| 02-Appendix | 9.52 MB |
Appendix A Server specifications
Server models and chassis view
Front panel view of the server
Appendix B Component specifications
DRAM DIMM rank classification label
Front 4LFF SAS/SATA drive backplane
Front 8SFF UniBay drive backplane
Front 2SFF UniBay drive backplane
Rear 2SFF UniBay drive backplane
Front 8SFF SAS/SATA drive backplane
Front 8LFF SAS/SATA drive backplane
Front 12LFF SAS/SATA drive backplane
Front 8SAS/SATA+4UniBay drive backplane
Front 4SAS/SATA+8UniBay drive backplane
Front 12LFF UniBay drive backplane
Front 17SAS/SATA+8UniBay drive backplane
Mid 8SFF UniBay drive backplane
Rear 2LFF SAS/SATA drive backplane
Rear 4LFF SAS/SATA drive backplane
Rear 2SFF SAS/SATA drive backplane
Rear 4SFF SAS/SATA drive backplane
Rear 4SFF UniBay drive backplane
Rear 2UniBay drive backplane (compatible with OCP riser card)
Front SATA M.2 expander module
Appendix C Managed removal of OCP network adapters
Appendix D Environment requirements
About environment requirements
General environment requirements
Operating temperature requirements
Operating temperature requirements without liquid-cooled module
Operating temperature requirements with liquid-cooled module
The information in this document might differ from your product if it contains custom configuration options or features.
Figures in this document are for illustration only.
H3C UniServer R4900 G6 Ultra servers are 2U dual-processor servers independently developed by H3C based on the new-generation Eagle Stream platform of Intel. The servers can be widely used in general computing scenarios, while focusing on high-performance computing, artificial intelligence, cloud desktop and other scenarios. They are suitable for typical applications in industries such as Internet, service providers, enterprises, and government. The servers have the characteristics of high computing performance, large storage capacity, low power consumption, strong scalability, high reliability, and ease of management and deployment.
The servers come in the models listed in Table 1. These models support different drive configurations. For more information about drive configuration and compatible storage controller configuration, see H3C UniServer R4900 G6 Ultra Server Drive Configurations and Cabling Solutions.
Table 1 R4900 G6 Ultra server models
Model |
Maximum drive configuration |
LFF |
12LFF drives at the front + drives (4LFF+2SFF) at the rear + 4LFF drives in the middle |
SFF |
25SFF drives at the front + drives (2SFF+2SFF+4SFF) at the rear + 8SFF drives in the middle |
E1.S |
32E1.S drives at the front |
Technical specifications
Item |
Specifications |
Dimensions (H × W × D) |
· Without a security bezel: ¡ LFF&SFF models: 87.5 × 445.4 × 780 mm (3.44 × 17.54 × 30.71 in) ¡ E1.S model: 87.5 × 445.4 × 820 mm (3.44 × 17.54 × 32.28 in) · With a security bezel: ¡ LFF&SFF models: 87.5 × 445.4 × 808 mm (3.44 × 17.54 × 31.81 in) ¡ E1.S model: 87.5 × 445.4 × 848 mm (3.44 × 17.54 × 33.39 in) |
Max. weight |
46.5 kg (102.51 lb) |
Processors |
2 × Intel Eagle Stream processors, maximum 350 W power consumption per processor Supports HBM Supports Montage Jintide processors |
Memory |
Up to 32 DIMMs (DDR5 supported) |
Storage controllers |
· High-performance standard storage controller · NVMe VROC module · Serial & DSD module (supports RAID 1) |
Chipset |
Intel Emmitsburg |
Integrated graphics |
The graphics chip (model AST2600) is integrated in the BMC management chip to provide a maximum resolution of 1920 × 1200@60Hz (32bpp), where: · 1920 × 1200: 1920 horizontal pixels and 1200 vertical pixels. · 60Hz: Screen refresh rate, 60 times per second. · 32bpp: Color depts. The higher the value, the more colors that can be displayed. If you attach monitors to both the front and rear VGA connectors, only the monitor connected to the front VGA connector is available. |
Network connectors |
· 1 × embedded 1 Gbps HDM dedicated management port · Up to three OCP 3.0 network adapter connectors (OCP 3.0 network adapters support NCSI) |
I/O connectors |
· 5 × USB connectors ¡ 3 × USB3.0 connectors (one on the right chassis ear, and two on the rear panel) ¡ 2 × USB2.0 connectors (one on the system board, and one available on the left chassis ear only when the multifunctional rack mount kit is used) · 12 × built-in SATA connectors (displayed as 3 × x4 SlimSAS connectors) · 12 × MCIO connectors (PCIe5.0 x8) · 1 × RJ-45 HDM dedicated network port (at the server rear) · 2 × VGA connectors (one on the front panel, and one available on the left chassis ear only when the multifunctional rack mount kit is used) · 1 × serial port (available only when the Serial & DSD module is used) · 1 × HDM dedicated management port (available on the left chassis ear only when the multifunctional rack mount kit is used) |
Expansion slots |
14 × PCIe standard slots (10 × PCIe 5.0 slots and 4 × PCIe 4.0 slots) |
Optical drives |
External USB optical drives |
Power supplies |
2 × hot-swappable power supplies, 1 + 1 redundancy |
Standards |
CCC, UL, CE |
Components
Figure 2 R4900 G6 Ultra server components
Item |
(1) Chassis access panel |
N/A |
(2) Mid drive cage |
Installed in the server to accommodate drives. |
(3) Standard PCIe network adapter |
Installed in a standard PCIe slot to provide network ports. |
(4) System battery |
Supplies power to the system clock to ensure system time correctness. |
(5) Storage controller |
Provides RAID capability to SAS/SATA drives, including RAID configuration and RAID scale-up. It supports online upgrade of the controller firmware and remote configuration. |
(6) NVMe VROC module |
Works with Intel VMD to provide RAID capability for the server to virtualize storage resources of NVMe drives. |
(7) GPU module |
Provides computing services such as graphics processing and AI. |
(8) Riser card |
Provides PCIe slots. |
(9) OCP riser card |
Provides one slot for installing an OCP network adapter and two slots for installing drives at the server rear. |
(10) Serial & DSD module |
Provides one serial port and two SD card slots. |
(11) Memory |
Stores computing data and data exchanged with external storage temporarily. |
(12) Rear drive backplane |
Provides power and data channels for drives at the server rear. |
(13) Rear drive cage |
Installed at the server rear to accommodate drives. |
(14) Server management module |
Provides I/O connectors and HDM out-of-band management features. |
(15) OCP network adapter |
Network adapter installed onto the OCP network adapter connector on the system board. |
(16) Riser card blank |
Installed on an empty PCIe riser connector to ensure good ventilation. |
(17) Power supply |
Supplies power to the server. The power supplies support hot swapping and 1+1 redundancy. |
(18) Chassis |
N/A |
(19) Chassis ears |
Attach the server to the rack. The right ear is integrated with the front I/O component, and the left ear is integrated with VGA connector, HDM dedicated management connector, and USB 3.0 connector. |
(20) Front drive backplane |
Provides power and data channels for drives at the server front. This document installs an 8SFF front drive backplane as an example. |
(21) LCD smart management module |
Displays basic server information, operating status, and fault information. Together with HDM event logs, users can fast locate faulty components and troubleshoot the server, ensuring server operation. |
(22) Drive |
Provides data storage space. Drives support hot swapping. |
(23) SATA M.2 SSD expander module |
Provides M.2 SSD slots. |
(24) SATA M.2 SSD drive |
Provides data storage space for the server. |
(25) Encryption module |
Provides encryption services for the server to enhance data security. |
(26) System board |
One of the most important parts of a server, on which multiple components are installed, such as processor, memory, and fan. It is integrated with basic server components, including the BIOS chip and PCIe connectors. |
(27) Processor socket cover |
Installed over an empty processor socket to protect pins in the socket. |
(28) Fan cage |
Accommodates fan modules. |
(29) Chassis open-alarm module |
Detects if the access panel is removed. The detection result can be displayed from the HDM Web interface. |
(30) Air baffle |
Provides ventilation aisles for processor heatsinks and memory modules and provides support for the supercapacitor. |
(31) Fan |
Helps server ventilation. Fans support hot swapping and N+1 redundancy. |
(32) Processor |
Integrates memory and PCIe controllers to provide data processing capabilities for the server. |
(33) Processor retaining bracket |
Attaches a processor to the heatsink. |
(34) Supercapacitor holder |
Secures a supercapacitor in the chassis. |
(35) Supercapacitor |
Supplies power to the flash card on the power fail safeguard module, which enables the storage controller to back up data to the flash card for protection when power outage occurs. |
(36) Mid GPU module |
Installed in the server to expand GPU modules to meet graphics computing and AI processing requirements. |
(37) Processor heatsink |
Cools the processor. |
(38) Processor liquid-cooled module |
Front panel
Figure 3 8LFF front panel
Table 2 8LFF front panel description
Item |
1 |
USB 3.0 connector |
2 |
Drive or LCD mart management module (optional) |
3 |
Serial label pull tab |
4 |
HDM dedicated management connector |
5 |
USB 2.0 connector |
6 |
VGA connector |
Figure 4 12LFF front panel
Table 3 12LFF front panel description
Item |
1 |
12LFF UniBay drives* |
2 |
USB 3.0 connector |
3 |
4 |
5 |
6 |
USB 2.0 connector |
7 |
VGA connector |
*: Drive types supported by the server vary by drive backplane configuration. For more information, see "Drive backplanes." |
Figure 5 8SFF front panel
Table 4 8SFF front panel description
Item |
1 |
Bay 1: 8SFF drives (optional)* |
2 |
Bay 2: 8SFF drives (optional)* |
3 |
Bay 3: 8SFF drives (optional)* |
4 |
USB 3.0 connector |
5 |
LCD smart management module (optional) |
6 |
7 |
8 |
USB 2.0 connector |
9 |
VGA connector |
Figure 6 25SFF front panel
Table 5 25SFF front panel description
Item |
1 |
25SFF drives* |
2 |
USB 3.0 connector |
3 |
4 |
5 |
6 |
USB 2.0 connector |
7 |
VGA connector |
Figure 7 32E1.S front panel
Table 6 32E1.S front panel description
Item |
1 |
USB 3.0 connector |
2 |
32E1.S drives |
3 |
4 |
5 |
USB 2.0 connector |
6 |
VGA connector |
LEDs and buttons
Figure 8 Front panel LEDs and buttons
Table 7 LEDs and buttons on the front panel
Button/LED |
Status |
Power on/standby button and system power LED |
· Steady green—The system has started. · Flashing green (1 Hz)—The system is starting. · Steady amber—The system is in standby state. · Off—No power is present. Possible reasons: ¡ No power source is connected. ¡ No power supplies are present. ¡ The installed power supplies are faulty. ¡ The system power cords are not connected correctly. |
OCP 3.0 network adapter Ethernet port LED |
· Steady green—A link is present on a port of an OCP 3.0 network adapter. · Flashing green (1 Hz)—A port on an OCP 3.0 network adapter is receiving or sending data. · Off—No link is present on any port of either OCP 3.0 network adapter. NOTE: The server supports a maximum of three OCP3.0 network adapters. |
Health LED |
· Steady green—The system is operating correctly or a minor alarm is present. · Flashing green (4 Hz)—HDM is initializing. · Flashing amber (1 Hz)—A major alarm is present. · Flashing red (1 Hz)—A critical alarm is present. If a system alarm is present, log in to HDM to obtain more information about the system running status. |
UID button LED |
· Steady blue—UID LED is activated. The UID LED can be activated by using the following methods: ¡ Press the UID button LED. ¡ Activate the UID LED from HDM. · Flashing blue: ¡ 1 Hz—The firmware is being upgraded or the system is being managed from HDM. Do not power off the server. ¡ 4 Hz—HDM is restarting. To restart HDM, press the UID button LED for eight seconds. · Off—UID LED is not activated. |
Security bezel light
The security bezel provides hardened security and uses effect light to visualize operation and health status to help inspection and fault location. The default effect light is as shown in Figure 9.
Table 8 Security bezel effect light
System status |
Light status |
Standby |
Steady white: The system is in standby state. |
Startup |
· Beads turn on white from middle in turn—POST progress. · Beads turn on white from middle three times—POST has finished. |
Running |
· Breathing white (gradient at 0.2 Hz)—Normal state, indicating the system load by the percentage of beads turning on from the middle to the two sides of the security bezel. ¡ No load—Less than 10%. ¡ Light load—10% to 50%. ¡ Middle load—50% to 80%. ¡ Heavy load—More than 80%. · Breathing white (gradient at 1 Hz)—A pre-alarm is present (only for drive pre-failure). · Flashing amber (1 Hz)—A major alarm is present. · Flashing red (1 Hz)—A critical alarm is present (only for power supply errors). |
UID |
· All beads flash white (1 Hz)—The firmware is being upgraded or the system is being managed from HDM. Do not power off the server. · Some beads flash white (1 Hz)—HDM is restarting. |
Ports
Table 9 Ports on the front panel
Port |
Type |
VGA connector |
DB-15 |
Connects a display terminal, such as a monitor or KVM device. |
USB connector |
USB 2.0/3.0 |
Connects the following devices: · USB flash drive. · USB keyboard or mouse. · USB optical drive for operating system installation. |
Type-C |
Connects a Type-C to USB adapter cable, which connects to a USB Wi-Fi adapter or USB drive. |
Rear panel
Rear panel view
Figure 10 Rear panel components
Table 10 Rear panel description
1 |
PCIe riser bay 1: PCIe slots 1 through 3 |
2 |
PCIe riser bay 2: PCIe slots 4 through 6 |
3 |
PCIe riser bay 3: PCIe slots 7 and 8 |
4 |
PCIe riser bay 4: PCIe slots 9 and 10 |
5 |
Power supply 2 |
6 |
Power supply 1 |
7 |
OCP 3.0 network adapter/Serial & DSD module (in slot 17) (optional) |
8 |
VGA connector |
9 |
Two USB 3.0 connectors |
10 |
HDM dedicated network port (1Gbps, RJ-45, default IP address 192.168.1.2/24) |
11 |
OCP 3.0 network adapter (in slot 16) (optional) |
For more information about the serial & DSD module, see "Serial & DSD module." |
When the server is installed with the liquid-cooled module, slot 6 on the rear panel will be used to install the inlet and outlet ports. The quick connectors will be differentiated into male connectors and hose connectors, as shown in Figure 11 and Figure 12, respectively.
Figure 11 Rear panel components (Processor liquid-cooled module with male connector)
Figure 12 Rear panel components (Processor liquid-cooled module with hose connector)
Table 11 Rear panel description (with liquid-cooled module installed)
Item |
1 |
2 |
PCIe riser bay 2: PCIe slots 4 through 5 |
3 |
PCIe riser bay 3: PCIe slots 7 through 8 |
4 |
5 |
Power supply 2 |
6 |
Power supply 1 |
7 |
OCP 3.0 network adapter or serial & DSD module (in slot 17) (optional) |
8 |
Liquid outlet (red) |
9 |
Liquid inlet (blue) |
10 |
VGA connector |
11 |
12 |
13 |
LEDs
(1) Power supply LED for power supply 2 |
(2) Power supply LED for power supply 1 |
(3) Activity LED of the Ethernet port |
(4) Link LED of the Ethernet port |
(5) UID LED |
Table 12 LEDs on the rear panel
LED |
Status |
Power supply LED |
· Steady green—The power supply is operating correctly. · Flashing green (0.33 Hz)—The power supply is in standby state and does not output power. · Flashing green (2 Hz)—The power supply is updating its firmware. · Steady amber—Either of the following conditions exists: ¡ The power supply is faulty. ¡ The power supply does not have power input, but another power supply has correct power input. · Flashing amber (1 Hz)—An alarm has occurred on the power supply. · Off—No power supplies have power input, which can be caused by an incorrect power cord connection or power source shutdown. |
· Flashing green (1 Hz)—The port is receiving or sending data. · Off—The port is not receiving or sending data. |
· Steady green—A link is present on the port. · Off—No link is present on the port. |
UID LED |
· Steady blue—UID LED is activated. The UID LED can be activated by using the following methods: ¡ Press the UID button LED. ¡ Enable UID LED from HDM. · Flashing blue: ¡ 1 Hz—The firmware is being upgraded or the system is being managed from HDM. Do not power off the server. ¡ 4 Hz—HDM is restarting. To restart HDM, press the UID button LED for 8 seconds. · Off—UID LED is not activated. |
Ports
Table 13 Ports on the rear panel
Port |
Type |
VGA connector |
DB-15 |
BIOS serial port |
DB-9 |
The BIOS serial port is used for the following purposes: · Log in to the server when the remote network connection to the server has failed. · Establish a GSM modem or encryption lock connection. NOTE: The serial port is on the serial & DSD module. For more information, see "Serial & DSD module." |
USB connector |
USB 3.0 |
HDM dedicated network port |
RJ-45 |
Establishes a network connection to manage HDM from its Web interface. |
Power receptacle |
Standard single-phase |
Connects the power supply to the power source. |
System board
System board components
Figure 14 System board components
Table 14 System board components
No. |
Mark |
1 |
PCIe riser connector 3 (for processor 2) |
RISER3 PCIe X16 |
2 |
PCIe riser connector 2 (for processor 2) |
RISER2 PCIe X16 |
3 |
Fan connector 2 for the OCP 3.0 network adapter |
4 |
OCP 3.0 network adapter connector 2/Serial & DSD module connector |
OCP2&DSD&UART CARD |
5 |
PCIe riser connector 1 (for processor 1) |
RISER1 PCIe X16 |
6 |
Server management module slot |
BMC |
7 |
Fan connector 1 for the OCP 3.0 network adapter |
OCP1 FAN |
8 |
OCP 3.0 network adapter connector 1 |
OCP1 |
9 |
SlimSAS connector 3 (x4 SATA) |
SATA PORT3 |
10 |
AUX connector 9 for mid drive backplane |
AUX9 |
11 |
Mid drive backplane/Riser card AUX connector 7 |
AUX7 |
12 |
SlimSAS connector 2 (x4 SATA) |
SATA PORT2 |
13 |
SlimSAS connector 1 (x4 SATA or M.2 SSD) |
M.2&SATA PORT1 |
14 |
Front I/O connector |
RIGHT EAR |
15 |
M.2 SSD AUX connector |
M.2 AUX |
16 |
Fan connector 4 |
J245 |
17 |
Liquid Leakage Detection module connector |
LEAKDET |
18 |
LCD smart management module connector |
DIAG LCD |
19 |
MCIO connector C1-P4A (for processor 1) |
C1-P4A |
20 |
MCIO connector C1-P4C (for processor 1) |
C1-P4C |
21 |
Fan connector 3 |
J104 |
22 |
MCIO connector C1-P3C (for processor 1) |
C1-P3C |
23 |
MCIO connector C1-P3A (for processor 1) |
C1-P3A |
24 |
Power connector 3 for front drive backplane |
PWR3 |
25 |
Power connector 2 for front drive backplane |
PWR2 |
26 |
Connector for the thermal sensor module at the air inlet |
27 |
Power connector 1 for front drive backplane |
PWR1 |
28 |
Fan connector 2 |
J94 |
29 |
MCIO connector C2-P4A (for processor 2) |
C2-P4A |
30 |
AUX connector 3 for front drive backplane |
AUX3 |
31 |
MCIO connector C2-P4C (for processor 2) |
C2-P4C |
32 |
MCIO connector C2-P3C (for processor 2) |
C2-P3C |
33 |
Fan connector 1 |
J96 |
34 |
AUX connector 2 for front drive backplane |
AUX2 |
35 |
AUX connector 1 for front drive backplane |
AUX1 |
36 |
MCIO connector C2-P3A (for processor 2) |
C2-P3A |
37 |
Chassis-open alarm module connector |
INTRUDER |
38 |
Mid drive backplane/Riser card power connector 6 |
PWR6 |
39 |
Front VGA and USB 2.0 connector |
LEFT EAR |
40 |
Power connector 4 for rear drive backplane |
PWR4 |
41 |
Power connector 5 for rear drive backplane |
PWR5 |
42 |
MCIO connector C2-P2C (for processor 2) |
C2-P2C |
43 |
AUX connector 5 for rear drive backplane |
AUX5 |
44 |
MCIO connector C2-P2A (for processor 2) |
C2-P2A |
45 |
AUX connector 6 for mid drive backplane |
AUX6 |
46 |
AUX connector 4 for rear drive backplane |
AUX4 |
47 |
Riser card AUX connector 8 |
AUX8 |
48 |
NVMe VROC module connector |
NVMe RAID KEY |
49 |
Embedded USB 2.0 connector |
INTERNAL USB2.0 |
50 |
TPM/TCM connector |
TPM |
51 |
System battery |
52 |
MCIO connector C1-P2C (for processor 1) |
C1-P2C |
53 |
MCIO connector C1-P2A (for processor 1) |
C1-P2A |
X |
System maintenance switch |
MAINTENANCE SW |
Figure 15 shows the system maintenance switch. Table 15 describes how to use the maintenance switch.
Figure 15 System maintenance switch
Table 15 System maintenance switch description
Item |
Remarks |
1 |
· Off (default)—HDM login requires the username and password of a valid HDM user account. · On—HDM login requires the default username and password. |
For security purposes, turn off the switch after you complete tasks with the default username and password as a best practice. |
5 |
· Off (default)—Normal server startup. · On—Restores the default BIOS settings. |
To restore the default BIOS settings, turn on and then turn off the switch. The server starts up with the default BIOS settings at the next startup. The server cannot start up when the switch is turned on. To avoid service data loss, stop running services and power off the server before turning on the switch. |
6 |
· Off (default)—Normal server startup. · On—Clears all passwords from the BIOS at server startup. |
If this switch is on, the server will clear all the passwords at each startup. Make sure you turn off the switch before the next server startup if you do not need to clear all the passwords. |
2, 3, 4, 7, and 8 |
Reserved for future use. |
N/A |
DIMM slots
The system board provides eight DIMM channels per processor, and 16 channels in total, as shown in Figure 16. Each channel contains two DIMM slots.
Figure 16 System board DIMM slot layout
For components compatible with the server and detailed component information, use the component compatibility lookup tool at http://www.h3c.com/en/home/qr/default.htm?id=66.
About component model names
The model name of a hardware option in this document might differ slightly from its model name label.
A model name label might add a prefix or suffix to the hardware-coded model name for purposes such as identifying the matching server brand or applicable region. For example, the DDR5-4800-32G-1Rx4 memory model represents memory module labels including UN-DDR5-4800-32G-1Rx4-R, UN-DDR5-4800-32G-1Rx4-F, and UN-DDR5-4800-32G-1Rx4-S, which have different prefixes and suffixes.
DIMMs
The server provides eight DIMM channels per processor and each channel has two DIMM slots. If the server has one processor, the total number of DIMM slots is 16. If the server has two processors, the total number of DIMM slots is 32. For the physical layout of DIMM slots, see "DIMM slots."
A DIMM rank is a set of memory chips that the system accesses while writing or reading from the memory. On a multi-rank DIMM, only one rank is accessible at a time.
To determine the rank classification of a DIMM, use the label attached to the DIMM, as shown in Figure 17. The meaning of the DDR DIMM rank classification labels are similar and this section uses the label of a DDR5 DIMM as an example.
Figure 17 DDR DIMM rank classification label
Table 16 DIMM rank classification label description
Callout |
Remarks |
1 |
Capacity |
Options include: · 8GB. · 16GB. · 32GB. |
2 |
Number of ranks |
Options include: · 1R—One rank (Single-Rank). · 2R—Two ranks (Dual-Rank). A 2R DIMM is equivalent to two 1R DIMMs. · 4R—Four ranks (Quad-Rank). A 4R DIMM is equivalent to two 2R DIMMs · 8R—Eight ranks (8-Rank). An 8R DIMM is equivalent to two 4R DIMMs. |
3 |
Data width |
Options include: · ×4—4 bits. · ×8—8 bits. |
4 |
DIMM generation |
DDR5 |
5 |
Data rate |
Options include: · 2666V—2666 MHz. · 2933Y—2933 MHz. · 3200AA—3200 MHz. · 4800—4800 MHz. |
6 |
DIMM type |
Options include: · L—LRDIMM. · R—RDIMM. |
HDDs and SSDs
Drive numbering
The server provides different drive numbering schemes for different drive configurations at the server front and rear, as shown in Figure 18 through Figure 22.
Figure 18 Drive numbering for front 25SFF drive configuration
Figure 19 Drive numbering for front 12LFF drive configuration
Figure 20 Drive numbering for front 8LFF drive configuration
Figure 21 Drive numbering for front 32E1.S drive configuration
Figure 22 Drive numbering for rear 4LFF+4SFF drive configuration
Figure 23 Drive numbering for rear 2SFF+2SFF+4SFF drive configuration
Figure 24 Drive numbering for the rear OCP riser card configuration
Figure 25 Drive numbering for the mid 4LFF drive configuration
Figure 26 Drive numbering for the mid 8SFF drive configuration
Drive LEDs
The server supports SAS, SATA, and NVMe (including E1.S) drives, of which SAS and SATA drives support hot swapping and NVMe drives support hot insertion and managed hot removal. You can use the LEDs on a drive to identify its status after it is connected to a storage controller.
For more information about OSs that support hot insertion and managed hot removal of NVMe drives, use the component compatibility lookup tool at http://www.h3c.com/en/home/qr/default.htm?id=66.
Figure 27 shows the location of the LEDs on a drive.
(1) Fault/UID LED |
(2) Present/Active LED |
Figure 28 E1.S drive LEDs
(1) Fault/UID LED |
To identify the status of a SAS or SATA drive, use Table 17. To identify the status of an NVMe drive, use Table 18.
Table 17 SAS/SATA drive LED description
Fault/UID LED status |
Present/Active LED status |
Flashing amber (0.5 Hz) |
Steady green/Flashing green (4.0 Hz) |
A drive failure is predicted. As a best practice, replace the drive before it fails. |
Steady amber |
The drive is faulty. Replace the drive immediately. |
Steady blue |
The drive is operating correctly and is selected by the RAID controller. |
Off |
The drive is performing a RAID migration or rebuilding, or the system is reading or writing data to the drive. |
Off |
Steady green |
The drive is present but no data is being read or written to the drive. |
Off |
Off |
The drive is not securely installed. |
Table 18 NVMe drive LED description
Flashing amber (4 Hz) |
Off |
The drive is in hot insertion process. |
Steady amber |
Steady blue |
The drive is operating correctly and selected by the RAID controller. |
Off |
Off |
Steady green |
Off |
Off |
Drive configurations
The server supports multiple drive configurations. For more information about drive configurations and their required storage controller and riser cards, see H3C UniServer R4900 G6 Ultra Server Drive Configurations and Cabling Guide.
Drive backplanes
The server supports the following types of drive backplanes:
· SAS/SATA drive backplanes—Support only SAS/SATA drives.
· NVMe drive backplanes—Support only NVMe drives.
· UniBay drive backplanes—Support both SAS/SATA and NVMe drives. You must connect both SAS/SATA and NVMe data cables. The number of supported drives varies by drive cabling.
The PCA-BP-4LFF-1U-G6 4LFF SAS/SATA drive backplane can be installed at the server front to support four 3.5-inch SAS/SATA drives.
Figure 29 4LFF SAS/SATA drive backplane
(1) AUX connector (AUX 1) |
(2) Power connector (PWR 1) |
(3) x4 Mini-SAS-HD connector (SAS PORT 1) |
The PCA-BP-8UniBay-1U-G6 8SFF UniBay drive backplane can be installed at the server front to support eight 2.5-inch SAS/SATA/NVMe drives.
Figure 30 8SFF UniBay drive backplane
(1) AUX connector (AUX1) |
(2) MCIO connector A1/A2 (PCIe5.0 x8)(NVMe A1/A2) |
(3) Power connector (PWR1) |
(4) MCIO connector A3/A4 (PCIe5.0 x8)(NVMe A3/A4) |
(5) SAS/SATA connector (SAS PORT) |
(6) MCIO connector B1/B2 (PCIe5.0 x8)(NVMe B1/B2) |
(7) MCIO connector B3/B4 (PCIe5.0 x8)(NVMe B3/B4) |
PCIe5.0 x8 description: · PCIe5.0: Fifth-generation signal speed. · x8: Bus bandwidth. |
The HDDCage-2UniBay-1U-G6 UniBay drive backplane can be installed at the server front to support two 2.5-inch SAS/SATA/NVMe drives.
Figure 31 2SFF UniBay drive backplane
(1) SlimSAS connector A1/A2 (PCIe4.0 x8)(NVME-A1/A2) |
(2) x4 Mini-SAS-HD connector (SAS PORT) |
(3) AUX connector (AUX) |
(4) Power connector (PWR) |
PCIe4.0 x8 description: · PCIe4.0: Fourth-generation signal speed. · x8: Bus bandwidth. |
The HDDCage-2UniBay-R-1U-G6 drive backplane can be installed at the server front to support two 3.5-inch SAS/SATA/NVMe drives.
Figure 32 2SFF UniBay drive backplane
(1) SlimSAS connector A1/A2 (PCIe4.0 x8) (NVME-A1/A2) |
Drive backplanes
· X SAS/SATA+Y UniBay drive backplanes—Support SAS/SATA drives in all slots and support NVMe drives in certain slots.
¡ X: Number of slots supporting only SAS/SATA drives.
¡ Y: Number of slots supporting both SAS/SATA and NVMe drives.
For UniBay drive backplanes and X SAS/SATA+Y UniBay drive backplanes:
· The two drive types are supported only when both SAS/SATA and NVMe data cables are connected.
· The number of supported SAS/SATA drives and the number of supported NVMe drives vary by cable connection.
The PCA-BP-8SFF-2U-G6 8SFF SAS/SATA drive backplane can be installed at the server front to support eight 2.5-inch SAS/SATA drives.
Figure 33 8SFF SAS/SATA drive backplane
(1) x8 SlimSAS connector (SAS PORT1) |
(2) AUX connector (AUX) |
(3) Power connector (PWR) |
The PCA-BP-8UniBay-2U-G6 8SFF UniBay drive backplane can be installed at the server front to support eight 2.5-inch SAS/SATA/NVMe drives.
Figure 34 8SFF UniBay drive backplane
(1) x8 SlimSAS connector (SAS PORT) |
(2) AUX ( AUX) |
(3) MCIO connector B3/B4 (PCIe5.0 x8)(NVMe B3/B4) |
(4) Power connector (POWER) |
(5) MCIO connector B1/B2 (PCIe5.0 x8)(NVMe B1/B2) |
(6) MCIO connector A3/A4 (PCIe5.0 x8)(NVMe A3/A4) |
(7) MCIO connector A1/A2 (PCIe5.0 x8)(NVMe A1/A2) |
The PCA-BP-8LFF-2U-G6 8LFF SAS/SATA drive backplane can be installed at the server front to support eight 3.5-inch SAS/SATA drives.
Figure 35 8LFF SAS/SATA drive backplane
(1) X8 Mini-SAS-HD connector (SAS PORT) |
(2) Power connector (PWR) |
The PCA-BP-12LFF-2U-G6 12LFF SAS/SATA drive backplane can be installed at the server front to support twelve 3.5-inch SAS/SATA drives.
Figure 36 12LFF SAS/SATA drive backplane
(1) x4 SlimSAS connector (SAS PORT 2), managing the last four SAS/SATA drives on the backplane |
(2) Power connector 2 (PWR 2) |
(4) Power connector 1 (PWR 1) |
(5) x8 SlimSAS connector (SAS PORT 1), managing the first eight SAS/SATA drives on the backplane |
The PCA-BP-12LFF-4NVMe-2U-G6 12LFF drive backplane can be installed at the server front to support twelve 3.5-inch SAS/SATA/NVMe drives, including eight SAS/SATA drives and four SAS/SATA/NVMe drives.
Figure 37 8SAS/SATA+4UniBay drive backplane
(1) MCIO connector A3 (PCIe5.0 x4)(NVMe-A3), supporting NVMe drive 9 |
(2) x4 SlimSAS connector (SAS PORT 2), managing the last four SAS/SATA drives on the backplane |
(3) Power connector 2 (PWR 2) |
(4) AUX connector 1(AUX 1) |
(5) Power connector 1 (PWR 1) |
(6) x8 SlimSAS connector (SAS PORT 1), managing the first eight SAS/SATA drives on the backplane |
(7) MCIO connector A4 (PCIe5.0 x4)(NVMe-A4), supporting NVMe drive 8 |
(8) MCIO connector A1/A2 (PCIe5.0 x8)(NVMe-A1/A2), supporting NVMe drives 10 and 11 |
For more information about drive numbering, see "Drive numbering." PCIe5.0 x8 description: · PCIe5.0: Fifth-generation signal speed. · x8: Bus bandwidth. |
The PCA-BP-12LFF-EXP-2U-G6 12LFF drive backplane can be installed at the server front to support twelve 3.5-inch SAS/SATA/NVMe drives, including four SAS/SATA drives and eight SAS/SATA/NVMe drives. The drive backplane integrates an Expander chip to manage 12 SAS/SATA drives through an x8 SlimSAS connector. The drive backplane also provides three downlink interfaces to connect to other drive backplanes and support more drives.
Figure 38 4SAS/SATA+8UniBay drive backplane
(1) x8 SlimSAS uplink interface (SAS PORT), managing all drives on the backplane |
(2) x4 SlimSAS downlink interface 3 (SAS EXP3) |
(3) Power connector 2 (PWR2) |
(4) MCIO connector B1/B2 (PCIe5.0 x8)(NVMe-B1/B2), supporting NVMe drives 6 and 7 |
(5) Power connector 1 (PWR1) |
(6) x8 SlimSAS downlink interface 2 (SAS EXP2) |
(7) x4 SlimSAS downlink interface 1 (SAS EXP1) |
(8) AUX connector (AUX) |
(9) MCIO connector B3/B4 (PCIe5.0 x8)(NVMe B3/B4), supporting NVMe drives 4 and 5 |
(10) MCIO connector A3/A4 (PCIe5.0 x8)(NVMe A3/A4), supporting NVMe drives 8 and 9 |
(11) MCIO connector A1/A2 (PCIe5.0 x8)(NVMe A1/A2), supporting NVMe drives 10 and 11 |
The PCA-BP-12LFF-UniBay-2U-G6 12LFF UniBay drive backplane can be installed at the server front to support twelve 3.5-inch SAS/SATA/NVMe drives.
Figure 39 12LFF UniBay drive backplane
(1) MCIO connector A3 (PCIe5.0 x4)(NVMe-A3) |
(3) MCIO connector B1/B2 (PCIe5.0 x8)(NVMe-B1/B2) |
(4) Power connector 2 (PWR 2) |
(5) AUX connector 1 (AUX 1) |
(6) MCIO connector C1 (PCIe5.0 x4)(NVMe-C1) |
(7) Power connector 1 (PWR 1) |
(8) x8 SlimSAS connector (SAS PORT 1), managing the first eight SAS/SATA drives on the backplane |
(9) MCIO connector C3/C4 (PCIe5.0 x8)(NVMe-C3/C4) |
(10) MCIO connector C2 (PCIe5.0 x4)( NVMe-C2) |
(11) MCIO connector B3/B4 (PCIe5.0 x8)(NVMe-B3/B4) |
(12) MCIO connector A4 (PCIe5.0 x4)(NVMe-A4) |
(13) MCIO connector A1/A2 (PCIe5.0 x8)(NVMe-A1/A2) |
The PCA-BP-25SFF-2U-G6 25SFF drive backplane can be installed at the server front to support twenty-five 2.5-inch SAS/SATA/NVMe drives, including 17 SAS/SATA drives and 8 SAS/SATA/NVMe drives. The drive backplane can use an x8 SlimSAS connector to manage 25 SAS/SATA drives. The drive backplane also integrates an Expander chip and three downlink interfaces to connect to other drive backplanes and support more drives.
Figure 40 17SAS/SATA+8UniBay drive backplane
(1) x4 SlimSAS downlink interface 3 (SAS EXP 3) |
(2) x8 SlimSAS uplink interface (SAS PORT), managing all drives on the backplane |
(3) x8 SlimSAS downlink interface 2 (SAS EXP 2) |
(4) x4 SlimSAS downlink interface 1 (SAS EXP 1) |
(6) Power connector 2 (PWR 2) |
(7) MCIO connector 4 (PCIe5.0 x8)(NVMe 4), supporting NVMe drives 17 and 18 |
(9) MCIO connector 3 (PCIe5.0 x8)(NVMe 3), supporting NVMe drives 19 and 20 |
(10) MCIO connector 2 (PCIe5.0 x8)(NVMe 2), supporting NVMe drives 21 and 22 |
(11) Power connector 3 (PWR 3) |
(12) MCIO connector 1 (PCIe5.0 x8)(NVMe 1), supporting NVMe drives 23 and 24 |
Front 16E1.S drive backplane
The PCA-BP-16E1S-1U-G6 16E1.S drive backplane can be installed at the server front to support sixteen 9.5 mm E1.S drives.
Figure 41 16E1.S drive backplane
(2) MCIO connector D3/D4 (PCIe5.0 x8)(EDSFF-D3/D4) |
(3) Power connector 1 (PWR 1) |
(4) MCIO connector D1/D2 (PCIe5.0 x8)(EDSFF-D1/D2) |
(5) MCIO connector C3/C4 (PCIe5.0 x8)(EDSFF-C3/C4) |
(6) MCIO connector C1/C2 (PCIe5.0 x8)(EDSFF-C1/C2) |
(7) MCIO connector B3/B4 (PCIe5.0 x8)(EDSFF-B3/B4) |
(8) MCIO connector B1/B2 (PCIe5.0 x8)(EDSFF-B1/B2) |
(9) MCIO connector A3/A4 (PCIe5.0 x8)(EDSFF-A3/A4) |
(10) Power connector 2 (PWR 2) |
(11) MCIO connector A1/A2 (PCIe5.0 x8)(EDSFF-A1/A2) |
Mid 4LFF SAS/SATA backplane
The PCA-BP-4LFF-2U-M-G6 4LFF drive backplane can be installed in the mid 4LFF drive cage on the server to support four 3.5-inch SAS/SATA drives.
Figure 42 4LFF SAS/SATA drive backplane
(3) x4 Mini-SAS-HD connector (SAS PORT1) |
The PCA-BP-8Unibay-2U-M-G6 8SFF UniBay drive backplane is combined by two 4SFF UniBay drive backplanes and can be installed at the server middle. Each 4SFF UniBay drive backplane can support four 2.5-inch SAS/SATA/NVMe drives.
Figure 43 4SFF UniBay drive backplane
(1) AUX connector (AUX) |
(3) MCIO connector B1/B2 (PCIe5.0 x8)(NVME-B1/B2) |
(4) MCIO connector B3/B4 (PCIe5.0 x8)(NVME-B3/B4) |
(5) x4 Mini-SAS-HD connector (SAS PORT) |
The PCA-BP-2LFF-2U-G6 2LFF SAS/SATA drive backplane is installed at the server rear to support two 3.5-inch SAS/SATA drives.
Figure 44 2LFF SAS/SATA drive backplane
(1) x4 Mini-SAS-HD connector (SAS PORT1) |
(2) AUX connector (AUX1) |
The PCA-BP-4LFF-2U-G6 4LFF SAS/SATA drive backplane is installed at the server rear to support four 3.5-inch SAS/SATA drives.
Figure 45 4LFF SAS/SATA drive backplane
(2) Power connector (PWR1) |
The PCA-BP-2SFF-2U-G6 2SFF SAS/SATA drive backplane is installed at the server rear to support two 2.5-inch SAS/SATA drives.
Figure 46 2SFF SAS/SATA drive backplane
(1) Power connector (PWR) |
The PCA-BP-2SFF-2UniBay-2U-G6 2SFF UniBay drive backplane is installed at the server rear to support two 2.5-inch SAS/SATA/NVMe drives.
Figure 47 2SFF UniBay drive backplane
(3) SlimSAS connector (PCIe4.0 x8)(NVME) |
(4) AUX connector (AUX) |
PCIe4.0 x8 description: · PCIe4.0: Fifth-generation signal speed. · x8: Bus bandwidth. |
The PCA-BP-4SFF-2U-G6 4SFF SAS/SATA drive backplane is installed at the server rear to support four 2.5-inch SAS/SATA drives.
Figure 48 4SFF SAS/SATA drive backplane
(1) x4 Mini-SAS-HD connector (SAS PORT) |
The PCA-BP-4SFF-4UniBay-2U-G6 4SFF UniBay drive backplane is installed at the server rear to support four 2.5-inch SAS/SATA/NVMe drives.
Figure 49 4SFF UniBay drive backplane
The PCA-BP-2UniBay-OCP-2U-G6 2SFF UniBay drive backplane is installed together with an OCP riser card at the server rear to support two 2.5-inch SAS/SATA/NVMe drives.
Figure 50 2SFF UniBay drive backplane
Riser cards
To expand the server with PCIe modules, install riser cards on the PCIe riser connectors.
Riser card guidelines
Each PCIe slot in a riser card can supply a maximum of 75 W of power to the PCIe module. You must connect a separate power cord to the PCIe module if it requires more than 75 W of power.
If a processor is faulty or absent, the PCIe slots connected to it are unavailable.
The slot number of a PCIe slot varies by the PCIe riser connector that holds the riser card. For example, slot 1/4 represents PCIe slot 1 if the riser card is installed on connector 1 and represents PCIe slot 4 if the riser card is installed on connector 2. For information about PCIe riser connector locations, see "Rear panel view."
RC-FHFL-2U-G6
Figure 51 RC-FHFL-2U-G6
(1) PCIe5.0 x16 (16,8,4,2,1) slot 3/6* |
(2) Rear 2SFF SAS/SATA drive backplane |
PCIe5.0 x16 (16,8,4,2,1) description: · PCIe5.0: Fifth-generation signal speed. · x16: Connector bandwidth. · (16,8,4,2,1): Compatible bus bandwidth, including x16, x8, x4, x2, and x1. |
NOTE: · slot 3/6: When the riser card is installed in PCIe riser card slot 1, this slot corresponds to PCIe slot 3. When the riser card is installed in PCIe riser card slot 2, this slot corresponds to PCIe slot 6. This rule applies to all the other PCIe riser card slots. For information about PCIe slots, see "Rear panel view." · For more information about the rear 2SFF SAS/SATA drive backplane, see "Rear 2SFF SAS/SATA drive backplane." |
RC-1FHFL-R3-2U-G6
Figure 52 RC-1FHFL-R3-2U-G6
(1) GPU module power connector |
(2) PCIe5.0 x16 (16,8,4,2,1) slot 7 |
NOTE: This type is riser card is not supported when liquid-cooled modules are installed on the server. |
RC-2FHFL-2U-LC-G6
Figure 53 RC-2FHFL-2U-LC-G6 (1)
Figure 54 RC-2FHFL-2U-LC-G6 (2)
(1) PCIe5.0 x16 (16,8,4,2,1) slot 5 |
(2) PCIe5.0 x16 (16,8,4,2,1) slot 4 |
(3) GPU module power connector |
(4) MCIO connector 2-C |
(5) MCIO connector 2-A |
(6) MCIO connector 1-A |
(7) MCIO connector 1-C |
RC-2HHHL-R3-2U-G6
Figure 55 RC-2HHHL-R3-2U-G6
(1) PCIe5.0 x16 (8,4,2,1) slot 8 |
(2) PCIe5.0 x16 (8,4,2,1) slot 7 |
PCIe5.0 x16 (8,4,2,1) description: · PCIe5.0: Fifth-generation signal speed. · x16: Connector bandwidth. · (8,4,2,1): Compatible bus bandwidth, including x8, x4, x2, and x1. |
RC-2FHFL-R3-2U-G6
Figure 56 RC-2FHFL-R3-2U-G6
RC-2HHHL-R4-2U-G6
Figure 57 RC-2HHHL-R4-2U-G6
(1) SLOT 2 cable |
(2) AUX connector |
(3) PCIe5.0 x16 (8,4,2,1) slot 8 |
(4) PCIe5.0 x16 (8,4,2,1) slot 7 |
(5) Power connector |
(6) SLOT 1 cable |
RC-3FHFL-2U-G6
Figure 58 RC-3FHFL-2U-G6 (1)
Figure 59 RC-3FHFL-2U-G6 (2)
(1) PCIe5.0 x16 (16,8,4,2,1) slot 2/5 |
(2) PCIe5.0 x16 (16,8,4,2,1) slot 3/6 |
(4) PCIe5.0 x16 (16,8,4,2,1) slot 1/4* |
(5) MCIO connector 2-C |
(6) MCIO connector 2-A |
(7) PMCIO connector 1-A |
(8) MCIO connector 1-C |
NOTE: slot 1/4: When the riser card is installed in PCIe riser card slot 1, this slot corresponds to PCIe slot 1. When the riser card is installed in PCIe riser card slot 2, this slot corresponds to PCIe slot 4. This rule applies to all the other PCIe riser card slots. For information about PCIe slots, see "Rear panel view." |
RC-3FHHL-2U-G6
Figure 60 RC-3FHHL-2U-G6 (1)
Figure 61 RC-3FHHL-2U-G6 (2)
(1) PCIe5.0 x16 (8,4,2,1) slot 2/5 |
(2) PCIe5.0 x16 (8,4,2,1) slot 3/6 |
(3) PCIe5.0 x16 (16,8,4,2,1) slot 1/4* |
(4) MCIO connector 1-A |
(5) MCIO connector 1-C |
RC-5HHHL-R5-2U-G5
Figure 62 RC-5HHHL-R5-2U-G5
(1) PCIe5.0 x16 (8,4,2,1) slot 12 |
(2) MCIO connector 2 |
(3) PCIe5.0 x16 (8,4,2,1) slot 13 |
(4) MCIO connector 3 |
(5) PCIe5.0 x16 (8,4,2,1) slot 14 |
(6) MCIO connector 4 |
(7) PCIe5.0 x16 (8,4,2,1) slot 15 |
(8) MCIO connector 5 |
(9) Power connector |
(10) AUX connector |
PCA-R4900-4GPU-G6
Figure 63 PCA-R4900-4GPU-G6 (1)
(1) PCIe5.0 x16 (8,4,2,1) slot 14 |
(2) PCIe5.0 x16 (8,4,2,1) slot 13 |
(3) PCIe5.0 x16 (8,4,2,1) slot 12 |
(4) PCIe5.0 x16 (8,4,2,1) slot 11 |
(5) GPU module power connector |
(6) GPU module power connector |
Figure 64 PCA-R4900-4GPU-G6 (2)
(7) GPU module power connector |
(8) GPU module power connector |
Figure 65 PCA-R4900-4GPU-G6 (3)
(9) PCIe5.0 x16 (16,8,4,2,1) slot 6 |
(10) PCIe5.0 x16 (16,8,4,2,1) slot 3 |
OCP riser card
Figure 66 OCP riser card
(1) MCIO connector 4 |
(2) MCIO connector 3 |
(3) Power connector |
(4) AUX connector |
(5) MCIO connector 2 |
(6) MCIO connector 1 |
An LCD smart management module displays basic server information, operating status, and fault information, and provides diagnostics and troubleshooting capabilities. You can locate and troubleshoot component failures by using the LCD module in conjunction with the event logs generated in HDM.
Figure 67 LCD smart management module
Table 19 LCD smart management module description
No. |
Item |
1 |
Mini-USB connector |
Used for upgrading the firmware of the LCD module. |
2 |
LCD module cable |
Connects the LCD module to the system board of the server. For information about the LCD smart management module connector on the system board, see "System board." |
3 |
LCD module shell |
Protects and secures the LCD screen. |
4 |
LCD screen |
Displays basic server information, operating status, and fault information. |
Fan modules
The server supports four hot swappable fan modules. The server supports N+1 fan module redundancy. Figure 68 shows the layout of the fan modules in the chassis.
The server uses intelligent fan energy-saving and noise-reduction technology, which integrates multiple AI algorithms. It can monitor the temperature, power, and other status information of the device in real-time to obtain the optimal fan adjustment policy. Then, it dynamically adjusts the fan duty cycle configuration to meet the device's energy-saving and noise-reduction requirements.
PCIe slot
The server supports installing mid GPU adapters in the server middle and supports installing riser cards, rear GPU modules, and OCP 3.0 adapters at the server rear. The PCIe slot numbers vary by configuration.
Figure 69 PCIe slot numbering when riser cards are installed at the server rear
Figure 70 PCIe slot numbering when 2UniBay drive backplanes and OCP 3.0 adapters are installed at the server rear
Figure 71 PCIe slot numbering when rear GPU modules are installed
Figure 72 PCIe slot numbering on a mid GPU adapter
IMPORTANT: You cannot configure both rear GPU modules and mid GPU adapters on the same server. |
PCIe modules
Typically, the PCIe modules are available in the following standard form factors:
· LP—Low profile.
· FHHL—Full height and half length.
· FHFL—Full height and full length.
· HHHL—Half height and half length.
· HHFL—Half height and full length.
The following PCIe modules require PCIe I/O resources: Storage controllers, FC HBAs, and GPU modules. Make sure the number of such PCIe modules installed does not exceed 11.
Storage controllers
The server supports the following types of storage controllers:
· Embedded VROC controller—Embedded in the server and does not require installation.
· Standard storage controller—Comes in a standard PCIe form factor and typically requires a riser card for installation.
For some storage controllers, you can order a power fail safeguard module to prevent data loss from power outages. This module provides a flash card and a supercapacitor. When a system power failure occurs, the supercapacitor provides power for a minimum of 20 seconds. During this interval, the storage controller can transfer data from DDR memory to the flash card, where the data remains indefinitely or until the controller retrieves the data. If the storage controller contains a built-in flash card, you can order only a supercapacitor.
Item |
Specifications |
Type |
Embedded in PCH of the system board |
Number of internal ports |
12 internal SAS ports (compatible with SATA) |
Connectors |
Three onboard ×4 SlimSAS connectors |
Drive interface |
6 Gbps SATA 3.0 Supports drive hot swapping |
PCIe interface |
PCIe3.0 ×4 |
RAID levels |
0, 1, 5, 10 |
Built-in cache memory |
N/A |
Built-in flash |
N/A |
Power fail safeguard module |
Not supported |
Firmware upgrade |
Upgrade with the BIOS |
Standard storage controllers
For more information, use the component compatibility lookup tool at http://www.h3c.com/en/home/qr/default.htm?id=66.
NVMe VROC modules
Model |
RAID levels |
Compatible NVMe SSDs |
NVMe-VROC-Key-S |
0, 1, 10 |
All NVMe drives |
NVMe-VROC-Key-P |
0, 1, 5, 10 |
All NVMe drives |
Figure 73 Front view of the front SATA M.2 expander module
(1) Data cable connector |
(2) M.2 SSD drive slot 1 |
Figure 74 Rear view of the front SATA M.2 expander module
(1) SATA M.2 SSD drive slot 2 |
Rear NVMe M.2 expander module
Figure 75 Rear NVMe M.2 expander module
(1) NVMe M.2 SSD drive slot 1 |
(2) NVMe M.2 SSD drive slot 2 |
The server management module is installed on the system board to provide I/O connectors and HDM out-of-band features for the server.
Figure 76 Server management module
(1) VGA connector |
(2) Two USB 3.0 connectors |
(3) HDM dedicated network interface |
(4) UID LED |
(5) HDM serial port |
(6) iFIST module |
(7) NCSI connector |
Serial & DSD module
The serial & DSD module is installed in the slot on the server rear panel. The module provides two SD slots and forms RAID 1 by default.
Figure 77 Serial & DSD module
Table 20 Component description
Item |
1 |
SD card slot 1 |
2 |
SD card slot 2 |
3 |
Serial port |
B/D/F information
You can obtain B/D/F information by using one of the following methods:
· BIOS log—Search the dumpiio keyword in the BIOS log.
· UEFI shell—Execute the pci command. For information about how to execute the command, execute the help pci command.
· Operating system—The obtaining method varies by OS.
¡ For Linux, execute the lspci command.
If Linux does not support the lspci command by default, use the software package manager supported by the operating system to obtain and install the pci-utils package.
¡ For Windows, install the pciutils package, and then execute the lspci command.
¡ For VMware, execute the lspci command.
Before you begin
Before you perform a managed removal of an OCP network adapter, perform the following tasks:
· Use the OS compatibility query tool at http://www.h3c.com/en/home/qr/default.htm?id=66 to obtain operating systems that support managed removal of OCP network adapters.
· Make sure the BIOS version is 6.00.15 or higher, the HDM2 version is 1.13 or higher, and the CPLD version is V001 or higher.
Performing a hot removal
This section uses an OCP network adapter in slot 16 as an example.
To perform a hot removal:
1. Access the operating system.
2. Execute the dmidecode -t 9 command to search for the bus address of the OCP network adapter. As shown in Figure 78, the bus address of the OCP network adapter in slot 16 is 0000:31:00.0.
Figure 78 Searching for the bus address of an OCP network adapter by slot number
3. Execute the echo 0 > /sys/bus/pci/slots/slot number/power command, where slot number represents the number of the slot where the OCP network adapter resides.
Figure 79 Executing the echo 0 > /sys/bus/pci/slots/slot number/power command
4. Identify whether the OCP network adapter has been disconnected:
¡ Observe the OCP network adapter LED. If the LED is off, the OCP network adapter has been disconnected.
¡ Execute the lspci –vvv –s 0000:31:00.0 command. If no output is displayed, the OCP network adapter has been disconnected.
Figure 80 Identifying OCP network adapter status
5. Replace the OCP network adapter.
6. Identify whether the OCP network adapter has been connected:
¡ Observe the OCP network adapter LED. If the LED is on, the OCP network adapter has been connected.
¡ Execute the lspci –vvv –s 0000:31:00.0 command. If an output is displayed, the OCP network adapter has been connected.
Figure 81 Identifying OCP network adapter status
7. Identify whether any exception exists. If any exception occurred, contact H3C Support.
The operating temperature requirements for the server vary depending on the server model and hardware configuration. When the general and component-based requirements conflict, use the component-based requirement.
Be aware that the actual maximum operating temperature of the server might be lower than what is stated because of poor site cooling performance. In a real data center, the server cooling performance might decrease because of adverse external factors, including poor cabinet cooling performance, high power density inside the cabinet, or insufficient spacing between devices.
Item |
Specifications |
Operating temperature |
Minimum: 5°C (41°F) Maximum: 40°C (104°F) · The maximum temperature varies by hardware option presence. For more information, see "Operating temperature requirements." |
Storage temperature |
–40°C to +70°C (–40°F to +158°F) |
Operating humidity |
8% to 90%, noncondensing |
Storage humidity |
5% to 95%, noncondensing |
Operating altitude |
–60 m to +3000 m (–196.85 ft to +9842.52 ft) The allowed maximum temperature decreases by 0.33°C (32.59°F) as the altitude increases by 100 m (328.08 ft) from 900 m (2952.76 ft) |
Storage altitude |
–60 m to +5000 m (–196.85 ft to +16404.20 ft) |
General guidelines
The cooling capability of the server depends on the power density of devices within the cabinet, the cooling capability of the cabinet, and the spacing between the server and other devices. When the server is stacked with other devices, the maximum operating temperature of the server might decrease.
If a mid drive or mid GPU adapter is installed, you cannot install processors with a TDP of more than 165 W.
When a CRPS-195mm 2000W power supply is installed, the maximum server operating temperature decreases by 3°C (37.4°F).
When an 8038 or 8056 fan fails, the maximum server operating temperature decreases by 5°C (41°F). If the power consumption of GPU modules is greater than 165W, the performance of processors might decrease.
Table 21 shows the operating temperature requirements for the server without the liquid-cooled module.
Table 21 Operating temperature requirements without liquid-cooled module
Drive configuration |
Maximum temperature |
Remarks |
30°C (86°F) |
35°C (95°F) |
40°C (104°F) |
· 8LFF · 8SFF 1 (without TOSHIBA SAS HDD SFF) · 16SFF · E1.S |
Smart network adapters and GPUs are not supported when mid drives are installed. |
The following are not supported: · A40 GPUs. · Mid GPUs. · Smart network adapters and GPUs when mid drives are installed. · Processors of more than 270W when the 4GPU module is installed. |
The following are not supported: · GPUs. · U.2 NVMe SSDs. · Mid drives and rear drives. · Processors of more than 165W. · Delta DPS-1600AB-13 R 1600W Platinum AC power supply. |
Fan speed unrestricted. |
· 8SFF1(without TOSHIBA SAS HDD SFF) · 12LFF · 25SFF · 24SFF |
The following are not supported: · A40/A16 GPU. · Mid GPU. · Smart network adapters and GPUs are not supported when mid drives are installed |
The following are not supported: · A100-80G/A40/A16 GPUs · Processors of more than 300W when rear drives (including HDDs, U.2/E1.S NVMe SSDs, excluding SATA/SAS SSDs) are installed. · Delta DPS-1600AB-13 R 1600W Platinum AC power supply. · Mid GPUs. · Smart network adapters and GPUs when mid drives are installed. · Processors of more than 270W when the rear 4GPU module is installed. · Processors of more than 250W when the rear A2 GPU is installed. · Processors of more than 250W when E1.S NVMe drives of 3.84 TB are installed. |
With the 8SFF drive configuration that uses TOSHIBA SAS HDD SFF, the 8056 fan module is limited to 90% of its maximum speed. |
1: The 8SFF drives are installed in slots 0 to 7. For more information about drive slots, see "Drive numbering." |
Table 22 shows the operating temperature requirements for the server without the liquid-cooled module.
Table 22 Operating temperature requirements with liquid-cooled module
Remarks |
30°C (86°F) |
35°C (95°F) |
40°C (104°F) |
· 8LFF · 8SFF1 (without TOSHIBA SAS HDD SFF) · 16SFF · E1.S |
All configurations are supported. |
The following are not supported: · GPUs. · U.2/E1.S NVMe SSDs. · Mid drives and rear drives. · Delta DPS-1600AB-13 R 1600W Platinum AC power supply. |
· 8SFF1 (with TOSHIBA SAS HDD SFF) · 12LFF · 25SFF · 24SFF |
A40/A16 GPUs are not supported. |
A100-80G/A40/A16 GPUs are not supported |
Appendix E Product recycling
New H3C Technologies Co., Ltd. provides product recycling services for its customers to ensure that hardware at the end of its life is recycled. Vendors with product recycling qualification are contracted to New H3C to process the recycled hardware in an environmentally responsible way.
For product recycling services, contact New H3C at
· Tel: 400-810-0504
· E-mail: [email protected]
· Website: http://www.h3c.com
Appendix F Glossary
B |
BIOS |
Basic input/output system is non-volatile firmware pre-installed in a ROM chip on a server's management module. The BIOS stores basic input/output, power-on self-test, and auto startup programs to provide the most basic hardware initialization, setup and control functionality. |
C |
CPLD |
Complex programmable logic device is an integrated circuit used to build reconfigurable digital circuits. |
G |
GPU module |
Graphics processing unit module converts digital signals to analog signals for output to a display device and assists processors with image processing to improve overall system performance. |
H |
HDM |
Hardware Device Management is the server management control unit with which administrators can configure server settings, view component information, monitor server health status, and remotely manage the server. |
A module that supports hot swapping (a hot-swappable module) can be installed or removed while the server is running without affecting the system operation. |
K |
KVM |
KVM is a management method that allows remote users to use their local video display, keyboard, and mouse to monitor and control the server. |
N |
NVMe VROC module |
A module that works with Intel VMD to provide RAID capability for the server to virtualize storage resources of NVMe drives. |
R |
RAID |
Redundant array of independent disks (RAID) is a data storage virtualization technology that combines multiple physical hard drives into a single logical unit to improve storage and security performance. |
Redundancy |
A mechanism that ensures high availability and business continuity by providing backup modules. In redundancy mode, a backup or standby module takes over when the primary module fails. |
S |
Security bezel |
A locking bezel mounted to the front of a server to prevent unauthorized access to modules such as hard drives. |
U |
A unit of measure defined as 44.45 mm (1.75 in) in IEC 60297-1. It is used as a measurement of the overall height of racks, as well as equipment mounted in the racks. |
UniBay drive backplane |
A UniBay drive backplane supports both SAS/SATA and NVMe drives. |
UniSystem |
UniSystem provided by H3C for easy and extensible server management. It can guide users to configure a server quickly with ease and provide an API interface to allow users to develop their own management tools. |
V |
VMD |
VMD provides hot removal, management and fault-tolerance functions for NVMe drives to increase availability, reliability, and serviceability. |
Appendix G Acronyms
Acronym |
Full name |
B |
BIOS |
C |
CMA |
Cable Management Arm |
CPLD |
D |
DCPMM |
Data Center Persistent Memory Module |
DDR |
Double Data Rate |
DIMM |
Dual In-Line Memory Module |
DRAM |
Dynamic Random Access Memory |
DVD |
Digital Versatile Disc |
G |
GPU |
H |
HBA |
Host Bus Adapter |
HDD |
Hard Disk Drive |
HDM |
I |
IDC |
Internet Data Center |
iFIST |
integrated Fast Intelligent Scalable Toolkit |
K |
KVM |
Keyboard, Video, Mouse |
L |
LRDIMM |
Load Reduced Dual Inline Memory Module |
N |
NCSI |
Network Controller Sideband Interface |
NVMe |
Non-Volatile Memory Express |
P |
PCIe |
Peripheral Component Interconnect Express |
POST |
Power-On Self-Test |
R |
RDIMM |
Registered Dual Inline Memory Module |
S |
SAS |
Serial Attached Small Computer System Interface |
SATA |
Serial ATA |
SD |
Secure Digital |
SDS |
Secure Diagnosis System |
SFF |
Small Form Factor |
sLOM |
Small form factor Local Area Network on Motherboard |
SSD |
Solid State Drive |
T |
TCM |
Trusted Cryptography Module |
TDP |
Thermal Design Power |
TPM |
Trusted Platform Module |
U |
UID |
Unit Identification |
UPI |
Ultra Path Interconnect |
UPS |
Uninterruptible Power Supply |
USB |
Universal Serial Bus |
V |
VROC |
Virtual RAID on CPU |
VMD |
Volume Management Device |
