15-Network Management and Monitoring
HomeSupportSwitchesS12500R SeriesReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10115-Network Management and Monitoring
06-RMON-MIB
06-RMON-MIB 84.06 KB
RMON-MIB
About this MIB
Use this MIB to monitor data traffic on a network segment or the entire network.
MIB file name
rfc2819-rmon.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).rmon(16)
Tabular objects
etherStatsTable
About this table
Use this table to obtain statistics about Ethernet interfaces.
Support for operations
Create
Edit/Modify
Delete
Read
You must specify etherStatsDataSource and etherStatsStatus in pairs when creating a row of instances.
Not supported
Supported
Supported
Columns
The table index is etherStatsIndex.
Object (OID)
Access
Value range
Implementation
etherStatsIndex (1.3.6.1.2.1.16.1.1.1.1)
read-only
Integer32
Integer32 (1..65535)
Index of an etherStats entry.
As per the MIB.
etherStatsDataSource (1.3.6.1.2.1.16.1.1.1.2)
read-create
OBJECT IDENTIFIER
Standard MIB values.
Interface on which statistics are gathered.
As per the MIB.
etherStatsDropEvents (1.3.6.1.2.1.16.1.1.1.3)
read-only
Counter32
Total number of events in which packets were dropped.
Implementation varies by product..
etherStatsOctets (1.3.6.1.2.1.16.1.1.1.4)
read-only
Counter32
Total number of octets received on the interface.
etherStatsPkts (1.3.6.1.2.1.16.1.1.1.5)
read-only
Counter32
Total number of packets received on the interface.
etherStatsBroadcastPkts (1.3.6.1.2.1.16.1.1.1.6)
read-only
Counter32
Total number of broadcast packets received on the interface.
etherStatsMulticastPkts (1.3.6.1.2.1.16.1.1.1.7)
read-only
Counter32
Total number of multicast packets received on the interface.
etherStatsCRCAlignErrors (1.3.6.1.2.1.16.1.1.1.8)
read-only
Counter32
Total number of packets with CRC errors received on the interface.
etherStatsUndersizePkts (1.3.6.1.2.1.16.1.1.1.9)
read-only
Counter32
Total number of undersize packets received on the interface.
etherStatsOversizePkts (1.3.6.1.2.1.16.1.1.1.10)
read-only
Counter32
Total number of oversize packets received on the interface.
etherStatsFragments (1.3.6.1.2.1.16.1.1.1.11)
read-only
Counter32
Total number of undersize packets with FCS errors received on the interface.
etherStatsJabbers (1.3.6.1.2.1.16.1.1.1.12)
read-only
Counter32
Total number of oversize packets with FCS errors received on the interface.
etherStatsCollisions (1.3.6.1.2.1.16.1.1.1.13)
read-only
Counter32
Total number of colliding packets received on the interface.
etherStatsPkts64Octets (1.3.6.1.2.1.16.1.1.1.14)
read-only
Counter32
Total number of packets with a length smaller than or equal to 64 octets received on the interface.
etherStatsPkts65to127Octets (1.3.6.1.2.1.16.1.1.1.15)
read-only
Counter32
Total number of 65- to 127-octet packets received on the interface.
etherStatsPkts128to255Octets (1.3.6.1.2.1.16.1.1.1.16)
read-only
Counter32
Total number of 128- to 255-octet packets received on the interface
etherStatsPkts256to511Octets (1.3.6.1.2.1.16.1.1.1.17)
read-only
Counter32
Total number of 256- to 511-octet packets received on the interface.
etherStatsPkts512to1023Octets (1.3.6.1.2.1.16.1.1.1.18)
read-only
Counter32
Total number of 512- to 1023-octet packets received on the interface
etherStatsPkts1024to1518Octets (1.3.6.1.2.1.16.1.1.1.19)
read-only
Counter32
Total number of 1024- to 1518-octet packets received on the interface
etherStatsOwner (1.3.6.1.2.1.16.1.1.1.20)
read-create
OwnerString
OCTET STRING (0..127)
Owner of the etherStats entry.
Not-displayable characters or question marks are not allowed.
The default value is a zero-length string.
etherStatsStatus (1.3.6.1.2.1.16.1.1.1.21)
read-create
EntryStatus
valid(1),
createRequest(2),
underCreation(3),
invalid(4)
Status of the etherStats entry.
As per the MIB.
historyControlTable
About this table
Use this table to configure history control entries.
Create
Edit/Modify
Delete
Read
You must specify historyControlDataSource and historyControlStatus in pairs when creating an instance.
Not supported
Supported
Supported
Columns
The table index is historyControlIndex.
Object (OID)
Access
Value range
Implementation
historyControlIndex (1.3.6.1.2.1.16.2.1.1.1)
read-only
Integer32
Index of a historyControl entry.
As per the MIB.
historyControlDataSource (1.3.6.1.2.1.16.2.1.1.2)
read-create
OBJECT IDENTIFIER
Interface on which historical data was collected.
As per the MIB.
historyControlBucketsRequested (1.3.6.1.2.1.16.2.1.1.3)
read-create
Integer32
Requested number of samples to be retained for the entry.
A maximum of 50 samples are supported.
You can set a value larger than 50 for this object, but only 50 samples are supported.
historyControlBucketsGranted (1.3.6.1.2.1.16.2.1.1.4)
read-only
Integer32
Granted number of samples to be retained for the entry.
As per the MIB.
historyControlInterval (1.3.6.1.2.1.16.2.1.1.5)
read-create
Integer32
Integer32 (1..3600)
Sampling interval in seconds.
Value range: 5 to 3600
Default: 1800
historyControlOwner (1.3.6.1.2.1.16.2.1.1.6)
read-create
OwnerString
Owner of this entry.
historyControlStatus (1.3.6.1.2.1.16.2.1.1.7)
read-create
EntryStatus
valid(1),
createRequest(2),
underCreation(3),
invalid(4)
Statistics about this entry.
As per the MIB.
etherHistoryTable
About this table
Use this table to obtain information about RMON history control entries and history samples of Ethernet statistics for Ethernet interfaces.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are etherHistoryIndex and etherHistorySampleIndex.
Object (OID)
Access
Value range
Implementation
etherHistoryIndex (1.3.6.1.2.1.16.2.2.1.1)
read-only
Integer32
Index of an etherHistory entry.
As per the MIB.
etherHistorySampleIndex (1.3.6.1.2.1.16.2.2.1.2)
read-only
Integer32
Integer32 (1..2147483647)
Index of a sample.
As per the MIB.
etherHistoryIntervalStart (1.3.6.1.2.1.16.2.2.1.3)
read-only
TimeTicks
Sampling start time.
As per the MIB.
etherHistoryDropEvents (1.3.6.1.2.1.16.2.2.1.4)
read-only
Counter32
Total number of events in which packets were dropped during this sampling interval.
etherHistoryOctets (1.3.6.1.2.1.16.2.2.1.5)
read-only
Counter32
Total number of octets received on the interface during this sampling interval.
etherHistoryPkts (1.3.6.1.2.1.16.2.2.1.6)
read-only
Counter32
Total number of packets received during this sampling interval.
etherHistoryBroadcastPkts (1.3.6.1.2.1.16.2.2.1.7)
read-only
Counter32
Total number of broadcast packets received during this sampling interval.
etherHistoryMulticastPkts (1.3.6.1.2.1.16.2.2.1.8)
read-only
Counter32
Total number of multicast packets received during this sampling interval.
etherHistoryCRCAlignErrors (1.3.6.1.2.1.16.2.2.1.9)
read-only
Counter32
Total number of packets with CRC alignment errors received during the sampling interval.
etherHistoryUndersizePkts (1.3.6.1.2.1.16.2.2.1.10)
read-only
Counter32
Total number of undersize packets received during the sampling interval.
etherHistoryOversizePkts (1.3.6.1.2.1.16.2.2.1.11)
read-only
Counter32
Total number of oversize packets received during the sampling interval.
etherHistoryFragments (1.3.6.1.2.1.16.2.2.1.12)
read-only
Counter32
Total number of undersize packets with FCS errors received during the sampling interval.
etherHistoryJabbers (1.3.6.1.2.1.16.2.2.1.13)
read-only
Counter32
Total number of oversize packets with FCS errors received during the sampling interval.
etherHistoryCollisions (1.3.6.1.2.1.16.2.2.1.14)
read-only
Counter32
Total number of colliding packets received during the sampling interval.
etherHistoryUtilization (1.3.6.1.2.1.16.2.2.1.15)
read-only
Integer32
Integer32 (0..10000)
Bandwidth utilization during the sampling period.
alarmTable
About this table
Use this table to configure alarm entries.
Create
Edit/Modify
Delete
Read
You must specify alarmVariable and alarmStatus in pairs when creating a row of instances. If the buildruns of the instances exceed the maximum specification, the creation fails.
Not supported
Supported
Supported
Columns
The table index is alarmIndex.
Object (OID)
Access
Value range
Implementation
alarmIndex (1.3.6.1.2.1.16.3.1.1.1)
read-only
Integer32
Index of an RMON alarm entry.
As per the MIB.
alarmInterval (1.3.6.1.2.1.16.3.1.1.2)
read-create
Integer32
Value range: 5 to 3600.
Default value: 1800.
alarmVariable (1.3.6.1.2.1.16.3.1.1.3)
read-create
OBJECT IDENTIFIER
OID of the variable to be sampled.
As per the MIB.
alarmSampleType (1.3.6.1.2.1.16.3.1.1.4)
read-create
INTEGER
absoluteValue(1),
deltaValue(2)
Sampling type.
Default value: absoluteValue(1).
alarmValue (1.3.6.1.2.1.16.3.1.1.5)
read-only
Integer32
Value of the sampled variable.
If the object value exceeds the maximum positive value, the negation of the object value is returned when read.
alarmStartupAlarm (1.3.6.1.2.1.16.3.1.1.6)
read-create
INTEGER
risingAlarm(1),
fallingAlarm(2),
risingOrFallingAlarm(3)
Alarms that can be generated at the first sampling.
Default value: risingOrFallingAlarm(3).
alarmRisingThreshold (1.3.6.1.2.1.16.3.1.1.7)
read-create
Integer32
Rising threshold.
Default value: 1.
alarmFallingThreshold (1.3.6.1.2.1.16.3.1.1.8)
read-create
Integer32
Falling threshold.
Default value: 0.
alarmRisingEventIndex (1.3.6.1.2.1.16.3.1.1.9)
read-create
Integer32
Integer32 (0..65535)
Index of the event that is triggered when the rising threshold is crossed.
Default value: 0.
alarmFallingEventIndex (1.3.6.1.2.1.16.3.1.1.10)
read-create
Integer32
Index of the event that is triggered when the falling threshold is crossed.
Default value: 0.
alarmOwner (1.3.6.1.2.1.16.3.1.1.11)
read-create
OwnerString
Owner of the alarm entry.
Default value: zero-length string.
alarmStatus (1.3.6.1.2.1.16.3.1.1.12)
read-create
EntryStatus
valid(1), createRequest(2), underCreation(3), invalid(4)
Status of the alarm entry.
As per the MIB.
eventTable
About this table
Use this table to configure event entries.
Create
Edit/Modify
Delete
Read
Supported.
You must specify eventStatus when creating a row of instances. If the buildruns of the instances exceed the maximum specification, the creation fails.
Not supported
Supported
Supported
Columns
The table index is eventIndex.
Object (OID)
Access
Value range
Implementation
eventIndex (1.3.6.1.2.1.16.9.1.1.1)
read-only
Integer32
Event entry index.
As per the MIB.
eventDescription (1.3.6.1.2.1.16.9.1.1.2)
read-create
DisplayString
Event description.
Default value: Zero-length string.
eventType (1.3.6.1.2.1.16.9.1.1.3)
read-create
INTEGER
none(1), log(2), snmptrap(3), logandtrap(4)
Event type.
Default value: none(1)
eventCommunity (1.3.6.1.2.1.16.9.1.1.4)
read-create
OCTET STRING
SNMP community to which an SNMP trap is sent.
Not supported.
eventLastTimeSent (1.3.6.1.2.1.16.9.1.1.5)
read-only
TimeTicks
TimeTicks (0..4294967295)
Time at which the most recent event occurs.
As per the MIB.
eventOwner (1.3.6.1.2.1.16.9.1.1.6)
read-create
OwnerString
Event owner.
eventStatus (1.3.6.1.2.1.16.9.1.1.7)
read-create
EntryStatus
Event status.
As per the MIB.
logTable
About this table
Use this table to obtain event logs.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are logEventIndex and logIndex.
Object (OID)
Access
Value range
Implementation
logEventIndex (1.3.6.1.2.1.16.9.2.1.1)
read-only
Integer32
Index of the event entry that generated this log entry.
As per the MIB.
logIndex (1.3.6.1.2.1.16.9.2.1.2)
read-only
Integer32
Index of the log entry.
As per the MIB.
logTime (1.3.6.1.2.1.16.9.2.1.3)
read-only
TimeTicks
Time when the log entry was created.
As per the MIB.
logDescription (1.3.6.1.2.1.16.9.2.1.4)
read-only
DisplayString
OCTET STRING (0..255)
Description of the event that activated this log entry.
As per the MIB.
Notifications
This section contains the RMON-MIB notifications.
risingAlarm
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.16.0.1
An alarm entry crossed its rising threshold
Informational
Warning
N/A
ON
This notification is generated when an alarm entry crosses its rising threshold and generates an event configured for sending SNMP traps.
Status control
ON
CLI: Use the rmon event entry-number [ description string ] { log-trap security-string | trap security-string } [ owner text ] command.
OFF
CLI: Use the rmon event entry-number [ description string ] { log | none } [ owner text ] command.
Objects
OID (object name)
Index
Value range
1.3.6.1.2.1.16.3.1.1.1 (alarmIndex)
Index of the alarm entry
Y
Integer32
1..65535
1.3.6.1.2.1.16.3.1.1.3 (alarmVariable)
Variable to be sampled
N
OBJECT IDENTIFIER
1.3.6.1.2.1.16.3.1.1.4 (alarmSampleType)
Sampling type
N
INTEGER
absoluteValue(1)
deltaValue(2)
1.3.6.1.2.1.16.3.1.1.5 (alarmValue)
Sampled value
N
Integer32
1.3.6.1.2.1.16.3.1.1.7 (alarmRisingThreshold)
Rising threshold
N
Integer32
Recommended action
To resolve the issue:
1. Check the monitored object for the reason that causes the alarm.
2. If the issue persists, contact H3C Support.
