05-Comware 9 CLI-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10105-Comware 9 CLI-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
80-Static Blacklist Configuration Examples
80-Static Blacklist Configuration Examples 95.25 KB
H3C Access Controllers
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example for configuring the WLAN static blacklist.
This document applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of WLAN static blacklists.
Example: Configuring the WLAN static blacklist
As shown in Figure 1, the switch acts as a DHCP server to assign IP addresses to the AP and the clients, and the AC forwards client traffic. Client 1 is a rogue client. Configure the static blacklist to deny Client 1's access to the WLAN.
Figure 1 Network diagram
Use the serial ID labeled on the AP's rear panel to specify an AP.
Procedures
Configuring the AC
1.     Configure AC interfaces:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish a CAPWAP tunnel with the AP.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.1.0.1 16
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. Clients will use this VLAN to access the WLAN.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 192.2.0.1 24
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the AC to the switch as a trunk port, and assign the port to VLANs 1, 100, and 200.
[AC-GigabitEthernet1/0/1] port trunk permit vlan 1 100 200
2.     Configure wireless services:
# Create service template service and enter its view.
[AC] wlan service-template service
# Configure the SSID as service.
[AC-wlan-st-service] ssid service
# Specify VLAN 200 for clients to access the WLAN defined by the service template.
[AC-wlan-st-service] vlan 200
# Set the AKM mode to PSK and specify plaintext string 12345678 as the preshared key.
[AC-wlan-st-service] akm mode psk
[AC-wlan-st-service] preshared-key pass-phrase simple 12345678
# Specify the cipher suite as CCMP and the security IE as RSN.
[AC-wlan-st-service] cipher-suite ccmp
[AC-wlan-st-service] security-ie rsn
# Configure the AC to forward client data traffic. You can skip this step if the AC is the client traffic forwarder by default.
[AC-wlan-st-service] client forwarding-location ac
# Enable the service template.
[AC-wlan-st-service] service-template enable
[AC-wlan-st-service] quit
3.     Configure the AP:
In large-scale networks, configure AP groups instead of single APs as a best practice.
# Create manual AP officeap, and specify the AP model and serial ID.
[AC] wlan ap officeap model WA6320
[AC-wlan-ap-officeap] serial-id 219801A28N819CE0002T
# Create AP group group1, add the AP to the AP group, and specify the AP model.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap officeap
[AC-wlan-ap-group-group1] ap-model WA6320
# Bind service template service to radio 1.
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 1
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] service-template service
# Enable radio 1.
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] quit
[AC-wlan-ap-group-group1-ap-model-WA6320] quit
[AC-wlan-ap-group-group1] quit
4.     Add Client 1 to the static blacklist.
[AC] wlan static-blacklist mac-address 0000-000f-1211
Configuring the switch
1.     Configure switch interfaces:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The switch will use VLAN 100 to forward packets between the AC and the AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
[Switch-Vlan-interface100] ip address 192.1.0.2 16
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The switch will use VLAN 200 to forward client traffic.
[Switch] vlan 200
[Switch-vlan200] quit
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 192.2.0.2 24
[Switch-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the switch to the AC as a trunk port, and assign the port to VLANs 1, 100, and 200.
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 1 100 200
# Configure GigabitEthernet 1/0/2 that connects the switch to the AP as an access port, and assign the port to VLAN 100.
# Enable PoE on GigabitEthernet 1/0/2.
2.     Configure DHCP:
# Enable DHCP.
[Switch] dhcp enable
# Create DHCP address pool 100 to assign an IP address to the AP, and specify subnet 192.1.0.0/16 in the DHCP address pool.
[Switch] dhcp server ip-pool 100
[Switch-dhcp-pool-100] network 192.1.0.0 mask 255.255.0.0
# Specify the gateway address as 192.1.0.1 in the DHCP address pool.
[Switch-dhcp-pool-100] gateway-list 192.1.0.1
[Switch-dhcp-pool-100] quit
# Create DHCP address pool 200 to assign IP addresses to clients, and specify subnet 192.2.0.0/24 in the DHCP address pool.
[Switch] dhcp server ip-pool 200
[Switch-dhcp-pool-200] network 192.2.0.0 mask 255.255.255.0
# Specify the gateway address as 192.2.0.1 and specify the DNS server address in the DHCP address pool. In this example, the gateway also acts as the DNS server.
[Switch-dhcp-pool-200] gateway-list 192.2.0.1
[Switch-dhcp-pool-200] dns-list 192.2.0.1
[Switch-dhcp-pool-200] quit
# Verify that the MAC address of Client 1 is in the static blacklist.
[AC] display wlan blacklist static
Total number of clients: 1
 MAC addresses:
  0000-000f-1211
# Verify that only Client 2 is associated with the AP successfully.
[AC] display wlan client
MAC address     Username   AP name      RID   IP address      IPv6 address   VLAN
0000-000f-1212  N/A        officeap     1     192.2.0.3       N/A            200
Configuration files
·     AC:
vlan 1
vlan 100
vlan 200
 ssid service
 vlan 200
akm mode psk
cipher-suite ccmp
security-ie rsn
interface Vlan-interface100
 ip address 192.1.0.1 255.255.0.0
interface Vlan-interface200
 ip address 192.2.0.1 255.255.255.0
ap officeap
ap-model WA6320
radio 1
radio enable
·     Switch:
vlan 1
vlan 100
vlan 200
 dns-list 192.2.0.1
 ip address 192.1.0.2 255.255.0.0
 ip address 192.2.0.2 255.255.255.0
 port access permit vlan 100
 poe enable
Related documentation
·     WLAN Access Command Reference in H3C Access Controllers Command References
·     WLAN Access Configuration Guide in H3C Access Controllers Configuration Guides
