15-Network Management and Monitoring
HomeSupportSwitchesS12500R SeriesReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10115-Network Management and Monitoring
13-SNMPv2-MIB
13-SNMPv2-MIB 96.44 KB
SNMPv2-MIB
About this MIB
Use this MIB to configure SNMPv2 basic settings and obtain SNMP packet statistics.
MIB file name
rfc3418-snmpv2.mib
Root object
iso(1).org(3).dod(6).internet(1).snmpV2(6).snmpModules(3).snmpMIB(1)
Scalar objects
snmpTrapOID
Object (OID)
Access
Value range
Implementation
snmpTrapOID (1.3.6.1.6.3.1.1.4.1)
accessible-for-notify
OBJECT IDENTIFIER
Standard MIB values.
OID of the notification currently being sent.
As per the MIB.
snmpTrapEnterprise
Object (OID)
Access
Value range
Implementation
snmpTrapEnterprise (1.3.6.1.6.3.1.1.4.3)
OBJECT IDENTIFIER
OID of the enterprise associated with the trap currently being sent.
As per the MIB.
snmpSetSerialNo
Object (OID)
Access
Value range
Implementation
snmpSetSerialNo (1.3.6.1.6.3.1.1.6.1)
read-write
TestAndIncr
An advisory lock used to allow several cooperating command generator applications to coordinate their use of the SNMP set operation.
As per the MIB.
snmpInPkts
Object (OID)
Access
Value range
Implementation
snmpInPkts (1.3.6.1.2.1.11.1)
read-only
Counter32
Total number of SNMP messages received on the SNMP agent.
As per the MIB.
snmpOutPkts
Object (OID)
Access
Value range
Implementation
snmpOutPkts (1.3.6.1.2.1.11.2)
read-only
Counter32
Total number of SNMP messages sent by the SNMP agent.
As per the MIB.
snmpInBadVersions
Object (OID)
Access
Value range
Implementation
snmpInBadVersions (1.3.6.1.2.1.11.3)
read-only
Counter32
Total number of received SNMP messages not supported by the SNMP version.
As per the MIB.
snmpInBadCommunityNames
Object (OID)
Access
Value range
Implementation
snmpInBadCommunityNames (1.3.6.1.2.1.11.4)
read-only
Counter32
Total number of received SNMP messages which used an SNMP community name unknown to the SNMP entity.
As per the MIB.
snmpInBadCommunityUses
Object (OID)
Access
Value range
Implementation
snmpInBadCommunityUses (1.3.6.1.2.1.11.5)
read-only
Counter32
Total number of messages carrying an operation that the community has no right to perform.
As per the MIB.
snmpInASNParseErrs
Object (OID)
Access
Value range
Implementation
snmpInASNParseErrs (1.3.6.1.2.1.11.6)
read-only
Counter32
Total number of received SNMP messages that had ASN.1 or BER errors during decoding.
As per the MIB.
snmpInTooBigs
Object (OID)
Access
Value range
Implementation
snmpInTooBigs (1.3.6.1.2.1.11.8)
read-only
Counter32
Total number of received SNMP PDUs with a TooBig error.
When read, this object always returns 0.
snmpInNoSuchNames
Object (OID)
Access
Value range
Implementation
snmpInNoSuchNames (1.3.6.1.2.1.11.9)
read-only
Counter32
Total number of received SNMP PDUs with a NoSuchName error.
snmpInBadValues
Object (OID)
Access
Value range
Implementation
snmpInBadValues (1.3.6.1.2.1.11.10)
read-only
Counter32
Total number of received SNMP PDUs with a BadValue error.
snmpInReadOnlys
Object (OID)
Access
Value range
Implementation
snmpInReadOnlys (1.3.6.1.2.1.11.11)
read-only
Counter32
Total number of received SNMP PDUs with a readOnly error.
snmpInGenErrs
Object (OID)
Access
Value range
Implementation
snmpInGenErrs (1.3.6.1.2.1.11.12)
read-only
Counter32
Total number of received SNMP PDUs with a genErr error.
snmpInTotalReqVars
Object (OID)
Access
Value range
Implementation
snmpInTotalReqVars (1.3.6.1.2.1.11.13)
read-only
Counter32
Total number of MIB objects that have been successfully retrieved.
As per the MIB.
snmpInTotalSetVars
Object (OID)
Access
Value range
Implementation
snmpInTotalSetVars (1.3.6.1.2.1.11.14)
read-only
Counter32
Total number of MIB objects that have been successfully modified.
As per the MIB.
snmpInGetRequests
Object (OID)
Access
Value range
Implementation
snmpInGetRequests (1.3.6.1.2.1.11.15)
read-only
Counter32
Total number of GetRequest requests that have been received and processed.
As per the MIB.
snmpInGetNexts
Object (OID)
Access
Value range
Implementation
snmpInGetNexts (1.3.6.1.2.1.11.16)
read-only
Counter32
Total number of getNext requests that have been received and processed.
As per the MIB.
snmpInSetRequests
Object (OID)
Access
Value range
Implementation
snmpInSetRequests (1.3.6.1.2.1.11.17)
read-only
Counter32
Total number of set requests that have been received and processed.
As per the MIB.
snmpOutTooBigs
Object (OID)
Access
Value range
Implementation
snmpOutTooBigs (1.3.6.1.2.1.11.20)
read-only
Counter32
Total number of sent SNMP PDUs with a TooBig error.
As per the MIB.
snmpOutNoSuchNames
Object (OID)
Access
Value range
Implementation
snmpOutNoSuchNames (1.3.6.1.2.1.11.21)
read-only
Counter32
Total number of sent SNMP PDUs with a NoSuchName error.
As per the MIB.
snmpOutBadValues
Object (OID)
Access
Value range
Implementation
snmpOutBadValues (1.3.6.1.2.1.11.22)
read-only
Counter32
Total number of sent SNMP PDUs with a BadValues error.
As per the MIB.
snmpOutGenErrs
Object (OID)
Access
Value range
Implementation
snmpOutGenErrs (1.3.6.1.2.1.11.24)
read-only
Counter32
Total number of sent SNMP PDUs with a genErr error.
As per the MIB.
snmpOutGetRequests
Object (OID)
Access
Value range
Implementation
snmpOutGetRequests (1.3.6.1.2.1.11.25)
read-only
Counter32
Total number of sent SNMP Get-Request PDUs.
As per the MIB.
snmpOutGetNexts
Object (OID)
Access
Value range
Implementation
snmpOutGetNexts (1.3.6.1.2.1.11.26)
read-only
Counter32
Total number of sent SNMP Get-Next PDUs.
As per the MIB.
snmpOutSetRequests
Object (OID)
Access
Value range
Implementation
snmpOutSetRequests (1.3.6.1.2.1.11.27)
read-only
Counter32
Total number of sent SNMP Set-Request PDUs.
As per the MIB.
snmpOutGetResponses
Object (OID)
Access
Value range
Implementation
snmpOutGetResponses (1.3.6.1.2.1.11.28)
read-only
Counter32
Total number of sent SNMP Get-Response PDUs.
As per the MIB.
snmpOutTraps
Object (OID)
Access
Value range
Implementation
snmpOutTraps (1.3.6.1.2.1.11.29)
read-only
Counter32
Total number of notifications sent by the SNMP entity.
As per the MIB.
snmpEnableAuthenTraps
Object (OID)
Access
Value range
Implementation
snmpEnableAuthenTraps (1.3.6.1.2.1.11.30)
read-write
INTEGER
enabled(1),
disabled(2)
Whether authenticationFailure traps are enabled.
The default value is enabled(1).
snmpSilentDrops
Object (OID)
Access
Value range
Implementation
snmpSilentDrops (1.3.6.1.2.1.11.31)
read-only
Counter32
Number of packets delivered to but dropped by the SNMP entity because the response packet size exceeded the limit.
As per the MIB.
snmpProxyDrops
Object (OID)
Access
Value range
Implementation
snmpProxyDrops (1.3.6.1.2.1.11.32)
read-only
Counter32
Total number of packets delivered to but dropped by the SNMP entity because transmission of the message to a proxy target failed.
Notifications
This section contains SNMPv2-MIB notifications.
coldStart
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.6.3.1.1.5.1
SNMP agent cold start
Informational
Warning
N/A
ON
This notification is generated when an SNMP agent is reinitializing itself with the configuration probably changed.
Status control
ON
CLI: snmp-agent trap enable standard coldstart
OFF
CLI: undo snmp-agent trap enable standard coldstart
Objects
N/A
Recommended action
No action is required.
warmStart
Basic information
OID
Event
Severity
Default status
1.3.6.1.6.3.1.1.5.2
SNMP agent warm start
Informational
Warning
N/A
ON
This notification is generated when an SNMPv2 agent is reinitializing itself with the configuration unaltered.
Status control
ON
CLI: snmp-agent trap enable standard warmstart
OFF
CLI: undo snmp-agent trap enable standard warmstart
Objects
N/A
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.6.3.1.1.5.5
SNMP authentication failure
Informational
Warning
N/A
ON
This notification is generated when an SNMPV2 agent receives a protocol message that is not properly authenticated. While all implementations of the SNMPv2 must be capable of generating this trap, the snmpEnableAuthenTraps object indicates whether this trap will be generated.
Status control
ON
CLI: snmp-agent trap enable standard authentication
OFF
CLI: undo snmp-agent trap enable standard authentication
Objects
N/A
Recommended action
1.     Verify that the agent and network management system are configured with the same SNMP settings.
2.     Identify whether a network attack has occurred.
3.     If the issue persists, contact H3C Support.
