| 04-Tunnel policy commands | 71.00 KB |
Only advanced and expert modes support tunnel policies. For more information about system operating modes, see device management in Fundamentals Configuration Guide.
Layer 3 aggregate interfaces do not support tunnel policies. The device does not support MPLS forwarding for tunnel packets.
display mpls tunnel
Use display mpls tunnel to display tunnel information.
display mpls tunnel { all | statistics | [ vpn-instance vpn-instance-name ] destination ipv4-address }
all: Displays all tunnels.
statistics: Displays tunnel statistics.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays tunnel information for the public network.
destination: Displays the tunnel destined for the specified address.
ipv4-address: Specifies the tunnel destination IPv4 address.
# Display information about all tunnels.
<Sysname> display mpls tunnel all
Destination Type Tunnel/NHLFE VPN Instance
2.2.2.2 LSP NHLFE1024 -
Destination |
Tunnel destination address. |
Type |
Tunnel type: LSP |
Tunnel/NHLFE |
Tunnel or NHLFE entry. NHLFEnumber represents the ingress LSP that matches the NHLFE entry with NID of number. |
VPN Instance |
VPN instance name. If the tunnel belongs to the public network, this field displays a hyphen (-). |
# Display tunnel statistics.
<Sysname> display mpls tunnel statistics
LSP : 1
GRE : 0
CRLSP: 0
SRLSP: 0
LSP |
Number of LSP tunnels. |
GRE |
This field is not supported in the current software version. Number of GRE tunnels. |
CRLSP |
This field is not supported in the current software version. Number of CRLSP tunnels. |
SRLSP |
This field is not supported in the current software version. Number of SRLSP tunnels. |
display tunnel-policy
Use display tunnel-policy to display tunnel policy information.
display tunnel-policy [ tunnel-policy-name ]
tunnel-policy-name: Specifies a tunnel policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a tunnel policy, this command displays information about all tunnel policies.
# Display information about all tunnel policies.
<Sysname> display tunnel-policy
Tunnel policy name : policy1
Preferred paths :
Interface : not configured
Tunnel type: not configured
Select-Seq : LSP
Load balance number : 8
Strict : no
# Display information about tunnel policy policy1.
<Sysname> display tunnel-policy policy1
Preferred paths :
Select-Seq : LSP
Load balance number : 1
Strict : no
Preferred paths |
Preferred tunnels information. |
Tunnel interface name of the preferred tunnel. |
Tunnel type |
This field is not supported in the current software version. Type of the preferred tunnel: TE. |
Select-Seq |
Tunnel selection order. The tunnel types are displayed in descending order of priority in tunnel selection. |
Load balance number |
Number of tunnels for load balancing. |
Strict |
Whether the strict method is used to select tunnels for load balancing: · no—The tunnel policy can use a hybrid of the specified types of tunnels for load balancing. · yes—The tunnel policy uses only one type of tunnels for load balancing. |
select-seq load-balance-number
Use select-seq load-balance-number to configure the tunnel selection order and set the number of tunnels for load balancing.
Use undo select-seq to restore the default.
select-seq [ strict ] lsp load-balance-number number
undo select-seq
The device selects only one tunnel.
Tunnel policy view
strict: Uses the same type of tunnels for load balancing. If you do not specify this keyword, the device can use a hybrid of the specified types of tunnels for load balancing.
lsp: Uses LSP tunnels.
load-balance-number number: Specifies the number of tunnels for load balancing, in the range of 1 to 16.
A tunnel type closer to the select-seq keyword has a higher priority, and only the tunnel types specified in this command can be used.
For example, the select-seq lsp cr-lsp load-balance-number 3 command specifies three tunnels for load balancing and gives LSP tunnels higher priority over CRLSP tunnels.
· If you do not specify the strict keyword, VPN can use CRLSP tunnels to remedy the deficiency of LSP tunnels.
· If you specify the strict keyword, VPN uses only one type of tunnels. It uses CRLSP tunnels only if no LSP tunnels are available.
Tunnels selected by this method are not fixed, making it hard to plan VPN traffic. As a best practice, do not use this method.
When you configure both the select-seq load-balance-number and preferred-path commands for a tunnel policy, the tunnel policy selects tunnels in the following steps:
1. If the destination address of the preferred tunnel identifies a peer PE, the tunnel policy uses the preferred tunnel to forward traffic destined for the peer PE.
2. If not, the tunnel policy selects tunnels as configured by the select-seq load-balance-number command.
# Configure tunnel policy policy1 to use only LSP tunnels, and set the load balancing number to 2.
[Sysname] tunnel-policy policy1
[Sysname-tunnel-policy-policy1] select-seq lsp load-balance-number 2
preferred-path
tunnel-policy (system view)
Use tunnel-policy to create a tunnel policy and enter its view, or enter the view of an existing tunnel policy.
Use undo tunnel-policy to delete a tunnel policy.
tunnel-policy tunnel-policy-name
undo tunnel-policy tunnel-policy-name
No tunnel policies exist.
tunnel-policy-name: Specifies a name for the tunnel policy, a case-sensitive string of 1 to 19 characters.
# Create tunnel policy policy1 and enter its view.
