02-Device Management
HomeSupportSwitchesS12500R SeriesReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10102-Device Management
05-HH3C-TRAP-MIB
05-HH3C-TRAP-MIB 55.44 KB
HH3C-TRAP-MIB
About this MIB
Use this MIB to enable the device to send a notification to a network management station when a specific event occurs, such as a MAC address table getting full.
MIB file name
hh3c-trap.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cTrap(38)
Scalar objects
hh3cPeriodicalTrapInterval
Object (OID)
Access
Value range
Implementation
hh3cPeriodicalTrapInterval (1.3.6.1.4.1.25506.2.38.1.6.1.1)
read-write
Integer32
Integer32 (0 | 10..3600)
Interval for sending periodical traps, in seconds.
Implementation varies by product
hh3cPeriodicalTrapSwitch
Object (OID)
Access
Value range
Implementation
hh3cPeriodicalTrapSwitch (1.3.6.1.4.1.25506.2.38.1.6.1.2)
read-write
INTEGER
enable(1), disable(2)
Status of the periodical trap sending feature.
Tabular objects
hh3cTrapDesInfoTable
About this table
Use this table to configure a trap destination host address and port number.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cTrapDesInfoIndex.
Object (OID)
Access
Value range
Implementation
hh3cTrapDesInfoIndex (1.3.6.1.4.1.25506.2.38.1.7.1.1.1)
not-accessible
Integer32
Integer32 (1..20)
Index of a trap destination information entry.
As per the MIB.
hh3cTrapDesIPAddress (1.3.6.1.4.1.25506.2.38.1.7.1.1.2)
read-create
IpAddress
Standard MIB values
Trap destination host IP address.
As per the MIB.
hh3cTrapDesPort (1.3.6.1.4.1.25506.2.38.1.7.1.1.3)
read-create
Integer32
Integer32 (0..65535)
Trap destination port number.
As per the MIB.
hh3cTrapDesRowStatus (1.3.6.1.4.1.25506.2.38.1.7.1.1.4)
read-create
RowStatus
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6)
Row status.
Supports only active(1), createAndGo(4), and destroy(6).
hh3cTrapDesAddrTAddress (1.3.6.1.4.1.25506.2.38.1.7.1.1.5)
read-create
TAddress
Standard MIB values
Transport address.
As per the MIB.
Notifications
This section contains the HH3C-TRAP-MIB notifications.
hh3cArpTabFullTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.38.1.2.4.1
ARP table full
Informational
Major
N/A
ON
This notification is generated when the ARP table gets full.
Status control
This notification cannot be disabled.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.38.1.2.3.1 (hh3cArpTabLen)
Length of the ARP table.
N
Integer32
Standard MIB values.
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
hh3cRtTabFullTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.38.1.3.5.1
Routing table full
Informational
Major
N/A
ON
This notification is generated when the routing table gets full.
Status control
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.38.1.3.4.1 (hh3cRtTabLen)
Length of the routing table.
N
Integer32
Recommended action
hh3cNdTabFullTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.38.1.5.4.1
ND table full
Informational
Major
N/A
ON
This notification is generated when the ND table gets full.
Status control
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.38.1.5.3.1 (hh3cNdTabLen)
Length of the ND table.
N
Integer32
Recommended action
hh3cPeriodicalTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.38.1.6.3.0.1
SNMP periodical trap
Informational
Warning
N/A
ON
If no trap occurs during the interval specified by hh3cPeriodicalTrapInterval, an hh3cPeriodicalTrap is generated. If the interval is set to 0, no hh3cPeriodicalTrap will be generated.
Status control
ON
MIB: Set hh3cPeriodicalTrapSwitch to enable(1).
OFF
MIB: Set hh3cPeriodicalTrapSwitch to disable(2).
Objects
N/A
Recommended action
