- 04-Layer 2 - LAN Switching
- 01-IEEE8021-CFM-MIB
- 02-IEEE8023-LAG-MIB
- 03-LLDP-EXT-DOT1-MIB
- 04-LLDP-EXT-DOT1-V2-MIB
- 05-LLDP-EXT-DOT3-MIB
- 06-LLDP-EXT-DOT3-V2-MIB
- 07-LLDP-EXT-MED-MIB
- 08-LLDP-MIB
- 09-LLDP-V2-MIB
- 10-MAU-MIB
- 11-P-BRIDGE-MIB
- 12-Q-BRIDGE-MIB
- 13-BRIDGE-MIB
- 14-EtherLike-MIB
- 15-HH3C-LAG-MIB
- 16-HH3C-LLDP-EXT-MIB
- 17-HH3C-LPBKDT-MIB
- 18-HH3C-LswMAM-MIB
- 19-HH3C-LswMSTP-MIB
- 20-HH3C-LswVLAN-MIB
- 21-HH3C-MAC-INFORMATION-MIB
- 22-HH3C-MLAG-MIB
- 23-HH3C-PVST-MIB
- 24-HH3C-QINQV2-MIB
- 25-HH3C-VLANTERM-MIB
- 26-HH3C-VMAP-MIB
| 19-HH3C-LswMSTP-MIB | 123.76 KB |
hh3cdot1sMstAdminFormatSelector
hh3cdot1sMstAdminRevisionLevel
HH3C-LswMSTP-MIB
About this MIB
Spanning tree protocols eliminate loops by selectively blocking ports to prune the loop structure into a loop-free tree structure.
This MIB defines private MIB objects for MSTP.
MIB file name
hh3c-splat-mstp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).huawei(2011).products(2).lanSw(23).lswCommon(1).hwdotlsMstp(14)
Scalar objects
hh3cdot1sStpStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sStpStatus (1.3.6.1.4.1.25506.8.35.14.1) |
read-write |
EnabledStatus |
enabled(1) disabled(2) |
MSTP status. |
As per the MIB. |
hh3cdot1sStpForceVersion
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sStpForceVersion (1.3.6.1.4.1.25506.8.35.14.2) |
read-write |
INTEGER |
stp(0) rstp(2) mstp(3) |
Spanning tree mode. |
Same as MIB definition. The value for PVST is 2. |
hh3cdot1sStpDiameter
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sStpDiameter (1.3.6.1.4.1.25506.8.35.14.3) |
read-write |
INTEGER |
2..7 |
Network diameter. |
This object is related to the dot1dStpHelloTime, dot1dStpMaxAge, and dot1dStpForwardDelay objects defined in IEEE 802.1d. Modification to the hh3cdot1sStpDiameter object will change the values of those objects. Modification to any of the dot1dStpHelloTime, dot1dStpMaxAge, and dot1dStpForwardDelay objects will invalidate the value of the hh3cdot1sStpDiameter object. |
hh3cdot1sMstBridgeMaxHops
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstBridgeMaxHops (1.3.6.1.4.1.25506.8.35.14.4) |
read-write |
INTEGER |
1..40 |
Maximum hops of an MST region. |
As per the MIB. |
hh3cdot1sMstMasterBridgeID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstMasterBridgeID (1.3.6.1.4.1.25506.8.35.14.5) |
read-only |
BridgeId |
OCTET STRING (8) |
Root bridge in an MSTP region. |
As per the MIB. |
hh3cdot1sMstMasterPathCost
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstMasterPathCost (1.3.6.1.4.1.25506.8.35.14.6) |
read-only |
INTEGER |
Standard MIB values. |
Cost of the path to the root bridge. |
As per the MIB. |
hh3cdot1sMstBpduGuard
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstBpduGuard (1.3.6.1.4.1.25506.8.35.14.7) |
read-write |
EnabledStatus |
BPDU guard. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstAdminFormatSelector (1.3.6.1.4.1.25506.8.35.14.8) |
read-write |
INTEGER |
0. |
Bridge selection factor. |
This object is configurable, and you can set it only to 0. |
hh3cdot1sMstAdminRegionName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstAdminRegionName (1.3.6.1.4.1.25506.8.35.14.9) |
read-write |
OCTET STRING |
SIZE (1..32) |
MST region name. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstAdminRevisionLevel (1.3.6.1.4.1.25506.8.35.14.10) |
read-write |
INTEGER |
0..65535 |
MSTP revision level. |
As per the MIB. |
hh3cdot1sMstOperFormatSelector
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstOperFormatSelector (1.3.6.1.4.1.25506.8.35.14.11) |
read-only |
INTEGER |
Effective selection factor of an MSTP region. |
As per the MIB. |
hh3cdot1sMstOperRegionName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstOperRegionName (1.3.6.1.4.1.25506.8.35.14.12) |
read-only |
OCTET STRING |
SIZE (0..32) |
Effective MST region name. |
As per the MIB. |
hh3cdot1sMstOperRevisionLevel
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstOperRevisionLevel (1.3.6.1.4.1.25506.8.35.14.13) |
read-only |
INTEGER |
0..65535 |
Effective MSTP revision level. |
As per the MIB. |
hh3cdot1sMstOperConfigDigest
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstOperConfigDigest (1.3.6.1.4.1.25506.8.35.14.14) |
read-only |
OCTET STRING
SIZE (0..16) |
Effective configuration digest of an MST region. |
As per the MIB. |
hh3cdot1sMstRegionConfActive
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstRegionConfActive (1.3.6.1.4.1.25506.8.35.14.15) |
read-write |
INTEGER |
enable(1) disable(2) |
Activate MST region configuration. |
Default: Enabled. If you set the value to disable, MST region configuration is read-only and does not take effect. |
hh3cdot1sMstDefaultVlanAllo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstDefaultVlanAllo (1.3.6.1.4.1.25506.8.35.14.16) |
read-write |
INTEGER |
enable(1) unused(65535) |
Default VLAN-to-instance mappings in an MST region. |
As per the MIB. |
hh3cdot1sMstDefaultRegionName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstDefaultRegionName (1.3.6.1.4.1.25506.8.35.14.17) |
read-write |
INTEGER |
Default MST region name. |
As per the MIB. |
hh3cdot1sStpPathCostStandard
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sStpPathCostStandard (1.3.6.1.4.1.25506.8.35.14.21) |
read-write |
INTEGER |
legacy(0) dot1d-1998(1) dot1t(2) |
Standard for calculating the default path costs. |
· legacy—Private standard. · dot1d-1998—IEEE 802.1d-1998. · dot1t—IEEE 802.1t. |
Tabular objects
hh3cdot1sVIDAllocationTable
About this table
Use this table to configure MSTP VLAN settings.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is hh3cdot1sMstVID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstVID (1.3.6.1.4.1.25506.8.35.14.18.1.1) |
read-only |
INTEGER |
1..4094 |
VLAN ID |
As per the MIB. |
hh3cdot1sAdminMstID (1.3.6.1.4.1.25506.8.35.14.18.1.2) |
read-write |
INTEGER |
0..4094 |
Configured MST region mapping. |
As per the MIB. |
hh3cdot1sOperMstID (1.3.6.1.4.1.25506.8.35.14.18.1.3) |
read-only |
INTEGER |
0..4094 |
Effective MST region mapping. |
As per the MIB. |
hh3cdot1sInstanceTable
About this table
Use this table to configure MST region settings.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is hh3cdot1sInstanceID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sInstanceID (1.3.6.1.4.1.25506.8.35.14.19.1.1) |
read-only |
INTEGER |
0..4094 |
Instance ID. |
As per the MIB. |
hh3cdot1sMstiBridgeID (1.3.6.1.4.1.25506.8.35.14.19.1.2) |
read-only |
BridgeId |
OCTET STRING (8) |
Bridge ID. |
As per the MIB. |
hh3cdot1sMstiBridgePriority (1.3.6.1.4.1.25506.8.35.14.19.1.3) |
read-write |
INTEGER |
0..61440 |
Bridge priority. |
As per the MIB. |
hh3cdot1sMstiDesignedRoot (1.3.6.1.4.1.25506.8.35.14.19.1.4) |
read-only |
BridgeId |
OCTET STRING (8) |
Root bridge. |
As per the MIB. |
hh3cdot1sMstiRootPathCost (1.3.6.1.4.1.25506.8.35.14.19.1.5) |
read-only |
INTEGER |
Path cost from the MSTI to the root bridge. |
As per the MIB. |
hh3cdot1sMstiRootPort (1.3.6.1.4.1.25506.8.35.14.19.1.6) |
read-only |
INTEGER |
Root port. |
As per the MIB. |
hh3cdot1sMstiRootType (1.3.6.1.4.1.25506.8.35.14.19.1.7) |
read-write |
INTEGER |
normal(0) secondary(1) primary(2) |
Root bridge type. |
As per the MIB. |
hh3cdot1sMstiRemainingHops (1.3.6.1.4.1.25506.8.35.14.19.1.8) |
read-only |
INTEGER |
Remaining hops. |
As per the MIB. |
hh3cdot1sMstiAdminMappedVlanListLow (1.3.6.1.4.1.25506.8.35.14.19.1.9) |
read-only |
OCTET STRING |
SIZE (0..256) |
Lower part of the VLAN ID list mapped to the instance. |
As per the MIB. |
hh3cdot1sMstiAdminMappedVlanListHigh (1.3.6.1.4.1.25506.8.35.14.19.1.10) |
read-only |
OCTET STRING |
SIZE (0..256) |
Higher part of the VLAN ID list mapped to the instance. |
As per the MIB. |
hh3cdot1sMstiOperMappedVlanListLow (1.3.6.1.4.1.25506.8.35.14.19.1.11) |
read-only |
OCTET STRING |
SIZE (0..256) |
Lower part of the effective VLAN ID list. |
As per the MIB. |
hh3cdot1sMstiOperMappedVlanListHigh (1.3.6.1.4.1.25506.8.35.14.19.1.12) |
read-only |
OCTET STRING |
SIZE (0..256) |
Higher part of the effective VLAN ID list. |
As per the MIB. |
hh3cdot1sPortTable
About this table
Use this table to configure MSTP on ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are hh3cdot1sInstanceID and hh3cdot1sMstiPortIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstiPortIndex (1.3.6.1.4.1.25506.8.35.14.20.1.1) |
read-only |
INTEGER |
(0..65535) |
Port index. |
As per the MIB. |
hh3cdot1sMstiState (1.3.6.1.4.1.25506.8.35.14.20.1.2) |
read-only |
INTEGER |
disabled(1) discarding(2) learning(4) forwarding(5) |
Port status. |
Does not support disabled. |
hh3cdot1sMstiPortPriority (1.3.6.1.4.1.25506.8.35.14.20.1.3) |
read-write |
INTEGER |
0..240 |
Port priority. |
As per the MIB. |
hh3cdot1sMstiPathCost (1.3.6.1.4.1.25506.8.35.14.20.1.4) |
read-write |
INTEGER |
1..200000000 |
Port path cost. |
As per the MIB. |
hh3cdot1sMstiDesignatedRoot (1.3.6.1.4.1.25506.8.35.14.20.1.5) |
read-only |
BridgeId |
OCTET STRING (8) |
Root bridge. |
As per the MIB. |
hh3cdot1sMstiDesignatedCost (1.3.6.1.4.1.25506.8.35.14.20.1.6) |
read-only |
INTEGER |
Path cost of the designated port. |
As per the MIB. |
hh3cdot1sMstiDesignatedBridge (1.3.6.1.4.1.25506.8.35.14.20.1.7) |
read-only |
BridgeId |
OCTET STRING (8) |
Designated bridge. |
As per the MIB. |
hh3cdot1sMstiDesignatedPort (1.3.6.1.4.1.25506.8.35.14.20.1.8) |
read-only |
OCTET STRING |
SIZE (2) |
Designated port. |
As per the MIB. |
hh3cdot1sMstiMasterBridgeID (1.3.6.1.4.1.25506.8.35.14.20.1.9) |
read-only |
BridgeId |
OCTET STRING (8) |
Master bridge. |
As per the MIB. |
hh3cdot1sMstiMasterPortCost (1.3.6.1.4.1.25506.8.35.14.20.1.10) |
read-only |
INTEGER |
Path cost to the master bridge. |
As per the MIB. |
hh3cdot1sMstiStpPortEdgeport (1.3.6.1.4.1.25506.8.35.14.20.1.11) |
read-write |
EnabledStatus |
Whether the port is an edge port. |
As per the MIB. |
hh3cdot1sMstiStpPortPointToPoint (1.3.6.1.4.1.25506.8.35.14.20.1.12) |
read-write |
INTEGER |
forceTrue(1) forceFalse(2) auto(3) |
Whether to set the port link type to point-to-point. |
As per the MIB. |
hh3cdot1sMstiStpMcheck (1.3.6.1.4.1.25506.8.35.14.20.1.13) |
read-write |
INTEGER |
Perform mCheck. |
As per the MIB. |
hh3cdot1sMstiStpTransLimit (1.3.6.1.4.1.25506.8.35.14.20.1.14) |
read-write |
INTEGER |
1..255 |
BPDU transmission rate. |
Default: 10. |
hh3cdot1sMstiStpRXStpBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.15) |
read-only |
Counter32 |
Incoming BPDU count. |
As per the MIB. |
hh3cdot1sMstiStpTXStpBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.16) |
read-only |
Counter32 |
Outgoing BPDU count. |
As per the MIB. |
hh3cdot1sMstiStpRXTCNBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.17) |
read-only |
Counter32 |
Incoming TCN BPDU count. |
As per the MIB. |
hh3cdot1sMstiStpTXTCNBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.18) |
read-only |
Counter32 |
Outgoing TCN BPDU count. |
As per the MIB. |
hh3cdot1sMstiStpRXRSTPBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.19) |
read-only |
Counter32 |
Incoming RSTP BPDU count. |
As per the MIB. |
hh3cdot1sMstiStpTXRSTPBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.20) |
read-only |
Counter32 |
Outgoing RSTP BPDU count. |
As per the MIB. |
hh3cdot1sMstiStpRXMSTPBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.21) |
read-only |
Counter32 |
Incoming MSTP BPDU count. |
As per the MIB. |
hh3cdot1sMstiStpTXMSTPBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.22) |
read-only |
Counter32 |
Outgoing MSTP BPDU count. |
As per the MIB. |
hh3cdot1sMstiStpClearStatistics (1.3.6.1.4.1.25506.8.35.14.20.1.23) |
read-write |
INTEGER |
clear(1) unused(65535) |
Clear packet statistics. |
As per the MIB. |
hh3cdot1sMstiStpDefaultPortCost (1.3.6.1.4.1.25506.8.35.14.20.1.24) |
read-write |
INTEGER |
Default port path cost. |
As per the MIB. |
hh3cdot1sMstiStpStatus (1.3.6.1.4.1.25506.8.35.14.20.1.25) |
read-write |
EnabledStatus |
Spanning tree feature status. |
As per the MIB. |
hh3cdot1sMstiPortRootGuard (1.3.6.1.4.1.25506.8.35.14.20.1.26) |
read-write |
EnabledStatus |
Root guard status. |
As per the MIB. |
hh3cdot1sMstiPortLoopGuard (1.3.6.1.4.1.25506.8.35.14.20.1.27) |
read-write |
EnabledStatus |
Loop guard status. |
As per the MIB. |
hh3cdot1sMstiStpPortSendingBPDUType (1.3.6.1.4.1.25506.8.35.14.20.1.28) |
read-only |
INTEGER |
stp(1) rstp(2) mstp(3) |
BPDU type. |
As per the MIB. |
hh3cdot1sMstiStpOperPortPointToPoint (1.3.6.1.4.1.25506.8.35.14.20.1.29) |
read-only |
TruthValue |
true(1) false(2) |
Whether the port link type is point-to-point. |
As per the MIB. |
hh3cdot1sMstiStpPortAdminBPDUFmt (1.3.6.1.4.1.25506.8.35.14.20.1.30) |
read-write |
Hh3cdot1sFormatStatus |
legacy(1) dot1s(2) auto(3) |
Set the mode used by the port to recognize and send MSTP BPDUs. |
· legacy—The port receives and sends only compatible-format MSTP BPDUs. · dot1s—The port receives and sends only standard-format (802.1s-compliant) MSTP BPDUs. · auto—The port recognizes the MSTP BPDU format automatically and determines the format of MSTP BPDUs to send accordingly. This mode takes effect only on the CIST. |
hh3cdot1sMstiStpPortOperBPDUFmt (1.3.6.1.4.1.25506.8.35.14.20.1.31) |
read-only |
Read the mode used by the port to send MSTP BPDUs. |
· legacy—The port sends only compatible-format MSTP BPDUs. · dot1s—The port sends only standard-format (802.1s-compliant) MSTP BPDUs. · auto—The port recognizes the MSTP BPDU format automatically and determines the format of MSTP BPDUs to send accordingly. This mode takes effect only on the CIST. |
hh3cdot1sMstiStpPortRoleRestriction(1.3.6.1.4.1.25506.8.35.14.20.1.32) |
read-write |
EnabledStatus |
Port role restriction status. |
As per the MIB. |
hh3cdot1sMstiStpPortTcRestriction(1.3.6.1.4.1.25506.8.35.14.20.1.33) |
read-write |
EnabledStatus |
TC-BPDU transmission restriction status. |
As per the MIB. |
hh3cdot1sMstiStpPortDisputed(1.3.6.1.4.1.25506.8.35.14.20.1.34) |
read-only |
TruthValue |
true(1) false(2) |
Dispute guard status. |
As per the MIB. |
Notifications
hh3cPortMstiStateForwarding
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.1 |
A port transits to the forwarding state. |
Informational |
Warning |
OFF |
This notification is generated when a port transits to the forwarding state.
Status control
ON
CLI: Use the stp port-log command.
OFF
CLI: Use the undo stp port-log command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.8.35.14.19.1.1 (hh3cdot1sInstanceID) |
Instance ID. |
Yes |
INTEGER |
0..4094 |
1.3.6.1.4.1.25506.8.35.14.20.1.1 (hh3cdot1sMstiPortIndex) |
Port index. |
Yes |
INTEGER |
1..65535 |
Recommended action
Check for link failures after the network topology becomes stable.
hh3cPortMstiStateDiscarding
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.2 |
A port transits to the discarding state. |
Informational |
Warning |
OFF |
This notification is generated when a port transits to the discarding state.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Instance ID. |
Yes |
INTEGER |
0..4094 |
Port index. |
Yes |
INTEGER |
1..65535 |
Recommended action
hh3cBridgeLostRootPrimary
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.3 |
The device loses its root bridge role after another device is elected as root bridge. |
Informational |
Warning |
ON |
This table does not contain indexes. For information about the index or indexes of a MIB object instance, see the section for that MIB object.
This notification is generated when the device loses its root bridge role after another device is elected as root bridge.
Status control
This notification cannot be disabled.
Objects
OID (object name) |
Index |
Type |
Value range |
Instance ID. |
No |
INTEGER |
0..4094 |
Recommended action
· Verify the bridge priorities of the devices.
· Check for possible attacks from other devices.
hh3cPortMstiRootGuarded
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.4 |
A root guard-enabled port receives a configuration BPDU with a higher priority. |
Informational |
Warning |
OFF |
This notification is generated when a root guard-enabled port receives a configuration BPDU with a higher priority.
Status control
ON
CLI: Use the stp root-protection command.
MIB: Set hh3cdot1sMstiPortRootGuard to true(1).
OFF
MIB: Set hh3cdot1sMstiPortRootGuard to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
Instance ID. |
Yes |
INTEGER |
0..4094 |
Port index. |
Yes |
INTEGER |
1..65535 |
Recommended action
hh3cPortMstiBpduGuarded
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.5 |
A BPDU guard-enabled edge port receives configuration BPDUs. |
Informational |
Warning |
OFF |
This notification is generated when a BPDU guard-enabled edge port receives configuration BPDUs.
Status control
ON
CLI: Use the stp bpdu-protection command.
MIB: Set hh3cdot1sMstBpduGuard to true(1).
OFF
MIB: Set hh3cdot1sMstBpduGuard to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.17.2.15.1.1 (dot1dStpPort) |
Port index. |
Yes |
INTEGER |
1..65535 |
Recommended action
· Verify that the downstream device is an endpoint device.
hh3cPortMstiLoopGuarded
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.6 |
An alternate port or root port does not receive a BPDU upon BPDU reception timeout. |
Informational |
Warning |
OFF |
This notification is generated when an alternate port or root port does not receive a BPDU upon BPDU reception timeout.
Status control
ON
CLI: Use the stp loop-protection command.
MIB: Set hh3cdot1sMstiPortLoopGuard to true(1).
OFF
MIB: Set hh3cdot1sMstiPortLoopGuard to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
Instance ID. |
Yes |
INTEGER |
0..4094 |
Port index. |
Yes |
INTEGER |
1..65535 |
Recommended action
· Verify that the spanning tree status of the upstream device is correct.
hh3cMstiNewRoot
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.7 |
A new root bridge is elected. |
Informational |
Warning |
OFF |
This notification is generated when a new root bridge is elected in the network.
Status control
ON
CLI: Use the snmp trap enable stp new-root command.
OFF
CLI: Use the undo snmp trap enable stp new-root command.
Objects
OID |
Index |
Type |
Value range |
Instance ID. |
Yes |
INTEGER |
0..4094 |
1.3.6.1.4.1.25506.8.35.14.19.1.4 (hh3cdot1sMstiDesignedRoot) |
Root bridge information. |
No |
BridgeId |
No |
BridgeId |
Recommended action
hh3cMstiProTcGuarded
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.12 |
The number of TC-BPDUs received by the device exceeds the upper threshold. |
Informational |
Warning |
ON |
This notification is generated when the number of TC-BPDUs received by the device exceeds the upper threshold.
Status control
ON
CLI: Use the stp tc-protection command.
OFF
CLI: Use the undo stp tc-protection command.
Objects
OID |
Index |
Type |
Value range |
Instance ID. |
No |
INTEGER |
0..4094 |
1.3.6.1.4.1.25506.8.35.14.22.1 (hh3cMstiTcGuardVal) |
Upper threshold |
No |
Integer32 |
Integer32 (1..255) |
Recommended action
Check the STP function of upstream devices and identify whether attacks occur on other devices in the network.
