| 01-Text | 631.41 KB |
U-Center 2.0 deployment procedure at a glance
(Optional.) Deploying the IOM component
(Optional.) Deploying the CMDB component
(Optional.) Deploying the BSM component
(Optional.) Deploying the ITSM component
(Optional.) Deploying the NTA component
(Optional.) Deploying the AOM component
(Optional.) Deploying the STM component
Installing and obtaining licenses
Backing up and restoring the configuration
Recovering the cluster from failures
Shutting down and powering off servers
Shutting down and powering off part of nodes
Shutting down and powering off all nodes
Starting servers and checking the network
Verifying licenses and service functionalities
Overview
With an advanced containerized microservice architecture, U-Center 2.0 provides clustering and high availability capabilities, features easy deployment, and supports large-scale data storage. Based on the architecture, U-Center 2.0 integrates the monitoring, CMDB, automation, IT process management, and service management components to form a unified operations and maintenance (O & M) platform.
In the containerized microservice architecture, the installation and deployment of different components might vary. This document provides streamlined installation and deployment guidelines for correct deployment of U-Center 2.0.
U-Center 2.0 contains CMDB, IOM, BSM, ITSM, NTA, AOM, and STM components. It supports standalone deployment on one master node and cluster deployment on three master nodes and N worker nodes (N ≥ 0).
NOTE: All components of U-Center 2.0 support small-, medium-, and default-scale deployment. To deploy these components in small scale, make sure the Unified Platform is in simplified mode (lite mode). For more information about the lite deployment mode, see H3C Unified Platform Deployment Guide. |
Table 1 shows the U-Center 2.0 deployment workflow.
Table 1 U-Center 2.0 deployment workflow
Step |
Remarks |
Prepare servers. |
· The standalone mode requires one server. · The cluster mode requires a minimum of three servers. |
Required. For hardware and software requirements, see "Server requirements." |
Deploy Unified Platform. |
Install an operating system and dependencies. |
Required. For more information, see H3C Unified Platform Deployment Guide. |
Install Matrix. |
Required if a non-H3Linux 1.0 operating system is used. For more information, see H3C Unified Platform Deployment Guide. |
Create a cluster. |
Deploy Unified Platform installation packages. |
Deploy IOM. |
Deploy IOM installation packages. |
Optional. For more information, see "(Optional.) Deploying the IOM component." |
Deploy CMDB. |
Deploy CMDB installation packages. |
Optional. For more information, see "(Optional.) Deploying the CMDB component." |
Deploy BSM. |
Deploy BSM installation packages. |
Optional. For more information, see "(Optional.) Deploying the BSM component." |
Deploy ITSM. |
Deploy ITSM installation packages. |
Optional. For more information, see "(Optional.) Deploying the ITSM component." |
Deploy NTA. |
Deploy NTA installation packages. |
Optional. For more information, see "(Optional.) Deploying the NTA component." |
Deploy AOM. |
Deploy AOM installation packages. |
Optional. For more information, see "(Optional.) Deploying the AOM component." |
Deploy STM. |
Deploy STM installation packages. |
Optional. For more information, see "(Optional.) Deploying the STM component." |
Preparing for deployment
IP address assignment
IMPORTANT: Deploy the environment and make sure that: · The IP addresses of all the nodes can communicate with the internal virtual IP address of the cluster or northbound service virtual IP address. · The internal IP addresses of all the nodes can communicate with one another, including the IP addresses in the service IP pool and content IP pool. |
IMPORTANT: Follow these restrictions and guidelines when deploying, upgrading, or rebuilding a cluster in a scenario where multiple NICs exist: · Make sure all physical NICs before the NIC whose IP is used as the node IP in the Matrix cluster have IPs assigned or the ONBOOT value set to no. For example, if the node uses the IP of NIC ens191 as the node IP in the Matrix cluster, and ens190 is before ens191 in order, make sure ens190 has an IP assigned. · You must use the ifconfig command to view the NIC order. · Make sure no abnormal NIC configuration file exists in the cluster. For example, the ONBOOT value is yes when the NIC is not connected or not configured with an IP. · If the cluster uses a bonding interface as the node IP in the Matrix cluster, make sure all physical NICs not the members of the bonding interface have IPs assigned or the ONBOOT value set to no. |
Table 2 shows the IP address assignment for U-Center 2.0 deployment. Only IPv4 addresses are supported.
IP address |
Remarks |
Master node 1 IP |
IP address assigned to the master node installed with an operating system. |
Required. (Only one master node is required in standalone mode.) IP addresses of master nodes in one cluster must be on the same subnet. |
Master node 2 IP |
Master node 3 IP |
Northbound service VIP |
The unified external access address for all applications deployed through Matrix. |
Required. The northbound service VIP must be on the same subnet as the subnet of the master nodes. |
Worker node IP addresses |
IP address assigned to a worker node. |
Optional. This IP address must be on the same subnet as those of the master nodes. |
Installation packages
Table 3 describes the U-Center 2.0 installation packages when the H3C Linux operating system is used. If another operating system is used, H3Linux ISO files are not necessarily required. In this table, version indicates the version number and platform represents the CPU architecture type.
Name |
Product package |
Remarks |
Dependencies |
common_Linux-version_platform.iso |
H3Linux OS installation package |
PLAT |
Required |
N/A |
UDTP_Middle_version_platform.zip |
Middleware images installation package |
PLAT |
Required. |
N/A |
UDTP_GlusterFS_version_platform.zip |
Installation package for the local shared storage. |
PLAT |
Required. |
Middle |
UDTP_Core_version_platform.zip |
Installation package for the portal, unified authentication, user management, service gateway, help center, permission, resource identity, license, configuration center, resource group, and log services. |
PLAT |
Required. |
Middle, GlusterFS |
UDTP_IMonitor_version_platform.zip |
Installation package for the self-monitoring service. |
PLAT |
Required. |
Middle, GlusterFS, Core |
BMP_Report_version_platform.zip |
Installation package for the report service. |
PLAT |
Optional. |
N/A |
BMP_QuickReport_version_platform.zip |
Installation package for the quick report service. |
PLAT |
Optional. |
Report |
BMP_Alarm_version_platform.zip |
Installation package for the alarm service. |
PLAT |
Optional. |
Report |
BMP_Certificate_version_platform.zip |
Installation package for the certificate management service. |
PLAT |
Optional. |
N/A |
BMP_Dashboard_version_platform.zip |
Installation package for the dashboard framework. |
PLAT |
Optional. |
The dashboard application requires installation of both the dashboard and widget packages, with the dashboard installed before the widget. |
BMP_Widget_version_platform.zip |
Installation package for the dashboard widget service. |
PLAT |
Optional. |
Dashboard The dashboard application requires installation of both the dashboard and widget packages, with the dashboard installed before the widget. |
BMP_NETCONF_version_platform.zip |
Installation package for the NETCONF channel service and NETCONF configuration invalidity check service. |
PLAT |
Optional. |
N/A |
BMP_OneClickCheck_version_platform.zip |
Installation package for the one-click inspection service. |
PLAT |
Recommended. |
Report, Alarm |
BMP_RDR_version_platform.zip |
Installation package for the disaster recovery service. |
PLAT |
Optional. |
Report, Alarm |
BMP_Snapshot_version_platform.zip |
Installation package for the snapshot management service. |
PLAT |
Optional. |
N/A |
BMP_Subscription_version_platform.zip |
Installation package for the subscription service. |
PLAT |
Optional. |
Report, Alarm |
BMP_Suspension_version_platform.zip |
Installation package for the resource maintenance tag service. |
PLAT |
Optional. |
Report, Alarm |
BMP_Template_version_platform.zip |
Installation package for the access parameter templates and monitoring templates. |
PLAT |
Optional. |
N/A |
BMP_WebSocket_version_platform.zip |
Installation package for the southbound WebSocket service. |
PLAT |
Optional. |
N/A |
BMP_RDRArbitrator_version_platform.zip |
Installation package for the arbitration service. |
PLAT |
Optional. |
For the procedure of deploying the arbitration service, see H3C Unified Platform Deployment Guide. |
BMP_Region_version_platform.zip |
Installation package for hierarchical management. |
PLAT |
Optional. |
For the module to send alarms, you need also install Report and Alarm. |
BMP_Syslog_version_platform.zip |
Installation package for the syslog service. |
PLAT |
Optional. |
Report, Alarm |
BMP_Aggregation_version_platform.zip |
Installation package for alarm aggregation. |
PLAT |
Optional. |
Report, Alarm |
BMP_AIOPS_version_platform.zip |
Installation package for the time-series data trend prediction and anomaly detection services. |
PLAT |
Optional. Matrix converged deployment does not support installation of this package. You can install this package on Unified Platform. |
N/A |
NSM_FCAPS-Res_version_platform.zip |
Installation package for discovery, incorporation, and basic information management of network devices. |
NSM |
Optional. |
· portal(UDTP_Core_version_platform.zip) · alarm(BMP_Alarm_version_platform.zip) · report(BMP_Report_version_platform.zip) · suspension(BMP_Suspension_version_platform.zip) · template(BMP_Template_version_platform.zip) |
NSM_FCAPS-Perf_version_platform.zip |
Installation package for network device performance monitoring and display. |
NSM |
Optional. |
· portal(UDTP_Core_version_platform.zip) · alarm(BMP_Alarm_version_platform.zip) · report(BMP_Report_version_platform.zip) · res(NSM_FCAPS-Res_version_platform.zip) · template(BMP_Template_version_platform.zip) |
U-Center_UCP_version_platform.zip |
Installation package for the U-Center public platform component service. |
IOM |
Required. |
N/A |
U-Center_CLICKHOUSE_version_platform.zip |
Installation package for the ClickHouse database service. |
IOM |
Optional. |
N/A |
U-Center_COLLECTPLAT_version_platform.zip |
Installation package for the collection platform service. |
IOM |
Required. |
N/A |
U-Center_IOM_version_platform.zip |
Installation package for the application monitoring service. |
IOM |
Required. |
· portal · kernel(UDTP_Core_version_platform.zip) · accesstemp, monitortemp(BMP_Template_version_platform.zip) · alarm(BMP_Alarm_version_platform.zip) · dashboard(BMP_Dashboard_version_platform.zip) |
U-Center_ADDM_version_platform.zip |
Installation package for the auto-discovery service. |
IOM |
Optional. |
N/A |
U-Center_AGENT_version_platform.zip |
Installation package for the agent service. |
IOM |
Optional. |
N/A |
U-Center_VKVM_2.0_version_platform.zip |
Installation package for the server virtual remote console service. |
IOM |
Optional. |
· Portal, kernel(UDTP_Core_version_platform.zip) · accesstemp, monitortemp(BMP_Template_version_platform.zip) · alarm(BMP_Alarm_version_platform.zip) · dashboard(BMP_Dashboard_version_platform.zip) · kernel-base(BMP_Template_version_platform.zip) · U-Center_COLLECTPLAT_version_platform.zip · U-Center_IOM_version_platform.zip |
U-Center_CMDB_2.0_version_platform.zip |
Installation package for the configuration management database. |
CMDB |
Optional. |
· glusterfs(UDTP_GlusterFS_version_platform.zip) · common(UDTP_Middle_version_platform.zip) · UDTP_Core_version_platform.zip · alarm(BMP_Alarm_version_platform.zip) |
U-Center_BSM_version_platform.zip |
Installation package for the service health analysis service. |
BSM |
Optional. |
· glusterfs(UDTP_GlusterFS_version_platform.zip) · portal, kernel(UDTP_Core_version_platform.zip) · kernel-base(BMP_Template_version_platform.zip) · alarm(BMP_Alarm_version_platform.zip) · cmdb(U-Center_CMDB_version_platform.zip) · ucp(U-Center_UCP_version_platform.zip) · collectplat(U-Center_COLLECTPLAT_version_platform.zip) · iop, iom(U-Center_IOM_version_platform.zip) |
U-Center_UEM_version_platform.zip |
Installation package for the user experience analysis service. |
BSM |
Optional. |
N/A |
U-Center_ITSM_version_platform.zip |
Installation package for the process management service. |
ITSM |
Optional. |
· glusterfs(UDTP_GlusterFS_version_platform.zip) · portal, kernel(UDTP_Core_version_platform.zip) · common(UDTP_Middle_version_platform.zip) |
U-Center_NTA_version_platform.zip |
Installation package for the traffic monitoring service. |
NTA |
Optional. |
· portal, kernel(UDTP_Core_version_platform.zip) · alarm(BMP_Alarm_version_platform.zip) · accesstemp(BMP_Template_version_platform.zip) · network(NSM_FCAPS-Res_version_platform.zip) · zookeeper, clickhouse(U-Center_CLICKHOUSE_version_platform.zip) · etcd(U-Center_UCP_version_platform.zip) |
U-Center_STM_version_platform.zip |
Installation package for simulation polling test management (STM). |
STM |
Optional. |
· glusterfs(UDTP_GlusterFS_version_platform.zip) · portal, kernel(UDTP_Core_version_platform.zip) · kernel-base(BMP_Template_version_platform.zip) · alarm(BMP_Alarm_version_platform.zip) · ucp(U-Center_UCP_version_platform.zip) · collectplat(U-Center_COLLECTPLAT_version_platform.zip) · iom(U-Center_IOM_version_platform.zip) |
U-Center_NQA_version_platform.zip |
Installation package for STM task management. |
STM |
Optional. |
· glusterfs(UDTP_GlusterFS_version_platform.zip) · portal, kernel(UDTP_Core_version_platform.zip) · kernel-base(BMP_Template_version_platform.zip) · alarm(BMP_Alarm_version_platform.zip) · ucp(U-Center_UCP_version_platform.zip) · collectplat(U-Center_COLLECTPLAT_version_platform.zip) · iom(U-Center_IOM_version_platform.zip) · network(NSM_FCAPS-Res_version_platform.zip) · network(NSM_FCAPS-Perf_version_platform.zip) |
U-Center_AOM_2.0_version_platform.zip |
Installation package for automated operation and maintenance management. |
AOM |
Optional. |
· gluster(UDTP_GlusterFS_version_platform.zip) · common(UDTP_Middle_version_platform.zip) · portal, kernel(UDTP_Core_version_platform.zip) · kernel-base(BMP_Template_version_platform.zip) · alarm(BMP_Alarm_version_platform.zip) · network(NSM_FCAPS-Res_version_platform.zip) · network(NSM_FCAPS-Perf_version_platform.zip) · ucp(U-Center_UCP_version_platform.zip) |
Server requirements
Hardware requirements
You can go to http://iservice.h3c.com to obtain the hardware configuration evaluation result. The evaluation result can be used as a reference. You can also contact Technical Support for an evaluation.
Software requirements
Table 4 Available Operating systems
Architecture |
Operating system |
x86 |
H3Linux V1.1.2 |
H3Linux V2.0.2 |
Red Hat Enterprise Linux 7.6 |
Community Enterprise Operating System 7.6 |
Red Hat Enterprise Linux 8.4 |
Red Hat Enterprise Linux 8.6 |
Kylin-Server-10-SP2-x86-RC01-Build09-20210524.iso |
IMPORTANT: · You must install the same operating system version on all nodes in a cluster. · For the support of an operating system for the ARM and x86 architecture, see the release notes for the operating system. |
Client requirements
You can use a browser to access U-Center 2.0 without installing client software. As a best practice, use Google Chrome 70 or Firefox 78 or higher with a minimum resolution width of 1600 pixels.
Pre-installation checklist
Table 5 shows the check list for the installation requirements. Make sure the U-Center 2.0 installation requirements are met.
Table 5 Pre-installation checklist
Item |
Requirements |
Server or VM |
Hardware |
The CPU, memory, disk, and NIC settings are as required. |
Software |
· The operating system meets the requirements. · The system time settings are configured correctly. As a best practice, configure NTP on each node to ensure time synchronization on the network, and make sure the NTP server time is the same as the current time. · RAID is configured. |
Client |
Make sure the browser version meets the requirement. |
CAUTION: · During the U-Center 2.0 deployment process, do not enable or disable firewall services. · To avoid exceptions, do not modify the system time after cluster deployment. |
IMPORTANT: · As a best practice, set the mode to UEFI for the next startup of the server or VM. Select EFI from the boot firmware list. Do not select Enable UEFI secure boot for the VM. · Do not use KVM to install the same image for multiple servers when installing an operating system. · H5 KVM is unstable in performance and issues such as slow or unsuccessful image loading might occur during installation. As a best practice, use Java KVM to mount the image and install the operating system. · A power failure during the installation process might cause installation failure of some service components. For function integrity, perform a reinstallation when a power failure occurs during installation. · Do not enable or disable firewalls during the U-Center 2.0 deployment. · To avoid cluster exceptions, do not edit the system time after the completion of cluster deployment. |
Software package verification
Before installing the software, first perform MD5 verification on each software package to ensure its integrity and correctness.
Installing Unified Platform
Before deploying U-Center 2.0, first deploy Unified Platform and then deploy U-Center 2.0 components on Unified Platform.
1. Install the operating system and dependencies.
2. Install Matrix (required for a non-H3Linux 1.0 operating system).
3. Create a Matrix cluster.
4. Deploy PLAT components.
For more information about the deployment procedure, see H3C Unified Platform Deployment Guide.
Installing U-Center 2.0
1. Enter https://ip_address:8443/matrix/ui in your browser and then enter the username and password to log in to the Matrix. ip_address represents the IP of the node.
The default username is admin and the default password is Pwd@12345. If a password has been set during the installation of the operating system, enter the set password.
2. On the top navigation bar, click DEPLOY.
3. From the navigation pane, select Applications. The application list page opens.
4. Click Deploy Applications.
5. Click Upload. In the windows that opens, upload the application installation packages.
After installing the required packages, install optional packages as needed. Before installing a package, install its dependencies first. For the dependency relations between installation packages, see Table 3.
IMPORTANT: · Middle, GlusterFS, Core, and IMonitor are required installation packages for Unified Platform. If the packages have been installed during Unified Platform deployment, you do not need to install them again. · If you want to use the upper-level and lower-level functions, install BMP_Region_version_platform.zip. · You can select and install all of the following packages simultaneously: UCP, COLLECTPLAT, IOM, ADDM, and AGENT. · You can select and install all of the following packages simultaneously: BSM, UEM, ITSM, and VDI. NTA and ITSM require a separate installation and cannot be selected simultaneously with other packages. · NTA requires installation of the NTA, NSM_FCAPS-Res, UCP, and CLICKHOUSE packages, which must be installed in the following order: NSM_FCAPS-Res, UCP, CLICKHOUSE, and NTA. · To install AOM, first install the AOM_PLAT component, and then install the other components in any order. IPMS, INI, CCMS, OMTS, and PROBE can be installed at different steps. In a scenario with low performance or low disk read or write speed, install them in multiple steps. · You can select the number of probes for AOM as needed. Select a minimum of one collector. As a best practice, add one collector for every 1,000 devices. · To use HTTPS, log in to Unified Platform after the applications and components are installed and then select System > System Settings > Security Settings to enable HTTPS. · After completing installation package upload, the system automatically synchronizes the installation packages to the following directory of each node: /opt/matrix/app/install/packages/ |
The installation packages listed as IOM in the Product Package column in Table 3 are IOM component-related installation packages. You can deploy the installation package as needed.
IMPORTANT: Before installing the component, install its dependencies. For the dependency relations of the installation packages, see Table 3. |
To deploy the IOM component:
1. On the Select Installation Package page, select U-Center_IOM_version_platform.zip, and then click Next.
2. Select applications and click Next.
All applications are selected by default.
3. On the Configure Shared Storage page, click Next.
4. On the Configure Database page, click Next.
5. On the Configure Params page, click Next.
6. Click Deploy.
The installation packages listed as CMDB in the Product Package column in Table 3 are CMDB component-related installation packages. You can deploy the installation package as needed.
To deploy the CMDB component:
1. On the Select Installation Package page, select U-Center_CMDB_2.0_version_platform.zip, and then click Next.
6. Click Deploy.
The installation packages listed as BSM in the Product Package column in Table 3 are BSM component-related installation packages. You can deploy the installation package as needed.
To deploy the BSM component:
1. On the Select Installation Package page, select U-Center_BSM_version_platform.zip, and then click Next.
6. Click Deploy.
The installation packages listed as ITSM in the Product Package column in Table 3 are ITSM component-related installation packages. You can deploy the installation package as needed.
To deploy the ITSM component:
1. On the Select Installation Package page, select U-Center_ITSM_version_platform.zip, and then click Next.
6. Click Deploy.
The installation packages listed as NTA in the Product Package column in Table 3 are NTA component-related installation packages. You can deploy the installation package as needed.
To deploy the NTA component:
1. On the Select Installation Package page, select U-Center_NTA_version_platform.zip, and then click Next.
6. Click Deploy.
The installation packages listed as AOM in the Product Package column in Table 3 are AOM component-related installation packages. You can deploy the installation package as needed.
1. On the Select Installation Package page, select U-Center_AOM_2.0_version_platform.zip, and then click Next.
6. Click Deploy.
The installation packages listed as STM in the Product Package column in Table 3 are STM component-related installation packages. You can deploy the installation package as needed.
1. On the Select Installation Package page, select U-Center_STM_version_platform.zip, and then click Next.
6. Click Deploy.
Logging in to U-Center 2.0
1. Enter the URL of U-Center 2.0 http://ip_address:30000 in your browser. Replace ip_address with the northbound service VIP. The default port number is 30000. Figure 1 shows the login page.
Figure 1 U-Center 2.0 login page
2. Enter the username and password, and then click Login.
The default username is admin and the default password is Pwd@12345. If you have set the password when installing the operating system, enter the set password.
Registering the software
After you deploy U-Center 2.0, you must obtain licenses to use it. If you have purchased the product, obtain the relevant license key to complete the consequent registration process. To obtain a trial license, contact relevant H3C marketing personnel.
For more information about requesting and installing licenses, see H3C Software Products Remote Licensing Guide.
License support
NOTE: The license server and U-Center 2.0 are one-to-one related. A license server can be used by only one U-Center 2.0. |
Table 6 describes the licenses for each component of U-Center 2.0.
Component |
License description |
Product code |
Product description |
NSM |
Network basic license |
LIS-IMC9-NSM |
H3C iMC9.0, Intelligent Management Center License |
Network quantity license |
LIS-IMC9-NSMA-25 |
H3C iMC9.0, Intelligent Management Platform (Network Management), 25 Licenses |
LIS-IMC9-NSMB-50 |
H3C iMC9.0, Intelligent Management Platform (Network Management), 50 Licenses |
LIS-IMC9-NSMC-100 |
H3C iMC9.0, Intelligent Management Platform (Network Management), 100 Licenses |
LIS-IMC9-NSMD-200 |
H3C iMC9.0, Intelligent Management Platform (Network Management), 200 Licenses |
LIS-IMC9-NSME-500 |
H3C iMC9.0, Intelligent Management Platform (Network Management), 500 Licenses |
LIS-IMC9-NSMF-1K |
H3C iMC9.0, Intelligent Management Platform (Network Management), 1000 Licenses |
Table 7 U-Center 2.0 licenses
Component |
Product code |
CMDB |
U-Center basic license |
LIS-UCENTER2-IOP |
H3C U-Center2.0, Intelligent Operations Platform Software |
CMDB basic license |
LIS-UCENTER2-CMDB |
H3C U-Center2.0, CMDB License |
CMDB quantity license |
LIS-UCENTER2-CMDB-25 |
H3C U-Center2.0, CMDB, 25 Licenses |
LIS-UCENTER2-CMDB-50 |
H3C U-Center2.0, CMDB, 50 Licenses |
LIS-UCENTER2-CMDB-100 |
H3C U-Center2.0, CMDB, 100 Licenses |
LIS-UCENTER2-CMDB-200 |
H3C U-Center2.0, CMDB, 200 Licenses |
LIS-UCENTER2-CMDB-500 |
H3C U-Center2.0, CMDB, 500 Licenses |
LIS-UCENTER2-CMDB-1K |
H3C U-Center2.0, CMDB, 1000 Licenses |
LIS-UCENTER2-CMDB-1 |
H3C U-Center2.0, CMDB, 1 License |
LIS-UCENTER2-CMDB-100-A |
Report |
Report |
LIS-UCENTER2-IOM-IAR |
H3C U-Center2.0, IOM, Intelligent Analysis Report License |
IOM |
IOM basic license |
LIS-UCENTER2-IOM |
H3C U-Center2.0, IOM Licenses |
IOM quantity license |
LIS-UCENTER2-IOM-25 |
H3C U-Center2.0, IOM, 25 Licenses |
LIS-UCENTER2-IOM-50 |
H3C U-Center2.0, IOM, 50 Licenses |
LIS-UCENTER2-IOM-100 |
H3C U-Center2.0, IOM, 100 Licenses |
LIS-UCENTER2-IOM-200 |
H3C U-Center2.0, IOM, 200 Licenses |
LIS-UCENTER2-IOM-500 |
H3C U-Center2.0, IOM, 500 Licenses |
LIS-UCENTER2-IOM-1K |
H3C U-Center2.0, IOM, 1000 Licenses |
LIS-UCENTER2-IOM-1 |
H3C U-Center2.0, IOM, 1 License |
LIS-UCENTER2-IOM-100-A |
BSM |
BSM basic license |
LIS-UCENTER2-BSM |
H3C U-Center2.0, BSM License |
BSM quantity license |
LIS-UCENTER2-BSM-1 |
H3C U-Center2.0, BSM, 1 License |
LIS-UCENTER2-BSM-5 |
H3C U-Center2.0, BSM, 5 Licenses |
LIS-UCENTER2-BSM-10 |
H3C U-Center2.0, BSM, 10 Licenses |
UEM quantity license |
LIS-UCENTER2-BSM-UEM-1-B |
H3C U-Center2.0, BSM, UEM, 1 License |
LIS-UCENTER2-BSM-UEM-1 |
LIS-UCENTER2-BSM-UEM-2 |
H3C U-Center2.0, BSM, UEM, 2 License |
LIS-UCENTER2-BSM-UEM-5 |
H3C U-Center2.0, BSM, UEM, 5 License |
NTA |
NTA basic license |
LIS-UCENTER2-IOM-NTA |
H3C U-Center2.0, IOM, Network Traffic Analyzer License |
NTA quantity license |
LIS-UCENTER2-IOM-NTA-1-B |
H3C U-Center2.0, IOM, Network Traffic Analyzer, 1 License |
LIS-UCENTER2-IOM-NTA-1 |
LIS-UCENTER2-IOM-NTA-2 |
H3C U-Center2.0, IOM, Network Traffic Analyzer, 2 License |
LIS-UCENTER2-IOM-NTA-5 |
H3C U-Center2.0, IOM, Network Traffic Analyzer, 5 License |
ITSM |
ITSM basic license |
LIS-UCENTER2-ITSM |
H3C U-Center2.0, ITSM License |
ITSM quantity license |
LIS-UCENTER2-ITSM-1 |
H3C U-Center2.0, ITSM, 1 License |
LIS-UCENTER2-ITSM-5 |
H3C U-Center2.0-ITSM-5 License |
LIS-UCENTER2-ITSM-10 |
H3C U-Center2.0-ITSM-10 License |
LIS-UCENTER2-ITSM-20 |
H3C U-Center2.0-ITSM-20 License |
LIS-UCENTER2-ITSM-50 |
H3C U-Center2.0-ITSM-50 License |
LIS-UCENTER2-ITSM-100 |
H3C U-Center2.0-ITSM-100 License |
ITSM change release management license |
LIS-UCENTER2-ITSM-CRM |
H3C U-Center2.0, ITSM, Change and Release Management License |
ITSM service level management basic license |
LIS-UCENTER2-ITSM-SLM |
H3C U-Center2.0, ITSM, Service Level Management License |
ITSM knowledge base license |
LIS-UCENTER2-ITSM-KB |
H3C U-Center2.0, ITSM, Knowledge Base License |
ITSM self-service platform license |
LIS-UCENTER2-ITSM-SSD |
H3C U-Center2.0, ITSM, Self-Service Desk License |
AOM |
IP address management |
LIS-UCENTER-AOM-IPMS-50 |
H3C UCenter, AOM, IP Address Management System, 50 Licenses |
LIS-UCENTER-AOM-IPA-100 |
H3C UCenter, AOM, IP Address Management System, 100 Licenses |
LIS-UCENTER-AOM-IPA-200 |
H3C UCenter, AOM, IP Address Management System, 200 Licenses |
LIS-UCENTER-AOM-IPA-500 |
H3C UCenter, AOM, IP Address Management System, 500 Licenses |
LIS-UCENTER-AOM-IPA-1000 |
H3C UCenter, AOM, IP Address Management System, 1000 Licenses |
LIS-UCENTER2-AOM-IPA-1 |
H3C U-Center2.0, AOM, IP Address Management System, 1 License |
LIS-UCENTER2-AOM-IPA-100-A |
H3C U-Center2.0, AOM, IP Address Management System, 100 Licenses |
Configuration and compliance intelligent management license |
LIS-UCENTER-AOM-CCI-50-2 |
H3C UCenter, AOM, Configuration And Compliance Intelligent Management, 50 Licenses |
LIS-UCENTER-AOM-CCI-100-2 |
H3C UCenter, AOM, Configuration And Compliance Intelligent Management, 100 Licenses |
LIS-UCENTER-AOM-CCI-200-2 |
H3C UCenter, AOM, Configuration And Compliance Intelligent Management, 200 Licenses |
LIS-UCENTER-AOM-CCI-500-2 |
H3C UCenter, AOM, Configuration And Compliance Intelligent Management, 500 Licenses |
LIS-UCENTER-AOM-CCI-1000-2 |
H3C UCenter, AOM, Configuration And Compliance Intelligent Management, 1000 Licenses |
LIS-UCENTER2-AOM-CCI-1 |
H3C U-Center2.0, AOM, Configuration And Compliance Intelligent Management, 1 License |
LIS-UCENTER2-AOM-CCI-100-A |
H3C U-Center2.0, AOM, Configuration And Compliance Intelligent Management, 100 Licenses |
Intelligent inspection |
LIS-UCENTER-AOM-IIE-50 |
H3C U-Center, AOM, Intelligent Inspection Expert Provider Edition, 50 Licenses |
LIS-UCENTER-AOM-IIE-100 |
H3C U-Center, AOM, Intelligent Inspection Expert Provider Edition, 100 Licenses |
LIS-UCENTER-AOM-IIE-200 |
H3C U-Center, AOM, Intelligent Inspection Expert Provider Edition, 200 Licenses |
LIS-UCENTER-AOM-IIE-500 |
H3C U-Center, AOM, Intelligent Inspection Expert Provider Edition, 500 Licenses |
LIS-UCENTER-AOM-IIE-1000 |
H3C U-Center, AOM, Intelligent Inspection Expert Provider Edition, 1000 Licenses |
LIS-UCENTER2-AOM-IIE-1 |
H3C U-Center2.0, AOM, Intelligent Inspection Expert Provider Edition, 1 License |
LIS-UCENTER2-AOM-IIE-100-A |
H3C U-Center2.0, AOM, Intelligent Inspection Expert Provider Edition, 100 Licenses |
STM |
STM quantity license |
LIS-UCENTER2-IOM-STM-1 |
H3C U-Center2.0, IOM, STM, 1 License |
STM license |
LIS-UCENTER2-IOM-STM |
H3C U-Center2.0, IOM, STM License |
For more information about license request and installation, see H3C Software Products Remote Licensing Guide. After importing a license file to the H3C license management system, configure U-Center 2.0 as the license client to access the license server.
Creating a license client
1. Log in to the license server, and navigate to the Configuration > License Clients page.
2. Click Add. On the page that opens, configure the client name and password.
3. Click OK.
Configuring the client connection
This function allows you to connect the client to the license server to obtain licenses.
1. Log in to U-Center 2.0.
2. Navigate to the System > License Management > License Information page.
3. In the License Server Info area, configure the following parameters of the license server, and then click Connect:
¡ Address—Specify the IP address of the license server.
¡ Port Number—Enter the service port number of the license server. The default value is 5555.
¡ Username—Enter the client name configured on the license server.
¡ Password—Enter the client password configured on the license server.
4. You can obtain the license if the client is connected to the license server. When the connection status is Connected, click Refresh in 5 minutes to view the latest license information.
IMPORTANT: · To avoid failure to connect to the license server, make sure the firewall is disabled for the license server when you start the client service. · To obtain licenses successfully, make sure the license server has available licenses when you start the client service. |
Viewing the license usage
1. Log in to the license server.
2. Navigate to the Clients > Client Connections page.
On the page that opens, you can view and manage clients connected to the license server.
To bulk disconnect clients from the license server, select them and then click Bulk Disconnect. To disconnect all clients, click Disconnect All.
To reclaim all licenses from a client, click Details in the Actions column for the client and then click Reclaim All on the page that opens. To reclaim a license from the client, click Reclaim for the license.
You can back up and restore configuration for U-Center 2.0 components on Unified Platform. For more information, see H3C Unified Platform Deployment Guide.
On Unified Platform, you can recover the cluster when a failure occurs. For more information, see H3C Unified Platform Deployment Guide.
Upgrading U-Center 2.0
TIP: · Before upgrading U-Center 2.0, upgrade Matrix and Unified Platform to the corresponding version. For more information about upgrading Matrix and Unified Platform, see H3C Unified Platform Deployment Guide. · Follow the installation sequence of application packages to upgrade the applications. |
U-Center 2.0 (E07xx) supports rolling update. You can upgrade U-Center 2.0 directly by deploying the latest version of the U-Center 2.0 application package. The upgrade upgrades U-Center 2.0 only with configuration retained and does not affect any installed components. If the U-Center 2.0 upgrade fails, uninstall and reinstall it.
To upgrade U-Center 2.0:
1. Enter https://ip_address:8443/matrix/ui in your browser to log in to Matrix. ip_address represents the configured northbound service VIP.
2. On the top navigation bar, select the Deploy tab.
3. From the left navigation tree, select Application to enter the application list page.
5. Click Upload and upload the application installation packages in the pop-up window. After the upload is complete, the application software packages will be displayed in the list.
6. Deploy the application installation packages. For more information, see "Installing U-Center 2.0."
Uninstalling U-Center 2.0
IMPORTANT: · The uninstallation of a single component or application will affect the use of other components or applications. Please uninstall a component or application with caution. · After you uninstall and reinstall U-Center 2.0, you must clear the content in the /var/lib/ssdata/ directory on each node. |
To retain the component configuration and data, use the backup function before uninstallation. For more information about the backup function, see "Backing up and restoring the configuration."
To uninstall the applications in the revered order they are installed.
To uninstall a single application:
1. Enter https://ip_address:8443/matrix/ui in the browser to log in to Matrix. Replace ip_address with the northbound service VIP.
4. Click the
icon in the Actions column for an application.
5. In the dialog box that opens, click OK.
Backing up the configuration
1. In the address bar of the browser, enter http://ip_address:30000. Then, enter the username and password.
¡ Both HTTP and HTTPS are supported. The default protocol is HTTP and the default port number is 30000. If the protocol and port number have been set, enter the set protocol and port number.
¡ The default username and password are admin and Pwd@12345, respectively. If the username and password have been set, enter the set username and password.
2. Navigate to the System > Backup & Restore page.
3. Manually back up the configuration and save the backup files locally.
For more information about the backup procedure and restrictions and guidelines, see the online help and configuration backup and restoration in H3C Unified Platform Deployment Guide.
Perform this task to shut down and power off one or multiple nodes to ensure that the system is still operating correctly when U-Center is deployed in cluster mode. This task applies to scenarios such as software upgrade and hardware replacement for nodes and routine inspection.
To shut down and power off part of nodes:
1. In the address bar of the browser, enter https://ip_address:8443/matrix/ui to log in to Matrix. Then, enter the username, password, and verification code.
The default username and password are admin and Pwd@12345, respectively. If the Matrix username and password has been set, enter the set username and password.
2. Navigate to the DEPLOY > Clusters > Deploy Cluster page, select a node. To shut down and power off multiple nodes, disable these nodes one by one. That is, perform operations on a node only after the operations such as backup and restoration have been completed on another node.
3. To disable a node, click the set icon in the upper right corner of the node and click Disable.
4. After a node is disabled, execute the shutdown -h now command to shut down the node.
5. Before you power off a node, make sure the node power status is off on HDM or the power LED of the node indicates that the node is in standby state.
Perform this task to shut down and power off the system. This task applies to scenarios such as emergency power outages and equipment room relocations.
To shut down and power off all nodes:
2. Navigate to the DEPLOY > Clusters > Deploy Cluster page. Disable all master nodes in the cluster.
Starting servers
1. Power on and start up servers.
2. After the servers start up, execute the ip addr command to verify that the nodes and the service networks are up.
3. Verify network connectivity. Make sure a node can reach the other nodes in different network segments and the client can reach the service networks of all nodes in the cluster.
Starting the system service
1. Access Matrix from the browser.
2. Navigate to the DEPLOY > Clusters > Deploy Cluster page, and then enable nodes.
Wait for about 30 minutes. The actual waiting time might vary by data volume being processed.
3. On the top navigation pane, click DASHBOARD to view system operation statistics to identify whether the system service has started up.
4. On the top navigation pane, click OBSERVE to view workload information about Pods.
1. Access U-Center from the browser.
3. Verify that the license information is synchronized from the license server and the authorization status is normal.
4. Verify that the features of U-Center are operating correctly.
FAQ
How can I prepare a disk partition for GlusterFS on a node?
Prepare a disk partition for GlusterFS on each node in the cluster, and record the disk partition name for future use.
To prepare a disk partition for GlusterFS on a node, perform one of the following tasks:
Manually create a new disk partition.
a. Reserve sufficient disk space for GlusterFS when you install the operating system.
b. After the operating system is installed, execute the fdisk command to create a disk partition.
Figure 2 gives an example of how to create a 250 GB disk partition /dev/sda7 on disk sda. If the system fails to obtain the partition list, execute the reboot command to restart the node.
Figure 2 Creating a disk partition
Use an existing disk partition.
If an existing disk partition with 250 GB or more capacity has not been used or mounted, you can clear the disk partition and use it for GlusterFS, for example, /dev/sda7 as shown in Figure 3. To clear the disk partition, execute the wipefs -a /dev/sda7 command.
Figure 3 Disk partition information
Prepare an independent disk for GlusterFS.
Execute the wipefs -a command to clear the disk before using it for GlusterFS.
Figure 4 Clearing disk
I have activated IOM basic and quantity licenses, but the application incorporation fails. An error massage is displayed that the number of monitors exceeds license limit. Why does this happen?
IOM depends on COLLECTPLAT. You need to activate CMDB quantity license of COLLECTPLAT.
Is there any additional information that I should pay attention to?
After the IOP license (H3C U-Center2.0, Intelligent Operations Platform Software) is registered, two license names, UCENTER-UCENTER-UCD and UCENTER-UCENTER2, are generated.
How can I manually modifying the ES values in the back end?
1. Execute the kubectl edit sts elasticsearch-node-1 -n service-software command.
3. Locate memory in the limits entry, and change its value from 2G to 12G. You can adjust the value 12G as needed. Make sure the value is at least 3G greater than the value following Xms or Xmx.
4. Save the configuration and exit.
5. Execute the kubectl edit sts elasticsearch-node-2 -n service-software command. Repeat steps 2 through 4.
6. Execute the kubectl edit sts elasticsearch-node-3 -n service-software command. Repeat steps 2 through 4.
7. After modification, enter any elasticsearch pod, and execute the curl ‘elasticsearch-http-service:9200/_cat/health?v’ command to view the cluster state. When the status is green or yellow in the returned value, the cluster is available. If a large amount of data exist, ES takes a certain period of time to restore data after you complete the preceding steps.
How can I identify the enabling status for the RAID controller cache policies when configuring a RAID array for servers if the IOPS of a disk is as low as 1k?
When configuring a RAID array for servers, you must enable the RAID controller cache policies. Table 8 shows only some parameters in the RAID configuration. In the actual configuration, see the storage controller user guide for the corresponding server model.
Parameter |
Array Label |
Name of the RAID array. The default is DefaultValue0. |
Stripe Size |
Strip size, which determines the data block size of a stripe on each drive. |
Array Size Selection |
RAID array capacity. |
Read Cache |
Read cache policy status. Options include Enabled and Disabled. |
Write Cache |
Write cache policy status. Options include: · Enable Always—Always enables the write cache. Without a supercapacitor installed, this status might cause data loss if power supply fails. · Enable With Backup Unit—Disables the write cache when the supercapacitor is absent or not ready. · Disabled—Disables the write cache. |
Create RAID via |
Operation after the RAID array is created. Options include Quick Init, Skip Init, Build/Verify, and Clear. |
