- 02-Layer 2—LAN Switching Configuration Guide
- 01-MAC address table configuration
- 02-Bulk interface configuration
- 03-Ethernet interface configuration
- 04-Ethernet link aggregation configuration
- 05-M-LAG configuration
- 06-Port isolation configuration
- 07-VLAN configuration
- 08-MVRP configuration
- 09-Loopback, null, and inloopback interface configuration
- 10-QinQ configuration
- 11-Loop detection configuration
- 12-Spanning tree configuration
- 13-LLDP configuration
- 14-L2PT configuration
- 15-Service loopback group configuration
- 16-Cut-through Layer 2 forwarding configuration
| 10-QinQ configuration | 168.23 KB |
Restrictions and guidelines: QinQ configuration
Configuring the TPID for VLAN tags
Configuring the global TPID value
Configuring an interface-specific TPID value
Setting the 802.1p priority in SVLAN tags
About the 802.1p priority in SVLAN tags
Prerequisites for setting the 802.1p priority in SVLAN tags
Creating a traffic class and configuring CVLAN match criteria
Creating a traffic behavior and configuring a priority marking action for SVLAN tags
Display and maintenance commands for QinQ
Example: Configuring basic QinQ
Configuring QinQ
This document uses the following terms:
· CVLAN—Customer network VLANs, also called inner VLANs, refer to VLANs that a customer uses on the private network.
· SVLAN—Service provider network VLANs, also called outer VLANs, refer to VLANs that a service provider uses to transmit VLAN tagged traffic for customers.
About QinQ
802.1Q-in-802.1Q (QinQ) adds an 802.1Q tag to 802.1Q tagged customer traffic. It enables a service provider to extend Layer 2 connections across an Ethernet network between customer sites.
QinQ benefits
QinQ provides the following benefits:
· Enables a service provider to use a single SVLAN to convey multiple CVLANs for a customer.
· Enables customers to plan CVLANs without conflicting with SVLANs.
· Enables customers to keep their VLAN assignment schemes unchanged when the service provider changes its VLAN assignment scheme.
· Allows different customers to use overlapping CVLAN IDs. Devices in the service provider network make forwarding decisions based on SVLAN IDs instead of CVLAN IDs.
How QinQ works
As shown in Figure 1, a QinQ frame transmitted over the service provider network carries the following tags:
· CVLAN tag—Identifies the VLAN to which the frame belongs when it is transmitted in the customer network.
· SVLAN tag—Identifies the VLAN to which the QinQ frame belongs when it is transmitted in the service provider network. The service provider allocates the SVLAN tag to the customer.
The devices in the service provider network forward a tagged frame according to its SVLAN tag only. The CVLAN tag is transmitted as part of the frame's payload.
Figure 1 Single-tagged Ethernet frame header and double-tagged Ethernet frame header
As shown in Figure 2, customer A has remote sites CE 1 and CE 4. Customer B has remote sites CE 2 and CE 3. The CVLANs of the two customers overlap. The service provider assigns SVLANs 3 and 4 to customers A and B, respectively.
When a tagged Ethernet frame from CE 1 arrives at PE 1, the PE tags the frame with SVLAN 3. The double-tagged Ethernet frame travels over the service provider network until it arrives at PE 2. PE 2 removes the SVLAN tag of the frame, and then sends the frame to CE 4.
Figure 2 Typical QinQ application scenario
QinQ implementations
QinQ is enabled on a per-port basis. The link type of a QinQ-enabled port can be access, hybrid, or trunk. The QinQ tagging behaviors are the same across these types of ports.
A QinQ-enabled port tags all incoming frames (tagged or untagged) with the PVID tag.
· If an incoming frame already has one tag, it becomes a double-tagged frame.
· If the frame does not have any 802.1Q tags, it becomes a frame tagged with the PVID.
QinQ provides the most basic VLAN manipulation method to tag all incoming frames (tagged or untagged) with the PVID tag.
For more information about VLAN mappings, see "Configuring VLAN mapping." For more information about QoS, see ACL and QoS Configuration Guide.
Protocols and standards
· IEEE 802.1Q, IEEE Standard for Local and Metropolitan Area Networks-Virtual Bridged Local Area Networks
· IEEE 802.1ad, IEEE Standard for Local and Metropolitan Area Networks-Virtual Bridged Local Area Networks-Amendment 4: Provider Bridges
When you configure QinQ, follow these restrictions and guidelines:
· The inner 802.1Q tag of QinQ frames is treated as part of the payload. As a best practice to ensure correct transmission of QinQ frames, set the MTU to a minimum of 1504 bytes for each port on their forwarding path. This value is the sum of the default Ethernet interface MTU (1500 bytes) and the length (4 bytes) of a VLAN tag.
Enabling QinQ
Enable QinQ on customer-side ports of PEs. A QinQ-enabled port tags an incoming frame with its PVID.
1. Enter system view.
2. Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view.
3. Set the port link type.
By default, the link type of a port is access.
4. Configure the port to allow packets from its PVID and the CVLANs to pass through.
¡ Assign the access port to the specified VLAN.
port access vlan vlan-id
By default, all access ports belong to VLAN 1.
The PVID and CVLAN of an access port are the VLAN to which the port belongs. The port sends packets from the VLAN untagged.
¡ Configure the hybrid port to send packets from its PVID untagged and send packets from the CVLANs tagged.
By default, the hybrid port is an untagged member of the VLAN to which the port belongs when its link type is access.
¡ Configure trunk port to allow packets from its PVID and the CVLANs to pass through.
By default, a trunk port allows packets only from VLAN 1 to pass through.
5. Enable QinQ on the port.
qinq enable
By default, QinQ is disabled on the port.
About TPID
TPID identifies a frame as an 802.1Q tagged frame. The TPID value varies by vendor. On an H3C device, the TPID in the 802.1Q tag added on a QinQ-enabled port is 0x8100 by default, in compliance with IEEE 802.1Q. In a multi-vendor network, make sure the TPID setting is the same between directly connected devices so 802.1Q tagged frames can be identified correctly.
TPID settings include CVLAN TPID and SVLAN TPID.
A QinQ-enabled port uses the CVLAN TPID to match incoming tagged frames. An incoming frame is handled as untagged if its TPID is different from the CVLAN TPID.
SVLAN TPIDs are configurable on a per-port basis. A service provider-side port uses the SVLAN TPID to replace the TPID in outgoing frames' SVLAN tags and match incoming tagged frames. An incoming frame is handled as untagged if the TPID in its outer VLAN tag is different from the SVLAN TPID.
For example, a PE device is connected to a customer device that uses the TPID 0x8200 and to a provider device that uses the TPID 0x9100. For correct packet processing, you must set the CVLAN TPID and SVLAN TPID to 0x8200 and 0x9100 on the PE, respectively.
The TPID field is at the same position as the EtherType field in an untagged Ethernet frame. To ensure correct packet type identification, do not set the TPID value to any of the values listed in Table 1.
Table 1 Reserved EtherType values
Protocol type |
Value |
ARP |
0x0806 |
PUP |
0x0200 |
RARP |
0x8035 |
IP |
0x0800 |
IPv6 |
0x86dd |
PPPoE |
0x8863/0x8864 |
MPLS |
0x8847/0x8848 |
IPX/SPX |
0x8137 |
IS-IS |
0x8000 |
LACP |
0x8809 |
LLDP |
0x88cc |
802.1X |
0x888e |
802.1ag |
0x8902 |
Cluster |
0x88a7 |
Reserved |
0xfffd/0xfffe/0xffff |
The TPID value in VLAN tags is typically configured on the service provider-side ports of PEs.
2. Set the global SVLAN TPID.
qinq ethernet-type service-tag hex-value
The default setting is 0x8100 for SVLAN tags.
3. Set the interface-specific CVLAN TPID or SVLAN TPID.
qinq ethernet-type { customer-tag | service-tag } hex-value
If the device supports global TPID configuration, the default interface-specific TPID value in the SVLAN and CVLAN tags is the same as the global TPID value.
If the device does not support global TPID configuration, the default TPID value is 0x8100 in both SVLAN and CVLAN tags.
By default, the 802.1p priority in the SVLAN tag added by a QinQ-enabled port depends on the priority trust mode on the port.
· If the 802.1p priority in frames is trusted, the device copies the 802.1p priority in the CVLAN tag to the SVLAN tag.
· If port priority is trusted, the port priority (0 by default) is used as the 802.1p priority in the SVLAN tag.
You can configure a QoS policy to modify the 802.1p priority in SVLAN tags as follows:
· Modify the 802.1p priority in the SVLAN tag based on the 802.1p priority in the CVLAN tag or the CVLAN ID.
· Copy the 802.1p priority in the CVLAN tag to the SVLAN tag.
For more information about QoS policies and priority trust mode, see ACL and QoS Configuration Guide.
1. Enable QinQ. For more information, see "Enabling QinQ."
To use the CVLAN ID or 802.1p priority of the CVLAN tag to set the 802.1p priority of the SVLAN tag, you must first enable QinQ on the port.
2. Use the qos trust dot1p command to configure the port to trust the 802.1p priority in incoming frames. For more information, see ACL and QoS Configuration Guide.
This setting is required if the remark dot1p command is configured. It is optional if the remark dot1p customer-dot1p-trust command is configured.
Tasks at a glance
To use QoS policies to set the 802.1p priority in SVLAN tags, perform the following tasks:
1. Creating a traffic class and configuring CVLAN match criteria
2. Creating a traffic behavior and configuring a priority marking action for SVLAN tags
2. Create a traffic class and enter its view.
3. Configure CVLAN match criteria.
Choose one option as needed:
¡ Match CVLAN IDs.
if-match customer-vlan-id vlan-id-list
¡ Match 802.1p priority.
if-match customer-dot1p dot1p-value&<1-8>
2. Create a traffic behavior and enter its view.
3. Configure a priority marking action for SVLAN tags.
¡ Replace the priority in the SVLAN tags of matching frames with the configured priority.
remark dot1p dot1p-value
¡ Copy the 802.1p priority in the CVLAN tag to the SVLAN tag.
The default setting varies by device model.
Creating a QoS policy
2. Create a QoS policy and enter its view.
qos policy policy-name
3. Specify the traffic behavior for the traffic class in the QoS policy.
classifier classifier-name behavior behavior-name
Applying the QoS policy
2. Enter Layer 2 Ethernet interface view.
3. Apply the QoS policy to the inbound direction of the port.
Task |
Command |
Display QinQ-enabled ports. |
display qinq [ interface interface-type interface-number ] |
QinQ configuration examples
As shown in Figure 3:
· The service provider assigns VLAN 100 to Company A's VLANs 10 through 70.
· The service provider assigns VLAN 200 to Company B's VLANs 30 through 90.
· The devices between PE 1 and PE 2 in the service provider network use a TPID value of 0x8200.
Configure QinQ on PE 1 and PE 2 to transmit traffic in VLANs 100 and 200 for Company A and Company B, respectively.
For the QinQ frames to be identified correctly, set the SVLAN TPID to 0x8200 on the service provider-side ports of PE 1 and PE 2.
1. Configure PE 1:
# Configure HundredGigE 1/1/1 as a trunk port, and assign it to VLAN 100 and VLANs 10 through 70.
<PE1> system-view
[PE1] interface hundredgige 1/1/1
[PE1-HundredGigE1/1/1] port link-type trunk
[PE1-HundredGigE1/1/1] port trunk permit vlan 100 10 to 70
# Set the PVID of HundredGigE 1/1/1 to VLAN 100.
[PE1-HundredGigE1/1/1] port trunk pvid vlan 100
# Enable QinQ on HundredGigE 1/1/1.
[PE1-HundredGigE1/1/1] qinq enable
[PE1-HundredGigE1/1/1] quit
# Configure HundredGigE 1/1/2 as a trunk port, and assign it to VLANs 100 and 200.
[PE1] interface hundredgige 1/1/2
[PE1-HundredGigE1/1/2] port link-type trunk
[PE1-HundredGigE1/1/2] port trunk permit vlan 100 200
# Set the TPID value in the SVLAN tags to 0x8200 on HundredGigE 1/1/2.
[PE1-HundredGigE1/1/2] qinq ethernet-type service-tag 8200
[PE1-HundredGigE1/1/2] quit
# Configure HundredGigE 1/1/3 as a trunk port, and assign it to VLAN 200 and VLANs 30 through 90.
[PE1] interface hundredgige 1/1/3
[PE1-HundredGigE1/1/3] port link-type trunk
[PE1-HundredGigE1/1/3] port trunk permit vlan 200 30 to 90
# Set the PVID of HundredGigE 1/1/3 to VLAN 200.
[PE1-HundredGigE1/1/3] port trunk pvid vlan 200
# Enable QinQ on HundredGigE 1/1/3.
[PE1-HundredGigE1/1/3] qinq enable
[PE1-HundredGigE1/1/3] quit
2. Configure PE 2:
# Configure HundredGigE 1/1/1 as a trunk port, and assign it to VLAN 200 and VLANs 30 through 90.
<PE2> system-view
[PE2] interface hundredgige 1/1/1
[PE2-HundredGigE1/1/1] port link-type trunk
[PE2-HundredGigE1/1/1] port trunk permit vlan 200 30 to 90
# Set the PVID of HundredGigE 1/1/1 to VLAN 200.
[PE2-HundredGigE1/1/1] port trunk pvid vlan 200
[PE2-HundredGigE1/1/1] qinq enable
[PE2-HundredGigE1/1/1] quit
[PE2] interface hundredgige 1/1/2
[PE2-HundredGigE1/1/2] port link-type trunk
[PE2-HundredGigE1/1/2] port trunk permit vlan 100 200
[PE2-HundredGigE1/1/2] qinq ethernet-type service-tag 8200
[PE2-HundredGigE1/1/2] quit
# Configure HundredGigE 1/1/3 as a trunk port, and assign it to VLAN 100 and VLANs 10 through 70.
[PE2] interface hundredgige 1/1/3
[PE2-HundredGigE1/1/3] port link-type trunk
[PE2-HundredGigE1/1/3] port trunk permit vlan 100 10 to 70
# Set the PVID of HundredGigE 1/1/3 to VLAN 100.
[PE2-HundredGigE1/1/3] port trunk pvid vlan 100
[PE2-HundredGigE1/1/3] qinq enable
[PE2-HundredGigE1/1/3] quit
3. Configure the devices between PE 1 and PE 2:
# Set the MTU to a minimum of 1504 bytes for each port on the path of QinQ frames. (Details not shown.)
# Configure all ports on the forwarding path to allow frames from VLANs 100 and 200 to pass through without removing the VLAN tag. (Details not shown.)
