- 15-Layer 3—IP Routing Command Reference
- 01-Basic IP routing commands
- 02-Static routing commands
- 03-IPv6 static routing commands
- 04-RIP commands
- 05-RIPng commands
- 06-OSPF commands
- 07-OSPFv3 commands
- 08-IS-IS commands
- 09-BGP commands
- 10-Policy-based routing commands
- 11-IPv6 policy-based routing commands
- 12-Routing policy commands
- 13-Guard route commands
- 14-RIR commands
| 02-Static routing commands | 173.08 KB |
display route-static routing-table
ip route-static default-preference
ip route-static fast-reroute auto
ip route-static primary-path-detect bfd echo
Non-default vSystems do not support some of the static routing commands. For information about vSystem support for a command, see the usage guidelines on that command. For information about vSystem, see Virtual Technologies Configuration Guide.
delete static-routes all
Use delete static-routes all to delete all static routes.
delete [ vpn-instance vpn-instance-name ] static-routes all
context-admin
vsys-admin
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command deletes all static routes for the public network.
CAUTION: This command might interrupt network communication and cause packet forwarding failure. Before executing the command, make sure you fully understand the potential impact on the network. |
When you use this command, the system will prompt you to confirm the operation before deleting all the static routes.
To delete one static route, use the undo ip route-static command. To delete all static routes, including the default route, use the delete static-routes all command.
# Delete all static routes.
[Sysname] delete static-routes all
This will erase all IPv4 static routes and their configurations, you must reconfigure all static routes.
Are you sure?[Y/N]:y
ip route-static
display route-static nib
Use display route-static nib to display static route next hop information.
display route-static nib [ nib-id ] [ verbose ]
context-admin
context-operator
nib-id: Specifies a NIB by its ID, a hexadecimal string of 1 to ffffffff. If you do not specify this argument, the command displays all static route next hop information.
verbose: Displays detailed static route next hop information. If you do not specify this keyword, the command displays brief static route next hop information.
Non-default vSystems do not support this command.
# Displays brief static route next hop information.
<Sysname> display route-static nib
Total number of nexthop(s): 44
NibID: 0x11000000 Sequence: 0
Type: 0x21 Flushed: Yes
UserKey0: 0x111 VrfNthp: 0
UserKey1: 0x0 Nexthop: 0.0.0.0
IFIndex: 0x111 LocalAddr: 0.0.0.0
NewUK0: 0x0 NewUK1: 0x0
NewUK2: 0x0 NewUK3: 0x0
NewUK4: 0x0 NewUK5: 0x0
NewUK6: 0x0 NewUK7: 0x0
TopoNthp: 0 ExtType: 0x0
Color: 0 COFlag: 0x0
LinkID: 0x0
SIDIndex: 0x0 SRPName:
OriNexthop: 0.0.0.0
NibID: 0x11000001 Sequence: 1
Type: 0x41 Flushed: Yes
UserKey0: 0x0 VrfNthp: 5
UserKey1: 0x0 Nexthop: 2.2.2.2
IFIndex: 0x0 LocalAddr: 0.0.0.0
LinkID: 0x0
OriNexthop: 0.0.0.0
NibID |
ID of the NIB. |
Sequence |
Sequence number of the NIB. |
Type |
Type of the NIB. |
Flushed |
Indicates whether the route with the NIB has been flushed to the FIB. |
UserKey0 |
Reserved data 1. |
UserKey1 |
Reserved data 2. |
VrfNthp |
Index of the VPN instance that the next hop belongs to. This field displays 0 if the next hop is on the public network. |
Nexthop |
Next hop address. |
IFIndex |
Interface index |
LocalAddr |
Local interface address. |
NewUK0 |
New reserved data 1. |
NewUK1 |
New reserved data 2. |
NewUK2 |
New reserved data 3. |
NewUK3 |
New reserved data 4. |
NewUK4 |
New reserved data 5. |
NewUK5 |
New reserved data 6. |
NewUK6 |
New reserved data 7. |
NewUK7 |
New reserved data 8. |
TopoNthp |
This field is not supported in the current software version. Index of the topology that contains the next hop. This field displays 0 if the next hop is on the public network. |
ExtType |
NIB extension type. |
Color |
This field is not supported in the current software version. Color extended community attribute. |
COFlag |
This field is not supported in the current software version. Flag of the color extended community attribute. |
LinkID |
Link ID of the SDWAN TTE connection. |
SIDIndex |
This field is not supported in the current software version. SID index value. |
SRPName |
This field is not supported in the current software version. SR-MPLS TE policy name. |
OriNexthop |
Original next hop address of the route. If the route is obtained from a BGP UPDATE message, the address is the next hop IP address in the BGP UPDATE message. |
# Displays detailed static route next hop information.
<Sysname> display route-static nib verbose
LinkID: 0x0
OriNexthop: 0.0.0.0
RefCnt: 2 FlushRefCnt: 0
Flag: 0x2 Version: 1
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 0.0.0.0
RelyDepth: 0 RealNexthop: 0.0.0.0
Interface: NULL0 LocalAddr: 0.0.0.0
TunnelCnt: 0 Vrf: default-vrf
TunnelID: N/A Topology: base
Weight: 1000000 Flags: 0x0
SRPolicyNID: 4294967295 SRInterface:
ColorWeight: 0 Locator: N/A
OrigLinkID: 0x0 RealLinkID: 0x0
LinkID: 0x0
OriNexthop: 0.0.0.0
RefCnt: 1 FlushRefCnt: 0
Flag: 0x12 Version: 1
2 nexthop(s):
PrefixIndex: 0 OrigNexthop: 2.2.2.2
RelyDepth: 7 RealNexthop: 8.8.8.8
Interface: GE1/0/1 LocalAddr: 12.12.12.12
RelyDepth: 9 RealNexthop: 0.0.0.0
NibID |
ID of the NIB. |
Sequence |
Type |
Type of the NIB. |
Flushed |
UserKey0 |
Reserved data 1. |
VrfNthp |
UserKey1 |
Reserved data 2. |
Nexthop |
Next hop address. |
IFIndex |
Interface index |
LocalAddr |
TopoNthp |
Non-base topologies are not supported in the current software version. Index of the topology that contains the next hop. This field displays 0 if the next hop is on the public network. |
RefCnt |
Reference count of the next hop. |
FlushRefCnt |
Reference count of the next hop that is flushed to the FIB. |
Flag |
Flag of the next hop. |
Version |
Version of the next hop. |
x nexthop(s) |
Number of next hops. |
PrefixIndex |
Prefix index of the next hop for an ECMP route. |
OrigNexthop |
Original next hop. |
RelyDepth |
Recursion depth. |
RealNexthop |
Real next hop. |
Output interface. |
localAddr |
TunnelCnt |
Number of tunnels after route recursion. |
Vrf |
VPN instance name. For the public network, this field displays default-vrf. |
TunnelID |
ID of the tunnel after route recursion. |
Topology |
This field is not supported in the current software version. Topology name. The topology name for the public network is base. |
Weight |
ECMP route weight. This field displays 0 for non-ECMP routes. |
Flags |
Flags of the detailed next hop. |
SRPolicyNID |
This field is not supported in the current software version. NIB ID of the route obtained from an SR-MPLS TE policy through route recursion. |
SRInterface |
This field is not supported in the current software version. Output interface of the route obtained from the SR-MPLS TE policy through route recursion. |
ColorWeight |
This field is not supported in the current software version. Weight value of the color attribute in the SR-MPLS TE policy. |
Locator |
This field is not supported in the current software version. IPv6 prefix of the locator to which the SID belongs. If no locator is available, this field displays N/A. |
OrigLinkID |
Original link ID of the SDWAN TTE connection. |
RealLinkID |
Real link ID of the SDWAN TTE connection. |
Use display route-static routing-table to display static routing table information.
display route-static routing-table [ vpn-instance vpn-instance-name ] [ ip-address { mask-length | mask } ]
context-admin
context-operator
vsys-admin
vsys-operator
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays static routing table information for the public network.
ip-address: Specifies the destination IP address in dotted decimal notation. If you do not specify this argument, the command displays all static routing table information.
mask-length: Specifies the mask length, an integer in the range of 0 to 32.
mask: Specifies the subnet mask in dotted decimal notation.
# Display static routing table information.
<Sysname> display route-static routing-table
Total number of routes: 24
Status: * - valid
*Destination: 0.0.0.0/0
NibID: 0x1100000a NextHop: 2.2.2.10
MainNibID: N/A BkNextHop: N/A
BkNibID: N/A Interface: GigabitEthernet1/0/1
TableID: 0x2 BkInterface: GigabitEthernet1/0/2
Flag: 0x82d01 BfdSrcIp: N/A
DbIndex: 0xd BfdIfIndex: 0x0
Type: Normal BfdVrfIndex: 0
TrackIndex: 0xffffffff Label: NULL
Preference: 60 vrfIndexDst: 0
BfdMode: N/A vrfIndexNH: 0
Permanent: 0 Tag: 0
NibID: 0x1100000b NextHop: 2.2.2.11
BkNibID: N/A Interface: GigabitEthernet1/0/3
TableID: 0x2 BkInterface: GigabitEthernet1/0/4
Permanent: 0 Tag: 0
destination |
Destination address/prefix. |
NibID |
ID of the NIB. |
MainNibID |
ID of the primary next hop for static route FRR. |
BkNibID |
ID of the backup next hop for static route FRR. |
NextHop |
Next hop address. |
BkNextHop |
Backup next hop address. |
Output interface of the route. |
BkInterface |
Backup output interface. |
TableID |
ID of the table to which the route belongs. |
Flag |
Flag of the route. |
DbIndex |
Index of the database to which the route belongs. |
Type |
Route type: · Normal. · DHCP. · NAT. · IPsec. |
BfdSrcIp |
Source IP address of the indirect BFD session. |
BfdIfIndex |
Index of the interface where BFD is enabled. |
BfdVrfIndex |
Index of the VPN instance where BFD is enabled. This field displays 0 if BFD is enabled for the public network. |
BfdMode |
BFD session mode: · N/A—No BFD session is configured. · Ctrl—Control packet mode · Echo—Echo packet mode. |
TrackIndex |
NQA Track index. |
Label |
This field is not supported in the current software version. Label of the route. |
vrfIndexDst |
Index of VPN instance that the destination belongs to. For the public network, this field displays 0. |
vrfIndexNH |
Index of the VPN instance that the next hop belongs to. For the public network, this field displays 0. |
Permanent |
Permanent static route flag. 1 indicates a permanent static route. |
BfdStatic |
Name of the static BFD session associated with the route. If no static BFD session is associated with the route, this field is not available. |
ip route-static
Use ip route-static to configure a static route.
Use undo ip route-static to delete a static route.
In non-default vSystem view:
ip route-static { dest-address { mask-length | mask } | group group-name } interface-type interface-number [ dhcp | next-hop-address ] [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | bfd { control-packet | echo-packet | static session-name } | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
ip route-static { dest-address { mask-length | mask } | group group-name } next-hop-address [ bfd { control-packet bfd-source ip-address | static session-name } | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
ip route-static { dest-address { mask-length | mask } | group group-name } vpn-instance d-vpn-instance-name next-hop-address [ bfd { control-packet bfd-source ip-address | static session-name } | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
ip route-static dest-address { mask-length | mask } vpn-instance d-vpn-instance-name [ track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
undo ip route-static { dest-address { mask-length | mask } | group group-name } [ interface-type interface-number [ dhcp | next-hop-address ] | next-hop-address | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference ]
ip route-static dest-address { mask-length | mask } interface-type interface-number [ dhcp | next-hop-address ] [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | bfd { control-packet | echo-packet | static session-name } | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
ip route-static dest-address { mask-length | mask } next-hop-address [ bfd { control-packet bfd-source ip-address | static session-name } | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
ip route-static dest-address { mask-length | mask } public [ track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
undo ip route-static dest-address { mask-length | mask } [ interface-type interface-number [ next-hop-address ] | next-hop-address | public ] [ preference preference ]
No static route is configured.
context-admin
vsys-admin
dest-address: Specifies the destination IP address of the static route, in dotted decimal notation.
group group-name: Specifies a static route group by its name, a case-sensitive string of 1 to 31 characters. Non-default vSystems do not support this parameter.
vpn-instance d-vpn-instance-name: Specifies a destination MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If a destination VPN instance is specified, packets will search for the output interface in the destination VPN instance based on the configured next hop address.
public: Specifies the default vSystem where the destination address of the static route resides. If you specify this keyword, you do not need to specify a next hop address.
interface-type interface-number: Specifies an output interface by its type and number. For more information, see Layer 3—IP Routing Configuration Guide.
dhcp: Specifies the default router designated by the DHCP server for the output interface as the next hop of the static route.
next-hop-address: Specifies the IP address of the next hop, in dotted decimal notation. For more information, see Layer 3—IP Routing Configuration Guide.
backup-interface interface-type interface-number: Specifies a backup output interface by its type and number. If the backup output interface is an NBMA interface or broadcast interface and not a P2P interface, you must specify the backup next hop address.
backup-nexthop backup-nexthop-address: Specifies a backup next hop address.
bfd: Enables BFD to detect reachability of the static route's next hop. When the next hop is unreachable, the system immediately switches to the backup route.
control-packet: Specifies the BFD control mode.
bfd-source ip-address: Specifies the source IP address of BFD packets. As a best practice, specify the loopback interface address.
echo-packet: Specifies the BFD echo mode.
static session-name: Specifies a static BFD session by its name, a case-sensitive string of 1 to 64 characters. You can specify a nonexistent static BFD session. For the configuration to take effect, you must create the static BFD session.
permanent: Specifies the route as a permanent static route. After you specify this keyword, the static route will always be active, even if the output interface is down.
track track-entry-number: Associates the static route with a track entry specified by its number in the range of 1 to 1024. For more information about Track, see Network Management and Monitoring Configuration Guide.
preference preference: Specifies a preference for the static route, in the range of 1 to 255. The default is 60.
tag tag-value: Sets a tag value for marking the static route, in the range of 1 to 4294967295. The default is 0. Tags of routes are used for route control in routing policies. For more information about routing policies, see Layer 3—IP Routing Configuration Guide.
description text: Configures a description of 1 to 60 characters for the static route. The description can include special characters, such as the space, except the question mark (?).
If the destination IP address and the mask are both 0.0.0.0 (or 0), the configured route is a default route. The default route is used for forwarding a packet matching no entry in the routing table.
To realize intercommunication between the default vSystem and a non-default vSystem, use the following commands:
· In the system view of the default vSystem, execute the ip route-static dest-address { mask-length | mask } vpn-instance d-vpn-instance-name [ track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ] command. This command allows the default vSystem to access a non-default vSystem. The d-vpn-instance-name argument specifies the name of the VPN instance that has the same name as the non-default vSystem.
· In the system view of a non-default vSystem, execute the ip route-static dest-address { mask-length | mask } public [ track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ] command. This command allows the non-default vSystem to access the default vSystem.
Implement different routing policies to configure different route preferences. For example, to enable load sharing for multiple routes to the same destination, assign the same preference to the routes. To enable the routes to back up one another, assign different preferences to them.
Follow these guidelines when you specify the output interface or the next hop address of the static route:
· If the output interface is a Null 0 interface, no next hop address is required.
· If the output interface is a point-to-point interface, you can specify only the output interface. You do not need to change the configuration of the route even if the peer address is changed.
· NBMA or P2MP interfaces need IP address-to-link layer address mappings for successful packet delivery. As a best practice, specify the next hop address for the route at the same time if the output interface is an NBMA or P2MP interface.
· Multiple next hops might exist if the output interface is a broadcast interface (for example, an Ethernet interface or VLAN interface). You must specify both the output interface and next hop IP address for the static route.
Follow these guidelines when you configure a static route:
· Enabling BFD for a flapping route could worsen the route flapping situation. Therefore, use it with caution. For more information about BFD, see Network Management and Monitoring Configuration Guide.
· For static routing-Track-NQA collaboration, you must configure the same VPN instance ID for the next hop to be detected and the NQA operation.
· If a static route needs route recursion, the associated track entry must monitor the next hop of the recursive route instead of that of the static route. Otherwise, a valid route might be mistakenly considered invalid.
If you specify a static route group, all prefixes in the static route group will be assigned the next hop and output interface specified by using this command.
After an interface obtains an IP address and gateway address through DHCP, the device automatically generates a static route with the interface as the output interface. The destination address of the static route is 0.0.0.0/0 and the next hop of the static route is the default router (the gateway address designated by the DHCP server). This static route cannot form ECMP routes with manually configured static routes. The device uses this static route to guide traffic forwarding only after the manually configured static routes become invalid.
Specify the dhcp keyword to use both the automatically generated static route and the manually configured static routes to guide traffic forwarding. This keyword is applicable when the device has dual egress WAN links.
The dhcp keyword enables the device to automatically generate a static route destined for the specified network with the DHCP-designated default router of the output interface as the next hop. This static route takes effect only after the output interface obtains an IP address and gateway address through DHCP, and becomes invalid upon the DHCP lease expiration. The next hop of this static route changes as the gateway address of the output interface changes. In addition, this static route can form ECMP routes with manually configured static routes.
To specify the dhcp keyword, make sure the output interface of the static route is a broadcast interface.
# Configure a static route, whose destination address is 1.1.1.1/24, next hop address is 2.2.2.2, tag value is 45, and description information is for internet.
[Sysname] ip route-static 1.1.1.1 24 2.2.2.2 tag 45 description for internet
display ip routing-table protocol
ip route-static-group
prefix
Use ip route-static default-preference to configure a default preference for static routes.
Use undo ip route-static default-preference to restore the default.
ip route-static default-preference default-preference
The default preference of static routes is 60.
context-admin
default-preference: Specifies a default preference for static routes, in the range of 1 to 255.
If no preference is specified for a static route, the default preference applies.
When the default preference is reconfigured, it applies only to newly added static routes.
# Set a default preference of 120 for static routes.
[Sysname] ip route-static default-preference 120
Use ip route-static fast-reroute auto to configure static route FRR to automatically select a backup next hop.
Use undo ip route-static fast-reroute auto to disable static route FRR from automatically selecting a backup next hop.
Static route FRR is disabled from automatically selecting a backup next hop.
context-admin
If you execute this command on the default vSystem, this command takes effect on all vSystems.
# Configure static route FRR to automatically select a backup next hop.
[Sysname] ip route-static fast-reroute auto
Use ip route-static primary-path-detect bfd echo to enable BFD echo packet mode for static route FRR.
Use undo ip route-static primary-path-detect bfd to disable BFD echo packet mode for static route FRR.
BFD echo packet mode for static route FRR is disabled.
context-admin
This command enables static route FRR to use BFD echo packet mode for fast failure detection on the primary link.
# Enable BFD echo packet mode for static route FRR.
[Sysname] ip route-static 1.1.1.1 32 gigabitethernet 1/0/1 2.2.2.2 backup-interface gigabitethernet 1/0/2 backup-nexthop 3.3.3.3
[Sysname] ip route-static primary-path-detect bfd echo
ip route-static vpn-instance
Use ip route-static vpn-instance to configure a static route in a VPN instance.
Use undo ip route-static vpn-instance to delete a static route from a VPN instance.
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number [ dhcp | next-hop-address ] [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | bfd { control-packet | echo-packet | static session-name } | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } vpn-instance d-vpn-instance-name next-hop-address [ bfd { control-packet bfd-source ip-address | static session-name } | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } next-hop-address [ public ] [ bfd { control-packet bfd-source ip-address | static session-name } | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } vpn-instance d-vpn-instance-name [ track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name group group-name interface-type interface-number [ dhcp | next-hop-address ] [ bfd { control-packet | echo-packet | static session-name } | backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] ] [ preference preference ] [ tag tag-value ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name group group-name next-hop-address [ public ] [ bfd { control-packet bfd-source ip-address | static session-name } | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
undo ip route-static vpn-instance s-vpn-instance-name { dest-address { mask-length | mask } | group group-name } [ interface-type interface-number [ dhcp | next-hop-address ] | next-hop-address [ public ] | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference ]
No static route is configured in a VPN instance.
context-admin
s-vpn-instance-name: Specifies a source MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. Each VPN instance has its own routing table, and the configured static route is installed in the routing tables of the specified VPN instances.
backup-interface interface-type interface-number: Specifies a backup output interface by its type and number. If the backup output interface is a non-P2P interface (an NBMA interface or broadcast interface), you must specify the backup next hop address.
public: Specifies the public network, which indicates that the specified next hop address is on the public network. The device searches for the output interface in the public network based on the next hop address for packets matching the static route. If you do not specify this keyword or the destination VPN instance, the specified next hop address is in the source VPN instance. The device searches for the output interface in the source VPN instance based on the next hop address for packets matching the static route.
To realize intercommunication between two non-default vSystems, use the ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } vpn-instance d-vpn-instance-name [ track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ] command in the system view of the default vSystem. The s-vpn-instance-name and d-vpn-instance-name arguments specify the names of the VPN instances that have the same names as the non-default vSystems.
· If the output interface is a broadcast interface (for example, an Ethernet interface or VLAN interface), the device uses the next hop IP address to obtain the MAC address of the next hop. Therefore, you must specify both the output interface and next hop IP address.
· If a static route needs route recursion, the associated track entry must monitor the next hop of the related route instead of that of the recursive static route. Otherwise, a valid route might be mistakenly considered invalid.
# Configure a static route in VPN instance vpn1, whose destination address is 1.1.1.1/24, next hop address is 2.2.2.2 in VPN instance vpn2, tag value is 45, and description information is for internet.
[Sysname] ip route-static vpn-instance vpn1 1.1.1.1 24 vpn-instance vpn2 2.2.2.2 tag 45 description for internet
prefix
Use ip route-static-group to create a static route group and enter its view, or enter the view of an existing static route group.
Use undo ip route-static-group to delete a static route group.
ip route-static-group group-name
undo ip route-static-group group-name
No static route groups exist.
context-admin
group-name: Specifies the static route group name, a case-sensitive string of 1 to 31 characters.
# Create static route group test and enter its view.
[Sysname] ip route-static-group test
[Sysname-route-static-group-test]
ip route-static
prefix
prefix
Use prefix to add a static route prefix to a static route group.
Use undo prefix to delete a static route prefix from a static route group.
prefix dest-address { mask-length | mask }
undo prefix dest-address { mask-length | mask }
No static route prefix is added to a static route group.
Static route group view
context-admin
Execute this command repeatedly to add multiple static route prefixes to a static route group.
After you add static route prefixes to a static route group, you can specify that group in the ip route-static group command to configure static routes with the prefixes. To configure more static routes, you only need to add new static route prefixes to the group.
# Add static route prefix 1.1.1.1/32 to static route group test.
[Sysname-route-static-group-test] prefix 1.1.1.1 32
ip route-static
