- 15-Network Management and Monitoring
- 01-HH3C-NTP-MIB
- 02-HH3C-RMON-EXT2-MIB
- 03-HH3C-SNMP-EXT-MIB
- 04-HH3C-TWAMP-MIB
- 05-RMON2-MIB
- 06-RMON-MIB
- 07-SFLOW-MIB
- 08-SNMP-FRAMEWORK-MIB
- 09-SNMP-MPD-MIB
- 10-SNMP-NOTIFICATION-MIB
- 11-SNMP-TARGET-MIB
- 12-SNMP-USER-BASED-SM-MIB
- 13-SNMPv2-MIB
- 14-SNMP-VIEW-BASED-ACM-MIB
- 15-DISMAN-EVENT-MIB
- 16-DISMAN-PING-MIB
- 17-DISMAN-TRACEROUTE-MIB
- 18-HH3C-MIRRORGROUP-MIB
- 19-HH3C-NQA-MIB
04-HH3C-TWAMP-MIB | 123.15 KB |
hh3cTwamplightSenderAdminTable
hh3cTwamplightSenderStatusTable
hh3cTwamplightTwoWayDelayTable
hh3cTwamplightSenderLossSeqTable
hh3cTwamplightSendDelaySeqTable
HH3C-TWAMP-MIB
About this MIB
Use HH3C-TWAMP-MIB to implement NQA TWAMP Light as follows:
· Enable the TWAMP Light client and the TWAMP Light sender.
· Configure and obtain information about test sessions on the TWAMP Light client.
· Configure and obtain packet sending intervals, timeout time of the reflected packet, and statistics collection interval for TWAMP Light tests on the TWAMP Light sender.
· Obtain the TWAMP Light sender status.
· Obtain two-way delay and two-way jitter statistics for TWAMP Light tests on the TWAMP Light sender.
· Obtain two-way packet loss statistics for TWAMP Light tests on the TWAMP Light sender.
· Obtain the largest index value in TWAMP loss results and TWAMP delay results.
· Clear statistics about TWAMP Light tests.
· Enable the TWAMP Light responder.
· Configure and obtain information about test sessions on the TWAMP Light responder.
MIB file name
hh3c-twamp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cTwamp(184)
Scalar objects
hh3cTwamplightClientEnable
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightClientEnable (1.3.6.1.4.1.25506.2.184.2.1.1) |
read-write |
TruthValue |
Standard MIB values. |
Enabling status of the TWAMP Light client. |
As per the MIB. |
hh3cTwamplightSenderEnable
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightSenderEnable (1.3.6.1.4.1.25506.2.184.2.1.2) |
read-write |
TruthValue |
Enabling status of the TWAMP Light sender. |
As per the MIB. |
Tabular objects
hh3cTwamplightClientTable
About this table
Use this table to configure and obtain information about test sessions on the TWAMP Light client.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cTwamplightControllerID.
The OID of the table is 1.3.6.1.4.1.25506.2.184.2.1.3
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightControllerID(1.3.6.1.4.1.25506.2.184.2.1.3.1.1) |
not-accessible |
Integer32 |
Integer32(1..512) |
Test session ID. |
Implementation varies by product. |
hh3cTwamplightClientSrcAddrType(1.3.6.1.4.1.25506.2.184.2.1.3.1.2) |
read-create |
InetAddressType |
Type of the source address. |
As per the MIB. |
hh3cTwamplightClientSrcAddr(1.3.6.1.4.1.25506.2.184.2.1.3.1.3) |
read-create |
InetAddress |
Source IP address. |
As per the MIB. |
hh3cTwamplightClientTrgtAddrType(1.3.6.1.4.1.25506.2.184.2.1.3.1.4) |
read-create |
InetAddressType |
Type of the destination IP address. |
As per the MIB. |
hh3cTwamplightClientTrgtAddr(1.3.6.1.4.1.25506.2.184.2.1.3.1.5) |
read-create |
InetAddress |
Destination IP address. |
As per the MIB. |
hh3cTwamplightClientSrcPort(1.3.6.1.4.1.25506.2.184.2.1.3.1.6) |
read-create |
Integer32 |
Integer32(0..65535) |
Source port number. |
As per the MIB. |
hh3cTwamplightClientTrgtPort(1.3.6.1.4.1.25506.2.184.2.1.3.1.7) |
read-create |
Integer32 |
Destination port number. |
As per the MIB. |
hh3cTwamplightClientVPN(1.3.6.1.4.1.25506.2.184.2.1.3.1.8) |
read-create |
DisplayString |
OCTET STRING(0..31) |
MPLS L3VPN instance name. |
As per the MIB. |
hh3cTwamplightClientDscp (1.3.6.1.4.1.25506.2.184.2.1.3.1.9) |
read-create |
Integer32 |
integer32(0..63) |
Differentiated services code point (DSCP) value. |
As per the MIB. |
hh3cTwamplightClientDataSize(1.3.6.1.4.1.25506.2.184.2.1.3.1.10) |
read-create |
Integer32 |
Integer32(44..1518) |
Probe packet size. |
As per the MIB. |
hh3cTwamplightClientDescription(1.3.6.1.4.1.25506.2.184.2.1.3.1.11) |
read-create |
DisplayString |
OCTET STRING(0..200) |
Description for the test session. |
As per the MIB. |
hh3cTwamplightClientRowStatus(1.3.6.1.4.1.25506.2.184.2.1.3.1.12) |
read-create |
RowStatus |
Manages the creation and deletion of the conceptual row. |
Supports only active(1), createAndGo(4), and destroy(6). |
hh3cTwamplightClientSrcIfName(1.3.6.1.4.1.25506.2.184.2.1.3.1.13) |
read-create |
DisplayString |
OCTET STRING(0..47) |
Source interface type and number. |
As per the MIB. |
hh3cTwamplightClientServiceID(1.3.6.1.4.1.25506.2.184.2.1.3.1.14) |
read-create |
Unsigned32 |
Unsigned32(1.. 4096) |
Ethernet service instance ID. |
As per the MIB. |
hh3cTwamplightClientDesMac(1.3.6.1.4.1.25506.2.184.2.1.3.1.15) |
read-create |
MacAddress |
Destination MAC address of the probe packets. |
As per the MIB. |
hh3cTwamplightClientSrcMac(1.3.6.1.4.1.25506.2.184.2.1.3.1.16) |
read-create |
MacAddress |
Source MAC address of the probe packets. |
As per the MIB. |
hh3cTwamplightClientTimeFormat(1.3.6.1.4.1.25506.2.184.2.1.3.1.17) |
read-create |
INTEGER |
ntp (1), ptp (2) |
Timestamp format of the probe packets. |
As per the MIB. |
hh3cTwamplightClientDataFill(1.3.6.1.4.1.25506.2.184.2.1.3.1.18) |
read-create |
DisplayString |
OCTET STRING(1..200) |
Payload fill string. |
As per the MIB. |
hh3cTwamplightClientDataFillType(1.3.6.1.4.1.25506.2.184.2.1.3.1.19) |
read-create |
INTEGER |
string (1), hex (2) |
Type of the payload fill string. |
As per the MIB. |
hh3cTwamplightClientSVlanID(1.3.6.1.4.1.25506.2.184.2.1.3.1.20) |
read-create |
Unsigned32 |
Unsigned32(1..4094) |
Outer VLAN ID of the probe packets. |
As per the MIB. |
hh3cTwamplightClientCVlanID(1.3.6.1.4.1.25506.2.184.2.1.3.1.21) |
read-create |
Unsigned32 |
Inner VLAN ID of the probe packets. |
As per the MIB. |
hh3cTwamplightClientVlanPriority(1.3.6.1.4.1.25506.2.184.2.1.3.1.22) |
read-create |
Unsigned32 |
Unsigned32(0..7) |
802.1p priority of the probe packets. |
As per the MIB. |
hh3cTwamplightClientBindIfName(1.3.6.1.4.1.25506.2.184.2.1.3.1.23) |
read-create |
DisplayString |
Name of the interface to which the session binds. |
As per the MIB. |
About this table
Use this table to configure and obtain information about TWAMP light tests.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The OID of the table is 1.3.6.1.4.1.25506.2.184.2.1.4
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightSendAdminContinual(1.3.6.1.4.1.25506.2.184.2.1.4.1.1) |
read-create |
Integer32 |
TWAMP test type. |
As per the MIB. |
hh3cTwamplightSendAdminDuration(1.3.6.1.4.1.25506.2.184.2.1.4.1.2) |
read-create |
Integer32 |
Integer32(60..3600) |
TWAMP test duration. |
As per the MIB. |
hh3cTwamplightSendAdminPktCount 1.3.6.1.4.1.25506.2.184.2.1.4.1.3) |
read-create |
Integer32 |
Integer32(100..30000) |
Number of packets to send for the TWAMP test. |
As per the MIB. |
hh3cTwamplightSendAdminTxPeriod 1.3.6.1.4.1.25506.2.184.2.1.4.1.4) |
read-create |
INTEGER |
interval10ms(1), interval100ms(2), interval1s(3), interval30s(4), interval10s(5) |
Interval at which probe packets are sent for the TWAMP test. |
Supports only interval10ms(1), interval100ms(2), interval1s(3), interval30s(4), and interval10s(5). |
hh3cTwamplightSendAdminTimeOut (1.3.6.1.4.1.25506.2.184.2.1.4.1.5) |
read-create |
Integer32 |
Integer32(1..60) |
Timeout time for TWAMP response packets. |
hh3cTwamplightSendAdminRowStatus(1.3.6.1.4.1.25506.2.184.2.1.4.1.6) |
read-create |
RowStatus |
Supports only createAndGo(4) and destory(6). |
About this table
Use this MIB to obtain the TWAMP Light sender status.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The OID of the table is 1.3.6.1.4.1.25506.2.184.2.1.5.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightSenderStatus(1.3.6.1.4.1.25506.2.184.2.1.5.1.1) |
read-only |
INTEGER |
inactive(1), active(2) |
Operational state of a TWAMP test. |
Supports only inactive(1) and active(2). |
hh3cTwamplightSenderStatusType(1.3.6.1.4.1.25506.2.184.2.1.5.1.2) |
read-only |
INTEGER |
init(0), continual(1), onDemand(2) |
Operational type of a TWAMP test. |
Supports only init(0), continual(1), and onDemand(2). |
hh3cTwamplightLastStartTime(1.3.6.1.4.1.25506.2.184.2.1.5.1.4) |
read-only |
DateAndTime |
Date and time when the most recent test started. |
As per the MIB. |
hh3cTwamplightLastStopTime(1.3.6.1.4.1.25506.2.184.2.1.5.1.5) |
read-only |
DateAndTime |
Date and time when the most recent test stopped. |
As per the MIB. |
About this table
Use this table to obtain statistics result about TWAMP Light tests.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cTwamplightControllerID and hh3cTwamplightTWDelaySeq.
The OID of the table is 1.3.6.1.4.1.25506.2.184.2.1.6.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightTWDelaySeq(1.3.6.1.4.1.25506.2.184.2.1.6.1.1) |
read-only |
Gauge32 |
Sequence number. |
As per the MIB. |
hh3cTwamplightTWDelayAvgDelay (1.3.6.1.4.1.25506.2.184.2.1.6.1.2) |
read-only |
Integer32 |
Average delay. |
As per the MIB. |
hh3cTwamplightTWDelayMaxDelay (1.3.6.1.4.1.25506.2.184.2.1.6.1.3) |
read-only |
Integer32 |
Maximum delay. |
As per the MIB. |
hh3cTwamplightTWDelayMinDelay (1.3.6.1.4.1.25506.2.184.2.1.6.1.4) |
read-only |
Integer32 |
Minimum delay. |
As per the MIB. |
hh3cTwamplightTWDelayAvgJitter(1.3.6.1.4.1.25506.2.184.2.1.6.1.5) |
read-only |
Integer32 |
Average jitter. |
As per the MIB. |
hh3cTwamplightTWDelayMaxJitter(1.3.6.1.4.1.25506.2.184.2.1.6.1.6) |
read-only |
Integer32 |
Maximum jitter. |
As per the MIB. |
hh3cTwamplightTWDelayMinJitter(1.3.6.1.4.1.25506.2.184.2.1.6.1.7) |
read-only |
Integer32 |
Minimum jitter. |
As per the MIB. |
hh3cTwamplightTWDelayAvgJitterSD (1.3.6.1.4.1.25506.2.184.2.1.6.1.8) |
read-only |
Integer32 |
Average jitter from source to destination. |
As per the MIB. |
hh3cTwamplightTWDelayMaxJitterSD (1.3.6.1.4.1.25506.2.184.2.1.6.1.9) |
read-only |
Integer32 |
Maximum jitter from source to destination. |
As per the MIB. |
hh3cTwamplightTWDelayMinJitterSD (1.3.6.1.4.1.25506.2.184.2.1.6.1.10) |
read-only |
Integer32 |
Minimum jitter from source to destination. |
As per the MIB. |
hh3cTwamplightTWDelayAvgJitterDS (1.3.6.1.4.1.25506.2.184.2.1.6.1.11) |
read-only |
Integer32 |
Average jitter from destination to source. |
As per the MIB. |
hh3cTwamplightTWDelayMaxJitterDS (1.3.6.1.4.1.25506.2.184.2.1.6.1.12) |
read-only |
Integer32 |
Maximum jitter from destination to source. |
As per the MIB. |
hh3cTwamplightTWDelayMinJitterDS (1.3.6.1.4.1.25506.2.184.2.1.6.1.13) |
read-only |
Integer32 |
Minimum jitter from destination to source. |
As per the MIB. |
hh3cTwamplightTwoWayLossTable
About this table
Use this table to obtain packet loss statistics for TWAMP Light tests.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cTwamplightControllerID and hh3cTwamplightTWLossSeq.
The OID of the table is 1.3.6.1.4.1.25506.2.184.2.1.7.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightTWLossSeq(1.3.6.1.4.1.25506.2.184.2.1.7.1.1) |
read-only |
Gauge32 |
Sequence number. |
As per the MIB. |
hh3cTwamplightTWLossValue(1.3.6.1.4.1.25506.2.184.2.1.7.1.2) |
read-only |
Integer32 |
Number of lost packets in a statistical cycle of a TWAMP test. |
As per the MIB. |
hh3cTwamplightTWSentCount(1.3.6.1.4.1.25506.2.184.2.1.7.1.3) |
read-only |
Integer32 |
Number of sent packets in a statistical cycle of a TWAMP test. |
As per the MIB. |
hh3cTwamplightTWTotalLossValue(1.3.6.1.4.1.25506.2.184.2.1.7.1.4) |
read-only |
Integer32 |
Number of lost packets in the most recent 30 statistical cycle of a TWAMP test. |
As per the MIB. |
hh3cTwamplightTWTotalSentCount(1.3.6.1.4.1.25506.2.184.2.1.7.1.5) |
read-only |
Integer32 |
Number of sent packets in the most recent 30 statistical cycle of a TWAMP test. |
As per the MIB. |
hh3cTwamplightTWErrorCount1.3.6.1.4.1.25506.2.184.2.1.7.1.6) |
read-only |
Unsigned32 |
Number of error packets received in a statistical cycle of a TWAMP-light test. |
As per the MIB. |
hh3cTwamplightTWTotalErrorCount 1.3.6.1.4.1.25506.2.184.2.1.7.1.7) |
read-only |
Unsigned32 |
Number of error packets received in last 30 statistical cycles of a TWAMP-light test. |
As per the MIB. |
About this table
Use this table to obtain the largest index value in TWAMP loss results.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The OID of the table is 1.3.6.1.4.1.25506.2.184.2.1.8.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightLossSeqNumValue(1.3.6.1.4.1.25506.2.184.2.1.8.1.1) |
read-only |
Gauge32 |
Largest index value in TWAMP loss results. |
As per the MIB. |
About this table
Use this table to obtain the largest index value in TWAMP delay results.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The OID of the table is 1.3.6.1.4.1.25506.2.184.2.1.9.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightSenderDelaySeqNum(1.3.6.1.4.1.25506.2.184.2.1.9.1.1) |
read-only |
Gauge32 |
Largest index value in TWAMP delay results. |
As per the MIB. |
hh3cTwamplightResetStatTable
About this table
Use this table to clear TWAMP Light test statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
The OID of the table is 1.3.6.1.4.1.25506.2.184.2.1.10.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightResetStatistics(1.3.6.1.4.1.25506.2.184.2.1.10.1.1) |
read-create |
INTEGER |
single(1), all(2) |
Clears statistics for one or all TWAMP Light tests. |
Supports only set operations. Supports only single(1) and all(2). |
hh3cTwamplightReactionTable
About this table
Use this table to configure and obtain information about a reaction entry.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are hh3cTwamplightControllerID and hh3cTwamplightReactItemIndex.
The OID of the table is 1.3.6.1.4.1.25506.2.184.2.1.11.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightReactItemIndex(1.3.6.1.4.1.25506.2.184.2.1.11.1.1) |
not-accessible |
Unsigned32 |
Integer32(1..10) |
ID of a reaction entry |
As per the MIB. |
hh3cTwamplightReactCheckElement(1.3.6.1.4.1.25506.2.184.2.1.11.1.2) |
read-create |
INTEGER |
twoWayDelay(1), twoWayJitter(2), twoWayLoss(3) |
Monitored performance metric. |
As per the MIB. |
hh3cTwamplightReactUpperLimit(1.3.6.1.4.1.25506.2.184.2.1.11.1.3) |
read-create |
Unsigned32 |
Unsigned32(2..1000000) |
Lower threshold limit. |
As per the MIB. |
hh3cTwamplightReactLowerLimit (1.3.6.1.4.1.25506.2.184.2.1.11.1.4) |
read-create |
Integer32 |
Unsigned32(1..999999) |
Upper threshold limit. |
As per the MIB. |
hh3cTwamplightReactActionType(1.3.6.1.4.1.25506.2.184.2.1.11.1.5) |
read-create |
INTEGER |
none(0), trapOnly(1) |
Action for the threshold violation event. |
As per the MIB. |
hh3cTwamplightReactRowStatus(1.3.6.1.4.1.25506.2.184.2.1.11.1.6) |
read-create |
RowStatus |
Controls the creation and deletion of the conceptual row. |
Supports only active(1), createAndGo(4), and destory(6). |
hh3cTwamplightResponderTable
About this table
Use this table to configure and obtain information about test sessions on the TWAMP Light responder.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cTwamplightRespID.
The OID of the table is 1.3.6.1.4.1.25506.2.184.2.2.2.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightRespID(1.3.6.1.4.1.25506.2.184.2.2.2.1.1) |
not-accessible |
Integer32 |
Integer32(1..512) |
Test session ID. |
hh3cTwamplightRespSrcAddrType(1.3.6.1.4.1.25506.2.184.2.2.2.1.2) |
read-create |
InetAddressType |
As per the MIB. |
hh3cTwamplightRespSrcAddr(1.3.6.1.4.1.25506.2.184.2.2.2.1.3) |
read-create |
InetAddress |
As per the MIB. |
hh3cTwamplightRespTrgtAddrType(1.3.6.1.4.1.25506.2.184.2.2.2.1.4) |
read-create |
Integer32 |
As per the MIB. |
hh3cTwamplightRespTrgtAddr(1.3.6.1.4.1.25506.2.184.2.2.2.1.5) |
read-create |
OCTET STRING |
As per the MIB. |
hh3cTwamplightRespSrcPort(1.3.6.1.4.1.25506.2.184.2.2.2.1.6) |
read-create |
Integer32 |
Integer32(1..65535) |
As per the MIB. |
hh3cTwamplightRespTrgtPort(1.3.6.1.4.1.25506.2.184.2.2.2.1.7) |
read-create |
Integer32 |
As per the MIB. |
hh3cTwamplightRespVPN(1.3.6.1.4.1.25506.2.184.2.2.2.1.8) |
read-create |
DisplayString |
OCTET STRING(1..31) |
As per the MIB. |
hh3cTwamplightRespDescription(1.3.6.1.4.1.25506.2.184.2.2.2.1.9) |
read-create |
DisplayString |
Description about the test session. |
As per the MIB. |
hh3cTwamplightRespRowStatus(1.3.6.1.4.1.25506.2.184.2.2.2.1.10) |
read-create |
RowStauts |
active(1), createAndGo(4), destroy(6) |
hh3cTwamplightRespSrcIfName(1.3.6.1.4.1.25506.2.184.2.2.2.1.11) |
read-create |
DisplayString |
Source interface of the reflected packets. |
As per the MIB. |
hh3cTwamplightRespServiceID(1.3.6.1.4.1.25506.2.184.2.2.2.1.12) |
read-create |
Unsigned32 |
Unsigned32(1..4096) |
Ethernet service instance ID for the session. |
As per the MIB. |
hh3cTwamplightRespDesMac(1.3.6.1.4.1.25506.2.184.2.2.2.1.13) |
read-create |
MacAddress |
Destination MAC address of the reflected packets. |
As per the MIB. |
hh3cTwamplightRespSrcMac(1.3.6.1.4.1.25506.2.184.2.2.2.1.14) |
read-create |
MacAddress |
Source MAC address of the reflected packets. |
As per the MIB. |
hh3cTwamplightRespTimeFormat(1.3.6.1.4.1.25506.2.184.2.2.2.1.15) |
read-create |
INTEGER |
auto(0) ntp(1) ptp(2) |
Timestamp format of the reflected packets. |
As per the MIB. |
hh3cTwamplightRespSVlanID(1.3.6.1.4.1.25506.2.184.2.2.2.1.16) |
read-create |
Unsigned32 |
Outer VLAN ID of the reflected packets. |
As per the MIB. |
hh3cTwamplightRespCVlanID(1.3.6.1.4.1.25506.2.184.2.2.2.1.17) |
read-create |
Unsigned32 |
Inner VLAN ID of the reflected packets. |
As per the MIB. |
