- 04-Layer 2 - LAN Switching
- 01-IEEE8021-CFM-MIB
- 02-IEEE8023-LAG-MIB
- 03-LLDP-EXT-DOT1-MIB
- 04-LLDP-EXT-DOT1-V2-MIB
- 05-LLDP-EXT-DOT3-MIB
- 06-LLDP-EXT-DOT3-V2-MIB
- 07-LLDP-EXT-MED-MIB
- 08-LLDP-MIB
- 09-LLDP-V2-MIB
- 10-MAU-MIB
- 11-P-BRIDGE-MIB
- 12-Q-BRIDGE-MIB
- 13-BRIDGE-MIB
- 14-EtherLike-MIB
- 15-HH3C-LAG-MIB
- 16-HH3C-LLDP-EXT-MIB
- 17-HH3C-LPBKDT-MIB
- 18-HH3C-LswMAM-MIB
- 19-HH3C-LswMSTP-MIB
- 20-HH3C-LswVLAN-MIB
- 21-HH3C-MAC-INFORMATION-MIB
- 22-HH3C-MLAG-MIB
- 23-HH3C-PVST-MIB
- 24-HH3C-QINQV2-MIB
- 25-HH3C-VLANTERM-MIB
- 26-HH3C-VMAP-MIB
| 12-Q-BRIDGE-MIB | 95.48 KB |
Q-BRIDGE-MIB
About this MIB
Use this MIB to manage Virtual Bridged Local Area Networks, as defined by IEEE 802.1Q-2003.
MIB file name
rfc4363-qbridge.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).dot1dBridge(17).qBridgeMIB(7)
dot1qVlanVersionNumber
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qVlanVersionNumber (1.3.6.1.2.1.17.7.1.1.1) |
read-only |
INTEGER |
version1(1) |
The version number of IEEE 802.1Q that this device supports. |
As per the MIB. |
dot1qMaxVlanId
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qMaxVlanId (1.3.6.1.2.1.17.7.1.1.2) |
read-only |
VlanId |
Standard MIB values. |
The maximum IEEE 802.1Q VLAN ID that this device supports. |
As per the MIB. |
dot1qMaxSupportedVlans
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qMaxSupportedVlans (1.3.6.1.2.1.17.7.1.1.3) |
read-only |
Unsigned32 |
The maximum number of IEEE 802.1Q VLANs that this device supports. |
As per the MIB. |
dot1qNumVlans
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qNumVlans (1.3.6.1.2.1.17.7.1.1.4) |
read-only |
Unsigned32 |
The current number of IEEE 802.1Q VLANs that are configured in this device. |
As per the MIB. |
dot1qGvrpStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qGvrpStatus (1.3.6.1.2.1.17.7.1.1.5) |
read-write |
EnabledStatus |
enabled(1) disabled(2) |
The administrative status requested by management for GVRP: · enable(1)—GVRP should be enabled on this device, on all ports for which it has not been specifically disabled. · disable(2)—GVRP is disabled on all ports. |
Not supported |
Tabular objects
dot1qFdbTable
About this table
Use this table to display configuration and control information for each filtering database currently operating on this device.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is dot1qFdbId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qFdbId (1.3.6.1.2.1.17.7.1.2.1.1.1) |
not-accessible |
Unsigned32 |
The identity of this filtering database. |
As per the MIB. |
dot1qFdbDynamicCount (1.3.6.1.2.1.17.7.1.2.1.1.2) |
read-only |
Counter32 |
The current number of dynamic entries in this filtering database. |
As per the MIB. |
dot1qTpFdbTable
About this table
Use this table to display information about unicast entries for which the device has forwarding and/or filtering information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are dot1qFdbId and dot1qTpFdbAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qTpFdbAddress (1.3.6.1.2.1.17.7.1.2.2.1.1) |
not-accessible |
MacAddress |
A unicast MAC address for which the device has forwarding and/or filtering information. |
As per the MIB. |
dot1qTpFdbPort (1.3.6.1.2.1.17.7.1.2.2.1.2) |
read-only |
Integer32 |
Integer32 (0..65535) |
The port number of the port on which a frame having a source address equal to the value of the corresponding instance of dot1qTpFdbAddress has been seen. A value of 0 indicates that the port number has not been learned but that the device does have some forwarding/filtering information about this address. |
As per the MIB. |
dot1qTpFdbStatus (1.3.6.1.2.1.17.7.1.2.2.1.3) |
read-only |
INTEGER |
other(1) invalid(2) learned(3) self(4) mgmt(5) |
The status of this entry. |
Manually added dynamic MAC address entries are counted as learned MAC address entries. |
dot1qTpGroupTable
About this table
Use this table to obtain filtering information for VLANs configured into the bridge by (local or network) management, or learned dynamically.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are dot1qVlanIndex and dot1qTpGroupAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qTpGroupAddress (1.3.6.1.2.1.17.7.1.2.3.1.1) |
not-accessible |
MacAddress |
The destination group MAC address in a frame to which this entry's filtering information applies. |
As per the MIB. |
dot1qTpGroupEgressPorts (1.3.6.1.2.1.17.7.1.2.3.1.2) |
read-only |
PortList |
The complete set of ports, in this VLAN, to which frames destined for this Group MAC address are currently being explicitly forwarded. |
As per the MIB. |
dot1qTpGroupLearnt (1.3.6.1.2.1.17.7.1.2.3.1.3) |
read-only |
PortList |
The subset of ports in dot1qTpGroupEgressPorts that were learned by GMRP or some other dynamic mechanism, in this filtering database. |
As per the MIB. |
dot1qVlanCurrentTable
About this table
Use this table to obtain current configuration information for each VLAN currently configured into the device.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are dot1qVlanTimeMark and dot1qVlanIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qVlanTimeMark (1.3.6.1.2.1.17.7.1.4.2.1.1) |
not-accessible |
TimeFilter |
A time filter for this entry. |
As per the MIB. |
dot1qVlanIndex (1.3.6.1.2.1.17.7.1.4.2.1.2) |
not-accessible |
VlanIndex |
The VLAN-ID or other identifier referring to this VLAN. |
As per the MIB. |
dot1qVlanFdbId (1.3.6.1.2.1.17.7.1.4.2.1.3) |
read-only |
Unsigned32 |
The filtering database used by this VLAN. |
As per the MIB. |
dot1qVlanCurrentEgressPorts (1.3.6.1.2.1.17.7.1.4.2.1.4) |
read-only |
PortList |
The set of ports that are transmitting traffic for this VLAN as either tagged or untagged frames. |
As per the MIB. |
dot1qVlanCurrentUntaggedPorts (1.3.6.1.2.1.17.7.1.4.2.1.5) |
read-only |
PortList |
The set of ports that are transmitting traffic for this VLAN as untagged frames. |
As per the MIB. |
dot1qVlanStatus (1.3.6.1.2.1.17.7.1.4.2.1.6) |
read-only |
INTEGER |
other(1) permanent(2) dynamicGvrp(3) |
Status of this VLAN. |
As per the MIB. |
dot1qVlanCreationTime (1.3.6.1.2.1.17.7.1.4.2.1.7) |
read-only |
TimeTicks |
Time when this VLAN was created. |
As per the MIB. |
dot1qVlanStaticTable
About this table
Use this table to obtain static configuration information for each VLAN configured into the device.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Not supported |
Supported |
Columns
The table index is dot1qVlanIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qVlanStaticName (1.3.6.1.2.1.17.7.1.4.3.1.1) |
read-create |
SnmpAdminString |
OCTET STRING (0..32) |
VLAN name. |
If the name string is too long or empty, a default name in the vlan VLAN ID format applies. |
dot1qVlanStaticEgressPorts (1.3.6.1.2.1.17.7.1.4.3.1.2) |
read-create |
PortList |
The set of ports that are permanently assigned to the egress list for this VLAN by management. |
As per the MIB. |
dot1qVlanForbiddenEgressPorts (1.3.6.1.2.1.17.7.1.4.3.1.3) |
read-create |
PortList |
The set of ports that are prohibited by management from being included in the egress list for this VLAN. |
Not supported |
dot1qVlanStaticUntaggedPorts (1.3.6.1.2.1.17.7.1.4.3.1.4) |
read-create |
PortList |
The set of ports that should transmit egress packets for this VLAN as untagged. |
As per the MIB. |
dot1qVlanStaticRowStatus (1.3.6.1.2.1.17.7.1.4.3.1.5) |
read-create |
RowStatus |
Supports only active(1), createAndgo(4) and destroy(6). You cannot delete the default VLAN. |
dot1qPortVlanTable
About this table
Use this table to obtain per-port control and status information for VLAN configuration in the device.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is ifIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qPvid (1.3.6.1.2.1.17.7.1.4.5.1.1) |
read-write |
VlanIndex |
The PVID, the VLAN ID assigned to untagged frames received on this port. |
Does not support the write operation on an access port. |
dot1qPortAcceptableFrameTypes (1.3.6.1.2.1.17.7.1.4.5.1.2) |
read-write |
INTEGER |
admitAll(1) admitOnlyVlanTagged(2) |
Packet types that this port can receive: · admitOnlyVlanTagged(2)—Drop untagged packets. · admitAll(1)—Accept untagged packets and assign them the PVID. |
Supports only the read operation. |
dot1qPortIngressFiltering (1.3.6.1.2.1.17.7.1.4.5.1.3) |
read-write |
TruthValue |
true(1), false(2) |
When this is true(1), the device will discard incoming frames for VLANs that do not include this port in its member set. When false(2), the port will accept all incoming frames. |
dot1qPortGvrpStatus (1.3.6.1.2.1.17.7.1.4.5.1.4) |
read-write |
EnabledStatus |
enabled(1), disabled(2) |
The state of GVRP operation on this port: · enabled(1)—GVRP is enabled. · disabled(2)—GVRP is disabled. This port drops any incoming GVRP frames. |
Not supported |
dot1qPortGvrpFailedRegistrations (1.3.6.1.2.1.17.7.1.4.5.1.5) |
read-only |
Counter32 |
The total number of failed GVRP registrations, for any reason, on this port. |
Not supported |
dot1qPortGvrpLastPduOrigin (1.3.6.1.2.1.17.7.1.4.5.1.6) |
read-only |
MacAddress |
The source MAC address of the last GVRP message received on this port. |
Not supported |
