00-Preface | 110.67 KB |
Preface
This configuration guide describes OpenFlow fundamentals and configuration. OpenFlow separates the data forwarding and routing decision functions. An OpenFlow switch matches and forwards packets by using the flow table entries obtained from a controller.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the routers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
