| 04-802.1X commands | 348.92 KB |
dot1x { ip-verify-source | ipv6-verify-source } enable
dot1x after-mac-auth max-attempt
dot1x duplicate-eapol-start discard
dot1x eap-tls-fragment to-server
dot1x re-authenticate server-unreachable keep-online
dot1x server-recovery online-user-sync
dot1x unauthenticated-user aging enable
802.1X commands
display dot1x
Use display dot1x to display information about 802.1X.
display dot1x [ sessions | statistics ] [ ap ap-name [ radio radio-id ] | interface interface-type interface-number ]
sessions: Displays 802.1X session information.
statistics: Displays 802.1X statistics.
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by AP model. If you do not specify a radio, this command displays 802.1X information for all radios on the specified AP.
interface interface-type interface-number: Specifies a port by its type and number.
If you do not specify the sessions keyword or the statistics keyword, this command displays all information about 802.1X, including session information, statistics, and settings.
If you do not specify the ap ap-name [ radio radio-id ] option or the interface interface-type interface-number option, this command displays all 802.1X information, including wired 802.1X information and wireless 802.1X information.
# Display all information about 802.1X.
<Sysname> display dot1x
Global 802.1X parameters:
802.1X authentication : Enabled
M-LAG member configuration conflict : Unknown
EAP authentication : Enabled
Max-tx period : 30 s
Handshake period : 15 s
Offline detect period : 300 s
Quiet timer : Disabled
Quiet period : 60 s
Supp timeout : 30 s
Server timeout : 100 s
Reauth period : 3600 s
Max auth requests : 2
User aging period for Auth-Fail VLAN : 1000 s
User aging period for critical VLAN : 1000 s
User aging period for guest VLAN : 1000 s
EAD assistant function : Disabled
URL : http://www.dwsoft.com
Free IP : 6.6.6.0 255.255.255.0
EAD timeout : 30 min
Domain delimiter : @
Max EAP-TLS fragment (to-server) : 400 bytes
Online 802.1X wired users : 1
Online 802.1X wireless users : 1
GigabitEthernet1/0/1 is link-up
Handshake : Enabled
Handshake reply : Disabled
Handshake security : Disabled
Offline detection : Disabled
Unicast trigger : Disabled
Periodic reauth : Disabled
Port role : Authenticator
Authorization mode : Auto
Port access control : MAC-based
Multicast trigger : Enabled
Mandatory auth domain : Not configured
Guest VLAN : 3
Auth-Fail VLAN : Not configured
Critical VLAN : Not configured
Critical voice VLAN : Disabled
Add Guest VLAN delay : Disabled
Max online users : 4294967295
User IP freezing : Disabled
Reauth period : 0 s
Send Packets Without Tag : Disabled
Max Attempts Fail Number : 0
User aging : Enabled
Server-recovery online-user-sync : Enabled
Auth-Fail EAPOL : Disabled
Critical EAPOL : Disabled
Discard duplicate EAPOL-Start : No
EAPOL packets: Tx 3, Rx 3
Sent EAP Request/Identity packets : 1
EAP Request/Challenge packets: 1
EAP Success packets: 1
EAP Failure packets: 0
Received EAPOL Start packets : 1
EAPOL LogOff packets: 1
EAP Response/Identity packets : 1
EAP Response/Challenge packets: 1
Error packets: 0
Online 802.1X users: 1
MAC address Auth state
0001-0000-0000 Authenticated
AP name: AP1 Radio ID: 1 SSID: wlan_dot1x_ssid
BSSID : 1111-1111-1111
Handshake : Enabled
Max online users : 256
Error packets: 0
0001-0000-0002 Authenticated
Global 802.1X parameters |
Global 802.1X configuration. |
802.1X authentication |
Whether 802.1X is enabled globally. |
M-LAG member configuration conflict |
This field is not supported in the current software version. M-LAG member configuration check result: · Conflicted—The configuration on one M-LAG member device conflicts with that on the other M-LAG member device. · Not conflicted—The configuration on one M-LAG member device does not conflict with that on the other M-LAG member device. · Unknown—The system cannot detect whether the configuration on one M-LAG member device conflicts with that on the other M-LAG member device. |
CHAP authentication |
Performs EAP termination and uses CHAP to communicate with the RADIUS server. |
EAP authentication |
Relays EAP packets and supports any of the EAP authentication methods to communicate with the RADIUS server. |
PAP authentication |
Performs EAP termination and uses PAP to communicate with the RADIUS server. |
Max-tx period |
Username request timeout timer in seconds. |
Handshake period |
Handshake timer in seconds. |
Offline detect period |
Offline detect timer in seconds. |
Quiet timer |
Status of the quiet timer, enabled or disabled. |
Quiet period |
Quiet timer in seconds. |
Supp timeout |
Client timeout timer in seconds. |
Server timeout |
Server timeout timer in seconds. |
Reauth period |
Periodic reauthentication timer in seconds. |
Max auth requests |
Maximum number of attempts for sending an authentication request to a client. |
User aging period for Auth-Fail VLAN |
Aging timer in seconds for users in Auth-Fail VLANs. |
User aging period for critical VLAN |
Aging timer in seconds for users in critical VLANs. |
User aging period for guest VLAN |
Aging timer in seconds for users in guest VLANs. |
EAD assistant function |
Whether EAD assistant is enabled. |
URL |
Redirect URL for unauthenticated users using a Web browser to access the network. |
Free IP |
Network segment accessible to unauthenticated users. |
EAD timeout |
EAD rule timer in minutes. |
Domain delimiter |
Domain delimiters supported by the device. |
Max EAP-TLS fragment (to-server) |
Maximum size of EAP-TLS fragments sent in authentication packets to the server. If no maximum size is set, this field displays N/A. |
Online 802.1X wired users |
Number of wired online 802.1X users, including users that have passed 802.1X authentication and users that are performing 802.1X authentication. |
Online 802.1X wireless users |
Number of wireless online 802.1X users, including users that have passed 802.1X authentication and users that are performing 802.1X authentication. |
GigabitEthernet1/0/1 is link-up |
Status of the port. In this example, GigabitEthernet 1/0/1 is up. |
Whether 802.1X is enabled on the port. |
Handshake |
Whether the online user handshake feature is enabled on the port. |
Handshake reply |
Whether the online user handshake reply feature is enabled on the port. |
Handshake security |
Whether the online user handshake security feature is enabled on the port. |
Offline detection |
Status of 802.1X offline detection: · Enabled—This feature is enabled and effective. · Disabled—This feature is disabled. · Enabled(NOT effective)—This feature is enabled but it does not take effect. This state is displayed when the port access control mode is port-based. |
Unicast trigger |
Whether the 802.1X unicast trigger is enabled on the port. |
Periodic reauth |
Whether 802.1X periodic reauthentication is enabled on the port. |
Port role |
Role of the port. The port functions only as an Authenticator. |
Authorization mode |
Authorization state of the port, which can be Force-Authorized, Auto, or Force-Unauthorized. |
Port access control |
Access control method of the port: · MAC-based—MAC-based access control. · Port-based—Port-based access control. |
Multicast trigger |
Whether the 802.1X multicast trigger feature is enabled. |
Mandatory auth domain |
Mandatory authentication domain on the port. |
Guest VLAN |
802.1X guest VLAN configured on the port. If no 802.1X guest VLAN is configured on the port, this field displays Not configured. |
Auth-Fail VLAN |
802.1X Auth-Fail VLAN configured on the port. If no 802.1X Auth-Fail VLAN is configured on the port, this field displays Not configured. |
Critical VLAN |
802.1X critical VLAN configured on the port. If no 802.1X critical VLAN is configured on the port, this field displays Not configured. |
Critical voice VLAN |
This field is not supported in the current version.. Whether the 802.1X critical voice VLAN feature is enabled on the port. |
Add Guest VLAN delay |
Status and mode of the 802.1X guest VLAN assignment delay feature on a port: · EAPOL—EAPOL-triggered 802.1X guest VLAN assignment delay is enabled. · NewMac—New MAC-triggered 802.1X guest VLAN assignment delay is enabled. · ALL—Both EAPOL-triggered and new MAC-triggered 802.1X guest VLAN assignment delays are enabled. · Disabled—802.1X guest VLAN assignment delay is disabled. |
Re-auth server-unreachable |
Whether to log off online 802.1X users or keep them online when no server is reachable for 802.1X reauthentication. |
Max online users |
Maximum number of concurrent 802.1X users on the port. |
User IP freezing |
Whether user IP freezing is enabled on the port. |
Reauth period |
Periodic reauthentication timer in seconds on the port. |
Send Packets Without Tag |
Whether to remove the VLAN tags of all 802.1X protocol packets sent out of the port to 802.1X clients. |
Max Attempts Fail Number |
Maximum number of 802.1X authentication attempts for MAC authenticated users. |
User aging |
Status of 802.1X unauthenticated user aging on a port: · Enabled. · Disabled. |
Server-recovery online-user-sync |
Status of 802.1X online user synchronization: · Enabled. · Disabled. |
Auth-Fail EAPOL |
This field displays whether the device sends EAP-Success packets to 802.1X clients on their assignment to the 802.1X Auth-Fail VLAN on the port. Options: · Enabled. · Disabled. |
Critical EAPOL |
This field displays whether the device sends EAP-Success packets to 802.1X clients on their assignment to the 802.1X critical VLAN on the port. Options: · Enabled. · Disabled. |
Discard duplicate EAPOL-Start |
Whether the device discards duplicate EAPOL-Start requests on the port. Options: · Yes—Discard. · No—Not discard. |
EAPOL packets |
Number of sent (Tx) and received (Rx) EAPOL packets. |
Sent EAP Request/Identity packets |
Number of sent EAP-Request/Identity packets. |
EAP Request/Challenge packets |
Number of sent EAP-Request/MD5-Challenge packets. |
EAP Success packets |
Number of sent EAP-Success packets. |
EAP Failure packets |
Number of sent EAP-Failure packets. |
Received EAPOL Start packets |
Number of received EAPOL-Start packets. |
EAPOL LogOff packets |
Number of received EAPOL-LogOff packets. |
EAP Response/Identity packets |
Number of received EAP-Response/Identity packets. |
EAP Response/Challenge packets |
Number of received EAP-Response/MD5-Challenge packets. |
Error packets |
Number of received error packets. |
Online 802.1X users |
Number of online 802.1X users on the port, including users that have passed 802.1X authentication and users that are performing 802.1X authentication. |
MAC address |
MAC addresses of the online 802.1X users. |
Auth state |
Authentication status of the online 802.1X users. |
AP name |
Name of the AP with which users are associated. |
Radio ID |
ID of the radio with which users are associated. |
SSID |
SSID with which users are associated. |
BSSID |
ID of the BSS with which users are associated. |
display dot1x connection
Use display dot1x connection to display information about online 802.1X users.
display dot1x connection [ open ] [ ap ap-name [ radio radio-id ] | interface interface-type interface-number | user-mac mac-address | user-name name-string ]
open: Displays information only about 802.1X users that use nonexistent usernames or incorrect passwords for network access in open authentication mode. If you do not specify this keyword, the command displays information about all online 802.1X users.
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-). If you do not specify an AP, this command displays information about online 802.1X users for all APs.
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by AP model. If you do not specify a radio, this command displays information about online 802.1X users for all radios on the specified AP.
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command displays online 802.1X user information for all ports.
user-mac mac-address: Specifies an 802.1X user by MAC address. The mac-address argument represents the MAC address of the user, in the form of H-H-H. If you do not specify an 802.1X user, this command displays all online 802.1X user information.
user-name name-string: Specifies an 802.1X user by its name. The name-string argument represents the username, a case-sensitive string of 1 to 253 characters. If you do not specify an 802.1X user, this command displays all online 802.1X user information.
# Display information about all online 802.1X users.
<Sysname> display dot1x connection
Total connections: 2
Username: ias
User access state: Successful
Authentication domain: aaa
IPv4 address: 192.168.1.1
Authentication method: CHAP
Initial VLAN: 1
Authorization untagged VLAN: 6
Authorization tagged VLAN list: 1 to 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 29 31 33
35 37 40 to 100
Authorization CAR:
Average input rate: 102400
Peak input rate: 204800
Average output rate: 102400
Peak output rate: 204800
Authorization URL: N/A
Termination action: Default
Session timeout period: 2 s
Online from: 2020/01/02 13:14:15
Online duration: 0h 2m 15s
User MAC address : 0015-e9a6-7cfe
AP name : ap1
Radio ID : 1
SSID : wlan_dot1x_ssid
BSSID : 0015-e9a6-7cf0
User name : ias
Authentication domain : 1
IPv4 address : 192.168.1.1
IPv6 address : 2000:0:0:0:1:2345:6789:abcd
Authentication method : CHAP
Initial VLAN : 1
Authorization VLAN : N/A
Authorization ACL number : 3001
Authorization user profile : N/A
Authorization CAR : N/A
Authorization URL : http://oauth.h3c.com
Authorization IPv6 URL : N/A
Termination action : Default
Session timeout period : 2 sec
Online from : 2020/01/02 13:14:15
Online duration : 0 h 2 m 15 s
Total connections |
Number of online 802.1X users. |
User MAC address |
MAC address of the user. |
Access interface |
Interface through which the user access the device. |
AP name |
Name of the AP with which the user is associated. |
Radio ID |
ID of the radio with which the user is associated. |
SSID |
SSID with which the user is associated. |
BSSID |
ID of the BSS with which the user is associated. |
User access state |
Access state of the user. · Successful—The user passes 802.1X authentication and comes online. · Open—The user uses a nonexistent username or an incorrect password to come online in open authentication mode. |
Authentication domain |
ISP domain used for 802.1X authentication. |
IPv4 address |
IPv4 address of the user. If the device does not get the IPv4 address of the user, this field is not available. |
IPv6 address |
IPv6 address of the user. If the device does not get the IPv6 address of the user, this field is not available. |
Authentication method |
EAP message handling method: · CHAP—Performs EAP termination and uses CHAP to communicate with the RADIUS server. · EAP—Relays EAP packets and supports any of the EAP authentication methods to communicate with the RADIUS server. · PAP—Performs EAP termination and uses PAP to communicate with the RADIUS server. |
Initial VLAN |
VLAN to which the user belongs before 802.1X authentication. |
Authorization untagged VLAN |
Untagged VLAN authorized to the user. |
Authorization tagged VLAN list |
Tagged VLANs authorized to the user. |
Authorization ACL number/name |
Number or name of the ACL authorized to the user. If no authorization ACL has been assigned, this field displays N/A. If the ACL authorization fails, this field displays (Not effective) next to the ACL. |
Authorization user profile |
User profile authorized to the user. |
Authorization CAR |
Authorization CAR attributes assigned by the server. · Average input rate—Average rate of inbound traffic in bps. · Peak input rate—Peak rate of inbound traffic in bps. · Average output rate—Average rate of outbound traffic in bps. · Peak output rate—Peak rate of outbound traffic in bps. If the device fails to assign the CAR attributes to the user, the Authorization CAR field displays (NOT effective). If the server does not assign the peak rates, the peak rates by default are the same as the assigned average rates. In the current software version, the device does not support exclusive assignment of peak rates from the server. If no authorization CAR attributes are assigned, this field displays N/A. |
Authorization URL |
Redirect URL authorized to the user. |
Authorization IPv6 URL |
Redirect IPv6 URL authorized to the user. |
Termination action |
Action attribute assigned by the server to terminate the user session: · Default—Logs off the online authenticated 802.1X user when the server-assigned session timeout timer expires. This attribute does not take effect when 802.1X periodic reauthentication is enabled and the periodic reauthentication timer is shorter than the server-assigned session timeout timer. · Radius-request—Reauthenticates the online user when the server-assigned session timeout timer expires, regardless of whether the 802.1X periodic reauthentication feature is enabled or not. If the device performs local authentication, this field displays Default. |
Session timeout period |
Session timeout timer assigned by the server. |
Online from |
Time from which the 802.1X user came online. |
Online duration |
Online duration of the 802.1X user. |
display dot1x mac-address
Use display dot1x mac-address to display the MAC addresses of 802.1X users in a type of 802.1X microsegment or VLAN.
display dot1x mac-address { auth-fail-vlan | critical-vlan | guest-vlan } [ interface interface-type interface-number ]
auth-fail-vlan: Specifies 802.1X Auth-Fail VLANs.
critical-vlan: Specifies 802.1X critical VLANs.
guest-vlan: Specifies 802.1X guest VLANs.
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command displays the MAC addresses of 802.1X users in the specified type of 802.1X micorsegment or VLAN on all ports.
The displayed MAC addresses and MAC address count might not include all MAC addresses if a large number of 802.1X users are performing authentication frequently.
# Display the MAC addresses of 802.1X users in the 802.1X Auth-Fail VLANs on all ports.
<Sysname> display dot1x mac-address auth-fail-vlan
Total MAC addresses: 10
Interface: GigabitEthernet1/0/1 Auth-Fail VLAN: 3 Aging time: N/A
MAC addresses: 8
0800-2700-9427 0800-2700-2341 0800-2700-2324 0800-2700-2351
0800-2700-5627 0800-2700-2251 0800-2700-8624 0800-2700-3f51
Interface: GigabitEthernet1/0/2 Auth-Fail VLAN: 5 Aging time: 30 sec
MAC addresses: 2
0801-2700-9427 0801-2700-2341
Total MAC addresses |
Total number of MAC addresses in the specified type of microsegment or VLAN on the specified port or all ports. |
Access port of 802.1X users. |
Type microsegment/VLAN |
VLAN that contains the 802.1X users. Available VLAN types: · Auth-Fail VLAN. · Critical VLAN. · Guest VLAN. |
MAC address aging time in seconds. This field displays N/A if the MAC addresses do not age out. |
MAC addresses |
Number of matching MAC addresses on a port. |
xxxx-xxxx-xxxx |
MAC address. |
dot1x auth-fail vlan
dot1x critical vlan
dot1x guest-vlan
dot1x
Use dot1x to enable 802.1X globally or on a port.
Use undo dot1x to disable 802.1X globally or on a port.
dot1x
undo dot1x
802.1X is neither enabled globally nor enabled for any port.
For the 802.1X feature to take effect on a port, you must enable the feature both globally and on the port.
# Enable 802.1X globally.
[Sysname] dot1x
# Enable 802.1X on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x
display dot1x
Use dot1x { ip-verify-source | ipv6-verify-source } enable to enable generation of dynamic IPv4SG or IPv6SG binding entries for 802.1X authenticated users.
Use undo dot1x { ip-verify-source | ipv6-verify-source } enable to disable generation of dynamic IPv4SG or IPv6SG binding entries for 802.1X authenticated users.
Generation of dynamic IPv4SG or IPv6SG binding entries for 802.1X authenticated users is enabled.
IMPORTANT: This feature must operate in conjunction with the IP source guard (IPSG) feature. |
The dot1x { ip-verify-source | ipv6-verify-source } enable command takes effect only on 802.1X users that come online after the command is used. If the IP address of an online 802.1X user changes, the device will update the dynamic IPv4SG or IPv6SG binding entry for the user.
The undo dot1x { ip-verify-source | ipv6-verify-source } enable command does not delete the existing dynamic IPv4SG or IPv6SG binding entries for online 802.1X users. If the IP address of an online 802.1X user changes after the command is used, the device will delete the dynamic IPv4SG or IPv6SG binding entry for the user.
# Disable generation of dynamic IPv4SG or IPv6SG binding entries for 802.1X authenticated users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] undo dot1x ip-verify-source enable
dot1x access-user log enable
Use dot1x access-user log enable to enable 802.1X user logging.
Use undo dot1x access-user log enable to disable 802.1X user logging.
dot1x access-user log enable [ abnormal-logoff | failed-login | normal-logoff | successful-login ] *
undo dot1x access-user log enable [ abnormal-logoff | failed-login | normal-logoff | successful-login ] *
802.1X user logging is disabled.
abnormal-logoff: Logs exceptional logoffs of 802.1X users, such as logoffs caused by real-time accounting failures or reauthentication failures.
failed-login: Logs 802.1X user login failures.
normal-logoff: Logs logoffs requested by 802.1X users.
successful-login: Logs successful 802.1X user logins.
To prevent excessive 802.1X user log entries, use this feature only if you need to analyze abnormal 802.1X user logins or logouts.
If you do not specify any parameters, this command enables all types of 802.1X user logs.
# Enable logging 802.1X user login failures.
[Sysname] dot1x access-user log enable failed-login
info-center source dot1x logfile deny (System Management Command Reference)
Use dot1x after-mac-auth max-attempt to set the maximum number of 802.1X authentication attempts for MAC authenticated users on a port.
Use undo dot1x after-mac-auth max-attempt to restore the default.
dot1x after-mac-auth max-attempt max-attempts
The number of 802.1X authentication attempts for MAC authenticated users is not limited on a port.
max-attempts: Specifies a number in the range of 1 to 50.
The device denies 802.1X authentication requests of a MAC authenticated user after the maximum number of 802.1X authentication attempts has been made.
The device will recount the number of 802.1X authentication attempts made by a MAC authenticated user if a user logoff or device reboot event occurs.
# Configure GigabitEthernet 1/0/1 to allow a maximum of 10 802.1X authentication attempts made by a MAC authenticated user.
[Sysname-GigabitEthernet1/0/1] dot1x after-mac-auth max-attempt 10
display dot1x
dot1x authentication-method
Use dot1x authentication-method to specify an EAP message handling method.
Use undo dot1x authentication-method to restore the default.
The access device performs EAP termination and uses CHAP to communicate with the RADIUS server.
chap: Configures the access device to perform Extensible Authentication Protocol (EAP) termination and use the Challenge Handshake Authentication Protocol (CHAP) to communicate with the RADIUS server.
eap: Configures the access device to relay EAP packets, and supports any of the EAP authentication methods to communicate with the RADIUS server.
pap: Configures the access device to perform EAP termination and use the Password Authentication Protocol (PAP) to communicate with the RADIUS server.
The access device terminates or relays EAP packets.
· In EAP termination mode—The access device re-encapsulates and sends the authentication data from the client in standard RADIUS packets to the RADIUS server. The device performs either CHAP or PAP authentication with the RADIUS server. In this mode, the RADIUS server supports only MD5-Challenge EAP authentication and the username and password EAP authentication initiated by an iNode client.
¡ PAP transports usernames and passwords in plain text. The authentication method applies to scenarios that do not require high security. To use PAP, the client can be an iNode 802.1X client.
¡ CHAP transports usernames in plain text and passwords in encrypted form over the network. CHAP is more secure than PAP.
· In EAP relay mode—The access device relays EAP messages between the client and the RADIUS server. The EAP relay mode supports multiple EAP authentication methods, such as MD5-Challenge, EAP-TLS, and PEAP. To use this mode, make sure the RADIUS server meets the following requirements:
¡ Supports the EAP-Message and Message-Authenticator attributes.
¡ Uses the same EAP authentication method as the client.
If this mode is used, the user-name-format command configured in RADIUS scheme view does not take effect. For more information about the user-name-format command, see "AAA commands."
If RADIUS authentication is used, you must configure the access device to use the same authentication method (PAP, CHAP, or EAP) as the RADIUS server.
# Enable the access device to terminate EAP packets and perform PAP authentication with the RADIUS server.
[Sysname] dot1x authentication-method pap
display dot1x
dot1x auth-fail eapol
Use dot1x auth-fail eapol to enable the device to send an EAP-Success packet to a client when the client user is assigned to the 802.1X Auth-Fail VLAN on a port.
Use undo dot1x auth-fail eapol to restore the default.
The device sends an EAP-Failure packet to a client when the client user is assigned to the 802.1X Auth-Fail VLAN on a port.
Some 802.1X clients cannot send DHCP requests for IP addresses after they receive EAP-Failure packets. To have these clients obtain IP addresses to access authorized resources after they are assigned to the 802.1X Auth-Fail VLAN, use this feature.
# Enable the device to send an EAP-Success packet to a client when the client user is assigned to the 802.1X Auth-Fail VLAN on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x auth-fail eapol
Use dot1x auth-fail vlan to configure an 802.1X Auth-Fail VLAN on a port.
Use undo dot1x auth-fail vlan to restore the default.
dot1x auth-fail vlan authfail-vlan-id
No 802.1X Auth-Fail VLAN exists on a port.
authfail-vlan-id: Specifies the ID of the 802.1X Auth-Fail VLAN on the port. The value range for the VLAN ID is 1 to 4094. Make sure the VLAN has been created.
An 802.1X Auth-Fail VLAN accommodates users that have failed 802.1X authentication for any reason other than unreachable servers. Users in the Auth-Fail VLAN can access a limited set of network resources.
To delete a VLAN that has been configured as an 802.1X Auth-Fail VLAN, you must first use the undo dot1x auth-fail vlan command.
# Configure VLAN 100 as the Auth-Fail VLAN on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x auth-fail vlan 100
display dot1x
dot1x critical eapol
Use dot1x critical eapol to enable the sending of an EAP-Success packet to a client when the 802.1X client user is assigned to the 802.1X critical VLAN on a port.
Use undo dot1x critical eapol to restore the default.
The device sends an EAP-Failure packet to a client when the 802.1X client user is assigned to the 802.1X critical VLAN on a port.
By default, the device sends EAP-Failure packets to 802.1X clients when the client users are assigned to the 802.1X critical VLAN. Some 802.1X clients, for example, Windows built-in 802.1X clients, cannot respond to the EAP-Request/Identity packets from the device for reauthentication if they have received an EAP-Failure packet. As a result, reauthentication for these clients will fail after the authentication server becomes reachable.
To avoid this situation, enable the device to send EAP-Success packets instead of EAP-Failure packets to 802.1X clients when the client users are assigned to the 802.1X critical VLAN.
# Send an EAP-Success packet to a client when the 802.1X client user is assigned to the 802.1X critical VLAN on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x critical eapol
dot1x critical vlan
dot1x critical vlan
Use dot1x critical vlan to configure an 802.1X critical VLAN on a port.
Use undo dot1x critical vlan to restore the default.
dot1x critical vlan critical-vlan-id
No 802.1X critical VLAN exists on a port.
critical-vlan-id: Specifies the ID of the 802.1X critical VLAN on the port. The value range for the VLAN ID is 1 to 4094. Make sure the VLAN has been created.
An 802.1X critical VLAN accommodates users that fail 802.1X authentication because all the RADIUS servers in their ISP domains are unreachable. Users in the critical VLAN can access a limited set of network resources depending on the configuration.
You cannot specify a VLAN as both a super VLAN and an 802.1X critical VLAN on a port. For more information about super VLANs, see Network Connectivity Configuration Guide.
To delete a VLAN that has been configured as an 802.1X critical VLAN, you must first use the undo dot1x critical vlan command.
# Specify VLAN 100 as the 802.1X critical VLAN on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x critical vlan 100
display dot1x
Use dot1x duplicate-eapol-start discard to discard duplicate EAPOL-Start requests on an interface.
Use undo dot1x duplicate-eapol-start discard to restore the default.
The device does not discard duplicate EAPOL-Start requests on an interface if the requests are legal.
During 802.1X authentication, the device might receive duplicate EAPOL-Start requests from an 802.1X user. By default, the device delivers the duplicate EAPOL-Start requests to the authentication server as long as they are legal. This mechanism might result in authentication failure if the authentication server cannot respond to duplicate EAPOL-Start requests. To resolve this issue, use this command on the user access interface to discard duplicate EAPOL-Start requests.
As a best practice, use this command only if the server cannot respond to duplicate EAPOL-Start requests. Do not use this command in other situations.
# Discard duplicate EAPOL-Start requests on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x duplicate-eapol-start discard
display dot1x
dot1x domain-delimiter
Use dot1x domain-delimiter to specify a set of domain name delimiters supported by the device.
Use undo dot1x domain-delimiter to restore the default.
dot1x domain-delimiter string
The device supports only the at sign (@) delimiter for 802.1X users.
string: Specifies a set of 1 to 16 domain name delimiters for 802.1X users. No space is required between delimiters. Available delimiters include the at sign (@), backslash (\), dot (.), and forward slash (/). If you want to use backslash (\) as the domain name delimiter, you must enter the escape character (\) along with the backslash (\) sign.
Any character in the configured set can be used as the domain name delimiter for 802.1X authentication users. Usernames that include domain names can use the format of username@domain-name, domain-name\username, username.domain-name, or username/domain-name.
The delimiter set you configured overrides the default setting. If the at sign (@) is not included in the delimiter set, the device does not support the 802.1X users that use this sign as the domain name delimiter.
If a username string contains multiple configured delimiters, the device takes the rightmost delimiter in the username string as the domain name delimiter. For example, if you configure the forward slash (/), dot (.), and backslash (\) as delimiters, the domain name delimiter for the username string 121.123/22\@abc is the backslash (\). The username is @abc and the domain name is 121.123/22.
# Specify the at sign (@) and forward slash (/) as domain name delimiters.
[Sysname] dot1x domain-delimiter @/
display dot1x
dot1x ead-assistant enable
Use dot1x ead-assistant enable to enable the EAD assistant feature.
Use undo dot1x ead-assistant enable to disable the EAD assistant feature.
The EAD assistant feature is disabled.
The EAD assistant feature enables the access device to redirect the HTTP or HTTPS requests of a user to a URL to download and install EAD client. This feature eliminates the tedious job of the administrator to deploy EAD clients.
For the EAD assistant feature to take effect on a port, you must set the port authorization mode to auto.
The feature is mutually exclusive with MAC authentication and port security. You must disable MAC authentication and port security globally before you enable the EAD assistant feature.
To redirect the HTTPS requests of 802.1X users, use the http-redirect https-port command to specify the HTTPS redirect listening port. For information about the http-redirect https-port command, see "HTTP redirect commands."
# Enable the EAD assistant feature.
[Sysname] dot1x ead-assistant enable
display dot1x
dot1x ead-assistant free-ip
dot1x ead-assistant url
Use dot1x ead-assistant free-ip to configure a free IP.
Use undo dot1x ead-assistant free-ip to remove the specified or all free IP addresses.
dot1x ead-assistant free-ip ip-address { mask-address | mask-length }
undo dot1x ead-assistant free-ip { ip-address { mask-address | mask-length } | all }
No free IPs exist. Users cannot access any segments before they pass 802.1X authentication.
ip-address: Specifies a freely accessible IP address segment, also called a free IP.
mask: Specifies an IP address mask.
mask-length: Specifies IP address mask length in the range of 1 to 32.
all: Removes all free IP addresses.
With EAD assistant enabled on the device, unauthenticated 802.1X users can access the network resources in the free IP segments before they pass 802.1X authentication.
Execute this command multiple times to configure multiple free IPs. The maximum number of free IPs supported by the device depends on the device model.
# Configure 192.168.1.1/16 as a free IP.
[Sysname] dot1x ead-assistant free-ip 192.168.1.1 255.255.0.0
display dot1x
Use dot1x ead-assistant url to configure a redirect URL for EAD assistant.
Use undo dot1x ead-assistant url to restore the default.
dot1x ead-assistant url url-string [ secondary ] [ track track-entry-number ]
undo dot1x ead-assistant url [ secondary ]
No redirect URL exists for EAD assistant.
url-string: Specifies the redirect URL, a case-sensitive string of 1 to 64 characters in the format http://string or https://string. If the specified URL does not start with http:// or https://, the device prefixes the specified URL with http://. Because the URL string can contain question marks (?), you cannot obtain help information by entering a question mark at the position of this argument.
secondary: Specifies the URL as the secondary redirect URL. If you do not specify this keyword, the URL is the primary redirect URL.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024. If you do not specify a track entry number, the specified redirect URL is not associated with a track entry.
When an unauthenticated user uses a Web browser to access any network other than the free IP, the device redirects the HTTP or HTTPS requests from the user to the redirect URL.
The redirect URL must be on the free IP subnet.
You can specify only one primary redirect URL and one secondary redirect URL.
You can associate a track entry with a redirect URL. The 802.1X module can determine whether the Web redirect server providing the URL is reachable, depending on the status of the track entry. If the server providing the primary redirect URL is unreachable, the device can redirect HTTP or HTTPS requests to the secondary redirect URL.
As a best practice, configure the track entry associated with a redirect URL to collaborate with an HTTP NQA operation. The redirect URL-Track-NQA collaboration can detect the connectivity of the Web redirect server and server performance. For more information about Track, see High Availability Configuration Guide. For more information about NQA, see Network Management and Monitoring Configuration Guide.
The device selects a redirect URL as follows:
· If both the primary and secondary redirect URLs are configured and the URLs are not associated with track entries, the primary redirect URL takes precedence over the secondary redirect URL.
· If only the primary or secondary redirect URL is configured and the URL is not associated with a track entry, the redirect URL takes effect.
· The primary redirect URL takes effect if it is not associated with a track entry or the track entry associated with the URL is in Positive or NotReady state. If the primary redirect URL is not available, the secondary redirect URL takes effect.
· If the primary redirect URL is not configured or the state of the track entry associated with the primary redirect URL changes to Negative, the device checks the secondary redirect URL.
¡ The secondary redirect URL takes effect if it is not associated with a track entry or its associated track entry is in Positive or NotReady state.
¡ No redirect URL is available if no secondary redirect URL is configured or the track entry associated with the secondary redirect URL is in Negative state.
# Configure the redirect URL as http://test.com.
[Sysname] dot1x ead-assistant url http://test.com
display dot1x
Use dot1x eap-tls-fragment to-server to enable 802.1X EAP-TLS fragmentation and set the maximum EAP-TLS fragment size.
Use undo dot1x eap-tls-fragment to-server to restore the default.
dot1x eap-tls-fragment to-server eap-tls-max-length
EAP-TLS messages are not fragmented.
eap-tls-max-length: Sets the maximum EAP-TLS fragment size in bytes. The value range is 100 to 1500.
802.1X EAP-TLS fragmentation takes effect only when EAP relay mode is used.
When the device uses EAP-TLS authentication method in EAP relay mode, the RADIUS packets might exceed the maximum packet size supported by the RADIUS server. This situation typically occurs when long EAP-TLS messages are encapsulated in the EAP-Message attribute of the RADIUS packet sent to the RADIUS server.
To avoid authentication failures caused by oversized packets, fragment the EAP-TLS messages depending on the maximum RADIUS packet size supported by the remote RADIUS server.
For example, the maximum packet length allowed by the server is 1200 bytes and the length of a RADIUS packet (excluding the EAP-Message attribute) is 800 bytes. To make sure the maximum length of a RADIUS packet does not exceed 1200 bytes, you must set the maximum length of an EAP-TLS fragment to a value less than 400 bytes.
# Set the maximum EAP-TLS fragment size to 400 bytes.
[Sysname] dot1x eap-tls-fragment to-server 400
display dot1x
dot1x eapol untag
Use dot1x eapol untag to enable the device to remove the VLAN tags of all 802.1X protocol packets sent out of a port to 802.1X clients.
Use undo dot1x eapol untag to restore the default.
dot1x eapol untag
Whether the device removes the VLAN tags of all 802.1X protocol packets sent out of a port to 802.1X clients depends on the configuration in the VLAN module.
CAUTION: This command removes the VLAN tags of all 802.1X protocol packets sent out of the port to 802.1X clients. Do not use this command if VLAN-aware 802.1X clients are attached to the port. As a best practice, use this command only in the scenario described in the command usage guidelines. |
This command operates on a hybrid port to have it send 802.1X protocol packets with their VLAN tags removed, regardless of whether the port is a tagged or untagged member of a VLAN.
Use this command if the 802.1X-enabled hybrid port is a tagged member of its PVID and the attached 802.1X clients cannot recognize VLAN-tagged 802.1X protocol packets.
# Enable the device to remove the VLAN tags of all 802.1X protocol packets sent out of GigabitEthernet 1/0/1 to 802.1X clients.
[Sysname-GigabitEthernet1/0/1] dot1x eapol untag
display dot1x
dot1x guest-vlan
Use dot1x guest-vlan to configure an 802.1X guest VLAN on a port.
Use undo dot1x guest-vlan to restore the default.
dot1x guest-vlan guest-vlan-id
No 802.1X guest VLAN exists on a port.
guest-vlan-id: Specifies the ID of the 802.1X guest VLAN. The value range for the VLAN ID is 1 to 4094. Make sure the VLAN has been created.
An 802.1X guest VLAN accommodates users that have not performed 802.1X authentication. In the guest VLAN, users can access a limited set of network resources, such as a software server, to download anti-virus software and system patches.
You cannot specify a VLAN as both a super VLAN and an 802.1X guest VLAN on a port. For more information about super VLANs, see Network Connectivity Configuration Guide.
To delete a VLAN that has been configured as a guest VLAN, you must use the undo dot1x guest-vlan command first.
# Specify VLAN 100 as the 802.1X guest VLAN on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x guest-vlan 100
display dot1x
dot1x guest-vlan-delay
Use dot1x guest-vlan-delay to enable 802.1X guest VLAN assignment delay on a port.
Use undo dot1x guest-vlan-delay to disable the specified 802.1X guest VLAN assignment delay on a port.
dot1x guest-vlan-delay { eapol | new-mac }
undo dot1x guest-vlan-delay [ eapol | new-mac ]
802.1X guest VLAN assignment delay is disabled on a port.
eapol: Specifies EAPOL-triggered 802.1X guest VLAN assignment delay. This keyword takes effect if 802.1X authentication is triggered by EAPOL-Start packets.
new-mac: Specifies new MAC-triggered 802.1X guest VLAN assignment delay. This keyword takes effect if 802.1X authentication is triggered by packets from unknown MAC addresses.
This command enables the device to delay assigning an 802.1X-enabled port to the 802.1X guest VLAN when 802.1X authentication is triggered on the port.
To use this feature, the 802.1X-enabled port must perform MAC-based access control.
When 802.1X authentication is triggered on a port, the device performs the following operations:
1. Sends a unicast EAP-Request/Identity packet to the MAC address that triggers the authentication.
2. Retransmits the packet if no response has been received within the username request timeout interval set by using the dot1x timer tx-period command.
3. Assigns the port to the 802.1X guest VLAN after the maximum number of request attempts set by using the dot1x retry command is reached.
If you use the undo command without any keyword, the command disables both EAPOL-triggered and new MAC-triggered 802.1X guest VLAN assignment delay on a port.
# Enable EAPOL-triggered 802.1X guest VLAN assignment delay on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x guest-vlan-delay eapol
display dot1x
dot1x guest-vlan
dot1x retry
dot1x handshake
Use dot1x handshake to enable the online user handshake feature.
Use undo dot1x handshake to disable the online user handshake feature.
dot1x handshake
The online user handshake feature is enabled.
The online user handshake feature enables the device to periodically send EAP-Request/Identity packets to the client for verifying the connectivity status of online 802.1X users. The device sets a user to the offline state if it does not receive an EAP-Response/Identity packet from the user after making the maximum attempts within the handshake period. To set the handshake timer, use the dot1x timer handshake-period command. To set the maximum handshake attempts, use the dot1x retry command.
# Enable the online user handshake feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x handshake
display dot1x
dot1x retry
dot1x handshake reply enable
Use dot1x handshake reply enable to enable the 802.1X online user handshake reply feature.
Use undo dot1x handshake reply enable to disable the 802.1X online user handshake reply feature.
The 802.1X online user handshake reply feature is disabled.
This command enables the device to reply to 802.1X clients' EAP-Response/Identity packets with EAP-Success packets during the online handshake process.
Use this command only if 802.1X clients will go offline without receiving EAP-Success packets from the device.
# Enable the 802.1X online user handshake reply feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x handshake reply enable
dot1x handshake
dot1x handshake secure
Use dot1x handshake secure to enable the online user handshake security feature.
Use undo dot1x handshake secure to disable the online user handshake security feature.
The online user handshake security feature is disabled.
The online user handshake security feature is applicable only to the network that deploys the iNode client and IMC server for 802.1X authentication. It prevents users from using illegal client software to bypass iNode security check.
To have this feature take effect, make sure the online user handshake feature is enabled.
# Enable the online user handshake security feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x handshake secure
display dot1x
dot1x handshake
dot1x mac-binding
Use dot1x mac-binding to add an 802.1X MAC address binding entry.
Use undo dot1x mac-binding to delete the specified 802.1X MAC address binding entries.
dot1x mac-binding mac-address
undo dot1x mac-binding { mac-address | all }
No 802.1X MAC address binding entries exist on a port.
mac-address: Specifies a MAC address in the format of H-H-H, excluding broadcast, multicast, and all-zero MAC addresses.
all: Specifies all MAC addresses that are bound to a port.
This command takes effect only when the 802.1X MAC address binding feature takes effect.
802.1X MAC address binding entries, both manually added and automatically generated, never age out. They can survive a user logoff or a device reboot. To delete an entry, you must use the undo dot1x mac-binding mac-address command. An 802.1X MAC address binding entry cannot be deleted when the user in the entry is online.
After the number of 802.1X MAC address binding entries reaches the upper limit of concurrent 802.1X users (set by using the dot1x max-user command), the following restrictions exist:
· Users not in the binding entries will fail authentication even after users in the binding entries go offline.
· New 802.1X MAC address binding entries are not allowed.
# Add an 802.1X MAC address binding entry on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x mac-binding 000a-eb29-75f1
dot1x
dot1x mac-binding enable
dot1x port-method
Use dot1x mac-binding enable to enable the 802.1X MAC address binding feature.
Use undo dot1x mac-binding enable to disable the 802.1X MAC address binding feature.
The 802.1X MAC address binding feature is disabled.
This command takes effect only on a port that performs MAC-based access control.
The 802.1X MAC address binding feature automatically binds MAC addresses of authenticated 802.1X users to the users' access port and generates 802.1X MAC address binding entries.
802.1X MAC address binding entries, both automatically generated and manually added, never age out. They can survive a user logoff or a device reboot. To delete an entry, you must use the undo dot1x mac-binding mac-address command. An 802.1X MAC address binding entry cannot be deleted when the user in the entry is online.
# Enable 802.1X MAC address binding on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x mac-binding enable
dot1x
dot1x mac-binding
dot1x port-method
dot1x mandatory-domain
Use dot1x mandatory-domain to specify a mandatory 802.1X authentication domain on a port.
Use undo dot1x mandatory-domain to restore the default.
No mandatory 802.1X authentication domain is specified on a port.
domain-name: Specifies the ISP domain name, a case-insensitive string of 1 to 255 characters.
When the system authenticates an 802.1X user trying to access a port, it selects an authentication domain in the following order:
1. Mandatory domain.
2. ISP domain specified in the username.
3. Default ISP domain.
# Specify my-domain as the mandatory authentication domain for 802.1X users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x mandatory-domain my-domain
display dot1x
dot1x max-user
Use dot1x max-user to set the maximum number of concurrent 802.1X users on a port.
Use undo dot1x max-user to restore the default.
dot1x max-user max-number
undo dot1x max-user
A port allows a maximum of 4294967295 concurrent 802.1X users.
max-number: Specifies the maximum number of concurrent 802.1X users on a port. The value range is 1 to 4294967295.
Set the maximum number of concurrent 802.1X users on a port to prevent the system resources from being overused. When the maximum number is reached, the port denies subsequent 802.1X users.
# Set the maximum number of concurrent 802.1X users to 32 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x max-user 32
display dot1x
dot1x multicast-trigger
Use dot1x multicast-trigger to enable the 802.1X multicast trigger feature.
Use undo dot1x multicast-trigger to disable the 802.1X multicast trigger feature.
The 802.1X multicast trigger feature is enabled.
The multicast trigger feature enables the device to act as the initiator. The device periodically multicasts EAP-Request/Identity packets out of a port to detect 802.1X clients and trigger authentication. You can use the dot1x timer tx-period command to set the interval for sending multicast EAP-Request/Identity packets.
Disable the multicast trigger in a wireless LAN. Wireless clients and the wireless module of the access device can both initiate 802.1X authentication.
As a best practice to conserve link bandwidth, disable the multicast trigger if a lot of VLANs are configured on the port.
# Enable the multicast trigger feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x multicast-trigger
display dot1x
dot1x unicast-trigger
dot1x port-control
Use dot1x port-control to set the authorization state for the port.
Use undo dot1x port-control to restore the default.
dot1x port-control { authorized-force | auto | unauthorized-force }
The default port authorization state is auto.
authorized-force: Places the port in authorized state, enabling users on the port to access the network without authentication.
auto: Places the port initially in unauthorized state to allow only EAPOL packets to pass, and places the port in authorized state after a user passes authentication. You can use this option in most scenarios.
unauthorized-force: Places the port in unauthorized state, denying any access requests from users on the port.
You can use this command to set the port authorization state to determine whether a client is granted access to the network.
# Set the authorization state of GigabitEthernet 1/0/1 to unauthorized-force.
[Sysname-GigabitEthernet1/0/1] dot1x port-control unauthorized-force
display dot1x
dot1x port-method
Use dot1x port-method to specify an access control method for the port.
Use undo dot1x port-method to restore the default.
dot1x port-method { macbased | portbased }
MAC-based access control applies.
macbased: Uses MAC-based access control on the port to separately authenticate each user attempting to access the network. Using this method, when an authenticated user logs off, no other online users are affected. Support for the MAC-based access control depends on the device model.
portbased: Uses port-based access control on the port. Using this method, once an 802.1X user passes authentication on the port, any subsequent user can access the network through the port without authentication. When the authenticated user logs off, all other users are logged off.
CAUTION: If online 802.1X users are present on a port, changing its access control method will cause the online users to go offline. |
MAC-based access control provides higher security than port-based access control.
# Configure GigabitEthernet 1/0/1 to implement port-based access control.
[Sysname-GigabitEthernet1/0/1] dot1x port-method portbased
display dot1x
dot1x quiet-period
Use dot1x quiet-period to enable the quiet timer.
Use undo dot1x quiet-period to disable the quiet timer.
dot1x quiet-period
The quiet timer is disabled.
When a client fails 802.1X authentication, the device must wait a period of time before it can process authentication requests from the client. You can use the dot1x timer quiet-period command to set the quiet timer.
# Enable the quiet timer and set the quiet timer to 100 seconds.
[Sysname] dot1x quiet-period
[Sysname] dot1x timer quiet-period 100
display dot1x
dot1x timer
Use dot1x re-authenticate to enable the 802.1X periodic reauthentication feature.
Use undo dot1x re-authenticate to disable the 802.1X periodic reauthentication feature.
The 802.1X periodic reauthentication feature is disabled.
Periodic reauthentication enables the access device to periodically authenticate online 802.1X users on a port. This feature tracks the connection status of online users and updates the authorization attributes assigned by the server, such as the ACL and VLAN.
You can use the dot1x timer reauth-period command to configure the interval for reauthentication.
If periodic reauthentication is triggered for a user while that user is waiting for online synchronization, the system performs online synchronization and does not perform reauthentication for the user.
# Enable the 802.1X periodic reauthentication feature on GigabitEthernet 1/0/1, and set the periodic reauthentication interval to 1800 seconds.
[Sysname] dot1x timer reauth-period 1800
[Sysname-GigabitEthernet1/0/1] dot1x re-authenticate
display dot1x
dot1x timer
dot1x re-authenticate manual
Use dot1x re-authenticate manual to manually reauthenticate all online 802.1X users on a port.
After this command is executed, this device reauthenticates all online 802.1X users on a port. The command takes effect regardless of the server-assigned reauthentication attribute and the periodic reauthentication feature.
# Manually reauthenticate all online 802.1X users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x re-authenticate manual
Use dot1x re-authenticate server-unreachable keep-online to enable the keep-online feature on a port.
Use undo dot1x re-authenticate server-unreachable to restore the default.
The keep-online feature is disabled on a port. The device logs off online 802.1X authenticated users if no server is reachable for 802.1X reauthentication.
This feature keeps authenticated 802.1X users online when no server is reachable for 802.1X reauthentication.
# Enable the keep-online feature on GigabitEthernet 1/0/1 for 802.1X reauthentication.
[Sysname-GigabitEthernet1/0/1] dot1x re-authenticate server-unreachable keep-online
display dot1x
dot1x retry
Use dot1x retry to set the maximum number of attempts for sending an authentication request to a client.
Use undo dot1x retry to restore the default.
dot1x retry retries
undo dot1x retry
A maximum of two attempts are made to send an authentication request to a client.
retries: Specifies the maximum number of attempts for sending an authentication request to a client. The value range is 1 to 10.
The access device retransmits an authentication request to a client in any of the following situations:
· The device does not receive any responses from the client within the username request timeout interval. The timer is set by using the dot1x timer tx-period tx-period-value command for the EAP-Request/Identity packet.
· The device does not receive any responses from the client within the client timeout interval. The timer is set by using the dot1x timer supp-timeout supp-timeout-value command for the EAP-Request/MD5-Challenge packet.
The access device stops retransmitting the request, if it has made the maximum number of request transmission attempts but still received no response.
# Set the maximum number of attempts to 9 for sending an authentication request to a client.
[Sysname] dot1x retry 9
display dot1x
dot1x timer
Use dot1x server-recovery online-user-sync to enable 802.1X online user synchronization.
Use undo dot1x server-recovery online-user-sync to disable 802.1X online user synchronization.
802.1X online user synchronization is disabled. The device does not synchronize online 802.1X user information on a port with a RADIUS server after the RADIUS server recovers from the unreachable state.
IMPORTANT: This command takes effect only when the device uses an IMC RADIUS server to authenticate 802.1X users. |
To ensure that the RADIUS server maintains the same online 802.1X user information as the device after the server state changes from unreachable to reachable, use this feature.
This feature synchronizes online 802.1X user information between the device and the RADIUS server when the RADIUS server state is detected having changed from unreachable to reachable.
When synchronizing online 802.1X user information on a port with the RADIUS server, the device initiates 802.1X authentication in turn for each authenticated online 802.1X user to the RADIUS server.
If synchronization fails for an online user, the device logs off that user unless the failure occurs because the server has become unreachable again.
The amount of time required to complete online user synchronization increases as the number of online users grows. This might result in an increased delay for new 802.1X users and users in the critical VLAN to authenticate or reauthenticate to the RADIUS server and come online.
To have this feature take effect, you must use it in conjunction with the RADIUS server status detection feature, which is configurable with the radius-server test-profile command. When you configure this feature, make sure the detection interval is shorter than the RADIUS server quiet timer configured by using the timer quiet command in RADIUS scheme view. The server state changes to active on expiration of the quiet timer regardless of its actual reachability. Setting a shorter detection interval than the quiet timer prevents the RADIUS server status detection feature from falsely reporting the server reachability.
For more information about the RADIUS server status detection feature, see AAA configuration in User Access and Authentication Configuration Guide.
# Enable 802.1X online user synchronization on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x server-recovery online-user-sync
display dot1x
timer quiet (RADIUS scheme view)
dot1x timer
Use dot1x timer to set an 802.1X timer.
Use undo dot1x timer to restore the default of an 802.1X timer.
dot1x timer { ead-timeout ead-timeout-value | handshake-period handshake-period-value | quiet-period quiet-period-value | reauth-period reauth-period-value | server-timeout server-timeout-value | supp-timeout supp-timeout-value | tx-period tx-period-value | user-aging { auth-fail-vlan | critical-vlan | guest-vlan } aging-time-value }
undo dot1x timer { ead-timeout | handshake-period | quiet-period | reauth-period | server-timeout | supp-timeout | tx-period | user-aging { auth-fail-vlan | critical-vlan | guest-vlan } }
The following 802.1X timers apply:
· EAD rule timer: 30 minutes.
· Handshake timer: 15 seconds.
· Offline detect timer: 300 seconds.
· Quiet timer: 60 seconds.
· Periodic reauthentication timer: 3600 seconds.
· Server timeout timer: 100 seconds.
· Client timeout timer: 30 seconds.
· Username request timeout timer: 30 seconds.
· User aging timers for all applicable types of 802.1X microsegments and VLANs: 1000 seconds.
ead-timeout ead-timeout-value: Sets the EAD rule timer in minutes. The value range for the ead-timeout-value argument is 1 to 1440.
handshake-period handshake-period-value: Sets the handshake timer in seconds. The value range for the handshake-period-value argument is 5 to 1024.
quiet-period quiet-period-value: Sets the quiet timer in seconds. The value range for the quiet-period-value argument is 10 to 120.
reauth-period reauth-period-value: Sets the periodic reauthentication timer in seconds. The value range for the reauth-period-value argument is 60 to 7200.
server-timeout server-timeout-value: Sets the server timeout timer in seconds. The value range for the server-timeout-value argument is 100 to 300.
supp-timeout supp-timeout-value: Sets the client timeout timer in seconds. The value range for the supp-timeout-value argument is 1 to 120.
tx-period tx-period-value: Sets the username request timeout timer in seconds. The value range for the tx-period-value argument is 1 to 120.
user-aging: Sets the user aging timer for a type of 802.1X VLAN.
aging-time-value: Sets the user aging timer. The value range is 60 to 2147483647 seconds.
In most cases, the default settings are sufficient. You can edit the timers, depending on the network conditions.
· In a low-speed network, increase the client timeout timer.
· In a vulnerable network, set the quiet timer to a high value.
· In a high-performance network with quick authentication response, set the quiet timer to a low value.
· In a network with authentication servers of different performance, adjust the server timeout timer.
The network device uses the following 802.1X timers:
· EAD rule timer (ead-timeout)—Sets the lifetime of each EAD rule. When the timer expires or the user passes authentication, the rule is removed. If users fail to download the EAD client or fail to pass authentication before the timer expires, they must reconnect to the network to access the free IP.
· Handshake timer (handshake-period)—Sets the interval at which the access device sends client handshake requests to check the online status of a client that has passed authentication. If the device does not receive a response after sending the maximum number of handshake requests, it considers that the client has logged off.
· Quiet timer (quiet-period)—Starts when a client fails authentication. The access device must wait the time period before it can process the authentication attempts from the client.
· Periodic reauthentication timer (reauth-period)—Sets the interval at which the network device periodically reauthenticates online 802.1X users. To enable 802.1X periodic reauthentication on a port, use the dot1x re-authenticate command.
· Server timeout timer (server-timeout)—Starts when the access device sends a RADIUS Access-Request packet to the authentication server. If no response is received when this timer expires, the 802.1X authentication fails.
To avoid forced logoff before the server timeout timer expires, set the server timeout timer to a value that is lower than or equal to the product of the following values:
¡ The maximum number of RADIUS packet transmission attempts set by using the retry command in RADIUS scheme view.
¡ The RADIUS server response timeout timer set by using the timer response-timeout command in RADIUS scheme view.
For information about setting the maximum number of RADIUS packet transmission attempts and the RADIUS server response timeout timer, see AAA configuration in User Access and Authentication Configuration Guide.
· Client timeout timer (supp-timeout)—Starts when the access device sends an EAP-Request/MD5-Challenge packet to a client. If no response is received when this timer expires, the access device retransmits the request to the client.
· Username request timeout timer (tx-period)—Starts when the device sends an EAP-Request/Identity packet to a client in response to an authentication request. If the device does not receive a response before this timer expires, it retransmits the request. The timer also sets the interval at which the network device sends multicast EAP-Request/Identity packets to detect clients that cannot actively request authentication.
· User aging timer (user-aging)—Sets the amount of time that a user can stay in a type of 802.1X microsegment or VLAN. The timer takes effect after you enable unauthenticated user aging by using the dot1x unauthenticated-user aging enable command. For more information about how user aging operates, see the usage guidelines for the dot1x unauthenticated-user aging enable command.
IMPORTANT: Do not set a user aging timer to a multiple of the username request timeout timer (the dot1x timer tx-period command). If you do so, the aging timer will not take effect. |
The change to the periodic reauthentication timer applies to the users that have been online only after the old timer expires. Other timer changes take effect immediately on the device.
# Set the server timeout timer to 150 seconds.
[Sysname] dot1x timer server-timeout 150
display dot1x
retry
timer response-timeout (RADIUS scheme view)
Use dot1x timer reauth-period to set the 802.1X periodic reauthentication timer on a port.
Use undo dot1x timer reauth-period to restore the default.
No 802.1X periodic reauthentication timer is configured on a port. The port uses the global 802.1X periodic reauthentication timer.
reauth-period-value: Sets the 802.1X periodic reauthentication timer in seconds. The value range for the reauth-period-value argument is 60 to 7200.
The device reauthenticates online 802.1X users on a port at the specified periodic reauthentication interval when the port is enabled with periodic reauthentication. To enable periodic reauthentication on a port, use the dot1x re-authenticate command.
A change to the periodic reauthentication timer applies to online users only after the old timer expires.
The device selects a periodic reauthentication timer for 802.1X reauthentication in the following order:
1. Server-assigned reauthentication timer.
2. Port-specific reauthentication timer.
3. Global reauthentication timer.
4. Default reauthentication timer.
# Set the 802.1X periodic reauthentication timer to 60 seconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x timer reauth-period 60
dot1x timer
Use dot1x unauthenticated-user aging enable to enable 802.1X unauthenticated user aging.
Use undo dot1x unauthenticated-user aging enable to disable 802.1X unauthenticated user aging.
User aging is enabled for 802.1X users that have not been authenticated or have not passed authentication.
802.1X unauthenticated user aging takes effect only on a port that performs port-based access control in the current software version. This feature applies to users added to an 802.1X critical or Auth-Fail VLAN because they have failed authentication.
For users in one of those VLANs on one port to be authenticated successfully and come online on another port, enable this feature. In any other scenarios, disable this feature as a best practice.
A user aging timer starts when the port is assigned to the critical or Auth-Fail VLAN. When the aging timer expires, the port is removed from the VLAN and all MAC address entries for users in the VLAN are also removed. The removed users will be unable to access any network resources until after another authentication is triggered.
In port-based access control mode, the user aging timer cannot take effect on users in the guest VLAN in the current software version.
# Disable 802.1X unauthenticated user aging on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] undo dot1x unauthenticated-user aging enable
dot1x timer
Use dot1x unicast-trigger to enable the 802.1X unicast trigger feature.
Use undo dot1x unicast-trigger to disable the 802.1X unicast trigger feature.
The 802.1X unicast trigger feature is disabled.
The unicast trigger feature enables the access device to initiate 802.1X authentication when the device receives a data frame from an unknown source MAC address. The device sends a unicast EAP-Request/Identity packet to the unknown source MAC address. It will retransmit the packet if it does not receive any responses within a period of time (set by using the dot1x timer tx-period command). This process continues until the maximum number of request attempts (set by using the dot1x retry command) is reached.
As a best practice, do not use the unicast trigger on a port that performs port-based access control. If you do so, users on the port might fail to come online correctly.
# Enable the unicast trigger feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x unicast-trigger
display dot1x
dot1x port-method
dot1x retry
dot1x timer
reset dot1x access-user
Use reset dot1x access-user to log off 802.1X users.
reset dot1x access-user [ interface interface-type interface-number | mac mac-address | username username | vlan vlan-id ]
mac mac-address: Specifies an 802.1X user by its MAC address. The mac-address argument is in the format of H-H-H.
username username: Specifies an 802.1X user by its name. The username argument is a case-sensitive string of 1 to 253 characters.
vlan vlan-id: Specifies a VLAN by its VLAN ID. The value range for the vlan-id argument is 1 to 4094.
Use this command to log off the specified 802.1X users and clear information about these users from the device. These users must perform 802.1X authentication to come online again.
With a VLAN specified, this command logs off the following 802.1X users:
· Users that have passed 802.1X authentication and have been assigned the specified VLAN as the authorization VLAN by the server.
· Users that stay in the specified VLAN after they have passed 802.1X authentication, because they have not been assigned an authorization VLAN yet.
· Users that are performing 802.1X authentication in the specified VLAN.
To identify the VLAN in which a user is staying, use the display mac-address command.
If you do not specify any parameters, the reset dot1x access-user command logs off all 802.1X users on the device.
The reset dot1x access-user command takes effect only on wired 802.1X users. To log off wireless 802.1X users, use the reset wlan client command. For more information about the reset wlan client command, see WLAN Access Command Reference.
# Log off all 802.1X users on GigabitEthernet 1/0/1.
<Sysname> reset dot1x access-user interface gigabitethernet 1/0/1
display dot1x connection
reset dot1x guest-vlan
Use reset dot1x guest-vlan to remove users from the 802.1X guest VLAN on a port.
reset dot1x guest-vlan interface interface-type interface-number [ mac-address mac-address ]
mac-address mac-address: Specifies the MAC address of an 802.1X user in the guest VLAN. If you do not specify this option, the command removes all 802.1X users from the 802.1X guest VLAN on the port.
# Remove the 802.1X user with MAC address 1-1-1 from the 802.1X guest VLAN on GigabitEthernet 1/0/1.
<Sysname> reset dot1x guest-vlan interface gigabitethernet 1/0/1 mac-address 1-1-1
dot1x guest-vlan
reset dot1x statistics
Use reset dot1x statistics to clear 802.1X statistics.
reset dot1x statistics [ ap ap-name [ radio radio-id ] | interface interface-type interface-number ]
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).If you do not specify an AP, this command clears statistics of 802.1X users for all APs.
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by AP model. If you do not specify a radio, this command clears 802.1X statistics for all radios on the specified AP.
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command clears 802.1X statistics on all ports.
# Clear 802.1X statistics on GigabitEthernet 1/0/1.
<Sysname> reset dot1x statistics interface gigabitethernet 1/0/1
display dot1x
