- H3C G6 Servers Storage Controller User Guide-6W100
- 01-Storage controller overview
- 02-Storage controller features
- 03-Configuring a VROC SATA RAID controller
- 04-Configuring an NVMe VROC module
- 05-Configuring an LSI-9540 or 9560 storage controller
- 06-Configuring a P460, P2404 or P4408 storage controller
- 07-Configuring an LSI 9500 series storage controller
- 08-Configuring a RAID-MARVELL-SANTACRUZ-LP-2i storage controller
- 09-Configuring a RAID-MARVELL-M.2 storage controller
- 10-Appendix A Troubleshooting storage controllers
- 11-Appendix B RAID arrays and fault tolerance
| 01-Storage controller overview | 33.27 KB |
The information in this document might differ from your product if it contains custom configuration options or features. The following information is subject to change over time. For the most up-to-date information, contact H3C Support.
The software screenshots used in this document are for illustration only and might differ from your products or versions.
The model name of a hardware option in this document might differ slightly from its model name label.
A model name label might add a prefix or suffix to the hardware-coded model name for purposes such as identifying the matching server brand, applicable region, or capacity. For example, the RAID-LSI-9560-LP-16i-8GB or LSI-9560 storage controller model represents the storage controller model name label UN-RAID-LSI-9560-LP-16i-8GB-M.
Storage controllers provide powerful I/O transmission and bandwidth processing capabilities and support various RAID expansions to improve system performance. With support for multi-disk fragment storage of data and data read/write concurrency over multiple disks, storage controllers effectively reduce disk access delay and can meet RAID requirements in various scenarios.
Applicable servers
This document is applicable to the following servers:
· H3C UniServer R4700 G6
· H3C UniServer R4700LE G6
· H3C UniServer R4900LE G6 Ultra
· H3C UniServer R4900 G6 Ultra
· H3C UniServer R4950 G6
· H3C UniServer R5300 G6
· H3C UniServer R5350 G6
· H3C UniServer R5500 G6
· H3C UniServer R6700 G6
· H3C UniServer R6900 G6
For information about storage controller and server compatibility, contact Technical Support.
Technical specifications
For technical specifications of storage controllers, see H3C Servers Storage Controllers Technical Specifications.
Operating systems
For operating systems supported by storage controllers, contact Technical Support.
Configuration methods
Table 1 RAID configuration methods
RAID configuration method |
Whether services are affected |
Application scenarios |
Reference |
Configure RAID from the BIOS text or graphical interface |
Yes |
Applicable to all RAID configuration scenarios |
H3C Servers Storage Controllers User Guide |
Configure RAID simultaneously when the OS is installed from the iFIST interface |
Yes |
Applicable to the scenario where iFIST is used to configure RAID in the OS installation process for a single server. For the available storage controllers, see H3C Servers iFIST User Guide. |
H3C Servers iFIST User Guide |
Configure RAID from the HDM2 interface. |
No |
Applicable to the scenario where service continuity must be guaranteed during the RAID configuration process. For the available storage controllers, see H3C Servers HDM2 User Guide. |
H3C Servers HDM2 User Guide |
Configure a template with RAID settings and then apply the template to the server from the FIST interface. |
Yes |
Applicable to the scenario to configure RAID for multiple servers in batch. For the available storage controllers, see H3C Servers FIST User Guide. |
H3C Servers FIST User Guide |
Use command lines or a third-party tool to configure RAID in the OS. |
No |
Applicable to the following scenarios · Use ARCCONF Command Line Utility to configure RAID with a PMC storage controller. · Use StorCLI to configure RAID with an LSI storage controller. · Use Intel VROC 6.0 PV GUI to configure RAID with a VROC module in a Windows operating system. · Use command lines to configure RAID with a VROC module in a Linux operating system. |
For more information about common functions, see H3C Servers Storage Controllers User Guide. For detailed information, see the tool user guide from third parties. |
