00-Preface | 111.07 KB |
Preface
· This configuration guide describes the fundamentals and configuration procedures for NAT, NAT66, and AFT.
· Security zones, security policies, object groups, object policies, APR, and session management.
· User access and authentication features (such as AAA, portal, user identification, password control, and PKI).
· Data security features (such as public key management, SSL, SSH, and crypto engine).
· Attack protection features (such as ASPF, connection limit, IP source guard, ARP attack protection, ND attack defense, uRPF, attack detection and prevention, and IP-MAC binding).
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
