| 00-Preface | 32.70 KB |
Preface
This deployment guide describes how to deploy U-Center 2.0. It contains the following chapters:
· Overview
· U-Center 2.0 deployment procedure at a glance
· Preparing for deployment
· Installing U-Center 2.0
· Logging in to U-Center 2.0
· Registering the software
· Backup and recovery
· Cluster disaster recovery
· Upgrading the software
· Uninstalling U-Center 2.0
· FAQ
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the Unified Platform.
Conventions
GUI conventions
Convention |
Window names, button names, menu items, field values |
Window names, button names, menu items, and field values are in bold text. |
Multi-level menus |
Symbols
Convention |
NOTE: |
Documentation feedback
We appreciate your comments.
