12-Layer 2—LAN Switching Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath F1000[F5000] Firewalls Series Configuration Guides(V7)-6W90012-Layer 2—LAN Switching Configuration Guide
01-MAC address table configuration
01-MAC address table configuration 124.58 KB
Configuring the MAC address table
About the MAC address table
An Ethernet device uses a MAC address table to forward frames. A MAC address entry includes a destination MAC address, an outgoing interface, and a VLAN ID. When the device receives a frame, it uses the destination MAC address of the frame to look for a match in the MAC address table.
·     The device forwards the frame out of the outgoing interface in the matching entry if a match is found.
·     The device floods the frame in the VLAN of the frame if no match is found.
How a MAC address entry is created
The entries in the MAC address table include entries automatically learned by the device and entries manually added.
MAC address learning
The device can automatically populate its MAC address table by learning the source MAC addresses of incoming frames on each interface.
The device performs the following operations to learn the source MAC address of incoming packets:
1.     Checks the source MAC address (for example, MAC-SOURCE) of the frame.
2.     Looks up the source MAC address in the MAC address table.
¡     The device updates the entry if an entry is found.
¡     The device adds an entry for MAC-SOURCE and the incoming port if no entry is found.
When the device receives a frame destined for MAC-SOURCE after learning this source MAC address, the device performs the following operations:
1.     Finds the MAC-SOURCE entry in the MAC address table.
2.     Forwards the frame out of the port in the entry.
The device performs the learning process for each incoming frame with an unknown source MAC address until the table is fully populated.
Manually configuring MAC address entries
Dynamic MAC address learning does not distinguish between illegitimate and legitimate frames, which can invite security hazards. When Host A is connected to Port A, a MAC address entry will be learned for the MAC address of Host A (for example, MAC A). When an illegal user sends frames with MAC A as the source MAC address to Port B, the device performs the following operations:
1.     Learns a new MAC address entry with Port B as the outgoing interface and overwrites the old entry for MAC A.
2.     Forwards frames destined for MAC A out of Port B to the illegal user.
As a result, the illegal user obtains the data of Host A. To improve the security for Host A, manually configure a static entry to bind Host A to Port A. Then, the frames destined for Host A are always sent out of Port A. Other hosts using the forged MAC address of Host A cannot obtain the frames destined for Host A.
Types of MAC address entries
A MAC address table can contain the following types of entries:
·     Static entries—A static entry is manually added to forward frames with a specific destination MAC address out of the associated interface, and it never ages out. A static entry has higher priority than a dynamically learned one.
·     Dynamic entries—A dynamic entry can be manually configured or dynamically learned to forward frames with a specific destination MAC address out of the associated interface. A dynamic entry might age out. A manually configured dynamic entry has the same priority as a dynamically learned one.
·     Blackhole entries—A blackhole entry is manually configured and never ages out. A blackhole entry is configured for filtering out frames with a specific source or destination MAC address. For example, to block all frames destined for or sourced from a user, you can configure the MAC address of the user as a blackhole MAC address entry. A blackhole entry has higher priority than a dynamically learned one.
A static or blackhole MAC address entry can overwrite a dynamic MAC address entry, but not vice versa. A static entry and a blackhole entry cannot overwrite each other.
MAC address table tasks at a glance
All MAC address table configuration tasks are optional.
To configure the MAC address table, perform the following tasks:
·     Configuring MAC address entries
¡     Adding or modifying a static or dynamic MAC address entry
¡     Adding or modifying a blackhole MAC address entry
·     Setting the aging timer for dynamic MAC address entries
·     Configuring MAC address learning
¡     Disabling MAC address learning
¡     Setting the MAC learning limit
¡     Configuring the unknown frame forwarding rule after the MAC learning limit is reached
¡     Assigning MAC learning priority to interfaces
·     Enabling SNMP notifications for the MAC address table
About MAC address entry-based frame forwarding
A frame whose source MAC address matches different types of MAC address entries is processed differently.
Static MAC address entry
Forwards the frame according to the destination MAC address regardless of whether the frame's ingress interface is the same as that in the entry.
Blackhole MAC address entry
Drops the frame.
Dynamic MAC address entry
·     Learns the MAC address of the frames received on a different interface from that in the entry and overwrites the original entry.
·     Forwards the frame received on the same interface as that in the entry and updates the aging timer for the entry.
Restrictions and guidelines for MAC address entry configuration
You cannot add a dynamic MAC address entry if a learned entry already exists with a different outgoing interface for the MAC address.
The manually configured static and blackhole MAC address entries cannot survive a reboot if you do not save the configuration. The manually configured dynamic MAC address entries are lost upon reboot whether or not you save the configuration.
Do not configure the following MAC addresses as static, dynamic, or blackhole MAC addresses:
·     Reserved MAC addresses of the device.
·     MAC addresses of Layer 3 Ethernet interfaces or subinterfaces.
·     MAC addresses of Layer 3 aggregate interfaces or subinterfaces.
For information about bridge MAC addresses, see IRF in Virtual Technologies Configuration Guide.
Prerequisites for MAC address entry configuration
Before manually configuring a MAC address entry for an interface, make sure the VLAN in the entry has been created.
Adding or modifying a static or dynamic MAC address entry globally
2.     Add or modify a static or dynamic MAC address entry.
By default, no MAC address entry is configured globally.
Make sure you have assigned the interface to the VLAN.
Adding or modifying a static or dynamic MAC address entry on an interface
2.     Enter interface view.
¡     Enter Layer 2 Ethernet interface view.
¡     Enter Layer 2 aggregate interface view.
3.     Add or modify a static or dynamic MAC address entry.
mac-address { dynamic | static } mac-address vlan vlan-id
By default, no MAC address entry is configured on an interface.
2.     Add or modify a blackhole MAC address entry.
By default, no blackhole MAC address entry is configured.
For security and efficient use of table space, the MAC address table uses an aging timer for each dynamic MAC address entry. If a dynamic MAC address entry is not updated before the aging timer expires, the device deletes the entry. This aging mechanism ensures that the MAC address table can promptly update to accommodate latest network topology changes.
A stable network requires a longer aging interval, and an unstable network requires a shorter aging interval.
An aging interval that is too long might cause the MAC address table to retain outdated entries. As a result, the MAC address table resources might be exhausted, and the MAC address table might fail to update its entries to accommodate the latest network changes.
An interval that is too short might result in removal of valid entries, which would cause unnecessary floods and possibly affect the device performance.
To reduce floods on a stable network, set a long aging timer or disable the timer to prevent dynamic entries from unnecessarily aging out. Reducing floods improves the network performance. Reducing flooding also improves the security because it reduces the chances for a data frame to reach unintended destinations.
2.     Set the aging timer for dynamic MAC address entries.
The default setting is 300 seconds.
About disabling MAC address learning
MAC address learning is enabled by default. To prevent the MAC address table from being saturated when the device is experiencing attacks, disable MAC address learning. For example, you can disable MAC address learning to prevent the device from being attacked by a large amount of frames with different source MAC addresses.
After MAC address learning is disabled, existing dynamic MAC address entries can age out.
Disabling global MAC address learning
After you disable global MAC address learning, the device cannot learn MAC addresses on any interfaces.
2.     Disable global MAC address learning.
undo mac-address mac-learning enable
By default, global MAC address learning is enabled.
Disabling MAC address learning on an interface
When global MAC address learning is enabled, you can disable MAC address learning on a single interface.
3.     Disable MAC address learning on the interface.
By default, MAC address learning is enabled on an interface.
Setting the MAC learning limit on interfaces
This feature limits the MAC address table size. A large MAC address table will degrade forwarding performance.
3.     Set the MAC learning limit on the interface.
By default, the maximum number of MAC addresses that an interface can learn is restricted by hardware capability of the device.
In this document, unknown frames refer to frames whose source MAC addresses are not in the MAC address table.
About unknown frame forwarding rule configuration
You can enable or disable forwarding of unknown frames after the MAC learning limit is reached.
Configuring the device to forward unknown frames after the MAC learning limit on an interface is reached
3.     Configure the device to forward unknown frames received on the interface after the MAC learning limit on the interface is reached.
mac-address max-mac-count enable-forwarding
By default, the device can forward unknown frames received on an interface after the MAC learning limit on the interface is reached.
The MAC learning priority mechanism assigns either low priority or high priority to an interface. An interface with high priority can learn MAC addresses as usual. However, an interface with low priority is not allowed to learn MAC addresses already learned on a high-priority interface.
The MAC learning priority mechanism can help defend your network against MAC address spoofing attacks. In a network that performs MAC-based forwarding, an upper layer device MAC address might be learned by a downlink interface because of a loop or attack to the downlink interface. To avoid this issue, perform the following tasks:
·     Assign high MAC learning priority to an uplink interface.
·     Assign low MAC learning priority to a downlink interface.
3.     Assign MAC learning priority to the interface.
mac-address mac-learning priority { high | low }
By default, low MAC learning priority is used.
To report critical MAC address move events to an NMS, enable SNMP notifications for the MAC address table. For MAC address move event notifications to be sent correctly, you must also configure SNMP on the device.
When SNMP notifications are disabled for the MAC address table, the device sends the generated logs to the information center. To display the logs, configure the log destination and output rule configuration in the information center.
For more information about SNMP and information center configuration, see the network management and monitoring configuration guide for the device.
2.     Enable SNMP notifications for the MAC address table.
snmp-agent trap enable mac-address
By default, SNMP notifications are enabled for the MAC address table.
When SNMP notifications are disabled for the MAC address table, syslog messages are sent to notify important events on the MAC address table module.
Display and maintenance commands for MAC address table
Display MAC address table information.
Display the aging timer for dynamic MAC address entries.
display mac-address aging-time
Display the system or interface MAC address learning state.
