03-WLAN Configuration Guides
HomeSupportConfigure & DeployConfiguration GuidesH3C Unified Wired and Wireless Access Controller User Manual (R5456Pxx)-6W10003-WLAN Configuration Guides
19-WLAN optimization configuration
19-WLAN optimization configuration 104.59 KB
Configuring WLAN optimization
About WLAN optimization
Proper channel planning and power control policies during WLAN deployment are important for good performance. However, in live WLAN networks, channel overlapping, collisions, and interference can easily occur because the none-overlapping channels are limited but the number of WLAN devices always increases.
The WLAN optimization features can help you improve the quality and stability of a WLAN.
Restrictions and guidelines: WLAN optimization configuration
Use WLAN optimization commands under the guidance of H3C Support.
There is no fixed combination of features for optimizing a specific WLAN. Select and adjust the features based on the application effect and WLAN performance.
The overall performance of a WLAN is determined by the network architecture as well as channel and power planning. Therefore, the WLAN optimization features cannot significantly increase the performance of a WLAN. In practice, if the features can improve the WLAN performance by 3%, the optimization is considered successful.
Configuring rejection of weak-signal clients
This feature enables an AP to reject clients with an RSSI lower than the specified threshold to release channel resources and enhance WLAN performance.
After you enable this feature, wireless clients with an RSSI lower than the threshold might fail to access the WLAN.
After a client accesses the WLAN, an AP will not log off the client with an RSSI lower than the threshold but will reject the client after it disconnects from the network.
To avoid client access failures, set an appropriate RSSI value when enabling this feature.
2.     Enter AP view or an AP group's AP model view.
¡     Enter AP view.
wlan ap ap-name
¡     Execute the following commands in sequence to enter an AP group's AP model view:
wlan ap-group group-name
ap-model ap-model
3.     Enter radio view.
radio radio-id
4.     Configure rejection of weak-signal clients.
option client reject { disable | enable [ rssi rssi-value ] }
By default:
¡     In radio view, a radio uses the configuration in an AP group's radio view.
¡     In an AP group's radio view, rejection of weak-signal clients is disabled.
Configuring AP-triggered client reassociation
A client with a low signal strength can roam to another AP only when its signal strength is lower than the manufacturer-defined signal strength for triggering roaming. Therefore, the client cannot obtain good network experience and service quality.
This feature enables an AP to send unsolicited deauthentication frames to a client when the signal strength of the client is lower than the specified RSSI threshold. Then, the client can reassociate with the AP or roam to another AP.
To avoid unexpected client logoff, set an appropriate RSSI value when enabling this feature.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Configure AP-triggered client reassociation.
option client reconnect { disable | enable [ rssi rssi-value ] [ interval interval ] }
By default:
¡     In an AP group's radio view, AP-triggered client reassociation is disabled.
Configuring hidden node protection
This feature enables clients to send RTS or CTS frames before transmitting frames to avoid interference from hidden nodes.
This feature takes effect only on 802.11g, 802.11n, and 802.11ac clients.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Configure hidden node protection.
option client hide-node-protection { disable | enable }
By default:
¡     In an AP group's radio view, hidden node protection is disabled.
Configuring fast forwarding of AP-to-client data frames
This feature enables an AP to forward data frames to clients without extra processing (such as verification and counting) to improve processing efficiency.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Configure fast forwarding of AP-to-client data frames.
option client fast-forwarding { disable | enable level level-value }
By default:
¡     In an AP group's radio view, fast forwarding of AP-to-client data frames is disabled.
Setting the maximum retransmissions and retries for an EAPOL-Key packet
In Robust Security Network Association (RSNA) authentication, an AP and a client use EAPOL-Key packets in the four-way handshake to negotiate the keys. After that, the AP and the client periodically exchange EAPOL-Key packets to update the keys.
During key negotiation or update, the AP keeps retransmitting an EAPOL-Key packet until a response is received or the maximum number of retries for an EAPOL-Key packet is reached.
The system starts to count the retries when the maximum number of retransmissions is reached.
For more information about RSN key negotiation or update, see WLAN Security Configuration Guide.
To ensure successful RSN key negotiation or update, you can increase the maximum number of retransmissions and the maximum number of retries for an EAPOL-Key packet.
2.     Enter service template view.
wlan service-template service-template-name
3.     Set the maximum number of retransmissions for an EAPOL-Key packet and the retransmission interval.
option 4-way-handshake resend max-count [ interval interval ]
By default, the maximum number of retransmissions for an EAPOL-Key packet is three, and the retransmission interval is 300 milliseconds.
4.     Set the maximum number of retries for an EAPOL-Key packet and the retry interval.
option 4-way-handshake retry max-count [ interval interval ]
By default, the maximum number of retries for an EAPOL-Key packet is three, and the retry interval is 5 seconds.
Configuring client fast keepalive
To quickly determine whether clients are online and save radio resources, configure this feature to set the maximum number of unicast keepalive packets that an AP can send to a client. The AP logs off a client if it does not receive any replies from the client after sending three groups of keepalive packets within the specified keepalive packet sending interval. Packets specified by the count count-value option are counted as one group of keepalive packet.
This feature is mainly used in scenarios with high client mobility. If the network quality is poor, reduce the maximum number of keepalive packets that an AP can send to a client or set a smaller interval. As a best practice, use the default setting in scenarios with stable clients.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Configure the client fast keepalive feature.
rrop client fast-keep-alive { disable | enable [ count count-value ] [ interval interval-value] }
By default:
¡     In radio view, a radio uses the configuration in the AP group's radio view.
¡     In an AP group's radio view, the client fast keepalive feature is enabled.
Enabling client inspection
The client inspection feature enables you to view information about packets exchanged and time consumed in each stage of the client association process.
In the current software version, the client inspection feature supports only client association, client association failure, and IP address lease extension events.
2.     Enter AP view or AP group view.
¡     Enter AP view.
wlan ap ap-name
¡     Enter AP group view.
3.     Enable client inspection.
wlan client inspect enable
By default, client inspection is disabled.
Enabling data transmission holding during roaming
With data transmission holding during roaming enabled, the device caches the packets during client roaming and sends the packets to the client after the client roams successfully to reduce the packet loss during client roaming. With data transmission holding during roaming disabled, the device ages out the cached packets after a period of time and will not send the packets to the client. As a best practice, enable this feature in the packet loss-sensitive scenario.
To make this feature take effect, enable client association at the AC and enable the AC to forward client data traffic.
This feature is not supported in an AC hierarchy network or inter-AC roaming network.
3.     Enable data transmission holding during roaming.
sacp roam-optimize traffic-hold enable
By default, data transmission holding during roaming is disabled.
Enabling application traffic forwarding optimization
Application traffic forwarding optimization provides the following benefits:
·     Dual-WiFi-based application traffic optimization—After you enable dual-WiFi-based application traffic optimization and enable dual-WiFi on a wireless client, the client will establish a backup WiFi link with the AP. Data packets of the client will be transmitted through both the primary and backup WiFi links to improve the transmission reliability.
·     QoS-based application traffic optimization—After you enable QoS-based application traffic optimization, the device will preferentially process high-priority packets to improve the downlink transmission rate for audio and video traffic.
This feature is not supported in an AC hierarchy network.
2.     Enter wireless service template view.
3.     Enabling application traffic forwarding optimization.
sacp application optimization enable oppo [ dual-wifi | qos ]
By default, application traffic forwarding optimization is disabled.
