02-Device Management
HomeSupportSwitchesS12500R SeriesReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10102-Device Management
04-HH3C-TRANSCEIVER-INFO-MIB
04-HH3C-TRANSCEIVER-INFO-MIB 100.39 KB
About this MIB
Use this MIB to obtain information about transceiver modules, including vendor information and physical transmission characteristics.
MIB file name
hh3c-transceiver-info.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cTransceiver(70)
Tabular objects
hh3cTransceiverInfoTable
About this table
Use this table to obtain information about transceiver modules.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cTransceiverHardwareType (1.3.6.1.4.1.25506.2.70.1.1.1.1)
read-only
OCTET STRING
Standard MIB values.
Hardware type of the transceiver module, such as single mode (SM).
As per the MIB.
hh3cTransceiverType (1.3.6.1.4.1.25506.2.70.1.1.1.2)
read-only
OCTET STRING
Type of the transceiver module, such as SFP.
As per the MIB.
hh3cTransceiverWaveLength (1.3.6.1.4.1.25506.2.70.1.1.1.3)
read-only
Integer32
Wavelength of the transceiver module, in nm.
As per the MIB.
hh3cTransceiverVendorName (1.3.6.1.4.1.25506.2.70.1.1.1.4)
read-only
OCTET STRING
Vendor name of the transceiver module.
As per the MIB.
hh3cTransceiverSerialNumber (1.3.6.1.4.1.25506.2.70.1.1.1.5)
read-only
OCTET STRING
Serial number of the transceiver module.
As per the MIB.
hh3cTransceiverFiberDiameterType (1.3.6.1.4.1.25506.2.70.1.1.1.6)
read-only
INTEGER
fiber9(1),
fiber50(2),
fiber625(3),
copper(4),
unknown(65535)
Fiber diameter for the transceiver module, in microns (μm).
As per the MIB.
hh3cTransceiverTransferDistance (1.3.6.1.4.1.25506.2.70.1.1.1.7)
read-only
Integer32
Maximum transmission distance of the transceiver module, in meters.
As per the MIB.
hh3cTransceiverDiagnostic (1.3.6.1.4.1.25506.2.70.1.1.1.8)
read-only
TruthValue
true(1),
false(2)
Whether the transceiver module supports digital diagnosis.
As per the MIB.
hh3cTransceiverCurTXPower (1.3.6.1.4.1.25506.2.70.1.1.1.9)
read-only
Integer32
Current transmit power of the transceiver module, in dBm, accurate to 0.01 dBm.
The object returns 2147483647 when read if the device does not support this parameter.
hh3cTransceiverMaxTXPower (1.3.6.1.4.1.25506.2.70.1.1.1.10)
read-only
Integer32
Maximum transmit power of the transceiver module, in dBm, accurate to 0.01 dBm.
hh3cTransceiverMinTXPower (1.3.6.1.4.1.25506.2.70.1.1.1.11)
read-only
Integer32
Minimum transmit power of the transceiver module, in dBm, accurate to 0.01 dBm.
hh3cTransceiverCurRXPower (1.3.6.1.4.1.25506.2.70.1.1.1.12)
read-only
Integer32
Current receive power in dBm of the transceiver module, accurate to 0.01 dBm.
hh3cTransceiverMaxRXPower (1.3.6.1.4.1.25506.2.70.1.1.1.13)
read-only
Integer32
Maximum receive power of the transceiver module, in dBm, accurate to 0.01 dBm.
hh3cTransceiverMinRXPower (1.3.6.1.4.1.25506.2.70.1.1.1.14)
read-only
Integer32
Minimum receive power of the transceiver module, in dBm, accurate to 0.01 dBm.
hh3cTransceiverTemperature (1.3.6.1.4.1.25506.2.70.1.1.1.15)
read-only
Integer32
Current temperature of the transceiver module, in °C.
As per the MIB.
hh3cTransceiverVoltage (1.3.6.1.4.1.25506.2.70.1.1.1.16)
read-only
Integer32
Current voltage of the transceiver module, in V, accurate to 0.01 V.
As per the MIB.
hh3cTransceiverBiasCurrent (1.3.6.1.4.1.25506.2.70.1.1.1.17)
read-only
Integer32
Current bias current of the transceiver module, in mA, accurate to 0.01 mA.
As per the MIB.
hh3cTransceiverTempHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.18)
read-only
Integer32
High temperature alarm threshold in °C, accurate to 0.001 °C , for example, 49120 representing 49.120 °C
As per the MIB.
hh3cTransceiverTempLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.19)
read-only
Integer32
Low temperature alarm threshold in °C, accurate to 0.001 °C
As per the MIB.
hh3cTransceiverTempHiWarn (1.3.6.1.4.1.25506.2.70.1.1.1.20)
read-only
Integer32
High temperature warning threshold in °C, accurate to 0.001 °C
As per the MIB.
hh3cTransceiverTempLoWarn (1.3.6.1.4.1.25506.2.70.1.1.1.21)
read-only
Integer32
Low temperature warning threshold in °C, accurate to 0.001 °C
As per the MIB.
hh3cTransceiverVccHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.22)
read-only
Integer32
High voltage alarm threshold in µV, accurate to 0.01 µV.
As per the MIB.
This object returns 0 when read if the transceiver module does not support this parameter.
hh3cTransceiverVccLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.23)
read-only
Integer32
Low voltage alarm threshold in µV, accurate to 0.01 µV.
As per the MIB.
hh3cTransceiverVccHiWarn (1.3.6.1.4.1.25506.2.70.1.1.1.24)
read-only
Integer32
High voltage warning threshold in µV, accurate to 0.01 µV.
As per the MIB.
hh3cTransceiverVccLoWarn (1.3.6.1.4.1.25506.2.70.1.1.1.25)
read-only
Integer32
Low voltage warning threshold in mV, accurate to 0.01 µV.
As per the MIB.
hh3cTransceiverBiasHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.26)
read-only
Integer32
High bias current alarm threshold in µA.
As per the MIB.
hh3cTransceiverBiasLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.27)
read-only
Integer32
Low bias current alarm threshold in µA.
As per the MIB.
hh3cTransceiverBiasHiWarn (1.3.6.1.4.1.25506.2.70.1.1.1.28)
read-only
Integer32
High bias current warning threshold in µA.
As per the MIB.
hh3cTransceiverBiasLoWarn (1.3.6.1.4.1.25506.2.70.1.1.1.29)
read-only
Integer32
Low bias current warning threshold in µA.
As per the MIB.
hh3cTransceiverPwrOutHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.30)
read-only
Integer32
High transmit power alarm threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverPwrOutLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.31)
read-only
Integer32
Low transmit power alarm threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverPwrOutHiWarn (1.3.6.1.4.1.25506.2.70.1.1.1.32)
read-only
Integer32
High transmit power warning threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverPwrOutLoWarn (1.3.6.1.4.1.25506.2.70.1.1.1.33)
read-only
Integer32
Low transmit power warning threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverRcvPwrHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.34)
read-only
Integer32
High receive power alarm threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverRcvPwrLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.35)
read-only
Integer32
Low receive power alarm threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverRcvPwrHiWarn (1.3.6.1.4.1.25506.2.70.1.1.1.36)
read-only
Integer32
High receive power warning threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverRcvPwrLoWarn (1.3.6.1.4.1.25506.2.70.1.1.1.37)
read-only
Integer32
Low receive power warning threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverErrors (1.3.6.1.4.1.25506.2.70.1.1.1.38)
read-only
BITS
BITS {
xcvrIOError(0),
xcvrChecksum(1),
xcvrTypeAndPortConfigMismatch(2),
xcvrTypeNotSupported(3),
wisLocalFault(4),
rcvOpticalPowerFault(5),
pmapmdReceiverLocalFault(6),
pcsReceiveLocalFault(7),
phyXSReceiveLocalFault(8),
laserBiasCurrentFault(9),
laserTemperatureFault(10),
laserOutputPowerFault(11),
txFault(12),
pmapmdTransmitterLocalFault(13),
pcsTransmitLocalFault(14),
phyXSTransmitLocalFault(15),
rxLossOfSignal(16),
tecError(17),
wavelengthUnlocked(18),
txIsNotReadyDueToTuning(19) ,
Unused(20-31)
Error information about the transceiver module.
As per the MIB.
hh3cTransceiverVendorOUI (1.3.6.1.4.1.25506.2.70.1.1.1.39)
read-only
SnmpAdminString
OCTET STRING (0..255)
Vendor OUI of the transceiver module.
As per the MIB.
hh3cTransceiverRevisionNumber (1.3.6.1.4.1.25506.2.70.1.1.1.40)
read-only
SnmpAdminString
Revision number of the transceiver module.
As per the MIB.
hh3cTransceiverFrequency (1.3.6.1.4.1.25506.2.70.1.1.1.41)
read-only
Integer32
Frequency of the current ITU channel on the transceiver module, in THz, accurate to 0.01 THz.
As per the MIB.
hh3cTransceiverActiveITUChannel (1.3.6.1.4.1.25506.2.70.1.1.1.42)
read-write
Unsigned32
Unsigned32 (1.. 4294967295)
Index of the current ITU channel on the transceiver module.
As per the MIB.
hh3cTransceiverCurWaveErr (1.3.6.1.4.1.25506.2.70.1.1.1.43)
read-only
Integer32
Wavelength offset of the current ITU channel on the transceiver module, in nm, accurate to 0.001 nm.
As per the MIB.
hh3cTransceiverWaveErrHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.44)
read-only
Integer32
High wavelength offset alarm threshold for the current ITU channel on the transceiver module, in nm, accurate to 0.001 nm.
As per the MIB.
hh3cTransceiverWaveErrLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.45)
read-only
Integer32
Low wavelength offset alarm threshold for the current ITU channel on the transceiver module, in nm, accurate to 0.001 nm.
As per the MIB.
hh3cTransceiverCurFreqErr (1.3.6.1.4.1.25506.2.70.1.1.1.46)
read-only
Integer32
Frequency offset of the current ITU channel on the transceiver module, in GHz, accurate to 0.1 GHz.
As per the MIB.
hh3cTransceiverFreqErrHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.47)
read-only
Integer32
High frequency offset alarm threshold for the current ITU channel on the transceiver module, in GHz, accurate to 0.1 GHz.
As per the MIB.
hh3cTransceiverFreqErrLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.48)
read-only
Integer32
Low frequency offset alarm threshold for the current ITU channel on the transceiver module, in GHz, accurate to 0.1 GHz.
As per the MIB.
hh3cTransceiverChannelTable
About this table
Use this table to obtain statistics about channels of a transceiver module.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ifIndex and hh3cTransceiverChannelIndex.
Object (OID)
Access
Value range
Implementation
hh3cTransceiverChannelIndex (1.3.6.1.4.1.25506.2.70.1.2.1.1)
not-accessible
Integer32
Integer32 (1..2147483647)
Transceiver module channel index.
As per the MIB.
hh3cTransceiverChannelCurTXPower (1.3.6.1.4.1.25506.2.70.1.2.1.2)
read-only
Integer32
Current transmit power in dBm, accurate to 0.01 dBm.
This object returns 2147483647 when read if this parameter is not supported.
hh3cTransceiverChannelCurRXPower (1.3.6.1.4.1.25506.2.70.1.2.1.3)
read-only
Integer32
Current receiver power in dBm, accurate to 0.01 dBm.
hh3cTransceiverChannelTemperature (1.3.6.1.4.1.25506.2.70.1.2.1.4)
read-only
Integer32
Current temperature in °C.
hh3cTransceiverChannelBiasCurrent (1.3.6.1.4.1.25506.2.70.1.2.1.5)
read-only
Integer32
Current bias current in mA, accurate to 0.01 mA.
hh3cTransceiverChannelBiasHiAm
(1.3.6.1.4.1.25506.2.70.1.2.1.6)
read-only
Integer32
As per the MIB.
hh3cTransceiverChannelBiasLoAm
(1.3.6.1.4.1.25506.2.70.1.2.1.7)
read-only
Integer32
As per the MIB.
hh3cTransceiverChannelTXPwrHiAm
(1.3.6.1.4.1.25506.2.70.1.2.1.8)
read-only
Integer32
High transmit power alarm threshold in dBm, accurate to 0.01 dBm.
As per the MIB.
hh3cTransceiverChannelTXPwrLoAm
(1.3.6.1.4.1.25506.2.70.1.2.1.9)
read-only
Integer32
Low transmit power alarm threshold in dBm, accurate to 0.01 dBm.
As per the MIB.
hh3cTransceiverITUChanTable
About this table
Use this table to obtain information about ITU channels supported on the transceiver module on an interface.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ifIndex and hh3cTransceiverITUChanIdx.
Object (OID)
Access
Value range
Implementation
hh3cTransceiverITUChanIdx (1.3.6.1.4.1.25506.2.70.1.3.1.1)
not-accessible
Unsigned32
Index of an ITU channel on the transceiver module.
As per the MIB.
hh3cTransceiverITUChanFreq (1.3.6.1.4.1.25506.2.70.1.3.1.2)
read-only
Integer32
Frequency of the ITU channel, in THz, accurate to 0.01 THz.
As per the MIB.
hh3cTransceiverITUChanWaveLth (1.3.6.1.4.1.25506.2.70.1.3.1.3)
read-only
Integer32
Wavelength of the ITU channel, in pm.
As per the MIB.
