01-HH3C-LswDEVM-MIB | 48.97 KB |
HH3C-LswDEVM-MIB
About this MIB
Use this MIB to obtain information the resources on the device. For example, access this MIB to obtain power supply or fan information, including their number or status.
MIB file name
hh3c-splat-devm.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswdevMMib(9)
Scalar objects
hh3cdot1qTpFdbLearnStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1qTpFdbLearnStatus (1.3.6.1.4.1.25506.8.35.9.1.10) |
read-write |
INTEGER |
enabled(1), |
Enablement status of MAC address learning. |
Implementation varies by product. |
Tabular objects
hh3cdevMFanStatusTable
About this table
This table contains basic fan information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cDevMFanNum.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDevMFanNum (1.3.6.1.4.1.25506.8.35.9.1.1.1.1) |
read-only |
Integer32 |
Standard MIB values. |
Fan index. |
hh3cDevMFanStatus (1.3.6.1.4.1.25506.8.35.9.1.1.1.2) |
read-only |
INTEGER |
active(1), |
Fan status. |
hh3cDevMFanPosFrame |
read-only |
Integer32 |
ID of the chassis where the fan resides. |
Not supported |
hh3cDevMFanPosSlot |
read-only |
Integer32 |
Slot number of the fan. |
hh3cDevMFanPosIndex |
read-only |
Integer32 |
Fan number. |
hh3cdevMPowerStatusTable
About this table
This table contains basic power supply information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cDevMPowerNum.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDevMPowerNum (1.3.6.1.4.1.25506.8.35.9.1.2.1.1) |
read-only |
Integer32 |
Power supply index. |
hh3cDevMPowerStatus (1.3.6.1.4.1.25506.8.35.9.1.2.1.2) |
read-only |
INTEGER |
active(1), |
Power supply status. |
hh3cdevMSlotEnvironmentTable
About this table
This table contains environment information for a card.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cdevMSlotEnvironmentType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdevMSlotEnvironmentType (1.3.6.1.4.1.25506.8.35.9.1.3.1.1) |
not-accessible |
INTEGER |
temperature(1), |
Type of the environment elements. |
hh3cDevMSlotEnvironmentStatus (1.3.6.1.4.1.25506.8.35.9.1.3.1.2) |
read-only |
INTEGER |
normal(1), upper(2), lower(3) |
Status of the environment where the card resides. |
Not supported. |
hh3cDevMSlotEnvironmentValue (1.3.6.1.4.1.25506.8.35.9.1.3.1.3) |
read-only |
Integer32 |
Environment data for the card. |
hh3cDevMSlotEnvironmentUpperLimit (1.3.6.1.4.1.25506.8.35.9.1.3.1.4) |
read-write |
Integer32 |
Upper limit for the environment requirements. |
Not supported. |
hh3cDevMSlotEnvironmentLowerLimit (1.3.6.1.4.1.25506.8.35.9.1.3.1.5) |
read-write |
Integer32 |
Lower limit for the environment requirements. |
Not supported. |
