- 12-WLAN Advanced Features Command Reference
- 01-WLAN optimization commands
- 02-Hotspot 2.0 commands
- 03-WLAN probe commands
- 04-WSA commands
- 05-Wireless location commands
- 06-WLAN process maintenance commands
- 07-Bonjour gateway commands
- 08-WLAN mesh commands
- 09-AC hierarchy commands
- 10-WLAN fast forwarding commands
- 11-WLAN forwarding commands
10-WLAN fast forwarding commands | 46.72 KB |
display wlan fast-forwarding status
Use display wlan fast-forwarding status to display WLAN fast forwarding status.
# Display WLAN fast forwarding status.
<Sysname> display wlan fast-forwarding status
Slot 1 WLAN fast forwarding information:
Status : Enabled
Mode : Software fast forwarding
Status |
WLAN fast forwarding status: · Enable. · Disable. |
Mode |
WLAN fast forwarding mode: · Software fast-forwarding. · Hardware fast-forwarding. |
wlan fast-forwarding enable
Use wlan fast-forwarding enable to enable WLAN fast forwarding.
Use undo wlan fast-forwarding enable to disable WLAN fast forwarding.
# Enable WLAN fast forwarding.
[Sysname] wlan fast-forwarding enable
wlan fast-forwarding hardware disable
Use wlan fast-forwarding hardware disable to disable the hardware forwarding function.
Use undo wlan fast-forwarding hardware disable to enable the hardware forwarding function.
The hardware forwarding function is enabled.
# Disable the hardware forwarding function.
[Sysname] wlan fast-forwarding hardware disable
wlan fast-forwarding mode
Use wlan fast-forwarding mode to set the WLAN fast forwarding mode.
wlan fast-forwarding mode { hardware | hardware-lite | software }
The WLAN fast forwarding mode is hardware.
hardware: Specifies hardware fast forwarding.
hardware-lite: Specifies light hardware fast forwarding. In this mode, hardware fast forwarding does not apply to CAPWAP packets and CAPWAP packets are forwarded only through software hard forwarding.
software: Specifies software fast forwarding.
# Set the WLAN fast forwarding mode to software.
[Sysname] wlan fast-forwarding mode software
