00-Preface | 100.44 KB |
Preface
This command reference describes commands that help you get started with the device. It includes the commands for the following features and tasks:
· WLAN authentication
· WLAN IP snooping
· AAA
· 802.1X
· MAC authentication
· Port security
· Portal
· User identification
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
