- H3C Wi-Fi7 Indoor Access Points Installation Guide-5W101
- 01-Installing the device
- 02-Logging in to the device
- 03-Appendix A AP views and technical specifications
- 04-Appendix B LEDs and buttons
- 05-Appendix C Optional transceiver modules
- 06-Appendix D Connecting the hybrid copper-fiber cable
- 07-Appendix E Cabling recommendations
| 05-Appendix C Optional transceiver modules | 188.50 KB |
5 Appendix C Optional transceiver modules
Transceiver module, fiber connector, and fiber view
PoE optical transceiver module
Common transceiver module
You must use an SFP transceiver module and optical fiber with an LC connector to connect the fiber port on the AP.
Figure5-1 SFP transceiver module
Figure5-2 Optical fibers with LC connectors
(1) LC connector |
(2) Optical fiber |
Technical specifications
Table5-1 SFP-XG-CPRI-IR-SM1310 transceiver module specifications
Item |
SFP-XG-CPRI-IR-SM1310 |
Central wavelength |
1310 nm |
Max transmission distance |
1.4 km (0.87 miles) |
Data rate |
4920 to 10310 Mbps |
Connector type |
LC connector |
Fiber mode |
SMF |
Fiber diameter |
9/125 μm |
Output power |
–8.2 to +0.5 dBm |
Table5-2 SFP-2.5G-LX10-SM1310-DR-I transceiver module specifications
Item |
SFP-2.5G-LX10-SM1310-DR-I |
1310 nm |
10 km (6.21 miles) |
Data rate |
1228.8 to 2457.6 Mbps |
Connector type |
LC connector |
Fiber mode |
SMF |
Fiber diameter |
9/125 μm |
Output power |
–7 to +2 dBm |
PoE optical transceiver module and fiber PoE patch cord
Insert PoE optical transceiver modules only into the photoelectric hybrid ports (PSFP or PSFP+ ports). To connect the photoelectric hybrid ports, use hybrid copper-fiber cables with fiber PoE patch cords.
Figure5-3 PoE optical transceiver module
Figure5-4 Hybrid copper-fiber cable with fiber PoE patch cord
(1) Fiber PoE patch cord |
(2) Hybrid copper-fiber cable |
Table5-3 H3C-LS5M1SFPPOE-SFP GE PoE optical transceiver module specifications
Item |
H3C-LS5M1SFPPOE-SFP |
1310 nm |
Data rate |
1.25 Gbps |
Connector type |
LC connector |
Max power consumption |
1.0 W |
Operating temperature |
–40ºC to +85ºC (–40°F to +185°F) |
Output power |
–9 to –1 dBm |
Table5-4 H3C-LS5M1SFPPOEA-SFP 10-GE multirate PoE optical transceiver module specifications
Item |
H3C--LS5M1SFPPOEA-SFP |
1310 nm |
Data rate |
10.3125 Gbps |
Connector type |
LC connector |
1.2 W |
Output power |
–8.2 to +0.5 dBm |
