01-IPsec VPN Configuration Examples | 698.14 KB |
Example: Configuring IPsec VPN in IKE main mode with preshared key authentication
Example: Configuring IPsec VPN in IKE main mode with NAT traversal
Introduction
The following information provides IPsec VPN configuration examples in the following modes:
· IKE main mode and preshared key authentication—Applicable in scenarios where both the WAN interfaces on the headquarters and branch gateway routers use fixed public addresses.
· IKE main mode and NAT traversal—Applicable in scenarios where the WAN interface on the headquarters or branch gateway router uses dynamic public addresses (for example, DHCP-assigned IP addresses).
Refer to the configuration examples in this document to configure the IPsec VPN according to your actual network.
Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of IPsec VPN.
Software versions used
The configuration examples were created and verified on R6749P21 of the MSR830-6HI router and R6749P21 of the MSR3600-28-G-DP router.
As shown in Figure 1, the headquarters gateway Router A and branch gateway Router B each use a single WAN interface with a fixed public address to connect to the Internet. The headquarters and the branch communicate with each other over the Internet. To protect data flows between the headquarters and the branch, establish an IPsec tunnel between the gateway routers. Configure the network as follows:
· Configure Router A and Router B to use preshared key 123456TESTplat&! for authentication.
· Specify the encapsulation mode as the tunnel mode and the security protocol as ESP.
· Specify the encryption algorithm as 3DES-CBC and the authentication algorithm as MD5.
Analysis
To configure IPsec VPN, complete the following configurations on Router A and Router B:
1. Configure basic WAN and LAN settings.
a. Specify the IP address and gateway of the WAN interface on each router.
b. Edit the default IP address of VLAN1 on each router.
2. Add an IPsec policy.
Because the WAN interface on each router uses a fixed IP address to connect to the Internet, configure the IPsec policy to use the main mode for phase 1 IKE negotiation.
After you edit the default IP address of VLAN1, the Web connection fails. You must use the modified IP address to log in to the Web interface again.
If your network uses double-WAN or multiple-WAN access, configure a static route on each router to direct the traffic destined for the peer internal network to the WAN interface specified in the IPsec policy. In this example, the routers use single-WAN access. No static route configuration is needed. The routers will generate a default route to direct all traffic to the egress gateway.
Make sure both sides of the IPsec tunnel use the same preshared key, security protocol, encryption algorithm, authentication algorithm, and encapsulation mode.
Procedures
Configuring Router A
Editing the IP address of VLAN1
# Edit the IP address of VLAN1 to 10.1.1.1/24.
1. Log in to the Web interface. From the navigation pane, select Network Settings > LANs.
2. Click the LAN Settings tab.
3. Click the Edit icon in the Actions column for VLAN1.
4. In the Interface IP address field, enter 10.1.1.1.
5. In the Subnet mask field, enter 255.255.255.0.
6. Use the default settings for other parameters, and then click Apply.
Figure 2 Editing LAN
Configuring WAN0 to connect to the Internet
# Configure a single WAN interface using a fixed IP address.
1. From the navigation pane, select Network Settings > External Networks.
2. On the Scene tab, select Single-WAN scenario, select WAN0 for Line1, and then click Apply.
Figure 3 Configuring WAN scenario
3. Click the WAN Settings tab.
4. Click the Edit icon in the Actions column for WAN0.
5. In the Connection mode field, select Fixed IP.
6. In the IP address field, enter 2.2.2.1.
7. In the Subnet mask field, enter 255.255.255.0.
8. In the Gateway field, enter 2.2.2.254.
9. Use the default settings for other parameters, and then click Apply.
Figure 4 Editing WAN settings
Configuring the IPsec policy
# Specify the network mode as the headquarters gateway and the IKE negotiation mode as the main mode.
1. From the navigation pane, select VPN > IPsec VPN.
2. Click Add.
3. On the page that opens, configure the following parameters:
¡ Specify the name as map1.
¡ Select WAN0 in the Interface field.
¡ Select Headquarters gateway in the Network mode field.
¡ Enter 123456TESTplat&! in the Preshared key field.
Figure 5 Adding the IPsec policy
4. Click Show advanced settings. On the page that opens, configure the following parameters:
¡ In the Negotiation mode field, select Main mode.
¡ In the Local ID field, select IP address, and then enter 2.2.2.1.
¡ In the DPD field, select Enable. Set the DPD retry interval to 30.
This feature is disabled by default. To timely monitor the availability of the IPsec tunnel, enable this feature.
¡ In the Algorithm suite field, select Customize.
¡ In the Authentication algorithm field, select MD5.
¡ In the Encryption algorithm field, select 3DES-CBC.
¡ Use the default settings for other parameters.
Figure 6 Configuring advanced IKE settings
5. Click the IPsec settings tab, and then configure the following parameters:
¡ In the Algorithm combination field, select Customize.
¡ In the Security protocol field, select ESP.
¡ In the ESP authentication algorithm field, select MD5.
¡ In the ESP encryption algorithm field, select 3DES-CBC.
¡ In the Encapsulation mode field, select Tunnel.
Figure 7 Configuring advanced IPsec settings
6. Click Back to basic settings to go back to the Add IPsec Policy page.
7. Click Apply.
Configuring Router B
# Edit the IP address of VLAN1 to 10.1.2.1/24.
2. From the navigation pane, select Network Settings > LANs.
3. Click the LAN Settings tab.
4. Click the Edit icon in the Actions column for VLAN1.
5. In the Interface IP address field, enter 10.1.2.1.
6. In the Subnet mask field, enter 255.255.255.0.
7. Use the default settings for other parameters, and then click Apply.
Figure 8 Editing VLAN1
Configuring WAN3 to connect to the Internet
2. On the Scene tab, select Single-WAN scenario, select WAN3 for Line1, and then click Apply.
Figure 9 Configuring WAN scenario
4. Click the Edit icon in the Actions column for WAN3.
6. In the IP address field, enter 2.2.3.1.
8. In the Gateway field, enter 2.2.3.254.
Figure 10 Editing WAN settings
# Specify the network mode as the branch gateway and the IKE negotiation mode as the main mode.
2. Click Add.
¡ Select WAN3 in the Interface field.
¡ Select Branch gateway in the Network mode field
¡ Enter 2.2.2.1 in the Peer gateway address field.
¡ In
the Protected data flows area, select IP as the protocol
to be protected, enter 10.1.2.0/24 in the Local subnet/mask filed and 10.1.1.0/24 in the Peer subnet/mask field, and then click the icon.
Figure 11 Adding the IPsec policy
¡ In the Local ID field, select IP address, and then enter 2.2.3.1.
¡ In the Remote ID field, select IP address, and then enter 2.2.2.1.
¡ In the DPD field, select Enable. Set the DPD retry interval to 30 seconds.
Figure 12 Configuring advanced IKE settings
Figure 13 Configuring advanced IPsec settings
7. Click Apply.
1. Verify that Host A can ping Host B successfully.
C:\Users\abc>ping 10.1.2.2
Ping 10.1.2.2 (10.1.2.2): 56 data bytes, press CTRL_C to break
56 bytes from 10.1.2.2: icmp_seq=0 ttl=254 time=2.137 ms
56 bytes from 10.1.2.2: icmp_seq=1 ttl=254 time=2.051 ms
56 bytes from 10.1.2.2: icmp_seq=2 ttl=254 time=1.996 ms
56 bytes from 10.1.2.2: icmp_seq=3 ttl=254 time=1.963 ms
56 bytes from 10.1.2.2: icmp_seq=4 ttl=254 time=1.991 ms
--- Ping statistics for 10.1.2.2 ---
round-trip min/avg/max/std-dev = 1.963/2.028/2.137/0.062 ms
C:\Users\abc>
2. Click VPN > IPsec VPN > Monitor Info on the Web interface to verify that the IPsec tunnel is successfully established. Status Active indicates successful establishment of the IPsec tunnel.
As shown in Figure 14, the headquarters gateway Router A uses a single WAN interface with a fixed public address to connect to the Internet. The branch gateway Router B uses a DHCP-assigned IP address to connect to the Internet through a NAT device. The headquarters and the branch communicate with each other over the Internet. To protect data flows between the headquarters and the branch, establish an IPsec tunnel between the routers. Configure the network as follows:
Analysis
2. Configure port mapping on the NAT device.
Because Router A is in the internal network side of the NAT device, you must map the WAN interface of Router A to UDP ports 500 and 4500 on the NAT device. This mapping ensures that Router B can initiate a connection to Router A.
3. Add an IPsec policy.
Because one side of the IPsec tunnel (Router B) uses DHCP-assigned IP addresses, to successfully set up the IPsec tunnel, configure the IPsec policy to use main mode for phase 1 IKE negotiation and use FQDN as the local ID.
Procedures
Configuring NAT
For information about configuring interface addresses and port mappings, see Port Mappings and NAT Hairpin Configuration Examples.
Figure 15 Editing VLAN1
# Configure a single WAN interface using a DHCP-assigned IP address.
Figure 16 Configuring WAN scenario
5. In the Connection mode field, select DHCP.
Figure 17 Editing WAN settings
2. Click Add.
Figure 18 Adding the IPsec policy
¡ In the Local ID field, select FDQN, and then enter the FQDN name (for example, www.test.com).
Figure 19 Configuring advanced IKE settings
Figure 20 Configuring advanced IPsec settings
7. Click Apply.
Figure 21 Editing VLAN1
# Configure a single WAN interface using DHCP-assigned IP addresses.
Figure 22 Configuring WAN scenario
Figure 23 Editing WAN settings
2. Click Add.
¡ Select Branch gateway in the Network mode field.
¡ In the Peer gateway address field, enter the fixed IP address used by the NAT device to connect to the Internet. This example uses 2.2.2.1.
¡ Enter 123456TESTplat&! in the Preshared Key field.
¡ In
to be protected, enter 10.1.2.0/255.255.255.0 in the Local Subnet/Mask filed and 10.1.1.0/255.255.255.0 in the Peer Subnet/Mask
Figure 24 Adding the IPsec policy
¡ In the Local ID field, select FDQN, then enter the FQDN name (for example, www.test1.com).
¡ In the Remote ID field, select FDQN, and then enter FQDN name www.test.com.
Figure 25 Configuring advanced IKE settings
¡ In the Algorithm Combination field, select Customize.
Figure 26 Configuring advanced IPsec settings
7. Click Apply.
C:\Users\abc>
