HomeSupportSwitchesS5590-EI SeriesConfigure & DeployConfiguration GuidesH3C S5590-HI[S5590-EI][S5500V3-HI] Switch Series Configuration Guides-R8307Pxx-6W10009-Security Configuration Guide
23-MACsec configuration
23-MACsec configuration 297.95 KB
Configuring MACsec
About MACsec
Media Access Control Security (MACsec) secures data communication on IEEE 802 LANs. MACsec provides services such as data encryption, frame integrity check, and data origin validation for frames on the MAC sublayer of the Data Link Layer.
Basic concepts
CA
Connectivity association (CA) is a group of participants that use the same key and key algorithm. The encryption key used by the CA participants is called a connectivity association key (CAK). The following types of CAKs are available:
·     Pairwise CAK—Used by CAs that have two participants.
·     Group CAK—Used by CAs that have more than two participants.
The pairwise CAK is used most often because MACsec is typically applied to point-to-point networks.
A CAK can be an encryption key generated during 802.1X authentication or a user-configured preshared key. The user-configured preshared key takes precedence over the 802.1X-generated key.
SA
Secure association (SA) is an agreement negotiated by CA participants. The agreement includes a cipher suite and keys for integrity check.
A secure channel can contain more than one SA. Each SA uses a unique secure association key (SAK). The SAK is generated from the CAK, and MACsec uses the SAK to encrypt data transmitted along the secure channel.
MACsec Key Agreement (MKA) limits the number of packets that can be encrypted by an SAK. When the limit is exceeded, the SAK will be refreshed. For example, when packets with the minimum size are sent on a 10-Gbps link, an SAK rekey occurs about every 300 seconds.
MKA life time
The participants at each end of a secure session exchange MKA protocol packets to keep the session alive.
MKA life time sets the session keepalive timer for participants. The timer starts on a participant when the participant receives the first MKA protocol packet from its peer. If the participant does not receive any subsequent MKA protocol packets from that peer before the timer expires, the participant determines that the session is insecure and then removes the session.
In client-oriented mode, the MKA life time is 6 seconds and is not user configurable.
In device-oriented mode, the MKA life time is user configurable. By default, the MKA life time is 6 seconds.
MACsec services
Data encryption
MACsec enables a port to encrypt outbound frames and decrypt MACsec-encrypted inbound frames. The keys for encryption and decryption are negotiated by MKA.
Integrity check
MACsec performs integrity check when the device receives a MACsec-encrypted frame. The integrity check uses the following process:
·     Uses a key negotiated by MKA to calculate an integrity check value (ICV) for the frame.
·     Compares the calculated ICV with the ICV in the frame trailer.
¡     If the ICVs are the same, the device verifies the frame as legal.
¡     If the ICVs are different, the device determines whether to drop the frame based on the validation mode. The device supports the following validation modes:
-     check—Performs validation only, and does not drop illegal frames.
-     disabled—Does not perform validation.
-     strict—Performs validation, and drops illegal frames.
Replay protection
When MACsec frames are transmitted over the network, frame disorder might occur. MACsec replay protection allows the device to accept the out-of-order packets within the replay protection window size and drop other out-of-order packets.
MACsec application modes
MACsec supports client-oriented and device-oriented modes.
Client-oriented mode
As shown in Figure 1, MACsec secures data transmission between the client and the access device. In this mode, MACsec must operate with 802.1X authentication.
Client-oriented MACsec includes the following entities:
·     Client (supplicant)—A user terminal seeking access to the LAN or a device that supports the 802.1X client feature. The terminal must have 802.1X software to authenticate to the access device. The terminal also performs CAK negotiation and packet encryption.
·     Access device (authenticator)—Authenticates the client to control access to the LAN and performs CAK negotiation and packet encryption.
·     Authentication server—Provides AAA services for the access device. The authentication server is typically a RADIUS server. After the client passes authentication, the authentication server generates and distributes the CAK to the client and the access device.
Figure 1 Client-oriented mode
In client-oriented mode, an MKA-enabled port on the access device must perform port-based 802.1X access control. The authentication method must be EAP relay.
Device-oriented mode
As shown in Figure 2, MACsec secures data transmission between devices. In this mode, the same preshared key must be configured on the MACsec ports that connect the devices. The devices use the configured preshared key as the CAK.
Figure 2 Device-oriented mode
MACsec operating mechanism
Operating mechanism for client-oriented mode
Figure 3 illustrates how MACsec operates in client-oriented mode.
Figure 3 MACsec interactive process in client-oriented mode
The following shows the MACsec process:
1.     After the client passes 802.1X authentication, the RADIUS server distributes the generated CAK to the client and the access device.
2.     After receiving the CAK, the client and the access device exchange EAPOL-MKA packets.
The client and the access device exchange the MACsec capability and required parameters for session establishment. The parameters include MKA key server priority and MACsec desire.
During the negotiation process, the access device automatically becomes the key server. The key server generates an SAK from the CAK for packet encryption, and it distributes the SAK to the client.
3.     The client and the access device use the SAK to encrypt packets, and they send and receive the encrypted packets in secure channels.
4.     When the access device receives a logoff request from the client, it immediately removes the associated secure session from the port. The remove operation prevents an unauthorized client from using the secure session established by the previous authorized client to access the network.
Operating mechanism for device-oriented mode
As shown in Figure 4, the devices use the configured preshared key to start session negotiation.
Figure 4 MACsec interactive process in device-oriented mode
1.     The devices use the configured preshared key as the CAK to exchange EAPOL-MKA packets.
They exchange the MACsec capability and required parameters for session establishment. The parameters include MKA key server priority and MACsec desire.
During the negotiation process, the port with higher MKA key server priority becomes the key server. The key server generates and distributes an SAK.
2.     The devices use the SAK to encrypt packets, and they send and receive the encrypted packets in secure channels.
3.     When a device receives a logoff request from the peer, it immediately deletes the associated secure session.
Protocols and standards
IEEE 802.1X-2010, Port-Based Network Access Control
IEEE 802.1AE-2006, Media Access Control (MAC) Security
Restrictions and guidelines: MACsec configuration
To avoid packet dropping, make sure MACsec traffic speed is below 100 Gbps.
You can enable MACsec on a maximum of 32 ports.
In a serpentine-shaped network, if you enable MKA on multiple ports in bulk, one port might occupy two encryption/decryption hardware resources and one resource will be deleted. If the number of encryption/decryption hardware resources is 32, you can enable MKA on a maximum of 16 ports in such a network. If you enable MKA on more than 16 ports in bulk, some ports will fail to establish channels. The failed ports can establish channels successfully only after other ports release encryption and decryption hardware resources.
Before a MACsec encryption/decryption channel is stably established, traffic forwarding exceptions might occur.
If all ports belong to the same VLAN, you can enable MKA on a maximum of five ports in bulk when each pair of ports establishes a channel.
MACsec tasks at a glance
To configure MACsec, perform the following tasks:
1.     Enabling MKA
2.     Enabling MACsec desire
3.     Specifying the cipher suite for MACsec encryption
This task is applicable only to device-oriented mode.
4.     Enabling inclusion of the SCI in the SecTAG field of MACsec frames on an interface
5.     Configuring a preshared key
This task is required in device-oriented mode. Do not perform this task in client-oriented mode.
6.     (Optional.) Configuring the MKA key server priority
7.     (Optional.) Setting the MKA life time
This task is applicable only in device-oriented mode.
8.     (Optional.) Configuring MACsec protection parameters
¡     Configuring MACsec protection parameters in interface view
¡     Configuring MACsec protection parameters by MKA policy
9.     (Optional.) Enabling MACsec maintenance mode on an interface
10.     (Optional.) Disabling MACsec encryption for STP packets
11.     (Optional.) Enabling MKA session logging
Enabling MKA
MKA establishes and manages MACsec secure channels on a port. It also negotiates keys used by MACsec.
2.     Enter interface view.
3.     Enable MKA.
mka enable
By default, MKA is disabled on the port.
The MACsec desire feature expects MACsec protection for outbound frames. The key server determines whether MACsec protects the outbound frames.
MACsec protects the outbound frames of a port when the following requirements are met:
·     The key server is MACsec capable.
·     Both the local participant and its peer are MACsec capable.
·     A minimum of one participant is enabled with MACsec desire.
3.     Enable MACsec desire.
macsec desire
By default, the port does not expect MACsec protection for outbound frames.
MACsec uses the GCM-AES-128, GCM-AES-256, GCM-AES-XPN-128, or GCM-AES-XPN-256 cipher suite to encrypt, validate, and decrypt protected data frames.
This feature is supported only in device-oriented mode. Do not configure this feature on an 802.1X-enabled port.
Make sure the connected MACsec ports are configured with the same cipher suite. If the ports are configured with different cipher suites, they cannot successfully establish MKA sessions.
3.     Specify the cipher suite for MACsec encryption.
macsec cipher-suite { gcm-aes-128 | gcm-aes-256 | gcm-aes-xpn-128 | gcm-aes-xpn-256 }
By default, MACsec uses the GCM-AES-128 cipher suite for encryption.
The secure channel identifier (SCI) identifies the source of a MACsec frame. It contains the MAC address and ID of the port that sends the frame.
To have an interface send encrypted MACsec frames with the SCI included in the SecTAG field, perform this task.
To forward traffic between a pair of peer MACsec interfaces, you must make sure inclusion of the SCI in the SecTAG field is enabled or disabled on both of them.
3.     Enable inclusion of the SCI in the SecTAG field of MACsec frames sent out of the interface.
macsec include-sci
By default, inclusion of the SCI in the SecTAG field of MACsec frames depends on the device model.
In device-oriented mode, configure a preshared key as the CAK. To successfully establish an MKA session between two devices, make sure the following requirements are met:
·     The connected MACsec ports are configured with the same CAK name (CKN) and CAK.
·     Only the ports are configured with the same CKN in the network.
A user-configured preshared key has higher priority than the 802.1X-generated CAK. To ensure a successful MKA session establishment, do not configure a preshared key in client-oriented mode.
Different cipher suites for MACsec encryption have different requirements for the CKN and CAK configuration.
·     The GCM-AES-128 or GCM-AES-XPN-128 cipher suite requires that the CKN and CAK each must be 32 characters long. If the configured CKN or CAK is not 32 characters long, the system performs the following operations when it runs the cipher suite:
¡     Automatically increases the length of the CKN or CAK by zero padding if the CKN or CAK contains less than 32 characters.
¡     Uses only the first 32 characters if the CKN or CAK contains more than 32 characters.
·     The GCM-AES-256 or GCM-AES-XPN-256 cipher suite requires that the CKN and CAK each must be 64 characters long. If the configured CKN or CAK contains less than 64 characters, the system automatically increases the length of the CKN or CAK by zero padding when it runs the cipher suite.
3.     Set a preshared key.
mka psk ckn name cak { cipher | simple } string
By default, no MKA preshared key exists.
When you configure the MKA key server priority, follow these restrictions and guidelines:
·     In client-oriented mode, the access device port automatically becomes the key server. You do not have to configure the MKA key server priority.
·     In device-oriented mode, the port that has higher priority becomes the key server. The lower the priority value, the higher the priority. If a port and its peers have the same priority, MACsec compares the secure channel identifier (SCI) values on the ports. The port with the lowest SCI value (a combination of MAC address and port ID) becomes the key server.
·     A port with priority 255 cannot become the key server. For a successful key server selection, make sure a minimum of one participant's key server priority is not 255.
3.     Set the MKA key server priority.
mka priority priority-value
The default setting is 0.
Make sure the participants at each end of a secure session have the same MKA life time.
3.     Set the MKA life time.
mka timer mka-life seconds
About MACsec protection parameters
You can set the following MACsec protection parameters:
·     MACsec confidentiality offset—Specifies the number of bytes starting from the frame header. MACsec encrypts only the bytes after the offset in a frame. The offset value can be 0, 30, or 50.
·     MACsec replay protection—Allows a MACsec port to accept a number of out-of-order or repeated inbound frames.
·     MACsec validation—Allows a port to perform integrity check based on the validation modes.
Restrictions and guidelines for MACsec protection parameter configuration
You can configure MACsec protection parameters either in interface view or through MKA policies.
The use of MKA policies provides a centralized method to configure MACsec protection parameters. When you need to configure the same settings for MACsec protection parameters on multiple ports, you can configure them in an MKA policy and apply the policy to the ports.
If you configure a protection parameter in interface view after applying an MKA policy, the configuration in interface view overwrites the configuration of that parameter in the MKA policy. The other protection parameters in the MKA policy still take effect.
If you apply an MKA policy to a port after configuring protection parameters on the port, the settings in the policy overwrite all protection parameter settings in interface view. The protection parameters not configured in the policy are restored to the default.
The configured MACsec confidentiality offset does not take effect on the GCM-AES-XPN-128 or GCM-AES-XPN-256 cipher suite. The confidentiality offset is fixed at 0 for these two suites.
3.     Set the MACsec confidentiality offset.
macsec confidentiality-offset offset-value
The default setting is 0, and the entire frame needs to be encrypted.
MACsec uses the confidentiality offset propagated by the key server.
4.     Configure MACsec replay protection:
a.     Enable MACsec replay protection.
macsec replay-protection enable
By default, MACsec replay protection is enabled on the port.
b.     Set the MACsec replay protection window size.
macsec replay-protection window-size size-value
The default setting is 0. The device accepts only frames that arrive in the correct order. Out-of-order or duplicated frames will be dropped.
The configured replay protection window size takes effect only when MACsec replay protection is enabled.
5.     Set a MACsec validation mode.
macsec validation mode { check | disabled| strict }
The default setting is check.
To avoid data loss, use the display macsec command to verify that MKA negotiation with the peer device has succeeded before you change the mode to strict.
Parameter
check
Verifies incoming frames but does not drop illegal frames.
disabled
Disables MACsec validation for incoming frames.
strict
Verifies incoming frames and drops illegal frames.
An MKA policy can be applied to a port or multiple ports. When you apply an MKA policy to a port, follow these restrictions and guidelines:
·     The settings in the MKA policy overwrite all protection parameter settings configured in interface view. The protection parameters not configured in the policy are restored to the default.
·     Any modifications to the MKA policy take effect immediately.
·     When you remove an MKA policy application from the port, the MACsec parameter settings on the port restore to the default.
·     When you apply a nonexistent MKA policy to the port, the port automatically uses the system-defined MKA policy named default-policy. If you create the policy, the policy will be automatically applied to the port.
·     The configured MACsec confidentiality offset does not take effect on the GCM-AES-XPN-128 or GCM-AES-XPN-256 cipher suite. The confidentiality offset is fixed at 0 for these two suites.
2.     Create an MKA policy and enter its view.
mka policy policy-name
By default, a system-defined MKA policy exists. The policy name is default-policy.
The settings for parameters in the system-defined policy are the same as the default settings for the parameters on a port.
You cannot delete or modify the system-defined MKA policy.
You can create multiple MKA policies.
By default, MACsec replay protection is enabled.
b.     Set the replay protection window size.
The default replay protection window size is 0. The device accepts only frames that arrive in the correct order. Out-of-order or duplicated frames will be dropped.
validation mode { check | disabled | strict }
Parameter
check
disabled
strict
6.     Apply an MKA policy:
a.     Return to system view.
b.     Enter interface view.
c.     Apply the MKA policy to the port.
mka apply policy policy-name
By default, no MKA policy is applied to a port.
To protect data security, a MACsec port is blocked by default until it establishes an MKA session with its peer port. In blocked state, the MACsec port can send and receive MKA protocol packets, but it cannot send or receive data packets. On a network that uses a controller to deploy configuration, this might cause a configuration deployment failure if the configuration delivered to a device must traverse a MACsec port.
To make sure a device can always receive its configuration from a controller over the link between a pair of MACsec ports, enable MACsec maintenance mode on the MACsec ports. In this mode, a MACsec port is unblocked regardless of whether it has established an MKA session with its peer port.
For security purposes, a MACsec port in MACsec maintenance mode will still be blocked when it receives frames that contain its own SCI (identified by its MAC address and port ID).
A MACsec port in MACsec maintenance mode issues its SCI information only after it receives MKA protocol packets from its peer port.
CAUTION
CAUTION:
If you enable MACsec maintenance mode on an interface before it establishes an MKA session with its peer end, data frames are exposed to security risks. Before you perform this operation, make sure you fully understand this impact on security.
Before you enable or disable MACsec maintenance mode on a MACsec port:
·     Disable MKA on that port.
·     Use the link-delay down command to increase the delay to report a link down event to CPU. Transient link state flapping might occur after you enable MACsec maintenance mode. This step prevents a link down event from causing MKA packet exchange failure during this period.
3.     Enable MACsec maintenance mode.
macsec maintenance-mode enable
By default, MACsec maintenance mode is disabled.
In MACsec communication, the enabling statuses of MACsec encryption for STP packets on two ends might be different. For the STP protocol to function correctly, make sure the enabling statuses on both ends are consistent. You can use this feature to adjust the setting on an H3C device to match that on the peer device.
3.     Disable MACsec encryption for STP packets.
macsec unencrypt stp
By default, the enabling status of MACsec encryption for STP packets varies by device model.
This feature enables the device to generate logs for MKA session changes, such as peer aging and SAK updates. The logs are sent to the information center of the device. For the logs to be output correctly, you must also configure the information center on the device. For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
As a best practice, disable this feature to prevent excessive MKA session log output.
2.     Enable MKA session logging.
macsec mka-session log enable
By default, MKA session logging is disabled.
Display and maintenance commands for MACsec
Display MACsec information on ports.
display macsec [ interface interface-type interface-number ] [ verbose ]
Display MKA policy information.
display mka { default-policy | policy [ name policy-name ] }
Display MKA session information.
display mka session [ interface interface-type interface-number | local-sci sci-id ] [ verbose ]
Display MKA statistics on ports.
display mka statistics [ interface interface-type interface-number ]
Reset MKA sessions on ports.
reset mka session [ interface interface-type interface-number ]
Clear MKA statistics on ports.
reset mka statistics [ interface interface-type interface-number ]
MACsec configuration examples
Example: Configuring client-oriented MACsec (host as client)
As shown in Figure 5, the host accesses the network through GigabitEthernet 1/0/1. The device performs RADIUS-based 802.1X authentication for the host to control user access to the Internet.
To ensure secure communication between the host and device, perform the following tasks on the device:
·     Enable MACsec desire, and configure MKA to negotiate SAKs for packet encryption.
·     Set the MACsec confidentiality offset to 30 bytes.
·     Enable MACsec replay protection, and set the replay protection window size to 100.
·     Set the MACsec validation mode to strict.
Figure 5 Network diagram
1.     Configure IP addresses for the Ethernet ports. (Details not shown.)
2.     Configure the RADIUS server to provide authentication, authorization, and accounting services. Add a user account for the host. (Details not shown.)
3.     Configure AAA:
# Enter system view.
# Configure RADIUS scheme radius1.
[Device] radius scheme radius1
[Device-radius-radius1] primary authentication 10.1.1.1
[Device-radius-radius1] primary accounting 10.1.1.1
[Device-radius-radius1] key authentication simple name
[Device-radius-radius1] key accounting simple name
[Device-radius-radius1] user-name-format without-domain
[Device-radius-radius1] quit
# Configure authentication domain bbb for 802.1X users.
[Device] domain bbb
[Device-isp-bbb] authentication lan-access radius-scheme radius1
[Device-isp-bbb] authorization lan-access radius-scheme radius1
[Device-isp-bbb] accounting lan-access radius-scheme radius1
[Device-isp-bbb] quit
4.     Configure 802.1X:
# Enable 802.1X on GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] dot1x
# Implement port-based access control on GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] dot1x port-method portbased
# Specify bbb as the mandatory authentication domain for 802.1X users on GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] dot1x mandatory-domain bbb
# Enable 802.1X globally, and sets the device to relay EAP packets.
[Device] dot1x
[Device] dot1x authentication-method eap
5.     Configure MACsec:
# Create an MKA policy named pls.
[Device] mka policy pls
# Set the MACsec confidentiality offset to 30 bytes.
[Device-mka-policy-pls] confidentiality-offset 30
# Enable MACsec replay protection.
[Device-mka-policy-pls] replay-protection enable
# Set the MACsec replay protection window size to 100.
[Device-mka-policy-pls] replay-protection window-size 100
# Set the MACsec validation mode to strict.
[Device-mka-policy-pls] validation mode strict
[Device-mka-policy-pls] quit
# Apply the MKA policy to GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] mka apply policy pls
# Configure MACsec desire and enable MKA on GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] macsec desire
[Device-GigabitEthernet1/0/1] mka enable
# Display MACsec information on GigabitEthernet 1/0/1.
[Device] display macsec interface gigabitethernet 1/0/1 verbose
  Protect frames                : Yes
  Active MKA policy             : pls
  Replay protection             : Enabled
  Config reply window size      : 100 frames
  Active replay window size     : 100 frames
  Config confidentiality offset : 30 bytes
  Active confidentinlity offset : 30 bytes
  Validation mode               : Strict
  Included SCI                  : No
  SCI conflict                  : No
  Cipher suite                  : GCM-AES-128
  MKA life time                 : 6 seconds
  Transmit secure channel:
    SCI           : 00E00100000A0006
      Elapsed time: 00h:02m:07s
      Current SA  : AN 0        PN 1
  Receive secure channels:
    SCI           : 00E0020000000106
      Elapsed time: 00h:02m:03s
      Current SA  : AN 0        LPN 1
      Previous SA : AN N/A      LPN N/A
# Display MKA session information on GigabitEthernet 1/0/1 after a user logs in.
[Device] display mka session interface gigabitethernet 1/0/1 verbose
Tx-SCI    : 00E00100000A0006
Priority  : 0
Capability: 3
  CKN for participant: 1234
    Key server            : Yes
    MI (MN)               : A1E0D2897596817209CD2307 (2509)
    Live peers            : 1
    Potential peers       : 0
    Principal actor       : Yes
    MKA session status    : Secured
    Confidentiality offset: 30 bytes
   Tx-SSCI               : N/A
   Current SAK status    : Rx & Tx
   Current SAK AN        : 0
   Current SAK KI (KN)   : A1E0D2897596817209CD230700000002 (2)
   Previous SAK status   : N/A
   Previous SAK AN       : N/A
   Previous SAK KI (KN)  : N/A
   Live peer list:
   MI                        MN         Prio  Cap  Rx-SCI            Rx-SSCI
   B2CAF896C9BFE2ABFB135E63  2512       0     3    00E0020000000106  N/A
Example: Configuring client-oriented MACsec (device as client)
As shown in Figure 6:
·     The switch connects to the device through trunk ports GigabitEthernet 1/0/2 and GigabitEthernet 1/0/3. GigabitEthernet 1/0/2 allows packets only from VLAN 1 and VLAN 2, and GigabitEthernet 1/0/3 allows packets only from VLAN 1 and VLAN 3.
·     The device acts as a network access device. You cannot configure a preshared key on the device for MKA negotiation and packet encryption.
·     The RADIUS server acts as an 802.1X authentication server.
To secure data between the device and the switch, configure MACsec on the switch as follows:
·     Enable MKA and MACsec desire on GigabitEthernet 1/0/2 and GigabitEthernet 1/0/3 to protect traffic forwarding on a per-port basis.
·     Configure MACsec to use 802.1X-generated CAKs for MKA negotiation and packet encryption. For this purpose, configure the 802.1X client feature on the switch.
Figure 6 Network diagram
1.     Configure IP addresses for the Ethernet ports. Make sure the switch, the device, and the RADIUS server can reach one another. (Details not shown.)
2.     Configure the access device. (Details not shown.)
Configuration on the access device varies by manufacturer. For information about device configuration, see the corresponding product manual. This part covers only the switch configuration, and for information about 802.1X client commands, see Security Command Reference.
3.     Configure the RADIUS server to provide authentication, authorization, and accounting services. Add user accounts. (Details not shown.)
4.     Configure the switch:
# Create VLAN 2.
<Switch> system-view
[Switch] vlan 2
[Switch-vlan2] quit
# Configure GigabitEthernet 1/0/2 as a trunk port, and assign the port to VLAN 2.
[Switch-GigabitEthernet1/0/2] port link-type trunk
[Switch-GigabitEthernet1/0/2] port trunk permit vlan 2
# Configure the 802.1X client username as aaaa, and set the password to 123456 in plaintext form on GigabitEthernet 1/0/2.
[Switch-GigabitEthernet1/0/2] dot1x supplicant username aaaa
[Switch-GigabitEthernet1/0/2] dot1x supplicant password simple 123456
# Specify TTLS-GTC as the 802.1X client EAP authentication method on GigabitEthernet 1/0/2.
[Switch-GigabitEthernet1/0/2] dot1x supplicant eap-method ttls-gtc
# Specify MAC address 1-1-1 for 802.1X client authentication on GigabitEthernet 1/0/2.
[Switch-GigabitEthernet1/0/2] dot1x supplicant mac-address 1-1-1
# Enable the 802.1X client feature on GigabitEthernet 1/0/2.
[Switch-GigabitEthernet1/0/2] dot1x supplicant enable
# Configure MACsec desire and enable MKA on GigabitEthernet 1/0/2.
[Switch-GigabitEthernet1/0/2] macsec desire
[Switch-GigabitEthernet1/0/2] mka enable
# Create VLAN 3.
[Switch] vlan 3
[Switch-vlan3] quit
# Configure GigabitEthernet 1/0/3 as a trunk port, and assign the port to VLAN 3.
[Switch] interface gigabitethernet 1/0/3
[Switch-GigabitEthernet1/0/3] port link-type trunk
[Switch-GigabitEthernet1/0/3] port trunk permit vlan 3
# Configure the 802.1X client username as bbbb, and set the password to 654321 in plaintext form on GigabitEthernet 1/0/3.
[Switch-GigabitEthernet1/0/3] dot1x supplicant username bbbb
[Switch-GigabitEthernet1/0/3] dot1x supplicant password simple 654321
# Specify TTLS-GTC as the 802.1X client EAP authentication method on GigabitEthernet 1/0/3.
[Switch-GigabitEthernet1/0/3] dot1x supplicant eap-method ttls-gtc
# Specify MAC address 1-1-2 for 802.1X client authentication on GigabitEthernet 1/0/3.
[Switch-GigabitEthernet1/0/3] dot1x supplicant mac-address 1-1-2
# Enable the 802.1X client feature on GigabitEthernet 1/0/3.
[Switch-GigabitEthernet1/0/3] dot1x supplicant enable
# Configure MACsec desire and enable MKA on GigabitEthernet 1/0/3.
[Switch-GigabitEthernet1/0/3] macsec desire
[Switch-GigabitEthernet1/0/3] mka enable
[Switch-GigabitEthernet1/0/3] quit
# Display MACsec information on GigabitEthernet 1/0/2.
[Switch] display macsec interface gigabitethernet 1/0/2 verbose
Interface GigabitEthernet1/0/2
  Config replay window size     : 100 frames
  Active confidentiality offset : 30 bytes
  Included SCI                  : No
  SCI conflict                  : No
# Display MACsec information on GigabitEthernet 1/0/3.
[Switch] display macsec interface gigabitethernet 1/0/3 verbose
Interface GigabitEthernet1/0/3
  Validation mode               : Check
  Included SCI                  : No
  SCI conflict                  : No
    SCI           : A087100801000103
      Elapsed time: 00h:00m:55s
    SCI           : A0872B3602000003
      Elapsed time: 00h:00m:52s
# Display MKA session information on GigabitEthernet 1/0/2 after 802.1X client user aaaa comes online.
[Switch] display mka session interface gigabitethernet 1/0/2 verbose
Priority  : 0
Capability: 3
   Key server            : No
   Live peers            : 1
   Potential peers       : 0
   Confidentiality offset: 0 bytes
   Tx-SSCI               : N/A
   Current SAK AN        : 0
   Live peer list:
# Display MKA session information on GigabitEthernet 1/0/3 after 802.1X client user bbbb comes online.
[Switch] display mka session interface gigabitethernet 1/0/3 verbose
Tx-SCI    : A087100801000103
Priority  : 0
Capability: 3
  CKN for participant: 7B8784F16F85ED8F9D0130AA9B93D0F0
    Key server            : No
    MI (MN)               : D3F6D374598C8FD1F1819D6C (78)
    Live peers            : 1
    Potential peers       : 0
    Tx-SSCI               : N/A
    Current SAK AN        : 0
    Current SAK KI (KN)   : FCA71854FCAE51398EC2DA7900000001 (1)
    Live peer list:
    FCA71854FCAE51398EC2DA79  71         0     3    A0872B3602000003  N/A
Example: Configuring device-oriented MACsec
As shown in Figure 7, Device A is the MACsec key server.
To secure data transmission between the two devices by MACsec, perform the following tasks on Device A and Device B, respectively:
·     Configure the CAK name (CKN) and the CAK as E9AC and 09DB3EF1, respectively.
Figure 7 Network diagram
1.     Configure Device A:
# Enter GigabitEthernet 1/0/1 interface view.
# Enable MACsec desire on GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] macsec desire
# Set the MKA key server priority to 5.
[DeviceA-GigabitEthernet1/0/1] mka priority 5
# Configure the CKN as E9AC and the CAK as 09DB3EF1 in plain text.
[DeviceA-GigabitEthernet1/0/1] mka psk ckn E9AC cak simple 09DB3EF1
[DeviceA-GigabitEthernet1/0/1] macsec confidentiality-offset 30
[DeviceA-GigabitEthernet1/0/1] macsec replay-protection enable
[DeviceA-GigabitEthernet1/0/1] macsec replay-protection window-size 100
[DeviceA-GigabitEthernet1/0/1] macsec validation mode strict
# Enable MKA on GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] mka enable
2.     Configure Device B:
[DeviceB-GigabitEthernet1/0/1] macsec desire
# Set the MKA key server priority to 10.
[DeviceB-GigabitEthernet1/0/1] mka priority 10
[DeviceB-GigabitEthernet1/0/1] mka psk ckn E9AC cak simple 09DB3EF1
[DeviceB-GigabitEthernet1/0/1] macsec confidentiality-offset 30
[DeviceB-GigabitEthernet1/0/1] macsec replay-protection enable
[DeviceB-GigabitEthernet1/0/1] macsec replay-protection window-size 100
[DeviceB-GigabitEthernet1/0/1] macsec validation mode strict
[DeviceB-GigabitEthernet1/0/1] mka enable
# Display MACsec information on GigabitEthernet 1/0/1 of Device A.
[DeviceA] display macsec interface gigabitethernet 1/0/1 verbose
  Included SCI                  : No
  SCI conflict                  : No
      Elapsed time: 00h:05m:00s
      Elapsed time: 00h:03m:18s
# Display MKA session information on GigabitEthernet 1/0/1 of Device A.
[DeviceA] display mka session interface gigabitethernet 1/0/1 verbose
Priority  : 5
Capability: 3
  CKN for participant: E9AC
    Key server            : Yes
    MI (MN)               : 85E004AF49934720AC5131D3 (182)
    Live peers            : 1
    Potential peers       : 0
    Tx-SSCI               : N/A
    Current SAK AN        : 0
    Current SAK KI (KN)   : 85E004AF49934720AC5131D300000003 (3)
    Live peer list:
    12A1677D59DD211AE86A0128  182        10    3    00E0020000000106  N/A
# Display MACsec information on GigabitEthernet 1/0/1 of Device B.
[DeviceB] display macsec interface gigabitethernet 1/0/1 verbose
  Included SCI                  : No
  SCI conflict                  : No
      Elapsed time: 00h:05m:36s
      Elapsed time: 00h:03m:21s
# Display MKA session information on GigabitEthernet 1/0/1 of Device B.
[DeviceB] display mka session interface gigabitethernet 1/0/1 verbose
Tx-SCI    : 00E0020000000106
Priority  : 10
Capability: 3
    Key server            : No
    MI (MN)               : 12A1677D59DD211AE86A0128 (1219)
    Live peers            : 1
    Potential peers       : 0
    Tx-SSCI               : N/A
    Current SAK AN        : 0
    Live peer list:
    85E004AF49934720AC5131D3  1216       5     3    00E00100000A0006  N/A
Troubleshooting MACsec
Cannot establish MKA sessions between MACsec devices
Symptom
The devices cannot establish MKA sessions when the following conditions exist:
·     The link connecting the devices is up.
·     The ports at the ends of the link are MACsec capable.
Analysis
The symptom might occur for the following reasons:
·     The ports at the link are not enabled with MKA.
·     A port at the link is not configured with a preshared key or configured with a preshared key different from the peer.
Solution
To resolve the issue:
1.     Enter interface view.
2.     Use the display this command to check the MACsec configuration:
¡     If MKA is not enabled on the port, execute the mka enable command.
¡     If a preshared key is not configured or the preshared key is different from the peer, use the mka psk command to configure a preshared key. Make sure the preshared key is the same as the preshared key on the peer.
3.     If the issue persists, contact H3C Support.
