast group address, the value range for this argument is 4 to 32. For a multicast source address, the value range for this argument is 0 to 32.
mask: Specifies an address mask. The default value is 255.255.255.255.
incoming-interface: Specifies the multicast forwarding entries that contain the specified incoming interface.
interface-type interface-number: Specifies an incoming interface by its type and number.
outgoing-interface: Specifies the multicast forwarding entries that contain the specified outgoing interface.
exclude: Specifies the multicast forwarding entries that do not contain the specified interface in the outgoing interface list.
include: Specifies the multicast forwarding entries that contain the specified interface in the outgoing interface list.
match: Specifies the forwarding entries that contain only the specified interface in the outgoing interface list.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays multicast forwarding entries for the master device.
statistics: Displays statistics for the multicast forwarding table.
# Display multicast forwarding entries on an ADVPN network.
<Sysname> display multicast forwarding-table
00001. (172.168.0.2, 227.0.0.1)
Flags: 0x0
Incoming interface: Tunnel1, 12.1.1.3
List of 2 outgoing interface:
1: Tunnel1, 12.1.1.1
2: Tunnel1, 12.1.1.2
Matched 19648 packets(20512512 bytes), Wrong If 0 packet
# Display multicast forwarding entries on the public network.
Flags: 0x0
Incoming interface: Vlan-interface10
1: Vlan-interface20
Table 6 Command output
Total number of (S, G) entries, and the total number of matching (S, G) entries. |
00001 |
Sequence number of the (S, G) entry. |
(172.168.0.2,227.0.0.1) |
(S, G) entry. |
Flags |
Entry flag. This field displays one flag or the sum of multiple flags. In this example, the value 0x0 means that the entry has only one flag 0x0. The following entries are available for an entry: · 0x0—The entry is in correct state. · 0x1—The entry is in inactive state. · 0x2—The entry is null. · 0x4—The entry fails to update. · 0x8—Outgoing interface information fails to update for the entry. · 0x10—Data-group information fails to update for the entry. · 0x20—A register outgoing interface is available. · 0x40—The entry is to be deleted. · 0x80—The entry is in registration suppression state. · 0x100—The entry is being deleted. · 0x200—The entry is in GR state. · 0x800—The entry has the associated ARP entry for the multicast source address. · 0x400000—The entry is created by the IGMP proxy. · 0x2000000—The entry is a BIDIR-PIM forwarding entry. |
Uptime |
Length of time for which the (S, G) entry has been up. |
Timeout in |
Length of time in which the (S, G) entry will expire. |
Tunnel1, 12.1.1.1 |
Matched 19648 packets(20512512 bytes), Wrong If 0 packet |
Number of packets (bytes) that match the (S, G) entry, and number of packets with incoming interface errors. The numbers are displayed as 0 if an outgoing interface of the (S, G) entry is on the specified slot. |
Forwarded 19648 packets(20512512 bytes) |
Number of packets (bytes) that have been forwarded. The numbers are displayed as 0 if an outgoing interface of the (S, G) entry is on the specified slot. |
Use display multicast forwarding-table df-list to display information about the DF list in multicast forwarding entries.
display multicast [ vpn-instance vpn-instance-name ] forwarding-table df-list [ group-address ] [ verbose ] [ slot slot-number ]
context-admin
context-operator
vsys-admin
vsys-operator
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about the DF list in multicast forwarding entries on the public network.
verbose: Specifies detailed information about the DF list in multicast forwarding entries. If you do not specify this keyword, the command displays brief information about the DF list in multicast forwarding entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about the DF list in multicast forwarding entries for the master device.
# Display brief information about the DF list in multicast forwarding entries on the public network.
<Sysname> display multicast forwarding-table df-list
00001. (0.0.0.0, 225.0.0.1)
1: GigabitEthernet1/0/1
# Display detailed information about the DF list in multicast forwarding entries on the public network.
<Sysname> display multicast forwarding-table df-list verbose
Product information: 0x347849f6, 0x14bd6837
Tunnel information: 0xc4857986, 0x128a9c8f
Table 7 Command output
Total number of forwarding entries, and the total number of matching entries. |
00001 |
Sequence number of the entry. |
(0.0.0.0, 225.0.0.1) |
(*, G) entry. |
Use display multicast routing-table to display multicast routing entries.
context-admin
context-operator
vsys-admin
vsys-operator
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays multicast routing entries on the public network.
incoming-interface: Specifies the multicast routing entries that contain the specified incoming interface.
outgoing-interface: Specifies the multicast routing entries that contain the specified outgoing interface.
exclude: Specifies the multicast routing entries that do not contain the specified interface in the outgoing interface list.
include: Specifies the multicast routing entries that contain the specified interface in the outgoing interface list.
match: Specifies the multicast routing entries that contain only the specified interface in the outgoing interface list.
Multicast routing entries are the basis of multicast forwarding. You can use this command to view the establishment state of (S, G) entries.
# Display multicast routing entries on an ADVPN network.
<Sysname> display multicast routing-table
Total 1 entries
Uptime: 00:00:28
Upstream Interface: Tunnel1, 12.1.1.3
List of 2 downstream interfaces
# Display multicast routing entries on the public network.
Total 1 entries
Uptime: 00:00:28
Upstream Interface: GigabitEthernet1/0/1
2: GigabitEthernet1/0/3
Table 8 Command output
Total 1 entries |
Total number of (S, G) entries. |
00001 |
(172.168.0.2, 227.0.0.1) |
(S, G) entry. |
Uptime |
Upstream Interface |
Upstream interface at which (S, G) packets should arrive. |
List of 2 downstream interfaces |
List of downstream interfaces that need to forward (S, G) packets. |
Tunnel1, 12.1.1.1 |
Use display multicast routing-table static to display static multicast routing entries.
context-admin
context-operator
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays static multicast routing entries on the public network.
mask-length: Specifies an address mask length in the range of 0 to 32.
This command displays only valid static multicast routing entries.
# Display static multicast routing entries on the public network.
<Sysname> display multicast routing-table static
Destinations: 3 Routes: 4
Destination/Mask Pre RPF neighbor Interface
1.1.0.0/16 10 7.12.0.1 GE1/0/1
7.11.0.1 GE1/0/2
2.2.2.0/24 20 7.11.0.1 GE1/0/3
3.3.3.3/32 50 7.12.0.1 GE1/0/4
Table 9 Command output
Destinations |
Number of the multicast destination addresses. |
Routes |
Number of routes. |
Destination/Mask |
Destination address and its mask length. |
Pre |
Route preference. |
RPF neighbor |
IP address of the RPF neighbor to the reachable destination. |
Outgoing interface to the reachable destination. |
display multicast rpf-info
Use display multicast rpf-info to display RPF information for a multicast source.
context-admin
context-operator
vsys-admin
vsys-operator
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays RPF information for a multicast source on the public network.
# Display RPF information for multicast source 192.168.1.55 on the public network.
<Sysname> display multicast rpf-info 192.168.1.55
RPF information about source 192.168.1.55:
RPF interface: GigabitEthernet1/0/1, RPF neighbor: 10.1.1.1
Referenced route/mask: 192.168.1.0/24
Referenced route type: igp
Load splitting rule: disable
Source AS: 0
C-multicast route target: 0x0000000000000000
Table 10 Command output
RPF neighbor |
IP address of the RPF neighbor. |
Referenced route/mask |
Referenced route and its mask length. |
Referenced route type |
Type of the referenced route: · igp—IGP unicast route. · egp—EGP unicast route. · unicast (direct)—Directly connected unicast route. · unicast—Other unicast routes, such as static unicast route. · multicast static—Static multicast route. · mbgp—MBGP route. |
Route selection rule |
Rule for RPF route selection: · Route preference. · Longest prefix match. |
Load splitting rule |
Status of the load splitting rule: enable or disable. |
Source AS |
AS number of the source-side PE. |
C-multicast route target |
Route target attribute value of the C-multicast route. |
ip rpf-route-static
Use ip rpf-route-static to configure a static multicast route.
Use undo ip rpf-route-static to delete a static multicast route.
undo ip rpf-route-static [ vpn-instance vpn-instance-name ] source-address { mask-length | mask } { rpf-nbr-address | interface-type interface-number }
No static multicast routes exist.
context-admin
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command configures a static multicast route on the public network.
rpf-nbr-address: Specifies an RPF neighbor by its IP address.
interface-type interface-number: Specifies an interface by its type and number. The interface connects the RPF neighbor.
preference: Sets a route preference in the range of 1 to 255. The default value is 1.
If the interface connected to an RPF neighbor is a point-to-point interface, you must specify the interface by its type and number.
If the interface connected to an RPF neighbor is not a point-to-point interface, you must specify the interface by its IP address. This type of interfaces includes Layer 3 Ethernet, Layer 3 aggregate, Loopback, and VLAN interfaces.
The configured static multicast route might not take effect when one of the following conditions exists:
· The outgoing interface iteration fails.
· The specified interface is not in the public network or the same VPN instance as the current interface.
· The specified interface is not a point-to-point interface.
· The specified interface is down.
If multiple static multicast routes within the same multicast source address range are available, only the one with the highest route preference can become active. You can use the display multicast routing-table static command to verify that the configured static multicast route has taken effect.
The undo ip rpf-route-static command deletes the specified static multicast route, but the delete ip rpf-route-static command deletes all static multicast routes.
# Configure a static multicast route to multicast source 10.1.1.0/24 and specify the interface with IP address 192.168.1.23 as the RPF neighbor on the public network.
[Sysname] ip rpf-route-static 10.1.1.0 24 192.168.1.23
load-splitting (MRIB view)
Use load-splitting to enable multicast load splitting.
Use undo load-splitting to restore the default.
undo load-splitting
Multicast load splitting is disabled.
MRIB view
context-admin
source: Enables multicast load splitting based on multicast source.
source-group: Enables multicast load splitting based on multicast source and group.
This command does not take effect on BIDIR-PIM.
# Enable multicast load splitting based on multicast source on the public network.
[Sysname] multicast routing
[Sysname-mrib] load-splitting source
longest-match (MRIB view)
Use longest-match to specify the longest prefix match principle for RPF route. The device will use the matching route with the longest prefix as the RPF route.
Use undo longest-match to restore the default.
longest-match
undo longest-match
Route preference is used for RPF route selection. The route with the highest preference is used as the RPF route.
MRIB view
context-admin
# Specify the longest prefix match principle for RPF route selection on the public network.
[Sysname-mrib] multicast longest-match
multicast boundary
Use multicast boundary to configure a multicast forwarding boundary.
Use undo multicast boundary to delete a multicast forwarding boundary.
undo multicast boundary { group-address { mask-length | mask } | all }
No multicast forwarding boundaries are configured on an interface.
Interface view
context-admin
all: Specifies all forwarding boundaries configured on the interface.
A multicast forwarding boundary sets the boundary condition for the multicast groups in the specified address range. If the destination address of a multicast packet matches the set boundary condition, the packet is not forwarded.
You can configure an interface as a multicast forwarding boundary for different multicast group ranges by executing this command multiple times on the interface.
You do not need to enable IP multicast routing before you execute this command.
Assume that Set A and Set B are multicast forwarding boundary sets with different address ranges, and B is a subset of A. A takes effect on the interface no matter whether A is configured earlier or later than B.
# Configure GigabitEthernet 1/0/1 as the forwarding boundary of multicast groups in the range of 239.2.0.0/16.
[Sysname-GigabitEthernet1/0/1] multicast boundary 239.2.0.0 16
Use multicast forwarding-table cache-unknown per-entry to set the maximum number of unknown multicast packets that can be cached for an (S, G) entry.
Use undo multicast forwarding-table cache-unknown per-entry to restore the default.
multicast forwarding-table cache-unknown per-entry per-entry-limit
The device can cache only one unknown multicast packet for an (S, G) entry.
context-admin
per-entry-limit: Specifies the maximum number of unknown multicast packets that can be cached for an (S, G) entry. The value range for this argument is 0 to 256. If you set the value to 0, the device cannot cache unknown multicast packets.
# Set the maximum number to 20 for unknown multicast packets that can be cached for an (S, G) entry.
[Sysname] multicast forwarding-table cache-unknown per-entry 20
Use multicast forwarding-table cache-unknown total to set the maximum number of all unknown multicast packets that can be cached.
Use undo multicast forwarding-table cache-unknown total to restore the default.
multicast forwarding-table cache-unknown total total-limit
The device can cache 1024 unknown multicast packets in total.
context-admin
total-limit: Specifies the maximum number of all unknown multicast packets that can be cached. The value range for this argument is 0 to 65535. If you set the value to 0, the device cannot cache unknown multicast packets.
As a best practice, set the value in this command to be far greater than the value set in the multicast forwarding-table cache-unknown per-entry command.
# Set the maximum number to 10000 for all unknown multicast packets that can be cached.
[Sysname] multicast forwarding-table cache-unknown total 10000
multicast routing
Use multicast routing to enable IP multicast routing and enter MRIB view.
Use undo multicast routing to disable IP multicast routing.
undo multicast routing [ vpn-instance vpn-instance-name ]
IP multicast routing is disabled.
context-admin
vsys-admin
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command enables IP multicast routing on the public network.
Other Layer 3 multicast commands take effect only when IP multicast routing is enabled on the public network or for a VPN instance.
The device does not forward multicast packets before IP multicast routing is enabled.
# Enable IP multicast routing on the public network, and enter MRIB view.
[Sysname-mrib]
# Enable IP multicast routing for the VPN instance mvpn, and enter MRIB view.
[Sysname-mrib-mvpn]
Use reset multicast fast-forwarding cache to clear multicast fast forwarding entries.
reset multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache { { source-address | group-address } * | all } [ slot slot-number ]
context-admin
vsys-admin
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears multicast fast forwarding entries on the public network.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears multicast fast forwarding entries for the master device.
all: Specifies all multicast fast forwarding entries.
# Clear all multicast fast forwarding entries on the public network.
<Sysname> reset multicast fast-forwarding cache all
# Clear the multicast fast forwarding entry for multicast source and group (20.0.0.2, 225.0.0.2) on the public network.
<Sysname> reset multicast fast-forwarding cache 20.0.0.2 225.0.0.2
Use reset multicast forwarding event to clear statistics for multicast forwarding events.
context-admin
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears statistics for the multicast forwarding events on the public network.
# Clear statistics for multicast forwarding events on the public network.
<Sysname> reset multicast forwarding event
Use reset multicast forwarding-table to clear multicast forwarding entries.
context-admin
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears multicast forwarding entries on the public network.
all: Specifies all multicast forwarding entries.
When you clear a multicast forwarding entry, the associated multicast routing entry is also cleared.
# Clear multicast forwarding entries for multicast group 225.5.4.3 on the public network.
<Sysname> reset multicast forwarding-table 225.5.4.3
reset multicast routing-table
Use reset multicast routing-table to clear multicast routing entries.
reset multicast [ vpn-instance vpn-instance-name ] routing-table { { source-address [ mask { mask-length | mask } ] | group-address [ mask { mask | mask-length } ] | incoming-interface interface-type interface-number } * | all }
context-admin
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears multicast routing entries on the public network.
incoming-interface: Specifies the routing entries that contain the specified incoming interface.
all: Specifies all multicast routing entries.
When you clear a multicast routing entry, the associated multicast forwarding entry is also cleared.
# Clear multicast routing entries for multicast group 225.5.4.3 on the public network.
<Sysname> reset multicast routing-table 225.5.4.3
