02-Device Management
HomeSupportSwitchesS12500R SeriesReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10102-Device Management
02-HH3C-LswTRAP-MIB
02-HH3C-LswTRAP-MIB 119.30 KB
HH3C-LswTRAP-MIB
About this MIB
This MIB contains information about notifications for state change of cards and resources on the device.
MIB file name
hh3c-splat-trap.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswTrapMib(12)
Notifications
This section contains the HH3C-LswTRAP-MIB notifications.
hh3cpowerfailure
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.8.35.12.1.1
Failure of a power supply
Error
Major
1.3.6.1.4.1.25506.8.35.12.1.2(hh3cPowerNormal)
ON
This notification is generated when a power supply fails or a new power supply is inserted into the device.
Status control
The notification cannot be disabled.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.8.35.9.1.2.1.1 (hh3cDevMPowerNum)
Power supply ID.
Y
Integer32
Standard MIB values.
1.3.6.1.4.1.25506.8.35.9.1.13 (hh3cDevMFirstTrapTime)
Timestamp of the notification.
N
TimeTicks
Recommended action
To resolve the issue:
1.     Verify that the power supply is installed correctly.
2.     If the issue persists, contact H3C Support.
hh3cPowerNormal
Basic information
OID
Event
Severity
Default status
Recovery of a power supply from a fault
Recovery
N/A
N/A
ON
This notification is generated when a power supply recovers from an abnormal state.
Status control
Objects
OID (object name)
Index
Value range
Power supply ID.
Y
Integer32
N
TimeTicks
Recommended action
No action is required.
hh3cPowerRemoved
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.5
Removal of a power supply
Error
Minor
1.3.6.1.4.1.25506.8.35.12.1.23 (hh3cPowerInserted)
ON
This notification is generated when a power supply is removed from the device.
Status control
Objects
OID (object name)
Index
Value range
Power supply ID.
Y
Integer32
Recommended action
1.     Verify that a power supply is removed from the device.
¡     If the power supply is removed from the device, no action is required.
¡     If the power supply is not removed from the device, verify that the power supply is installed correctly.
hh3cfanfailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.6
Failure of a fan tray
Error
Major
1.3.6.1.4.1.25506.8.35.12.1.7(hh3cFanNormal)
ON
This notification is generated when a fan tray fails.
Status control
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.8.35.9.1.1.1.1 (hh3cDevMFanNum)
Fan tray ID.
Y
Integer32
1.3.6.1.4.1.25506.8.35.12.2.28 (hh3cDevTrapFanFailureErrcode)
Reason for the fan tray failure.
N
INTEGER
Recommended action
1.     Verify that the fan tray is installed correctly.
hh3cFanNormal
Basic information
OID
Event
Severity
Default status
Recovery of a fan tray from a fault.
Recovery
N/A
N/A
ON
This notification is generated when a fan tray recovers from a fault.
Status control
Objects
OID (object name)
Index
Value range
Fan tray ID.
Y
Integer32
Recommended action
hh3cBoardRemoved
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.8
Removal of a card
Error
Minor
1.3.6.1.4.1.25506.8.35.12.1.9(hh3cBoardInserted)
ON
This notification is generated when a card is removed from the device.
Status control
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.8.35.18.4.2.1.1 (hh3cLswFrameIndex)
Member ID of the device.
Y
Integer32
1.3.6.1.4.1.25506.8.35.18.4.3.1.1 (hh3cLswSlotIndex)
Slot ID.
Y
Integer32
Recommended action
1.     Verify that the card is removed from the device.
¡     If the card is removed from the device, no action is required.
¡     If the card is not removed from the device, verify that the card is installed correctly.
hh3cBoardInserted
Basic information
OID
Event
Severity
Default status
Insertion of a card
Recovery
N/A
N/A
ON
This notification is generated when a card is inserted into the device.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
Recommended action
hh3cBoardFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.10
Failure or startup of a card
Error
Major
1.3.6.1.4.1.25506.8.35.12.1.11(hh3cBoardNormal)
ON
This notification is generated when a card is starting up or a fault occurs on the card.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID
Y
Integer32
Recommended action
1.     Verify that the card is installed correctly.
2.     If the issue persists after 24 hours, contact H3C Support.
hh3cBoardNormal
Basic information
OID
Event
Severity
Default status
Initialization completion of a card
Recovery
N/A
N/A
ON
This notification is generated when a card completes initialization.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
Recommended action
hh3cSubcardRemove
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.12
Removal of a subcard
Error
Minor
1.3.6.1.4.1.25506.8.35.12.1.13(hh3cSubcardInsert)
ON
This notification is generated when a subcard is removed from the device.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID
Y
Integer32
1.3.6.1.4.1.25506.8.35.18.4.4.1.1 (hh3cLswSubslotIndex)
Subslot ID
Y
Integer32
Recommended action
1.     Verify that the subcard is removed from the device.
¡     If the subcard is removed from the device, no action is required.
¡     If the subcard is not removed from the device, verify that the subcard is installed correctly.
hh3cSubcardInsert
Basic information
OID
Event
Severity
Default status
Insertion of a subcard
Recovery
N/A
N/A
ON
This notification is generated when a subcard is inserted into the device.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
Subslot ID.
Y
Integer32
Recommended action
hh3cPowerInserted
Basic information
OID
Event
Severity
Default status
Insertion of a power supply
Recovery
N/A
N/A
ON
This notification is generated when a power supply is inserted into the device.
Status control
Objects
OID (object name)
Index
Value range
Power supply ID.
Y
Integer32
Recommended action
hh3cCpuRemoved
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.25
Removal of a non-default CPU
Error
Minor
N/A
ON
This notification is generated when a non-default CPU subcard is removed from the device.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
1.3.6.1.4.1.25506.8.35.18.4.10.1.1 (hh3cLswCpuIndex)
CPU ID.
Y
Integer32
Recommended action
1.     Verify that the non-default CPU is removed from the device.
¡     If the non-default CPU is removed from the device, no action is required.
¡     If the non-default CPU is not removed from the device, verify that the non-default CPU is installed correctly.
hh3cCpuFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.26
Failure or startup of a non-default CPU
Error
Major
1.3.6.1.4.1.25506.8.35.12.1.27(hh3cCpuNormal)
ON
This notification is generated when a non-default CPU is starting up or a fault occurs on it.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
CPU ID.
Y
Integer32
Recommended action
1.     Verify that the non-default CPU is installed correctly.
hh3cCpuNormal
Basic information
OID
Event
Severity
Default status
Initialization completion of a non-default CPU
Recovery
N/A
N/A
ON
This notification is generated when a non-default CPU completes initialization.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
CPU ID.
Y
Integer32
Recommended action
hh3cPowerIncompatible
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.28
Incompatibility of a power supply with the device
Error
Major
ON
This notification is generated when a power supply is not compatible with the device.
Status control
Objects
OID (object name)
Index
Value range
Power supply ID.
Y
Integer32
Recommended action
hh3cLoadFinished
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.20
A card finished loading of the image file.
Informational
N/A
N/A
ON
This notification is generated when a card finishes loading of the image file.
Status control
This notification cannot be disabled.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.8.35.18.4.2.1.1(hh3cLswFrameIndex)
Chassis ID.
Y
Integer
Slot ID.
Y
Integer
Recommended action
hh3cBootImageUpdated
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.24
Startup software images updated.
Informational
N/A
N/A
ON
This notification is generated when the startup software images are updated.
Status control
Objects
OID (object name)
Index
Value range
Chassis ID.
Y
Integer
Slot ID.
Y
Integer
Recommended action
hh3cRequestLoading
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.18
Image loading request received.
Informational
N/A
N/A
ON
This notification is generated when the loading service end receives an image loading request.
Status control
Objects
OID (object name)
Index
Value range
Chassis ID.
Y
Integer
Slot ID.
Y
Integer
Recommended action
