| 02-FRUs and compatibility matrixes | 15.73 MB |
2 FRUs and compatibility matrixes
CEPC-CQ8L/CEPC-CQ8LA/CEPC-CQ8L1A/CEPC-CQ8L3A
CSPEX-1104-E/CSPEX-1204/CSPEX-1304X/CSPEX-1404X/CSPEX-1504X/CSPEX-1504XA
CSPEX-1502X/CSPEX-1502XA/CSPEX-1602X/CSPEX-1602XA
CSPEX-1512X/CSPEX-1612X/CSPEX-1812X/CSPEX-1812X-E/CSPEX-1802X/CSPEX-1802XA/CSPEX-2612XA
MIC-GT20L/MIC-GT20L1/MIC-GT20LA
IM modules (Universal line processing unit)
IM modules (Security monitor line processing unit)
IM modules (Network data encryption service processing unit)
IM modules (Universal open application platform)
CSFC-04-1/CSFC-04-2/CSFC-04-3/CSFC-04-4
CSFC-16T/CSFC-16T1/CSFC-16E/CSFC-16EA
CR16010-F (one fan tray) fan tray
CR16010-F (dual fan trays) fan tray
CR16010H-F/CR16010H-FA/CR16018-F/CR16018-FA fan trays
For compatibility between the cards and the software release, see the release notes.
For compatibility between the cards and transceiver modules, see the cards and transceiver modules compatibility matrixes for the device.
NOTE: · This document uses the identifier printed on a card or subcard as its model name. · All subcards except for the MIC-SM are hot swappable. |
MPUs
You can install one MPU, or two MPUs for redundancy for the router. To install two MPUs for the router, make sure they are the same model.
CSR05SRP1L1
View
Figure2-1 CSR05SRP1L1 view
(1) CF card |
(2) Console port |
(3) USB console port |
(4) Management Ethernet port (10/100/1000Base-T) |
(5) USB 2.0 port |
(6) System reset button |
(7) MPU active/standby LED. For the LED description, see Table2-1. |
(8) Card status LEDs. For the LED description, see Table2-2. |
(9) Fan tray status LEDs. For the LED description, see Table2-3. |
(10) Management Ethernet port LED. For the LED description, see Table2-4. |
(11) CF card LED. For the LED description, see Table2-5. |
LEDs
Table2-1 MPU active/standby LED description
LED mark |
Status |
ACTIVE |
Steady green |
The MPU is in active state. |
Off |
The following are the possible causes: · The MPU is in standby state. · The MPU has failed. To identify the failure, see the card status LED description. |
Table2-2 Card status LED description
Status |
RUN (Green) |
ALM (Red) |
Flashing green (once every 2 seconds) |
Off |
The card in the corresponding slot is operating correctly. |
Fast flashing green (once every 4 seconds) |
Steady on |
The card in the corresponding slot is loading software. If the card keeps in this state, the current software version of the device is not running the software version compatible with the card. |
Flashing red (once every 4 seconds) |
The temperature of the card in the corresponding slot is abnormal. The temperature has exceeded the upper warning temperature threshold or dropped below the lower temperature threshold. |
Steady on |
Steady on |
The card in the corresponding slot is starting or faulty. |
Off |
Off |
No card is available in the corresponding slot. |
NOTE: At the system startup, the ALM LED being on for a while does not mean that the card is faulty. |
Table2-3 Fan tray status LED description
Status |
OK (Green) |
FAIL (Red) |
Steady on |
Off |
The fan tray is operating correctly. |
Off |
Steady on |
One or more fans in the fan tray have failed or the fan tray is not in position. |
Off |
Off |
The router is not powered on. |
Table2-4 Management Ethernet port LED description
Status |
LINK (Green) |
ACT (yellow) |
Steady on |
Flashing green |
The port is in sending or receiving data. |
Steady on |
Off |
A link is present on the port. |
Off |
Off |
No link is present on the port. |
Table2-5 CF card LED description
LED |
Status |
CF card |
Steady green |
The CF card is present and idle. Do not hot swap it. |
Flashing green |
The CF card is present and the system is reading/writing the card. Do not hot swap it. |
Off |
The CF card is not in position, or the CF card is in offline state. You can hot swap it. |
Ports
Console port
The console port can be connected to a computer for system debugging, configuration, maintenance, management, and host software loading.
Table2-6 Console port specifications
Item |
Connector type |
RJ-45 |
Compliant standard |
Asynchronous EIA/TIA-232 |
Transmission baud rate |
≤ 115200 bps. The default value is 9600 bps. |
Transmission medium and max transmission distance |
Common asynchronous serial interface cable, with a maximum transmission distance of 15 m (49.21 ft) |
Services |
Connects to the serial port on a local PC running a terminal emulation program. |
USB console port
Table2-7 USB console port specifications
Item |
Connector type |
USB-AB |
USB 2.0, full speed |
USB-AB cable, with a maximum transmission distance of 2 m (6.56 ft) |
Services |
Connects to the USB port on a local PC running a terminal emulation program to provide a command-line interface for the router. A generic USB to serial port driver is required on the PC. Connects routers to PCs or similar terminals that do not have a serial port. |
Connects to a computer for router program loading and router debugging, or connects to a remote NMS for remote management.
Table2-8 Management Ethernet port specifications
Item |
Connector type |
RJ-45 |
Port quantity |
1 |
10/100/1000 Mbps |
Category-5 or above twisted pair cable, with a transmission distance of 100 m (328.08 ft) |
Services |
For router software upgrade and network management |
USB port
USB ports can connect multiple types of devices and provide a higher data transfer rate than common parallel interfaces and serial interfaces.
Table2-9 USB port specifications
Item |
Connector type |
USB A |
USB 2.0 |
Services |
External storage media |
NOTE: Extension cables are not supported. |
CF card slot
A CF card is a mobile storage device that features fast speed, large capacity, small size, light weight, and low power consumption.
Table2-10 External CF card specifications
Item |
CF card slots |
1 |
CF card capacity |
4 GB |
Services |
You can use a CF card to store logs, application program files, and configuration files. |
NOTE: Before you use a CF card, insert the CF card into the card slot and fasten the card cover. |
Technical specifications
Table2-11 Technical specifications
Item |
Dimensions (H × W × D) |
40 × 399 × 352 mm (1.57 × 15.71 × 13.86 in) |
Weight |
3.05 kg (6.72 lb) |
Maximum power consumption |
53 W |
Power consumption (with typical configuration) |
47 W |
Minimum power consumption |
46 W |
Operating temperature |
0°C to 45°C (32°F to 113°F) |
SDRAM |
8 GB or 16 GB (subject to the card specifications) |
CSR05SRP1L3
View
Figure2-2 CSR05SRP1L3 view
(1) High-precision time synchronization ports (Both are input ports by default. When both ports are input ports, only port 1 takes effect.) |
(2) CF card |
(3) SMB coaxial clock ports (2 input ports and 2 output ports) |
(4) Console port |
(5) USB console port |
(6) Management Ethernet ports (10/100/1000Base-T) |
(7) USB 2.0 port |
(8) System reset button |
(9) MPU active/standby LED. For the LED description, see Table2-12. |
(10) Card status LEDs. For the LED description, see Table2-13. |
(11) Fan tray status LEDs. For the LED description, see Table2-14. |
(12) Management Ethernet port LED. For the LED description, see Table2-15. |
(13) CF card LED. For the LED description, see Table2-16. |
LEDs
Table2-12 MPU active/standby LED description
LED mark |
Status |
ACTIVE |
Steady green |
Off |
Table2-13 Card status LED description
Status |
RUN (Green) |
ALM (Red) |
Off |
Steady on |
Steady on |
Steady on |
Off |
Off |
Table2-14 Fan tray status LED description
Status |
OK (Green) |
FAIL (Red) |
Steady on |
Off |
Off |
Steady on |
Off |
Off |
Table2-15 Management Ethernet port LED description
Status |
LINK (Green) |
ACT (yellow) |
Steady on |
Flashing green |
Steady on |
Off |
Off |
Off |
Table2-16 CF card LED description
LED |
Status |
CF card |
Steady green |
Flashing green |
Off |
Ports
Console port
Table2-17 Console port specifications
Item |
Connector type |
RJ-45 |
Services |
USB console port
Table2-18 USB console port specifications
Item |
Connector type |
USB-AB |
Services |
Table2-19 Management Ethernet port specifications
Item |
Connector type |
RJ-45 |
Port quantity |
1 |
10/100/1000 Mbps |
Services |
USB port
Table2-20 USB port specifications
Item |
Connector type |
USB A |
USB 2.0 |
Services |
CF card slot
Table2-21 External CF card specifications
Item |
CF card slots |
1 |
CF card capacity |
4 GB |
Services |
SMB coaxial clock input/output port
SMB coaxial clock ports provide input or output clock references at 2.048 Mbps (2.048 MHz). You can set the data rate mode or frequency mode through the CLI. Two of them are input ports and two are output ports.
Table2-22 SMB coaxial clock input/output port specifications
Item |
Connector type |
SMB coaxial |
GJB681 |
2.048 Mbps |
Transmission medium |
75-ohm coaxial cable |
Services |
Sends and receives 2.048 MHz clocks and 2.048 Mbps signals to synchronize the clocks of the router and other devices, such as routers and the terminals. |
Table2-23 High-precision time synchronization port specifications
Item |
Connector type |
RJ-45 |
QB-B-016-2010 |
9600 bps |
Category-5 or above twisted pair cable |
Services |
You can configure the port as an input port or output port at the CLI. Synchronizes the clocks of the router and other devices, such as GPS receivers and terminals. |
Table2-24 Technical specifications
Item |
Weight |
3.18 kg (7.01 lb) |
53 W |
52 W |
50 W |
SDRAM |
CSR05SRP1P1
View
Figure2-3 CSR05SRP1P1 view
(1) USB console port |
(2) USB 2.0 port |
(3) Management Ethernet ports (10/100/1000Base-T) (port 1 reserved for future use) |
(4) Console port |
(5) System reset button |
(6) MPU active/standby LED. For the LED description, see Table2-25. |
(7) Card status LEDs. For the LED description, see Table2-26. |
(8) Power supply status LED. For the LED description, see Table2-27. |
(9) Fan tray status LED. For the LED description, see Table2-28. |
(10) Management Ethernet port LED. For the LED description, see Table2-29. |
LEDs
Table2-25 MPU active/standby LED description
LED mark |
Status |
ACTIVE |
Steady green |
Off |
Table2-26 Card status LED description
Status |
RUN (Green) |
ALM (Red) |
Off |
Steady on |
Steady on |
Steady on |
Off |
Off |
Table2-27 Power supply status LED description
Status |
OK (Green) |
FAIL (Red) |
Steady on |
Off |
All power supplies in the chassis are operating correctly. |
Off |
Steady on |
A power supply in the chassis does not have power output, because the power supply is faulty, the power supply is not powered on, the power cable is faulty, or the external power supply system has a power outage. |
Off |
Off |
The following are the possible causes: · No power supplies exist in the chassis. · No power supply in the chassis has power output, because the power supplies are faulty, the power supplies are not powered on, the power cables are faulty, or the external power supply system has a power outage. |
Table2-28 Fan tray status LED description
Status |
OK (Green) |
FAIL (Red) |
Steady on |
Off |
Off |
Steady on |
Off |
Off |
Table2-29 Management Ethernet port LED description
LED mark |
Status |
LINK/ACT |
Flashing green |
Steady green |
Off |
Ports
Console port
Table2-30 Console port specifications
Item |
Connector type |
RJ-45 |
Services |
USB console port
Table2-31 USB console port specifications
Item |
Connector type |
USB-AB |
Services |
Table2-32 Management Ethernet port specifications
Item |
Connector type |
RJ-45 |
Port quantity |
2 (port 1 reserved for future use) |
10/100/1000 Mbps |
Services |
USB port
Table2-33 USB port specifications
Item |
Connector type |
USB A |
USB 2.0 |
Services |
Table2-34 Technical specifications
Item |
52.2 × 399 × 352 mm (2.06 × 15.71 × 13.86 in) |
Weight |
4.30 kg (9.48 lb) |
64 W |
60 W |
58 W |
SDRAM |
8 GB |
CSR05SRP1P3/CSR05SRP1P3A
View
Figure2-4 CSR05SRP1P3 view
(2) CF card |
(4) SMB coaxial clock ports (2 input ports and 2 output ports) |
(5) USB 2.0 port |
(6) Management Ethernet ports (10/100/1000Base-T) (port 1 reserved for future use) |
(7) Console port |
(9) MPU active/standby LED. For the LED description, see Table2-35. |
(10) Card status LEDs. For the LED description, see Table2-36. |
(11) Power supply status LED. For the LED description, see Table2-37. |
(12) Fan tray status LED. For the LED description, see Table2-38. |
(13) Management Ethernet port LED. For the LED description, see Table2-39. |
(14) CF card LED. For the LED description, see Table2-40. |
The views of the CSR05SRP1P3 and CSR05SRP1P3A are similar. This figure uses the CSR05SRP1P3 as an example.
LEDs
Table2-35 MPU active/standby LED description
LED mark |
Status |
ACTIVE |
Steady green |
Off |
Table2-36 Card status LED description
Status |
RUN (Green) |
ALM (Red) |
Off |
Steady on |
Steady on |
Steady on |
Off |
Off |
Table2-37 Power supply status LED description
Status |
OK (Green) |
FAIL (Red) |
Steady on |
Off |
Off |
Steady on |
Off |
Off |
The following are the possible causes: No power supplies exist in the chassis. No power supply in the chassis has power output, because the power supplies are faulty, the power supplies are not powered on, the power cables are faulty, or the external power supply system has a power outage. |
Table2-38 Fan tray status LED description
Status |
OK (Green) |
FAIL (Red) |
Steady on |
Off |
Off |
Steady on |
Off |
Off |
Table2-39 Management Ethernet port LED description
LED mark |
Status |
LINK/ACT |
Flashing green |
Steady green |
Off |
Table2-40 CF card LED description
LED |
Status |
CF card |
Steady green |
Flashing green |
Off |
Ports
Console port
Table2-41 Console port specifications
Item |
Connector type |
RJ-45 |
Services |
USB console port
Table2-42 USB console port specifications
Item |
Connector type |
USB-AB |
Services |
Table2-43 Management Ethernet port specifications
Item |
Connector type |
RJ-45 |
Port quantity |
10/100/1000 Mbps |
Services |
USB port
Table2-44 USB port specifications
Item |
Connector type |
USB A |
USB 2.0 |
Services |
CF card slot
Table2-45 External CF card specifications
Item |
CF card slots |
1 |
CF card capacity |
4 GB |
Services |
IMPORTANT: Before you use a CF card, insert the CF card into the card slot and fasten the card cover. |
Table2-46 SMB coaxial clock input/output port specifications
Item |
Connector type |
SMB coaxial |
GJB681 |
2.048 Mbps |
Services |
Table2-47 High-precision time synchronization port specifications
Item |
Connector type |
RJ-45 |
QB-B-016-2010 |
9600 bps |
Services |
Table2-48 CSR05SRP1P3/CSR05SRP1P3A MPU
Item |
Weight |
CSR05SRP1P3: 4.80 kg (10.58 lb) CSR05SRP1P3A: 4.40kg (9.70 lb) |
64 W |
60 W |
58 W |
SDRAM |
16 GB |
CSR05SRP1P3-G
View
Figure2-5 CSR05SRP1P3-G view
(2) SMB coaxial clock ports (2 input ports and 2 output ports) |
(4) USB 2.0 port |
(5) Management Ethernet ports (1000Base-T) |
(6) Console port |
(7) System reset button |
(8) MPU active/standby LED. For the LED description, see Table2-49. |
(9) Card status LEDs. For the LED description, see Table2-50. |
(10) Power supply status LED. For the LED description, see Table2-51. |
(11) Fan tray status LED. For the LED description, see Table2-52. |
(12) Management Ethernet port LED. For the LED description, see Table2-53. |
LEDs
Table2-49 MPU active/standby LED description
LED mark |
Status |
ACTIVE |
Steady green |
Off |
Table2-50 Card status LED description
LED mark |
Status |
RUN/ALM |
Flashing green |
Fast flashing green (4 Hz) |
The service module in the corresponding slot is loading software. If the card keeps in this state, the current software version of the device is not running the software version compatible with the card. |
Steady red |
Flashing red |
Off |
Table2-51 Power supply status LED description
Power supply status LED |
Status |
PWR (Red or green) |
Green |
Red |
Off |
Table2-52 Fan tray status LED description
Fan tray status LED |
Status |
FAN (Red or green) |
Green |
Red |
Off |
Table2-53 Management Ethernet port LED description
LED mark |
Status |
LINK/ACT |
Flashing green |
Steady green |
Off |
Ports
Console port
Table2-54 Console port specifications
Item |
Connector type |
RJ-45 |
Services |
USB console port
Table2-55 USB console port specifications
Item |
Connector type |
USB-AB |
Services |
Table2-56 Management Ethernet port specifications
Item |
Connector type |
RJ-45 |
Port quantity |
2 |
1000 Mbps, full duplex |
Services |
USB port
Table2-57 USB port specifications
Item |
Connector type |
USB A |
USB 2.0 |
Services |
Table2-58 SMB coaxial clock input/output port specifications
Item |
Connector type |
SMB coaxial |
GJB681 |
2.048 Mbps |
Services |
Table2-59 High-precision time synchronization port specifications
Item |
Connector type |
RJ-45 |
QB-B-016-2010 |
9600 bps |
Services |
Table2-60 Technical specifications
Item |
Weight |
4.50 kg (9.92 lb) |
65W |
50 W |
40 W |
SDRAM |
16 GB |
CSR05SRP1R3/CSR05SRP1R3A
View
Figure2-6 CSR05SRP1R3 view
(4) USB 2.0 port |
(5) Management Ethernet ports (1000Base-T) (port 1 reserved for future use) |
(6) Console port |
(8) MPU active/standby LED. For the LED description, see Table2-61. |
(9) Card status LEDs. For the LED description, see Table2-62. |
(10) Power supply status LED. For the LED description, see Table2-63. |
(11) Fan tray status LED. For the LED description, see Table2-64. |
(12) Management Ethernet port LED. For the LED description, see Table2-65. |
The views of the CSR05SRP1R3 and CSR05SRP1R3A are similar. This figure uses the CSR05SRP1R3 as an example.
LEDs
Table2-61 MPU active/standby LED description
LED mark |
Status |
ACTIVE |
Steady green |
Off |
Table2-62 Card status LED description
Status |
RUN (Green) |
ALM (Red) |
Off |
Steady on |
Steady on |
Steady on |
Off |
Off |
Table2-63 Power supply status LED description
Status |
OK (Green) |
FAIL (Red) |
Steady on |
Off |
Off |
Steady on |
Off |
Off |
Table2-64 Fan tray status LED description
Status |
OK (Green) |
FAIL (Red) |
Steady on |
Off |
Off |
Steady on |
Off |
Off |
Table2-65 Management Ethernet port LED description
LED mark |
Status |
LINK/ACT |
Flashing green |
Steady green |
Off |
Ports
Console port
Table2-66 Console port specifications
Item |
Connector type |
RJ-45 |
Services |
USB console port
Table2-67 USB console port specifications
Item |
Connector type |
USB-AB |
Services |
Table2-68 Management Ethernet port specifications
Item |
Connector type |
RJ-45 |
Port quantity |
Services |
USB port
Table2-69 USB port specifications
Item |
Connector type |
USB A |
USB 2.0 |
Services |
Table2-70 SMB coaxial clock input/output port specifications
Item |
Connector type |
SMB coaxial |
GJB681 |
2.048 Mbps |
Services |
Table2-71 High-precision time synchronization port specifications
Item |
Connector type |
RJ-45 |
QB-B-016-2010 |
9600 bps |
Services |
Table2-72 Technical specifications
Item |
Weight |
4.90 kg (10.80 lb) |
130W |
95W |
89W |
SDRAM |
2 × 16 GB |
CSR05SRP051E3-G
View
Figure2-7 CSR05SRP051E3-G view
(1) Management Ethernet port (10/100/1000Base-T) |
(2) Console port |
(3) System reset button |
(4) USB 2.0 port |
(5) High-precision time synchronization ports (Both are input ports by default. When both ports are input ports, only port 1 takes effect.) |
(6) SMB coaxial clock output ports (2 in total) |
(7) SMB coaxial clock input ports (2 in total) |
(8) MPU active/standby LED. For the LED description, see Table2-73. |
(9) Power supply status LED. For the LED description, see Table2-74. |
(10) Fan tray status LED. For the LED description, see Table2-75. |
(11) Card status LEDs. For the LED description, see Table2-76. |
(12) Management Ethernet port LED. For the LED description, see Table2-77. |
LEDs
Table2-73 MPU active/standby LED description
LED mark |
Status |
ACTIVE |
Steady green |
Off |
Table2-74 Power supply status LED description
Status |
Steady green |
Steady red |
Off |
Table2-75 Fan tray status LED description
Status |
Steady green |
Steady red |
Off |
Table2-76 Card status LED description
LED mark |
Status |
RUN/ALM |
Flashing green |
Steady red |
Flashing red |
Off |
Table2-77 Management Ethernet port LED description
Status |
LINK (Green) |
ACT (yellow) |
Steady on |
Flashing |
A link is present, and the port is sending or receiving data. |
Steady on |
Off |
A link is present, but the port is not sending or receiving data. |
Off |
Off |
Ports
Table2-78 Management Ethernet port specifications
Item |
Connector type |
RJ-45 |
Port quantity |
1 |
10/100/1000 Mbps |
Services |
Console port
Table2-79 Console port specifications
Item |
Connector type |
RJ-45 |
Services |
USB port
Table2-80 USB port specifications
Item |
Connector type |
USB A |
USB 2.0 |
Services |
Table2-81 High-precision time synchronization port specifications
Item |
Connector type |
RJ-45 |
QB-B-016-2010 |
9600 bps |
Services |
Table2-82 SMB coaxial clock input/output port specifications
Item |
Connector type |
SMB coaxial |
GJB681 |
2.048 Mbps |
Services |
Table2-83 Technical specifications
Item |
38.9 × 199 × 353 mm (1.53 × 7.83 × 13.90 in) |
Weight |
2.45 kg (5.40 lb) |
120 W |
100 W |
94 W |
SDRAM |
16 GB or 32 GB (subject to the card specifications) |
CSR05SRP101E3-G
View
Figure2-8 CSR05SRP101E3-G view
(2) Console port |
(3) USB 2.0 port |
(4) System reset button |
(8) MPU active/standby LED. For the LED description, see Table2-84. |
(9) Power supply status LED. For the LED description, see Table2-85. |
(10) Fan tray status LED. For the LED description, see Table2-86. |
(11) Card status LEDs. For the LED description, see Table2-87. |
(12) Management Ethernet port LED. For the LED description, see Table2-88. |
LEDs
Table2-84 MPU active/standby LED description
LED mark |
Status |
ACTIVE |
Steady green |
Off |
Table2-85 Power supply status LED description
Status |
Steady green |
Steady red |
Off |
Table2-86 Fan tray status LED description
Status |
Steady green |
Steady red |
Off |
Table2-87 Card status LED description
LED mark |
Status |
RUN/ALM |
Flashing green |
Steady red |
Flashing red |
Off |
Table2-88 Management Ethernet port LED description
Status |
LINK (Green) |
ACT (yellow) |
Steady on |
Flashing |
Steady on |
Off |
Off |
Off |
Ports
Table2-89 Management Ethernet port specifications
Item |
Connector type |
RJ-45 |
Port quantity |
1 |
10/100/1000 Mbps |
Services |
Console port
Table2-90 Console port specifications
Item |
Connector type |
RJ-45 |
Services |
USB port
Table2-91 USB port specifications
Item |
Connector type |
USB A |
USB 2.0 |
Services |
Table2-92 High-precision time synchronization port specifications
Item |
Connector type |
RJ-45 |
QB-B-016-2010 |
9600 bps |
Services |
Table2-93 SMB coaxial clock input/output port specifications
Item |
Connector type |
SMB coaxial |
GJB681 |
2.048 Mbps |
Services |
Table2-94 Technical specifications
Item |
35 × 399.2 × 353.6 mm (1.38 × 15.72 × 13.92 in) |
Weight |
4.70 kg (10.36 lb) |
160 W |
103 W |
95 W |
SDRAM |
Compatibility information
Table2-95 Compatibility matrix between MPUs and routers
Card model |
Applicable router models |
CSR05SRP1L1 |
CR16006-F, CR16010-F, CR16014-F |
CSR05SRP1L3 |
CSR05SRP1P1 |
CR16010H-F, CR16018-F |
CSR05SRP1P3 |
CSR05SRP1P3A |
CR16010H-FA, CR16018-FA |
CSR05SRP1P3-G |
CSR05SRP1R3 |
CSR05SRP1R3A |
CSR05SRP051E3-G |
CR16005E-F |
CSR05SRP101E3-G |
CR16010E-F |
CSPC LPUs
A combo interface is a logical interface that contains an SFP port and an RJ-45 Ethernet port. Only one of them can be activated at a time.
CSPC-CP1LCX
View
Figure2-9 CSPC-CP1LCX view
(1) 100GBASE-R-CFP fiber port (1 in total) |
(2) CFP port LED. For the LED description, see Table2-96. |
LEDs
Table2-96 CFP port LED description
LED |
Status |
CFP port LED |
Flashing |
The CFP port is sending or receiving data. |
Steady on |
A link is present on the CFP port. |
Off |
No link is present on the CFP port. |
Ports
Table2-97 Port specifications
Card model |
Connector type |
Port quantity |
Port transmission speed |
CSPC-CP1LCX |
1-port 100GE optical interface module |
LC |
1 |
100 Gbps |
Table2-98 Technical specifications
Item |
Weight |
3.50 kg (7.72 lb) |
173 W |
156 W |
115 W |
CSPC-CP2LB
View
Figure2-10 CSPC-CP2LB view
(1) 100GBASE-R-CFP fiber ports (2 in total) |
(2) CFP port LED. For the LED description, see Table2-99. |
LEDs
Table2-99 CFP port LED description
LED |
Status |
CFP port LED |
Flashing |
Steady on |
Off |
Ports
Table2-100 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-CP2LB |
2-port 100GE optical interface module |
LC |
2 |
100 Gbps |
Table2-101 Technical specifications
Item |
Weight |
4.06 kg (8.95 lb) |
197 W |
178 W |
150 W |
CSPC-GE16XP4L-E
View
Figure2-11 CSPC-GE16XP4L-E view
(1) 10GBASE-R-SFP+ fiber ports (4 in total) (10GE SFP+ modules supported) |
(2) Combo interfaces (16 in total) (10GE SFP+ modules supported in 1000BASE-X-SFP fiber ports) |
(3) SFP port LED. For the LED description, see Table2-103. |
(4) RJ-45 Ethernet Interface LED. For the LED description, see Table2-102. |
(5) SFP+ port LED. For the LED description, see Table2-104. |
LEDs
Table2-102 RJ-45 Ethernet port LED description
LED |
Status |
RJ-45 Ethernet port LED |
Flashing |
The port is sending or receiving data. |
Steady on |
Off |
Table2-103 SFP port LED description
LED |
Status |
SFP port LED |
Flashing |
Steady on |
Off |
Table2-104 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
NOTE: You can identify the speed of an SFP+ port by observing the color of its LED. Green indicates a speed of 10 Gbps, and yellow indicates a speed of 1000 Mbps. |
Ports
Table2-105 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-GE16XP4L-E |
16-port GE combo interface + 4-port 10GE optical interface module |
RJ-45 |
16 |
10/100/1000 Mbps |
LC |
16 |
1000 Mbps |
4 |
10 Gbps |
Table2-106 Technical specifications
Item |
Weight |
4.35 kg (9.59 lb) |
127 W |
114 W |
107 W |
CSPC-GE24L-E
View
Figure2-12 CSPC-GE24L-E view
(1) Combo interfaces (24 in total) (10GE SFP+ modules supported in 1000BASE-X-SFP fiber ports) |
(2) SFP port LED. For the LED description, see Table2-108. |
(3) RJ-45 Ethernet Interface LED. For the LED description, see Table2-107. |
LEDs
Table2-107 RJ-45 Ethernet port LED description
LED |
Status |
Flashing |
Steady on |
Off |
Table2-108 SFP port LED description
LED |
Status |
SFP port LED |
Flashing |
Steady on |
Off |
Ports
Table2-109 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-GE24L-E |
24-port GE Combo interface service module |
RJ-45 |
24 |
10/100/1000 Mbps |
LC |
24 |
1000 Mbps |
Table2-110 Technical specifications
Item |
Weight |
4.45 kg (9.81 lb) |
114 W |
110 W |
108 W |
CSPC-GP24GE8XP2L-E
View
Figure2-13 CSPC-GP24GE8XP2L-E view
(1) 10GBASE-R-SFP+ fiber ports (2 in total) (10GE SFP+ modules supported) |
(2) 1000BASE-X-SFP fiber ports (24 in total) (GE SFP modules supported) |
(3) Combo interfaces (8 in total) (10GE SFP+ modules supported in 1000BASE-X-SFP fiber ports) |
(4) RJ-45 Ethernet Interface LED. For the LED description, see Table2-111. |
(5) SFP port LED. For the LED description, see Table2-112. |
(6) SFP+ port LED. For the LED description, see Table2-113. |
LEDs
Table2-111 RJ-45 Ethernet port LED description
LED |
Status |
Flashing |
Steady on |
Off |
Table2-112 SFP port LED description
LED |
Status |
SFP port LED |
Flashing |
Steady on |
Off |
Table2-113 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-114 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-GP24GE8XP2L-E |
24-port 1000BASE-X Ethernet optical interface (SFP, LC) + 8-port 1000BASE-X Ethernet combo interface + 2-port 10GBASE-R/W Ethernet optical interface line processing unit (SFP+, LC) (E Type) |
RJ45 |
8 |
10/100/1000 Mbps |
LC |
32 |
1000 Mbps |
2 |
10 Gbps |
Table2-115 Technical specifications
Item |
Weight |
4.45 kg (9.81 lb) |
126 W |
113 W |
101 W |
CSPC-GP24LA1
View
Figure2-14 CSPC-GP24LA1 view
(1) 1000BASE-X-SFP fiber ports (16 in total) |
(2) Combo interfaces (8 in total) |
(3) SFP port LED. For the LED description, see Table2-117. |
(4) RJ-45 Ethernet port LED. For the LED description, see Table2-116. |
NOTE: · A combo interface is a logical interface that contains an SFP fiber port and an RJ-45 copper port. The two ports share one forwarding channel. As a result, they cannot work simultaneously. When you activate one port, the other port is automatically disabled. You can activate the fiber or copper port as needed. By default, the copper port is activated. · Use a category 5 or above twisted pair cable to connect a 1000BASE-T RJ-45 copper port. The maximum transmission distance is 100 m (328.08 ft). |
LEDs
Table2-116 RJ-45 Ethernet port LED description
LED |
Status |
Flashing |
Steady on |
Off |
Table2-117 SFP port LED description
LED |
Status |
SFP port LED |
Flashing |
Steady on |
Off |
Ports
Table2-118 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-GP24LA1 |
16-port 1000BASE-X Ethernet optical interface (SFP, LC) + 8-port combo interface module (A Type) |
RJ45 |
8 |
10/100/1000 Mbps |
LC |
24 |
155 Mbps |
1000 Mbps |
10/100/1000 Mbps |
Table2-119 Technical specifications
Item |
Weight |
3.01 kg (6.64 lb) |
75 W |
68 W |
47 W |
CSPC-GP24XP2LB
View
Figure2-15 CSPC-GP24XP2LB view
(3) 10GBASE-R-XFP fiber ports (2 in total) |
(4) SFP port LED. For the LED description, see Table2-121. |
(5) RJ-45 Ethernet port LED. For the LED description, see Table2-120. |
(6) XFP port LED. For the LED description, see Table2-122. |
LEDs
Table2-120 RJ-45 Ethernet port LED description
LED |
Status |
Flashing |
Steady on |
Off |
Table2-121 SFP port LED description
LED |
Status |
SFP port LED |
Flashing |
Steady on |
Off |
Table2-122 XFP port LED description
XFP port LED status |
LINK |
ACT |
Steady on |
Flashing green |
A link is present, and the XFP port is sending or receiving data. |
Steady on |
Off |
A link is present, but the XFP port is not sending or receiving data. |
Off |
Off |
No link is present on the XFP port. |
Ports
Table2-123 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-GP24XP2LB |
16-port 1000BASE-X optical interface (SFP, LC) + 8-port combo interface + 2-port 10GE optical interface module (XFP, LC) (B Type) |
RJ45 |
8 |
10/100/1000 Mbps |
LC |
24 |
155 Mbps |
1000 Mbps |
Table2-124 Technical specifications
Item |
Weight |
3.08 kg (6.79 lb) |
100 W |
90 W |
51 W |
CSPC-GP44XP4LCX
View
Figure2-16 CSPC-GP44XP4LCX view
(1) 1000BASE-X-SFP fiber ports (44 in total) |
(2) 10GBASE-R-SFP+ fiber ports (4 in total) |
(3) SFP port LED. For the LED description, see Table2-125. |
(4) SFP+ port LED. For the LED description, see Table2-126. |
LEDs
Table2-125 SFP port LED description
LED |
Status |
SFP port LED |
Flashing |
Steady on |
Off |
Table2-126 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-127 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-GP44XP4LCX |
44-port 1000BASE-X Ethernet optical interface module (SFP, LC) + 4-port 10GBASE Ethernet optical interface module (SFP+, LC) (C Type) |
LC |
44 |
100 Mbps |
155 Mbps |
1000 Mbps |
10/100/1000 Mbps |
4 |
10 Gbps |
Table2-128 Technical specifications
Item |
Weight |
3.60 kg (7.94 lb) |
142 W |
128 W |
118 W |
CSPC-GP48LB
View
Figure2-17 CSPC-GP48LB view
(1) 1000BASE-X-SFP fiber ports (48 in total) |
(2) SFP port LED. For the LED description, see Table2-129. |
LEDs
Table2-129 SFP port LED description
LED |
Status |
SFP port LED |
Flashing |
Steady on |
Off |
Ports
Table2-130 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-GP48LB |
48-port enhanced 1000BASE-X Ethernet optical interface module (SFP, LC) (B Type) |
LC |
48 |
100 Mbps |
155 Mbps |
1000 Mbps |
10/100/1000 Mbps |
2 |
10 Gbps |
Table2-131 Technical specifications
Item |
Weight |
3.25 kg (7.17 lb) |
110 W |
99 W |
43 W |
CSPC-GT48LA1
View
Figure2-18 CSPC-GT48LA1 view
(1) 10/100/1000BASE-T copper ports (48 in total) |
(2) RJ-45 Ethernet port LED. For the LED description, see Table2-132. |
LEDs
Table2-132 RJ-45 Ethernet port LED description
LED |
Status |
Flashing |
Steady on |
Off |
Ports
Table2-133 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-GT48LA1 |
48-port 10/100/1000BASE-T Ethernet interface module (RJ45) (A Type) |
RJ45 |
48 |
10/100/1000 Mbps |
Table2-134 Technical specifications
Item |
Weight |
3.31 kg (7.30 lb) |
95 W |
86 W |
67 W |
CSPC-XLP6LCX
View
Figure2-19 CSPC-XLP6LCX view
(1) 40GBASE-R-QSFP+ fiber ports (6 in total) |
(2) QSFP+ port LED. For the LED description, see Table2-135. |
LEDs
Table2-135 QSFP+ port LED description
LED |
Status |
QSFP+ port LED |
Flashing |
The QSFP+ port is sending or receiving data. |
Steady on |
A link is present on the QSFP+ port. |
Off |
No link is present on the QSFP+ port. |
Ports
Table2-136 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-XLP6LCX |
6-port 40GBASE Ethernet optical interface module (QSFP+, MPO) (C Type) |
LC/MPO |
6 |
40 Gbps |
Table2-137 Technical specifications
Item |
Weight |
3.95 kg (8.71 lb) |
290 W |
261 W |
181 W |
CSPC-XP12LAX/CSPC-XP12LCX
View
Figure2-20 CSPC-XP12LCX view
(1) 10GBASE-R-SFP+ fiber ports (12 in total) |
(2) SFP+ port LED. For the LED description, see Table2-138. |
The views of the CSPC-XP12LAX and CSPC-XP12LCX are similar. This figure uses the CSPC-XP12LCX as an example.
LEDs
Table2-138 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-139 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-XP12LAX |
12-port 10GE optical interface module |
LC |
12 |
10 Gbps |
CSPC-XP12LCX |
LC |
12 |
10 Gbps |
Table2-140 Technical specifications
Item |
Weight |
3.65 kg (8.05 lb) |
· CSPC-XP12LAX: 130 W · CSPC-XP12LCX: 173 W |
· CSPC-XP12LAX: 117 W · CSPC-XP12LCX: 156 W |
· CSPC-XP12LAX: 107 W · CSPC-XP12LCX: 122 W |
CSPC-XP24LAX/CSPC-XP24LCX
View
Figure2-21 CSPC-XP24LCX view
(1) 10GBASE-R-SFP+ fiber ports (24 in total) |
(2) SFP+ port LED. For the LED description, see Table2-141. |
The views of the CSPC-XP24LAX and CSPC-XP24LCX are similar. This figure uses the CSPC-XP24LCX as an example.
LEDs
Table2-141 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-142 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-XP24LAX |
24-port 10GBASE Ethernet optical interface module (SFP+, LC) (A Type) |
LC |
24 |
10 Gbps |
CSPC-XP24LCX |
LC |
24 |
10 Gbps |
Table2-143 Technical specifications
Item |
Weight |
4.15 kg (9.15 lb) |
· CSPC-XP24LAX: 209 W · CSPC-XP24LCX: 294 W |
· CSPC-XP24LAX: 189 W · CSPC-XP24LCX: 265 W |
· CSPC-XP24LAX: 153 W · CSPC-XP24LCX: 178 W |
CSPC-XP2LA1
View
Figure2-22 CSPC-XP2LA1 view
(1) 10GBASE-R-XFP fiber ports (2 in total) |
(2) XFP port LED. For the LED description, see Table2-144. |
LEDs
Table2-144 XFP port LED description
LINK |
ACT |
Steady on |
Flashing green |
Steady on |
Off |
Off |
Off |
Ports
Table2-145 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-XP2LA1 |
2-port 10GBASE Ethernet optical interface module (XFP, LC) (A Type) |
LC |
2 |
10 Gbps |
Table2-146 Technical specifications
Item |
Weight |
2.93 kg (6.46 lb) |
55 W |
50 W |
43 W |
CSPC-XP4LB
View
Figure2-23 CSPC-XP4LB view
(2) XFP port LED. For the LED description, see Table2-147. |
LEDs
Table2-147 XFP port LED description
LINK |
ACT |
Steady on |
Flashing green |
Steady on |
Off |
Off |
Off |
Ports
Table2-148 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-XP4LB |
4-port Enhanced 10GBASE Ethernet optical interface module (XFP, LC) (B Type) |
LC |
4 |
10 Gbps |
Table2-149 Technical specifications
Item |
Weight |
2.93 kg (6.46 lb) |
80 W |
72 W |
53 W |
CSPC-XP8LB
View
Figure2-24 CSPC-XP8LB view
(1) 10GBASE-R-SFP+ fiber ports (8 in total) |
(2) SFP+ port LED. For the LED description, see Table2-150. |
LED
Table2-150 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-151 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-XP8LB |
8-port Enhanced 10GBASE Ethernet optical interface module (SFP+, LC) (B Type) |
LC |
8 |
10 Gbps |
Table2-152 Technical specifications
Item |
Weight |
3.44 kg (7.58 lb) |
170 W |
153 W |
117 W |
Table2-153 Compatibility matrix between CSPC cards and routers
Card model |
CR16010H-F (with five fabric modules), CR16018-F (with five fabric modules), CR16018-FA |
CR16010H-F (with four fabric modules), CR16018-F (with four fabric modules) |
CR16005E-F, CR16010E-F |
CSPC-GT48LA1 |
Supported |
Not supported |
Not supported |
Not supported |
CSPC-GE24L-E |
Supported |
Not supported |
Not supported |
Not supported |
CSPC-GP24LA1 |
Supported |
Not supported |
Not supported |
Not supported |
CSPC-GP24XP2LB |
Supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
CSPC-GE16XP4L-E |
Supported |
Not supported |
Not supported |
Not supported |
CSPC-XP2LA1 |
Supported |
Not supported |
Not supported |
Not supported |
CSPC-XP4LB |
Supported |
Not supported |
Not supported |
Not supported |
CSPC-XP8LB |
Supported |
Not supported |
Not supported |
Not supported |
CSPC-GP48LB |
Supported |
Not supported |
Not supported |
Not supported |
CSPC-GP44XP4LCX |
Supported |
Not supported |
Not supported |
Not supported |
CSPC-XP24LCX |
Supported |
Not supported |
Not supported |
Not supported |
CSPC-XP24LAX |
Supported |
Not supported |
Not supported |
Not supported |
CSPC-XP12LCX |
Supported |
Not supported |
Not supported |
Not supported |
CSPC-XP12LAX |
Supported |
Not supported |
Not supported |
Not supported |
CSPC-XLP6LCX |
Supported |
Not supported |
Not supported |
Not supported |
CSPC-CP1LCX |
Supported |
Not supported |
Not supported |
Not supported |
CSPC-CP2LB |
Supported |
Not supported |
Not supported |
Not supported |
CEPC LPUs (interface modules)
CEPC-CP4RX/CEPC-CP4RXA
View
Figure2-25 CEPC-CP4RX view
(1) 100GBASE-R-CFP2 fiber ports (4 in total) |
(2) CFP2 port LED. For the LED description, see Table2-154. |
The views of CEPC-CP4RX and CEPC-CP4RXA are similar. This figure uses the CEPC-CP4RX as an example.
LEDs
Table2-154 CFP2 port LED description
LED |
Status |
CFP2 port LED |
Flashing |
The CFP2 port is sending or receiving data at 100 Gbps. |
Steady on |
A 100 Gbps link is present on the CFP2 port. |
Off |
No link is present on the CFP2 port. |
Ports
Table2-155 Port specifications
Card model |
Connector type |
Port quantity |
CEPC-CP4RX |
4-port 100GBASE Ethernet optical interface module (CFP2) |
LC |
4 |
100 Gbps |
CEPC-CP4RXA |
4-port 100GBASE Ethernet optical interface module A (CFP2) |
LC |
4 |
100 Gbps |
Table2-156 Technical specifications
Item |
Weight |
4.20 kg (9.26 lb) |
368 W |
331 W |
228.5 W |
CEPC-CP4RX-L
View
Figure2-26 CEPC-CP4RX-L view
(1) 100GBASE-QSFP28 fiber ports (4 in total) (100G QSFP 28 modules supported) |
(2) QSFP 28 port LED. For the LED description, see Table2-157. |
LEDs
Table2-157 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
The QSFP28 port is sending or receiving data at 100 Gbps. |
Steady on |
A 100 Gbps link is present on the QSFP28 port. |
Off |
No link is present on the QSFP28 port. |
Ports
Table2-158 Port specifications
Card model |
Connector type |
Port quantity |
CEPC-CP4RX-L |
4-port 100G Ethernet optical interface line processing unit (QSFP28, LC) |
LC |
4 |
100 Gbps |
40 Gbps |
Table2-159 Technical specifications
Item |
Weight |
8.30 kg (18.30 lb) |
354 W |
252 W |
191 W |
CEPC-CQ16L1
View
Figure2-27 CEPC-CQ16L1 view
(1) 100GBASE-QSFP28 fiber ports (8 in total) (100G QSFP 28 modules supported) |
(2) QSFP 28 port LED. For the LED description, see Table2-160. |
LEDs
Table2-160 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-161 Port specifications
Card model |
Connector type |
Port quantity |
CEPC-CQ16L1 |
16-port 100G Ethernet optical interface line processing unit (QSFP28,LC) |
LC |
16 |
100 Gbps |
Table2-162 Technical specifications
Item |
52.5 × 399 × 370 mm (2.07 × 15.71 × 14.57 in) |
Weight |
8.25 kg (18.19 lb) |
1240 W |
970 W |
760 W |
View
Figure2-28 CEPC-CQ8L view
(2) QSFP 28 port LED. For the LED description, see Table2-163. |
The views of CEPC-CQ8L, CEPC-CQ8LA, CEPC-CQ8L1A, and CEPC-CQ8L3A are similar. This figure uses the CEPC-CQ8L as an example.
LEDs
Table2-163 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-164 Port specifications
Card model |
Connector type |
Port quantity |
CEPC-CQ8L |
8-port 100G Ethernet optical interface line processing unit (QSFP28, LC) |
LC |
8 |
100 Gbps |
CEPC-CQ8LA |
8-port 100G Ethernet optical interface line processing unit A (QSFP28,LC) |
LC |
8 |
100 Gbps |
CEPC-CQ8L1A |
LC |
8 |
100 Gbps |
CEPC-CQ8L3A |
LC |
8 |
100 Gbps |
Table2-165 Technical specifications
Item |
Weight |
8.00 kg (17.64 lb) |
· CEPC-CQ8L: 1100 W · CEPC-CQ8LA, CEPC-CQ8L1A, CEPC-CQ8L3A: 810 W |
· CEPC-CQ8L: 880 W · CEPC-CQ8LA, CEPC-CQ8L1A, CEPC-CQ8L3A: 705 W |
· CEPC-CQ8L: 653 W · CEPC-CQ8LA, CEPC-CQ8L1A, CEPC-CQ8L3A: 610 W |
CEPC-DQ2L1-G
View
Figure2-29 CEPC-DQ2L1-G view
(1) QSFP-DD port LED. For the LED description, see Table2-166. |
(2) 400GBASE-R-QSFP-DD fiber ports (2 in total) (400G QSFP-DD modules supported) |
(3) Card status LED. For the LED description, see Table2-167. |
LEDs
Table2-166 QSFP-DD port LED description
LED |
Status |
QSFP-DD port LED |
Flashing |
The QSFP-DD port is sending or receiving data. |
On |
A link is present on the QSFP-DD port. |
Off |
No link is present on the QSFP-DD port. |
Table2-167 Card status LED description
LED |
Status |
RUN (Green) |
Steady on |
The card is faulty. |
Off |
The card is faulty or is not in position. |
Flashing (about once per second) |
The card is operating correctly. |
Fast flashing (about eight times per second) |
The card is starting up. If the LED keeps fast flashing, card registration has failed. |
Ports
Table2-168 Port specifications
Card model |
Connector type |
Port quantity |
CEPC-DQ2L1-G |
2-port 400G Ethernet optical interface line processing unit (QSFP-DD,LC) |
LC |
2 |
400 Gbps |
Table2-169 Technical specifications
Item |
Weight |
6.96 kg (15.34 lb) |
458 W |
416 W |
331 W |
CEPC-XP24LX
View
Figure2-30 CEPC-XP24LX view
(1) 10GBASE-R/W-SFP+ fiber ports (24 in total) (10GE SFP+ modules supported) |
(2) SFP+ port LED. For the LED description, see Table2-170. |
LEDs
Table2-170 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
The SFP+ port is sending or receiving data. |
Steady on |
A link is present on the SFP+ port. |
Off |
No link is present on the SFP+ port. |
Ports
Table2-171 Port specifications
Card model |
Connector type |
Port quantity |
CEPC-XP24LX |
24-port 10GBASE-R/W Ethernet optical interface line processing unit (SFP+, LC) |
LC |
24 |
10 Gbps |
Table2-172 Technical specifications
Item |
Weight |
321 W |
289 W |
237.6 W |
CEPC-XP48RX
View
Figure2-31 CEPC-XP48RX view
(1) 10GBASE-R-SFP+ fiber ports (48 in total) |
(2) SFP+ port LED. For the LED description, see Table2-173. |
LEDs
Table2-173 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-174 Port specifications
Card model |
Connector type |
Port quantity |
CEPC-XP48RX |
48-port 10GBASE-R/W Ethernet optical interface module (SFP+, LC) |
LC |
48 |
10 Gbps |
Table2-175 Technical specifications
Item |
Weight |
4.75 kg (10.47 lb) |
407 W |
336 W |
234.8 W |
CEPC-XP4LX
View
Figure2-32 CEPC-XP4LX view
(1) 10GBASE-R/W-SFP+ fiber ports (4 in total) (10GE SFP+ modules supported) |
(2) SFP+ port LED. For the LED description, see Table2-176. |
LEDs
Table2-176 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-177 Port specifications
Card model |
Connector type |
Port quantity |
CEPC-XP4LX |
4-port 10GBASE-R/W Ethernet optical interface line processing unit module (SFP+, LC) |
LC |
4 |
10 Gbps |
Table2-178 Technical specifications
Item |
Weight |
184 W |
117 W |
102 W |
For adequate ventilation and cooling, you can install the CEPC-CP4RX, CEPC-XP48RX, and CEPC-XP24LX cards in the following slots only when the other slots are not available.
· CR16010-F router—Slots 0, 8 and 9.
· CR16014-F router—Slots 0 and 13.
Table2-179 Compatibility matrix between CEPC cards and routers (1)
Card model |
CR16006-F |
CR16010H-F (with five fabric modules), CR16018-F (with five fabric modules) |
CEPC-XP48RX |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
CEPC-CP4RX |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
CEPC-CP4RXA |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
CEPC-CP4RX-L |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
CEPC-XP24LX |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
CEPC-XP4LX |
Supported |
Supported |
Supported |
Not supported |
Not supported |
CEPC-CQ8L |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
CEPC-CQ8LA |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
CEPC-CQ8L1A |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
CEPC-CQ8L3A |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
CEPC-CQ16L1 |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
CEPC-DQ2L1-G |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
Table2-180 Compatibility matrix between CEPC cards and routers (2)
Card model |
CR16005E-F |
CR16010E-F |
CEPC-XP48RX |
Not supported |
Not supported |
CEPC-CP4RX |
Not supported |
Not supported |
CEPC-CP4RXA |
Not supported |
Not supported |
CEPC-CP4RX-L |
Not supported |
Not supported |
CEPC-XP24LX |
Not supported |
Not supported |
CEPC-XP4LX |
Not supported |
Not supported |
CEPC-CQ8L |
Not supported |
Not supported |
CEPC-CQ8LA |
Not supported |
Supported |
CEPC-CQ8L1A |
Not supported |
Not supported |
CEPC-CQ8L3A |
Not supported |
Not supported |
CEPC-CQ16L1 |
Not supported |
Supported |
CEPC-DQ2L1-G |
Not supported |
Supported |
CSPEX base cards
IMPORTANT: A CSPEX-1104-E card supports a maximum of three MIC-XP4L1 and MIC-GP4L subcards in total. |
View
Figure2-33 CSPEX-1204 view
(1) Card status LED. For the LED description, see Table2-181. |
The views of CSPEX-1204, CSPEX-1304X, CSPEX-1404X, CSPEX-1504X, CSPEX-1504XA, and CSPEX-1104-E are similar. This figure uses the CSPEX-1204 as an example.
LEDs
LED |
Status |
RUN (Green) |
Steady on |
Off |
Subcard slots
Table2-182 Subcard slots
Card model |
Number of subcard slots |
CSPEX-1104-E |
4 |
CSPEX-1204 |
4 |
CSPEX-1304X |
4 |
CSPEX-1404X |
4 |
CSPEX-1504X |
4 |
CSPEX-1504XA |
4 |
Table2-183 Technical specifications
Item |
Weight |
· CSPEX-1104-E: 3.45 kg (7.61 lb) · CSPEX-1204: 3.50 kg (7.72 lb) · CSPEX-1304X: 3.75 kg (8.27 lb) · CSPEX-1404X: 7.20 kg (15.87 lb) · CSPEX-1504X: 7.20 kg (15.87 lb) · CSPEX-1504XA: 3.80 kg (8.38 lb) |
· CSPEX-1104-E: 164 W · CSPEX-1204: 190 W · CSPEX-1304X: 184 W · CSPEX-1404X: 230 W · CSPEX-1504X, CSPEX-1504XA: 261 W |
· CSPEX-1104-E: 88 W · CSPEX-1204: 104 W · CSPEX-1304X: 101 W · CSPEX-1404X: 138 W · CSPEX-1504X, CSPEX-1504XA: 154 W |
· CSPEX-1104-E: 79 W · CSPEX-1204: 88 W · CSPEX-1304X: 90 W · CSPEX-1404X: 111.6 W · CSPEX-1504X, CSPEX-1504XA: 112.1 W |
View
Figure2-34 CSPEX-1602X view
(1) Card status LED. For the LED description, see Table2-184. |
The views of the CSPEX-1602X, CSPEX-1602XA, CSPEX-1502X, and CSPEX-1502XA are similar. This figure uses the CSPEX-1602X as an example.
LEDs
LED |
Status |
RUN (Green) |
Steady on |
Off |
Subcard slots
Table2-185 Subcard slots
Card model |
CSPEX-1502X |
2 |
CSPEX-1502XA |
2 |
CSPEX-1602X |
2 |
CSPEX-1602XA |
2 |
Table2-186 Technical specifications
Item |
· CSPEX-1502X, CSPEX-1602X, CSPEX-1602XA: 40 × 399 × 352 mm (1.57 × 15.71 × 13.86 in) · CSPEX-1502XA: 52.5 × 399 × 361 mm (2.07 × 15.71 × 14.21 in) |
Weight |
· CSPEX-1502X: 3.95 kg (8.71 lb) · CSPEX-1502XA: 5.00 kg (11.02 lb) · CSPEX-1602X, CSPEX-1602XA: 7.50 kg (16.53 lb) |
· CSPEX-1502X, CSPEX-1502XA: 270 W · CSPEX-1602X, CSPEX-1602XA: 354 W |
· CSPEX-1502X, CSPEX-1502XA: 135 W · CSPEX-1602X, CSPEX-1602XA: 222 W |
· CSPEX-1502X, CSPEX-1502XA: 120 W · CSPEX-1602X, CSPEX-1602XA: 174.6 W |
View
Figure2-35 CSPEX-1512X view
(1) Card status LED. For the LED description, see Table2-187. |
The views of the CSPEX-1512X, CSPEX-1612X, CSPEX-1812X, CSPEX-1812X-E, CSPEX-1802X, CSPEX-1802XA, and CSPEX-2612XA are similar. This figure uses the CSPEX-1512X as an example.
LEDs
LED |
Status |
RUN (Green) |
Steady on |
Off |
Subcard slots
Table2-188 Subcard slots
Card model |
CSPEX-1512X |
2 |
CSPEX-1612X |
2 |
CSPEX-1812X |
2 |
CSPEX-1812X-E |
2 |
CSPEX-1802X |
2 |
CSPEX-1802XA |
2 |
CSPEX-2612XA |
2 |
Table2-189 Technical specifications
Item |
52.5 × 399 × 352 mm (2.07 × 15.71 × 13.86 in) |
Weight |
· CSPEX-1512X: 5.40 kg (11.90 lb) · CSPEX-1612X: 8.75 kg (19.29 lb) · CSPEX-1812X: 5.95 kg (13.12 lb) · CSPEX-1812X-E, CSPEX-1802X, CSPEX-1802XA, CSPEX-2612XA: 9.00 kg (19.84 lb) |
· CSPEX-1512X: 281 W · CSPEX-1612X: 320 W · CSPEX-1812X: 657 W · CSPEX-1812X-E, CSPEX-1802X, CSPEX-1802XA: 486 W · CSPEX-2612XA: 538 W |
· CSPEX-1512X: 202 W · CSPEX-1612X: 238 W · CSPEX-1812X: 426 W · CSPEX-1812X-E, CSPEX-1802X, CSPEX-1802XA: 333 W · CSPEX-2612XA: 457 W |
· CSPEX-1512X: 185 W · CSPEX-1612X: 200 W · CSPEX-1812X: 413 W · CSPEX-1812X-E. CSPEX-1802X, CSPEX-1802XA: 275 W · CSPEX-2612XA: 330 W |
CSPEX-1804X
View
Figure2-36 CSPEX-1804X view
(1) Card status LED. For the LED description, see Table2-190. |
LEDs
LED |
Status |
RUN (Green) |
Steady on |
Off |
Subcard slots
Table2-191 Subcard slots
Card model |
CSPEX-1804X |
4 |
Table2-192 Technical specifications
Item |
Weight |
6.30 kg (13.89 lb) |
625 W |
510 W |
460 W |
CSPEX-2304X-G
View
Figure2-37 CSPEX-2304X-G view
(1) Card status LED. For the LED description, see Table2-193. |
LEDs
LED |
Status |
RUN (Green) |
Steady on |
Off |
Subcard slots
Table2-194 Subcard slots
Card model |
CSPEX-2304X-G |
4 |
Table2-195 Technical specifications
Item |
Weight |
4.65 kg (10.25 lb) |
280 W |
242 W |
200 W |
CSPEX-2304X-LG
View
Figure2-38 CSPEX-2304X-LG view
(1) Card status LED. For the LED description, see Table2-196. |
LEDs
LED |
Status |
RUN (Green) |
Steady on |
Off |
Subcard slots
Table2-197 Subcard slots
Card model |
CSPEX-2304X-LG |
4 |
Table2-198 Technical specifications
Item |
Weight |
280 W |
242 W |
200 W |
CSPEX-2612X3A
View
Figure2-39 CSPEX-2612X3A view
(1) Card status LED. For the LED description, see Table2-199. |
LEDs
LED |
Status |
RUN (Green) |
Steady on |
Off |
Subcard slots
Table2-200 Subcard slots
Card model |
CSPEX-2612X3A |
2 |
Table2-201 Technical specifications
Item |
Weight |
538 W |
457 W |
330 W |
· A CR16006-F router installed with Type-A switching fabric modules does not support the CSPEX-1304X, CSPEX-1404X, or CSPEX-1504X cards.
· For adequate ventilation and cooling, install the CSPEX-1602X card in the following slots only when the other slots are not available.
¡ CR16010-F router—Slots 0, 8 and 9.
¡ CR16014-F router—Slots 0 and 13.
Table2-202 Compatibility matrix between CSPEX cards and routers (1)
Card model |
CR16006-F |
CR16010-F |
CR16014-F |
CSPEX-1204 |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
CSPEX-1104-E |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
CSPEX-1304X |
Supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
CSPEX-1404X |
Supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
CSPEX-1504X |
Supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
CSPEX-1504XA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
CSPEX-1502X |
Not supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
CSPEX-1502XA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
CSPEX-1602X |
Not supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
CSPEX-1602XA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
CSPEX-1802X |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
CSPEX-1804X |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
CSPEX-1512X |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
CSPEX-1612X |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
CSPEX-1812X |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
CSPEX-1812X-E |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
CSPEX-1802XA |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
Supported |
CSPEX-2304X-G |
Supported |
Supported |
Not supported |
Supported |
Not supported |
Not supported |
CSPEX-2304X-LG |
Supported |
Supported |
Not supported |
Supported |
Not supported |
Not supported |
CSPEX-2612XA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
CSPEX-2612X3A |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Table2-203 Compatibility matrix between CSPEX cards and routers (2)
Card model |
CR16005E-F |
CR16010E-F |
CSPEX-1204 |
Not supported |
Not supported |
CSPEX-1104-E |
Not supported |
Not supported |
CSPEX-1304X |
Supported |
Supported |
CSPEX-1404X |
Supported |
Supported |
CSPEX-1504X |
Supported |
Supported |
CSPEX-1504XA |
Not supported |
Not supported |
CSPEX-1502X |
Not supported |
Not supported |
CSPEX-1502XA |
Not supported |
Not supported |
CSPEX-1602X |
Not supported |
Not supported |
CSPEX-1602XA |
Not supported |
Not supported |
CSPEX-1802X |
Not supported |
Supported |
CSPEX-1804X |
Not supported |
Not supported |
CSPEX-1512X |
Not supported |
Not supported |
CSPEX-1612X |
Not supported |
Not supported |
CSPEX-1812X |
Not supported |
Not supported |
CSPEX-1812X-E |
Not supported |
Supported |
CSPEX-1802XA |
Not supported |
Supported |
CSPEX-2304X-G |
Supported |
Supported |
CSPEX-2304X-LG |
Supported |
Supported |
CSPEX-2612XA |
Not supported |
Not supported |
CSPEX-2612X3A |
Not supported |
Not supported |
Table2-204 Compatibility matrix between CSPEX cards and subcards (1)
Subcard model |
CSPEX cards |
CSPEX-1204 |
CSPEX-1304X |
CSPEX-1504X CSPEX-1404X |
CSPEX-1504XA |
CSPEX-1502X |
CSPEX-1502XA |
CSPEX-1602X |
CSPEX-1602XA |
CSPEX-1804X |
PIC-GP10L |
Slots 1 and 2: Supported Slots 3 and 4: Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-TCP8L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-PSP4L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-PS2G4L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-PUP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-XP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GT20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GT20L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GT20LA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-ET16L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CLP2L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CLP4L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-SP4L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-SP8L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP4L |
Slots 1 and 2: Not supported Slots 3 and 4: Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP8L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP10L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP10L2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP10L-V2 |
Not supported |
Slots 1, 2, and 3: Supported Slot 4: Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP10LA |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP20L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
Supported |
Not supported |
Not supported |
MIC-XP2L |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP2L-LAN |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP4L1 |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP5L |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP5L1 |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP5L2 |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP8L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP10LF |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP10L-LAN |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
Supported |
Not supported |
Not supported |
MIC-XP20LA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
MIC-QP1L |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CP1L-V2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-CP2L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
Supported |
Not supported |
Not supported |
MIC-CP2L-V2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-CQ1L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CQ1L2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CQ1LF |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CQ2L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
Supported |
Not supported |
Not supported |
MIC-PSP4L |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-TCP8L |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-SEC |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-GT20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-GP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-GP24L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-GP24L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-GP24L1A |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
NIC-XP5L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-XP10L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-XP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-XP20L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-XP20L1A |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-CC1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-CC2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-CQ1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-CQ2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-CQ2LA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-GP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-XP5L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-XP10L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-XP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-YGS4L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-LGQ2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
RX-NIC-LGQ4L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-CQ1LF |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
RX-NIC-CQ2LF |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-CC1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
RX-NIC-CC2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Table2-205 Compatibility matrix between CSPEX cards and subcards (2)
Subcard model |
CSPEX cards |
CSPEX-1104-E |
CSPEX-1512X |
CSPEX-1612X |
CSPEX-1812X |
CSPEX-1812X-E |
CSPEX-1802X |
CSPEX-1802XA CSPEX-2612XA CSPEX-2612X3A |
CSPEX-2304X-G CSPEX-2304X-LG |
PIC-GP10L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-XP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-TCP8L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-PS2G4L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-PSP4L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-PUP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP4L |
Supported A maximum of three cards are supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-GP8L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP10L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP10L2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-SP4L |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-CLP2L |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-CLP4L |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-SP8L |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-ET16L |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-GP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP20L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GT20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GT20L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-GT20LA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP10L-V2 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP10LA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP2L |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-XP2L-LAN |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-XP4L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-XP5L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-XP5L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-XP5L2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-XP8L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP10LF |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-XP10L-LAN |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-XP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP20LA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CP2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-QP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-CP1L-V2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CP2L-V2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CQ1L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CQ1L2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-CQ1LF |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-CQ2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-PSP4L |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-TCP8L |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-SEC |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
NIC-GT20L |
Not supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-GP20L |
Not supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-GP24L |
Not supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-GP24L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Supported |
Not supported |
NIC-GP24L1A |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
NIC-XP5L |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
NIC-XP10L |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
NIC-XP20L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
NIC-XP20L1 |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
Supported |
Not supported |
Not supported |
NIC-XP20L1A |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
NIC-CC1L |
Not supported |
Not supported |
Supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
NIC-CC2L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
NIC-CQ1L |
Not supported |
Not supported |
Supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
NIC-CQ2L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
NIC-CQ2LA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
RX-NIC-GP20L |
Not supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-XP5L |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
RX-NIC-XP10L |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
RX-NIC-XP20L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
RX-NIC-YGS4L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
RX-NIC-LGQ2L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
RX-NIC-LGQ4L |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
Supported |
Not supported |
Not supported |
RX-NIC-CQ1LF |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
RX-NIC-CQ2LF |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
Supported |
Not supported |
Not supported |
RX-NIC-CC1L |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
RX-NIC-CC2L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
CMPE base cards
CMPE-1104
View
Figure2-40 CMPE-1104 view
(1) Card status LED. For the LED description, see Table2-206. |
LEDs
LED |
Status |
RUN (Green) |
Steady on |
Off |
Subcard slots
Table2-207 Subcard slots
Card model |
CMPE-1104 |
4 |
Table2-208 Technical specifications
Item |
Dimensions (H × W × D) |
40 × 399 × 352 mm (1.57 × 15.71 × 13.86 in) |
Weight |
3.52 kg (7.76 lb) |
Maximum power consumption |
158 W |
Power consumption (with typical configuration) |
94 W |
Minimum power consumption |
91 W |
Operating temperature |
0°C to 45°C (32°F to 113°F) |
The subslot restrictions of a CMPE card depend on the subslot mode. For more information about subslot modes, see device management configuration in H3C CR16000-F Routers Fundamentals Configuration Guide.
Table2-209 Compatibility matrix between CMPE cards and routers
Card model |
CMPE-1104 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Table2-210 Compatibility matrix between CMPE cards and subcards
Subcard model |
CMPE cards |
PIC-GP10L |
Not supported |
PIC-TCP8L |
Not supported |
PIC-PSP4L |
Not supported |
PIC-PS2G4L |
Not supported |
PIC-PUP1L |
Not supported |
PIC-XP1L |
Not supported |
MIC-GT20L |
Not supported |
MIC-GT20L1 |
Not supported |
MIC-GT20LA |
Not supported |
MIC-CLP4L |
Supported |
MIC-ET16L |
Supported |
MIC-CLP2L |
Supported |
MIC-SP8L |
Only one is supported. Can be installed only slot 1 or slot 2. |
MIC-SP4L |
Supported |
MIC-GP4L |
Supported |
MIC-GP8L |
Not supported in slot 3 or slot 4 |
MIC-GP10L1 |
Not supported |
MIC-GP10L2 |
Not supported |
MIC-GP10L-V2 |
Not supported |
MIC-GP10LA |
Not supported |
MIC-GP20L |
Not supported |
MIC-GP20L1 |
Not supported |
MIC-XP2L |
Not supported |
MIC-XP2L-LAN |
Not supported |
MIC-XP4L1 |
Not supported |
MIC-XP5L |
Not supported |
MIC-XP5L1 |
Not supported |
MIC-XP5L2 |
Not supported |
MIC-XP8L |
Not supported |
MIC-XP10LF |
Not supported |
MIC-XP10L-LAN |
Not supported |
MIC-XP20L |
Not supported |
MIC-XP20LA |
Not supported |
MIC-QP1L |
Not supported |
MIC-CP1L |
Not supported |
MIC-CP1L-V2 |
Not supported |
MIC-CP2L |
Not supported |
MIC-CP2L-V2 |
Not supported |
MIC-CQ1L1 |
Not supported |
MIC-CQ1L2 |
Not supported |
MIC-CQ1LF |
Not supported |
MIC-CQ2L |
Not supported |
MIC-CQ2LA |
Not supported |
MIC-PSP4L |
Not supported |
MIC-TCP8L |
Not supported |
MIC-SEC |
Not supported |
NIC-GT20L |
Not supported |
NIC-GP20L |
Not supported |
NIC-GP24L |
Not supported |
NIC-GP24L1 |
Not supported |
NIC-GP24L1A |
Not supported |
NIC-XP5L |
Not supported |
NIC-XP10L |
Not supported |
NIC-XP20L |
Not supported |
NIC-XP20L1 |
Not supported |
NIC-XP20L1A |
Not supported |
NIC-CC1L |
Not supported |
NIC-CC2L |
Not supported |
NIC-CQ1L |
Not supported |
NIC-CQ2L |
Not supported |
RX-NIC-GP20L |
Not supported |
RX-NIC-XP5L |
Not supported |
RX-NIC-XP10L |
Not supported |
RX-NIC-XP20L |
Not supported |
RX-NIC-YGS4L |
Not supported |
RX-NIC-LGQ2L |
Not supported |
RX-NIC-LGQ4L |
Not supported |
RX-NIC-CQ1LF |
Not supported |
RX-NIC-CQ2LF |
Not supported |
RX-NIC-CC1L |
Not supported |
RX-NIC-CC2L |
Not supported |
SPE base cards
RX-SPE200/RX-SPE200-E
View
Figure2-41 RX-SPE200 view
(1) Card status LED. For the LED description, see Table2-211. |
The views of the RX-SPE200 and RX-SPE200-E are similar. This figure uses the RX-SPE200 as an example.
LEDs
LED |
Status |
RUN (Green) |
Steady on |
Off |
Subcard slots
Table2-212 Subcard slots
Card model |
RX-SPE200 |
2 |
RX-SPE200-E |
2 |
Table2-213 Technical specifications
Item |
Weight |
· RX-SPE200: 5.35 kg (11.79 lb) · RX-SPE200-E: 5.00 kg (11.02 lb) |
· RX-SPE200: 530 W · RX-SPE200-E: 270 W |
· RX-SPE200: 300 W · RX-SPE200-E: 135 W |
· RX-SPE200: 280 W · RX-SPE200-E: 120 W |
Table2-214 Compatibility matrix between SPE cards and routers
Card model |
RX-SPE200 |
Not supported |
Supported |
Not supported |
Not supported |
Supported |
RX-SPE200-E |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Table2-215 Compatibility matrix between SPE cards and subcards
Subcard model |
RX-SPE200 |
RX-SPE200-E |
PIC-GP10L |
Not supported |
Not supported |
PIC-TCP8L |
Not supported |
Not supported |
PIC-PSP4L |
Not supported |
Not supported |
PIC-PS2G4L |
Not supported |
Not supported |
PIC-PUP1L |
Not supported |
Not supported |
PIC-XP1L |
Not supported |
Not supported |
MIC-GT20L |
Not supported |
Not supported |
MIC-GT20L1 |
Not supported |
Not supported |
MIC-GT20LA |
Not supported |
Not supported |
MIC-CLP4L |
Not supported |
Not supported |
MIC-ET16L |
Not supported |
Not supported |
MIC-CLP2L |
Not supported |
Not supported |
MIC-SP8L |
Not supported |
Not supported |
MIC-SP4L |
Not supported |
Not supported |
MIC-GP4L |
Not supported |
Not supported |
MIC-GP8L |
Not supported |
Not supported |
MIC-GP10L1 |
Not supported |
Not supported |
MIC-GP10L2 |
Not supported |
Not supported |
MIC-GP10L-V2 |
Not supported |
Not supported |
MIC-GP10LA |
Not supported |
Not supported |
MIC-GP20L |
Not supported |
Not supported |
MIC-GP20L1 |
Not supported |
Not supported |
MIC-XP2L |
Not supported |
Not supported |
MIC-XP2L-LAN |
Not supported |
Not supported |
MIC-XP4L1 |
Not supported |
Not supported |
MIC-XP5L |
Not supported |
Not supported |
MIC-XP5L1 |
Not supported |
Not supported |
MIC-XP5L2 |
Not supported |
Not supported |
MIC-XP8L |
Not supported |
Not supported |
MIC-XP10LF |
Not supported |
Not supported |
MIC-XP10L-LAN |
Not supported |
Not supported |
MIC-XP20L |
Not supported |
Not supported |
MIC-XP20LA |
Not supported |
Not supported |
MIC-QP1L |
Not supported |
Not supported |
MIC-CP1L |
Not supported |
Not supported |
MIC-CP1L-V2 |
Not supported |
Not supported |
MIC-CP2L |
Not supported |
Not supported |
MIC-CP2L-V2 |
Not supported |
Not supported |
MIC-CQ1L1 |
Not supported |
Not supported |
MIC-CQ1L2 |
Not supported |
Not supported |
MIC-CQ1LF |
Not supported |
Not supported |
MIC-CQ2L |
Not supported |
Not supported |
MIC-PSP4L |
Not supported |
Not supported |
MIC-TCP8L |
Not supported |
Not supported |
MIC-SEC |
Not supported |
Not supported |
NIC-GT20L |
Supported |
Not supported |
NIC-GP20L |
Supported |
Not supported |
NIC-GP24L |
Not supported |
Not supported |
NIC-GP24L1 |
Not supported |
Supported |
NIC-GP24L1A |
Not supported |
Not supported |
NIC-XP5L |
Not supported |
Not supported |
NIC-XP10L |
Supported |
Not supported |
NIC-XP20L |
Not supported |
Not supported |
NIC-XP20L1 |
Not supported |
Not supported |
NIC-XP20L1A |
Not supported |
Not supported |
NIC-CC1L |
Not supported |
Not supported |
NIC-CC2L |
Not supported |
Not supported |
NIC-CQ1L |
Supported |
Not supported |
NIC-CQ2L |
Not supported |
Not supported |
NIC-CQ2LA |
Not supported |
Not supported |
RX-NIC-GP20L |
Supported |
Not supported |
RX-NIC-XP5L |
Supported |
Supported |
RX-NIC-XP10L |
Supported |
Supported |
RX-NIC-XP20L |
Not supported |
Not supported |
RX-NIC-YGS4L |
Supported |
Supported |
RX-NIC-LGQ2L |
Supported |
Supported |
RX-NIC-LGQ4L |
Not supported |
Not supported |
RX-NIC-CQ1LF |
Supported |
Supported |
RX-NIC-CQ2LF |
Not supported |
Not supported |
RX-NIC-CC1L |
Supported |
Supported |
RX-NIC-CC2L |
Not supported |
Not supported |
MIC subcards
IMPORTANT: · To use a MIC interface card, you must install it on a CMPE, SPE, or CSPEX base card. You cannot install it directly on the router. · For the compatibility between MIC interface cards and CMPE, SPE, or CSPEX base cards, see the compatibility information for the base cards. · A combo interface is a logical interface that contains an SFP port and an RJ-45 Ethernet port. Only one of them can be activated at a time. |
MIC-CLP2L
View
Figure2-42 MIC-CLP2L view
(1) CPOS-OC3/STM1-SFP ports (2 in total) |
(2) Port LED. For the LED description, see Table2-216. |
LEDs
Table2-216 WAN port LED description
LED |
Status |
WAN port LED (ACT/ALM) |
Flashing green |
The port is up and is receiving or sending data correctly. |
Steady green |
The port is up and no services are running on the port. |
Steady red |
An alarm has occurred. |
Off |
The port is down. |
Ports
Table2-217 Port specifications
Card model |
Connector type |
Port quantity |
Port transmission speed |
MIC-CLP2L |
2-port OC-3/STM-1 CPOS optical interface card |
LC |
2 |
155 Mbps (OC-3/STM-1 ) |
Table2-218 Technical specifications
Item |
18 × 171 × 157 mm (0.71 × 6.73 × 6.18 in) |
Weight |
0.32 kg (0.71 lb) |
10.9 W |
9.8 W |
MIC-CLP4L
View
Figure2-43 MIC-CLP4L view
(1) CPOS-OC3/STM1-SFP ports (4 in total) |
(2) Port LED. For the LED description, see Table2-219. |
LEDs
Table2-219 WAN port LED description
LED |
Status |
Flashing green |
Steady green |
Steady red |
Off |
The port is down. |
Ports
Table2-220 Port specifications
Card model |
Connector type |
Port quantity |
MIC-CLP4L |
4-port OC-3/STM-1 CPOS optical interface card |
LC |
4 |
155 Mbps (OC-3/STM-1) |
Table2-221 Technical specifications
Item |
Weight |
0.30 kg (0.66 lb) |
12.9 W |
9.8 W |
MIC-CP1L
View
Figure2-44 MIC-CP1L view
(1) 100GBASE-R-CFP fiber port (1 in total) |
(2) CFP port LED. For the LED description, see Table2-222 |
LEDs
Table2-222 CFP port LED description
LED |
Status |
CFP port LED |
Flashing |
The CFP port is sending or receiving data. |
Steady on |
A link is present on the CFP port. |
Off |
No link is present on the CFP port. |
Ports
Table2-223 Port specifications
Card model |
Connector type |
Port quantity |
MIC-CP1L |
1-port 100G optical interface card (CFP, LC) |
LC |
1 |
100 Gbps |
Table2-224 Technical specifications
Item |
37 × 171 × 157 mm (1.46 × 6.73 × 6.18 in) |
Weight |
0.55 kg (1.21 lb) |
11.8 W |
3.3 W |
MIC-CP1L-V2
View
Figure2-45 MIC-CP1L-V2 view
(1) CFP2 port LED. For the LED description, see Table2-225. |
(2) 100GBASE-R-CFP2 fiber port (1 in total) |
LEDs
Table2-225 CFP2 port LED description
LED |
Status |
CFP2 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-226 Port specifications
Card model |
Connector type |
Port quantity |
MIC-CP1L-V2 |
1-port 100G Ethernet optical interface card (CFP2, LC) |
LC |
1 |
100 Gbps |
Table2-227 Technical specifications
Item |
23 × 137 × 119 mm (0.91 × 5.39 × 4.69 in) |
Weight |
0.45 kg (0.99 lb) |
8.7 W |
6 W |
MIC-CP2L
View
Figure2-46 MIC-CP2L view
(1) 100GBASE-R-CFP2 fiber ports (2 in total) (100G CFP2 modules supported) |
(2) CFP2 port LED. For the LED description, see Table2-228. |
LEDs
Table2-228 CFP2 port LED description
LED |
Status |
CFP2 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-229 Port specifications
Card model |
Connector type |
Port quantity |
MIC-CP2L |
2-port 100G Ethernet optical interface card (CFP2, LC) |
LC |
2 |
100 Gbps |
Table2-230 Technical specifications
Item |
38 × 179 × 149 mm (1.50 × 7.05 × 5.87 in) |
Weight |
0.80 kg (1.76 lb) |
18.1 W |
8.6 W |
MIC-CP2L-V2
View
Figure2-47 MIC-CP2L-V2 view
(1) QSFP28 port LED. For the LED description, see Table2-231. |
(2) 100GBASE-R-QSFP28 fiber ports (2 in total) |
LEDs
Table2-231 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-232 Port specifications
Card model |
Connector type |
Port quantity |
MIC-CP2L-V2 |
2-port 100G Ethernet optical interface card (QSFP28) |
LC |
2 |
100 Gbps |
Table2-233 Technical specifications
Item |
Weight |
0.40 kg (0.88 lb) |
15 W |
9.3 W |
MIC-CQ1L1
View
Figure2-48 MIC-CQ1L1 view
(1) 100GBASE-R-QSFP28 port (1 in total) |
(2) QSFP28 port LED. For the LED description, see Table2-234 |
LEDs
Table2-234 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-235 Port specifications
Card model |
Connector type |
Port quantity |
MIC-CQ1L1 |
1-port 100G Ethernet optical interface card |
LC |
1 |
100 Gbps |
40 Gbps |
Table2-236 Technical specifications
Item |
Weight |
0.50 kg (1.10 lb) |
15 W |
9 W |
MIC-CQ1L2
View
Figure2-49 MIC-CQ1L2 view
(1) QSFP28 port LED. For the LED description, see Table2-237. |
(2) 100GBASE-R-QSFP28 fiber port (1 in total) |
LEDs
Table2-237 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-238 Port specifications
Card model |
Connector type |
Port quantity |
MIC-CQ1L2 |
LC |
1 |
100 Gbps |
40 Gbps |
Table2-239 Technical specifications
Item |
Weight |
0.45 kg (0.99 lb) |
15 W |
9 W |
MIC-CQ1LF
View
Figure2-50 MIC-CQ1LF view
(1) 100G/50G/40G fiber port LED. For the LED description, see Table2-240. |
(2) 100G/50G/40G fiber port (1 in total) |
(3) 50G/40G fiber port (1 in total) |
(4) 50G/40G fiber port LED. For the LED description, see Table2-240. |
LEDs
Table2-240 Fiber port LED description
LED |
Status |
Fiber port LED |
Flashing |
The port is sending or receiving data. |
Steady on |
A link is present on the port. |
Off |
No link is present on the port. |
Ports
Table2-241 Port specifications
Card model |
Connector type |
Port quantity |
MIC-CQ1LF |
2-port 50G/1-port 100G flexible Ethernet optical interface card (QSFP28,LC) |
LC |
2 |
· 100 Gbps · 50 Gbps · 40 Gbps |
Table2-242 Technical specifications
Item |
36 × 171 × 157 mm (1.42 × 6.73 × 6.18 in) |
Weight |
0.58 kg (1.28 lb) |
27 W |
21 W |
MIC-CQ2L
View
Figure2-51 MIC-CQ2L view
(1) QSFP28 port LED. For the LED description, see Table2-243. |
LEDs
Table2-243 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-244 Port specifications
Card model |
Connector type |
Port quantity |
MIC-CQ2L |
LC |
2 |
100 Gbps |
40 Gbps |
Table2-245 Technical specifications
Item |
Weight |
0.40 kg (0.88 lb) |
16 W |
8 W |
MIC-ET16L
View
Figure2-52 MIC-ET16L view
(1) E1-HM96 copper ports (16 in total) |
(2) Port LED. For the LED description, see Table2-246. |
LED
LED |
Status |
ACT/ALM |
Flashing green |
Steady green |
A link is present, but the port is not receiving or sending data. |
Steady red |
Off |
Ports
Table2-247 Port specifications
Card model |
Connector type |
Port quantity |
MIC-ET16L |
16-port E1 electrical interface card (HM96 male connector) |
HM96 male |
16 |
E1 |
Table2-248 Technical specifications
Item |
Weight |
0.30 kg (0.66 lb) |
8.7 W |
8.6 W |
MIC-GP10L1/MIC-GP10L2
View
Figure2-53 MIC-GP10L1 view
(1) 1000BASE-X-SFP fiber ports (10 in total) |
(2) SFP port LED. For the LED description, see Table2-249. |
The views of the MIC-GP10L1 and MIC-GP10L2 are similar. This figure uses the MIC-GP10L1 as an example.
LEDs
Table2-249 GE SFP port LED description
LED |
Status |
GE SFP port LED (LINK/ACT) |
Flashing green |
The SFP port is sending or receiving data. |
Green |
A link is present on the SFP port. |
Off |
No link is present on the SFP port. |
Ports
Table2-250 Port specifications
Card model |
Connector type |
Port quantity |
MIC-GP10L1 |
10-port 1000BASE-X optical interface card (SFP, LC) |
LC |
10 |
1000 Mbps |
10/100/1000 Mbps |
MIC-GP10L2 |
10-port 1000BASE-X Ethernet optical interface card (SFP, LC) |
LC |
10 |
10/100/1000 Mbps |
Table2-251 Technical specifications
Item |
Weight |
· MIC-GP10L1: 0.30 kg (0.66 lb) · MIC-GP10L2: 0.48 kg (1.06 lb) |
· MIC-GP10L1: 7.9 W · MIC-GP10L2: 30 W |
· MIC-GP10L1: 2.1 W · MIC-GP10L2: 20 W |
MIC-GP10LA/MIC-GP10L-V2
View
Figure2-54 MIC-GP10L-V2 view
(2) SFP port LED. For the LED description, see Table2-252. |
The views of MIC-GP10LA and MIC-GP10L-V2 are similar. This figure uses the MIC-GP10L-V2 as an example.
LEDs
Table2-252 GE SFP port LED description
LED |
Status |
Flashing green |
Green |
Off |
Ports
Table2-253 Port specifications
Card model |
Connector type |
Port quantity |
MIC-GP10LA |
10-port 1000BASE-X Ethernet optical interface card A (SFP, LC) |
LC |
10 |
1000 Mbps |
10/100/1000 Mbps |
100 Mbps |
MIC-GP10L-V2 |
LC |
10 |
1000 Mbps |
10/100/1000 Mbps |
100 Mbps |
Table2-254 Technical specifications
Item |
Weight |
0.35 kg (0.77 lb) |
9.4 W |
9.3 W |
MIC-GP20L
View
Figure2-55 MIC-GP20L view
(1) 1000BASE-X-SFP fiber ports (20 in total) |
(2) SFP port LED. For the LED description, see Table2-255. |
LEDs
Table2-255 GE SFP port LED description
LED |
Status |
Flashing green |
Green |
Off |
Ports
Table2-256 Port specifications
Card model |
Connector type |
Port quantity |
MIC-GP20L |
20-port 1000BASE-X Ethernet optical interface card (SFP, LC) |
LC |
20 |
1000 Mbps |
10/100/1000 Mbps |
100 Mbps |
Table2-257 Technical specifications
Item |
Weight |
0.55 kg (1.21 lb) |
23 W |
7.6 W |
MIC-GP20L1
View
Figure2-56 MIC-GP20L1 view
(2) SFP port LED. For the LED description, see Table2-258. |
LEDs
Table2-258 GE SFP port LED description
LED |
Status |
Flashing green |
Green |
Off |
Ports
Table2-259 Port specifications
Card model |
Connector type |
Port quantity |
MIC-GP20L1 |
LC |
20 |
1000 Mbps |
10/100/1000 Mbps |
100 Mbps |
Table2-260 Technical specifications
Item |
Weight |
0.80 kg (1.76 lb) |
18 W |
7 W |
MIC-GP4L
View
Table2-261 MIC-GP4L view
(1) Combo interfaces (4 in total) |
(2) Combo fiber port LINK/ACT LED. For the LED description, see Table2-262. |
(3) Combo copper LINK LED. For the LED description, see Table2-262. |
(4) Combo copper ACT LED. For the LED description, see Table2-262. |
LEDs
Table2-262 Combo ports LED description
Port type |
LED |
Status |
Combo fiber port |
LINK/ACT |
Steady on |
The port is up. |
Flashing green |
The port is receiving or sending data correctly. |
Off |
The port is down. |
Combo copper port |
LINK (Green) |
Steady on |
The port is up. |
Off |
The port is down. |
ACT (Orange) |
Flashing green |
Off |
The port is not receiving or sending data. |
Ports
Table2-263 Port specifications
Card model |
Connector type |
Port quantity |
MIC-GP4L |
4-port 1000BASE-X/1000BASE-T combo interface card |
RJ45 |
4 |
10/100/1000 Mbps |
LC |
4 |
100 Mbps |
1000 Mbps |
Table2-264 Technical specifications
Item |
Weight |
0.31 kg (0.68 lb) |
5.5 W |
0.8 W |
MIC-GP8L
View
Figure2-57 MIC-GP8L view
(1) 1000BASE-X-SFP fiber ports (8 in total) |
(2) SFP port LED. For the LED description, see Table2-265. |
LEDs
Table2-265 GE SFP port LED description
LED |
Status |
Flashing green |
Green |
Off |
Ports
Table2-266 Port specifications
Card model |
Connector type |
Port quantity |
MIC-GP8L |
8-port 1000BASE-X optical interface card (SFP, LC) |
LC |
8 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
Table2-267 Technical specifications
Item |
Weight |
0.29 kg (0.64 lb) |
4.7 W |
0.6 W |
MIC-GT20L/MIC-GT20L1/MIC-GT20LA
View
Figure2-58 MIC-GT20L view
(1) 10/100/1000BASE-T copper ports (20 in total) |
(2) RJ-45 Ethernet port LED. For the description for the RJ-45 port LEDs on the MIC-GT20L and MIC-GT20LA, see Table2-268. For the description for the RJ-45 port LEDs on the MIC-GT20L1, see Table2-269. |
The views of the MIC-GT20L, MIC-GT20L1, and MIC-GT20LA are similar. This figure uses the MIC-GT20L as an example.
LEDs
Table2-268 RJ-45 Ethernet port LED description (1)
LED |
Status |
RJ-45 Ethernet port LED |
Flashing |
Steady on |
Off |
Table2-269 RJ-45 Ethernet port LED description (2)
LED |
Status |
Flashing green |
The port is receiving or sending data at 1000 Mbps. |
Steady green |
A link is present on the port, and the port operates at 1000 Mbps. |
Flashing yellow |
The port is receiving or sending data at 10/100 Mbps. |
Steady yellow |
A link is present on the port, and the port operates at 10/100 Mbps. |
Off |
Ports
Table2-270 Port specifications
Card model |
Connector type |
Port quantity |
MIC-GT20L |
20-port 1000BASE-X Ethernet electrical interface card (RJ45) |
RJ-45 |
20 |
10/100/1000 Mbps |
MIC-GT20L1 |
20-port 1000BASE-T Ethernet copper interface card (RJ45) |
RJ-45 |
20 |
10/100/1000 Mbps |
MIC-GT20LA |
20-port 1000BASE-X Ethernet electrical interface card A (RJ45) |
RJ-45 |
20 |
10/100/1000 Mbps |
Table2-271 Technical specifications
Item |
Weight |
· MIC-GT20L: 0.50 kg (1.10 lb) · MIC-GT20LA: 0.84 kg (1.85 lb) · MIC-GT20L1: 0.40 kg (0.88 lb) |
· MIC-GT20L, MIC-GT20LA: 11.9 W · MIC-GT20L1: 39 W |
· MIC-GT20L, MIC-GT20LA: 9.2 W · MIC-GT20L1: 28 W |
MIC-PSP4L
View
Figure2-59 MIC-PSP4L view
(1) OC-48c/STM-16c POS fiber ports (4 in total) |
(2) Port LED. For the LED description, see Table2-272. |
LEDs
Table2-272 WAN port LED description
LED |
Status |
Flashing green |
Steady green |
Steady red |
Off |
The port is down. |
Ports
Table2-273 Port specifications
Card model |
Connector type |
Port quantity |
MIC-PSP4L |
4-port OC-48c/STM-16c POS optical interface card (SFP, LC) |
LC |
4 |
2.5 Gbps |
Table2-274 Technical specifications
Item |
Weight |
0.40 kg (0.88 lb) |
33 W |
29 W |
MIC-QP1L
View
Figure2-60 MIC-QP1L view
(1) 40GBASE-R-QSFP+ fiber port (1 in total) |
(2) QSFP+ port LED. For the LED description, see Table2-275. |
LEDs
Table2-275 QSFP+ port LED description
LED |
Status |
QSFP+ port LED |
Flashing |
The QSFP+ port is sending or receiving data. |
Steady on |
A link is present on the QSFP+ port. |
Off |
No link is present on the QSFP+ port. |
Ports
Table2-276 Port specifications
Card model |
Connector type |
Port quantity |
MIC-QP1L |
1-port 40G Ethernet optical interface card (QSFP+, LC) |
LC |
1 |
40 Gbps |
4 |
10 Gbps |
Table2-277 Technical specifications
Item |
Weight |
0.35 kg (0.77 lb) |
7 W |
3 W |
MIC-SP4L
View
Figure2-61 MIC-SP4L view
(1) OC-3c/STM-1c POS/ATM fiber ports (4 in total) or OC-12c/STM-4c POS/ATM fiber ports (port 1) |
(2) Port LED. For the LED description, see Table2-278. |
LEDs
Table2-278 WAN port LED description
LED |
Status |
Flashing green |
Steady green |
Steady red |
Off |
The port is down. |
Ports
Table2-279 Port specifications
Card model |
Connector type |
Port quantity |
MIC-SP4L |
4-port OC-3c/STM-1c POS/ATM or 1-port OC-12c/STM-4c POS/ATM optical interface card (SFP, LC) |
LC |
4 |
1 |
622 Mbps (OC-12/STM-4) |
Table2-280 Technical specifications
Item |
Weight |
0.30 kg (0.66 lb) |
13.5 W |
9.6 W |
MIC-SP8L
View
Figure2-62 MIC-SP8L view
(1) OC-3c/STM-1c POS fiber ports (8 in total) |
(2) Port LED. For the LED description, see Table2-281. |
LEDs
Table2-281 WAN port LED description
LED |
Status |
Flashing green |
Steady green |
Steady red |
Off |
The port is down. |
Ports
Table2-282 Port specifications
Card model |
Connector type |
Port quantity |
MIC-SP8L |
8-port OC-3c/STM-1c POS optical interface card (SFP, LC) |
LC |
8 |
Table2-283 Technical specifications
Item |
Weight |
0.30 kg (0.66 lb) |
16.3 W |
14 W |
MIC-TCP8L
View
Figure2-63 MIC-TCP8L view
(1) OC-3c/OC-12c POS/GE fiber ports (8 in total) |
(2) Port LED. For the LED description, see Table2-284. |
LEDs
Table2-284 WAN port LED description
LED |
Status |
Flashing green |
Steady green |
Steady red |
Off |
The port is down. |
Ports
Table2-285 Port specifications
Card model |
Connector type |
Port quantity |
MIC-TCP8L |
8-port OC-3c/OC-12c POS/GE optical interface card (SFP, LC) |
LC |
8 |
10/100/1000 Mbps |
1000 Mbps |
Table2-286 Technical specifications
Item |
Weight |
0.40 kg (0.88 lb) |
30 W |
28 W |
MIC-XP10LF
View
Figure2-64 MIC-XP10LF view
(1) Port LED. For the LED description, see Table2-287. |
(2) 10GBASE-R-SFP+ fiber ports (10 in total) or 25GBASE-R-SFP28 fiber ports (ports 1 to 4) |
LEDs
Table2-287 Port LED description
LED |
Status |
Port LED |
Flashing |
The port is receiving or sending data. |
Steady on |
Off |
NOTE: You can identify the speed of a port by observing the color of its LED. Green indicates a speed of 25 Gbps, and yellow indicates a speed of 10 Gbps. |
Ports
Table2-288 Port specifications
Card model |
Connector type |
Port quantity |
MIC-XP10LF |
10-port 10GBASE-R flexible Ethernet optical interface card (SFP+,LC) |
LC |
10 |
10 Gbps |
4 |
25 Gbps |
Table2-289 Technical specifications
Item |
Weight |
0.61 kg (1.34 lb) |
37 W |
30 W |
MIC-XP10L-LAN
View
Figure2-65 MIC-XP10L-LAN view
(1) 10GBASE-R-SFP+ fiber ports or 1000BASE-X-SFP fiber ports (10 in total) |
(2) SFP+ port LED. For the LED description, see Table2-290. |
LEDs
Table2-290 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
NOTE: You can identify the speed of an SFP+ port by observing the color of its LED. Green indicates a speed of 10 Gbps, and yellow indicates a speed of 1000 Mbps. |
Ports
Table2-291 Port specifications
Card model |
Connector type |
Port quantity |
MIC-XP10L-LAN |
10-port 10GBASE-R Ethernet optical interface card (SFP+, LC)-LAN |
LC |
10 |
10 Gbps |
1000 Mbps |
Table2-292 Technical specifications
Item |
Weight |
0.46 kg (1.01 lb) |
20 W |
12 W |
MIC-XP20L/MIC-XP20LA
View
Figure2-66 MIC-XP20L view
(1) 10GBASE-R/W-SFP+ fiber ports (20 in total) (10GE SFP+ modules supported) |
(2) SFP+ port LED. For the LED description, see Table2-293. |
The views of MIC-XP20L and MIC-XP20LA are similar. This figure uses the MIC-XP20L as an example.
LEDs
Table2-293 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-294 Port specifications
Card model |
Connector type |
Port quantity |
MIC-XP20L |
20-port 10GBASE-R/W Ethernet optical interface card (SFP+, LC) |
LC |
20 |
100 Mbps |
10/100/1000 Mbps |
1000 Mbps |
10 Gbps |
MIC-XP20LA |
20-port 10GBASE-R/W Ethernet optical interface card A (SFP+, LC) |
LC |
20 |
100 Mbps |
10/100/1000 Mbps |
1000 Mbps |
10 Gbps |
Table2-295 Technical specifications
Item |
Weight |
0.95 kg (2.09 lb) |
53 W |
38.3 W |
MIC-XP2L
View
Figure2-67 MIC-XP2L view
(1) 10GBASE-R/W-SFP+ fiber ports (2 in total) |
(2) SFP+ port LED. For the LED description, see Table2-296. |
LEDs
Table2-296 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-297 Port specifications
Card model |
Connector type |
Port quantity |
MIC-XP2L |
2-port 10GBASE-R Ethernet optical interface card (SFP+, LC) |
LC |
2 |
100 Mbps |
10/100/1000 Mbps |
1000 Mbps |
10 Gbps |
Table2-298 Technical specifications
Item |
Weight |
0.29 kg (0.64 lb) |
13 W |
10 W |
MIC-XP2L-LAN
View
Figure2-68 MIC-XP2L-LAN view
(1) 10GBASE-R-SFP+ fiber ports (2 in total) |
(2) SFP+ port LED. For the LED description, see Table2-299. |
LEDs
Table2-299 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-300 Port specifications
Card model |
Connector type |
Port quantity |
MIC-XP2L-LAN |
2-port 10GBASE-R Ethernet optical interface card (SFP+, LC)-LAN |
LC |
2 |
100 Mbps |
10/100/1000 Mbps |
1000 Mbps |
10 Gbps |
Table2-301 Technical specifications
Item |
Weight |
0.28 kg (0.62 lb) |
9 W |
6 W |
MIC-XP4L1
View
Figure2-69 MIC-XP4L1 view
(1) 10GBASE-R/W-SFP+ fiber ports (4 in total) |
(2) SFP+ port LED. For the LED description, see Table2-302. |
LEDs
Table2-302 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-303 Port specifications
Card model |
Connector type |
Port quantity |
MIC-XP4L1 |
4-port 10GBASE-R/W Ethernet optical interface card 1 (SFP+, LC) |
LC |
4 |
100 Mbps |
10/100/1000 Mbps |
1000 Mbps |
10 Gbps |
Table2-304 MIC-XP4L1
Item |
Weight |
0.30 kg (0.66 lb) |
13 W |
11 W |
MIC-XP5L
View
Figure2-70 MIC-XP5L view
(1) 10GBASE-R/W-SFP+ fiber ports (5 in total) |
(2) SFP+ port LED. For the LED description, see Table2-305. |
LEDs
Table2-305 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-306 Port specifications
Card model |
Connector type |
Port quantity |
MIC-XP5L |
5-port 10GBASE-R/W Ethernet optical interface card (SFP+, LC) |
LC |
5 |
100 Mbps |
10/100/1000 Mbps |
1000 Mbps |
10 Gbps |
Table2-307 Technical specifications
Item |
Weight |
0.30 kg (0.66 lb) |
14.2 W |
10.4 W |
MIC-XP5L1/MIC-XP5L2
View
Figure2-71 MIC-XP5L1 view
(2) SFP+ port LED. For the LED description, see Table2-308. |
The views of the MIC-XP5L1 and MIC-XP5L2 are similar. This figure uses the MIC-XP5L1 as an example.
LEDs
Table2-308 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-309 Port specifications
Card model |
Connector type |
Port quantity |
MIC-XP5L1 |
LC |
5 |
10/100/1000 Mbps |
10 Gbps |
MIC-XP5L2 |
5-port 10GBASE-R Ethernet optical interface card (SFP+, LC) |
LC |
5 |
10/100/1000 Mbps |
10 Gbps |
Table2-310 Technical specifications
Item |
Weight |
0.35 kg (0.77 lb) |
· MIC-XP5L1: 13 W · MIC-XP5L2: 6.4 W |
· MIC-XP5L1: 11 W · MIC-XP5L2: 2.3 W |
MIC-XP8L
View
Figure2-72 MIC-XP8L view
(1) 10GBASE-R/W-SFP+ fiber ports (8 in total) |
(2) SFP+ port LED. For the LED description, see Table2-311. |
LEDs
Table2-311 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-312 Port specifications
Card model |
Connector type |
Port quantity |
MIC-XP8L |
8-port 10GBASE-R/W Ethernet optical interface card (SFP+, LC) |
LC |
8 |
10 Gbps |
Table2-313 Technical specifications
Item |
Weight |
0.70 kg (1.54 lb) |
22 W |
16 W |
NIC subcards
IMPORTANT: · To use a NIC interface card, you must install it on a CMPE, SPE, or CSPEX base card. You cannot install it directly on the router. · For the compatibility between NIC interface cards and CMPE, SPE, or CSPEX base cards, see the compatibility information for the base cards. |
NIC-CC1L
View
Figure2-73 NIC-CC1L view
(1) 100GBASE-R-CFP2 fiber port (1 in total) |
(2) CFP2 port LED. For the LED description, see Table2-314. |
LEDs
Table2-314 CFP2 port LED description
LED |
Status |
CFP2 port LED |
Flashing |
The CFP2 port is sending or receiving data at 100 Gbps. |
Steady on |
A 100 Gbps link is present on the CFP2 port. |
Off |
No link is present on the CFP2 port. |
Ports
Table2-315 Port specifications
Card model |
Connector type |
Port quantity |
NIC-CC1L |
LC |
1 |
100 Gbps |
Table2-316 Technical specifications
Item |
47.5 × 179 × 118 mm (1.87 × 7.05 × 4.65 in) |
Weight |
0.60 kg (1.32 lb) |
9.7 W |
9.6 W |
NIC-CC2L
View
Figure2-74 NIC-CC2L view
(1) 100GBASE-R-CFP2 fiber ports (2 in total) |
(2) CFP2 port LED. For the LED description, see Table2-317. |
LEDs
Table2-317 CFP2 port LED description
LED |
Status |
CFP2 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-318 Port specifications
Card model |
Connector type |
Port quantity |
NIC-CC2L |
2-port 100G Ethernet optical interface card |
LC |
2 |
100 Gbps |
Table2-319 Technical specifications
Item |
Weight |
0.85 kg (1.87 lb) |
21 W |
19.2 W |
NIC-CQ1L
View
Figure2-75 NIC-CQ1L view
(1) 100GBASE-R-QSFP28 fiber port (1 in total) |
(2) QSFP28 port LED. For the LED description, see Table2-320. |
LEDs
Table2-320 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
The QSFP28 port is sending or receiving data at 100 Gbps. |
Steady on |
A 100 Gbps link is present on the QSFP28 port. |
Off |
No link is present on the QSFP28 port. |
Ports
Table2-321 Port specifications
Card model |
Connector type |
Port quantity |
NIC-CQ1L |
LC |
1 |
100 Gbps |
Table2-322 Technical specifications
Item |
Weight |
0.35 kg (0.77 lb) |
13 W |
8 W |
NIC-CQ2L/NIC-CQ2LA
View
Figure2-76 NIC-CQ2L view
(1) 100GBASE-R-QSFP28 fiber ports (2 in total) |
(2) QSFP28 port LED. For the LED description, see Table2-323. |
The views of NIC-CQ2L and NIC-CQ2LA are similar. This figure uses the NIC-CQ2L as an example.
LEDs
Table2-323 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-324 Port specifications
Card model |
Connector type |
Port quantity |
NIC-CQ2L |
LC |
2 |
100 Gbps |
NIC-CQ2LA |
2-port 100G Ethernet optical interface card A |
LC |
2 |
100 Gbps |
Table2-325 Technical specifications
Item |
Weight |
· NIC-CQ2L: 0.35 kg (0.77 lb) · NIC-CQ2LA: 0.75 kg (1.65 lb) |
26 W |
16 W |
NIC-GP20L
View
Figure2-77 NIC-GP20L view
(2) SFP port LED. For the LED description, see Table2-326. |
LEDs
Table2-326 GE SFP port LED description
LED |
Status |
Flashing green |
Green |
Off |
Ports
Table2-327 Port specifications
Card model |
Connector type |
Port quantity |
NIC-GP20L |
20-port 1000BASE-X Ethernet optical interface card |
LC |
20 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
Table2-328 Technical specifications
Item |
Weight |
0.65 kg (1.43 lb) |
13.8 W |
12 W |
NIC-GP24L
View
Figure2-78 NIC-GP24L view
(1) 1000BASE-X-SFP fiber ports (24 in total) |
(2) SFP port LED. For the LED description, see Table2-329. |
LEDs
Table2-329 GE SFP port LED description
LED |
Status |
Flashing green |
Green |
Off |
Ports
Table2-330 Port specifications
Card model |
Connector type |
Port quantity |
NIC-GP24L |
24-port 1000BASE-X Ethernet optical interface card |
LC |
24 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
Table2-331 Technical specifications
Item |
Weight |
0.50 kg (1.10 lb) |
28 W |
20 W |
NIC-GP24L1/NIC-GP24L1A
View
Figure2-79 NIC-GP24L1 view
(2) SFP port LED. For the LED description, see Table2-332. |
The views of the NIC-GP24L1 and NIC-GP24L1A are similar. This figure uses the NIC-GP24L1 as an example.
LEDs
Table2-332 GE SFP port LED description
LED |
Status |
Flashing green |
Green |
Off |
Ports
Table2-333 Port specifications
Card model |
Connector type |
Port quantity |
NIC-GP24L1 |
LC |
24 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
NIC-GP24L1A |
24-port 1000BASE-X Ethernet optical interface card A |
LC |
24 |
1000 Mbps |
Table2-334 Technical specifications
Item |
Weight |
1.00 kg (2.20 lb) |
47 W |
41 W |
NIC-GT20L
View
Figure2-80 NIC-GT20L view
(2) RJ-45 Ethernet port LED. For the LED description, see Table2-335. |
LEDs
Table2-335 RJ-45 Ethernet port LED description
LED |
Status |
Flashing |
Steady on |
Off |
Ports
Table2-336 Port specifications
Card model |
Connector type |
Port quantity |
NIC-GT20L |
20-port 1000BASE-T Ethernet copper interface card |
RJ-45 |
20 |
10/100/1000 Mbps |
Table2-337 Technical specifications
Item |
Weight |
0.75 kg (1.65 lb) |
16.5 W |
14.6 W |
NIC-XP10L
View
Figure2-81 NIC-XP10L view
(1) 10GBASE-R/W-SFP+ fiber ports (10 in total) |
(2) SFP+ port LED. For the LED description, see Table2-338. |
LEDs
Table2-338 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-339 Port specifications
Card model |
Connector type |
Port quantity |
NIC-XP10L |
10-port 10GBASE-R/W Ethernet optical interface card |
LC |
10 |
10 Gbps |
1000 Mbps |
Table2-340 Technical specifications
Item |
Weight |
0.65 kg (1.43 lb) |
27.4 W |
26.9 W |
NIC-XP20L
View
Figure2-82 NIC-XP20L view
(1) 10GBASE-R/W-SFP+ fiber ports (20 in total) |
(2) SFP+ port LED. For the LED description, see Table2-341. |
LEDs
Table2-341 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-342 Port specifications
Card model |
Connector type |
Port quantity |
NIC-XP20L |
20-port 10GBASE-R/W Ethernet optical interface card |
LC |
20 |
10 Gbps |
1000 Mbps |
Table2-343 Technical specifications
Item |
Weight |
0.90 kg (1.98 lb) |
58 W |
39 W |
NIC-XP20L1/NIC-XP20L1A
View
Figure2-83 NIC-XP20L1 view
(1) 10GBASE-R/W-SFP+ fiber ports or 1000BASE-X-SFP fiber ports (20 in total) |
(2) SFP+ port/SFP port LED. For the SFP+ port LED description, see Table2-344. For the SFP port LED description, see Table2-345 |
The views of the NIC-XP20L1 and NIC-XP20L1A are similar. This figure uses the NIC-XP20L1 as an example.
LEDs
Table2-344 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Table2-345 GE SFP port LED description
LED |
Status |
Flashing green |
Green |
Off |
Ports
Table2-346 Port specifications
Card model |
Connector type |
Port quantity |
NIC-XP20L1 |
LC |
20 |
10 Gbps |
1000 Mbps |
NIC-XP20L1A |
20-port 10GBASE-R/W Ethernet optical interface card A |
LC |
20 |
10 Gbps |
1000 Mbps |
Table2-347 Technical specifications
Item |
Weight |
· NIC-XP20L1: 1.00 kg (2.20 lb) · NIC-XP20L1A: 0.90 kg (1.98 lb) |
60 W |
50 W |
NIC-XP5L
View
Figure2-84 NIC-XP5L view
(2) SFP+ port LED. For the LED description, see Table2-348. |
LEDs
Table2-348 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-349 Port specifications
Card model |
Connector type |
Port quantity |
NIC-XP5L |
5-port 10GBASE-R/W Ethernet optical interface card |
LC |
5 |
10 Gbps |
Table2-350 Technical specifications
Item |
Weight |
0.60 kg (1.32 lb) |
14.9 W |
11 W |
RX-NIC-CC1L
View
Figure2-85 RX-NIC-CC1L view
(2) CFP2 port LED. For the LED description, see Table2-351. |
LEDs
Table2-351 CFP2 port LED description
LED |
Status |
CFP2 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-352 Port specifications
Card model |
Connector type |
Port quantity |
RX-NIC-CC1L |
LC |
1 |
100 Gbps |
Table2-353 Technical specifications
Item |
Weight |
0.60 kg (1.32 lb) |
9.7 W |
9.6 W |
RX-NIC-CC2L
View
Figure2-86 RX-NIC-CC2L view
(2) CFP2 port LED. For the LED description, see Table2-354. |
LEDs
Table2-354 CFP2 port LED description
LED |
Status |
CFP2 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-355 Port specifications
Card model |
Connector type |
Port quantity |
RX-NIC-CC2L |
LC |
2 |
100 Gbps |
Table2-356 Technical specifications
Item |
Weight |
0.85 kg (1.87 lb) |
21 W |
19.2 W |
RX-NIC-CQ1LF
View
Figure2-87 RX-NIC-CQ1LF view
(2) QSFP28 port LED. For the description, see Table2-357. |
LEDs
Table2-357 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
Steady on |
Off |
NOTE: You can identify the speed of a QSFP28 port by observing the color of its LED. Green indicates a speed of 100 Gbps, and yellow indicates a speed of 50 Gbps. |
Ports
Table2-358 Port specifications
Card model |
Connector type |
Port quantity |
RX-NIC-CQ1LF |
1-port 100G flexible Ethernet optical interface card |
LC |
1 |
Standard Ethernet mode: 100 Gbps Flexible Ethernet mode: 100 Gbps |
Table2-359 Technical specifications
Item |
Weight |
0.85 kg (1.87 lb) |
53 W |
35 W |
RX-NIC-CQ2LF
View
Figure2-88 RX-NIC-CQ2LF view
(1) 100GBASE-R-QSFP28 fiber ports (2 in total). |
(2) QSFP28 port LED. For the description, see Table2-360. |
LEDs
Table2-360 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-361 Port specifications
Card model |
Connector type |
Port quantity |
RX-NIC-CQ2LF |
2-port 100G flexible Ethernet optical interface card |
LC |
2 |
Table2-362 Technical specifications
Item |
Weight |
1.00 kg (2.20 lb) |
61 W |
38 W |
RX-NIC-GP20L
View
Figure2-89 RX-NIC-GP20L view
(2) SFP port LED. For the LED description, see Table2-363. |
LEDs
Table2-363 GE SFP port LED description
LED |
Status |
Flashing green |
Green |
Off |
Ports
Table2-364 Port specifications
Card model |
Connector type |
Port quantity |
RX-NIC-GP20L |
LC |
20 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
Table2-365 Technical specifications
Item |
Weight |
0.65 kg (1.43 lb) |
13.8 W |
12 W |
RX-NIC-LGQ2L
View
Figure2-90 RX-NIC-LGQ2L view
(1) 50GBASE-R-QSFP28 fiber ports (2 in total) |
(2) QSFP28 port LED. For the LED description, see Table2-366. |
LEDs
Table2-366 QSFP28 port LED description
LED |
Status |
QSFP28 port LEDs |
Flashing |
Steady on |
Off |
Ports
Table2-367 Port specifications
Card model |
Connector type |
Port quantity |
RX-NIC-LGQ2L |
2-port 50G Ethernet optical interface card |
LC |
2 |
Standard Ethernet mode: 50 Gbps Flexible Ethernet mode: 50 Gbps |
Table2-368 Technical specifications
Item |
Weight |
0.85 kg (1.87 lb) |
61 W |
38 W |
RX-NIC-LGQ4L
View
Figure2-91 RX-NIC-LGQ4L view
(1) 50GBASE-R-QSFP28 fiber ports (4 in total) |
(2) QSFP28 port LED. For the description, see Table2-369. |
LEDs
Table2-369 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-370 Port specifications
Card model |
Connector type |
Port quantity |
RX-NIC-LGQ4L |
4-port 50G Ethernet optical interface card |
LC |
4 |
Table2-371 Technical specifications
Item |
Weight |
0.90 kg (1.98 lb) |
92 W |
55 W |
RX-NIC-XP10L
View
Figure2-92 RX-NIC-XP10L view
(2) SFP+ port LED. For the LED description, see Table2-372. |
LEDs
Table2-372 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-373 Port specifications
Card model |
Connector type |
Port quantity |
RX-NIC-XP10L |
LC |
10 |
10 Gbps |
Table2-374 Technical specifications
Item |
Weight |
0.65 kg (1.43 lb) |
27.4 W |
26.9 W |
RX-NIC-XP20L
View
Figure2-93 RX-NIC-XP20L view
(2) SFP+ port LED. For the LED description, see Table2-375. |
LEDs
Table2-375 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-376 Port specifications
Card model |
Connector type |
Port quantity |
RX-NIC-XP20L |
LC |
20 |
10 Gbps |
Table2-377 Technical specifications
Item |
Weight |
1.00 kg (2.20 lb) |
58 W |
39 W |
RX-NIC-XP5L
View
Figure2-94 RX-NIC-XP5L view
(2) SFP+ port LED. For the LED description, see Table2-378. |
LEDs
Table2-378 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-379 Port specifications
Card model |
Connector type |
Port quantity |
RX-NIC-XP5L |
LC |
5 |
10 Gbps |
Table2-380 Technical specifications
Item |
Weight |
0.60 kg (1.32 lb) |
14.9 W |
11 W |
RX-NIC-YGS4L
View
Figure2-95 RX-NIC-YGS4L view
(1) 10GBASE-R-SFP+ ports or 25GBASE-R-SFP28 ports (4 in total) |
(2) SFP28 port LED. For the LED description, see Table2-381. |
LEDs
Table2-381 SFP28 port LED description
LED |
Status |
SFP28 port LED |
Flashing |
Steady on |
Off |
NOTE: You can identify the speed of a QSFP28 port by observing the color of its LED. Green indicates a speed of 25 Gbps, and yellow indicates a speed of 10 Gbps. |
Ports
Table2-382 Port specifications
Card model |
Connector type |
Port quantity |
RX-NIC-YGS4L |
4-port 25G Ethernet optical interface card |
LC |
4 |
10 Gbps |
25 Gbps |
Table2-383 Technical specifications
Item |
Weight |
0.80 kg (1.76 lb) |
38 W |
25 W |
PIC subcards
IMPORTANT: · To use a PIC interface card, you must install it on a CMPE, SPE, or CSPEX base card. You cannot install it directly on the router. · For the compatibility between PIC interface cards and CMPE, SPE, or CSPEX base cards, see the compatibility information for the base cards. |
PIC-GP10L
View
Figure2-96 PIC-GP10L view
(1) 1000BASE-X-SFP Ethernet fiber ports (10 in total) |
(2) SFP port LED. For the LED description, see Table2-384. |
LEDs
Table2-384 GE SFP port LED description
LED |
Status |
Flashing green |
Green |
Off |
Ports
Table2-385 Port specifications
Card model |
Connector type |
Port quantity |
PIC-GP10L |
LC |
10 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
Table2-386 Technical specifications
Item |
Weight |
0.45 kg (0.99 lb) |
21 W |
9.5 W |
PIC-PS2G4L
View
Figure2-97 PIC-PS2G4L view
(1) OC48c/STM16c-SFP POS fiber ports (2 in total) |
(2) 1000BASE-X-SFP GE fiber ports (4 in total) |
(3) POS port LED. For the LED description, see Table2-387. |
(4) GE port LED. For the LED description, see Table2-388. |
LEDs
Table2-387 WAN port LED description
LED |
Status |
Green |
Red |
Off |
The port is down. |
Table2-388 GE SFP port LED description
LED |
Status |
Flashing green |
Green |
Off |
Ports
Table2-389 Port specifications
Card model |
Connector type |
Port quantity |
PIC-PS2G4L |
2-port OC-48c/STM-16c POS optical interface (SFP, LC) + 4-port 1000BASE-X optical interface card (SFP, LC) |
LC |
2 |
2.5 Gbps (OC-48/STM-16) |
4 |
1000 Mbps |
10/100/1000 Mbps |
Table2-390 Technical specifications
Item |
Weight |
0.40 kg (0.88 lb) |
16 W |
9.3 W |
PIC-PSP4L
View
Figure2-98 PIC-PSP4L view
(1) OC48c/STM16c-SFP POS fiber ports (4 in total) |
(2) Port LED. For the LED description, see Table2-391. |
LEDs
Table2-391 WAN port LED description
LED |
Status |
Green |
Red |
Off |
The port is down. |
Ports
Table2-392 Port specifications
Card model |
Connector type |
Port quantity |
PIC-PSP4L |
LC |
4 |
Table2-393 Technical specifications
Item |
Weight |
0.40 kg (0.88 lb) |
18 W |
9.7 W |
0°C to 45°C (32 °F to 113 °F) |
PIC-PUP1L
View
Figure2-99 PIC-PUP1L view
(1) OC192c/STM64c-XFP POS fiber port (1 in total) |
(2) Port LED. For the LED description, see Table2-394. |
LEDs
Table2-394 WAN port LED description
LED |
Status |
Green |
Red |
Off |
The port is down. |
Ports
Table2-395 Port specifications
Card model |
Connector type |
Port quantity |
PIC-PUP1L |
1-port OC-192c/STM-64c POS optical interface card (XFP, LC) |
LC |
1 |
10 Gbps (OC-192/STM-64) |
Table2-396 PIC-PUP1L
Item |
Weight |
0.50 kg (1.10 lb) |
19 W |
14.3 W |
PIC-TCP8L
View
Figure2-100 PIC-TCP8L view
(1) OC3c/OC12c/1000BASE-X-SFP POS/GE fiber ports (8 in total) |
(2) Port LED. For the LED description, see Table2-397. |
LEDs
Table2-397 WAN port LED description
LED |
Status |
Green |
Red |
Off |
The port is down. |
Ports
Table2-398 Port specifications
Card model |
Connector type |
Port quantity |
PIC-TCP8L |
LC |
8 |
1000 Mbps |
10/100/1000 Mbps |
Table2-399 Technical specifications
Item |
Weight |
0.40 kg (0.88 lb) |
17 W |
9.7 W |
PIC-XP1L
View
Figure2-101 PIC-XP1L view
(1) 10GBASE-R/W-XFP Ethernet fiber port (1 in total) |
(2) XFP port LED. For the LED description, see Table2-400. |
LEDs
Table2-400 10GE XFP port LED description
LED |
Status |
10GE XFP port LED (LINK/ACT) |
Flashing green |
The XFP port is sending or receiving data. |
Green |
A link is present on the XFP port. |
Off |
No link is present on the XFP port. |
Ports
Table2-401 Port specifications
Card model |
Connector type |
Port quantity |
PIC-XP1L |
1-port 10GBASE-R/W Ethernet optical interface card (XFP, LC) |
LC |
1 |
10 Gbps |
Table2-402 Technical specifications
Item |
Weight |
0.45 kg (0.99 lb) |
23.7 W |
12.5 W |
OAA modules
LSU1ADECEA0
View
Figure2-102 LSU1ADECEA0 view
(1) Console port (CONSOLE) |
(2) USB port (reserved for future use) |
(3) Combo copper port (10/100/1000BASE-T) |
(4) Combo copper port LED (LINK/ACT) |
(5) Combo fiber port (1000BASE-X) |
(6) Combo fiber port LED (LINK/ACT) |
(7) Alarm LED (ALM) |
(8) System LED (RUN) |
(9) Ejector lever |
(10) Captive screw |
LEDs
Table2-403 LED description
LED |
Mark |
Status |
Alarm LED |
ALM |
Off |
The system is operating correctly. |
Steady red |
A critical fault has occurred to the system and the fault must be handled immediately. |
System LED |
RUN |
Off |
No power is input or the service module has failed. |
Steady green |
The system is running incorrectly. |
Slow flashing green (1 Hz) |
Fast flashing green (8 Hz) |
The system is loading software or has not started. |
Combo interface LED |
LINK/ACT |
Off |
No link is present. |
Steady green |
A link is present. |
Flashing green |
The interface is sending or receiving data. |
Ports
Table2-404 Port specifications
Card model |
Connector type |
Port quantity |
LSU1ADECEA0 |
Application delivery service module |
RJ-45 |
2 |
10/100/1000 Mbps |
LC |
2 |
1000 Mbps |
Table2-405 Technical specifications
Item |
Weight |
3.90 kg (8.60 lb) |
150 W |
109 W |
IM-ACG1000X-IV
View
Figure2-103 IM-ACG1000X-IV view
(1) Captive screw |
(2) Ejector lever |
(3) Drive slot |
(4) Console port (CONSOLE) |
(5) GE copper port (10/100/1000BASE-T) |
(6) USB port |
(7) Drive LED (HD) |
(8) System LED (SYS) |
LEDs
Table2-406 LED description
LED |
Mark |
Status |
Drive LED |
HD |
Fast flashing green |
Data is being read from or written to the drive. |
Steady green |
The drive is running correctly. |
Off |
The drive is absent. |
System LED |
SYS |
Off |
Slow flashing green |
The system is loading software. |
Ports
Table2-407 Port specifications
Card model |
Connector type |
Port quantity |
IM-ACG1000X-IV |
Application control gateway module |
RJ45 |
1 |
10/100/1000 Mbps |
Table2-408 Technical specifications
Item |
Weight |
4.80 kg (10.60 lb) |
235 W |
175 W |
IM-IPSX-IV
View
Figure2-104 IM-IPSX-IV view
(1) Captive screw |
(2) Ejector lever |
(3) Drive slot |
(6) USB port |
LEDs
Figure2-105 LED description
LED |
Mark |
Status |
Drive LED |
HD |
Steady green |
Off |
System LED |
SYS |
Off |
Ports
Table2-409 Port specifications
Card model |
Connector type |
Port quantity |
IM-IPSX-IV |
Intrusion prevention system module |
RJ45 |
1 |
10/100/1000 Mbps |
Table2-410 Technical specifications
Item |
Weight |
4.80 kg (10.58 lb) |
235 W |
175 W |
IM-NGFWX-IV
View
Figure2-106 IM-NGFWX-IV view
(1) Captive screw |
(2) Ejector lever |
(3) Drive slot |
(6) USB port |
LEDs
Table2-411 LED description
LED |
Mark |
Status |
Drive LED |
HD |
Steady green |
Off |
System LED |
SYS |
Off |
Ports
Table2-412 Port specifications
Card model |
Connector type |
Port quantity |
IM-NGFWX-IV |
Firewall module |
RJ45 |
1 |
10/100/1000 Mbps |
Table2-413 Technical specifications
Item |
Weight |
235 W |
175 W |
LSU1FWCEA0
View
Figure2-107 LSU1FWCEA0 view
(9) Ejector lever |
LEDs
Table2-414 LED description
LED |
Mark |
Status |
Alarm LED |
ALM |
Off |
Steady red |
System LED |
RUN |
Off |
Steady green |
LINK/ACT |
Off |
Steady green |
Flashing green |
Ports
Table2-415 Port specifications
Card model |
Connector type |
Port quantity |
LSU1FWCEA0 |
Firewall module |
RJ45 |
2 |
10/100/1000 Mbps |
LC |
2 |
1000 Mbps |
Table2-416 Technical specifications
Item |
Weight |
3.90 kg (8.60 lb) |
150 W |
109 W |
LSU1IPSBEA0
View
Figure2-108 LSU1IPSBEA0 view
(2) USB port (Control power supply of the external PFC power fail safeguard module) |
(9) Ejector lever |
LEDs
Table2-417 LED description
LED |
Mark |
Status |
Alarm LED |
ALM |
Off |
Steady red |
System LED |
RUN |
Off |
Steady green |
LINK/ACT |
Off |
Steady green |
Flashing green |
Ports
Table2-418 Port specifications
Card model |
Connector type |
Port quantity |
LSU1IPSBEA0 |
RJ45 |
2 |
10/100/1000 Mbps |
LC |
2 |
1000 Mbps |
Table2-419 Technical specifications
Item |
Weight |
3.90 kg (8.60 lb) |
150 W |
109 W |
LSU3FWCEA0
View
Figure2-109 LSU3FWCEA0 view
(9) Ejector lever |
LEDs
Table2-420 LED description
LED |
Mark |
Status |
Alarm LED |
ALM |
Off |
Steady red |
System LED |
RUN |
Off |
Steady green |
LINK/ACT |
Off |
Steady green |
Flashing green |
Ports
Table2-421 Port specifications
Card model |
Connector type |
Port quantity |
LSU3FWCEA0 |
Firewall module |
RJ-45 |
2 |
10/100/1000 Mbps |
LC |
2 |
1000 Mbps |
Table2-422 Technical specifications
Item |
Weight |
3.90 kg (8.60 lb) |
150 W |
109 W |
For adequate ventilation and cooling, install the IM-NGFWX-IV, IM-IPSX-IV, and IM-ACG1000X-IV cards in the following slots only when the other slots are not available.
· CR16010-F router—Slots 0, 8 and 9.
· CR16014-F router—Slots 0 and 13.
Compatibility information
Table2-423 Compatibility matrix between OAA cards and routers
Card model |
CR16006-F, CR16010-F, CR16014-F |
CR16010H-F (with five fabric modules), CR16018-F (with five fabric modules) |
CR16010H-F (with four fabric modules), CR16018-F (with four fabric modules) |
CR16010H-FA, CR16018-FA |
CR16005E-F, CR16010E-F |
IM-NGFWX-IV |
Supported |
Supported |
Not supported |
Not supported |
Supported |
LSU1FWCEA0 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
LSU3FWCEA0 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-IPSX-IV |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
LSU1IPSBEA0 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-ACG1000X-IV |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
LSU1ADECEA0 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM modules (Universal line processing unit)
IM-MSUX (1 U)
View
Figure2-110 IM-MSUX (1 U) view
(1) Card status LED. For the LED description, see Table2-424. |
LED
Table2-424 Card status LED description
LED |
Status |
RUN (Green) |
Steady on |
The card is faulty. |
Off |
The card is faulty or is not in position. |
Flashing (about once per second) |
The card is operating correctly. |
Fast flashing |
The card is starting up. If the LED keeps fast flashing, card registration has failed. |
Ports
Table2-425 Port specifications
Card model |
IM-MSUX (1 U) |
Universal line processing unit |
Table2-426 Technical specifications
Item |
Weight |
4.95 kg (10.91 lb) |
186 W |
175 W |
158.2 W |
IM-MSUX (1.2 U)
View
Figure2-111 IM-MSUX (1.2 U) view
(1) Card status LED. For the LED description, see Table2-427. |
LEDs
Table2-427 Card status LED description
LED |
Status |
RUN (Green) |
Steady on |
Off |
Fast flashing |
Ports
Table2-428 Port specifications
Card model |
IM-MSUX (1.2 U) |
Table2-429 Technical specifications
Item |
52.5 × 399 × 352 mm (2.07 × 15.71 × 13.86 in) |
Weight |
4.85 kg (10.69 lb) |
186 W |
175 W |
158.2 W |
IM-MSEX-B
NOTE: The IM-MSEX-B provides one subcard slot. You can use it without a subcard, or use it with an IM-SP-B for double CGN packet processing rate. |
View
Figure2-112 IM-MSEX-B view
(1) Card status LED. For the LED description, see Table2-430. |
LEDs
Table2-430 Card status LED description
LED |
Status |
RUN (Green) |
Steady on |
Off |
Fast flashing |
Ports
Table2-431 Port specifications
Card model |
IM-MSEX-B |
Service processing unit |
Table2-432 Technical specifications
Item |
Weight |
3.12 kg (6.88 lb) |
400 W |
260 W |
248 W |
IM-SP-B
NOTE: The IM-SP-B must be installed on an IM-MSEX-B for use. It occupies one subcard slot and does not provide ports. |
View
Figure2-113 IM-SP-B view
(1) Card status LED. For the LED description, see Table2-433. |
LEDs
Table2-433 Card status LED description
LED |
Status |
RUN (Green) |
Steady on |
Off |
Fast flashing |
Ports
Table2-434 Port specifications
Card model |
IM-SP-B |
Universal expansion service processing module |
Table2-435 Technical specifications
Item |
47.5 × 170 × 192 mm (1.87 × 6.69 × 7.56 in) |
Weight |
1.20 kg (2.65 lb) |
130 W |
95 W |
For adequate ventilation and cooling, install the IM-MSUX (1U) card in the following slots only when the other slots are not available:
Table2-436 Compatibility matrix between universal line processing units and routers
Card model |
IM-MSUX (1 U) |
Supported |
Supported |
Not supported |
Not supported |
Supported |
IM-MSUX (1.2 U) |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
IM-MSEX-B |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
IM modules (Security monitor line processing unit)
IM-SMUX
View
Figure2-114 IM-SMUX view
(1) Card status LED. For the LED description, see Table2-437. |
LEDs
Table2-437 Card status LED description
LED |
Status |
RUN (Green) |
Steady on |
Off |
Fast flashing |
Ports
Table2-438 Port specifications
Card model |
IM-SMUX |
Security monitor line processing unit |
Table2-439 Technical specifications
Item |
Weight |
186 W |
175 W |
159 W |
Table2-440 Compatibility matrix between security monitor line processing units and routers
Card model |
IM-SMUX |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
IM modules (Network data encryption service processing unit)
IM-SFMX
NOTE: The IM-SFMX provides one subcard slot. When used without a subcard, it uses non-SM algorithms to encrypt and decrypt network data. When used with an MIC-SM, it uses SM algorithms to encrypt and decrypt network data. |
View
Figure2-115 IM-SFMX view
(1) Card status LED. For the LED description, see Table2-441. |
LEDs
Table2-441 Card status LED description
LED |
Status |
RUN (Green) |
Steady on |
Off |
Fast flashing |
Ports
Table2-442 Port specifications
Card model |
IM-SFMX |
Network data encryption service processing unit |
Table2-443 Technical specifications
Item |
40 × 399 × 355 mm (1.57 × 15.71 × 13.86 in) |
Weight |
4.05 kg (8.93 lb) |
165 W |
113 W |
90 W |
MIC-SEC
NOTE: The MIC-SEC must be installed on a card for use. It occupies one subcard slot. For more information, see the compatibility information between CMPE cards, SPE cards, or CSPEX cards between subcards. |
View
Figure2-1 MIC-SEC view
Ports
Table2-444 Port specifications
Card model |
Connector type |
Port quantity |
MIC-SEC |
Network data encryption service processing interface card |
N/A |
N/A |
N/A |
Table2-445 Technical specifications
Item |
Weight |
0.40 kg (0.88 lb) |
31 W |
29 W |
MIC-SM
NOTE: · The MIC-SM is not hot swappable. · The MIC-SM must be installed on an IM-SFMX for use. It occupies one subcard slot. · The MIC-SM is provided with six USB keys for you to obtain user roles to manage the card. To obtain a user role, first insert a USB key into USB port AUTH. For more information about the encryption card configuration, see encryption card user management in H3C CR16000-F Router Security Configuration Guide. |
View
Figure2-2 MIC-SM view
(1) Card status LED. For the LED description, see Table2-446. |
(2) USB port KEY (reserved for future use) |
(3) USB port AUTH |
LEDs
Table2-446 Card status LED description
LED |
Status |
RUN (Green) |
Steady on |
Off |
Fast flashing |
Ports
Table2-447 Port specifications
Card model |
MIC-SM |
Network data encryption interface card |
Table2-448 Technical specifications
Item |
37 × 179 × 149 mm (1.46 × 7.05 × 5.87 in) |
Weight |
0.90 kg (1.98 lb) |
40 W |
25 W |
Table2-449 Compatibility matrix between security monitor line processing units and routers
Card model |
IM-SFMX |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
IM modules (Universal open application platform)
IM-OAPX
View
Figure2-3 IM-OAPX view
No. |
(1) |
Power on/standby button and system power LED |
(2) |
2.5 in SATA drive slot |
(3) |
Drive Present/Active LED |
(4) |
Drive Fault/UID LED |
(5) |
BMC network port (1 Gb, RJ45) with default IP 192.168.1.2/24 |
(6) |
Shared network port, which can be used as the following: · Ethernet port (1Gb, RJ45) · BMC network port (1Gb, RJ45), with default IP automatically obtained through DHCP) |
(7) |
BMC network port status LED |
(8) |
Shared network port status LED |
(9) |
VGA connector |
(10) |
USB 2.0 port |
(11) |
USB 3.0 port |
(12) |
Console port |
(13) |
UID LED |
(14) |
RUN LED |
(15) |
Health LED |
LEDs
Table2-450 System power LED description
LED |
Status |
Steady green |
The system has started up. |
Flashing green (1 Hz) |
The system is starting up. |
Steady amber |
The system is in standby mode. |
Off |
The system is powered off. |
Table2-451 Health LED description
LED |
Status |
Health LED |
Steady green |
Flashing green (4 Hz) |
The BMC is currently resetting and initializing. |
Flashing yellow and green (1 Hz) |
A minor alarm occurs in the system, including an alarm on an error monitored by BMC or an alarm on hardware. |
Flashing yellow (1 Hz) |
A major alarm occurs in the system, including an alarm on an error monitored by BMC, an alarm on hardware or CPU. |
Table2-452 RUN LED description
LED |
Status |
RUN LED |
Steady on |
Off |
Flashing (1 Hz) |
Fast flashing |
Table2-453 UID LED description
LED |
Status |
UID LED |
Steady blue |
The UID LED is activated. You can activate the UID LED in the following methods: · Press down the UID LED. · Power on the UID LED from BMC. |
Flashing blue |
· 1 Hz: The system is being remote managed by BMC or performing software update. · 4Hz: BMC is restarting by pressing the UID button or LED for 8 seconds. |
Off |
The UID LED is not activated. |
Table2-454 Drive LED description
Fault/UID LED (orange/blue) |
Present/Active LED (green) |
Flashing orange (0.5 Hz) |
Steady green/flashing green (4 Hz) |
A predictive alarm occurs on the drive. Replace the drive in time.* |
Steady orange |
An error occurs on the drive. Replace the drive immediately. |
Steady blue |
The drive is operating correctly and has been selected by the array management tool. |
Off |
Flashing (4 Hz) |
The drive is present. Data is being read from or written to the drive, or the drive is being used for array migration or rebuilding. |
Off |
Steady on |
The drive is present but no data being read from or written to the drive. |
Off |
Off |
The drive is not installed properly. |
Table2-455 BMC network port LED description
LED |
Status |
BMC network port LED |
Steady green |
The network port is being activated. |
The network port is receiving or sending data. |
Off |
The network port is disconnected. |
Table2-456 Shared network port LED description
LED |
Status |
Shared network port LED |
Steady green |
Off |
Ports
Table2-457 Port specifications
Card model |
IM-OAPX |
Universal open application platform |
Table2-458 Technical specifications
Item |
Dimensions (H × W × D) |
Weight |
6.25 kg (13.78 lb) |
Maximum power consumption |
320 W |
Power consumption (with typical configuration) |
310 W |
Minimum power consumption |
295 W |
Operating temperature |
0°C to 45°C (32°F to 113°F) |
Processor |
Intel Skylake Xeon CPU · A maximum power consumption of 205 W · A maximum of 2.6 GHz CPU clock speed · 38.5 MB cache |
Memory |
Support six DDR4 memory modules · Single DIMM capacity: 32 GB · Total memory capacity: 192 GB |
Storage |
Maximum storage capacity: 2 × 960 GB |
Chipset |
Intel C62x Lewisburg chipset compatible with LBG-T SKU |
User port |
· 2 × console ports · 1 × BMC network port · 1 × shared network port (used as an Ethernet port or a BMC network port) · 1 × VGA connector · 1 × USB port (USB 3.0) · 2 × USB ports (USB 2.0) |
Table2-459 Drive specifications
Model |
Capacity |
Interface type |
Interface rate |
UIS-SSD-960GB-SATA-6G-SFF-EV |
960 G |
SATA |
6 Gbps |
UN-SSD-960G-SATA-6G-SFF-EV-1 |
960 G |
SATA |
6 Gbps |
· To avoid data loss on drives, you must shut down the universal open application platform before performing the following operations:
¡ Reboot or hot plug the universal open application platform.
¡ Reboot or shut down the router.
· Do not install the universal open application platform in slot 6 of the CR16010-F router or slot 8 of the CR16014-F router.
· The console port on the panel of the universal open application platform is only for users. The internal console port of the universal open application platform is only for H3C Support to perform maintenance and updates. Operations without permission are not allowed. H3C will not be liable for any consequences caused thereby.
· The shared network interface can operate only at 1000 Mbps and can be connected only with a GE port.
· USB ports do not support extension cables.
Table2-460 Compatibility matrix between the universal open application platform and routers
Card model |
CR16006-F |
IM-OAPX |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Supported |
Switching fabric modules
CSFC-04-1/CSFC-04-2/CSFC-04-3/CSFC-04-4
View
Figure2-4 CSFC-04-1 view
The views of CSFC-04-1, CSFC-04-2, CSFC-04-3, and CSFC-04-4 are similar. This figure uses the CSFC-04-1 as an example.
Table2-461 Technical specifications
Item |
40 × 256 × 298 mm (1.57 × 10.08 × 11.73 in) |
Weight |
1.00 kg (2.20 lb) |
N/A |
N/A |
CSFC-04B/CSFC-04D
View
Figure2-5 CSFC-04B view
(1) Switching fabric module status LED. For the LED description, see Table2-462. |
(2) Console port |
The views of CSFC-04B and CSFC-04D are similar. This figure uses the CSFC-04B as an example.
LEDs
Table2-462 Switching fabric module status LED description
LED status |
RUN |
ALM |
Flashing (0.5 Hz) |
Off |
The switching fabric module is operating correctly. |
Off |
Steady on |
The switching fabric module is faulty. |
Flashing (0.5 Hz) |
Steady on |
The temperature of the switching fabric module has exceeded the upper limit or dropped below the lower limit. |
Off |
Off |
The switching fabric module has not started up. |
Steady on |
Off |
The switching fabric module is starting up. |
Table2-463 Technical specifications
Item |
Weight |
· CSFC-04B: 1.75 kg (3.86 lb) · CSFC-04D: 1.71 kg (3.77 lb) |
· CSFC-04B: 65 W · CSFC-04D: 80 W |
· CSFC-04B: 59 W · CSFC-04D: 72 W |
· CSFC-04B: 48 W · CSFC-04D: 60 W |
CSFC-08B/CSFC-08D
View
Figure2-6 CSFC-08B view
(1) Console port |
(2) Switching fabric module status LED. For the LED description, see Table2-464. |
The views of the CSFC-08B and CSFC-08D are similar. This figure uses the CSFC-08B as an example.
LEDs
Table2-464 Switching fabric module status LED description
LED status |
RUN |
ALM |
Flashing (0.5 Hz) |
Off |
Off |
Steady on |
Flashing (0.5 Hz) |
Steady on |
Off |
Off |
Steady on |
Off |
Table2-465 Technical specifications
Item |
40 × 426 × 298 mm (1.57 × 16.77 × 11.73 in) |
Weight |
· CSFC-08B: 2.50 kg (5.51 lb) · CSFC-08D: 2.77 kg (6.11 lb) |
· CSFC-08B: 60 W · CSFC-08D: 135 W |
· CSFC-08B: 54 W · CSFC-08D: 122 W |
· CSFC-08B: 44 W · CSFC-08D: 101 W |
CSFC-12B/CSFC-12D
View
Figure2-7 CSFC-12B view
(1) Console port |
(2) Switching fabric module status LED. For the LED description, see Table2-466. |
The views of the CSFC-12B and CSFC-12D are similar. This figure uses the CSFC-12B as an example.
LEDs
Table2-466 Switching fabric module status LED description
LED status |
RUN |
ALM |
Flashing (0.5 Hz) |
Off |
Off |
Steady on |
Flashing (0.5 Hz) |
Steady on |
Off |
Off |
Steady on |
Off |
Table2-467 Technical specifications
Item |
40 × 602 × 298 mm (1.57 × 23.70 × 11.73 in) |
Weight |
· CSFC-12B: 3.89 kg (8.58 lb) · CSFC-12D: 4.51 kg (9.94 lb) |
· CSFC-12B: 140 W · CSFC-12D: 255 W |
· CSFC-12B: 126 W · CSFC-12D: 230 W |
· CSFC-12B: 107 W · CSFC-12D: 195 W |
CSFC-08E
View
Figure2-8 CSFC-08E view
(1) Switching fabric module status LED. For the LED description, see Table2-468. |
LEDs
Table2-468 Switching fabric module status LED description
LED status |
RUN |
ALM |
Flashing (0.5 Hz) |
Off |
Off |
Steady on |
Flashing (0.5 Hz) |
Steady on |
Off |
Off |
Steady on |
Off |
Table2-469 Technical specifications
Item |
Weight |
3.55 kg (7.83 lb) |
140 W |
130 W |
73 W |
CSFC-08E1/CSFC-08E1A/CSFC-08T
View
Figure2-9 CSFC-08E1 view
(1) Switching fabric module status LED. For the LED description, see Table2-470. |
The views of the CSFC-08E1, CSFC-08E1A, and CSFC-08T are similar. This figure uses the CSFC-08E1 as an example.
LEDs
Table2-470 Switching fabric module status LED description
RUN LED status |
Flashing (0.5 Hz) |
Flashing (8 Hz) |
Off |
Table2-471 Technical specifications
Item |
40 × 562 × 298 mm (1.57 × 22.13 × 11.73 in) |
Weight |
· CSFC-08E1, CSFC-08E1A: 5.20 kg (11.46 lb) · CSFC-08T: 5.15 kg (11.35 lb) |
· CSFC-08E1: 125 W · CSFC-08E1A, CSFC-08T: 129 W |
· CSFC-08E1: 112 W · CSFC-08E1A, CSFC-08T: 116 W |
· CSFC-08E1: 75 W · CSFC-08E1A, CSFC-08T: 100 W |
CSFC-12E
View
Figure2-10 CSFC-12E view
(1) Console port |
(2) Air inlet vents |
(3) Switching fabric module status LED. For the LED description, see Table2-472. |
LEDs
Table2-472 Switching fabric module status LED description
LED status |
RUN |
ALM |
Flashing (0.5 Hz) |
Off |
Off |
Steady on |
Flashing (0.5 Hz) |
Steady on |
Off |
Off |
Steady on |
Off |
Table2-473 Technical specifications
Item |
Weight |
5.30 kg (11.68 lb) |
178 W |
161 W |
146 W |
CSFC-16T/CSFC-16T1/CSFC-16E/CSFC-16EA
View
Figure2-11 CSFC-16T1 view
(1) Switching fabric module status LED. For the LED description, see Table2-474. |
The views of the CSFC-16T, CSFC-16T1, CSFC-16E, and CSFC-16EA are similar. This figure uses the CSFC-16T1 as an example.
LEDs
Table2-474 Switching fabric module status LED description
RUN LED status |
Flashing (0.5 Hz) |
Flashing (8 Hz) |
Off |
Table2-475 Technical specifications
Item |
40 × 961 × 298 mm (1.57 × 37.83 × 11.73 in) |
Weight |
· CSFC-16T: 10.25 kg (22.60 lb) · CSFC-16T1: 10.35 kg (22.82 lb) · CSFC-16E, CSFC-16EA: 10.50 kg (23.15 lb) |
· CSFC-16T: 402 W · CSFC-16E: 248 W · CSFC-16E: 248 W · CSFC-16EA: 402W |
· CSFC-16T: 361 W · CSFC-16T1: 245 W · CSFC-16E: 220 W · CSFC-16EA: 361 W |
· CSFC-16T: 267 W · CSFC-16T1: 210 W · CSFC-16E: 159 W · CSFC-16EA: 267 W |
CSFC-08T-G
View
Figure2-12 CSFC-08T-G view
(1) Switching fabric module status LED. For the LED description, see Table2-476. |
LEDs
Table2-476 Switching fabric module status LED description
RUN LED status |
Flashing (0.5 Hz) |
Flashing (8 Hz) |
Off |
Table2-477 Technical specifications
Item |
Weight |
130 W |
110 W |
100 W |
CSFC-16T-G
View
Figure2-13 CSFC-16T-G view
(1) Switching fabric module status LED. For the LED description, see Table2-478. |
LEDs
Table2-478 Switching fabric module status LED description
RUN LED status |
Flashing (0.5 Hz) |
Flashing (8 Hz) |
Off |
Table2-479 Technical specifications
Item |
Weight |
10.30 kg (22.71 lb) |
130 W |
110 W |
100 W |
CSFC-10T-G
View
Figure2-14 CSFC-10T-G view
(1) Switching fabric module status LED. For the LED description, see Table2-480. |
LEDs
Table2-480 Switching fabric module status LED description
RUN LED status |
Flashing (0.5 Hz) |
Flashing (8 Hz) |
Off |
Table2-481 Technical specifications
Item |
29 × 399.2 × 353.6 mm (1.14 × 15.72 × 13.92 in) |
Weight |
3.65 kg (8.05 lb) |
89 W |
81 W |
71 W |
CSFC-10E-G
View
Figure2-15 CSFC-10E-G view
(1) Switching fabric module status LED. For the LED description, see Table2-482. |
LEDs
Table2-482 Switching fabric module status LED description
RUN LED status |
Flashing (0.5 Hz) |
Flashing (8 Hz) |
Off |
Table2-483 Technical specifications
Item |
Weight |
3.20 kg (7.05 lb) |
54 W |
51 W |
50 W |
· Do not install switching fabric modules of different types on the same router.
· If you use Type-B, Type-D, Type-E, Type-T, or Type-TG switching fabric modules for the router, a minimum of two are required. For a CR16010H-F (with five fabric modules) or CR16010H-FA router, you must install switching fabric modules in slots 10 and 12. Slot 11 can be used only when five switching fabric modules are required. For a CR16018-F (with five fabric modules) or CR16018-FA router, you must install switching fabric modules in slots 18 and 20. Slot 19 can be used only when five switching fabric modules are required. For other routers, slots 1, 3, and 4 take precedence over the other slots.
· The console port on a switching fabric module is only for H3C Support to perform maintenance and updates. Operations without permission are not allowed. H3C will not be liable for any consequences caused thereby.
· If Type-A switching fabric modules are used, use the four together and install each into the specified slot. Each Type-A switching fabric module has a mark specifying the slot for installation. For example, the CSFC-04-1 has the mark Notes:Please insert to Slot 6.
Table2-484 Compatibility matrix between switching fabric modules and routers
Chassis model |
Available switching fabric module model |
Number |
CR16006-F |
Type-A: CSFC-04-1, CSFC-04-2, CSFC-04-3, CSFC-04-4 |
4 (1 for each switching fabric module model) |
· Type-B: CSFC-04B · Type-D: CSFC-04D |
2 to 4 |
CR16010-F |
· Type-B: CSFC-08B · Type-D: CSFC-08D · Type-E: CSFC-08E |
2 to 4 |
CR16010H-F (with five fabric modules) |
· Type-E: CSFC-08E1 · Type-T: CSFC-08T · Type-TG: CSFC-08T-G |
2 to 5 |
CR16010H-F (with four fabric modules) |
2 to 4 |
CR16010H-FA |
Type-E: CSFC-08E1A |
2 to 5 |
CR16014-F |
· Type-B: CSFC-12B · Type-D: CSFC-12D · Type-E: CSFC-12E |
2 to 4 |
· Type-E: CSFC-16E · Type-T: CSFC-16T, CSFC-16T1 · Type-TG: CSFC-16T-G |
2 to 5 |
2 to 4 |
CR16018-FA |
Type-E: CSFC-16EA |
2 to 5 |
CR16010E-F |
· Type-T: CSFC-10T-G · Type-E: CSFC-10E-G |
1 to 2 |
Table2-485 Compatibility matrix between switching fabric modules and service modules (1)
Service module |
Type-A switching fabric module |
CSFC-04B |
CSFC-04D |
CSFC-08B |
CSFC-08D |
CSPC-GT48LA1 |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPC-GE24L-E |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPC-GP24LA1 |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPC-GP48LB |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPC-GP24XP2LB |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPC-GP24GE8XP2L-E |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPC-GE16XP4L-E |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPC-GP44XP4LCX |
Not supported |
Supported |
Supported |
Supported |
Supported |
CSPC-XP2LA1 |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPC-XP4LB |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPC-XP8LB |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPC-XP12LAX |
Not supported |
Supported |
Supported |
Supported |
Supported |
CSPC-XP12LCX |
Not supported |
Supported |
Supported |
Supported |
Supported |
CSPC-XP24LAX |
Not supported |
Supported |
Supported |
Supported |
Supported |
CSPC-XP24LCX |
Not supported |
Supported |
Supported |
Supported |
Supported |
CSPC-XLP6LCX |
Not supported |
Supported |
Supported |
Supported |
Supported |
CSPC-CP1LCX |
Not supported |
Supported |
Supported |
Supported |
Supported |
CSPC-CP2LB |
Not supported |
Supported |
Supported |
Supported |
Supported |
CEPC-CP4RX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-CP4RXA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-CP4RX-L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-CQ8L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-CQ8LA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-CQ8L1A |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-CQ8L3A |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-CQ16L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-DQ2L1-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-XP4LX |
Not supported |
Supported |
Supported |
Supported |
Supported |
CEPC-XP24LX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-XP48RX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1204 |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1104-E |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1304X |
Not supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1404X |
Not supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1502X |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1502XA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1504X |
Not supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1504XA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1602X |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1602XA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1802X |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1802XA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1804X |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1512X |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1612X |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1812X |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1812X-E |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-2304X-G |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
CSPEX-2304X-LG |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
CSPEX-2612XA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-2612X3A |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CMPE-1104 |
Supported |
Supported |
Supported |
Supported |
Supported |
RX-SPE200 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-SPE200-E |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-NGFWX-IV |
Not supported |
Supported |
Supported |
Supported |
Supported |
LSU1FWCEA0 |
Supported |
Supported |
Supported |
Supported |
Supported |
LSU3FWCEA0 |
Supported |
Supported |
Supported |
Supported |
Supported |
IM-IPSX-IV |
Not supported |
Supported |
Supported |
Supported |
Supported |
LSU1IPSBEA0 |
Supported |
Supported |
Supported |
Supported |
Supported |
IM-ACG1000X-IV |
Not supported |
Supported |
Supported |
Supported |
Supported |
LSU1ADECEA0 |
Supported |
Supported |
Supported |
Supported |
Supported |
IM-MSUX (1U) |
Not supported |
Supported |
Supported |
Supported |
Supported |
IM-MSUX (1.2U) |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-MSEX-B |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-SMUX |
Not supported |
Supported |
Supported |
Supported |
Supported |
IM-SFMX |
Not supported |
Supported |
Supported |
Supported |
Supported |
IM-OAPX |
Not supported |
Supported |
Supported |
Supported |
Supported |
Table2-486 Compatibility matrix between switching fabric modules and service modules (2)
Service module |
CSFC-12B CSFC-12D |
CSFC-08E |
CSFC-08E1 |
CSFC-08E1A |
CSFC-16EA |
CSPC-GT48LA1 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-GE24L-E |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-GP24LA1 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-GP48LB |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-GP24XP2LB |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-GE16XP4L-E |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-GP44XP4LCX |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-XP2LA1 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-XP4LB |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-XP8LB |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-XP12LAX |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-XP12LCX |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-XP24LAX |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-XP24LCX |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-XLP6LCX |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-CP1LCX |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-CP2LB |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-CP4RX |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
CEPC-CP4RXA |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
CEPC-CP4RX-L |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
CEPC-CQ8L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-CQ8LA |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
CEPC-CQ8L1A |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
CEPC-CQ8L3A |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
CEPC-CQ16L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-DQ2L1-G |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
CEPC-XP4LX |
Supported |
Supported |
Supported |
Not supported |
Not supported |
CEPC-XP24LX |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
CEPC-XP48RX |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
CSPEX-1204 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1104-E |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1304X |
Supported |
Supported |
Supported |
Not supported |
Not supported |
CSPEX-1404X |
Supported |
Supported |
Supported |
Not supported |
Not supported |
CSPEX-1502X |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
CSPEX-1502XA |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
CSPEX-1504X |
Supported |
Supported |
Supported |
Not supported |
Not supported |
CSPEX-1504XA |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
CSPEX-1602X |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
CSPEX-1602XA |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
CSPEX-1802X |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
CSPEX-1802XA |
Not supported |
Not supported |
Supported |
Supported |
Supported |
CSPEX-1804X |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
CSPEX-1512X |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
CSPEX-1612X |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
CSPEX-1812X |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
CSPEX-1812X-E |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
CSPEX-2304X-G |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
CSPEX-2304X-LG |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
CSPEX-2612XA |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
CSPEX-2612X3A |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
CMPE-1104 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-SPE200 |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
RX-SPE200-E |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
IM-NGFWX-IV |
Supported |
Supported |
Supported |
Not supported |
Not supported |
LSU1FWCEA0 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
LSU3FWCEA0 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-IPSX-IV |
Supported |
Supported |
Supported |
Not supported |
Not supported |
LSU1IPSBEA0 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-ACG1000X-IV |
Supported |
Supported |
Supported |
Not supported |
Not supported |
LSU1ADECEA0 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-MSUX (1U) |
Supported |
Supported |
Supported |
Not supported |
Not supported |
IM-MSUX (1.2U) |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
IM-MSEX-B |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
IM-SMUX |
Supported |
Supported |
Supported |
Not supported |
Not supported |
IM-SFMX |
Supported |
Supported |
Supported |
Not supported |
Not supported |
IM-OAPX |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Table2-487 Compatibility matrix between switching fabric modules and service modules (3)
Service module |
CSFC-16E |
CSFC-12E |
CSFC-08T CSFC-16T CSFC-16T1 |
CSFC-08T-G |
CSFC-16T-G |
CSFC-10T-G CSFC-10E-G |
CSPC-GT48LA1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-GE24L-E |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-GP24LA1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-GP48LB |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-GP24XP2LB |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-GE16XP4L-E |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-GP44XP4LCX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-XP2LA1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-XP4LB |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-XP8LB |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-XP12LAX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-XP12LCX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-XP24LAX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-XP24LCX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-XLP6LCX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-CP1LCX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-CP2LB |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-CP4RX |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
CEPC-CP4RXA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-CP4RX-L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
CEPC-CQ8L |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
CEPC-CQ8LA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
CEPC-CQ8L1A |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-CQ8L3A |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-CQ16L1 |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
CEPC-DQ2L1-G |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
CEPC-XP4LX |
Supported |
Supported |
Supported |
Supported |
Supported |
Not supported |
CEPC-XP24LX |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
CEPC-XP48RX |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
CSPEX-1204 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1104-E |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1304X |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1404X |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1502X |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
CSPEX-1502XA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1504X |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1504XA |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1602X |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
CSPEX-1602XA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1802X |
Supported |
Not supported |
Supported |
Supported |
Not supported |
Supported |
CSPEX-1802XA |
Supported |
Not supported |
Supported |
Supported |
Not supported |
Supported |
CSPEX-1804X |
Supported |
Not supported |
Supported |
Supported |
Supported |
Not supported |
CSPEX-1512X |
Supported |
Not supported |
Supported |
Supported |
Supported |
Not supported |
CSPEX-1612X |
Supported |
Not supported |
Supported |
Supported |
Supported |
Not supported |
CSPEX-1812X |
Supported |
Not supported |
Supported |
Supported |
Supported |
Not supported |
CSPEX-1812X-E |
Supported |
Not supported |
Supported |
Supported |
Supported |
Not supported |
CSPEX-2304X-G |
Supported |
Not supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-2304X-LG |
Supported |
Not supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-2612XA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-2612X3A |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CMPE-1104 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-SPE200 |
Supported |
Not supported |
Supported |
Supported |
Supported |
Supported |
RX-SPE200-E |
Supported |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
IM-NGFWX-IV |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
LSU1FWCEA0 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
LSU3FWCEA0 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-IPSX-IV |
Supported |
Supported |
Supported |
Supported |
Supported |
Not supported |
LSU1IPSBEA0 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-ACG1000X-IV |
Supported |
Supported |
Supported |
Supported |
Supported |
Not supported |
LSU1ADECEA0 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-MSUX (1U) |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
IM-MSUX (1.2U) |
Supported |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
IM-MSEX-B |
Supported |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
IM-SMUX |
Supported |
Supported |
Supported |
Not supported |
Supported |
Not supported |
IM-SFMX |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-OAPX |
Supported |
Supported |
Supported |
Not supported |
Supported |
Supported |
Power supplies
The router supports the PSR1200B-12A, PSR1200B-12A1-F, LSUM1AC2500, PSR2500-12A, LSUM1DC2400, PSR2400-12D, PSR2400-D, PSR2500B-12AHD-F, PSR1600B-12A-B, and PSR2000-12D-B power supplies.
PSR1200B-12A
View
Figure2-16 PSR1200B-12A power supply view
(1) Captive screw |
(2) Power supply handle |
(3) Power input receptacle |
(4) Air inlet vent |
(5) Power output status LED |
(6) Power input status LED |
LEDs
Table2-488 PSR1200B-12A/LSUM1AC1200 LED description
LED mark |
Status |
AC |
Steady green |
The power supply system is operating correctly. |
Off |
No power input. |
The input voltage is too low and the power supply has entered self-protection state. |
DC |
Steady green |
Power output of the power supply system is normal. |
Steady red |
Power output of the power supply system is abnormal. The power supply has an output short circuit, output overcurrent, output overvoltage, input undervoltage, or remote shutdown alarm and has entered self-protection state. |
Steady amber |
An overtemperature alarm was triggered and the power supply has entered self-protection state. |
Table2-489 Technical specifications
Item |
41 × 102 × 410 mm (1.61 × 4.02 × 16.14 in) |
Weight |
2.27 kg (5.00 lb) |
Inputs |
1 |
Rated input voltage range |
100 VAC to 240 VAC @ 50 Hz or 60 Hz |
Input voltage range |
90 VAC to 290 VAC |
Maximum input current |
16 A |
Rated output voltage |
12 VDC |
Rated output current |
100 A |
Rated output power |
1200 W |
Front-level circuit breaker/fuse |
≥ 20 A |
Heat dissipation |
Built-in fans |
Power cable |
Standard C19 cable (3*1.5mm²) |
PSR1200B-12A1-F
View
Figure2-17 PSR1200B-12A1-F power supply view
(1) Captive screw |
LEDs
Table2-490 PSR1200B-12A1-F LED description
LED mark |
Status |
AC |
Steady green |
Off |
No power input. |
DC |
Steady green |
Steady red |
Steady amber |
Table2-491 Technical specifications
Item |
Weight |
2.27 kg (5.00 lb) |
Inputs |
1 |
200 VAC to 240 VAC @ 50 Hz or 60 Hz |
180 VAC to 264 VAC |
10 A |
12 VDC |
100 A |
1200 W |
≥ 20 A |
Heat dissipation |
Built-in fans |
Power cable |
Standard C13 cable (3*1.0mm²) |
PSR2500-12A/LSUM1AC2500
View
Figure2-18 PSR2500-12A power supply view
(1) Captive screw |
The views of the PSR2500-12A and LSUM1AC2500 power supplies are similar. This figure uses the PSR2500-12A as an example.
LEDs
Table2-492 PSR2500-12A/LSUM1AC2500 LED description
LED mark |
Status |
AC |
Steady green |
Off |
No power input. |
DC |
Steady green |
Steady red |
Steady amber |
Table2-493 Technical specifications
Item |
Weight |
2.50 kg (5.51 lb) |
Inputs |
1 |
· 100 VAC to 240 VAC @ 50 Hz or 60 Hz · 240 VDC |
· 90 VAC to 264 VAC · 190 VDC to 290 VDC |
16 A |
12 VDC |
· 100 A (100 VAC to 180 VAC input) · 208 A (180 VAC to 240 VAC or 240 VDC input) |
· 1200 W (100 VAC to 180 VAC input) · 2500 W (180 VAC to 240 VAC or 240 VDC input) |
≥ 20 A |
Heat dissipation |
Built-in fans |
Power cable |
PSR2400-12D/LSUM1DC2400
View
Figure2-19 PSR2400-12D power supply view
(1) Captive screw |
(3) Power input status LED |
(4) Power output status LED |
(5) DC input negative terminal (–) |
(6) DC input positive terminal (+) |
The views of the PSR2400-12D and LSUM1DC2400 power supplies are similar. This figure uses the PSR2400-12D as an example.
LEDs
Table2-494 PSR2400-12D/LSUM1DC2400 LED description
LED mark |
Status |
INP OK |
Steady green |
Off |
No power input. |
DC/FLT |
Steady green |
Steady red |
Steady amber |
Table2-495 Technical specifications
Item |
Weight |
2.40 kg (5.29 lb) |
Inputs |
1 |
–48 VDC to –60 VDC |
–36 V to –72 V |
78 A |
12 VDC |
200 A |
2400 W |
≥ 100 A |
Heat dissipation |
Built-in fans |
Power cable |
PWC01 2P cable |
PSR2400-D
View
Figure2-20 PSR2400-D power supply view
(1) Captive screw |
LEDs
Table2-496 PSR2400-D LED description
LED mark |
Status |
INP OK |
Steady green |
Off |
No power input. |
DC/FLT |
Steady green |
Steady red |
Steady amber |
Table2-497 Technical specifications
Item |
Weight |
2.40 kg (5.29 lb) |
Inputs |
1 |
–36 V to –72 V |
78 A |
12 VDC |
200 A |
2400 W |
≥ 100 A |
Heat dissipation |
Built-in fans |
Power cable |
ST M5 cable |
PSR2500B-12AHD-F
View
Figure2-21 PSR2500B-12AHD-F power supply view
(1) Captive screw |
(5) Power input status LED |
(6) Air inlet vent |
LEDs
Table2-498 PSR2500B-12AHD-F LED description
LED mark |
Status |
IN |
Steady green |
Off |
No power input. |
OUT |
Steady green |
Steady red |
Steady amber |
Table2-499 Technical specifications
Item |
Weight |
2.75 kg (6.06 lb) |
Inputs |
1 |
· 100 VAC to 240 VAC @ 50 Hz or 60 Hz · 240 VDC to 380 VDC |
· 90 VAC to 290 VAC · 180 VDC to 400 VDC |
16 A |
12 VDC |
· 100 A (90 VAC to 180 VAC input) · 208 A (180 VAC to 290 VAC or 180 VDC to 400 VDC input) |
· 1200 W (90 VAC to 180 VAC input) · 2500 W (180 VAC to 290 VAC or 180 VDC to 400 VDC input) |
≥ 20 A |
Heat dissipation |
Built-in fans |
Power cable |
Standard HVDCB cable (3*1.5mm²) |
PSR1600B-12A-B
View
Figure2-22 PSR1600B-12A-B power supply view
(1) Power supply handle |
(2) Power input receptacle |
(3) Latch |
(4) Power status LED |
LEDs
Table2-500 PSR1600B-12A-B LED description
LED status |
Steady green |
Flashing green (once per two seconds) |
The power supply has correct power input and is in standby state with 12 V standby output and without 12 V main output. |
Flashing green (twice per second) |
The power supply is upgrading software. |
Flashing green (once per three seconds) |
The power supply has entered cold redundancy state. |
Steady yellow |
The power supply is faulty and does not have power output. |
Flashing yellow (once per second) |
· The power supply is operating correctly, but an alarm has occurred (such as input undervoltage, output overcurrent, and overtemperature). · The power supply does not have power input, but the backup power supplies have correct power input. |
Off |
No power input. |
Table2-501 Technical specifications
Item |
40.2 × 73.5 × 225 mm (1.58 × 2.89 × 8.86 in) |
Weight |
1.85 kg (4.08 lb) |
Inputs |
1 |
· 90 VAC to 305 VAC · 100 VDC to 240 VDC |
10 A |
12 VDC |
· 65.5 A (100 to 175 VAC) · 131 A (175 to 240 VAC or 240 VDC) |
· 800 W (100 to 175 VAC) · 1600 W (175 to 240 VAC or 240 VDC) |
≥ 32 A |
Heat dissipation |
Built-in fans |
Power cable |
PSR2000-12D-B
View
Figure2-23 PSR2000-12D-B power supply view
(2) DC input negative terminal (+) |
(3) DC input negative terminal (–) |
(4) Latch |
(5) Power status LED |
LEDs
Table2-502 PSR2000-12D-B LED description
LED status |
Steady green |
Flashing green (once per second) |
Steady yellow |
Flashing yellow (once per two seconds) |
The power supply is operating correctly, but an alarm has occurred (such as input undervoltage, output overcurrent, and overtemperature). |
Off |
No power input. |
Table2-503 Technical specifications
Item |
Weight |
1.50 kg (3.31 lb) |
Inputs |
1 |
–48 VDC |
–40 VDC to –72 VDC |
60 A |
12 VDC |
167 A |
2000 W |
≥ 100 A |
Heat dissipation |
Built-in fans |
Power cable |
External DC power cords (6 AWG) |
· As a best practice, make sure the rated current of a single circuit breaker is not less than 1.2 times the maximum input current of the power supply.
· You can select a certain number of power supplies according to the power supply conditions at the installation site and actual power consumption of your router. Make sure the total maximum output power of the installed power supplies is greater than the system power consumption. As a best practice, reserve 20% of the maximum output power.
· Do not install power supplies of different models on the same router.
· When the temperature of a power supply exceeds the upper limit or drops below the lower limit, the power supply shuts down automatically. When the temperature falls into the normal range, the power supply starts up automatically.
Table2-504 Compatibility matrix between power supplies and routers (1)
Power supply module |
CR16006-F |
CR16010-F(one fan tray)/CR16010-F (dual fan trays) |
CR16010H-F (with four fabric modules), CR16010H-F (with five fabric modules) |
CR16010H-FA |
PSR1200B-12A |
l |
l |
l |
l |
PSR1200B-12A1-F |
l |
l |
l |
l |
LSUM1AC2500 |
l |
l |
l |
l |
PSR2500-12A |
l |
l |
l |
l |
LSUM1DC2400 |
l |
l |
l |
l |
PSR2400-12D |
l |
l |
l |
l |
PSR2400-D |
l |
l |
l |
l |
PSR2500B-12AHD-F |
l |
l |
l |
l |
PSR1600B-12A-B |
PSR2000-12D-B |
Table2-505 Compatibility matrix between power supplies and routers (2)
CR16014-F |
CR16018-F (with four fabric modules), CR16018-F (with five fabric modules) |
CR16018-FA |
PSR1200B-12A |
l |
l |
l |
PSR1200B-12A1-F |
l |
l |
l |
LSUM1AC2500 |
l |
l |
l |
PSR2500-12A |
l |
l |
l |
LSUM1DC2400 |
l |
l |
l |
PSR2400-12D |
l |
l |
l |
PSR2400-D |
l |
l |
l |
PSR2500B-12AHD-F |
l |
l |
l |
PSR1600B-12A-B |
l |
PSR2000-12D-B |
l |
NOTE: · "l" indicates that the power supply is compatible with the chassis. · "—" indicates that the power supply is not compatible with the chassis. |
Fan trays
The router came with fan trays installed. To replace a fan tray, make sure the new fan tray is compatible with the router.
CR16006-F fan tray
View
Figure2-24 CR16006-F fan tray view
(1) Captive screw |
(2) Status LED |
(3) Fan tray handle |
(4) Fan tray handle pivot |
(5) Fan |
LEDs
Table2-506 Fan tray LED description
LED status |
OK |
FAIL |
Steady on |
Off |
The fan tray is operating correctly. |
Off |
Steady on |
The fan tray is faulty. |
Off |
Off |
The fan tray is not powered on. |
Table2-507 Technical specifications
Item |
106 × 255 × 643 mm (4.17 × 10.04 × 25.32 in) |
Weight |
4.70 kg (10.36 lb) |
240 W |
190 W |
12 W |
Number of fans |
8 |
Fan diameter |
92 mm (3.62 in) |
Max fan speed |
6000 RPM |
Maximum air flow rate |
960 CFM (27.18 m3/min) |
CR16010-F (one fan tray) fan tray
View
Figure2-25 CR16010-F (one fan tray) fan tray view
(1) Fan |
(2) Status LED |
(3) Captive screw |
(4) Fan tray handle |
(5) Fan tray handle pivot |
LEDs
Table2-508 Fan tray LED description
LED status |
OK |
FAIL |
Steady on |
Off |
Off |
Steady on |
Off |
Off |
Table2-509 Technical specifications
Item |
80 × 440 × 654 mm (3.15 × 17.32 × 25.75 in) |
Weight |
8.30 kg (18.30 lb) |
300 W |
260 W |
13 W |
Number of fans |
12 |
Fan diameter |
120 mm (4.72 in) |
Max fan speed |
5200 RPM |
1152 CFM (32.62 m3/min) |
CR16010-F (dual fan trays) fan tray
View
Figure2-26 CR16010-F (dual fan trays) fan tray view
(1) Fan |
(2) Status LED |
(3) Captive screw |
LEDs
Table2-510 Fan tray LED description
LED status |
OK |
FAIL |
Steady on |
Off |
Off |
Steady on |
Off |
Off |
The CR16010-F (dual fan trays) has two fan trays, which are the same in technical specifications. Table2-511 describes the technical specifications of a single CR16010-F (dual fan trays) fan tray.
Table2-511 Technical specifications
Item |
49 × 440 × 654 mm (1.93 × 17.32 × 25.75 in) |
Weight |
7.40 kg (16.31 lb) |
320 W |
63 W |
18 W |
Number of fans |
12 |
Fan diameter |
120 mm (4.72 in) |
Max fan speed |
5200 RPM |
CR16010H-F/CR16010H-FA/CR16018-F/CR16018-FA fan trays
This section applies to the CR16010H-F (with five fabric modules), CR16010H-F (with four fabric modules), CR16010H-FA, CR16018-F (with five fabric modules), CR16018-F (with four fabric modules), and CR16018-FA routers.
View
Figure2-27 CR16010H-F (with five fabric modules) fan tray view
(1) Captive screw |
(2) Status LED |
(4) Fan |
The views of the CR16010H-F (with five fabric modules), CR16010H-F (with four fabric modules), CR16010H-FA, CR16018-F (with five fabric modules), CR16018-F (with four fabric modules), and CR16018-FA fan trays are similar. This figure uses the CR16010H-F (with five fabric modules) fan tray as an example.
LEDs
Table2-512 Fan tray LED description
RUN LED status |
Steady green |
Steady red |
One or more fans in the fan tray have failed or the fan tray is not in position. |
Off |
The CR16010H-F (with five fabric modules), CR16010H-F (with four fabric modules), and CR16010H-FA routers each have eight fan trays. The CR16018-F (with five fabric modules), CR16018-F (with four fabric modules), and CR16018-FA routers each have 15 fan trays. The fan trays have the same technical specifications. Table2-513 describes the technical specifications of a single CR16010H-F (with five fabric modules) fan tray.
Table2-513 Technical specifications
Item |
191 × 81 × 159 mm (7.52 × 3.19 × 6.26 in) |
Weight |
1.35 kg (2.98 lb) |
143 W |
114 W |
18 W |
Number of fans |
2 |
Fan diameter |
80 mm (3.15 in) |
Max fan speed |
12800 RPM |
350 CFM (9.91 m3/min) |
CR16014-F fan tray
View
Figure2-28 CR16014-F fan tray view
(1) Captive screw |
(2) Status LED |
(5) Fan |
LEDs
Table2-514 Fan tray LED description
LED status |
OK |
FAIL |
Steady on |
Off |
Off |
Steady on |
Off |
Off |
Table2-515 Technical specifications
Item |
84 × 301 × 646 mm (3.31 × 11.85 × 25.43 in) |
Weight |
· Upper fan tray: 4.49 kg (9.90 lb) · Lower fan tray: 3.61 kg (7.96 lb) |
· Upper fan tray: 190 W · Lower fan tray: 110 W |
· Upper fan tray: 160 W · Lower fan tray: 100 W |
· Upper fan tray: 9 W · Lower fan tray: 7 W |
Number of fans |
· Upper fan tray: 8 · Lower fan tray: 4 |
Fan diameter |
120 mm (4.72 in) |
Max fan speed |
5200 RPM |
· Upper fan tray: 1040 CFM (29.45 m3/min) · Lower fan tray: 720 CFM (20.39 m3/min) |
CR16005E-F fan tray
View
Figure2-29 CR16005E-F fan tray view
(1) Status LED |
(2) Captive screw |
(3) Fan tray handle pivot |
(5) Fan |
LEDs
Table2-516 Fan tray LED description
RUN LED status |
Steady green |
Steady red |
Off |
The CR16005E-F has two fan trays, which are the same in technical specifications. Table2-517 describes the technical specifications of a single CR16005E-F fan tray.
Table2-517 Technical specifications
Item |
247.5 × 111 × 105 mm (9.74 × 4.37 × 4.13 in) |
Weight |
2.05 kg (4.52 lb) |
142 W |
102 W |
7 W |
Number of fans |
3 |
Fan diameter |
80 mm (3.15 in) |
Max fan speed |
15200 RPM |
390 CFM (11.04 m3/min) |
CR16010E-F fan tray
View
Figure2-30 CR16010E-F fan tray view
(1) Captive screw |
(2) Status LED |
(4) Fan |
LEDs
Table2-518 Fan tray LED description
RUN LED status |
Steady green |
Steady red |
Off |
The CR16010E-F has two fan trays, which are the same in technical specifications. Table2-519 describes the technical specifications of a single CR16010E-F fan tray.
Table2-519 Technical specifications
Item |
571.5 × 93.2 × 162 mm (22.5 × 3.67 × 6.38 in) |
Weight |
4.25 kg (9.37 lb) |
284 W |
204 W |
14 W |
Number of fans |
6 |
Fan diameter |
80 mm (3.15 in) |
Max fan speed |
15200 RPM |
780 CFM (22.09 m3/min) |
Air filters
CAUTION: Clean air filters periodically (once or more times every three months) to guarantee adequate ventilation and to avoid overtemperature. |
To prevent dusts from entering the chassis, you can configure air filters for the router as needed and install them at the air intakes.
H3C CR16000-F air filters include the CR16006-F air filter, CR16010-F air filter, and CR16014-F air filter. Order air filters compatible with your router.
Slide rails
Before rack-mounting the router, install slide rails on the rack.
LSXM1BSR
Figure2-31 LSXM1BSR slide rail view
(1) Positioning tongue |
(2) Slide rail installation hole |
(3) Front plate installation hole |
(4) Sign |
(5) Guide rail |
Figure2-32 Front plate
(1) Installation hole |
Table2-520 Technical specifications
Item |
Maximum loading capacity |
650 kg (1432.98 lb) |
Adjustment range |
630 to 900 mm (24.80 to 35.43 in) |
Occupied rack space |
1 RU |
LSTM1KSGD0
Figure2-33 LSTM1KSGD0 slide rail view
(2) Sign |
(3) Guide rail |
Table2-521 Technical specifications
Item |
280 kg (617.28 lb) |
Adjustment range |
300 to 500 mm (11.81 to 19.69 in) |
2 RUs |
LSTM2KSGD0
Figure2-34 LSTM2KSGD0 slide rail view
(2) Sign |
(3) Guide rail |
Table2-522 Technical specifications
Item |
400 kg (881.83 lb) |
Adjustment range |
500 to 800 mm (19.69 to 31.50 in) |
2 RUs |
RL-1U-A
Figure2-35 RL-1U-A slide rail view
(4) Sign |
(5) Guide rail |
Figure2-36 Front plate
Table2-523 Technical specifications
Item |
200 kg (440.92 lb) |
Adjustment range |
380 to 630 mm (14.96 to 24.80 in) |
1 RU |
· Select slide rails for the router based on the chassis weight.
· To rack-mount a CR16018-F (with four fabric modules), CR16018-F (with five fabric modules), or CR16018-FA router, reserve a 2 RU space between the router (including slide rails) and the rack bottom.
Table2-524 Chassis weights and applicable slide rails
Model |
Chassis weight (fully configured) |
Applicable slide rails |
CR16006-F |
76 kg (167.55 lb) |
LSXM1BSR LSTM1KSGD0 LSTM2KSGD0 |
CR16010-F (one fan tray) |
120 kg (264.55 lb) |
170 kg (374.78 lb) |
SR8812-F |
95 kg (209.44 lb) |
CR16010H-F (with four fabric modules), CR16010H-F (with five fabric modules), CR16010H-FA |
245 kg (540.12 lb) |
CR16014-F |
174 kg (383.60 lb) |
CR16018-F (with four fabric modules), CR16018-F (with five fabric modules), CR16018-FA |
440 kg (970.02 lb) |
LSXM1BSR LSTM2KSGD0 |
CR16005E-F |
100 kg (220.46 lb) |
LSXM1BSR RL-1U-A |
CR16010E-F |
LSXM1BSR RL-1U-A |
DC power cords
DC power cords are used for connecting the DC power supplies of an SR8800-X router to the external DC power supply system.
Table2-525 DC power cord specifications
DC power cord |
Cable length |
0404A0E1 |
3 m (9.84 ft) |
Used for connecting the LSUM1DC2400/PSR2400-12D power supply |
0404A0H8 |
3 m (9.84 ft) |
0404A0E2 |
15 m (49.21 ft) |
0404A0H9 |
15 m (49.21 ft) |
0404A1BE |
20 m (65.62 ft) |
0404A1BF |
20 m (65.62 ft) |
0404A0J5 |
30 m (98.43 ft) |
0404A1BD |
40 m (131.23 ft) |
0404A1M7 |
10 m (32.81 ft) |
Used for connecting the PSR2400-D power supply |
0404A1M6 |
15 m (49.21 ft) |
0404A1M5 |
20 m (65.62 ft) |
0404A1MD |
30 m (98.43 ft) |
0404A1X2 |
3 m (9.84 ft) |
Used for connecting the PSR2000-12D-B power supply |
0404A1X3 |
15 m (49.21 ft) |
AC power cords
AC power cords are used for connecting the AC power supplies of a CR16000-F router to the external AC power supply system.
To select an AC power cord for an AC power supply, consider the following items:
· Power capacity of the power supply.
· Current-carrying capacity of the power cord.
· Region-and country-specific plug type.
The AC power supplies available for the router require a 16A AC power cord. Table2-526 describes the region-and country-specific plug types for 16A AC power cords.
Table2-526 16A AC power cords used in different countries or regions
1 |
Plug type |
Code (Length) |
Countries or regions where the type of power cords conforms to local safety regulations and can be used legally |
Other countries or regions using this type of power cords |
Countries or regions seldom using this type of power cords |
I type |
04043396: 3 m (9.8 ft) |
Mainland China |
N/A |
N/A |
Plug outline |
Power cord outline |
Connector outline |
2 |
Plug type |
Code (Length) |
C20 type |
0404A0C2: 3 m (9.8 ft) |
Mainland China |
N/A |
N/A |
Plug outline |
Connector outline |
3 |
Plug type |
Code (Length) |
B type |
0404A063: 3 m (9.8 ft) |
Canada and U.S.A |
Mexico, Argentina, Brazil, Columbia, Venezuela, Thailand, Peru, Philippine, and A6 countries or regions |
N/A |
Plug outline |
Connector outline |
4 |
Plug type |
Code (Length) |
F type |
0404A061: 3 m (9.8 ft) |
Holland, Denmark, Sweden, Finland, Norway, Germany, France, Austria, Belgium, and Italy |
Indonesia, Türkiye, Russia, and CIS |
N/A |
Plug outline |
Connector outline |
5 |
Plug type |
Code (Length) |
B type |
0404A062: 3 m (9.8 ft) |
Japan |
N/A |
N/A |
Connector outline |
Connector outline |
6 |
Plug type |
Code (Length) |
I type |
0404A01A: 3 m (9.8 ft) |
Australia |
N/A |
N/A |
Plug outline |
Connector outline |
7 |
Plug type |
Code (Length) |
I type |
0404A0RQ: 3 m (9.8 ft) |
Mainland China |
N/A |
N/A |
Plug outline |
Connector outline |
8 |
Plug type |
Code (Length) |
I type |
04041104: 3 m (9.8 ft) |
Mainland China |
N/A |
N/A |
Plug outline |
Connector outline |
