04-Layer 2 - LAN Switching
HomeSupportSwitchesS12500R SeriesReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10104-Layer 2 - LAN Switching
23-HH3C-PVST-MIB
23-HH3C-PVST-MIB 40.45 KB
HH3C-PVST-MIB
About this MIB
PVST allows every VLAN to have its own spanning tree, which increases usage of links and bandwidth. Because each VLAN runs RSTP independently, a spanning tree only serves its VLAN.
Use this MIB to configure PVST.
MIB file name
hh3c-pvst.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).h3cCommon(2).hh3cPvst(131)
Tabular objects
hh3cPvstVlanConfigTable
About this table
Use this table to configure a PVST VLAN.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table index is hh3cPvstVlanID.
Object (OID)
Access
Value range
Implementation
hh3cPvstVlanID (1.3.6.1.4.1.25506.2.131.1.1.1.1)
read-only
Integer32
1..4094
VLAN index.
Not supported
hh3cPvstVlanPortConfigTable
About this table
Use this table to configure a VLAN on a PVST port.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table indexes are hh3cPvstPortVlanID and hh3cPvstPortIndex.
Object (OID)
Access
Value range
Implementation
hh3cPvstPortVlanID (1.3.6.1.4.1.25506.2.131.1.2.1.1)
read-only
Integer32
1..4094
VLAN index.
Not supported
hh3cPvstPortIndex (1.3.6.1.4.1.25506.2.131.1.2.1.2)
read-only
Integer32
1..2147483647
Port index.
Not supported
