- 10-High Availability Configuration Guide
- 01-Ethernet OAM configuration
- 02-CFD configuration
- 03-DLDP configuration
- 04-RRPP configuration
- 05-ERPS configuration
- 06-Smart Link configuration
- 07-Monitor Link configuration
- 08-VRRP configuration
- 09-BFD configuration
- 10-Track configuration
- 11-Process placement configuration
00-Preface | 101.26 KB |
Preface
· This configuration guide describes the high availability fundamentals and configuration procedures. The high availability technologies include fault detection and fault failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery.
· CLI.
· RBAC, switch login, and switch access control.
· Management of the switch, file systems, and configuration files.
· FTP and TFTP.
· Tcl and Python.
· Common software upgrade.
· Automatic configuration.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S5170-EI switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
